AiP74LVC1G17GB235.TR
    I-CORE(中微爱芯)
    SOT23-5
    缓冲器/驱动器 SOT23-5 Vcc=1.65V~5.5V Ptot=250mW
AiP74LVC1G17GB235.TR 数据手册
Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC1G17-AX-LJ-B005EN or e AiP74LVC1G17 Single Buffer Schmitt Trigger Specification i-c Product Specification Revision History: Version Date Description 2017-07-A1 2021-05-A2 2017-07 2021-05 New Modify Transfer Characteristics Parameter 2021-09-A3 2021-09 2021-12-A4 2022-03-A5 2021-12 2022-03 Modify ambient temperature to -40℃~+105℃ and add electrical characteristics of -40℃~+105℃; Modify ordering information Modify ordering information Modify ordering information note 1 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 1/ 12 VER:2022-03-A5 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC1G17-AX-LJ-B005EN 1、General Description The AiP74LVC1G17 provides a buffer function with Schmitt trigger input. It is capable of transforming slowly changing input signals into sharply defined outputs. The input can be driven from either 3.3V or 5V devices. This feature allows the use of this device in a mixed 3.3V and 5V environment. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. or e Features:  Wide supply voltage range from 1.65V to 5.5V  ±24mA output drive (VCC=3.0V)  CMOS low power consumption  Latch-up performance exceeds 250mA  Direct interface with TTL levels  Unlimited rise and fall times  Input accepts voltages up to 5V  Specified from -40℃ to +105℃  Packaging information: SOT-23-5/SOT-353 Ordering Information: Reel packing specifications: Part number Packaging form Marking code Reel quantity Boxed reel quantity SOT-23-5 AFXX 3000 PCS/reel 30000 PCS/box AiP74LVC1G17GC353.TR SOT-353 AFXX 3000 PCS/reel 30000 PCS/box i-c AiP74LVC1G17GB235.TR Notes Dimensions of plastic enclosure: 2.9mm×1.6mm Pin spacing: 0.95mm Dimensions of plastic enclosure: 2.1mm×1.3mm Pin spacing: 0.65mm Note 1: “XX” refers to variable content, meaning year and package batch serial number. Note 2: If the physical information is inconsistent with the ordering information, please refer to the actual product. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 2/ 12 VER:2022-03-A5 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC1G17-AX-LJ-B005EN 2、Block Diagram And Pin Description 2.1、Block Diagram Figure 1. Logic symbol e Figure 2. IEC logic symbol or Figure 3. Logic diagram i-c 2.2、Pin Configurations 2.3、Pin Description Pin No. 1 2 3 4 5 Pin Name n.c. A GND Y VCC Description not connected data input ground (0V) data output supply voltage 2.4、Function Table Input A L H Note: H=HIGH voltage level; L=LOW voltage level. Output Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 Y L H 3/ 12 VER:2022-03-A5 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC1G17-AX-LJ-B005EN 3、Electrical Parameter 3.1、Absolute Maximum Ratings (Voltages are referenced to GND (ground = 0V), unless otherwise specified.) Symbol VCC VI output voltage VO Min. -0.5 -0.5 -0.5 -0.5 Max. +6.5 +6.5 VCC+0.5 +6.5 Unit V V V V IIK VI < 0V -50 - mA IOK VO > VCC or VO < 0V - ±50 mA IO ICC IGND VO=0V to VCC - -100 ±50 +100 - mA mA mA - -65 +150 ℃ - - 250 mW Tstg Ptot or input clamping current output clamping current output current supply current ground current storage temperature total power dissipation Soldering temperature Conditions Active mode Power-down mode; VCC=0V e Parameter supply voltage input voltage TL 10s ℃ 250 3.2、Recommended Operating Conditions Symbol VCC VI output voltage VO Conditions Active mode Power-down mode; VCC=0V Min. 1.65 0 0 0 Typ. - Max. 5.5 5.5 VCC 5.5 Unit V V V V - -40 - +105 ℃ i-c Parameter supply voltage input voltage ambient temperature Tamb Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 4/ 12 VER:2022-03-A5 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC1G17-AX-LJ-B005EN 3.3、Electrical Characteristics 3.3.1、DC Characteristics 1 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground = 0V), unless otherwise specified.) HIGH-level output voltage LOW-level output voltage Symbol VOH VOL Conditions IO=-100uA; VCC=1.65V to 5.5V IO=-4mA; VCC=1.65V IO=-8mA; VCC=2.3V VI = VT+ or VTIO=-12mA; VCC=2.7V IO=-24mA; VCC=3.0V IO=-32mA; VCC=4.5V IO=100uA; VCC=1.65V to 5.5V IO=4mA; VCC=1.65V IO=8mA; VCC=2.3V VI = VT+ or VTIO=12mA; VCC=2.7V IO=24mA; VCC=3.0V IO=32mA; VCC=4.5V Min. VCC0.1 1.2 1.9 2.2 2.3 3.8 Typ. Max. Unit - - V - - V V V V V - - 0.10 V - - 0.45 0.30 0.40 0.55 0.55 V V V V V e Parameter II VI=5.5V or GND; VCC=0V to 5.5V - ±0.1 ±1 uA IOFF VI or VO=5.5V; VCC=0V - ±0.1 ±2 uA supply current ICC - 0.1 4 uA - 5 500 uA - 5.0 - pF or input leakage current power-off leakage current VI=5.5V or GND; IO=0A; VCC=1.65V to 5.5V per pin; VI=VCC-0.6V; IO=0A; VCC=2.3V to 5.5V i-c additional ΔICC supply current input CI capacitance Note: All typical values are measured at maximum VCC and Tamb=25℃. 3.3.2、DC Characteristics 2 (Tamb=-40℃ to +105℃, voltages are referenced to GND (ground = 0V), unless otherwise specified.) Parameter HIGH-level output voltage LOW-level output voltage Symbol VOH VOL Conditions IO=-100uA; VCC=1.65V to 5.5V IO=-4mA; VCC=1.65V IO=-8mA; VCC=2.3V VI = VT+ or VTIO=-12mA; VCC=2.7V IO=-24mA; VCC=3.0V IO=-32mA; VCC=4.5V IO=100uA; VCC=1.65V to 5.5V IO=4mA; VCC=1.65V IO=8mA; VCC=2.3V VI = VT+ or VTIO=12mA; VCC=2.7V IO=24mA; VCC=3.0V IO=32mA; VCC=4.5V Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 Min. VCC0.1 0.95 1.7 1.9 2.0 3.4 Typ. Max. Unit - - V - - V V V V V - - 0.10 V - - 0.70 0.45 0.60 0.80 0.80 V V V V V 5/ 12 VER:2022-03-A5 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 input leakage current power-off leakage current rev:B3 Number:AiP74LVC1G17-AX-LJ-B005EN II VI=5.5V or GND; VCC=0V to 5.5V - - ±1 uA IOFF VI or VO=5.5V; VCC=0V - - ±2 uA - - 4 uA - - 500 uA VI=5.5V or GND; IO=0A; VCC=1.65V to 5.5V additional per pin; VI=VCC-0.6V; IO=0A; ΔICC supply current VCC=2.3V to 5.5V Note: All typical values are measured at maximum VCC and Tamb=25℃. supply current ICC 3.3.3、AC Characteristics 1 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground = 0V), unless otherwise specified.) Symbol A to Y propagation delay tpd Conditions VCC=1.65V to 1.95V VCC=2.3V to 2.7V see Figure 5 VCC=2.7V VCC=3.0V to 3.6V VCC=4.5V to 5.5V Min. 1.0 0.7 0.7 0.7 0.7 Typ. 4.1 2.8 3.2 3.0 2.2 Max. 11.0 6.5 6.5 5.5 5.0 Unit ns ns ns ns ns e Parameter i-c or Power dissipation CPD VCC=3.3V; VI=GND to VCC 16.6 capacitance Note: [1] Typical values are measured at Tamb=25℃ and VCC=1.8V, 2.5V, 2.7V, 3.3V and 5.0V respectively. [2] tpd is the same as tPLH and tPHL. [3] CPD is used to determine the dynamic power dissipation (PD in uW). PD=CPD×VCC2×fi×N+∑(CL×VCC2×fo) where: fi=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; VCC=supply voltage in V; N=number of inputs switching; ∑(CL×VCC2×fo)=sum of outputs. pF 3.3.4、AC Characteristics 2 (Tamb=-40℃ to +105℃, voltages are referenced to GND (ground = 0V), unless otherwise specified.) Parameter Symbol A to Y propagation delay tpd Conditions VCC=1.65V to 1.95V VCC=2.3V to 2.7V see Figure 5 VCC=2.7V VCC=3.0V to 3.6V VCC=4.5V to 5.5V Min. 1.0 0.7 0.7 0.7 0.7 Typ. - Max. 14.0 8.5 8.5 7.0 6.5 Unit ns ns ns ns ns Note: [1] Typical values are measured at Tamb=25℃ and VCC=1.8V, 2.5V, 2.7V, 3.3V and 5.0V respectively. [2] tpd is the same as tPLH and tPHL. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 6/ 12 VER:2022-03-A5 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC1G17-AX-LJ-B005EN 3.3.5、Transfer Characteristics 1 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground = 0V), unless otherwise specified.) Symbol positive-going threshold voltage VT+ see Figure 6 and Figure 7 negative-going threshold voltage VT- see Figure 6 and Figure 7 hysteresis voltage VH see Figure 6, Figure 7 and Figure 8 Conditions VCC=1.8V VCC=2.3V VCC=3.0V VCC=4.5V VCC=5.5V VCC=1.8V VCC=2.3V VCC=3.0V VCC=4.5V VCC=5.5V VCC=1.8V VCC=2.3V VCC=3.0V VCC=4.5V VCC=5.5V Min. 0.82 1.03 1.29 1.84 2.19 0.45 0.64 0.86 1.35 1.61 0.24 0.26 0.27 0.28 0.29 Typ. 1.02 1.25 1.5 2.15 2.6 0.6 0.8 1.1 1.75 2.15 0.4 0.4 0.42 0.45 0.47 Max. 1.2 1.45 1.71 2.41 2.91 0.75 0.96 1.34 2.09 2.59 0.54 0.57 0.64 0.65 0.75 Unit V V V V V V V V V V V V V V V or e Parameter 3.3.6、Transfer Characteristics 2 (Tamb=-40℃ to +105℃, voltages are referenced to GND (ground = 0V), unless otherwise specified.) Symbol positive-going threshold voltage VT+ see Figure 6 and Figure 7 Conditions VCC=1.8V VCC=2.3V VCC=3.0V VCC=4.5V VCC=5.5V VCC=1.8V VCC=2.3V VCC=3.0V VCC=4.5V VCC=5.5V VCC=1.8V VCC=2.3V VCC=3.0V VCC=4.5V VCC=5.5V i-c Parameter negative-going threshold voltage VT- see Figure 6 and Figure 7 hysteresis voltage VH see Figure 6, Figure 7 and Figure 8 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 Min. 0.79 1.00 1.26 1.81 2.16 0.45 0.64 0.86 1.35 1.61 0.17 0.20 0.21 0.22 0.23 Typ. - Max. 1.2 1.45 1.71 2.41 2.91 0.78 0.99 1.37 2.12 2.62 0.54 0.57 0.64 0.65 0.75 Unit V V V V V V V V V V V V V V V 7/ 12 VER:2022-03-A5 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC1G17-AX-LJ-B005EN 4、Testing Circuit 4.1、AC Testing Circuit Figure 4. Test circuit for measuring switching times i-c or 4.2、AC Testing Waveforms e Definitions for test circuit: RL=Load resistance. CL=Load capacitance including jig and probe capacitance. RT=Termination resistance; should be equal to the output impedance Zo of the pulse generator. VEXT=External voltage for measuring switching times. Figure 5. The data input (A) to output (Y) propagation delays 4.3、Transfer Characteristics Waveforms Figure 6. Transfer characteristic Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 8/ 12 VER:2022-03-A5 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC1G17-AX-LJ-B005EN or e Figure 7. Definition of VT+, VT- and VH Figure 8. Typical transfer characteristics i-c 4.4、Measurement Points Supply voltage VCC 1.65V to 1.95V 2.3V to 2.7V 2.7V 3.0V to 3.6V 4.5V to 5.5V 4.5、Test Data Supply voltage VCC 1.65V to 1.95V 2.3V to 2.7V 2.7V 3.0V to 3.6V 4.5V to 5.5V Input Output VM 0.5×VCC 0.5×VCC 1.5V 1.5V 0.5×VCC VM 0.5×VCC 0.5×VCC 1.5V 1.5V 0.5×VCC Input VI VCC VCC 2.7V 2.7V VCC tr = tf ≤ 2.0ns ≤ 2.0ns ≤ 2.5ns ≤ 2.5ns ≤ 2.5ns Load CL 30pF 30pF 50pF 50pF 50pF Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 VEXT RL 1kΩ 500Ω 500Ω 500Ω 500Ω tPLH, tPHL open open open open open 9/ 12 VER:2022-03-A5 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC1G17-AX-LJ-B005EN 5、Package Information i-c or e 5.1、SOT-23-5 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 10/ 12 VER:2022-03-A5 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC1G17-AX-LJ-B005EN i-c or e 5.2、SOT-353 Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 11/ 12 VER:2022-03-A5 Wuxi I-CORE Electronics Co., Ltd. Tab: 835-12 rev:B3 Number:AiP74LVC1G17-AX-LJ-B005EN 6、Statements And Notes 6.1、The name and content of Hazardous substances or Elements in the product Hazardous substances or Elements Part name Lead and lead compo unds Mercur y and mercur y compo unds Cadm ium and cadmi um comp ounds Hexaval ent chromiu m compoun ds Polybro minated biphenyl s Polybro minate d biphen yl ethers Dibutyl phthala te Butylbe nzyl phthala te Di-2-et hylhex yl phthala te Diisobu tyl phthala te ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Plastic resin ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Chip ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ The lead ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Plastic sheet installed ○ ○ ○ e Lead frame ○ ○ ○ ○ ○ ○ ○ ○:Indicates that the content of hazardous substances or elements in the detection limit of the following the SJ/T11363-2006 standard. ×:Indicates that the content of hazardous substances or elements exceeding the SJ/T11363-2006 Standard limit requirements. or explanation 6.2、Notion Recommended carefully reading this information before the use of this product; The information in this document are subject to change without notice; i-c This information is using to the reference only, the company is not responsible for any loss; The company is not responsible for the any infringement of the third party patents or other rights of the responsibility. Address:Building B4,NO.777,Jianzhu Road,Binhu District,Wuxi City,Jiangsu Province http://www.i-core. cn P.C.:214072 12/ 12 VER:2022-03-A5
AiP74LVC1G17GB235.TR 价格&库存
很抱歉,暂时无法提供与“AiP74LVC1G17GB235.TR”相匹配的价格&库存,您可以联系我们找货
