KW DMLN31.SG-6J6K-EBXD46EBZB46-8E8G-ZKW 数据手册
www.osram-os.com
Produktdatenblatt | Version 1.1
KW DMLN31.SG
KW DMLN31.SG
SYNIOS ® P2720
This compact LED device is part of the SYNIOS
P2720 family. Given the scalability of this product
family, it provides full performance and flexibility with
just one footprint.
The KW DMLN31.SG product is meant to provide
superior light quality in ¼ mm² chip size class.
Applications
——Headlamps, LED & Laser & Night Vision
——Signalling
Features:
——Package: SMD epoxy package
——Chip technology: UX:3
——Typ. Radiation: 120° (Lambertian emitter)
——Color: Cx = 0.32, Cy = 0.33 acc. to CIE 1931 (● white)
——Corrosion Robustness Class: 3B
——Qualifications: The product qualification test plan is based on the guidelines of IEC60810, Lamps for
road vehicles – Performance requirements – Requirements and test conditions for LED packages.
——ESD: 8 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 3B)
1 Version 1.5 | 2018-07-10
KW DMLN31.SG
Ordering Information
Type
KW DMLN31.SG-6J6K-ebvF46fcbB46-8E8G
2 Version 1.5 | 2018-07-10
Luminous Flux 1)
IF = 200 mA
ΦV
Ordering Code
50 ... 90 lm
Q65111A6228
KW DMLN31.SG
Maximum Ratings
Parameter
Symbol
Operating Temperature
Top
min.
max.
-40 °C
125 °C
Storage Temperature
Tstg
min.
max.
-40 °C
125 °C
Junction Temperature
Tj
max.
150 °C
Junction Temperature for short time applications*
Tj
max.
175 °C
Forward Current
TS = 25 °C
IF
min.
max.
5 mA
300 mA
Surge Current
t ≤ 10 µs; D = 0.005 ; TS = 25 °C
IFS
max.
750 mA
ESD withstand voltage
VESD
Reverse current 2)
IR
*The median lifetime (L70/B50) for Tj =175°C is 100h.
3 Version 1.5 | 2018-07-10
Values
8 kV
max.
200 mA
KW DMLN31.SG
Characteristics
IF = 200 mA; TS = 25 °C
Parameter
Symbol
Chromaticity Coordinate 3)
Cx
Cy
typ.
typ.
0.32
0.33
Viewing angle at 50 % IV
2φ
typ.
120 °
Forward Voltage 4)
IF = 200 mA
VF
min.
typ.
max.
2.75 V
3.00 V
3.50 V
Reverse voltage (ESD device)
VR ESD
min.
45 V
Reverse voltage
IR = 20 mA
VR
max.
1.2 V
Real thermal resistance junction/solderpoint 5)
RthJS real
typ.
max.
18 K / W
20 K / W
Electrical thermal resistance junction/solderpoint 5)
with efficiency ηe = 30 %
RthJS elec.
typ.
max.
13 K / W
14 K / W
2)
4 Version 1.5 | 2018-07-10
Values
KW DMLN31.SG
Brightness Groups
Group
Luminous Flux 1)
IF = 200 mA
min.
ΦV
Luminous Flux 1)
IF = 200 mA
max.
ΦV
Luminous Intensity 6)
IF = 200 mA
typ.
Iv
6J
50 lm
56 lm
18 cd
7J
56 lm
63 lm
20 cd
8J
63 lm
71 lm
22 cd
5K
71 lm
80 lm
25 cd
6K
80 lm
90 lm
28 cd
Forward Voltage Groups
Group
Forward Voltage 4)
IF = 200 mA
min.
VF
Forward Voltage 4)
IF = 200 mA
max.
