LO T776-S1T1-34-0-20-R18-Z 数据手册
www.osram-os.com
Produktdatenblatt | Version 1.1
LO T776
LO T776
TOPLED ® Reverse Gullwing
Applications
——Electronic Equipment
Features:
——Package: white SMT package, colorless clear resin
——Chip technology: InGaAlP
——Typ. Radiation: 120° (Lambertian emitter)
——Color: λdom = 606 nm (● orange)
——Corrosion Robustness Class: 3B
——ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM)
Discontinued
1 Version 1.2 | 2019-07-16
LO T776
Ordering Information
Type
Luminous Intensity 1)
IF = 20 mA
Iv
LO T776-Q2T1-24
90 ... 355 mcd
Discontinued
2 Version 1.2 | 2019-07-16
Ordering Code
Q65110A2219
LO T776
Maximum Ratings
Parameter
Symbol
Operating Temperature
Top
min.
max.
-40 °C
100 °C
Storage Temperature
Tstg
min.
max.
-40 °C
100 °C
Junction Temperature
Tj
max.
125 °C
Forward current
TS = 25 °C
IF
max.
30 mA
Surge Current
t ≤ 10 µs; D = 0.005 ; TS = 25 °C
IFS
max.
500 mA
Reverse voltage 2)
TS = 25 °C
VR
max.
5V
ESD withstand voltage
VESD
Discontinued
3 Version 1.2 | 2019-07-16
Values
2 kV
LO T776
Characteristics
IF = 20 mA; TS = 25 °C
Parameter
Symbol
Peak Wavelength
λpeak
typ.
610 nm
Dominant Wavelength 3)
IF = 20 mA
λdom
min.
typ.
max.
600 nm
606 nm
609 nm
Spectral Bandwidth at 50% Irel,max
∆λ
typ.
16 nm
Viewing angle at 50% IV
2φ
typ.
120 °
Forward Voltage 4)
IF = 20 mA
VF
min.
typ.
max.
1.85 V
2.00 V
2.35 V
Reverse current 2)
VR = 5 V
IR
typ.
max.
0.01 µA
10 µA
Temperature Coefficient of Peak Wavelength
-10°C ≤ T ≤ 100°C
TCλpeak
typ.
0.13 nm / K
Temperature Coefficient of Dominant Wavelength
-10°C ≤ T ≤ 100°C
TCλdom
typ.
0.07 nm / K
Temperature Coefficient of Forward Voltage
-10°C ≤ T ≤ 100°C
TCVF
typ.
-1.7 mV / K
Real thermal resistance junction/ambient 5)6)
RthJA real
max.
500 K / W
Real thermal resistance junction/solderpoint 5)
RthJS real
max.
280 K / W
Discontinued
4 Version 1.2 | 2019-07-16
Values
LO T776
Brightness Groups
Group
IF = 20 mA
min.
Iv
Luminous Intensity. 1)
IF = 20 mA
max.
Iv
Luminous Flux 7)
IF = 20 mA
typ.
ΦV
Q2
90 mcd
112 mcd
300 mlm
R1
112 mcd
140 mcd
380 mlm
R2
140 mcd
180 mcd
480 mlm
S1
180 mcd
224 mcd
610 mlm
S2
224 mcd
280 mcd
760 mlm
T1
280 mcd
355 mcd
950 mlm
Wavelength Groups
Group
IF = 20 mA
min.
λdom
IF = 20 mA
max.
