www.osram-os.com
Produktdatenblatt | Version 1.1
SFH 4736
SFH 4736
OSLON ® Black
OSLON Black (IR broad band emitter) - 80°
Applications
——Infrared Spectroscopy
Features:
——Package: clear silicone
——Corrosion Robustness Class: 3B
——ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2)
——Spectral range of emission: (typ) 650 ... 1050 nm
——Radiant intensity (λ = 600 - 1050 nm): typ. 11 mW/sr
——Viewing angle of 80°
——Low thermal resistance (Max. 9 K/W)
Ordering Information
Type
23 mW
Q65112A0833
Preliminary datasheet version
SFH 4736
Ordering Code
Total radiant flux 1)
typ.
IF = 350 mA; λ = 600 nm - 1050 nm; tp = 20 ms
Φe
1 Version 0.0 | 2018-08-27
SFH 4736
Maximum Ratings
TA = 25 °C
Parameter
Symbol
Operating temperature
Top
min.
max.
-40 °C
85 °C
Storage temperature
Tstg
min.
max.
-40 °C
85 °C
Junction temperature
Tj
max.
125 °C
Forward current
IF
max.
500 mA
Surge current
tp ≤ 1 ms; D = 0
IFSM
max.
1A
Reverse current 2)
IR
max.
200 mA
Power consumption
Ptot
max.
1900 mW
ESD withstand voltage
VESD
max.
2 kV
For the forward current and power consumption please see “maximum
permissible forward current” diagram
2 Version 0.0 | 2018-08-27
Values
SFH 4736
Characteristics
IF = 350 mA; tp = 25 ms; TA = 25 °C
Parameter
Symbol
Half angle
φ
typ.
Forward voltage
VF
typ.
max.
2.95 V
3.5 V
Forward voltage
IF = 500 mA; tp = 100 µs
VF
typ.
max.
3V
3.8 V
Reverse voltage 2)
IR = 20 mA
VR
max.
1.2 V
Reverse voltage (ESD device) 2)
VR ESD
min.
45 V
Radiant intensity
λ = 350 - 600 nm
Ie
typ.
60 mW/sr
Radiant intensity
λ = 600 - 1050 nm
Ie
typ.
11 mW/sr
Radiant intensity
IF = 500 mA; tp = 10 ms; λ = 350 - 600 nm
Ie
typ.
85 mW/sr
Radiant intensity
IF = 500 mA; tp = 10 ms; λ = 600 - 1050 nm
Ie
typ.
14 mW/sr
λ = 350 - 600 nm
Φe
typ.
120 mW
λ = 600 - 1050 nm
Φe
typ.
23 mW
Φe
typ.
160 mW
Φe
typ.
29 mW
Spectral flux
λ = 750 nm
Φe,λ
typ.
65 µW/nm
Spectral flux
λ = 850 nm
Φe,λ
typ.
63 µW/nm
Spectral flux
λ = 950 nm
Φe,λ
typ.
60 µW/nm
Thermal resistance junction solder point real 3)
RthJS
max.
9.0 K / W
3 Version 0.0 | 2018-08-27
Values
40 °
SFH 4736
Relative Spectral Emission
4), 5)
Irel = f (λ); IF = 350 mA; tp = 25 ms
Radiation Characteristics
4), 5)
Irel = f (φ)
φ[ ]
-20°
: 90°
-40°
-50°
-60°
-70°
-30°
-10°
0° 10° 20° 30° 40° 50° 60° 70° 80° 90°
1.0
0.9
0.8
0.7
0.6
0.5
0.4
0.3
-80°
0.2
0.1
-90°
4 Version 0.0 | 2018-08-27
0.0
SFH 4736
Forward current
Relative Total Radiant Flux
4), 5)
IF = f (VF); single pulse; tp = 100 µs
Φe/Φe(350mA) = f (IF); single pulse; tp = 100 µs
Max. Permissible Forward Current
Permissible Pulse Handling Capability
IF,max = f (TS); RthJS = 9.0 K / W
IF = f (tp); duty cycle D = parameter; TS = 85°C
[ ] 0.5
0.4
1.0
0.8
0.3
0.6
0.2
4), 5)
0.4
0.1
0.2
0.0
5 Version 0.0 | 2018-08-27
40
60
80
0.0 -5
10 10-4 10-3 0.01 0.1
:D=1
: D = 0,5
: D = 0,2
: D = 0,1
: D = 0,05
: D = 0,02
: D = 0,005
1
10 100
SFH 4736
Dimensional Drawing
6)
Approximate Weight:
32.0 mg
Package marking:
Anode
Corrosion test:
Class: 3B
Test condition: 40°C / 90 % RH / 15 ppm H2S / 14 days (stricter then IEC
60068-2-43)
ESD advice:
6 Version 0.0 | 2018-08-27
The device is protected by ESD device which is connected in parallel to the
Chip.
