SPL BK94-40 (919,5 +/-5NM)
    AMSOSRAM(艾迈斯半导体)
    LASER BAR HIGH POWER
SPL BK94-40 (919,5 +/-5NM) 数据手册
2007-05-23 Unmounted Laser Bars, 50% Fill Factor, 940nm Version 0.1 SPL BK94-40 SPL BK94-40 Features • Unmounted monolithic linear array • 25 emitter design (50% fill factor) • Recommended optical power 250W • Typical conversion efficiency 63% • High efficiency and reliable MOVPE-grown quantum-well structure • Other center pulse wavelengths available upon request • Solderable p- and n-side metallization • N-side metallization suitable for wire bonding Applications Recommended for continuous wave (cw)-applications Pumping of solid-state and fiber lasers Direct material processing Heating, illumination Medical applications Printing applications • • • • • • Safety Advices Depending on the mode of operation, these devices emit highly concentrated non-visible infrared light which can be hazardous to the human eye. Products which incorporate these devices have to follow the safety precautions found in IEC 60825-1 “Safety of laser products”. Ordering Information Type Power1) Wavelength2) Ordering Code SPL BK94-40 250 W 931 ± 5 nm Q65111A7639 1) 2) Recommended optical power implies a thermal resistance of Rth < 0.3 K/W. Center pulse wavelength (wafer median) of unmounted laser bars at 1 μs pulse width and 4 kHz repetition rate. Other wavelengths or tolerances available upon request. 07.07.2017 1 DRAFT – For reference only. Subject to change –  may be necessary in a limited number of cases. Version 0.1 SPL BK94-40 Characteristics1) (TA = 25 °C) Parameter Symbol Values Unit min. typ. Recommended output power Pop - 250 - W Threshold current Ith - 24 27 A Operating current 2) max. Iop - 236 260 A η 1.08 1.18 - W/A Total conversion efficiency2)3) ηtot - 63 - % Beam divergence fast-axis2)4) θ - 45 - ° Beam divergence slow-axis2)3)4) θII - 7.5 - ° Slope efficiency Center pulse wavelength (wafer median) λpulse 926 931 936 nm Spectral width (FWHM)2) Δλ - 3 - nm TE Polarization2)3) PTE - > 95 - % 1) All characteristics and limitations refer to pulsed measurements (1 μs pulse width at 4 kHz repetition rate) of unmounted laser bars. The realization of the specified values in cw-mode (continuous wave mode) implies a suitable mounting technology with a thermal resistance of Rth < 0.3 K/W. The operating emission wavelength depends on the operating mode (cw or pulsed, ambient temperature, thermal resistance Rth) and is in general higher than the specified center pulse wavelength λpulse. All characteristics obtained in the respective operating mode may differ from the characteristics specified herein. 2) Specified at the typical optical output power Pop, typ. 3) Parameter strongly depends on bar mounting.  Typical values for cw-operation of bars mounted with hard solder (Rth = 0.3 K/W, TA = 20°C). 4) Full width at 95% power content. Dimensions Parameter Symbol Values Unit min. typ. Number of emitters n - 25 max. - Single emitter contact width w - 200 - µm Emitter pitch p - 400 - µm Fill factor F - 50 - % mm Bar width W 11.3 11.4 11.5 Bar height H 105 115 125 µm Resonator length L 3990 4000 4010 µm 07.07.2017 2 DRAFT – For reference only. Subject to change –  may be necessary in a limited number of cases. Version 0.1 SPL BK94-40 Disclaimer OSRAM OS assumes no liability whatsoever for any use of this document or its content by recipient including, but not limited to, for any design in activities based on this preliminary draft version. OSRAM OS may e.g. decide at its sole discretion to stop developing and/or finalizing the underlying design at any time. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered.              Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 07.07.2017 3 DRAFT – For reference only. Subject to change –  may be necessary in a limited number of cases.
SPL BK94-40 (919,5 +/-5NM) 价格&库存
很抱歉,暂时无法提供与“SPL BK94-40 (919,5 +/-5NM)”相匹配的价格&库存,您可以联系我们找货
