KH-1.27PH90-1X10P-L10.5 数据手册
SPECIFICATIONS
RECOMMEND P.C.B LAYOUT
PCB TOLERANCE:±0.05 (TOP VIEW)
Current Rating:
1.0 Amps
Withstanding Voltage: AC 500V
Insulation Resistance:1000M Min
Contact Resistance:
20 mΩ Max
Operation Temperature:-40 °to+105°
Insrlator Material:
Polyester(UL94V-0)
Contact Material:
Brass
Standard:
PA6T
Contact Plating:
Gold Flash
Max.Processing Temp: 240 °C for30-60seconds
(260 °C for5seconds)
(1) Pin Spacing: 127=1.27mm
(2) Product Name: PH=Pin Header
(3) No.of Rows: 1=Single Row;2=Dual Row
(4) No.of Pins Per Row: 1~50
(5) Insulator Material Height: 10=1.0mm;15=1.5mm
(6) Connector Type:S=Straight;R=Right Angle;M=SMT
(7) Contact Material Length: 72=7.2mm;105=10.5mm
(8) No.of Insulator Material: 1=1PCS;2=2PCS
(9) Contact Plating:G0=Gold Flash; AU15=Au 1.5u"
(10)Insulator Material Option:
A=BK-PA6T;B=BK-PA46;C=KB-LCP;S=Special
深圳市金航标电子有限公司
WWW.BDS666.COM
0755-83044319
UNLESS OTHEWIXE SPECIFIED TOLERANCE
X
:±0.3
X.X :±0.2
X.XX:±0.1
X°
:±5°
X.X° :±1°
X.XX°:±0.5°
CHECKED: LI BEI LIN
12/03/07
1.27PH
SIZE
REV
A4
A
CHECKED:
of DIM.A
1xnPin H1.0 90 ° L10.5
SCALE
PROUCT NO.
UNIT
PROJECT
APPROVED:
PAGE
1/1
No. of DIM.A
DIM.B
No. of DIM.A
DIM.B
No. of DIM.A
DIM.B
No. of DIM.A
DIM.B
KH-1.27PH90-1X10P-L10.5 价格&库存
很抱歉,暂时无法提供与“KH-1.27PH90-1X10P-L10.5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.60767
- 30+0.58672
- 100+0.54481
- 500+0.50290
- 1000+0.48195
- 国内价格
- 5+0.20302
- 50+0.16255
- 150+0.14230
- 500+0.11732
- 2500+0.10517
- 5000+0.09912
