ESP32-PICO-MINI-02U-N8R2
    ESPRESSIF(乐鑫)
    SMD-53P
    RF收发器模块 Vi=3V~3.6V 2.4GHz 150Mbps -40°C~85°C
ESP32-PICO-MINI-02U-N8R2 数据手册
ESP32­PICO­MINI­02 ESP32­PICO­MINI­02U Datasheet 2.4 GHz Wi­Fi + Bluetooth® + Bluetooth LE module Built around ESP32 series of SoCs, Xtensa® dual­core 32­bit LX6 microprocessor Flash up to 8 MB, PSRAM up to 2 MB 27 GPIOs, rich set of peripherals On­board PCB antenna or external antenna connector ESP32­PICO­MINI­02 ESP32­PICO­MINI­02U Version 1.2 Espressif Systems Copyright © 2022 www.espressif.com 1 Module Overview 1 Module Overview Note: Check the link or the QR code to make sure that you use the latest version of this document: https://espressif.com/sites/default/files/documentation/esp32-pico-mini-02_datasheet_en.pdf 1.1 Features CPU and On­Chip Memory Peripherals • ESP32-PICO-V3-02 embedded, Xtensa • SD card, UART, SPI, SDIO, I2C, LED PWM, dual-core 32-bit LX6 microprocessor, up to 240 Motor PWM, I2S, IR, pulse counter, GPIO, MHz capacitive touch sensor, ADC, DAC, TWAI® (compatible with ISO 11898-1, i.e. CAN • 448 KB ROM for booting and core functions Specification 2.0), Ethernet MAC • 520 KB SRAM for data and instructions Integrated Components on Module • 16 KB SRAM in RTC • 40 MHz crystal oscillator • 8 MB SPI flash • 2 MB PSRAM Antenna Options • ESP32-PICO-MINI-02: On-board PCB antenna Wi­Fi • ESP32-PICO-MINI-02U: external antenna via a • 802.11b/g/n connector • Bit rate: 802.11n up to 150 Mbps Operating Conditions • A-MPDU and A-MSDU aggregation • Operating voltage/Power supply: 3.0 ~ 3.6 V • 0.4 µs guard interval support • Operating ambient temperature: –40 ~ 85 °C • Center frequency range of operating channel: 2412 ~ 2484 MHz Certification Bluetooth • RF certification: See certificates for ESP32-PICO-MINI-02 and • Bluetooth V4.2 BR/EDR and Bluetooth LE ESP32-PICO-MINI-02U specification • Green certification: REACH/RoHS • Class-1, class-2 and class-3 transmitter Test • AFH • CVSD and SBC Espressif Systems • Reliability: HTOL/HTSL/uHAST/TCT/ESD 2 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 1 Module Overview 1.2 Description ESP32-PICO-MINI-02 and ESP32-PICO-MINI-02U are two general-purpose Wi-Fi + Bluetooth + Bluetooth LE MCU modules. They are based on ESP32-PICO-V3-02, a System-in-Package (SiP) device, which integrates an 8 MB SPI flash, 2 MB SPI Pseudo static RAM (PSRAM) and 40 MHz crystal oscillator. The rich set of peripherals and a small size make the two modules an ideal choice for a wide variety of IoT applications, ranging from home automation, smart building, consumer electronics to industrial control, and they are suitable for intelligent speakers, speech recognition toys, intelligent gateway and Ethernet, etc. ESP32-PICO-MINI-02 comes with a PCB antenna. ESP32-PICO-MINI-02U comes with a connector for an external antenna. The ordering information of the two modules is listed as follows: Table 1: Ordering Information Module Ordering Code Chip embedded Module dimensions (mm) ESP32-PICO-MINI-02 ESP32-PICO-MINI-02-N8R2 ESP32-PICO-V3-02 13.2 × 16.6 × 2.4 ESP32-PICO-MINI-02U ESP32-PICO-MINI-02U-N8R2 ESP32-PICO-V3-02 13.2 × 11.2 × 2.4 At the core of ESP32-PICO-MINI-02 and ESP32-PICO-MINI-02U is the ESP32-PICO-V3-02 sip*. The chip embedded is designed to be scalable and adaptive. There are two CPU cores that can be individually controlled, and the CPU clock frequency is adjustable from 80 MHz to 240 MHz. The chip also has a low-power coprocessor that can be used instead of the CPU to save power while performing tasks that do not require much computing power, such as monitoring of peripherals. This ESP32 chip integrates a rich set of peripherals, ranging from SD card interface, capacitive touch sensors, ADC, DAC, Two-Wire Automotive Interface, to Ethernet, high-speed SPI, UART, I2S, I2C, etc. Note: * For details on the part numbers of the ESP32 family of chips, please refer to the document ESP32 Series Datasheet. 1.3 Applications • Generic Low-power IoT Sensor Hub • Smart Building • Generic Low-power IoT Data Loggers • Industrial Automation • Cameras for Video Streaming • Smart Agriculture • Over-the-top (OTT) Devices • Audio Applications • Speech Recognition • Health Care Applications • Image Recognition • Wi-Fi-enabled Toys • Mesh Network • Wearable Electronics • Home Automation • Retail & Catering Applications Espressif Systems 3 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback Contents Contents 1 Module Overview 2 1.1 Features 2 1.2 Description 3 1.3 Applications 3 2 Block Diagram 8 3 Pin Definitions 9 3.1 Pin Layout 9 3.2 Pin Description 10 3.3 Strapping Pins 11 4 Electrical Characteristics 14 4.1 Absolute Maximum Ratings 14 4.2 Recommended Operating Conditions 14 4.3 DC Characteristics (3.3 V, 25 °C) 14 4.4 Current Consumption Characteristics 15 4.5 Wi-Fi RF Characteristics 16 4.5.1 Wi-Fi RF Standards 16 4.5.2 Transmitter Characteristics 16 4.5.3 Receiver Characteristics 17 4.6 4.7 Bluetooth Radio 18 4.6.1 Receiver – Basic Data Rate 18 