2SD882-MS
2SD882-MS
    MSKSEMI(美森科)
    SOT89-3
    通用三极管 NPN Ic=3A Vceo=30V hfe=60~400 P=500mW SOT89
2SD882-MS 数据手册
www.msksemi.com 2SD882-MS Semiconductor 1. BASE Compiance TRANSISTOR (NPN) 2. COLLETOR FEATURES Power dissipation 3. EMITTER MAXIMUM RATINGS (TA=25℃ unless otherwise noted) Symbol Parameter Value Units VCBO Collector-Base Voltage 40 V VCEO Collector-Emitter Voltage 30 V VEBO Emitter-Base Voltage 6 V IC Collector Current -Continuous 3 A PC Collector Power Dissipation 0.5 W TJ Junction Temperature 150 ℃ Tstg Storage Temperature -55-150 ℃ ELECTRICAL CHARACTERISTICS(Tamb=25℃ unless otherwise specified) Parameter Symbol Test conditions MIN TYP MAX UNIT Collector-base breakdown voltage V(BR)CBO IC = 100μA, IE=0 40 V Collector-emitter breakdown voltage V(BR)CEO IC = 10mA, IB=0 30 V Emitter-base breakdown voltage V(BR)EBO IE= 100μA, IC=0 6 V Collector cut-off current ICBO VCB= 40V, IE=0 1 µA Collector cut-off current ICEO VCE= 30V, IB=0 10 µA Emitter cut-off current IEBO VEB= 6V, IC=0 1 µA hFE(1) VCE=2V, IC= 1A 60 hFE(2) VCE=2V, IC= 100mA 32 DC current gain 400 Collector-emitter saturation voltage VCE(sat) IC= 2A, IB= 0.2 A 0.5 V Base-emitter saturation voltage VBE(sat) IC= 2A, IB= 0.2 A 1.5 V fT Transition frequency VCE= 5V , f =10MHz Ic=0.1A 50 MHz CLASSIFICATION OF hFE(1) Rank R O Y GR Range 60-120 100-200 160-320 200-400 www.msksemi.com 2SD882-MS Semiconductor Compiance PACKAGE MECHANICAL DATA Symbol A b b1 c D D1 E E1 e e1 L Dimensions In Millimeters Max Min 1.400 1.600 0.320 0.520 0.400 0.580 0.350 0.440 4.400 4.600 1.550 REF. 2.300 2.600 3.940 4.250 1.500 TYP. 3.000 TYP. 0.900 1.200 Dimensions In Inches Min Max 0.055 0.063 0.013 0.020 0.016 0.023 0.014 0.017 0.173 0.181 0.061 REF. 0.091 0.102 0.155 0.167 0.060 TYP. 0.118 TYP. 0.035 0.047 REEL SPECIFICATION P/N 2SD882-MS PKG QTY SOT-89 1000 www.msksemi.com Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
2SD882-MS 价格&库存
很抱歉,暂时无法提供与“2SD882-MS”相匹配的价格&库存,您可以联系我们找货
2SD882-MS
  • 10+0.42790
  • 100+0.33977
  • 300+0.29571
  • 1000+0.25542
  • 5000+0.22896
  • 10000+0.21579
库存:170
