www.osram-os.com
Produktdatenblatt | Version 1.1
SFH 4770
SFH 4770
SYNIOS ® P2720
IR SYNIOS P2720 (850 nm) - 120°
Applications
——Safety and Security, CCTV
——CCTV Surveillance
——Eye Tracking
Features:
——Package: clear silicone
——Corrosion Robustness Class: 3B
——ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2)
——IR lightsource with high efficiency
——Low thermal resistance (Max. 10 K/W)
——Centroid wavelength 850 nm
Ordering Information
Type
Total radiant flux 1)
IF = 1000 mA; tp = 10 ms
Φe
450 ... 900 mW
Discontinued
SFH 4770
1 Version 1.1 | 2019-07-16
typ.
Φe
600 mW
Ordering Code
Q65112A1540
SFH 4770
Maximum Ratings
TA = 25 °C
Parameter
Symbol
Values
Operating temperature
Top
min.
max.
-40 °C
100 °C
Storage temperature
Tstg
min.
max.
-40 °C
100 °C
Junction temperature
Tj
max.
145 °C
Forward current
IF
max.
2000 mA
Surge current
tp ≤ 2 ms; D = 0.005
IFSM
max.
3A
Reverse voltage 2)
VR
max.
5V
Power consumption
Ptot
max.
3.45 W
ESD withstand voltage
VESD
max.
2 kV
For the forward current and power consumption please see “maximum permisssible forward current” diagram
Discontinued
2 Version 1.1 | 2019-07-16
SFH 4770
Characteristics
IF = 1000 mA; tp = 10 ms; TA = 25 °C
Parameter
Symbol
Peak wavelength
λpeak
typ.
860 nm
Centroid wavelength
λcentroid
typ.
850 nm
Spectral bandwidth at 50% Irel,max (FWHM)
∆λ
typ.
30 nm
Half angle
φ
typ.
60 °
Dimensions of active chip area
LxW
typ.
1 x 1
mm x mm
Rise time (10% / 90%)
IF = 3 A; RL = 50 Ω
tr
typ.
11 ns
Fall time (10% / 90%)
IF = 3 A; RL = 50 Ω
tf
typ.
14 ns
Forward voltage
VF
typ.
max.
1.65 V
2.1 V
Forward voltage
IF = 2 A; tp = 100 µs
VF
typ.
max.
1.9 V
2.5 V
Forward voltage
IF = 3 A; tp = 100 µs
VF
typ.
max.
2.15 V
3V
Reverse current 2)
VR = 5 V
IR
max.
10 µA
Radiant intensity
Ie
typ.
200 mW/sr
Radiant intensity
Ie
typ.
370 mW/sr
Φe
typ.
1110 mW
Temperature coefficient of voltage
TCV
typ.
-1 mV / K
Temperature coefficient of brightness
TCI
typ.
-0.3 % / K
Temperature coefficient of wavelength
TCλ
typ.
0.3 nm / K
Thermal resistance junction solder point real 3)
RthJS
typ.
max.
6.5 K / W
10.0 K / W
Discontinued
3 Version 1.1 | 2019-07-16
Values
SFH 4770
Brightness Groups
TA = 25 °C
Group
min.
Φe
max.
Φe
DA2
450 mW
630 mW
DB
500 mW
800 mW
EA1
630 mW
900 mW
Only one group in one packing unit (variation lower 1.6:1).
