GRF5109DS
GRF5109DS
    GUERRILLARF
    QFN16_3X3MM_EP
    RF放大器 28.5 dBm POWER-LNA™0.1 to 2.2 GHz
GRF5109DS 数据手册
Data Sheet RELEASE A DATA SHEET GRF5109 28.5 dBm POWER-LNA™ 0.1 to 2.2 GHz FEATURES DESCRIPTION Excellent P1dB, IP3, ACLR and NF Performance Flexible Biasing Provides Latitude for Linearity Optimization 160 mA Native Mode Quiescent Current Consumption 5 V Supply Voltage 50 Ω Single-ended Input and Output Impedances -40 to 105 °C Operating Temperature Range Process: GaAs pHEMT The GRF5109 is a high linearity PA/Linear Driver with low noise figure (NF). It delivers excellent P1dB, IP3 and NF over a wide range of frequencies with fractional bandwidths of roughly 5 to 10%. This device can be tuned over a wide range of frequencies from around 0.1 GHz up to 2.2 GHz. Please consult with the GRF applications engineering team for custom tuning/evaluation board data. Compact 3 x 3 mm QFN-16 Package BLOCK DIAGRAM OP1dB: 28.5 dBm GND/NC OIP3: 43.5 dBm BIAS1 GND/NC Gain: 19 dB GND/NC Reference: 5 V / 830 MHz / 160 mA IDDQ Evaluation Board Noise Figure: 1.3 dB APPLICATIONS 12 BIAS2 11 GND/NC 3 10 RF_OUT/VDD 4 9 RF_OUT/VDD VENABLE 1 GND/NC 2 RF_IN RF_IN Bias Control Power Amplifier Linear Driver Amplifier for High PAR Waveforms 5 6 7 8 GND/NC GND/NC GND/NC GND/NC Multi-stage LNA Guerrilla RF Proprietary Information. • ©2023 Guerrilla RF, Inc. • All rights reserved. • March 24, 2023 www.guerrilla-rf.com • (336) 510-7840 • sales@guerrilla-rf.com • 2000 Pisgah Church Road. Greensboro, NC 27455 1 GND/NC BIAS1 RELEASE A DATA SHEET GND/NC GND/NC GRF5109 28.5 dBm Power-LNA™ 0.1 to 2.2 GHz 12 BIAS2 11 GND/NC 3 10 RF_OUT/VDD 4 9 RF_OUT/VDD 7 8 GND/NC RF_IN GND/NC RF_IN Bias Control 6 2 GND/NC GND/NC 5 1 GND/NC VENABLE 3 x 3 mm QFN-16 Pin Out (Top View) Guerrilla RF Proprietary Information. • ©2023 Guerrilla RF, Inc. • All rights reserved. • March 24, 2023 2 www.guerrilla-rf.com • (336) 510-7840 • sales@guerrilla-rf.com • 2000 Pisgah Church Road. Greensboro, NC 27455 GRF5109 28.5 dBm Power-LNA™ 0.1 to 2.2 GHz RELEASE A DATA SHEET Pin Assignments Pin Name Description Note 1 VENABLE Enable Voltage Input VENABLE and series resistor sets IDDQ. VENABLE ≤ 0.2 V disables device. On-die pull-down resistor will turn the part off if this node is allowed to float. 2, 5, 6, 7, 8, 11, 13, 15, 16 GND/NC Ground or No Connect No internal connection to die. These pins can be left unconnected, or be connected to ground (recommended). Use a via as close to the pin as possible if grounded. 3, 4 RF_IN RF Input 9, 10 RF_OUT/VDD PA Output/Bias 12 Bias2 Bias Circuit Supply Connect to VDD through external resistor. 14 Bias1 Bias Circuit Ground Consult application schematic. PKG BASE GND Ground Pins 3 & 4 tied together on system board. Pins 9 & 10 tied together on system board. Supply VDD here. Provides DC and RF ground for the LNA, as well as thermal heat sink. Recommend multiple 8 mil vias beneath the package for optimal RF and thermal performance. Refer to evaluation board top layer graphic on schematic page. Guerrilla RF Proprietary Information. • ©2023 Guerrilla RF, Inc. • All rights reserved. • March 24, 2023 www.guerrilla-rf.com • (336) 510-7840 • sales@guerrilla-rf.com • 2000 Pisgah Church Road. Greensboro, NC 