LP E675-P1Q2-34-0-50-R18-Z 数据手册
www.osram-os.com
Produktdatenblatt | Version 1.1
LP E675
LP E675
Power TOPLED ®
PowerTOPLED, a powerful member of the TOPLED
family. Thanks to their high luminous efficacy, the
LEDs are ideal for rear light clusters and indicators
on vehicles and for display panels for traffic control
systems.
Applications
——Interior Illumination (e.g. Ambient Map)
——Traffic Lights
——Signalling
Features:
——Package: white PLCC-4 package, colorless clear resin
——Chip technology: InGaAlP
——Typ. Radiation: 120° (Lambertian emitter)
——Color: λdom = 560 nm (● pure green)
——Corrosion Robustness Class: 3B
——ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM)
Discontinued
1 Version 1.2 | 2019-07-15
LP E675
Ordering Information
Type
Luminous Intensity 1)
IF = 50 mA
Iv
Ordering Code
LP E675-P1Q2-25
45 ... 112 mcd
Q65110A2334
LP E675-P2R1-25
56 ... 140 mcd
Q65110A7298
Discontinued
2 Version 1.2 | 2019-07-15
LP E675
Maximum Ratings
Parameter
Symbol
Operating Temperature
Top
min.
max.
-40 °C
100 °C
Storage Temperature
Tstg
min.
max.
-40 °C
100 °C
Junction Temperature
Tj
max.
125 °C
Forward current
TS = 25 °C
IF
max.
70 mA
Surge Current
t ≤ 10 µs; D = 0.005 ; TS = 25 °C
IFS
max.
500 mA
Reverse voltage 2)
TS = 25 °C
VR
max.
12 V
ESD withstand voltage
VESD
Discontinued
3 Version 1.2 | 2019-07-15
Values
2 kV
LP E675
Characteristics
IF = 50 mA; TS = 25 °C
Parameter
Symbol
Peak Wavelength
λpeak
typ.
562 nm
Dominant Wavelength 3)
IF = 50 mA
λdom
min.
typ.
max.
554 nm
560 nm
566 nm
Spectral Bandwidth at 50% Irel,max
∆λ
typ.
19 nm
Viewing angle at 50% IV
2φ
typ.
120 °
Forward Voltage 4)
IF = 50 mA
VF
min.
typ.
max.
1.90 V
2.10 V
2.50 V
Reverse current 2)
VR = 12 V
IR
typ.
max.
0.01 µA
10 µA
Temperature Coefficient of Peak Wavelength
-10°C ≤ T ≤ 100°C
TCλpeak
typ.
0.11 nm / K
Temperature Coefficient of Dominant Wavelength
-10°C ≤ T ≤ 100°C
TCλdom
typ.
0.1 nm / K
Temperature Coefficient of Forward Voltage
-10°C ≤ T ≤ 100°C
TCVF
typ.
-2 mV / K
Real thermal resistance junction/solderpoint 5)
RthJS real
typ.
max.
110 K / W
130 K / W
Discontinued
4 Version 1.2 | 2019-07-15
Values
LP E675
Brightness Groups
Group
IF = 50 mA
min.
Iv
Luminous Intensity. 1)
IF = 50 mA
max.
Iv
Luminous Flux 6)
IF = 50 mA
typ.
ΦV
P1
45 mcd
56 mcd
150 mlm
P2
56 mcd
71 mcd
190 mlm
Q1
71 mcd
90 mcd
240 mlm
Q2
90 mcd
112 mcd
300 mlm
R1
112 mcd
140 mcd
380 mlm
Wavelength Groups
Group
IF = 50 mA
min.
λdom
IF = 50 mA
max.