VF
8E
2.75 V
3.00 V
8F
3.00 V
3.25 V
8G
3.25 V
3.50 V
5 Version 1.5 | 2018-07-10
KW DMLN31.SG
Chromaticity Coordinate Groups
ebvF46-fcbB46
0,0
Cy
Cx
0,2
0,4
0,6
0,8
550 nm
0,6
500 nm
600 nm
0,4
700 750 nm
0,2
0,0
400 380 nm
Cy
0,36
0,35
fcbB46
0,34
ebzB46
ebxD46
0,33
ebvF46
0,32
0,31
0,310
0,315
0,320
0,325
Cx
6 Version 1.5 | 2018-07-10
0,330
0,335
KW DMLN31.SG
Color Chromaticity Groups 3)
Group
Cx
Cy
Group
Cx
Cy
ebvF46
0.3127
0.3093
ebzB46
0.3203
0.3274
0.3212
0.3175
0.3299
0.3361
0.3199
0.3325
0.3298
0.3526
0.3104
0.3234
0.3190
0.3430
0.3163
0.3181
0.3248
0.3370
0.3253
0.3266
0.3350
0.3460
0.3246
0.3424
0.3355
0.3633
0.3145
0.3330
0.3241
0.3534
ebxD46
7 Version 1.5 | 2018-07-10
fcbB46
KW DMLN31.SG
Group Name on Label
Example: 5K-ebvF46-8E
Brightness
Color chromaticity
Forward Voltage
5K
ebvF46
8E
8 Version 1.5 | 2018-07-10
KW DMLN31.SG
Relative Spectral Emission
6)
Φrel = f (λ); IF = 200 mA; TS = 25 °C
Φrel
KW DMLN31.SG
1,0
: Vλ
: white
0,8
0,6
0,4
0,2
0,0
350
400
450
500
550
600
650
700
750
800
λ [nm]
Radiation Characteristics
6)
Irel = f (ϕ); TS = 25 °C
KW DMLN31.SG
ϕ [°]
-20°
-40°
-50°
-10°
0°
10°
20°
30°
40°
50°
60°
70°
80°
90°
1,0
-30°
0,8
0,6
-60°
-70°
-80°
-90°
-100°
9 Version 1.5 | 2018-07-10
0,4
0,2
0,0
Irel
KW DMLN31.SG
Forward current
Relative Luminous Flux
6), 7)
IF = f(VF); TS = 25 °C
IF [mA]
6), 7)
Φv/Φv(200 mA) = f(IF); TS = 25 °C
KW DMLN31.SG
ΦV
KW DMLN31.SG
300
ΦV(200mA) 1,4
250
1,2
1,0
200
0,8
150
0,6
100
0,4
0,2
50
VF [V]
Chromaticity Coordinate Shift
6)
∆Cx,∆Cy = f(IF); TS = 25 °C
∆Cx
∆Cy
KW DMLN31.SG
0,03
: ∆ Cx
: ∆ Cy
0,02
0,01
0,00
-0,01
-0,02
50
5
-0,03
IF [mA]
10 Version 1.5 | 2018-07-10
3,2
10
2,8
50
0,0
2,6
5
5
2,5
IF [mA]
KW DMLN31.SG
Forward Voltage
6)
∆VF = VF - VF(25 °C) = f(Tj); IF = 200 mA
∆VF [V]
Φv/Φv(25 °C) = f(Tj); IF = 200 mA
KW DMLN31.SG
0,3
Φv
KW DMLN31.SG
1,2
Φv(25°C)
0,2
1,0
0,1
0,8
0,0
0,6
-0,1
0,4
-0,2
0,2
-0,3
-40 -20
60
80 100 120 140
Tj [°C]
6)
∆Cx,∆Cy = f(Tj); IF = 200 mA
∆Cx
∆Cy
6)
KW DMLN31.SG
0,03
: ∆ Cx
: ∆ Cy
0,02
0,01
0,00
-0,01
-0,02
-0,03
-40 -20
60
80 100 120 140
Tj [°C]
11 Version 1.5 | 2018-07-10
0,0
-40 -20
60
80 100 120 140
Tj [°C]
KW DMLN31.SG
Max. Permissible Forward Current
IF = f(T)
KW DMLN31.SG
IF [mA]
300
250
200
: Ts
150
100
50
60
80
100
120
T [°C]
Permissible Pulse Handling Capability
IF = f(tp); D: Duty cycle
KW DMLN31.SG
KW DMLN31.SG
TS = 0°C ... 123°C
TS = 125°C
IF [A]
IF [A]
0,8
0,8
: D = 1.0
: D = 0.5
: D = 0.2
: D = 0.1
: D = 0.05
: D = 0.02
: D = 0.01
: D = 0.005
0,6
0,6
0,4
0,4
10-6
: D = 1.0
: D = 0.5
: D = 0.2
: D = 0.1
: D = 0.05
: D = 0.02
: D = 0.01
: D = 0.005
10-5
10-4
10-3
0,01
0,1
1
10
Pulse time [s]
12 Version 1.5 | 2018-07-10
10-6
10-5
10-4
10-3
0,01
0,1
1
10
Pulse time [s]
KW DMLN31.SG
Dimensional Drawing
8)
Approximate Weight:
12.0 mg
Corrosion test:
Class: 3B
Test condition: 40°C / 90 % RH / 15 ppm H2S / 14 days (stricter then IEC
60068-2-43)
ESD advice:
13 Version 1.5 | 2018-07-10
LED is protected by ESD device which is connected in parallel to LED-Chip.