27455 3 GRF5109 28.5 dBm Power-LNA™ 0.1 to 2.2 GHz RELEASE A DATA SHEET Absolute Ratings Parameter Drain Voltage Transient Average RF Input Power CW: Load VSWR < 2:1; Duration: 106 Hours) Maximum Dissipated Power Symbol Max. Unit VDD 6 V PIN MAX 24 dBm 105 °C TMAX 170 °C PDISS MAX 1.0 W TPKG HEAT SINK Min. -40 Electrostatic Discharge Charged Device Model CDM 1500 V Human Body Model HBM 250 V Storage Temperature TSTG -65 Moisture Sensitivity Level MSL Storage 150 °C 1 -- Caution! ESD Sensitive Device. Exceeding Absolute Maximum Rating conditions may cause permanent damage. Note: For additional information, please refer to Manufacturing Note MN-001 — Package and Manufacturing Information. All Guerrilla RF products are provided in RoHS compliant lead (Pb)-free packaging requiring no exemptions. Additional information for this topic can be found at this link - Environmental and Restricted Substance Statement Library. Guerrilla RF Proprietary Information. • ©2023 Guerrilla RF, Inc. • All rights reserved. • March 24, 2023 4 www.guerrilla-rf.com • (336) 510-7840 • sales@guerrilla-rf.com • 2000 Pisgah Church Road. Greensboro, NC 27455 GRF5109 28.5 dBm Power-LNA™ 0.1 to 2.2 GHz RELEASE A DATA SHEET Recommended Operating Conditions Specification Parameter Supply Voltage Operating Temperature (Package Heat Sink) RF Frequency Range Symbol Min. Typ. Max. Unit VDD 3 5 6 V TPKG HEAT SINK -40 105 °C FRF 0.1 2.2 GHz Condition Typical Application Schematic Using the 0.7 to 0.96 GHz Tuning Set (note 1). RF_IN Port Impedance ZRFIN 50 Ω Single Ended with 2-element Match. RF_OUT Port Impedance ZRFOUT 50 Ω Single Ended with 3-element Match. Note 1: Operation outside this range is possible, but with degraded performance of some parameters. Guerrilla RF Proprietary Information. • ©2023 Guerrilla RF, Inc. • All rights reserved. • March 24, 2023 www.guerrilla-rf.com • (336) 510-7840 • sales@guerrilla-rf.com • 2000 Pisgah Church Road. Greensboro, NC 27455 5 GRF5109 28.5 dBm Power-LNA™ 0.1 to 2.2 GHz RELEASE A DATA SHEET Nominal Operating Parameters – General The following conditions apply unless noted otherwise: Typical Application Schematic using the 0.7 to 0.96 GHz tuning set, M1 = 5.5 kΩ, M10 = 230 Ω, M13 = 475 Ω, IDDQ = 160 mA, 50 Ω system impedance, FTEST = 0.83 GHz, TPKG HEAT SINK = -40 to +105 °C. Typical values are at VDD = 5 V, IDDQ = 160 mA, TPKG HEAT SINK = 25 °C. MIN/MAX specifications listed in italics are guaranteed via production test screening. All other parameters are guaranteed by design and characterization. Evaluation board losses are included within the specifications. Specification Parameter Symbol Supply Quiescent Current Min. IDDQ Operating Temperature Range TPKG HEAT SINK Typ. Max. Unit 160 190 mA VDD = VENABLE = 5 V, RBIAS = 5.5 kΩ. +105 °C Measured on Package Heat Sink. -40 Switching Rise Time TRISE 100 ns Switching Fall Time TFALL 800 ns Enable Current IENABLE 0.7 mA IDD 100 JC 80 Condition Disabled Mode Supply Current (Leakage) 500 µA Thermal Data Thermal Resistance: (IR Scan Method) °C/W On Standard Evaluation Board (note 2). Note 2: MTTF > 106 hours for TCHANNEL ≤ 170 °C. Guerrilla RF Proprietary Information. • ©2023 Guerrilla RF, Inc. • All rights reserved. • March 