λdom
2
554 nm
557 nm
3
557 nm
560 nm
4
560 nm
563 nm
5
563 nm
566 nm
Discontinued
5 Version 1.2 | 2019-07-15
LP E675
Group Name on Label
Example: P1-2
Brightness
Wavelength
P1
2
Discontinued
6 Version 1.2 | 2019-07-15
LP E675
Relative Spectral Emission
6)
Irel = f (λ); IF = 50 mA; TS = 25 °C
I
LP E675
1,0
: Vλ
: pure green
0,8
0,6
0,4
0,2
0,0
350
400
450
500
550
600
650
700
750
800
λ/
Radiation Characteristics
6)
Irel = f (ϕ); TS = 25 °C
LP E675
ϕ/
-40°
-50°
-20°
-10°
0°
10°
20°
30°
40°
50°
60°
70°
80°
90°
1,0
-30°
0,8
0,6
-60°
-70°
-80°
Discontinued
-90°
-100°
7 Version 1.2 | 2019-07-15
0,4
0,2
0,0
I
LP E675
Forward current
Relative Luminous Intensity
6), 7)
IF = f(VF); TS = 25 °C
6), 7)
Iv/Iv(50 mA) = f(IF); TS = 25 °C
LP E675
LP E675
IV
IF / mA
IV(50mA)
50
1
40
30
0,5
0,1
5
0,05
4
3
2
VF / V
Discontinued
8 Version 1.2 | 2019-07-15
70
30
40
50
2,2
10
2,0
3
4
5
1,9
2
0,01
1,8
1
1
1,7
IF / mA
LP E675
6)
Iv/Iv(25 °C) = f(Tj); IF = 50 mA
Iv
LP E675
2,5
Iv(25°C)
2,0
1,5
1,0
0,5
0,0
-40 -20
60
80
100 120
Tj / °C
Discontinued
9 Version 1.2 | 2019-07-15
LP E675
Max. Permissible Forward Current
IF = f(T)
OHL01413
80
mA
IF
70
60
TA
TS
50
40
30
Τ A temp. ambient
Τ S temp. solder point
10
60
80 ˚C 100
T
Permissible Pulse Handling Capability
IF = f(tp); D: Duty cycle; TA = 25 °C
IF = f(tp); D: Duty cycle; TA = 85 °C
OHL01505
0.12
IF
A
0.1
Discontinued
0.08
IF
0.005
0.05
0.5
A
0.10
0.08
0.06
0.06
0.04
0.04
0.02
0.02
0 -5
10 10-4 10-3 10-2 10-1 100 101 s 102
tp
10 Version 1.2 | 2019-07-15
OHL01506
0.12
0.005
0.05
0.5
0 -5
tp
LP E675
Dimensional Drawing
8)
3.0 (0.118)
2.6 (0.102)
2.3 (0.091)
2.1 (0.083)
1.7 (0.067)
2.1 (0.083)
0.8 (0.031)
0.6 (0.024)
C
Package
marking
C
C
C
4˚±1
0.5 (0.020)
C
A
0.1 (0.004) typ
1.1 (0.043)
C
0.7 (0.028)
3.7 (0.146)
3.3 (0.130)
3.4 (0.134)
3.0 (0.118)
(2.4 (0.094))
A
0.9 (0.035)
0.18 (0.007)
0.6 (0.024)
0.4 (0.016)
0.12 (0.005)
GPLY6991
Further Information
Approximate Weight:
30.0 mg
Package marking:
Cathode
Corrosion test:
Class: 3B
Test condition: 40°C / 90 % RH / 15 ppm H2S / 14 days (stricter than IEC
60068-2-43)
Discontinued
11 Version 1.2 | 2019-07-15
LP E675
Recommended Solder Pad
8)
Fläche darf bei Verwendung von TOPLED®
elektrisch nicht beschaltet werden.
For TOPLED® assembly do not use
this area for electrical contact
Padgeometrie für
verbesserte Wärmeableitung
Paddesign for
improved heat dissipation
3.3 (0.130)
3.3 (0.130)
Anode
2.3 (0.091)
11.1 (0.437)
1.5 (0.059)
1.1 (0.043)
3.7 (0.146)
0.8 (0.031)
0.7 (0.028)
Kathode/
Cathode
Cu Fläche / 10
oi
st
e
e
fo
tim
ur
se
al
op
fo
M
se
oi st ur
as
k,
is
or .
33
se
is
M oi st
bed
k,
lo H
an
g ph
-0
M oi
in
an in F R ng ar
rbl
D
M
e
ba
T
r
po If bl ith
lif
ki r C.
(if
S
is
p.
w
ea r ks
lf
J10 ba to et
th va
Y ea
m
rs
m
_
r w,
he
ed
1
ee
te
Y
d, EC
iredicat
S
fte
at
nt
1
W Hou
D
A flody
qu In no ire
1.
d
e
ou
4 8
re
reity is
qu/JE
re
2.
bo
e
M
tim
to es id 2b
re C
16
e
a)
S
tim
is IP
ic
ed loor
tim e
b) ev Humor
or
e
en
F
tim
lo
or
D
2a king
nc
te
F
op
a)
lo or
3.
b) ba re
F lo
da
e
fe
l 1 2
F
If
al
re
tim ve
l
4.
se
d
l 2a
ve
Le
3
an
ve l
ag
e
Le
e
B
ve
ur
e
Le
at
st
ur
e
Le
D
oi
st
ur e
M
oi
st ur
M
oi st
M oi
M
N
E RS
s
in IV O
IT T
S C
nta
N U
TIO
U coSEND
Ais bUagRMEICO
T E
CThIS
S
d
Barcode label
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
Discontinued
Desiccant
AM
OSR
OHA00539
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033.