KW DMLN31.SG
Electrical internal circuit
Recommended Solder Pad
8)
For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not
suitable for ultra sonic cleaning.
14 Version 1.5 | 2018-07-10
KW DMLN31.SG
Reflow Soldering Profile
Product complies to MSL Level 2 acc. to JEDEC J-STD-020E
OHA04525
300
˚C
T 250
Tp 245 ˚C
240 ˚C
tP
217 ˚C
200
tL
150
tS
100
50
25 ˚C
100
150
200
250
s 300
t
Profile Feature
Symbol
Pb-Free (SnAgCu) Assembly
Minimum
Recommendation Maximum
Ramp-up rate to preheat*)
25 °C to 150 °C
Time tS
TSmin to TSmax
Ramp-up rate to peak*)
TSmax to TP
Liquidus temperature
tS
60
2
3
100
120
2
3
Unit
K/s
s
K/s
TL
217
Time above liquidus temperature
tL
80
100
s
Peak temperature
TP
245
260
°C
Time within 5 °C of the specified peak
temperature TP - 5 K
tP
3
6
Ramp-down rate*
TP to 100 °C
10
Time
25 °C to TP
All temperatures refer to the center of the package, measured on the top of the component
* slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range
15 Version 1.5 | 2018-07-10
°C
480
s
K/s
s
KW DMLN31.SG
Taping
8)
16 Version 1.5 | 2018-07-10
KW DMLN31.SG
Tape and Reel
9)
Reel dimensions [mm]
A
W
Nmin
W1
W2 max
Pieces per PU
180 mm
8 + 0.3 / - 0.1
60
8.4 + 2
14.4
2000
17 Version 1.5 | 2018-07-10
KW DMLN31.SG
Barcode-Product-Label (BPL)
Dry Packing Process and Materials
8)
Moisture-sensitive label or print
Barcode label
L
VE
LE
see
lab
e
If
nk,
bla cod
bar
hu
ve
y
el
H)
(R
dit
mi
e
ed ag
RH
/60
˚C
rar ck
rel
30
N s VE RS
inf pa
ainITI TO
of
to ak
90
d
ntNSUC
ns
(pe
or
TIO
d
cte
itio
an bje ing
U g coSEND
˚C
nd
5
˚C su ss
CO
Ais baRE
co
ce
y
40 be
TU MI
CThIS
˚C
ll pro
tor
SE
ati
_
urs
urs
Ho
de
urs
Ho
co
72
Ho urs
te
48
e
Ho
24 6
da
e
tim
e
th
tim
or
23
tim e
at t wi nt
l wi
or
fac
˚C
Flo
s
tim
at
or
ca
at
re.