SFH 4736
Recommended Solder Pad
6)
For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere.
Reflow Soldering Profile
Product complies to MSL Level 2 acc. to JEDEC J-STD-020E
OHA04525
300
˚C
T 250
Tp 245 ˚C
240 ˚C
tP
217 ˚C
200
150
tL
tS
100
50
25 ˚C
100
150
200
250
s 300
t
7 Version 0.0 | 2018-08-27
SFH 4736
Profile Feature
Symbol
Pb-Free (SnAgCu) Assembly
Minimum
Recommendation Maximum
Ramp-up rate to preheat*)
25 °C to 150 °C
tS
Time tS
TSmin to TSmax
60
Ramp-up rate to peak*)
TSmax to TP
2
3
100
120
2
3
Unit
K/s
s
K/s
Liquidus temperature
TL
217
Time above liquidus temperature
tL
80
100
s
Peak temperature
TP
245
260
°C
Time within 5 °C of the specified peak
temperature TP - 5 K
tP
3
6
Ramp-down rate*
TP to 100 °C
10
480
Time
25 °C to TP
All temperatures refer to the center of the package, measured on the top of the component
* slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range
Taping
°C
6)
8 Version 0.0 | 2018-08-27
s
K/s
s
SFH 4736
Tape and Reel
7)
W1
D0
P0
A
N
F
W
E
13.0 ±0.25
P2
Label
P1
Direction of unreeling
W2
Leader: min. 400 mm *
Trailer: min. 160 mm *
*) Dimensions acc. to IEC 60286-3; EIA 481-D
OHAY0324
Reel dimensions [mm]
A
W
Nmin
W1
W2 max
Pieces per PU
180 mm
8 + 0.3 / - 0.1
60
8.4 + 2
14.4
600
9 Version 0.0 | 2018-08-27
SFH 4736
Barcode-Product-Label (BPL)
Dry Packing Process and Materials
6)
Moisture-sensitive label or print
Barcode label
L
VE
LE
see
lab
e
If
nk,
bla cod
bar
hu
ve
y
el
H)
(R
dit
mi
e
ed ag
RH
/60
˚C
rar ck
rel
30
N s VE RS
inf pa
ainITI TO
of
to ak
90
d
ntNSUC
ns
(pe
or
TIO
d
cte
itio
an bje ing
U g coSEND
˚C
nd
5
˚C su ss
CO
Ais baRE
co
ce
y
40 be
TU MI
CThIS
˚C
ll pro
tor
SE
ati
_
urs
urs
Ho
de
urs
Ho
co
72
Ho urs
te
48
e
Ho
24 6
da
e
tim
e
th
tim
or
23
tim e
at t wi nt
l wi
or
fac
˚C
Flo
s
tim
at
or
ca
at
re.