16 Version 1.2 | 2019-07-15
LP E675
Schematic Transportation Box
8)
Barcode label
N
O
(Q
)Q
TY
:2
00
D
D
/C
:0
(X
Packing
Sealing label
Length
Height
200 ± 5 mm
195 ± 5 mm
30 ± 5 mm
352 ± 5 mm
352 ± 5 mm
33 ± 5 mm
Discontinued
17 Version 1.2 | 2019-07-15
M
Y
DE
-1
+Q
-1
R
18
P
OHA02044
Dimensions of Transportation Box
Width
RO
UP
M
RA
OS
PR
O
D
5
14 2
110 0
G
4
01
4
C:
D/
(9
D)
(Q
)Q
TY
O
TC
P)
(6
T
LO
(1
T)
O
D
PR
D
EM
Y
18
R
-1
Q
P
-1
G
R
O
U
P:
u L
lt S
iT Y
O T6
P 7
L 6
M
14
4
(G
E Bi
D Bi n1
Bi n2 : Pn3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R ditio 0 C R
07
PA 7 na RT
l TE
C
KV
XT
AR
Muster
A
o M
n O
d
u p
cto to
rs
R
34
ic
N
O
O
S
H
12
G
BA
TC
H
(1
T)
LO
T
N
O
:1
(6
P)
23
em
8
2199
2100
5
14 2
110 0
(X
O
M O
PT
O
M
998
NO
CThISTU
SE
S
21
2100
BA
_
s
ur s
Ho ururs s
de
Ho
co
72
Ho ur
te
48
e
Ho
24 6
da
40 be
tim e e
˚C
or
th
r
pr
ll
tim
ct
23
oo r
wi nt
tim e
at
l wi
fa
r
Fl oo
tim
s
at
at le ˚C at
e.
ica
l
Fl
th
oo r
th va
ur
nt
Fl oo
s ui
be
on
if: read
w
ed
l 4 5
Fl
la
m
ide
ce eq
lo
g,
oc
ve l
vi
is
in en
de
be
24 de or
l 5a6
pr
Le ve
nt wh
e
te
co
, w,
g:
ve l
Le
ke
r
re
ou
se
da
ba ed flo ba
Le ve
tu re
m %
ba
e
al
e
Le
r
en re
e
ed
re 10
ois stu ur e
tim
se
fo
al
op se
fo >
M oi
r
se
st ur
3
is
is ha
se
M
oi st
nk
be
k,
oo .
03
rd
g
M oi
in
an in Fl RH g,
r-p
bla
DM
ba
Ca
po If bl th
kinr
life is
(if
ar
ST
f
p.
wi
10 ba to et
Jel r th va
Ye ar ks s
m
_
cat m d, C
ed
1
Ye ee ur
ire
Sh te w, te
di
at
nt
1
W Ho
Af flody
qu In no ire DE
1.
e
ou
4 8
re
ed re
qu JE
2.
bo
ity is
M
or
tim e e
16
re C/
es id 2b
r
a)
St
tim
mor
is IP
ed
oo r
tim e
vic
b)
g e
r
Hu
Fl oo
en
tim
De
2a kin nc
te
Fl oo r
a)
op
3.
b) ba re
Fl oo
da
e
fe
l 1
Fl
If
al
re
tim ve l 2
4.
se
d
l 2a3
Le ve
g
an
ve l
e
Le
Ba
te
ur e
Le ve
Le
Da oist stur e
ur e
M
oi
st ur
M
oi st
M oi
H
12
34
RH
0%
/6
˚C
L
e el
selab
H)
nk de
co
(R
bla
r
S S
em R
ic AM
o
n O
d
u p
ct to
o
H
rs
NO
If
23
G
E
V
E
ba
ity
id
m
hu
e
e
d
tiv
re ag
NO
:1
L
la
re
fra ck
30
Nns IVE RS
in pa
k
of
ai IT TO
to
90
ea
d
ntNS
ns
UC
or
TIO
te (p
d
g
itio
ND
U g coSE
an bjec
˚C
sin
nd
O
5
˚C su es
Ais baRE
co
IC
y
M
oc
(G
M
u L
lt S
iT Y
O T6
P 7
L 6
E
D
Muster
Bi
Bi n1
Bi n2 : P-
n3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R0 ditio 0 C R
PA 77 na RT
l TE
CK
VA
XT
R:
Barcode label
LP E675
Type Designation System
Wavelength
(λdom typ.)
