JE-112DM
JE-112DM
    GOODSKY(国兴)
    插件,20x10mm
    功率继电器 单刀单掷 12V 200mW RELAY_20X10MM_TM
JE-112DM 数据手册
JE MAIN FEATURE 1. Low coil power consumption 200mW. 2. Dielectric Strength up to 4,000VAC. 3. Low profile 10.5 mm. 4. Clearance and creepage more than 5.0 mm. 5. UL Class F insulation available. 6. In accordance with IEC 60730-1. 7. Halogen Free series available. 8. Comply with RoHS and REACH regulations. CONTACT RATING JE (DM) JE (D) 8A 250VAC 8A 30VDC AC 440V DC 30V 8A 2000VA 240W Ag Alloy SPST 5A 250VAC 5A 30VDC AC 380V DC 30V 5A 1,250VA 150W Ag Alloy SPDT Load Type Rated Load (Resistive) Max. Allowable Voltage Max. Allowable Current Max. Allowable Power Force Contact Material Contact Form APPLICATION 1. Industrial Electronic Instrument, PLC, Timers, Temperature Control & Measure. 2. White goods. 3. Building Automation. 4. Air Conditioner. 5. Actuating Driver. PERFORMANCE (AT INITIAL VALUE) Contact Resistance ..............100 m Max.@1A,6VDC Operate Time........................8 mSec. Max. Release Time .......................6 mSec. Max. Dielectric Strength: Between Coil & Contact....... 4,000VAC at 50/60 Hz for one minute Between Contacts ................1,000VAC at 50/60 Hz for one minute Surge Strength .....................10,000V (between coil & contact 1.2x50μSec.) Insulation Resistance ...........100 Mega Min. at 500VDC Max. On/Off Switching: Electrical ...............................6 Cycles per Minute Mechanical............................300 Cycles per Minute 42 Temperature Range ........ -40 +85°C Humidity Range ............... 45 85% RH. Coil Temperature Rise .... 40°C Max. Vibration: Destruction ...................... 10 to 55 to 10 Hz,0.75 mm single amplitude (1.5mm double amplitude) Malfunction ...................... 10 to 55 to 10 Hz,0.75 mm single amplitude (1.5mm double amplitude) Shock: Destruction ...................... 1,000 m/S 2 2 Malfunction ...................... 100 m/S Life Expectancy: 7 Mechanical ....................... 10 Operations at No load condition 5 Electrical .......................... 10 Operations at Rated Resistive Load Weight ............................. about 6.0 g SAFETY STANDARD & FILE NUMBER UL & C-UL ....................... E141060 VDE .................................. 40013405 JE COIL SPECIFICATION (AT 20°C) Nominal Voltage (VDC) JE 3 5 6 9 12 24 48 Power Nominal Coil Resistance Consumption Current (mA) (Ω±10%) (W) 66.7 40.0 33.3 22.2 16.7 8.3 4.2 45 125 180 405 720 2,880 11,520 Abt. 0.2 Pull-In Voltage Drop-Out (VDC) Voltage (VDC) 75% Maximum 5% Minimum Maximum Allowable Voltage (VDC) JE Coil Sensitivity 150% ORDERING INFORMATION JE - 1 12 D M G F Insulation System: Nil: Standard Class F: Class F Contact Material: Nil: AgNi G: AgNi Gilded O: AgNi Plated N: AgSnO2 S: AgSnO2 Gilded Contact Form: Nil: One Form C M: One Form A Coil Sensitivity: D: Standard DC Coil Voltage: 03: 3V, 05: 5V, 06: 6V, 09: 9V, 12: 12V, 24: 24V, 48: 48V Number of Pole: 1: One Pole Type: JE CLASSIFICATION Model Coil Sensitivity Contact Form Wash Tight JE Standard DC 1C JE - 1 D JE - 1 1A DM DIMENSION ( ≤ 5mm ± 0.2mm, > 5mm ± 0.3mm, the tolerance of PCB thru hole: +0.1mm) JE-D Bottom View JE-DM P.C.B Layout Bottom View Bottom View REFERENCE DATA P.C.B Layout Bottom View V.01EZ www.goodsky.com.tw 43
JE-112DM 价格&库存
很抱歉,暂时无法提供与“JE-112DM”相匹配的价格&库存,您可以联系我们找货