24, 2023 6 www.guerrilla-rf.com • (336) 510-7840 • sales@guerrilla-rf.com • 2000 Pisgah Church Road. Greensboro, NC 27455 GRF5109 28.5 dBm Power-LNA™ 0.1 to 2.2 GHz RELEASE A DATA SHEET Nominal Operating Parameters – RF (0.7 to 0.96 GHz, 5 V Operation) The following conditions apply unless noted otherwise: Typical Application Schematic using the 0.7 to 0.96 GHz tuning set, M1 = 5.5 kΩ, M10 = 230 Ω, M13 = 475 Ω, IDDQ = 160 mA, 50 Ω system impedance, FTEST = 0.83 GHz, TPKG HEAT SINK = -40 to +105 °C. Typical values are at VDD = 5 V, IDDQ = 160 mA, TPKG HEAT SINK = 25 °C. MIN/MAX specifications listed in italics are guaranteed via production test screening. All other parameters are guaranteed by design and characterization. Evaluation board losses are included within the specifications. Specification Parameter Symbol Min. Typ. Small Signal Gain S21 18 19 dB FRF = 0.7 to 0.96 GHz. Input Return Loss S11 >8 dB FRF = 0.7 to 0.96 GHz. Output Return Loss S22 >15 dB FRF = 0.7 to 0.96 GHz. Reverse Isolation S12 >26 dB FRF = 0.7 to 0.96 GHz. Evaluation Board Noise Figure NF 1.3 dB OIP3 43.5 dBm 28.5 dBm Output 3rd Order Intercept Output 1 dB Compression Power OP1dB 26.8 Max. Unit Condition Typical Operating Curve Conditions The following conditions apply unless noted otherwise: Typical Application Schematic using the 0.7 to 0.96 GHz tuning set, M1 = 5.5 kΩ, M10 = 230 Ω, M13 = 475 Ω, IDDQ = 160 mA, 50 Ω system impedance, FTEST = 0.83 GHz, TPKG HEAT SINK = -40 to +105 °C. Evaluation board losses are included within the plots. Guerrilla RF Proprietary Information. • ©2023 Guerrilla RF, Inc. • All rights reserved. • March 24, 2023 www.guerrilla-rf.com • (336) 510-7840 • sales@guerrilla-rf.com • 2000 Pisgah Church Road. Greensboro, NC 27455 7 GRF5109 28.5 dBm Power-LNA™ 0.1 to 2.2 GHz RELEASE A DATA SHEET GRF5109 Typical Operating Curves: 0.7 to 0.96 GHz Tune Guerrilla RF Proprietary Information. • ©2023 Guerrilla RF, Inc. • All rights reserved. • March 24, 2023 8 www.guerrilla-rf.com • (336) 510-7840 • sales@guerrilla-rf.com • 2000 Pisgah Church Road. Greensboro, NC 27455 GRF5109 28.5 dBm Power-LNA™ 0.1 to 2.2 GHz RELEASE A DATA SHEET GRF5109 Typical Operating Curves: 0.7 to 0.96 GHz Tune Guerrilla RF Proprietary Information. • ©2023 Guerrilla RF, Inc. • All rights reserved. • March 24, 2023 www.guerrilla-rf.com • (336) 510-7840 • sales@guerrilla-rf.com • 2000 Pisgah Church Road. Greensboro, NC 27455 9 GRF5109 28.5 dBm Power-LNA™ 0.1 to 2.2 GHz RELEASE A DATA SHEET GRF5109 Typical Operating Curves: 0.7 to 0.96 GHz Tune Guerrilla RF Proprietary Information. • ©2023 Guerrilla RF, Inc. • All rights reserved. • March 24, 2023 10 www.guerrilla-rf.com • (336) 510-7840 • sales@guerrilla-rf.com • 2000 Pisgah Church Road. Greensboro, NC 27455 GRF5109 28.5 dBm Power-LNA™ 0.1 to 2.2 GHz RELEASE A DATA SHEET GRF5109 Typical Operating Curves: S-Parameters (0.7 to 0.96 GHz Tune) Guerrilla RF Proprietary Information. • ©2023 Guerrilla RF, Inc. • All rights reserved. • March 24, 2023 www.guerrilla-rf.com • (336) 510-7840 • sales@guerrilla-rf.com • 2000 Pisgah Church Road. Greensboro, NC 27455 11 GRF5109 28.5 dBm Power-LNA™ 0.1 to 2.2 GHz RELEASE A DATA SHEET GRF5109 Typical Operating Curves: Stability