G30N04D3
N-Channel Enhancement Mode Power MOSFET
Description
The G30N04D3 uses advanced trench technology to
provide excellent RDS(ON) , low gate charge. It can be used in
a wide variety of applications.
Schematic diagram
General Features
l
l
l
l
l
VDS
ID (at VGS = 10V)
RDS(ON) (at VGS = 10V)
RDS(ON) (at VGS = 4.5V)
100% Avalanche Tested
40V
30A
< 9mΩ
< 12mΩ
pin assignment
l RoHS Compliant
Application
l Power switch
l DC/DC converters
DFN3X3-8L
Ordering Information
Device
G30N04D3
Package
DFN3X3-8L
Marking
Packaging
G30N04
5000psc/Reel
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
40
V
ID
30
A
IDM
110
A
Gate-Source Voltage
VGS
±20
V
Power Dissipation
PD
50
W
EAS
92
mJ
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
Thermal Resistance, Junction-to-Ambient
RthJA
60
ºC/W
Maximum Junction-to-Case
RthJC
2.5
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Single pulse avalanche energy
(note2)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466(A1378)
G30N04D3
Specifications TJ = 25ºC, unless otherwise noted
Parameter
Symbol
Test Conditions
Drain-Source Breakdown Voltage
V(BR)DSS
Zero Gate Voltage Drain Current
Gate-Source Leakage
Value
Unit
Min.
Typ.
Max.
VGS = 0V, ID = 250µA
40
V
IDSS
VDS = 40V, VGS = 0V
1
μA
IGSS
VGS = ±20V
±100
nA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = 250µA
1
1.8
2.5
V
Drain-Source On-Resistance
RDS(on)
VGS = 10V, ID = 20A
6.5
9
VGS = 4.5V, ID = 15A
8
12
Forward Transconductance
gFS
VGS = 5V, ID = 6.5A
75
1940
176
166
30
4.2
9.5
6.4
17
30
17
Static Parameters
mΩ
S
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
Turn-off Delay Time
td(off)
Turn-off Fall Time
VGS = 0V,
VDS = 20V,
f = 1.0MHz
VDD = 20V,
ID = 6.5A,
VGS = 10V
VDD = 20V,
ID = 6.5A,
RG = 3Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
Body Diode Voltage
IS
TC = 25ºC
30
A
VSD
TJ = 25ºC, ISD = 20A, VGS = 0V
1.2
V
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
EAS condition : Tj=25℃ ,VDD=40V,VGS=10V,L=0.5mH,Rg=25Ω
3.
Identical low side and high side switch with identical RG
www.gofordsemi.com
TEL:0755-29961263
G30N04D3
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
G30N04D3
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 1. Output Characteristics
10V
6V
ID, Drain Current (A)
100
120
5V
VDS= 5V
4..5V
120
Figure 2. Transfer Characteristics
80
4V
60
40
VGS=3.5V
2
3
100
80
60
25℃
40
VDS, Drain-to-Source Voltage (V)
Vgs Gate-Source Voltage(V)
RDS(on),On-Resistance(mΩ)
9
8
VGS= 4.5V
VGS= 10V
5
4
3
2
Ciss
1500
1000
Coss
Crss
10
6
4
2
40
40
VDS Drain-Source Voltage(V)
www.gofordsemi.com
8
Is, Reverse Drain Current (A)
Capacitance(pF)
2500
VDS = 20V,
ID = 6.5A
Figure 6. Source-Drain Diode Forward
3000
Qg Gate Charge(nC)
Figure 5. Capacitance
500
10
ID-Drain Current(A)
2000
6
Figure 4. Gate Charge
10
6
4
VGS, Gate-to-Source Voltage (V)
Figure 3. Drain Source On Resistance
7
2
TEL:0755-29961263
VSD, Source-to-Drain Voltage (V)
G30N04D3
Figure 7. Drain-Source On-Resistance
Figure 8. Safe Operation Area
VGS = 4.5V
ID = 15A
ID, Drain Current(A)
RDS(on), (Normalized)
VGS = 10V,
ID = 20A
TJ, Junction Temperature (ºC)
VDS, Drain-Source Voltage(V)
ZthJC, Thermal Impedance (ºC/W)
Figure 9. Normalized Maximum Transient
Thermal Impedance
2.5°C/W
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
G30N04D3
DFN3X3-8L Package information
D1
A
D2
E3
θ
E5
t
E2
E1 E
E4
b
K
L
e
c
L1
D
A1
COMMON
MM
SYMBOL
A
A1
b
c
D
D1
D2
E
E1
E2
E3
E4
E5
e
K
L
L1
t
θ
www.gofordsemi.com
MIN
NO M
MAX
0.70
0.20
0.10
3.15
3.00
2.29
3.15
2.90
1.54
0.28
0.37
0.10
0.60
0.59
0.30
0.06
10°
0.75
0.30
0.152
3.30
3.15
2.45
3.30
3.05
1.74
0.48
0.57
0.20
0.65
0.69
0.40
0.125
0.075
12°
0.85
0.05
0.40
0.25
3.45
3.25
2.65
3.45
3.20
1.94
0.65
0.77
0.30
0.70
0.89
0.50
0.20
0.13
14°
TEL:0755-29961263
很抱歉,暂时无法提供与“G30N04D3”相匹配的价格&库存,您可以联系我们找货
