LB E67C-R1R2-35-34-30-R18-Z-HE 数据手册
www.osram-os.com
Produktdatenblatt | Version 1.1
LB E67C
LB E67C
Power TOPLED ®
PowerTOPLED, a powerful member of the TOPLED
family. Thanks to their high luminous efficacy, the
LEDs are ideal for rear light clusters and indicators
on vehicles and for display panels for traffic control
systems.
Applications
——Cluster, Button Backlighting
——Interior Illumination (e.g. Ambient Map)
——Electronic Equipment
Features:
——Package: white PLCC-4 package, colorless clear resin
——Chip technology: InGaN
——Typ. Radiation: 120° (Lambertian emitter)
——Color: λdom = 470 nm (● blue)
——Corrosion Robustness Class: 3B
——ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2)
Discontinued
1 Version 1.6 | 2019-07-15
LB E67C
Ordering Information
Type
Luminous Intensity 1)
IF = 30 mA
Iv
LB E67C-Q1S2-35-1
71 ... 280 mcd
Discontinued
2 Version 1.6 | 2019-07-15
Ordering Code
Q65110A9140
LB E67C
Maximum Ratings
Parameter
Symbol
Operating Temperature
Top
min.
max.
-40 °C
100 °C
Storage Temperature
Tstg
min.
max.
-40 °C
100 °C
Junction Temperature
Tj
max.
110 °C
Forward current
TS = 25 °C
IF
max.
30 mA
Surge Current
t ≤ 10 µs; D = 0.005 ; TS = 25 °C
IFS
max.
300 mA
Reverse voltage 2)
TS = 25 °C
VR
max.
5V
ESD withstand voltage
VESD
Discontinued
3 Version 1.6 | 2019-07-15
Values
2 kV
LB E67C
Characteristics
IF = 30 mA; TS = 25 °C
Parameter
Symbol
Peak Wavelength
λpeak
typ.
465 nm
Dominant Wavelength 3)
IF = 30 mA
λdom
min.
typ.
max.
463 nm
470 nm
475 nm
Spectral Bandwidth at 50% Irel,max
∆λ
typ.
25 nm
Viewing angle at 50% IV
2φ
typ.
120 °
Forward Voltage 4)
IF = 30 mA
VF
min.
typ.
max.
2.90 V
3.40 V
4.40 V
Reverse current 2)
VR = 5 V
IR
typ.
max.
0.01 µA
10 µA
Temperature Coefficient of Peak Wavelength
-10°C ≤ T ≤ 100°C
TCλpeak
typ.
Real thermal resistance junction/ambient 5)6)
RthJA real
max.
350 K / W
Real thermal resistance junction/solderpoint 5)
RthJS real
max.
180 K / W
Discontinued
4 Version 1.6 | 2019-07-15
Values
0.04 nm / K
LB E67C
Brightness Groups
Group
IF = 30 mA
min.
Iv
Luminous Intensity. 1)
IF = 30 mA
max.
Iv
Luminous Flux 7)
IF = 30 mA
typ.
ΦV
Q1
71 mcd
90 mcd
290 mlm
Q2
90 mcd
112 mcd
360 mlm
R1
112 mcd
140 mcd
450 mlm
R2
140 mcd
180 mcd
580 mlm
S1
180 mcd
224 mcd
730 mlm
S2
224 mcd
280 mcd
910 mlm
Forward Voltage Groups
Group
Forward Voltage 4)
IF = 30 mA
min.
VF
Forward Voltage 4)
IF = 30 mA
max.
VF
2
2.90 V
3.30 V
3
3.30 V
3.80 V
4
3.80 V
4.40 V
Wavelength Groups
Group
IF = 30 mA
min.
λdom
IF = 30 mA
max.
