LuxiGenTM High Efficiency VIOLET LED Emitter
LZ1‐00UB0R
Key Features
High Efficiency VIOLET (385‐420nm) LED emitter
Ultra‐small foot print – 4.4mm x 4.4mm
Surface mount ceramic package with integrated glass lens
Very low Thermal Resistance (4.2°C/W)
Electrically neutral thermal path
Very high Radiant Flux density
JEDEC Level 1 for Moisture Sensitivity Level
Lead (Pb) free and RoHS compliant
Emitter available on Star MCPCB (optional)
Typical Applications
Ink and adhesive curing
Dental Curing and Teeth Whitening
Counterfeit Identification
Leakage Detection
Sterilization and Medical
DNA Gel
Description
The LZ1‐00UB0R VIOLET LED emitter provides superior radiometric power in the wavelength range specifically
required for sterilization, dental curing lights, and numerous medical applications. With a 4.4mm x 4.4mm ultra‐
small footprint, this package provides exceptional optical power density. The radiometric power performance and
optimal peak wavelength of this LED are matched to the response curves of dental resins, inks and adhesives,
resulting in a significantly reduced curing time. The patented design has unparalleled thermal and optical
performance. The high quality materials used in the package are chosen to optimize light output, have excellent
VIOLET resistance, and minimize stresses which results in monumental reliability and radiant flux maintenance.
COPYRIGHT © 2019 LED ENGIN. ALL RIGHTS RESERVED. LZ1‐00UB0R (0.2 – 7/22/19)
4
LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE‐Sales@osram.com | www.osram.us/ledengin
Part number options
Base part number
Part number
Description
LZ1‐00UB0R‐xxxx
LZ1 emitter
LZ1‐10UB0R‐xxxx
LZ1 emitter on Standard Star MCPCB
Bin kit option codes
Single wavelength bin
Kit number suffix Min flux Bin Color Bin Range Description
00U4
M1
U4
M1 minimum flux; wavelength U4 bin only
00U5
M1
U5
M1 minimum flux; wavelength U5 bin only
00U6
M1
U6
M1 minimum flux; wavelength U6 bin only
00U7
M1
U7
M1 minimum flux; wavelength U7 bin only
00U8
M1
U8
M1 minimum flux; wavelength U8 bin only
5
Radiant Flux Bins
Table 1:
Bin Code
Minimum
Radiant Flux (Φ)
@ IF = 700mA [1]
(mW)
Maximum
Radiant Flux (Φ)
@ IF = 700mA [1]
(mW)
M1
1100
1375
N1
1375
1760
Notes for Table 1:
1.
Radiant flux performance is measured at specified current, 10ms pulse width, Tc = 25oC. LED Engin maintains a tolerance of ± 10% on flux measurements.
Peak Wavelength Bins
Table 2:
Bin Code
Minimum
Peak Wavelength (λP)
@ IF = 700mA [1]
(nm)
Maximum
@ IF = 700mA [1]
(nm)
U4
385
390
U5
390
395
U6
395
400
U7
400
405
U8
405
410
Notes for Table 2:
1.
Peak wavelength is measured at specified current, 10ms pulse width, Tc=25oC. LED Engin maintains a tolerance of ± 2.0nm on peak wavelength
measurements.
Forward Voltage Bins
Table 3:
Bin Code
Minimum
Forward Voltage (VF)
@ IF = 700mA [1]
(V)
Maximum
@ IF = 700mA [1]
(V)
3.20
4.20
Notes for Table 3:
1.
Forward voltage is measured at specified current, 10ms pulse width, Tc=25oC. LED Engin maintains a tolerance of ± 0.04V for forward voltage measurements.
6
Absolute Maximum Ratings
Table 4:
Parameter
Symbol
DC Forward Current
[1]
Peak Pulsed Forward Current [2]
Value
Unit
I F
1000
mA
IFP
1000
mA
Reverse Voltage
VR
See Note 3
V
Storage Temperature
Tstg
‐40 ~ +150
°C
Junction Temperature
TJ
130
°C
Soldering Temperature
Tsol
260
°C
[4]
Notes for Table 4:
1.
Maximum DC forward current is determined by the overall thermal resistance and ambient temperature. Follow the curves in Figure 11 for current derating.
2:
Pulse forward current conditions: Pulse Width ≤ 10msec and Duty Cycle ≤ 10%.