Flo
tha ale el
d
or
nth
nti
Flo
du
uiv
if: rea
es
l 4 5
Flo
mo
lab
ce
ide
eq
low
g,
l
ve
vic
5a
is
or
be
24
de
tin en
pro
ve l
6
Le
de ,
e
te
co
g:
un wh
Le ve l
ke
r
se
da
ba ed low
ure
Le ve
mo %
ba
e
ba
al
d
ure
Le
ist
en ref e
e 10
for
tim
se
ist ure
ale op se
for >
Mo
se
3
ure
is
or .
se
is ha
Mo istist
nk
be
g
nk
-03
rd
Mo
in
n Flo
r-p
RH g,
bla
Mo
ba
TD
po If blathi
life s
kin Ca
(if
ar
t.
wi
J-S
10 ba tor
thi, va p.
elf
Ye ar ks
_
e icat me , C
1
tem ted
Ye ee urs
Sh ter
at
ed
low
uir
1
W Ho
un
Af
Ind no uir DE
1.
dy
d
e
4
ref
8
y
is
req
JE
2.
bo
e
Mo ore
tim
req
16
C/
e
es dit2b
a)
St
tim
or
is IP
mior
ed
vic
tim e
b)
g e
or
Hu
en
Flo
tim
or
De
2a kin nc
te
Flo
op
a)
or
3.
b) baere
Flo
da
e
l 1 2
Flo
If
al
ref
tim ve
l
4.
se
d
l 2a
ve
Le
3
g
an
ve l
Le
Ba
te
ure
Le ve
ure
ist
Le
Da
ure
ist
Mo
ist ure
Mo
Mo ist
Mo
MO
TO
OP
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
Desiccant
AM
OSR
OHA00539
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033.
10 Version 0.0 | 2018-08-27
SFH 4736
Transportation Packing and Materials
6)
DE
R
18
-1
-1
+Q
P
OU
P:
44
01
C:
99
8
D/
(9
D)
210
021
34
O
H
12
(Q
)Q
TY
S S
em R
ic AM
o
nd O
uc p
to to
H
rs
NO
TC
BA
3G
5
14
2
(6
P)
NO
: 12
T
11
00
LO
(1
T)
NO
OD
M
Y
DE
-1
18
P
-1
Q
R
G
RO
UP
(G
44
01
D/
C:
(9
D)
AM
00
TY
:2
)Q
O
SR
34
NO
(X
PR
O
D
5
14 2
110 0
(Q
A
R
ic
NO
O
S
em
S
(1
T)
LO
T
NO
(6
P)
: 12
3G
BA
TC
H
H
12
o M
n O
d
u p
ct to
o
rs
M
Muster
u L
lt S
iT Y
O T6
P 76
L
E Bi
D Bi n1
Bi n2 : P-
n3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R0 ditio 0 C R
PA 77 na RT
l TE
CK
VA
XT
R:
(X
PR
8
2199
2100
GR
L
el
at
(G
M
u L
lt S
iT Y
O T67
P
L 6
Muster
E
V
LE
see
lab
e
H)
nk,
cod
(R
bla
r
If
ty
ba
idi
RH
m
hu
0%
e
/6
ive d
˚C
re ag
lat
ra ck
re
30
_
inf pa
k
s
of
to
90
ea
ur s
d
ns
(p
or
d
Ho ururs s
de
cteg
itio
Ho
an bje
co
˚C
72
sin
nd
Ho ur
5
te
48
˚C su es
e
Ho
co
24 6
da
40 be oc
ry
tim e e
˚C
th
r
pr
ll
tim
cto
23
oo r
wi nt
tim e
l wi
fa
r
˚C
Fl oo
tim
s
at
at ale
e.
at
ica
Fl
th
oo r
th
ur
el
nt
Fl oo
on es uiv
if: read
ed
l 4 5
Fl
lab
m
ide
eq
low
oc
ve l
vic
is
ingen
de
be
24 de or
l 5a6
pr
Le ve
nt wh
e
te
co
, w,
g:
ve l
Le
ke
r
re
ou%
se
da
ed
ba
flo ba
Le ve
tu re
m
ba
e
al
d
Le
r
en re
re
e
re 10
ois tu
tim
se
fo
tu re
ale op se
fo >
M ois
r
se
3
is
is ha
se
M
ois tu
nk
be
oo .