λdom
463 nm
467 nm
4
467 nm
471 nm
5
471 nm
475 nm
Discontinued
3
5 Version 1.6 | 2019-07-15
LB E67C
Group Name on Label
Example: Q1-3-2
Brightness
Wavelength
Q1
3
Discontinued
6 Version 1.6 | 2019-07-15
Forward Voltage
2
LB E67C
Relative Spectral Emission
7)
Irel = f (λ); IF = 30 mA; TS = 25 °C
Irel
LB E67C
1,0
: Vλ
: blue
0,8
0,6
0,4
0,2
0,0
350
400
450
500
550
600
650
700
750
800
λ [nm]
Radiation Characteristics
7)
Irel = f (ϕ); TS = 25 °C
LB E67C
ϕ [°]
-40°
-50°
-20°
-10°
0°
10°
20°
30°
40°
50°
60°
70°
80°
90°
1,0
-30°
0,8
0,6
-60°
-70°
-80°
Discontinued
-90°
-100°
7 Version 1.6 | 2019-07-15
0,4
0,2
0,0
Irel
LB E67C
Forward current
Relative Luminous Intensity
7), 8)
IF = f(VF); TS = 25 °C
IF [mA]
7), 8)
Iv/Iv(30 mA) = f(IF); TS = 25 °C
LB E67C
IV
LB E67C
30
IV(30mA)
: blue
1
: blue
0,4
10
0,3
0,2
5
4
3
Dominant Wavelength
7)
Δλdom = f(IF); TS = 25 °C
∆λ dom [nm]
LB E67C
8
: blue
6
4
2
30
25
10
2
Discontinued
5
-4
IF [mA]
8 Version 1.6 | 2019-07-15
30
3,4 3,5
VF [V]
10
3,0
4
2,8
5
2,6
3
2
2,4
2
0,1
IF [mA]
LB E67C
Forward Voltage
7)
ΔVF = VF - VF(25 °C) = f(Tj); IF = 30 mA
∆VF [V]
Iv/Iv(25 °C) = f(Tj); IF = 30 mA
LB E67C
0,3
Iv
1,0
0,1
0,8
0,0
0,6
-0,1
0,4
-0,2
0,2
60
80
100
Tj [°C]
Dominant Wavelength
7)
Δλdom = λdom - λdom(25 °C) = f(Tj); IF = 30 mA
∆λ dom [nm]
LB E67C
8
: blue
6
4
2
-4
-6
Discontinued
: blue
0,2
-20
-40
-20
60
80
100
Tj [°C]
9 Version 1.6 | 2019-07-15
LB E67C
1,2
Iv(25°C)
: blue
-0,3
-40
7)
0,0
-40
-20
60
80
100
Tj [°C]
LB E67C
Max. Permissible Forward Current
IF = f(T)
OHL21488
35
mA
IF
30
TA
TS
25
10
5
TA temp. ambient
TS temp. solder point
80 ˚C 100
60
T
Permissible Pulse Handling Capability
IF = f(tp); D: Duty cycle; TA = 25 °C
IF = f(tp); D: Duty cycle; TA = 85 °C
0.35
IF A
OHL01953
t
tP
IF
D = TP
T
0.25
D=
0.20
0.15
0.10
0.005
0.01
0.02
0.05
0.1
0.2
0.5
1
0.20
0.15
0.10
t
IF
D = TP
T
D=
0.005
0.01
0.02
0.05
0.1
0.2
0.5
1
0.05
0 -5
10 10-4 10-3 10-2 10-1 100 101 s 102
tp
10 Version 1.6 | 2019-07-15
OHL01954
tP
0.25
0.05
Discontinued
0.35
IF A
0 -5
tp
LB E67C
Dimensional Drawing
9)
3.0 (0.118)
2.6 (0.102)
2.3 (0.091)
2.1 (0.083)
1.7 (0.067)
2.1 (0.083)
0.8 (0.031)
0.6 (0.024)
C
Package
marking
C
C
C
4˚±1
0.5 (0.020)
C
A
0.1 (0.004) typ
1.1 (0.043)
C
0.7 (0.028)
3.7 (0.146)
3.3 (0.130)
3.4 (0.134)
3.0 (0.118)
(2.4 (0.094))
A
0.9 (0.035)
0.18 (0.007)
0.6 (0.024)
0.4 (0.016)
0.12 (0.005)
GPLY6991
Further Information
Approximate Weight:
30.0 mg
Package marking:
Cathode
Corrosion test:
Class: 3B
Test condition: 40°C / 90 % RH / 15 ppm H2S / 14 days (stricter than IEC
60068-2-43)
Discontinued
11 Version 1.6 | 2019-07-15
LB E67C
Recommended Solder Pad
9)
Fläche darf bei Verwendung von TOPLED®
elektrisch nicht beschaltet werden.