Relative Spectral Emission
4), 5)
Ie,rel = f (λ); IF = 1000 mA; tp = 10 ms
OHF04132
100
I rel %
80
60
40
Discontinued
750
800
850
nm 950
λ
4 Version 1.1 | 2019-07-16
SFH 4770
Radiation Characteristics
4), 5)
Ie,rel = f (φ)
40˚
30˚
20˚
10˚
0˚
ϕ
50˚
OHL01660
1.0
0.8
0.6
60˚
0.4
70˚
0.2
80˚
90˚
100˚
1.0
0.8
Forward current
0.6
0.4
0˚
20˚
40˚
60˚
80˚
100˚
Relative Total Radiant Flux
4), 5)
IF = f (VF); single pulse; tp = 100 µs
OHF05693
101
Φe
Φe (1 A)
0.5
4), 5)
Φe/Φe(1000mA) = f (IF); single pulse; tp = 100 µs
1
120˚
100
10-1
0.1
0.05
10-2
Discontinued
0.01
1.4
1.6
1.8
2.0
5 Version 1.1 | 2019-07-16
10-3 -2
10
10-1
100
A
IF
101
SFH 4770
Max. Permissible Forward Current
Permissible Pulse Handling Capability
IF,max = f (TS); RthJS = 10.0 K/W
IF = f (tp); duty cycle D = parameter; TS = 85°C
[ ] 2000
3
1500
2
1000
1
:D=1
: D = 0,5
: D =0,2
: D =0,1
: D =0,05
: D =0,02
: D =0,01
: D =0,005
500
Discontinued
6 Version 1.1 | 2019-07-16
60
80
100
0 -6 -5 -4 -3
10 10 10 10 0.01 0.1 1
10 100
SFH 4770
Dimensional Drawing
6)
Further Information
Approximate Weight:
12.0 mg
Package marking:
Cathode
Corrosion test:
Class: 3B
Test condition: 40°C / 90 % RH / 15 ppm H2S / 14 days (stricter than IEC
60068-2-43)
Discontinued
7 Version 1.1 | 2019-07-16
SFH 4770
Recommended Solder Pad
Discontinued
8 Version 1.1 | 2019-07-16
6)
SFH 4770
Reflow Soldering Profile
Product complies to MSL Level 2 acc. to JEDEC J-STD-020E
OHA04525
300
˚C
T 250
Tp 245 ˚C
240 ˚C
tP
217 ˚C
200
tL
150
tS
100
50
25 ˚C
100
150
200
250
s 300
t
Profile Feature
Symbol
Pb-Free (SnAgCu) Assembly
Minimum
Recommendation Maximum
Ramp-up rate to preheat*)
25 °C to 150 °C
tS
Time tS
TSmin to TSmax
Ramp-up rate to peak*)
TSmax to TP
Liquidus temperature
60
2
3
100
120
2
3
K/s
s
K/s
TL
217
Time above liquidus temperature
tL
80
100
s
Peak temperature
TP
245
260
°C
Time within 5 °C of the specified peak
temperature TP - 5 K
tP
3
6
Ramp-down rate*
TP to 100 °C
10
Time
25 °C to TP
Discontinued
Unit
All temperatures refer to the center of the package, measured on the top of the component
* slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range
9 Version 1.1 | 2019-07-16
°C
480
s
K/s
s
SFH 4770
Taping
6)
Discontinued
10 Version 1.1 | 2019-07-16
SFH 4770
Tape and Reel
7)
W1
D0
P0
A
N
F
W
E
13.0 ±0.25
P2
Label
P1
Direction of unreeling
W2
Leader: min. 400 mm *
Trailer: min. 160 mm *
*) Dimensions acc. to IEC 60286-3; EIA 481-D
OHAY0324
Reel Dimensions
A
180 mm
W
Nmin
8 + 0.3 / - 0.1 mm
Discontinued
11 Version 1.1 | 2019-07-16
W1
60 mm
W2 max
8.4 + 2 mm
14.4 mm
Pieces per PU
2000
SFH 4770
Barcode-Product-Label (BPL)
Dry Packing Process and Materials
6)
Moisture-sensitive label or print
L
E
E
V
l
e be
sela
k,
H
de
L
If
an
bl r co
ba
(R
id
m
ity
H
R
hu
0%
e
e
/6
tiv
˚C
la ared ag
ck
re
fr
30
_
in pa
k
of
to
90
rs
ea
s
d
rs
ou
or
te (p
on
rs
H
de
ou
iti
H
an bjec ng
ou rs
co
˚C
72
si
nd
H ou
5
te
48
˚C su es
e
H
co
24 6
da
e
y
40 be oc
tim
˚C
e
or
ith
tim
ill pr).
or
ct
w
O
w nt
23
tim e
at
lo
or
fa
M TO
F
s
al
tim
at le ˚C at
lo
at
or
e.