Flo
tha ale el
d
or
nth
nti
Flo
du
uiv
if: rea
es
l 4 5
Flo
mo
lab
ce
ide
eq
low
g,
l
ve
vic
5a
is
or
be
24
de
tin en
pro
ve l
6
Le
de ,
e
te
co
g:
un wh
Le ve l
ke
r
se
da
ba ed low
ure
Le ve
mo %
ba
e
ba
al
d
ure
Le
ist
en ref e
e 10
for
tim
se
ist ure
ale op se
for >
Mo
se
3
ure
is
or .
se
is ha
Mo istist
nk
be
g
nk
-03
rd
Mo
in
n Flo
r-p
RH g,
bla
Mo
ba
TD
po If blathi
life s
kin Ca
(if
ar
t.
wi
J-S
10 ba tor
thi, va p.
elf
Ye ar ks
_
e icat me , C
1
tem ted
Ye ee urs
Sh ter
at
ed
low
uir
1
W Ho
un
Af
Ind no uir DE
1.
dy
d
e
4
ref
8
y
is
req
JE
2.
bo
e
Mo ore
tim
req
16
C/
e
es dit2b
a)
St
tim
or
is IP
mior
ed
vic
tim e
b)
g e
or
Hu
en
Flo
tim
or
De
2a kin nc
te
Flo
op
a)
or
3.
b) baere
Flo
da
e
l 1 2
Flo
If
al
ref
tim ve
l
4.
se
d
l 2a
ve
Le
3
g
an
ve l
Le
Ba
te
ure
Le ve
ure
ist
Le
Da
ure
ist
Mo
ist ure
Mo
Mo ist
Mo
MO
TO
OP
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
Desiccant
AM
OSR
OHA00539
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033.
18 Version 1.5 | 2018-07-10
KW DMLN31.SG
Transportation Packing and Materials
8)
DE
R
18
-1
-1
+Q
P
OU
P:
44
01
C:
99
8
D/
(9
D)
210
021
34
O
H
12
(Q
)Q
TY
S S
em R
ic AM
o
nd O
uc p
to to
H
rs
NO
TC
BA
3G
5
14
2
(6
P)
NO
: 12
T
11
00
LO
(1
T)
NO
OD
M
Y
DE
-1
18
P
-1
Q
R
G
RO
UP
(G
44
01
D/
C:
(9
D)
AM
00
TY
:2
)Q
O
SR
34
NO
(X
PR
O
D
5
14 2
110 0
(Q
A
R
ic
NO
O
S
em
S
(1
T)
LO
T
NO
(6
P)
: 12
3G
BA
TC
H
H
12
o M
n O
d
u p
ct to
o
rs
M
Muster
u L
lt S
iT Y
O T6
P 76
L
E Bi
D Bi n1
Bi n2 : P-
n3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R0 ditio 0 C R
PA 77 na RT
l TE
CK
VA
XT
R:
(X
PR
8
2199
2100
GR
L
el
at
(G
M
u L
lt S
iT Y
O T67
P
L 6
Muster
E
V
LE
see
lab
e
H)
nk,
cod
(R
bla
r
If
ty
ba
idi
RH
m
hu
0%
e
/6
ive d
˚C
re ag
lat
ra ck
re
30
_
inf pa
k
s
of
to
90
ea
ur s
d
ns
(p
or
d
Ho ururs s
de
cteg
itio
Ho
an bje
co
˚C
72
sin
nd
Ho ur
5
te
48
˚C su es
e
Ho
co
24 6
da
40 be oc
ry
tim e e
˚C
th
r
pr
ll
tim
cto
23
oo r
wi nt
tim e
l wi
fa
r
˚C
Fl oo
tim
s
at
at ale
e.
at
ica
Fl
th
oo r
th
ur
el
nt
Fl oo
on es uiv
if: read
ed
l 4 5
Fl
lab
m
ide
eq
low
oc
ve l
vic
is
ingen
de
be
24 de or
l 5a6
pr
Le ve
nt wh
e
te
co
, w,
g:
ve l
Le
ke
r
re
ou%
se
da
ed
ba
flo ba
Le ve
tu re
m
ba
e
al
d
Le
r
en re
re
e
re 10
ois tu
tim
se
fo
tu re
ale op se
fo >
M ois
r
se
3
is
is ha
se
M
ois tu
nk
be
oo .