Mu (0.7 to 0.96 GHz Tune) Note: Mu factor ≥ 1.0 implies unconditional stability Guerrilla RF Proprietary Information. • ©2023 Guerrilla RF, Inc. • All rights reserved. • March 24, 2023 12 www.guerrilla-rf.com • (336) 510-7840 • sales@guerrilla-rf.com • 2000 Pisgah Church Road. Greensboro, NC 27455 GRF5109 28.5 dBm Power-LNA™ 0.1 to 2.2 GHz RELEASE A DATA SHEET VDD M10 M9 VENABLE M16 M1 Sets IDDQ M17 Bias Control 2 11 L(series) 9 RF_OUT 8 7 6 5 4 M21 M20 M4 M2 Note: Spliced into standard evaluation board immediately above M18 10 3 RF_IN M13 M14 12 1 GRF5109 Standard Test Schematic GRF5109 Evaluation Board Assembly Diagram Guerrilla RF Proprietary Information. • ©2023 Guerrilla RF, Inc. • All rights reserved. • March 24, 2023 www.guerrilla-rf.com • (336) 510-7840 • sales@guerrilla-rf.com • 2000 Pisgah Church Road. Greensboro, NC 27455 13 GRF5109 28.5 dBm Power-LNA™ 0.1 to 2.2 GHz RELEASE A DATA SHEET GRF5109 Evaluation Board Assembly Diagram Reference: 0.7 to 0.96 GHz Tune Component Type Manufacturer Family Value Package Size Substitution M1 (See Curves) Resistor Various 5% Sets IDDQ 0402 ok M2 Inductor: High Q Coilcraft HP 5.1 nH 0402 ok M4 Capacitor: High Q Murata GJM 12.0 pF 0402 ok M9 Inductor Murata LQG 39 nH 0402 ok M10 Resistor Various 5% 230 Ω 0402 ok M13 Resistor Various 5% 475 Ω 0402 ok M14 Inductor: High Q Coilcraft HP 18 nH 0402 ok M16 Capacitor Murata GRM 0.1 μF 0402 ok M17 Capacitor Murata GRM 100 pF 0402 ok M20 Capacitor Murata GJM 5.1 pF 0402 ok M21 Capacitor Murata GJM 39 pF 0402 ok L(series) Inductor: High Q Coilcraft HP 3.3 nH 0402 ok Evaluation Board PA-V3_RevA Guerrilla RF Proprietary Information. • ©2023 Guerrilla RF, Inc. • All rights reserved. • March 24, 2023 14 www.guerrilla-rf.com • (336) 510-7840 • sales@guerrilla-rf.com • 2000 Pisgah Church Road. Greensboro, NC 27455 GRF5109 28.5 dBm Power-LNA™ 0.1 to 2.2 GHz RELEASE A DATA SHEET GRF5109 Bias Resistor Selection Curves Guerrilla RF Proprietary Information. • ©2023 Guerrilla RF, Inc. • All rights reserved. • March 24, 2023 www.guerrilla-rf.com • (336) 510-7840 • sales@guerrilla-rf.com • 2000 Pisgah Church Road. Greensboro, NC 27455 15 GRF5109 28.5 dBm Power-LNA™ 0.1 to 2.2 GHz RELEASE A DATA SHEET 3 x 3 mm QFN-16 Suggested PCB Footprint (Top View) 3 x 3 mm QFN-16 Package Dimensions Guerrilla RF Proprietary Information. • ©2023 Guerrilla RF, Inc. • All rights reserved. • March 24, 2023 16 www.guerrilla-rf.com • (336) 510-7840 • sales@guerrilla-rf.com • 2000 Pisgah Church Road. Greensboro, NC 27455 GRF5109 28.5 dBm Power-LNA™ 0.1 to 2.2 GHz RELEASE A DATA SHEET Package Marking Diagram • Line 1: “XXXX” = Device PART NUMBER. • Line 2: “YY” = YEAR. “WW” = WORK WEEK the Device was assembled. Tape and Reel Information Guerrilla RF’s tape and reel specification complies with Electronics Industries Association (EIA) standards for “Embossed Carrier Tape of Surface Mount Components for Automatic Handling” (reference EIA-481). See the following page for the Tape and Reel Specification and Device Package Information table, which includes units per reel. Devices are loaded with pins down into the carrier pocket with protective cover tape and reeled onto a plastic reel. Each reel is packaged in a cardboard box. There