A:
617 nm
S:
633 nm
T:
528 nm
Y:
587 nm
O:
606 nm
CP/P: 560 nm
R:
625 nm
B:
470 nm
L:
Emission Color
amber
super red
true green
yellow
orange
pure green
red
blue
Color coordinates according
CIE 1931/Emission color:
W:
white
UW: ultra white
CW: warm white
CB: color on demand blue
CR: crystal pink
Package Type
E:
PowerTOPLED
Light
emitting
diode
L
A
E
6
Lead / Package Properties
6:
folded leads
T:
folded leads, improved corrosion stability
(Au-LF), w/o TiO2 jetting
Encapsulant Type / Lens Properties
7:
Colorless clear or white volume conversion
(resin encapsulation)
S:
Silicone (with or without diffuser)
3:
lens 30° … 70°
5:
lens 40° .. 80°
Discontinued
Chip Technology:
5: HOP 2000
B: HOP 2000
C: ATON
D: Low cost ThinGaN/ Thinfilm
(e.g. 6mil)
F: Thinfilm InGaAlP
G: ThinGaN(Thinfilm InGaN)
(Subcon:Sapphire)
18 Version 1.2 | 2019-07-15
7
6
LP E675
Notes
The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of
lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this
data sheet falls into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the
eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light
sources have a high secondary exposure potential due to their blinding effect. When looking at bright light
sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation.
Subcomponents of this device contain, in addition to other substances, metal filled materials including silver.
Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage,
production, and use. Devices that showed visible discoloration when tested using the described tests above
did show no performance deviations within failure limits during the stated test duration. Respective failure
limits are described in the IEC60810.
For further application related information please visit www.osram-os.com/appnotes
Discontinued
19 Version 1.2 | 2019-07-15
LP E675
Disclaimer
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may
contain dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version on the OSRAM OS website.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest
sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of
transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we
shall have to invoice you for any costs incurred.
Product and functional safety devices/applications or medical devices/applications
OSRAM OS components are not developed, constructed or tested for the application as safety relevant
component or for the application in medical devices.
OSRAM OS products are not qualified at module and system level for such application.
In case buyer – or customer supplied by buyer – considers using OSRAM OS components in product safety
devices/applications or medical devices/applications, buyer and/or customer has to inform the local sales
partner of OSRAM OS immediately and OSRAM OS and buyer and /or customer will analyze and coordinate the customer-specific request between OSRAM OS and buyer and/or customer.
Discontinued
20 Version 1.2 | 2019-07-15
LP E675
Glossary
1)
Brightness: Brightness values are measured during a current pulse of typically 25 ms, with an internal
reproducibility of ±8 % and an expanded uncertainty of ±11 % (acc. to GUM with a coverage factor of
k = 3).
2)
Reverse Operation: Reverse Operation of 10 hours is permissible in total. Continuous reverse operation is not allowed.
3)
Wavelength: The wavelength is measured at a current pulse of typically 25 ms, with an internal reproducibility of ±0.5 nm and an expanded uncertainty of ±1 nm (acc. to GUM with a coverage factor of k =
3).
4)
Forward Voltage: The forward voltage is measured during a current pulse of typically 8 ms, with an
internal reproducibility of ±0.05 V and an expanded uncertainty of ±0.1 V (acc. to GUM with a coverage
factor of k = 3).
5)
Thermal Resistance: Rth max is based on statistic values (6σ).
6)
Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures.
These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g.
because of technical improvements, these typ. data will be changed without any further notice.
7)
Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single devices within one packing unit.
8)
Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
9)
Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.
Discontinued
21 Version 1.2 | 2019-07-15
LP E675
Revision History
Version
Date
Change
1.2
2019-07-15
Discontinued
Discontinued
22 Version 1.2 | 2019-07-15
LP E675
Discontinued
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
23 Version 1.2 | 2019-07-15