λdom
2
600 nm
603 nm
3
603 nm
606 nm
4
606 nm
609 nm
Group Name on Label
Example: Q2-2
Brightness
Discontinued
Q2
5 Version 1.2 | 2019-07-16
Wavelength
2
LO T776
Relative Spectral Emission
7)
Irel = f (λ); IF = 20 mA; TS = 25 °C
OHL00235
100
Irel
80
Vλ
60
yellow
orange
amber
super-red
40
450
500
550
600
650
nm
700
λ
Radiation Characteristics
7)
Irel = f (ϕ); TS = 25 °C
40˚
30˚
20˚
10˚
0˚
ϕ
50˚
OHL01660
1.0
0.8
0.6
60˚
0.4
70˚
0.2
80˚
Discontinued
90˚
100˚
1.0
0.8
6 Version 1.2 | 2019-07-16
0.6
0.4
0˚
20˚
40˚
60˚
80˚
100˚
120˚
LO T776
Forward current
Relative Luminous Intensity
7)
IF = f(VF); TS = 25 °C
7), 8)
Iv/Iv(20 mA) = f(IF); TS = 25 °C
OHL00232
10 2
mA
5
OHL10233
10 1
IV
I V (20 mA)
IF
10 0
10 1
5
10 -1
10 0
5
10 -1
super-red
yellow
orange/amber
1
1.4
1.8
2.2
2.6
3 V 3.4
VF
Discontinued
7 Version 1.2 | 2019-07-16
10 -2
10 0
10 1
mA
IF
10 2
LO T776
7)
Iv/Iv(25 °C) = f(Tj); IF = 20 mA
OHL00238
IV 2.0
IV (25 ˚C)
1.6
orange
yellow
amber
super-red
1.2
0.8
orange
yellow
amber
super-red
0.4
60
˚C 100
Tj
Discontinued
8 Version 1.2 | 2019-07-16
LO T776
Max. Permissible Forward Current
IF = f(T)
OHL01031
35
I F mA
30
TS
25
TA
10
TA temp. ambient
TS temp. solder point
5
60
80 ˚C 100
T
Permissible Pulse Handling Capability
IF = f(tp); D: Duty cycle; TS = 25 °C
IF = f(tp); D: Duty cycle; TS = 85 °C;
IF
OHL00318
100
A
IF
5
5
D=
0.005
0.01
0.02
0.05
0.1
0.2
0.5
10-1
tP
D= T
OHL01427
t
D = TP
tP
IF
T
D=
10-1
5
5
Discontinued
100
A
0.005
0.01
0.02
0.05
0.1
0.2
0.5
tP
IF
T
10-2 -5
10 10-4 10-3 10-2 10-1 10 0 101 s 10 2
tp
9 Version 1.2 | 2019-07-16
10-2 -5
tp
LO T776
9)
2.1 (0.083)
3.0 (0.118)
2.6 (0.102)
2.3 (0.091)
1.7 (0.067)
4˚±1
0.9 (0.035)
A
5.4 (0.213)
5.0 (0.197)
3.4 (0.134)
3.0 (0.118)
(2.4 (0.094))
2.1 (0.083)
0.3 (0.012) max
1.0 (0.039)
0.3 (0.012) min
Dimensional Drawing
0...0.1 (0.004)
0.6 (0.024)
0.4 (0.016)
Cathode marking
C
GPLY6899
Further Information
Approximate Weight:
34.0 mg
Package marking:
Cathode
Corrosion test:
Class: 3B
Test condition: 40°C / 90 % RH / 15 ppm H2S / 14 days (stricter than IEC
60068-2-43)
Discontinued
10 Version 1.2 | 2019-07-16
LO T776
Recommended Solder Pad
9)
6 (0.236)
2.6 (0.102)
1.2 (0.047)
6 (0.236)
1.2 (0.047)
Padgeometrie
für verbesserte
Wärmeableitung
Cu-Fläche > 16 mm 2
Cu-area > 16 mm 2
2.6 (0.102)
Paddesign
for improved
heat dissipation
2.8 (0.110)
2.4 (0.094)
Lötstopplack
Solder resist
Hole on PCB
OHLPY977
For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not
suitable for ultra sonic cleaning.