are product labels on the reel, the protective ESD bag and the outside surface of the box. For the Tape and Reel Reference Table, please refer to: https://www.guerrilla-rf.com/prodFiles/Manufacturing/MN001.pdf Cover Tape D Label Carrier Tape Tape and Reel Packaging with Reel Diameter Noted (D) Pin 1 Quadrant W Q1 Q2 Q1 Q2 Q1 Q2 Q1 Q2 Q1 Q1 Q2 Feed Direction P Carrier Tape Width (W), Pitch (P), Feed Direction and Pin 1 Quadrant Information Guerrilla RF Proprietary Information. • ©2023 Guerrilla RF, Inc. • All rights reserved. • March 24, 2023 www.guerrilla-rf.com • (336) 510-7840 • sales@guerrilla-rf.com • 2000 Pisgah Church Road. Greensboro, NC 27455 17 GRF5109 28.5 dBm Power-LNA™ 0.1 to 2.2 GHz RELEASE A DATA SHEET Revision History Revision Date Description of Change March 7, 2022 Updated to New Format. Updated Package Marking Diagram. Changed Revision from “Released” to “Release A”. March 18, 2022 Raised Supply Current (Leakage) “Max” from 150µA to 500µA. Raised Supply Current (Leakage) “Typical” from 30µA to 100µA. March 24, 2023 Lowered IENABLE current typical value from 2.0 mA to 0.7 mA. Guerrilla RF Proprietary Information. • ©2023 Guerrilla RF, Inc. • All rights reserved. • March 24, 2023 18 www.guerrilla-rf.com • (336) 510-7840 • sales@guerrilla-rf.com • 2000 Pisgah Church Road. Greensboro, NC 27455 GRF5109 28.5 dBm Power-LNA™ 0.1 to 2.2 GHz RELEASE A DATA SHEET Data Sheet Classifications Data Sheet Status Advance Notes S-parameter and NF data based on EM simulations for the fully packaged device using foundry-supplied transistor S-parameters. Linearity estimates based on device size, bias condition and experience with related devices. Preliminary All data based on evaluation board measurements taken within the Guerrilla RF Applications Lab. Any MIN/MAX limits represented within the data sheet are based solely on estimated part-to-part variations and process spreads. All parametric values are subject to change pending the collection of additional data. Release 0/ All data based on measurements taken with production-released material. TYP values are based on a combination of ATE and bench-level measurements, with MIN/MAX limits defined using modelled estimates that account for part-to-part variations and expected process spreads. Although unlikely, future refinements to the TYP/MIN/MAX values may be in order as multiple lots are processed through the factory. Release A-Z All data based on measurements taken with production-released material derived from multiple lots which have been fabricated over an extended period of time. MIN/MAX limits may be refined over previous releases as more statistically significant data is collected to account for process spreads. Information in this data sheet is specific to the Guerrilla RF, Inc. (“Guerrilla RF”) product identified. This data sheet, including the information contained in it, is provided by Guerrilla RF as a service to its customers and may be used for informational purposes only by the customer. Guerrilla RF assumes no responsibility for errors or omissions on this data sheet or the information contained herein. Information provided is believed to be accurate and reliable, however, no responsibility is assumed by