05B104K500PF3C1N0R
05B104K500PF3C1N0R
    STE(松田)
    CAP_4.2X3.8MM_TM
    陶瓷电容/独石电容 CAP_4.2X3.8MM_TM 100nF ±10% 50V X7R
05B104K500PF3C1N0R 数据手册
Leaded MLCC for General Purpose Leaded MLCC for General Purpose Data Sheet Feature ■Small size and large capacitance ■Low ESR characteristics for high frequency ■Meet LF (Lead Free) and HF (Halogen Free) ■Epoxy resin coating Applications ■General electronic equipment Revision: 2019-07-30 1 Email: info@songtian.cn Website: http://www.songtian-ste.com Leaded MLCC for General Purpose Part Number Code 05 B Dimensions 05:0805 06:1206 10:1210 12:1812 25:2225 103 K Capacitance 4R7:4.7pF 220:22pF 471:470pF 472:4700pF 104:0.1uF 105:1.0uF Temperature Characteristic N: NP0 C: COG B: X7R Y: Y5V 500 B C1 Pitch F1:2.54mm F2:4.75mm F3:5.08mm F4:7.5mm F5:3.5mm Rated Voltage 160:16V 250:25V 101:100V 251:250V Capacitance Tolerance C: ±0.25pF D: ±0.5pF F: ±1.0pF G: ±2% J: ±5% K: ±10% M: ±20% F3 Packaging B: Bulk T: Tape & Reel packaging P: Ammo Packaging A5 R Environmental Standard R: RoHS F:RoHS+Halogen-Free Lead Lenght A5: 3.5mm N0:16.5±0.5mm (C1/C2 For Taping) Q0: 20.0±0.5mm(B1 For Taping) Lead Style B1: Straight Long C1: Outside Crimp C2: Inside Crimp Revision: 2019-07-30 2 Email: info@songtian.cn Website: http://www.songtian-ste.com Leaded MLCC for General Purpose Specifications Reference Standard GB/T 5966 Operating Temperature Range -55~125℃ Class 1: C≤1000pF,1MHZ±10%,1.0V C>1000pF,1KHZ±10%,1.0V CR≥50PF,DF≤0.15% CR0.1uF ) DF≤15% ( CR≥1uF) 25V、50V、100V、250V Capacitance(C) and Dissipation Factor(tg δ) Rated Voltage Withstand Voltage Insulation Resistance Temperature Characteristic Class1 300% Withstand Voltage Class2 250% Withstand Voltage The charge/discharge current is less than 50mA Rated Voltage,60±5sec Class1:C≤10nF,IR≥10000MΩ C>10nF,IR≥100MΩ.uF Class2:C≤25nF,IR≥4000MΩ C>25nF,IR≥100MΩ.uF COG(NP0)、X7R、Y5V Dimension、Voltage and Capacitance Revision: 2019-07-30 3 Email: info@songtian.cn Website: http://www.songtian-ste.com Leaded MLCC for General Purpose Dimensions (Unit: mm) Dimension F ±0.5 H ±1 L max W max T max Фd ±0.05 0805 2.54 5.08 5.08 10 5.0/ 10.0 5 4.2 3.8 3.8 0.45 0.50 1206 3.50 5.08 3.8 0.45 0.50 1210/1209 1812 2225 3.50 5.08 4.57 5.50 Revision: 2019-07-30 10 10 10 10 5.5 5.5 8.5 10.5 4.5 5.5 6.5 9.5 0.45 0.50 3.8 0.45 0.50 3.8 0.45 0.50 4.2 4 Rated voltage Available Capacitance Range N B Y COG(NPO) X7R Y5V 25V 50V 100V 0R5-272 0R5-222 05R-102 101-105 101-105 101-104 102-125 102-105 --- 25V 0R5-562 101-225 102-125 50V 0R5-472 101-105 102-105 100V 0R5-332 101-154 --- 25V 100-103 471-105 472-155 50V 100-103 471-105 472-205 100V 5R0-103 101-105 --- 25V 100-153 471-335 103-335 50V 100-103 471-225 103-225 100V 5R0-103 101-105 --- 25V 100-473 102-475 103-475 50V 100-273 102-335 103-335 100V 5R0-273 101-105 --- Email: info@songtian.cn Website: http://www.songtian-ste.com Leaded MLCC for General Purpose Taping And Dimensions (mm) Note: P1=3.85mm for F=5.08mm; P1=5.1mm for F=2.54mm Code P P0 Dim 12.7 12.7 TOL 士 1.0 士 0.2 Revision: 2019-07-30 P1 3.85 5.1 士 0.7 P2 Φd △h W W0 6.35 0.5 0 18.5 士 1.3 士 0.1 士 1.0 士 1.0 8 10 士 1.0 5 W1 W2 H H0 I ΦD0 t 9 1.5 32.25 15-20 1.42 4.0 0.7 士 0.5 士 1.5 Max 士 0.5 Max 士 0.2 Max Email: info@songtian.cn Website: http://www.songtian-ste.com
05B104K500PF3C1N0R 价格&库存
很抱歉,暂时无法提供与“05B104K500PF3C1N0R”相匹配的价格&库存,您可以联系我们找货
05B104K500PF3C1N0R
  • 1+0.25740
  • 100+0.24024
  • 300+0.22308
  • 500+0.20592
  • 2000+0.19734
  • 5000+0.19219
05B104K500PF3C1N0R
库存:20729