Discontinued
11 Version 1.2 | 2019-07-16
LO T776
Reflow Soldering Profile
Product complies to MSL Level 2 acc. to JEDEC J-STD-020E
OHA04525
300
˚C
T 250
Tp 245 ˚C
240 ˚C
tP
217 ˚C
200
tL
150
tS
100
50
25 ˚C
100
150
200
250
s 300
t
Profile Feature
Symbol
Pb-Free (SnAgCu) Assembly
Minimum
Recommendation
Ramp-up rate to preheat*)
25 °C to 150 °C
tS
Time tS
TSmin to TSmax
Ramp-up rate to peak*)
TSmax to TP
Liquidus temperature
60
2
3
100
120
2
3
K/s
s
K/s
TL
217
Time above liquidus temperature
tL
80
100
s
Peak temperature
TP
245
250
°C
Time within 5 °C of the specified peak
temperature TP - 5 K
tP
3
4
Ramp-down rate*
TP to 100 °C
10
Time
25 °C to TP
Discontinued
Maximum
Unit
All temperatures refer to the center of the package, measured on the top of the component
* slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range
12 Version 1.2 | 2019-07-16
°C
480
s
K/s
s
LO T776
9)
Cathode/Collector Marking
4 (0.157)
1.5 (0.059)
3 (0.118)
4 (0.157)
Discontinued
13 Version 1.2 | 2019-07-16
12 (0.472)
1.75 (0.069)
5.5 (0.217)
2 (0.079)
5.6 (0.220)
Taping
OHAY2272
LO T776
Tape and Reel
10)
Reel Dimensions
A
W
Nmin
W1
W2 max
Pieces per PU
180 mm
12 + 0.3 / - 0.1 mm
60 mm
12.4 + 2 mm
18.4 mm
2000
330 mm
12 + 0.3 / - 0.1 mm
60 mm
12.4 + 2 mm
18.4 mm
8000
Discontinued
14 Version 1.2 | 2019-07-16
LO T776
Barcode-Product-Label (BPL)
Dry Packing Process and Materials
9)
Moisture-sensitive label or print
L
E
E
V
l
e be
sela
k,
H
de
L
If
an
bl r co
ba
(R
id
m
ity
H
R
hu
0%
e
e
/6
tiv
˚C
la ared ag
ck
re
fr
30
_
in pa
k
of
to
90
rs
ea
s
d
rs
ou
or
te (p
on
rs
H
de
ou
iti
H
an bjec ng
ou rs
co
˚C
72
si
nd
H ou
5
te
48
˚C su es
e
H
co
24 6
da
e
y
40 be oc
tim
˚C
e
or
ith
tim
ill pr).
or
ct
w
O
w nt
23
tim e
at
lo
or
fa
M TO
F
s
al
tim
at le ˚C at
lo
at
or
e.
P
th
F
l
tic
th va
lo or
ur
O
F lo
s ui
on
be
if: read
en
w
ed
l 4 5
F
m
la
ce eq
id
lo
g, n
oc
l
ve
vi
5a
is
in
or
be
24
de
pr
ve l
6
Le
de ,
nt whe
e
te
co
g:
, w
e
Le ve l
ke
r
ou
se
da
ba ed flo
ur
e
Le ve
m %
ba
e
ba
al
st
ur e
Le
r
en re
ed
e
re> 10
oi
st
e
e
fo
tim
ur
se
al
op
fo
M
se
oi st ur
as
k,
is
or .
33
se
is
M oi st
bed
k,
lo H
an
g ph
-0
M oi
in
an in F R ng ar
rbl
D
M
e
ba
T
r
po If bl ith
lif
ki r C.
(if
S
is
p.
w
ea r ks
lf
J10 ba to et
th va
Y ea
m
rs
m
_
r w,
he
ed
1
ee
te
Y
d, EC
iredicat
S
fte
at
nt
1
W Hou
D
A flody
qu In no ire
1.
d
e
ou
4 8
re
reity is
qu/JE
re
2.
bo
e
M
tim
to es id 2b
re C
16
e
a)
S
tim
is IP
ic
ed loor
tim e
b) ev Humor
or
e
en
F
tim
lo
or
D
2a king
nc
te
F
op
a)
lo or
3.
b) ba re
F lo
da
e
fe
l 1 2
F
If
al
re
tim ve
l
4.
se
d
l 2a
ve
Le
3
an
ve l
ag
e
Le
e
B
ve
ur
e
Le
at
st
ur
e
Le
D
oi
st
ur e
M
oi
st ur
M
oi st
M oi
M
N
E RS
s
in IV O
IT T
S C
nta
N U
TIO
U coSEND
Ais bUagRMEICO
T E
CThIS
S
d
Barcode label
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
Discontinued
Desiccant
AM
OSR
OHA00539
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033.