Guerrilla RF for its use, nor for any infringement of patents, or other rights of third parties, resulting from its use. Guerrilla RF assumes no liability for any data sheet, data sheet information, materials, products, product information, or other information provided hereunder, including the sale, distribution, reproduction or use of Guerrilla RF products, information or materials. No license, whether express, implied, by estoppel, by implication or otherwise is granted by this data sheet for any intellectual property of Guerrilla RF, or any third party, including without limitation, patents, patent rights, copyrights, trademarks and trade secrets. All rights are reserved by Guerrilla RF. All information herein, products, product information, data sheets, and data sheet information are subject to change and availability without notice. Guerrilla RF reserves the right to change component circuitry, recommended application circuitry and specifications at any time without prior notice. Guerrilla RF may further change its data sheet, product information, documentation, products, services, specifications or product descriptions at any time, without notice. Guerrilla RF makes no commitment to update any materials or information and shall have no responsibility whatsoever for conflicts, incompatibilities, or other difficulties arising from any future changes. GUERRILLA RF INFORMATION, PRODUCTS, PRODUCT INFORMATION, DATA SHEETS AND DATA SHEET INFORMATION ARE PROVIDED “AS IS” AND WITHOUT WARRANTY OF ANY KIND, WHETHER EXPRESS, IMPLIED, STATUTORY, OR OTHERWISE, INCLUDING FITNESS FOR A PARTICULAR PURPOSE OR USE, MERCHANTABILITY, PERFORMANCE, QUALITY OR NON-INFRINGEMENT OF ANY INTELLECTUAL PROPERTY RIGHT; ALL SUCH WARRANTIES ARE HEREBY EXPRESSLY DISCLAIMED. GUERRILLA RF DOES NOT WARRANT THE ACCURACY OR COMPLETENESS OF THE INFORMATION, TEXT, GRAPHICS OR OTHER ITEMS CONTAINED WITHIN THESE MATERIALS. GUERRILLA RF SHALL NOT BE LIABLE FOR ANY DAMAGES, INCLUDING BUT NOT LIMITED TO ANY SPECIAL, INDIRECT, INCIDENTAL, STATUTORY, OR CONSEQUENTIAL DAMAGES, INCLUDING WITHOUT LIMITATION, LOST REVENUES OR LOST PROFITS THAT MAY RESULT FROM THE USE OF THE MATERIALS OR INFORMATION, WHETHER OR NO T THE RECIPIENT OF MATERIALS HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. Customers are solely responsible for their use of Guerrilla RF products in the Customer’s products and applications or in ways which deviate from Guerrilla RF’s published specifications, either intentionally or as a result of design defects, errors, or operation of products outside of published parameters or design specifications. Customers should include design and operating safeguards to minimize these and other risks. Guerrilla RF assumes no liability or responsibility for applications assistance, customer product design, or damage to any equipment resulting from the use of Guerrilla RF products outside of stated published specifications or parameters. Guerrilla RF Proprietary Information. • ©2023 Guerrilla RF, Inc. • All rights reserved. • March 24, 2023 www.guerrilla-rf.com • (336) 510-7840 • sales@guerrilla-rf.com • 2000 Pisgah Church Road. Greensboro, NC 27455 19
GRF5109DS 价格&库存
很抱歉,暂时无法提供与“GRF5109DS”相匹配的价格&库存,您可以联系我们找货