4.6.2 Transmitter – Basic Data Rate 19 4.6.3 Receiver – Enhanced Data Rate 19 4.6.4 Transmitter – Enhanced Data Rate 20 Bluetooth LE Radio 20 4.7.1 Receiver 20 4.7.2 Transmitter 21 5 Module Schematics 22 6 Peripheral Schematics 24 7 Physical Dimensions and PCB Land Pattern 25 7.1 Physical Dimensions 25 7.2 Recommended PCB Land Pattern 26 7.3 Dimensions of External Antenna Connector 27 8 Product Handling 29 8.1 Storage Conditions 29 8.2 Electrostatic Discharge (ESD) 29 8.3 Reflow Profile 29 Espressif Systems 4 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback Contents 8.4 Ultrasonic Vibration 30 9 Related Documentation and Resources 31 Revision History Espressif Systems 32 5 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback List of Tables List of Tables 1 Ordering Information 2 Pin Definitions 10 3 Strapping Pins 12 4 Parameter Descriptions of Setup and Hold Times for the Strapping Pins 13 5 Absolute Maximum Ratings 14 6 Recommended Operating Conditions 14 7 DC Characteristics (3.3 V, 25 °C) 14 8 Current Consumption Depending on RF Modes 15 9 Current Consumption Depending on Work Modes 16 10 Wi-Fi RF Standards 16 11 TX Power Characteristics 17 12 RX Sensitivity Characteristics 17 13 RX Maximum Input Level 18 14 Adjacent Channel Rejection 18 15 Receiver Characteristics – Basic Data Rate 18 16 Transmitter Characteristics – Basic Data Rate 19 17 Receiver Characteristics – Enhanced Data Rate 19 18 Transmitter Characteristics – Enhanced Data Rate 20 19 Receiver Characteristics – BLE 21 20 Transmitter Characteristics – BLE 21 Espressif Systems 3 6 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback List of Figures List of Figures 1 ESP32-PICO-MINI-02 Block Diagram 8 2 ESP32-PICO-MINI-02U Block Diagram 8 3 ESP32-PICO-MINI-02 Pin Layout (Top View) 9 4 ESP32-PICO-MINI-02U Pin Layout (Top View) 10 5 Setup and Hold Times for the Strapping Pins 13 6 ESP32-PICO-MINI-02 Schematics 22 7 ESP32-PICO-MINI-02U Schematics 23 8 Peripheral Schematics 24 9 ESP32-PICO-MINI-02 Physical Dimensions 25 10 ESP32-PICO-MINI-02U Physical Dimensions 25 11 ESP32-PICO-MINI-02 Recommended PCB Land Pattern 26 12 ESP32-PICO-MINI-02U Recommended PCB Land Pattern 27 13 Dimensions of External Antenna Connector 28 14 Reflow Profile 29 Espressif Systems 7 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 2 Block Diagram 2 Block Diagram 3V3 3V3 Antenna Antenna 40 MHz MHz 40 Crystal Crystal RF Matching Matching RF ESP32-PICO-V3-02 ESP32-PICO-V3-02 GPIOs GPIOs EN EN SPI Flash Flash SPI PSRAM PSRAM ESP32-PICO-MINI-02 ESP32-PICO-MINI-02 Figure 1: ESP32­PICO­MINI­02 Block Diagram 3V3 3V3 Antenna Antenna 40 MHz MHz 40 Crystal Crystal RF Matching Matching RF ESP32-PICO-V3-02 ESP32-PICO-V3-02 EN EN GPIOs GPIOs SPI Flash Flash SPI PSRAM PSRAM ESP32-PICO-MINI-02U ESP32-PICO-MINI-02U Figure 2: ESP32­PICO­MINI­02U Block Diagram Espressif Systems 8 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 3 Pin Definitions 3 Pin Definitions 3.1 Pin Layout The pin diagram below shows the approximate location of pins on the module. For the actual diagram drawn to scale, please refer to Figure 7.1 Physical Dimensions. GND GND GND GND GND GND GND GND GND GND GND GND GND Pin 47 Pin 46 Pin 45 Pin 44 Pin 43 Pin 42 Pin 41 Pin 40 Pin 39 Pin 38 Pin 37 Pin 36 Pin 53 GND Pin 48 Keepout Zone Pin 50 GND GND Pin 1 Pin 35 IO21 GND Pin 2 Pin 34 IO22 3V3 Pin 3 Pin 33 IO19 I36 Pin 4 Pin 32 NC I37 Pin 5 Pin 31 TXD0 I38 Pin 6 Pin 30 RXD0 I39 Pin 7 Pin 29 IO5 Pin 28 IO8 GND EN GND GND Pin 49 GND GND GND Pin 8 GND GND GND Pin 24 IO0 IO4 Pin 21 IO15 Pin 22 Pin 20 IO13 Pin 23 Pin 19 IO12 IO2 Pin 18 IO14 Pin 52 GND Pin 17 NC IO27 Pin 25 Pin 16 Pin 11 IO26 GND Pin 15 IO20 IO25 Pin 26 GND Pin 10 Pin 14 I35 IO33 IO7 Pin 13 Pin 27 Pin 12 Pin 9 IO32 I34 Pin 51 GND Figure 3: ESP32­PICO­MINI­02 Pin Layout (Top View) Espressif Systems 9 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback GND GND GND GND GND GND GND GND GND GND GND GND GND Pin 47 Pin 46 Pin 45 Pin 44 Pin 43 Pin 42 Pin 41 Pin 40 Pin 39 Pin 38 Pin 37 Pin 36 Pin 53 GND Pin 48 3 Pin Definitions Pin 50 GND GND Pin 1 Pin 35 IO21 GND Pin 2 Pin 34 IO22 3V3 Pin 3 Pin 33 IO19 Pin 32 NC Pin 31 TXD0 Pin 30 RXD0 Pin 29 IO5 Pin 28 IO8 GND I36 Pin 4 I37 Pin 5 I38 Pin 6 I39 Pin 7 EN GND GND Pin 49 GND GND GND Pin 8 GND GND GND Pin 16 Pin 17 Pin 18 Pin 19 Pin 20 Pin 21 Pin 22 Pin 23 Pin 24 IO27 IO14 IO12 IO13 IO15 IO2 IO0 IO4 NC Pin 52 GND IO26 GND IO25 IO20 Pin 25 Pin 15 Pin 26 Pin 11 GND Pin 10 Pin 14 I35 IO33 IO7 Pin 13 Pin 27 Pin 12 Pin 9 IO32 I34 Pin 51 GND Figure 4: ESP32­PICO­MINI­02U Pin Layout (Top View) 3.2 Pin Description ESP32-PICO-MINI-02 and ESP32-PICO-MINI-02U each has 53 pins. See pin definitions in Table 2. For peripheral pin configurations, please refer to ESP32 Series Datasheet. Table 2: Pin Definitions Type1 Function Name No. GND 1, 2, 11, 14, 36-53 P Ground 3V3 3 P Power supply I36 4 I GPIO36, ADC1_CH0, RTC_GPIO0 I37 5 I GPIO37, ADC1_CH1, RTC_GPIO1 I38 6 I GPIO38, ADC1_CH2, RTC_GPIO2 I39 7 I