03
nk
rd
g
M ois
in
r-p
bla
in Fl RH g,
DM
ba
Ca
po If blath
kin
life is
(if
ar
ST
p.
wi
10 baator et
Jelf r th va
Ye ar ks s
m
_
m
ed
1
Ye ee ur
d, C
iredic t
Sh te w, te
at
nt
1
W Ho
Af flody
qu In no ire DE
1.
e
ou
4 8
re
ed re ty is
qu JE
2.
bo
M
or
tim e e
16
re C/
es idi 2b
r
a)
St
tim
mor
is IP
e
ed
r
oo
vic
tim
b)
g e
r
Hu
Fl oo
en
tim
De
2a kin nc
te
Fl oo r
a)
op
re
3.
b)
Fl oo
da
ba
e
fe
l 1
Fl
If
al
re
tim ve l 2
4.
se
d
l 2a3
Le ve
g
an
ve l
Le
re
Ba
te
Le ve
tu re
Le
Da ois tu
re
tu re
M
ois
M
ois tu
M ois
M
Nns IVEORS
ai IT
ntNS CT
TIO
DU
U g EcoSE
ON
A ba
IC
UR
M
CThisSTSE
OI
M TO
OP
M
Y
Barcode label
E Bi
D n1
Bi
Bi n2 : Pn3 : Q- 1: 1- 20
M
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
0 C
R0 dit
ion C R
PA 77 al RT
CK
TE
VA
XT
R:
Barcode label
Packing
Sealing label
Dimensions of transportation box in mm
Width
Length
Height
200 ± 5 mm
195 ± 5 mm
30 ± 5 mm
19 Version 1.5 | 2018-07-10
OHA02044
KW DMLN31.SG
Notes
The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of
lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this
data sheet falls into the class moderate risk (exposure time 0.25 s). Under real circumstances (for exposure
time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources
have a high secondary exposure potential due to their blinding effect. When looking at bright light sources
(e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation.
Subcomponents of this LED contain, in addition to other substances, metal filled materials including silver.
Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize LED exposure to aggressive substances during storage, production, and use. LEDs that showed visible discoloration when tested using the described tests above did
show no performance deviations within failure limits during the stated test duration. Respective failure limits
are described in the IEC60810.
For further application related informations please visit www.osram-os.com/appnotes
20 Version 1.5 | 2018-07-10
KW DMLN31.SG
Disclaimer
Disclaimer
Language english will prevail in case of any discrepancies or deviations between the two language wordings.
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may
contain dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version on the OSRAM OS webside.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest
sales office.
By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For
packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to
invoice you for any costs incurred.
Product safety devices/applications or medical devices/applications
OSRAM OS components are not developed, constructed or tested for the application as safety relevant
component or for the application in medical devices.
In case Buyer – or Customer supplied by Buyer– considers using OSRAM OS components in product safety
devices/applications or medical devices/applications, Buyer and/or Customer has to inform the local sales
partner of OSRAM OS immediately and OSRAM OS and Buyer and /or Customer will analyze and coordinate the customer-specific request between OSRAM OS and Buyer and/or Customer.
21 Version 1.5 | 2018-07-10
KW DMLN31.SG
Glossary
1)
Brightness: Brightness values are measured during a current pulse of typically 25 ms, with an internal
reproducibility of ±8 % and an expanded uncertainty of ±11 % (acc. to GUM with a coverage factor of
k = 3).
2)
Reverse Operation: Reverse Operation of 10 hours is permissible in total. Continuous reverse operation is not allowed.
3)
Chromaticity coordinate groups: Chromaticity coordinates are measured during a current pulse of
typically 25 ms, with an internal reproducibility of ±0.005 and an expanded uncertainty of ±0.01 (acc. to
GUM with a coverage factor of k = 3).
4)
Forward Voltage: The forward voltage is measured during a current pulse of typically 8 ms, with an
internal reproducibility of ±0.05 V and an expanded uncertainty of ±0.1 V (acc. to GUM with a coverage
factor of k = 3).
5)
Thermal Resistance: Rth max is based on statistic values (6σ).
6)
Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data
or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical
data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical
improvements, these typ. data will be changed without any further notice.
7)
Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single LEDs within one packing unit.
8)
Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
9)
Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.
22 Version 1.5 | 2018-07-10
KW DMLN31.SG
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
23 Version 1.5 | 2018-07-10