2.
LEDs are not designed to be reverse biased.
3.
Tj‐max 130C was tested while Tc‐max 70C
Solder conditions per JEDEC 020D. See Reflow Soldering Profile Figure 3
LED Engin recommends taking reasonable precautions towards possible ESD damages and handling the LZ1‐00UB0R in an electrostatic protected area (EPA).
An EPA may be adequately protected by ESD controls as outlined in ANSI/ESD S6.1.
4.
5.
Optical Characteristics @ TC = 25°C
Table 5:
Parameter
Symbol
Typical
Unit
385‐390nm 390‐400nm 400‐410nm 410‐420nm
Radiant Flux (@ IF = 700mA)
Φ
1350
1350
1230
1230
mW
Radiant Flux (@ IF = 1000mA)
Φ
1822
1822
1660
mW
Peak Wavelength
λP
385
395
405
1660
415
nm
Viewing Angle [2]
Degrees
Total Included Angle [3]
Degrees
[1]
2Θ1/2
68
Θ0.9V
100
Notes for Table 5:
1.
When operating the VIOLET LED, observe IEC 60825‐1 class 3B rating. Avoid exposure to the beam.
2.
Viewing Angle is the off axis angle from emitter centerline where the radiometric power is ½ of the peak value.
3.
Total Included Angle is the total angle that includes 90% of the total radiant flux.
Electrical Characteristics @ TC = 25°C
Table 6:
Parameter
Symbol
Typical
Unit
Forward Voltage (@ IF = 700mA)
VF
3.7
V
Forward Voltage (@ IF = 1000mA)
VF
3.9
V
Temperature Coefficient
of Forward Voltage
ΔVF/ΔTJ
‐2.2
mV/°C
Thermal Resistance
(Junction to Case)
RΘJ‐C
4.2
°C/W
7
IPC/JEDEC Moisture Sensitivity Level
Table 7 ‐ IPC/JEDEC J‐STD‐20D.1 MSL Classification:
Floor Life
Soak Requirements
Standard
Accelerated
Level
Time
Conditions
Time (hrs)
Conditions
Time (hrs)
Conditions
1
Unlimited
≤ 30°C/
85% RH
168
+5/‐0
85°C/
85% RH
n/a
n/a
Notes for Table 7:
1.
The standard soak time includes a default value of 24 hours for semiconductor manufacturer’s exposure time (MET) between bake and bag and the
floor life of maximum time allowed out of the bag at the end user of distributor’s facility.
8
Mechanical Dimensions (mm)
Pin Out
Pad
Function
1
Anode
2
Cathode
3
Cathode
4
Anode
5 [2]
Thermal
Figure 1: Package outline drawing.
Notes for Figure 1:
1.
Unless otherwise noted, the tolerance = ± 0.20 mm.
2.
Thermal contact, Pad 5, is electrically neutral.
3.
Tc point = index mark
Recommended Solder Pad Layout (mm)
Non‐pedestal MCPCB Design
Pedestal MCPCB Design
Figure
2a:
Recommended solder pad layout for anode, cathode, and thermal pad for non‐pedestal and pedestal design
Note for Figure 2a:
1. Unless otherwise noted, the tolerance = ± 0.20 mm.
2. Pedestal MCPCB allows the emitter thermal slug to be soldered directly to the metal core of the MCPCB. Such MCPCB eliminate the high thermal resistance
dielectric layer that standard MCPCB technologies use in between the emitter thermal slug and the metal core of the MCPCB, thus lowering the overall system
thermal resistance.
3. LED Engin recommends x‐ray sample monitoring for solder voids underneath the emitter thermal slug. The total area covered by solder voids should be less
than 20% of the total emitter thermal slug area. Excessive solder voids will increase the emitter to MCPCB thermal resistance and may lead to higher failure
rates due to thermal over stress.
4. This emitter is compatible with all LZ1 MCPCBs provided that the MCPCB design follows the recommended solder mask layout (Figure 2b).
9
Recommended Solder Mask Layout (mm)
Figure 2b: Recommended solder mask opening for anode, cathode, and thermal pad for non‐pedestal and pedestal design
Note for Figure 2b:
1.
Recommended 8mil Stencil Apertures Layout (mm)
Figure 2c: Recommended solder mask opening for anode, cathode, and thermal pad for non‐pedestal and pedestal design
Note for Figure 2c:
1.