GPIO39, ADC1_CH3, RTC_GPIO3 EN 8 I High: On; enables the chip Low: Off; the chip shuts down Note: Do not leave EN pin floating. I34 9 I GPIO34, ADC1_CH6, RTC_GPIO4 I35 10 I GPIO35, ADC1_CH7, RTC_GPIO5 IO32 12 I/O IO33 13 I/O IO25 15 I/O GPIO25, DAC_1, ADC2_CH8, RTC_GPIO6, EMAC_RXD0 IO26 16 I/O GPIO26, DAC_2, ADC2_CH9, RTC_GPIO7, EMAC_RXD1 GPIO32, XTAL_32K_P (32.768 kHz crystal oscillator input), ADC1_CH4, TOUCH9, RTC_GPIO9 GPIO33, XTAL_32K_N (32.768 kHz crystal oscillator output), ADC1_CH5, TOUCH8, RTC_GPIO8 Cont’d on next page Espressif Systems 10 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 3 Pin Definitions Table 2 – cont’d from previous page 1 Name No. Type Function IO27 17 I/O IO14 18 I/O IO12 19 I/O IO13 20 I/O IO15 21 I/O IO2 22 I/O IO0 23 I/O IO4 24 I/O NC 25 - IO20 26 I/O GPIO20 IO7 27 I/O GPIO7, HS1_DATA0, U2RTS, SD_DATA0 IO8 28 I/O GPIO8, HS1_DATA1, U2CTS, SD_DATA1 IO5 29 I/O GPIO5, VSPICS0, HS1_DATA6, EMAC_RX_CLK RXD0 30 I/O GPIO3, U0RXD, CLK_OUT2 TXD0 31 I/O GPIO1, U0TXD, CLK_OUT3, EMAC_RXD2 NC 32 - IO19 33 I/O GPIO19, VSPIQ, U0CTS, EMAC_TXD0 IO22 34 I/O GPIO22, VSPIWP, U0RTS, EMAC_TXD1 IO21 35 I/O GPIO21, VSPIHD, EMAC_TX_EN GPIO27, ADC2_CH7, TOUCH7, RTC_GPIO17, EMAC_RX_DV GPIO14, ADC2_CH6, TOUCH6, RTC_GPIO16, MTMS, HSPICLK, HS2_CLK, SD_CLK, EMAC_TXD2 GPIO12, ADC2_CH5, TOUCH5, RTC_GPIO15, MTDI, HSPIQ, HS2_DATA2, SD_DATA2, EMAC_TXD3 GPIO13, ADC2_CH4, TOUCH4, RTC_GPIO14, MTCK, HSPID, HS2_DATA3, SD_DATA3, EMAC_RX_ER GPIO15, ADC2_CH3, TOUCH3, RTC_GPIO13, MTDO, HSPICS0, HS2_CMD, SD_CMD, EMAC_RXD3 GPIO2, ADC2_CH2, TOUCH2, RTC_GPIO12, HSPIWP, HS2_DATA0, SD_DATA0 GPIO0, ADC2_CH1, TOUCH1, RTC_GPIO11, CLK_OUT1, EMAC_TX_CLK GPIO4, ADC2_CH0, TOUCH0, RTC_GPIO10, HSPIHD, HS2_DATA1, SD_DATA1, EMAC_TX_ER - - * P: power supply; I: input; O: output. * Pins CMD/IO11 and CLK/IO6 are used for connecting the embedded flash, and pins SD2/IO9 and SD3/IO10 are used for connecting embedded PSRAM. These pins are not led out. 3.3 Strapping Pins Note: The content below is excerpted from Section Strapping Pins in ESP32 Series Datasheet. For the strapping pin mapping between the chip and modules, please refer to Chapter 5 Module Schematics. ESP32 has five strapping pins: • MTDI • GPIO0 • GPIO2 • MTDO Espressif Systems 11 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 3 Pin Definitions • GPIO5 Software can read the values of these five bits from register ”GPIO_STRAPPING”. During the chip’s system reset release (power-on-reset, RTC watchdog reset and brownout reset), the latches of the strapping pins sample the voltage level as strapping bits of ”0” or ”1”, and hold these bits until the chip is powered down or shut down. The strapping bits configure the device’s boot mode, the operating voltage of VDD_SDIO and other initial system settings. Each strapping pin is connected to its internal pull-up/pull-down during the chip reset. Consequently, if a strapping pin is unconnected or the connected external circuit is high-impedance, the internal weak pull-up/pull-down will determine the default input level of the strapping pins. To change the strapping bit values, users can apply the external pull-down/pull-up resistances, or use the host MCU’s GPIOs to control the voltage level of these pins when powering on ESP32. After reset release, the strapping pins work as normal-function pins. Refer to Table 3 for a detailed boot-mode configuration by strapping pins. Table 3: Strapping Pins Voltage of Internal LDO (VDD_SDIO) Pin MTDI Default 3.3 V 1.8 V Pull-down 0 1 Booting Mode Pin Default SPI Boot Download Boot GPIO0 Pull-up 1 0 GPIO2 Pull-down Don’t-care 0 Enabling/Disabling Debugging Log Print over U0TXD During Booting Pin Default U0TXD Active U0TXD Silent MTDO Pull-up 1 0 Timing of SDIO Slave FE Sampling FE Sampling RE Sampling RE Sampling Pin Default FE Output RE Output FE Output RE Output MTDO Pull-up 0 0 1 1 GPIO5 Pull-up 0 1 0 1 * FE: falling-edge, RE: rising-edge * Firmware can configure register bits to change the settings of ”Voltage of Internal LDO (VDD_SDIO)” and ”Timing of SDIO Slave”, after booting. * The module integrates a 3.3 V SPI flash, so the pin MTDI cannot be set to 1 when the module is powered up. The illustration below shows the setup and hold times for the strapping pins before and after the CHIP_PU signal goes high. Details about the parameters are listed in Table 4. Espressif Systems 12 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 3 Pin Definitions t0 CHIP_PU t1 VIL_nRST VIH Strapping pin Figure 5: Setup and Hold Times for the Strapping Pins Table 4: Parameter Descriptions of Setup and Hold Times for the Strapping Pins Parameters Description Min. Unit t0 Setup time before CHIP_PU goes from low to high 0 ms t1 Hold time after CHIP_PU goes high 1 ms Espressif Systems 13 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 4 Electrical Characteristics 4 Electrical Characteristics 4.1 Absolute Maximum Ratings Stresses above those listed in Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. Table 5: Absolute Maximum Ratings Symbol Parameter Min Max Unit VDD33 Power supply voltage –0.3 3.6 V TST ORE Storage temperature –40 85 °C IO MUX * Please see Appendix of ESP32 Series Datasheet for IO’s power domain. 