For TOPLED® assembly do not use
this area for electrical contact
Padgeometrie für
verbesserte Wärmeableitung
Paddesign for
improved heat dissipation
3.3 (0.130)
3.3 (0.130)
Anode
2.3 (0.091)
11.1 (0.437)
1.5 (0.059)
1.1 (0.043)
3.7 (0.146)
0.8 (0.031)
0.7 (0.028)
Kathode/
Cathode
Cu Fläche / 10
oi
st
e
e
fo
tim
ur
se
al
op
fo
M
se
oi st ur
as
k,
is
or .
33
se
is
M oi st
bed
k,
lo H
an
g ph
-0
M oi
in
an in F R ng ar
rbl
D
M
e
ba
T
r
po If bl ith
lif
ki r C.
(if
S
is
p.
w
ea r ks
lf
J10 ba to et
th va
Y ea
m
rs
m
_
r w,
he
ed
1
ee
te
Y
d, EC
iredicat
S
fte
at
nt
1
W Hou
D
A flody
qu In no ire
1.
d
e
ou
4 8
re
reity is
qu/JE
re
2.
bo
e
M
tim
to es id 2b
re C
16
e
a)
S
tim
is IP
ic
ed loor
tim e
b) ev Humor
or
e
en
F
tim
lo
or
D
2a king
nc
te
F
op
a)
lo or
3.
b) ba re
F lo
da
e
fe
l 1 2
F
If
al
re
tim ve
l
4.
se
d
l 2a
ve
Le
3
an
ve l
ag
e
Le
e
B
ve
ur
e
Le
at
st
ur
e
Le
D
oi
st
ur e
M
oi
st ur
M
oi st
M oi
M
N
E RS
s
in IV O
IT T
S C
nta
N U
TIO
U coSEND
Ais bUagRMEICO
T E
CThIS
S
d
Barcode label
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
Discontinued
Desiccant
AM
OSR
OHA00539
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033.
16 Version 1.6 | 2019-07-15
LB E67C
Schematic Transportation Box
9)
Barcode label
N
O
(Q
)Q
TY
:2
00
D
D
/C
:0
(X
Packing
Sealing label
Length
Height
200 ± 5 mm
195 ± 5 mm
30 ± 5 mm
352 ± 5 mm
352 ± 5 mm
33 ± 5 mm
Discontinued
17 Version 1.6 | 2019-07-15
M
Y
DE
-1
+Q
-1
R
18
P
OHA02044
Dimensions of Transportation Box
Width
RO
UP
M
RA
OS
PR
O
D
5
14 2
110 0
G
4
01
4
C:
D/
(9
D)
(Q
)Q
TY
O
TC
P)
(6
T
LO
(1
T)
O
D
PR
D
EM
Y
18
R
-1
Q
P
-1
G
R
O
U
P:
u L
lt S
iT Y
O T6
P 7
L 6
M
14
4
(G
E Bi
D Bi n1
Bi n2 : Pn3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R ditio 0 C R
07
PA 7 na RT
l TE
C
KV
XT
AR
Muster
A
o M
n O
d
u p
cto to
rs
R
34
ic
N
O
O
S
H
12
G
BA
TC
H
(1
T)
LO
T
N
O
:1
(6
P)
23
em
8
2199
2100
5
14 2
110 0
(X
O
M O
PT
O
M
998
NO
CThISTU
SE
S
21
2100
BA
_
s
ur s
Ho ururs s
de
Ho
co
72
Ho ur
te
48
e
Ho
24 6
da
40 be
tim e e
˚C
or
th
r
pr
ll
tim
ct
23
oo r
wi nt
tim e
at
l wi
fa
r
Fl oo
tim
s
at
at le ˚C at
e.
ica
l
Fl
th
oo r
th va
ur
nt
Fl oo
s ui
be
on
if: read
w
ed
l 4 5
Fl
la
m
ide
ce eq
lo
g,
oc
ve l
vi
is
in en
de
be
24 de or
l 5a6
pr
Le ve
nt wh
e
te
co
, w,
g:
ve l
Le
ke
r
re
ou
se
da
ba ed flo ba
Le ve
tu re
m %
ba
e
al
e
Le
r
en re
e
ed
re 10
ois stu ur e
tim
se
fo
al
op se
fo >
M oi
r
se
st ur
3
is
is ha
se
M
oi st
nk
be
k,
oo .
