SS32 THRU SS320
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 20 to 200 V
Forward Current - 3.0A
PINNING
PIN
Features
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: SS32~SS320
Simplified outline SMA and symbol
MECHANICAL DATA
• Case: SMA
• Terminals: Solderable per MIL-STD-750, Method 2026
• Approx. Weight: 60mg / 0.0021oz
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Symbols
Parameter
SS32
SS34
SS36
SS38
SS310
SS312
SS315
SS320
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
I F(AV)
3.0
A
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
80
A
Max Instantaneous Forward Voltage at 3 A
VF
0.55
T a =100°C
Typical Junction Capacitance (1)
Typical Thermal Resistance
(2)
Operating Junction Temperature Range
Storage Temperature Range
0.85
0.95
V
IR
0.5
5
0.3
3
mA
Cj
450
400
pF
Maximum DC Reverse Current T a = 25°C
at Rated DC Reverse Voltage
0.70
RθJA
70
°C/W
Tj
-55 ~ +125
°C
T stg
-55 ~ +150
°C
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
Page 1 of 3
SS32 THRU SS320
Fig.2 Typical Reverse Characteristics
3.5
3.0
2.4
1.8
1.2
0.6
Single phase half-wave 60 Hz
0.0
25
75
50
100
125
150
Instaneous Reverse Current ( μA)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
10 4
SS32-SS36
SS38-SS320
10
1
T J =25°C
10 0
80
100
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Fii g . 4 Typ
F
Ty p ic
ica
a l Ju
Junction C
Capa
ap a c i t a n ce
T J =2
=25°C
5°C
JJu
u n c t i o n C apa
ap a c i t anc
an c e ((p
pF)
1.0
SS32/SS34
SS34A/SS38
SS310/SS312
SS315/SS320
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
5 00
00
100
SS32~SS36
SS38~SS320
10
1
0.1
0.
1
1
10
1
1
00
R evers
ever s e Vol
Vo l t a ge ((V
V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.5- Typical Transient Thermal Impedance
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
100
10
00
Instaneous Forward Voltage (V)
10
Number of Cycles at 60Hz
100
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
T J =75°C
10 2
Case Temperature (°C)
Peak Forward Surage Current (A)
T J =100°C
10 3
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
Page 2 of 3
SS32 THRU SS320
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
A
SMA
c
a
e
B
g
D
E
B
c
e
g
max
2.2
4.5
2.8
5.3
0.31
1.6
1.5
min
1.9
4.0
2.4
4.8
0.15
1.3
0.9
max
87
181
110
209
12
63
59
min
75
157
94
189
6
51
35
a
0.3
12
SS24F
SS22F
SS26F
mil
e
A
UNIT
mm
g
e
E
D
The recommended mounting pad size
Marking
Type number
2.4
(94)
SS32
SS32
1.8
(71)
1.8
(71)
1.8
(71)
Marking code
mm
Unit :
(mil)
SS34
SS34
SS36
SS36
SS38
SS38
SS310
SS310
SS312
SS312
SS315
SS315
SS320
SS320
Page 3 of 3
很抱歉,暂时无法提供与“SS34”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.18555
- 200+0.14764
- 600+0.12658
- 2000+0.11362
- 10000+0.10260
- 20000+0.09666