03
nk
rd
g
M ois
in
r-p
bla
in Fl RH g,
DM
ba
Ca
po If blath
kin
life is
(if
ar
ST
p.
wi
10 baator et
Jelf r th va
Ye ar ks s
m
_
m
ed
1
Ye ee ur
d, C
iredic t
Sh te w, te
at
nt
1
W Ho
Af flody
qu In no ire DE
1.
e
ou
4 8
re
ed re ty is
qu JE
2.
bo
M
or
tim e e
16
re C/
es idi 2b
r
a)
St
tim
mor
is IP
e
ed
r
oo
vic
tim
b)
g e
r
Hu
Fl oo
en
tim
De
2a kin nc
te
Fl oo r
a)
op
re
3.
b)
Fl oo
da
ba
e
fe
l 1
Fl
If
al
re
tim ve l 2
4.
se
d
l 2a3
Le ve
g
an
ve l
Le
re
Ba
te
Le ve
tu re
Le
Da ois tu
re
tu re
M
ois
M
ois tu
M ois
M
Nns IVEORS
ai IT
ntNS CT
TIO
DU
U g EcoSE
ON
A ba
IC
UR
M
CThisSTSE
OI
M TO
OP
M
Y
Barcode label
E Bi
D n1
Bi
Bi n2 : Pn3 : Q- 1: 1- 20
M
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
0 C
R0 dit
ion C R
PA 77 al RT
CK
TE
VA
XT
R:
Barcode label
Packing
Sealing label
Dimensions of transportation box in mm
Width
Length
Height
200 ± 5 mm
195 ± 5 mm
30 ± 5 mm
11 Version 0.0 | 2018-08-27
OHA02044
SFH 4736
Notes
The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of
lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this
data sheet falls into the class moderate risk (exposure time 0.25 s). Under real circumstances (for exposure
time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources
have a high secondary exposure potential due to their blinding effect. When looking at bright light sources
(e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation.
Subcomponents of this device contain, in addition to other substances, metal filled materials including silver.
Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage,
production, and use. Devices that showed visible discoloration when tested using the described tests above
did show no performance deviations within failure limits during the stated test duration. Respective failure
limits are described in the IEC60810.Subcomponents of this device contain, in addition to other substances,
metal filled materials including silver. Metal filled materials can be affected by environments that contain
aggressive substances during storage, production, and use. Devices that showed visible discoloration when
tested using the described tests above did show no performance deviations within failure limits during the
stated test duration. Respective failure limits are described in the IEC60810.
For further application related informations please visit www.osram-os.com/appnotes
12 Version 0.0 | 2018-08-27
SFH 4736
Disclaimer
OSRAM OS assumes no liability whatsoever for any use of this document or its content by recipient including, but not limited to, for any design in activities based on this preliminary draft version. OSRAM OS may
e.g. decide at its sole discretion to stop developing and/or finalising the underlying design at any time.
Disclaimer
Language english will prevail in case of any discrepancies or deviations between the two language wordings.
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may
contain dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version in the OSRAM OS Webside.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest
sales office.
By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For
packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to
invoice you for any costs incurred.
Product safety devices/applications or medical devices/applications
OSRAM OS components are not developed, constructed or tested for the application as safety relevant
component or for the application in medical devices.
In case Buyer – or Customer supplied by Buyer– considers using OSRAM OS components in product safety
devices/applications or medical devices/applications, Buyer and/or Customer has to inform the local sales
partner of OSRAM OS immediately and OSRAM OS and Buyer and /or Customer will analyze and coordinate the customer-specific request between OSRAM OS and Buyer and/or Customer.
13 Version 0.0 | 2018-08-27
SFH 4736
Glossary
1)
Total radiant flux: Measured with integrating sphere.
2)
Reverse Operation: Reverse Operation of 10 hours is permissible in total. Continuous reverse operation is not allowed.
3)
Thermal resistance: junction - soldering point, of the device only, mounted on an ideal heatsink (e.g.
metal block)
4)
Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures.
These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g.
because of technical improvements, these typ. data will be changed without any further notice.
5)
Testing temperature: TA = 25°C
6)
Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
7)
Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.
14 Version 0.0 | 2018-08-27
SFH 4736
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
15 Version 0.0 | 2018-08-27