03
rd
g
M oi
in
an in Fl RH g,
r-p
bla
DM
ba
Ca
po If bl th
kinr
life is
(if
ar
ST
f
p.
wi
10 ba to et
Jel r th va
Ye ar ks s
m
_
cat m d, C
ed
1
Ye ee ur
ire
Sh te w, te
di
at
nt
1
W Ho
Af flody
qu In no ire DE
1.
e
ou
4 8
re
ed re
qu JE
2.
bo
ity is
M
or
tim e e
16
re C/
es id 2b
r
a)
St
tim
mor
is IP
ed
oo r
tim e
vic
b)
g e
r
Hu
Fl oo
en
tim
De
2a kin nc
te
Fl oo r
a)
op
3.
b) ba re
Fl oo
da
e
fe
l 1
Fl
If
al
re
tim ve l 2
4.
se
d
l 2a3
Le ve
g
an
ve l
e
Le
Ba
te
ur e
Le ve
Le
Da oist stur e
ur e
M
oi
st ur
M
oi st
M oi
H
12
34
RH
0%
/6
˚C
L
e el
selab
H)
nk de
co
(R
bla
r
S S
em R
ic AM
o
n O
d
u p
ct to
o
H
rs
NO
If
23
G
E
V
E
ba
ity
id
m
hu
e
e
d
tiv
re ag
NO
:1
L
la
re
fra ck
30
Nns IVE RS
in pa
k
of
ai IT TO
to
90
ea
d
ntNS
ns
UC
or
TIO
te (p
d
g
itio
ND
U g coSE
an bjec
˚C
sin
nd
O
5
˚C su es
Ais baRE
co
IC
y
M
oc
(G
M
u L
lt S
iT Y
O T6
P 7
L 6
E
D
Muster
Bi
Bi n1
Bi n2 : P-
n3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R0 ditio 0 C R
PA 77 na RT
l TE
CK
VA
XT
R:
Barcode label
LB E67C
Notes
The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of
lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this
data sheet falls into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the
eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light
sources have a high secondary exposure potential due to their blinding effect. When looking at bright light
sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation.
Subcomponents of this device contain, in addition to other substances, metal filled materials including silver.
Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage,
production, and use. Devices that showed visible discoloration when tested using the described tests above
did show no performance deviations within failure limits during the stated test duration. Respective failure
limits are described in the IEC60810.
For further application related information please visit www.osram-os.com/appnotes
Discontinued
18 Version 1.6 | 2019-07-15
LB E67C
Disclaimer
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may
contain dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version on the OSRAM OS website.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest
sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of
transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we
shall have to invoice you for any costs incurred.
Product and functional safety devices/applications or medical devices/applications
OSRAM OS components are not developed, constructed or tested for the application as safety relevant
component or for the application in medical devices.
OSRAM OS products are not qualified at module and system level for such application.
In case buyer – or customer supplied by buyer – considers using OSRAM OS components in product safety
devices/applications or medical devices/applications, buyer and/or customer has to inform the local sales
partner of OSRAM OS immediately and OSRAM OS and buyer and /or customer will analyze and coordinate the customer-specific request between OSRAM OS and buyer and/or customer.
Discontinued
19 Version 1.6 | 2019-07-15
LB E67C
Glossary
1)
Brightness: Brightness values are measured during a current pulse of typically 25 ms, with an internal
reproducibility of ±8 % and an expanded uncertainty of ±11 % (acc. to GUM with a coverage factor of
k = 3).
2)
Reverse Operation: Reverse Operation of 10 hours is permissible in total. Continuous reverse operation is not allowed.
3)
Wavelength: The wavelength is measured at a current pulse of typically 25 ms, with an internal reproducibility of ±0.5 nm and an expanded uncertainty of ±1 nm (acc. to GUM with a coverage factor of k =
3).
4)
Forward Voltage: The forward voltage is measured during a current pulse of typically 8 ms, with an
internal reproducibility of ±0.05 V and an expanded uncertainty of ±0.1 V (acc. to GUM with a coverage
factor of k = 3).
5)
Thermal Resistance: Rth max is based on statistic values (6σ).
6)
Thermal Resistance: RthJA results from mounting on PC board FR 4 (pad size 16 mm² per pad)
7)
Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures.
These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g.
because of technical improvements, these typ. data will be changed without any further notice.
8)
Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single devices within one packing unit.
9)
Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
10)
Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.
Discontinued
20 Version 1.6 | 2019-07-15
LB E67C
Revision History
Version
Date
Change
1.6
2019-07-15
Discontinued
Discontinued
21 Version 1.6 | 2019-07-15
LB E67C
Discontinued
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
22 Version 1.6 | 2019-07-15