4.2 Recommended Operating Conditions Table 6: Recommended Operating Conditions Symbol Parameter Min Typ Max Unit VDD33 Power supply voltage 3.0 3.3 3.6 V IV DD Current delivered by external power supply 0.5 — — A T Operating ambient temperature –40 — 85 °C 4.3 DC Characteristics (3.3 V, 25 °C) Table 7: DC Characteristics (3.3 V, 25 °C) Symbol Parameter CIN Pin capacitance VIH High-level input voltage Min Typ — 2 0.75 × VDD 1 — Max Unit — pF 1 VDD + 0.3 V 1 VIL Low-level input voltage –0.3 — 0.25 × VDD IIH High-level input current — — 50 nA IIL Low-level input current — — 50 nA — — VOH VOL High-level output voltage 0.8 × VDD Low-level output voltage — 1 — 0.1 × VDD V V 1 V Cont’d on next page Espressif Systems 14 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 4 Electrical Characteristics Table 7 – cont’d from previous page Symbol Parameter High-level source current 1 (VDD = 3.3 V, IOH Min Typ Max Unit — 40 — mA — 40 — mA — 20 — mA — 28 — mA VDD3P3_CPU power domain 1, 2 VDD3P3_RTC VOH >= 2.64 V, output drive strength set to the maximum) power domain 1, 2 VDD_SDIO power domain 1, 3 Low-level sink current (VDD1= 3.3 V, VOL = 0.495 V, IOL output drive strength set to the maximum) RP U Resistance of internal pull-up resistor — 45 — kΩ RP D Resistance of internal pull-down resistor — 45 — kΩ — — 0.6 V VIL_nRST 1 Low-level input voltage of CHIP_PU to shut down the chip Please see Appendix IO MUX of ESP32 Series Datasheet for IO’s power domain. VDD is the I/O voltage for a particular power domain of pins. 2 For VDD3P3_CPU and VDD3P3_RTC power domain, per-pin current sourced in the same domain is gradually reduced from around 40 mA to around 29 mA, VOH >=2.64 V, as the number of currentsource pins increases. 3 Pins occupied by flash and/or PSRAM in the VDD_SDIO power domain were excluded from the test. 4.4 Current Consumption Characteristics Owing to the use of advanced power-management technologies, the module can switch between different power modes. For details on different power modes, please refer to Section RTC and Low-Power Management in ESP32 Series Datasheet. Table 8: Current Consumption Depending on RF Modes Work mode Description TX Active (RF working) RX2 1 Peak (mA) 802.11b, 20 MHz, 1 Mbps, @19.5 dBm 368 802.11g, 20 MHz, 54 Mbps, @14 dBm 258 802.11n, 20 MHz, MCS7, @13 dBm 248 802.11n, 40 MHz, MCS7, @13 dBm 250 802.11b/g/n, 20 MHz 111 802.11n, 40 MHz 117 The current consumption measurements are taken with a 3.3 V supply at 25 °C of ambient temperature at the RF port. All transmitters’ measurements are based on a 100% duty cycle. 2 The current consumption figures for in RX mode are for cases when the peripherals are disabled and the CPU idle. Espressif Systems 15 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 4 Electrical Characteristics Table 9: Current Consumption Depending on Work Modes Work mode Modem-sleep Description 1, 2 The CPU is powered on 3 Current consumption (Typ) 240 MHz 30 ~ 68 mA 160 MHz 27 ~ 44 mA Normal speed: 80 MHz 20 ~ 31 mA Light-sleep — 0.8 mA The ULP coprocessor is powered up ULP sensor-monitored pattern 5 Deep-sleep Power off 1 4 150 µA 100 µA @1% duty RTC timer + RTC memory 10 µA RTC timer only 5 µA CHIP_PU is set to low level, the chip is powered down 1 µA The current consumption figures in Modem-sleep mode are for cases where the CPU is powered up and the cache idle. 2 When Wi-Fi is enabled, the chip switches between Active and Modem-sleep modes. Therefore, current consumption changes accordingly. 3 In Modem-sleep mode, the CPU frequency changes automatically. The frequency depends on the CPU load and the peripherals used. 4 During Deep-sleep, when the ULP coprocessor is powered up, peripherals such as GPIO and RTC I2C are able to operate. 5 The ”ULP sensor-monitored pattern” refers to the mode where the ULP coprocessor or the sensor works periodically. When ADC works with a duty cycle of 1%, the typical current consumption is 100 µA. 4.5 Wi­Fi RF Characteristics 4.5.1 Wi­Fi RF Standards Table 10: Wi­Fi RF Standards Name Description Center frequency range of operating channel 1 2412 ~ 2484 MHz Wi-Fi wireless standard IEEE 802.11b/g/n 11b: 1, 2, 5.5 and 11 Mbps Data rate 20 MHz 11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps 11n: MCS0-7, 72.2 Mbps (Max) 40 MHz 11n: MCS0-7, 150 Mbps (Max) PCB antenna, external antenna2 Antenna type 1 Device should operate in the center frequency range allocated by regional regulatory authorities. Target center frequency range is configurable by software. 2 For the modules that use external antennas, the output impedance is 50 Ω. For other modules without external antennas, the output impedance is irrelevant. 