15 Version 1.2 | 2019-07-16
LO T776
Schematic Transportation Box
9)
Barcode label
N
O
(Q
)Q
TY
:2
00
D
D
/C
:0
(X
Packing
Sealing label
Length
Height
195 ± 5 mm
195 ± 5 mm
30 ± 5 mm
349 ± 5 mm
349 ± 5 mm
33 ± 5 mm
Discontinued
16 Version 1.2 | 2019-07-16
M
Y
DE
-1
+Q
-1
R
18
P
OHA02044
Dimensions of Transportation Box
Width
RO
UP
M
RA
OS
PR
O
D
5
14 2
110 0
G
4
01
4
C:
D/
(9
D)
(Q
)Q
TY
O
TC
P)
(6
T
LO
(1
T)
O
D
PR
D
EM
Y
18
R
-1
Q
P
-1
G
R
O
U
P:
u L
lt S
iT Y
O T6
P 7
L 6
M
14
4
(G
E Bi
D Bi n1
Bi n2 : Pn3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R ditio 0 C R
07
PA 7 na RT
l TE
C
KV
XT
AR
Muster
A
o M
n O
d
u p
cto to
rs
R
34
ic
N
O
O
S
H
12
G
BA
TC
H
(1
T)
LO
T
N
O
:1
(6
P)
23
em
8
2199
2100
5
14 2
110 0
(X
O
M O
PT
O
M
998
NO
CThISTU
SE
S
21
2100
BA
_
s
ur s
Ho ururs s
de
Ho
co
72
Ho ur
te
48
e
Ho
24 6
da
40 be
tim e e
˚C
or
th
r
pr
ll
tim
ct
23
oo r
wi nt
tim e
at
l wi
fa
r
Fl oo
tim
s
at
at le ˚C at
e.
ica
l
Fl
th
oo r
th va
ur
nt
Fl oo
s ui
be
on
if: read
w
ed
l 4 5
Fl
la
m
ide
ce eq
lo
g,
oc
ve l
vi
is
in en
de
be
24 de or
l 5a6
pr
Le ve
nt wh
e
te
co
, w,
g:
ve l
Le
ke
r
re
ou
se
da
ba ed flo ba
Le ve
tu re
m %
ba
e
al
e
Le
r
en re
e
ed
re 10
ois stu ur e
tim
se
fo
al
op se
fo >
M oi
r
se
st ur
3
is
is ha
se
M
oi st
nk
be
k,
oo .
03
rd
g
M oi
in
an in Fl RH g,
r-p
bla
DM
ba
Ca
po If bl th
kinr
life is
(if
ar
ST
f
p.
wi
10 ba to et
Jel r th va
Ye ar ks s
m
_
cat m d, C
ed
1
Ye ee ur
ire
Sh te w, te
di
at
nt
1
W Ho
Af flody
qu In no ire DE
1.
e
ou
4 8
re
ed re
qu JE
2.
bo
ity is
M
or
tim e e
16
re C/
es id 2b
r
a)
St
tim
mor
is IP
ed
oo r
tim e
vic
b)
g e
r
Hu
Fl oo
en
tim
De
2a kin nc
te
Fl oo r
a)
op
3.
b) ba re
Fl oo
da
e
fe
l 1
Fl
If
al
re
tim ve l 2
4.
se
d
l 2a3
Le ve
g
an
ve l
e
Le
Ba
te
ur e
Le ve
Le
Da oist stur e
ur e
M
oi
st ur
M
oi st
M oi
H
12
34
RH
0%
/6
˚C
L
e el
selab
H)
nk de
co
(R
bla
r
S S
em R
ic AM
o
n O
d
u p
ct to
o
H
rs
NO
If
23
G
E
V
E
ba
ity
id
m
hu
e
e
d
tiv
re ag
NO
:1
L
la
re
fra ck
30
Nns IVE RS
in pa
k
of
ai IT TO
to
90
ea
d
ntNS
ns
UC
or
TIO
te (p
d
g
itio
ND
U g coSE
an bjec
˚C
sin
nd
O
5
˚C su es
Ais baRE
co
IC
y
M
oc
(G
M
u L
lt S
iT Y
O T6
P 7
L 6
E
D
Muster
Bi
Bi n1
Bi n2 : P-
n3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R0 ditio 0 C R
PA 77 na RT
l TE
CK
VA
XT
R:
Barcode label
LO T776
Type Designation System
Wavelength
(λdom typ.)
