PESDNC2XD5VBL
ESD Protector
Description
The PESDNC2XD5VBL protects sensitive semiconductor components from
damage or upset due to electrostatic discharge (ESD) and other voltage induced
transient events. They feature large cross-sectional area junctions for conducting
high transient currents, offer desirable electrical characteristics for board level
protection, such as fast response time, low operating voltage. It gives designer
the flexibility to protect one unidirectional line in applications where arrays are not
practical.
Applications
Feature
DFN0603-2L package
Cellular phones
Replacement for MLV(0201)
Portable devices
Bidirectional configurations
Digital cameras
Response time is typically < 1 ns
Power supplies
Low clamping voltage
RoHS compliant
Transient protection for data lines to IEC 61000-4-2(ESD)
±30KV(air), ±30KV(contact); IEC 61000-4-4 (EFT) 40A (5/50ns)
Mechanical Characteristics
Lead finish:100% matte Sn(Tin)
Mounting position: Any
Qualified max reflow temperature:260℃
Device meets MSL 2 requirements
Pure tin plating: 7 ~ 17 um
Pin flatness:≤3mil
Electronics Parameter
Symbol
Parameter
VRWM
Peak Reverse Working Voltage
IR
Reverse Leakage Current @ VRWM
VBR
Breakdown Voltage @ IT
IT
Test Current
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
PPP
Peak Pulse Power
CJ
Junction Capacitance
IF
Forward Current
VF
Forward Voltage @ IF
Rev.06.1
IPP
VC VBR VRWM
IT
IR
I
IR
IT
V
VRWM VBR VC
IPP
1
www.prisemi.com
ESD Protector
PESDNC2XD5VBL
Electrical characteristics per line@25℃( unless otherwise specified)
Parameter
Symbol
Conditions
VRWM
Breakdown Voltage
VBR
IR
VRWM = 5V
Clamping Voltage
VC
IPP = 1A
Clamping Voltage
VC
IPP = 5A
Cj
VR=0V
Min.
It = 1mA
Typ.
Max.
Units
5.0
V
5.6
V
T=25℃
1
μA
tP = 8/20μs
7.5
V
tP = 8/20μs
9.5
V
f = 1MHz
17.5
pF
Absolute maximum rating@25℃
Rating
Symbol
Value
Units
Operating Temperature
TJ
-55 to +150
Storage Temperature
TSTG
-55 to +150
tf=8μs
100
100
80
60
% Of Rated Power
IPP – Peak Pulse Current - % of
IPP
Typical Characteristics
tP =20μs(IPP /2)
40
60
40
10
15
t - Time -μs
25
50
75
100
125
150
TL – Lead Temperature - ℃
Fig 1.Pulse Waveform
Rev.06.1
Fig 2.Power Derating Curve
2
www.prisemi.com
ESD Protector
PESDNC2XD5VBL
7.1
6.9
12
IR(nA)
Breakdown Voltage (V) (VZ @ IZ)
7.3
6.7
8
6.5
4
6.3
-55
+25
Temperature (ºC)
Fig 3.Typical Breakdown Voltage vs. Temperature
25
50
75
Temperature (ºC)
100
125
150
Fig 4.Typical Leakage Current vs. Temperature
Pulse waveform: tp=8/20us
Peak Pulse Power (W)
VC-Clamping Voltage (V)
16
12
8
4
4
6
100
10
1
8
IPP-Peak pulse current (A)
1
1000
100
10
Pulse Duration(us)
Fig 5. Clamping voltage vs. Peak pulse current
Fig 6. Non-Repetitive Peak Pulse Power vs. Pulse
40ns/div
40ns/div
ESD clamping voltage
time
(IEC61000-4-2 +8KV contact)
Rev.06.1
(IEC61000-4-2-8KV contact)
3
www.prisemi.com
ESD Protector
PESDNC2XD5VBL
Solder Reflow Recommendation
Peak Temp=257℃, Ramp Rate=0.802deg. ℃/sec
280
240
200
160
120
80
40
60
90
120
150
180
240
210
270
300
330
360
390
420
450
480
Time (sec)
PCB Design
For TVS diodes a low-ohmic and low-inductive path to chassis earth is absolutely mandatory in order to achieve good ESD
protection. Novices in the area of ESD protection should take following suggestions to heart:
Do not use stubs, but place the cathode of the TVS diode directly on the signal trace.
Do not make false economies and save copper for the ground connection.
Place via holes to ground as close as possible to the anode of the TVS diode.
Use as many via holes as possible for the ground connection.
Keep the length of via holes in mind! The longer the more inductance they will have.
Rev.06.1
4
www.prisemi.com
ESD Protector
PESDNC2XD5VBL
Product dimension (DFN0603-2L)
D
L1
E
2
1
H2
H1
F1
E
B
L2
F2
A
Dim
Rev.06.1
5
Millimeters
MIN
Typ.
MAX
A
0.290
0.300
0.325
B
0.210
0.240
0.270
D
0.570
0.600
0.630
E
0.270
0.300
0.330
F1
0.140
0.170
0.200
F2
0.140
0.170
0.200
L1
0.015
0.030
0.045
L2
0.015
0.030
0.045
H1
0.030
0.045
0.060
H2
0.030
0.045
0.060
www.prisemi.com
ESD Protector
PESDNC2XD5VBL
C5
Device
Package
Reel
Shipping
PESDNC2XD5VBL
DFN0603-2L (Pb-Free)
7"
10000 / Tape & Reel
Rev.06.1
6
www.prisemi.com
ESD Protector
PESDNC2XD5VBL
IMPORTANT NOTICE
and
are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi
reserves the right to make changes without further notice to any products herein. Prisemi makes
no warranty, representation or guarantee regarding the suitability of its products for any particular
purpose, nor does Prisemi
assume any liability arising out of the application or use of any
product or circuit, and specifically disclaims any and all liability, including without limitation
special, consequential or incidental damages. “Typical” parameters which may be provided in
Prisemi data sheets and/or specifications can and do vary in different applications and actual
performance may vary over time. All operating parameters, including “Typicals” must be
validated for each customer application by customer’s technical experts. Prisemi does not
convey any license under its patent rights nor the rights of others. The products listed in this
document are designed to be used with ordinary electronic equipment or devices, Should you
intend to use these products with equipment or devices which require an extremely high level of
reliability and the malfunction of with would directly endanger human life (such as medical
instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety
devices), please be sure to consult with our sales representative in advance.
Website: http://www.prisemi.com
For additional information, please contact your local Sales Representative.
©Copyright 2009, Prisemi Electronics
is a registered trademark of Prisemi Electronics.
All rights are reserved.
Rev.06.1
7
www.prisemi.com
很抱歉,暂时无法提供与“PESDNC2XD5VBL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.07182
- 500+0.05638
- 1500+0.04774