4.5.2 Transmitter Characteristics Target TX power is configurable based on device or certification requirements. The default characteristics are provided in Table 11. Espressif Systems 16 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 4 Electrical Characteristics Table 11: TX Power Characteristics Rate Typ (dBm) 11b, 1 Mbps 19.5 11b, 11 Mbps 19.5 11g, 6 Mbps 18 11g, 54 Mbps 14 11n, HT20, MCS0 18 11n, HT20, MCS7 13 11n, HT40, MCS0 18 11n, HT40, MCS7 13 4.5.3 Receiver Characteristics Table 12: RX Sensitivity Characteristics Rate Typ (dBm) 1 Mbps –97 2 Mbps –94 5.5 Mbps –92 11 Mbps –88 6 Mbps –93 9 Mbps –91 12 Mbps –89 18 Mbps –87 24 Mbps –84 36 Mbps –80 48 Mbps –77 54 Mbps –75 11n, HT20, MCS0 –92 11n, HT20, MCS1 –88 11n, HT20, MCS2 –86 11n, HT20, MCS3 –83 11n, HT20, MCS4 –80 11n, HT20, MCS5 –76 11n, HT20, MCS6 –74 11n, HT20, MCS7 –72 11n, HT40, MCS0 –89 11n, HT40, MCS1 –85 11n, HT40, MCS2 –83 11n, HT40, MCS3 –80 11n, HT40, MCS4 –76 11n, HT40, MCS5 –72 11n, HT40, MCS6 –71 Cont’d on next page Espressif Systems 17 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 4 Electrical Characteristics Table 12 – cont’d from previous page Rate Typ (dBm) 11n, HT40, MCS7 –69 Table 13: RX Maximum Input Level Rate Typ (dBm) 11b, 1 Mbps 5 11b, 11 Mbps 5 11g, 6 Mbps 0 11g, 54 Mbps –8 11n, HT20, MCS0 0 11n, HT20, MCS7 –8 11n, HT40, MCS0 0 11n, HT40, MCS7 –8 Table 14: Adjacent Channel Rejection Rate Typ (dB) 11b, 11 Mbps 35 11g, 6 Mbps 27 11g, 54 Mbps 13 11n, HT20, MCS0 27 11n, HT20, MCS7 12 11n, HT40, MCS0 16 11n, HT40, MCS7 7 4.6 Bluetooth Radio 4.6.1 Receiver – Basic Data Rate Table 15: Receiver Characteristics – Basic Data Rate Parameter Conditions Min Typ Max Unit Sensitivity @0.1% BER — –90 –89 –88 dBm Maximum received signal @0.1% BER — 0 — — dBm Co-channel C/I — — +7 — dB F = F0 + 1 MHz — — –6 dB F = F0 – 1 MHz — — –6 dB F = F0 + 2 MHz — — –25 dB F = F0 – 2 MHz — — –33 dB F = F0 + 3 MHz — — –25 dB F = F0 – 3 MHz — — –45 dB Adjacent channel selectivity C/I Cont’d on next page Espressif Systems 18 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 4 Electrical Characteristics Table 15 – cont’d from previous page Parameter Out-of-band blocking performance Intermodulation Conditions Min Typ Max Unit 30 MHz ~ 2000 MHz –10 — — dBm 2000 MHz ~ 2400 MHz –27 — — dBm 2500 MHz ~ 3000 MHz –27 — — dBm 3000 MHz ~ 12.5 GHz –10 — — dBm — –36 — — dBm 4.6.2 Transmitter – Basic Data Rate Table 16: Transmitter Characteristics – Basic Data Rate Parameter Min Typ Max Unit - - 0 - dBm Gain control step - - 3 - dB RF power control range - –12 - +9 dBm +20 dB bandwidth - - 0.9 - MHz F = F0 ± 2 MHz - –55 - dBm F = F0 ± 3 MHz - –55 - dBm F = F0 ± > 3 MHz - –59 - dBm ∆ f 1avg - - - 155 kHz ∆ f 2max - 127 - - kHz ∆ f 2avg /∆ f 1avg - - 0.92 - - ICFT - - –7 - kHz Drift rate - - 0.7 - kHz/50 µs Drift (DH1) - - 6 - kHz Drift (DH5) - - 6 - kHz RF transmit power Conditions * Adjacent channel transmit power * There are a total of eight power levels from 0 to 7, and the transmit power ranges from –12 dBm to 9 dBm. When the power level rises by 1, the transmit power increases by 3 dB. Power level 4 is used by default and the corresponding transmit power is 0 dBm. 4.6.3 Receiver – Enhanced Data Rate Table 17: Receiver Characteristics – Enhanced Data Rate Parameter Conditions Min Typ Max Unit π/4 DQPSK Sensitivity @0.01% BER — –90 –89 –88 dBm Maximum received signal @0.01% BER — — 0 — dBm Co-channel C/I — — 11 — dB F = F0 + 1 MHz — –7 — dB F = F0 – 1 MHz — –7 — dB F = F0 + 2 MHz — –25 — dB F = F0 – 2 MHz — –35 — dB Adjacent channel selectivity C/I Cont’d on next page Espressif Systems 19 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 4 Electrical Characteristics Table 17 – cont’d from previous page Parameter Conditions Min Typ Max Unit F = F0 + 3 MHz — –25 — dB F = F0 – 3 MHz — –45 — dB 8DPSK Sensitivity @0.01% BER — –84 –83 –82 dBm Maximum received signal @0.01% BER — — –5 — dBm C/I c-channel — — 18 — dB F = F0 + 1 MHz — 2 — dB F = F0 – 1 MHz — 2 — dB F = F0 + 2 MHz — –25 — dB F = F0 – 2 MHz — –25 — dB F = F0 + 3 MHz — –25 — dB F = F0 – 3 MHz — –38 — dB Adjacent channel selectivity C/I 4.6.4 Transmitter – Enhanced Data Rate Table 18: Transmitter Characteristics – Enhanced Data Rate Parameter Conditions Min Typ Max Unit RF transmit power (see note under Table 16) — — 0 — dBm Gain control step — — 3 — dB RF power control range — –12 — +9 dBm π/4 DQPSK max w0 — — –0.72 — kHz π/4 DQPSK max wi — — –6 — kHz π/4 DQPSK max |wi + w0| — — –7.42 — kHz 8DPSK max w0 — — 0.7 — kHz 8DPSK max wi — — –9.6 — kHz 8DPSK max |wi + w0| — — –10 — kHz RMS DEVM — 4.28 — % 99% DEVM — 100 — % Peak DEVM — 13.3 — % RMS DEVM — 5.8 — % 99% DEVM — 100 — % Peak DEVM — 14 — % F = F0 ± 1 MHz — –46 — dBm F = F0 ± 2 MHz — –44 — dBm F = F0 ± 3 MHz — –49 — dBm F = F0 +/– > 3 MHz — — –53 dBm — — 100 — π/4 DQPSK modulation accuracy 8 DPSK modulation accuracy In-band spurious emissions EDR differential phase coding % 4.7 Bluetooth LE Radio 4.7.1 Receiver Espressif Systems 20 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 4 Electrical Characteristics Table 19: Receiver Characteristics – BLE Parameter Conditions Min Typ Max Unit Sensitivity @30.8% PER — –94 –93 –92 dBm Maximum received signal @30.8% PER — 0 — — dBm Co-channel C/I — — +10 — dB F = F0 + 1 MHz — –5 — dB F = F0 – 1 MHz — –5 — dB F = F0 + 2 MHz — –25 — dB F = F0 – 2 MHz — –35 — dB F = F0 + 3 MHz — –25 — dB F = F0 – 3 MHz — –45 — dB 30 MHz ~ 2000 MHz –10 — — dBm 2000 MHz ~ 2400 MHz –27 — — dBm 2500 MHz ~ 3000 MHz –27 — — dBm 3000 MHz ~ 12.5 GHz –10 — — dBm — –36 — — dBm Adjacent channel selectivity C/I Out-of-band blocking performance Intermodulation 4.7.2 Transmitter Table 20: Transmitter Characteristics – BLE Parameter Conditions Min Typ Max Unit RF transmit power (see note under Table 16) — — 0 — dBm Gain control step — — 3 — dB RF power control range — –12 — +9 dBm F = F0 ± 2 MHz — –52 — dBm F = F0 ± 3 MHz — –58 — dBm F = F0 ± > 3 MHz — –60 — dBm Adjacent channel transmit power ∆ f 1avg — — — 265 kHz ∆ f 2max — 247 — — kHz ∆ f 2avg /∆ f 1avg — — +0.92 — — ICFT — — –10 — kHz Drift rate — — 0.7 — kHz/50 µs Drift — — 2 — kHz Espressif Systems 21 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 5 4 3 2 1 This is the reference design of the module. D D VDD33 GND GND GND TBD C11 C12 TBD TBD GND GND I36 I37 I38 I39 EN I34 I35 IO32 1 2 3 4 5 6 7 8 9 10 11 12 48 47 46 45 44 43 42 41 40 39 38 37 VDDA LNA_IN VDDA3P3 VDDA3P3 SENSOR_VP/I36 SENSOR_CAPP/I37 SENSOR_CAPN/I38 SENSOR_VN/I39 EN VDET_1/I34 VDET_2/I35 32K_XP/IO32 49 48 47 46 45 44 43 42 41 40 39 38 37 36 53 NC NC IO5 SD1/IO8 SD0/IO7 CLK/IO6 CMD/IO11 SD3/IO10 SD2/IO9 IO20 VDD_SDIO NC 36 35 34 33 32 31 30 29 28 27 26 25 13 14 15 16 17 18 19 20 21 22 23 24 U1 B VDD33 IO5 IO8 IO7 IO20 I36 I37 I38 D1 I39 ESD EN I34 I35 GND ESP32-PICO-V3-02 IO13 IO15 IO2 IO0 IO4 VDD33 IO33 IO25 IO26 IO27 IO14 IO12 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 32K_XN/IO33 IO25 IO26 IO27 MTMS/IO14 MTDI/IO12 VDD3P3_RTC MTCK/IO13 MTDO/IO15 IO2 IO0 IO4 The values of C11, L2 and C12 vary with the actual PCB board. LNA_IN IO23:SPIDI IO18:SPIWP CLK:FLASH_CLK CMD:FLASH_CS SD3:PSRAM_CLK SD2:PSRAM_CS IO17:SPIDO IO16:SPIHD 1 2 3 4 5 6 7 8 9 10 11 52 GND GND GND GND 3V3 I36 I37 I38 I39 EN I34 I35 GND ESP32-PICO-MINI-02 IO21 IO22 IO19 NC TXD0 RXD0 IO5 IO8 IO7 IO20 NC GND GND U2 50 C 35 34 33 32 31 30 29 28 27 26 25 IO21 IO22 IO19 U0TXD U0RXD IO5 IO8 IO7 IO20 51 B IO25 IO26 IO27 IO14 IO12 IO13 IO15 IO2 IO0 IO4 PCB_ANT L2 NC NC VDDA NC NC VDDA IO21 U0TXD/IO1 U0RXD/IO3 IO22 IO19 VDD3P3_CPU GND RF_ANT 1 2 22 Submit Documentation Feedback C ANT1 VDD33 GND 49 GND EPAD GND GND GND GND GND GND GND GND GND GND GND GND GND 0.1uF IO32 IO33 GND IO25 IO26 IO27 IO14 IO12 IO13 IO15 IO2 IO0 IO4 10uF IO21 U0TXD U0RXD IO22 IO19 12 13 14 15 16 17 18 19 20 21 22 23 24 C5 IO32 IO33 C6 GND ESP32-PICO-MINI-02 (pin-out) Figure 6: ESP32­PICO­MINI­02 Schematics A A Title Size A4 Date: 5 4 3 2 Page Name Monday, January 18, 2021 Rev 1.2 Confidential and Proprietary 2 Sheet 1 of 2 5 Module Schematics Espressif Systems 5 Module Schematics D D 5 Module Schematics Espressif Systems VDD33 GND GND TBD ANT1 C11 C12 IPEX TBD TBD GND GND GND 48 47 46 45 44 43 42 41 40 39 38 37 VDDA LNA_IN VDDA3P3 VDDA3P3 SENSOR_VP/I36 SENSOR_CAPP/I37 SENSOR_CAPN/I38 SENSOR_VN/I39 EN VDET_1/I34 VDET_2/I35 32K_XP/IO32 49 48 47 46 45 44 43 42 41 40 39 38 37 36 53 NC NC IO5 SD1/IO8 SD0/IO7 CLK/IO6 CMD/IO11 SD3/IO10 SD2/IO9 IO20 VDD_SDIO NC 36 35 34 33 32 31 30 29 28 27 26 25 32K_XN/IO33 IO25 IO26 IO27 MTMS/IO14 MTDI/IO12 VDD3P3_RTC MTCK/IO13 MTDO/IO15 IO2 IO0 IO4 I36 I37 I38 I39 EN I34 I35 IO32 1 2 3 4 5 6 7 8 9 10 11 12 U1 B 13 14 15 16 17 18 19 20 21 22 23 24 23 ESP32-PICO-V3-02 IO13 IO15 IO2 IO0 IO4 IO33 IO25 IO26 IO27 IO14 IO12 VDD33 IO5 IO8 IO7 IO20 I36 I37 I38 D1 I39 ESD EN I34 I35 GND VDD33 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback The values of C11, L2 and C12 vary with the actual PCB board. LNA_IN IO23:SPIDI IO18:SPIWP CLK:FLASH_CLK CMD:FLASH_CS SD3:PSRAM_CLK SD2:PSRAM_CS IO17:SPIDO IO16:SPIHD 1 2 3 4 5 6 7 8 9 10 11 52 GND GND GND GND 3V3 I36 I37 I38 I39 EN I34 I35 GND ESP32-PICO-MINI-02U IO21 IO22 IO19 NC TXD0 RXD0 IO5 IO8 IO7 IO20 NC GND GND U2 50 C 35 34 33 32 31 30 29 28 27 26 25 IO21 IO22 IO19 U0TXD U0RXD IO5 IO8 IO7 IO20 51 B IO25 IO26 IO27 IO14 IO12 IO13 IO15 IO2 IO0 IO4 4 3 2 1 L2 NC NC VDDA NC NC VDDA IO21 U0TXD/IO1 U0RXD/IO3 IO22 IO19 VDD3P3_CPU GND C RF_ANT VDD33 GND 49 GND EPAD GND GND GND GND GND GND GND GND GND GND GND GND GND 0.1uF IO32 IO33 GND IO25 IO26 IO27 IO14 IO12 IO13 IO15 IO2 IO0 IO4 10uF IO21 U0TXD U0RXD IO22 IO19 12 13 14 15 16 17 18 19 20 21 22 23 24 C5 IO32 IO33 C6 GND ESP32-PICO-MINI-02U(pin-out) Figure 7: ESP32­PICO­MINI­02U Schematics A A Title Size 5 4 3 Page Name A4 Date: Thursday, April 01, 2021 2 Rev 1.0 Confidential and Proprietary 2 Sheet 1 of 2 4 3 2 6 Peripheral Schematics 6 Peripheral Schematics This is the typical application circuit of the module connected with peripheral components (for example, power supply, antenna, reset button, JTAG interface, and UART interface). C1 