P
th
F
l
tic
th va
lo or
ur
O
F lo
s ui
on
be
if: read
en
w
ed
l 4 5
F
m
la
ce eq
id
lo
g, n
oc
l
ve
vi
5a
is
in
or
be
24
de
pr
ve l
6
Le
de ,
nt whe
e
te
co
g:
, w
e
Le ve l
ke
r
ou
se
da
ba ed flo
ur
e
Le ve
m %
ba
e
ba
al
st
ur e
Le
r
en re
ed
e
re> 10
oi
st
e
e
fo
tim
ur
se
al
op
fo
M
se
oi st ur
as
k,
is
or .
33
se
is
M oi st
bed
k,
lo H
an
g ph
-0
M oi
in
an in F R ng ar
rbl
D
M
e
ba
T
r
po If bl ith
lif
ki r C.
(if
S
is
p.
w
ea r ks
lf
J10 ba to et
th va
Y ea
m
rs
m
_
r w,
he
ed
1
ee
te
Y
d, EC
iredicat
S
fte
at
nt
1
W Hou
D
A flody
qu In no ire
1.
d
e
ou
4 8
re
reity is
qu/JE
re
2.
bo
e
M
tim
to es id 2b
re C
16
e
a)
S
tim
is IP
ic
ed loor
tim e
b) ev Humor
or
e
en
F
tim
lo
or
D
2a king
nc
te
F
op
a)
lo or
3.
b) ba re
F lo
da
e
fe
l 1 2
F
If
al
re
tim ve
l
4.
se
d
l 2a
ve
Le
3
an
ve l
ag
e
Le
e
B
ve
ur
e
Le
at
st
ur
e
Le
D
oi
st
ur e
M
oi
st ur
M
oi st
M oi
M
N
E RS
s
in IV O
IT T
S C
nta
N U
TIO
U coSEND
Ais bUagRMEICO
T E
CThIS
S
d
Barcode label
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
Discontinued
Desiccant
AM
OSR
OHA00539
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033.
12 Version 1.1 | 2019-07-16
SFH 4770
Schematic Transportation Box
6)
Barcode label
N
O
(Q
)Q
TY
:2
00
D
D
/C
:0
(X
Packing
Sealing label
Length
200 ± 5 mm
195 ± 5 mm
Discontinued
13 Version 1.1 | 2019-07-16
M
Y
DE
-1
+Q
-1
R
18
P
OHA02044
Dimensions of Transportation Box
Width
RO
UP
M
RA
OS
PR
O
D
5
14 2
110 0
G
4
01
4
C:
D/
(9
D)
(Q
)Q
TY
O
TC
P)
(6
T
LO
(1
T)
O
D
PR
D
EM
Y
18
R
-1
Q
P
-1
G
R
O
U
P:
u L
lt S
iT Y
O T6
P 7
L 6
M
14
4
(G
E Bi
D Bi n1
Bi n2 : Pn3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R ditio 0 C R
07
PA 7 na RT
l TE
C
KV
XT
AR
Muster
A
o M
n O
d
u p
cto to
rs
R
34
ic
N
O
O
S
H
12
G
BA
TC
H
(1
T)
LO
T
N
O
:1
(6
P)
23
em
8
2199
2100
5
14 2
110 0
(X
O
M O
PT
O
M
998
NO
CThISTU
SE
S
21
2100
BA
_
s
ur s
Ho ururs s
de
Ho
co
72
Ho ur
te
48
e
Ho
24 6
da
40 be
tim e e
˚C
or
th
r
pr
ll
tim
ct
23
oo r
wi nt
tim e
at
l wi
fa
r
Fl oo
tim
s
at
at le ˚C at
e.
ica
l
Fl
th
oo r
th va
ur
nt
Fl oo
s ui
be
on
if: read
w
ed
l 4 5
Fl
la
m
ide
ce eq
lo
g,
oc
ve l
vi
is
in en
de
be
24 de or
l 5a6
pr
Le ve
nt wh
e
te
co
, w,
g:
ve l
Le
ke
r
re
ou
se
da
ba ed flo ba
Le ve
tu re
m %
ba
e
al
e
Le
r
en re
e
ed
re 10
ois stu ur e
tim
se
fo
al
op se
fo >
M oi
r
se
st ur
3
is
is ha
se
M
oi st
nk
be
k,
oo .