A:
617 nm
S:
633 nm
T:
528 nm
Y:
587 nm
O:
606 nm
G:
570 nm
P:
560 nm
R:
625 nm
B:
470 nm
H:
645 nm
V:
505 nm
L:
Emission Color
amber
super red
true green
yellow
orange
green
pure green
red
blue
hyper-red
verde green
Color coordinates according
CIE 1931/Emission color:
W:
white
UW: ultra white
CB:
color on demand blue
CG:
color on demand green
CL:
color on demand lagune
Package Type
T:
TOPLED
Light
emitting
diode
A
L
T
6
Lead / Package Properties
6:
folded leads
7:
reverse gullwing leads
T:
folded leads, improved corrosion stability
Au-LF), w/o TiO2 jetting
V:
folded leads and UX:3 w/ improved
corrosion stability (Au-LF), TiO2 jetting
Encapsulant Type / Lens Properties
7:
Colorless clear or white volume conversion
(resin encapsulation)
S:
Silicone (with or without diffuser)
Discontinued
Chip Technology:
1: TSN
3: standard InGaN
4: AlGaAs
5: HOP 2000
6: Standard InGalP
9: TSN low current
B: HOP 2000
C: ATON
D: Small ThinGaN/ Thinfilm (e.g. 6mil)
F: Thinfilm InGaAlP
G: ThinGaN(Thinfilm InGaN)
K: InGaAlP low current
S: standard InGaN low current
0: TSN
17 Version 1.2 | 2019-07-16
7
6
LO T776
Notes
The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of
lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this
data sheet falls into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the
eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light
sources have a high secondary exposure potential due to their blinding effect. When looking at bright light
sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation.
Subcomponents of this device contain, in addition to other substances, metal filled materials including silver.
Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage,
production, and use. Devices that showed visible discoloration when tested using the described tests above
did show no performance deviations within failure limits during the stated test duration. Respective failure
limits are described in the IEC60810.
For further application related information please visit www.osram-os.com/appnotes
Discontinued
18 Version 1.2 | 2019-07-16
LO T776
Disclaimer
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may
contain dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version on the OSRAM OS website.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest
sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of
transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we
shall have to invoice you for any costs incurred.
Product and functional safety devices/applications or medical devices/applications
OSRAM OS components are not developed, constructed or tested for the application as safety relevant
component or for the application in medical devices.
OSRAM OS products are not qualified at module and system level for such application.
In case buyer – or customer supplied by buyer – considers using OSRAM OS components in product safety
devices/applications or medical devices/applications, buyer and/or customer has to inform the local sales
partner of OSRAM OS immediately and OSRAM OS and buyer and /or customer will analyze and coordinate the customer-specific request between OSRAM OS and buyer and/or customer.
Discontinued
19 Version 1.2 | 2019-07-16
LO T776
Glossary
1)
Brightness: Brightness values are measured during a current pulse of typically 25 ms, with an internal
reproducibility of ±8 % and an expanded uncertainty of ±11 % (acc. to GUM with a coverage factor of
k = 3).
2)
Reverse Operation: Reverse Operation of 10 hours is permissible in total. Continuous reverse operation is not allowed.
3)
Wavelength: The wavelength is measured at a current pulse of typically 25 ms, with an internal reproducibility of ±0.5 nm and an expanded uncertainty of ±1 nm (acc. to GUM with a coverage factor of k =
3).
4)
Forward Voltage: The forward voltage is measured during a current pulse of typically 8 ms, with an
internal reproducibility of ±0.05 V and an expanded uncertainty of ±0.1 V (acc. to GUM with a coverage
factor of k = 3).
5)
Thermal Resistance: Rth max is based on statistic values (6σ).
6)
Thermal Resistance: RthJA results from mounting on PC board FR 4 (pad size 16 mm² per pad)
7)
Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures.
These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g.
because of technical improvements, these typ. data will be changed without any further notice.
8)
Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single devices within one packing unit.
9)
Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
10)
Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.
Discontinued
20 Version 1.2 | 2019-07-16
LO T776
Revision History
Version
Date
Change
1.2
2019-07-15
Discontinued
Discontinued
21 Version 1.2 | 2019-07-16
LO T776
Discontinued
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
22 Version 1.2 | 2019-07-16