C2 22uF TBD 52 ESP32-PICO-MINI-02 ESP32-PICO-MINI-02U GND GND U1 X1: ESR = Max. 70 KΩ C5 12pF(NC) 1 R5 R3 R4 C6 35 34 33 32 31 30 29 28 27 26 25 IO21 IO22 IO19 TXD0 RXD0 IO5 IO8 IO7 IO20 VDD33 JP1 1 2 3 4 1 2 3 4 UART GND 51 JP2 1 2 GND 1 2 Boot Option GND 12pF(NC) NC: No component. GND 0(NC) 0(NC) NC 2 X1 32.768kHz(NC) GND IO32 IO33 GND IO21 IO22 IO19 NC TXD0 RXD0 IO5 IO8 IO7 IO20 NC 50 12 13 14 15 16 17 18 19 20 21 22 23 24 GND 0.1uF GND GND 3V3 I36 I37 I38 I39 EN I34 I35 GND GND IO25 IO26 IO27 IO14 IO12 IO13 IO15 IO2 IO0 IO4 I36 I37 R1 I38 TBD I39 EN I34 I35 C3 1 2 3 4 5 6 7 8 9 10 11 VDD33 GND IO32 IO33 GND IO25 IO26 IO27 IO14 IO12 IO13 IO15 IO2 IO0 IO4 53 EPAD GND GND GND GND GND GND GND GND GND GND GND GND GND 49 48 47 46 45 44 43 42 41 40 39 38 37 36 GND SW1 JP3 IO14 IO12 IO13 IO15 TMS TDI TCK TDO IO12 should be kept low when the module is powered on. 1 2 3 4 1 2 3 4 JTAG R2 C4 0 EN 0.1uF GND Figure 8: Peripheral Schematics Note: • Soldering Pad 49 to the Ground of the base board is not necessary for a satisfactory thermal performance. If users do want to solder it, they need to ensure that the correct quantity of soldering paste is applied. • To ensure that the power supply to the ESP32 chip is stable during power-up, it is advised to add an RC delay circuit at the EN pin. The recommended setting for the RC delay circuit is usually R = 10 kΩ and C = 1 µF. However, specific parameters should be adjusted based on the power-up timing of the module and the power-up and reset sequence timing of the chip. For ESP32’s power-up and reset sequence timing diagram, please refer to Section Power Scheme in ESP32 Series Datasheet. 4 Espressif Systems 3 24 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 2 7 Physical Dimensions and PCB Land Pattern 7 Physical Dimensions and PCB Land Pattern 7.1 Physical Dimensions Unit: mm 16.6±0.15 13.2±0.15 0.8 1.45 0.6 0.62 5.4 8.4 9.2 10 11 11.2 12.6 2.4±0.15 Top view 11.2 0.6 5.4 1.45 10.6 9.2 9 8.4 7.6 6.8 5 0. 0.62 Ø 9.95 11.95 Side view Bottom view Figure 9: ESP32­PICO­MINI­02 Physical Dimensions 0.8 1.7 0.85 10.6 9.2 9 8.4 7.6 6.8 0.48 7.4 10.25 12.25 0.48 Top view 0.6 5.4 1.45 1.45 0.6 13.2±0.15 9.18 1.55 11.2±0.15 Unit: mm 5.4 8.4 9.2 10 11 11.2 12.6 2.4±0.15 Side view Bottom view Figure 10: ESP32­PICO­MINI­02U Physical Dimensions Note: For information about tape, reel, and product marking, please refer to Espressif Module Package Information. Espressif Systems 25 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 7 Physical Dimensions and PCB Land Pattern 7.2 Recommended PCB Land Pattern Unit: mm : Pad 13.2 Antenna Area 16.6 1.45 1.45 5.4 0.6 10.6 9.2 9 8.4 7.6 6.8 0.6 11.2 Pin 1 5.4 8.4 9.2 10 11 11.2 12.6 Figure 11: ESP32­PICO­MINI­02 Recommended PCB Land Pattern Espressif Systems 26 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 7 Physical Dimensions and PCB Land Pattern Unit: mm : Pad 13.2 1.45 1.45 5.4 0.6 10.6 9.2 9 8.4 7.6 6.8 0.6 11.2 Pin 1 5.4 8.4 9.2 10 11 11.2 12.6 Figure 12: ESP32­PICO­MINI­02U Recommended PCB Land Pattern 7.3 Dimensions of External Antenna Connector ESP32-PICO-MINI-02U uses the third generation external antenna connector as shown in Figure 13. This connector is compatible with the following connectors: • W.FL Series connector from Hirose • MHF III connector from I-PEX • AMMC connector from Amphenol Espressif Systems 27 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 7 Physical Dimensions and PCB Land Pattern Unit: mm Tolerance: +/-0.1 mm CONTACT 1.7 2.00±0.10 A A GROUND CONTACT 2.05±0.10 0.85 0.57 1.7 CONTACT 1.40 0.10 HOUSING HOUSING MATERIAL: THERMOPLASTIC, WHITE, UL 94V-0; SHELL CONTACT MATERIAL: COPPER ALLOY, GOLD PLATED ALL OVER; SECTION: A-A SCALE: 1:1 SHELL MATERIAL: COPPER ALLOY, GOLD PLATED ALL OVER; PERFORMANCE: CONTACT RESISTANCE: 20mOHM Max. DIELECTRIC WITHSTANDING VOLTAGE: 200V AC FOR 1MINUTE; INSULATION RESISTANCE: 500MOHM Min. Figure 13: Dimensions of External Antenna Connector Espressif Systems 28 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 8 Product Handling 8 Product Handling 8.1 Storage Conditions The products sealed in moisture barrier bags (MBB) should be stored in a non-condensing atmospheric environment of < 40 °C and 90%RH. The module is rated at the moisture sensitivity level (MSL) of 3. After unpacking, the module must be soldered within 168 hours with the factory conditions 25 ± 5 °C and 60 %RH. If the above conditions are not met, the module needs to be baked. 