413-K14-LN2-50A
413-K14-LN2-50A
    E-T-A
    电子断路器 28V 50A -55℃~+75℃
413-K14-LN2-50A 数据手册
High Performance Thermal Circuit Breaker 413-... Description Single pole high performance thermal circuit breaker with tease-free, trip-free, snap action mechanism and push/pull on/off manual actuation (M-type TO CBE to EN 60934). An indicator band on the push button clearly shows the tripped/off position. Threadneck panel mounted and available in tracked vehicle, aircraft and general purpose versions. Typical applications Extra low voltage wiring systems on all types of vehicles for land, sea and air; defence equipment; battery powered machines. 1 413-... Ordering information Type No. 413 threadneck panel mounting Terminal design K14 screw terminals M6 (to aircraft specs.) K54 reinforced screw terminals M6, housing sealed Version FN2 vehicle application, nickel-plated LN2 aircraft application, black finish N2 general application, nickel-plated Current ratings 30...55 A (-FN2) 30...90 A (-LN2/N2) 413 - K14 - LN2 - 40 A Technical data ordering example Please be informed that we have minimum ordering quantities to be observed. Preferred types Preferred types 413-K54-FN2413-K14-LN2- Standard current ratings (A) 30 35 40 45 50 x x x x x x x x x x 60 70 80 90 x x x x Standard current ratings and typical voltage drop values Current rating (A) Voltage drop (mV) -LN/N -FN 30 ≤ 250 ≤ 250 35 ≤ 250 ≤ 250 40 ≤ 200 45 50 1948 Current rating (A) Voltage drop (mV) -LN/N -FN 55 - ≤ 200 60 ≤ 200 - ≤ 200 70 ≤ 200 - ≤ 200 ≤ 200 80 ≤ 200 - ≤ 200 ≤ 200 90 ≤ 200 - For further details please see: www.e-t-a.de/ti_e Voltage rating DC 28 V AC 115 V (400 Hz) upon request Current rating range 30...55 A (-FN2) 30...90 A (-LN2/-N2), Typical life 2,000 operations at 1 x IN Ambient temperature -55...+75 °C (-67...+167 °F) Insulation co-ordination rated impulse pollution (IEC 60664 and 60664A) withstand voltage degree 1.5 kV 3 Dielectric strength (IEC 60664 and 60664A) test voltage operating area AC 1,500 V Insulation resistance > 100 MΩ (DC 500 V) Interrupting capacity Icn 6,000 A Interrupting capacity (UL 1077) 6,000 A Degree of protection operating area IP40 (IEC 60529/DIN 40050) terminal area IP00 Vibration 10 g (56-500 Hz), ± 0.76 mm (10-55 Hz) to VG 95210, sheet 19, MIL-STD-202, meth. 204, IEC 60068-2-6, test Fc Shock 50 g (11 ms) to VG 95210, sheet 28, MIL-STD-202, meth. 213, IEC 60068-2-27, test Ea Corrosion 96 hours at 5 % salt mist, to VG 95210, sheet 2, MIL-STD-202, meth. 101, IEC 60068-2-11, test Ka Humidity 240 hours at 95 % RH to VG 95210, sheet 7, MIL-STD-202, meth. 106, IEC 60068-2-3, test Ca Mass approx. 65 g www.e-t-a.de 1 High Performance Thermal Circuit Breaker 413-... Dimensions Internal connection diagram 413-K14-... tightening torque max. 4 Nm M12x1 min.3 min .118 lock washer 49 1.93 55 2.17 max. 64 max. 2.52 1.5 .059 max. 63 max. 2.48 1 line 1 black white 6.5 .256 ON 12.2 .480 7 .276 OFF ø10.6 .417 2 Typical time/current characteristics 35° 3.5 x. 38 ma x.1 a m 35° 23 .906 screw ISO1580-M6x8 (-N/-FN) M6x10 (-LN) lock washer DIN 137-B6 tightening torque max. 2.5 Nm ø12.5+0.2 .492+.008 max .748 max.19 6.5 .256 1 1 2 4 6 810 20 40 6080100 … times rated current 413-...-LN2/-N2 30...90 A 10000 +75 °C +167 °F 1000 +23 °C +73.4 °F -55 °C -67 °F 100 10 1 0.1 413-K54-FN2/-N2 .492+.008 ø12.5+0.2 max.19 50 SW14 .551 32 1.26 max .748 9.5 .374 thickness 1.5 - 3 mm .059 - .118 in. 9.5±0.2 .374±.008 0.01 mounting holes current rating in A 2.7 .106 10 0.001 Trip time in seconds max. 63 max. 2.48 49 1.93 55 2.17 max. 64 max. 2.52 1.5 .059 min.3 ON lock washer 3.5 x. 38 ma x.1 a m 35° 23 .906 -55 °C -67 °F 100 white screw ISO1580-M6x8 (-N/-FN) M6x10 (-LN) lock washer DIN 137-B6 tightening torque max. 2.5 Nm location pin +23 °C +73.4 °F 0.01 tightening torque max. 4 Nm M12x1 black ø10.6 .417 35° +75 °C +167 °F 0.1 thickness 1.5 - 3 mm .059 - .118 in. min .118 50 2.7 .106 SW14 .551 32 1.26 413-K54-... OFF 9.5±0.2 .374±.008 min. ø3.2 min .126 9.5 .374 Trip time in seconds mounting holes current rating in A 12.2 .480 7 .276 10000 1000 413-K14-LN2 location pin 413-...-FN2 30...55 A 0.001 1 2 4 6 810 20 40 6080100 … times rated current min. ø3.2 min .126 This is a metric design and millimeter dimensions take precedence ( mm ) inch 2 www.e-t-a.de 1948 High Performance Thermal Circuit Breaker 413-... Accessories (approved to VG 95345, part 23) Accessories Splash cover /hex nut assembly with O ring (IP66 and IP67) X 200 801 08 nickel plated nut M12x1, transparent cover X 200 801 03 matt black finish nut M12x1, black cover X 200 801 12 with blackened nut and transparent cover Identification collar to be snapped on the push button Y 307 004 01 black Y 307 004 02 white Y 307 004 03 red Y 307 004 04 green Y 307 004 05 blue ø14 .551 6.4 .252 ø6.85 .270 1 M12x1 ø12.35 .486 Splash cover black /hex nut assembly with O ring (IP54) X 200 802 01 nickel plated nut M12x1 X 200 802 02 matt black finish nut M12x1 0.65 .026 M12x1 Lock out ring to block the push button in OFF position Y 307 005 01 red Y 307 005 02 black Actuator extension (black) to be fitted on the push button X 200 803 01 7.7 .303 ø14.6 .575 ø20 ø.787 17 .669 ø10.9 .429 0.8 .031 Approvals Authority Standard Rated voltage Current ratings UL UL1077 DC 28 V 30 A…90 A CSA C22.2 No 235 DC 28 V 30 A…90 A QPL Sweden Defence Material Admin. TL 5925-001 DC 28 V 30 A…50 A This is a metric design and millimeter dimensions take precedence ( mm ) inch All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved.Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 1948 www.e-t-a.de 3
413-K14-LN2-50A 价格&库存
很抱歉,暂时无法提供与“413-K14-LN2-50A”相匹配的价格&库存,您可以联系我们找货