03
rd
g
M oi
in
an in Fl RH g,
r-p
bla
DM
ba
Ca
po If bl th
kinr
life is
(if
ar
ST
f
p.
wi
10 ba to et
Jel r th va
Ye ar ks s
m
_
cat m d, C
ed
1
Ye ee ur
ire
Sh te w, te
di
at
nt
1
W Ho
Af flody
qu In no ire DE
1.
e
ou
4 8
re
ed re
qu JE
2.
bo
ity is
M
or
tim e e
16
re C/
es id 2b
r
a)
St
tim
mor
is IP
ed
oo r
tim e
vic
b)
g e
r
Hu
Fl oo
en
tim
De
2a kin nc
te
Fl oo r
a)
op
3.
b) ba re
Fl oo
da
e
fe
l 1
Fl
If
al
re
tim ve l 2
4.
se
d
l 2a3
Le ve
g
an
ve l
e
Le
Ba
te
ur e
Le ve
Le
Da oist stur e
ur e
M
oi
st ur
M
oi st
M oi
H
12
34
RH
0%
/6
˚C
L
e el
selab
H)
nk de
co
(R
bla
r
S S
em R
ic AM
o
n O
d
u p
ct to
o
H
rs
NO
If
23
G
E
V
E
ba
ity
id
m
hu
e
e
d
tiv
re ag
NO
:1
L
la
re
fra ck
30
Nns IVE RS
in pa
k
of
ai IT TO
to
90
ea
d
ntNS
ns
UC
or
TIO
te (p
d
g
itio
ND
U g coSE
an bjec
˚C
sin
nd
O
5
˚C su es
Ais baRE
co
IC
y
M
oc
(G
M
u L
lt S
iT Y
O T6
P 7
L 6
E
D
Muster
Bi
Bi n1
Bi n2 : P-
n3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R0 ditio 0 C R
PA 77 na RT
l TE
CK
VA
XT
R:
Barcode label
Height
30 ± 5 mm
SFH 4770
Notes
The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of
lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this
data sheet falls into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the
eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light
sources have a high secondary exposure potential due to their blinding effect. When looking at bright light
sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation.
Subcomponents of this device contain, in addition to other substances, metal filled materials including silver.
Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage,
production, and use. Devices that showed visible discoloration when tested using the described tests above
did show no performance deviations within failure limits during the stated test duration. Respective failure
limits are described in the IEC60810.
For further application related information please visit www.osram-os.com/appnotes
Discontinued
14 Version 1.1 | 2019-07-16
SFH 4770
Disclaimer
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may
contain dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version on the OSRAM OS website.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest
sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of
transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we
shall have to invoice you for any costs incurred.
Product and functional safety devices/applications or medical devices/applications
OSRAM OS components are not developed, constructed or tested for the application as safety relevant
component or for the application in medical devices.
OSRAM OS products are not qualified at module and system level for such application.
In case buyer – or customer supplied by buyer – considers using OSRAM OS components in product safety
devices/applications or medical devices/applications, buyer and/or customer has to inform the local sales
partner of OSRAM OS immediately and OSRAM OS and buyer and /or customer will analyze and coordinate the customer-specific request between OSRAM OS and buyer and/or customer.
Discontinued
15 Version 1.1 | 2019-07-16
SFH 4770
Glossary
1)
Total radiant flux: Measured with integrating sphere.
2)
Reverse Operation: Reverse Operation of 10 hours is permissible in total. Continuous reverse operation is not allowed.
3)
Thermal resistance: junction - soldering point, of the device only, mounted on an ideal heatsink (e.g.
metal block)
4)
Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures.
These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g.
because of technical improvements, these typ. data will be changed without any further notice.
5)
Testing temperature: TA = 25°C (unless otherwise specified)
6)
Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
7)
Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.
Discontinued
16 Version 1.1 | 2019-07-16
SFH 4770
Revision History
Version
Date
Change
1.0
2019-01-23
Initial Version
1.1
2019-07-15
Discontinued
Discontinued
17 Version 1.1 | 2019-07-16
SFH 4770
Discontinued
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
18 Version 1.1 | 2019-07-16