8.2 Electrostatic Discharge (ESD) • Human body model (HBM): ±2000 V • Charged-device model (CDM): ±500 V 8.3 Reflow Profile Temperature (℃) Solder the module in a single reflow. Peak Temp. 235 ~ 250 ℃ 250 Preheating zone 150 ~ 200 ℃ 60 ~ 120 s 217 200 Reflow zone 217 ℃ 60 ~ 90 s Cooling zone –1 ~ –5 ℃/s Soldering time > 30 s Ramp-up zone 1 ~ 3 ℃/s 100 50 25 Time (sec.) 0 0 50 100 150 200 250 Ramp-up zone — Temp.: 25 ~ 150 ℃ Time: 60 ~ 90 s Ramp-up rate: 1 ~ 3 ℃/s Preheating zone — Temp.: 150 ~ 200 ℃ Time: 60 ~ 120 s Reflow zone — Temp.: >217 ℃ 60 ~ 90 s; Peak Temp.: 235 ~ 250 ℃ Time: 30 ~ 70 s Cooling zone — Peak Temp. ~ 180 ℃ Ramp-down rate: –1 ~ –5 ℃/s Solder — Sn-Ag-Cu (SAC305) lead-free solder alloy Figure 14: Reflow Profile Espressif Systems 29 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 8 Product Handling 8.4 Ultrasonic Vibration Avoid exposing Espressif modules to vibration from ultrasonic equipment, such as ultrasonic welders or ultrasonic cleaners. This vibration may induce resonance in the in-module crystal and lead to its malfunction or even failure. As a consequence, the module may stop working or its performance may deteriorate. Espressif Systems 30 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback 9 Related Documentation and Resources 9 Related Documentation and Resources Related Documentation • ESP32 Series Datasheet – Specifications of the ESP32 hardware. • ESP32 Technical Reference Manual – Detailed information on how to use the ESP32 memory and peripherals. • ESP32 Hardware Design Guidelines – Guidelines on how to integrate the ESP32 into your hardware product. • ESP32 ECO and Workarounds for Bugs – Correction of ESP32 design errors. • Certificates https://espressif.com/en/support/documents/certificates • ESP32 Product/Process Change Notifications (PCN) https://espressif.com/en/support/documents/pcns • ESP32 Advisories – Information on security, bugs, compatibility, component reliability. https://espressif.com/en/support/documents/advisories • Documentation Updates and Update Notification Subscription https://espressif.com/en/support/download/documents Developer Zone • ESP-IDF Programming Guide for ESP32 – Extensive documentation for the ESP-IDF development framework. • ESP-IDF and other development frameworks on GitHub. https://github.com/espressif • ESP32 BBS Forum – Engineer-to-Engineer (E2E) Community for Espressif products where you can post questions, share knowledge, explore ideas, and help solve problems with fellow engineers. https://esp32.com/ • The ESP Journal – Best Practices, Articles, and Notes from Espressif folks. https://blog.espressif.com/ • See the tabs SDKs and Demos, Apps, Tools, AT Firmware. https://espressif.com/en/support/download/sdks-demos Products • ESP32 Series SoCs – Browse through all ESP32 SoCs. https://espressif.com/en/products/socs?id=ESP32 • ESP32 Series Modules – Browse through all ESP32-based modules. https://espressif.com/en/products/modules?id=ESP32 • ESP32 Series DevKits – Browse through all ESP32-based devkits. https://espressif.com/en/products/devkits?id=ESP32 • ESP Product Selector – Find an Espressif hardware product suitable for your needs by comparing or applying filters. https://products.espressif.com/#/product-selector?language=en Contact Us • See the tabs Sales Questions, Technical Enquiries, Circuit Schematic & PCB Design Review, Get Samples (Online stores), Become Our Supplier, Comments & Suggestions. https://espressif.com/en/contact-us/sales-questions Espressif Systems 31 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback Revision History Revision History Date Version 2022-12-02 v1.2 Release notes Added Figure 5 and Table 4 in Section 3.3: Strapping Pins Added Section 8.4: Ultrasonic Vibration Added a link to RF certificates in Section 1.1 2022-03-28 v1.1 Updated the description of TWAI in Section 1.1 Updated Table 6 2021-07-15 v1.0 2021-03-16 v0.5 Espressif Systems Added ESP32-PICO-MINI-02U module. Updated the document formatting. Preliminary release 32 ESP32-PICO-MINI-02 & PICO-MINI-02U Datasheet v1.2 Submit Documentation Feedback Disclaimer and Copyright Notice Information in this document, including URL references, is subject to change without notice. ALL THIRD PARTY’S INFORMATION IN THIS DOCUMENT IS PROVIDED AS IS WITH NO WARRANTIES TO ITS AUTHENTICITY AND ACCURACY. NO WARRANTY IS PROVIDED TO THIS DOCUMENT FOR ITS MERCHANTABILITY, NONINFRINGEMENT, FITNESS FOR ANY PARTICULAR PURPOSE, NOR DOES ANY WARRANTY OTHERWISE ARISING OUT OF ANY PROPOSAL, SPECIFICATION OR SAMPLE. All liability, including liability for infringement of any proprietary rights, relating to use of information in this document is disclaimed. No licenses express or implied, by estoppel or otherwise, to any intellectual property rights are granted herein. The Wi-Fi Alliance Member logo is a trademark of the Wi-Fi Alliance. The Bluetooth logo is a registered trademark of Bluetooth SIG. www.espressif.com All trade names, trademarks and registered trademarks mentioned in this document are property of their respective owners, and are hereby acknowledged. Copyright © 2022 Espressif Systems (Shanghai) Co., Ltd. All rights reserved.
ESP32-PICO-MINI-02U-N8R2 价格&库存
很抱歉,暂时无法提供与“ESP32-PICO-MINI-02U-N8R2”相匹配的价格&库存,您可以联系我们找货
    • 50+49.77315
    • 200+46.27140
    • 500+45.34680
    • 1000+44.88335
    库存:13000
    • 1+56.737011+7.33689
    • 10+49.1269110+6.35279
    • 25+46.4872225+6.01145
    • 100+42.86109100+5.54254
    • 250+40.68776250+5.26150
    库存:4221