10
Figure 3: Reflow soldering profile for lead free soldering.
Typical Radiation Pattern
100%
90%
80%
Relatiive Intensity
70%
60%
50%
40%
30%
20%
10%
0%
‐90 ‐80 ‐70 ‐60 ‐50 ‐40 ‐30 ‐20 ‐10
40
50
60
70
80
90
Angular Displacement (Degrees)
Figure 4: Typical representative spatial radiation pattern
11
Typical Relative Spectral Power Distribution
1.0
0.9
0.8
0.7
0.6
0.5
0.4
385nm
0.3
395nm
0.2
405nm
0.1
0.0
340
360
380
400
420
440
460
Wavelength (nm)
Figure 5: Typical relative spectral power vs. wavelength @ TC = 25°C.
Typical Forward Current Characteristics
1200
IF ‐ Forward Current (mA)
1000
800
600
400
200
3.00
3.20
3.40
3.60
3.80
4.00
4.20
VF ‐ Forward Voltage (V)
Figure 6: Typical forward current vs. forward voltage @ TC = 25°C.
12
Typical Normalized Radiant Flux over Current
160%
Relative Radiant Flux
140%
120%
100%
80%
60%
40%
20%
0%
400
600
800
1000
1200
Figure 7: Typical normalized radiant flux vs. forward current @ TC = 25°C.
Typical Normalized Radiant Flux over Temperature
120%
100%
80%
60%
385nm
40%
395nm
405nm
20%
0%
60
80
100
120
TC ‐ Case Temperature (°C)
Figure 8: Typical normalized radiant flux vs. case temperature @700mA
13
Typical Peak Wavelength Shift over Current
3.0
Peak Wavelength Shift (nm)
2.0
1.0
0.0
‐1.0
‐2.0
‐3.0
400
600
800
1000
1200
Figure 9: Typical peak wavelength shift vs. forward current @ Tc = 25°C
Typical Peak Wavelength Shift over Temperature
5.0
4.0
3.0
2.0
1.0
0.0
‐1.0
‐2.0
50
75
100
Figure 10: Typical peak wavelength shift vs. case temperature @700mA
14
Current De‐rating
1200
1000
800
700
600
RΘJA = 9°C/W
400
RΘJA = 11°C/W
RΘJA = 13°C/W
200
50
75
100
TA ‐ Ambient Temperature (°C)
125
(TJ(MAX) =
130)
150
Figure 11: Maximum forward current vs. ambient temperature based on TJ(MAX) = 130°C.
Notes for Figure 11:
1.
RΘJ‐C [Junction to Case Thermal Resistance] for the LZ1‐00UB0R is typically 4.2°C/W.
2. RΘJ‐A [Junction to Ambient Thermal Resistance] = RΘJ‐C + RΘC‐A [Case to Ambient Thermal Resistance].
15
Emitter Tape and Reel Specifications (mm)
Figure 12: Emitter carrier tape specifications (mm).
Ø 178mm (SMALL REEL)
Ø 330mm (LARGE REEL)
Figure 13: Emitter reel specifications (mm).
Notes:
1.
Small reel quantity: up to 500 emitters
2.
Large reel quantity: 501‐2500 emitters.
3.
Single flux bin and single wavelength bin per reel.
16
LZ1 MCPCB Family
Part number
Type of MCPCB
Diameter
(mm)
LZ1‐1xxxxx
1‐channel Star
19.9
Emitter + MCPCB
Typical VF
Thermal Resistance
(V)
(°C /W)
4.2 + 1.5 = 5.7
3.7
Typical IF
(mA)
700
Mechanical Mounting of MCPCB
MCPCB bending should be avoided as it will cause mechanical stress on the emitter, which could lead to
substrate cracking and subsequently LED dies cracking.
To avoid MCPCB bending:
o Special attention needs to be paid to the flatness of the heat sink surface and the torque on the screws.
o Care must be taken when securing the board to the heat sink. This can be done by tightening three M3
screws (or #4‐40) in steps and not all the way through at once. Using fewer than three screws will
increase the likelihood of board bending.
o It is recommended to always use plastics washers in combinations with the three screws.
o If non‐taped holes are used with self‐tapping screws, it is advised to back out the screws slightly after
tightening (with controlled torque) and then re‐tighten the screws again.
Thermal interface material
To properly transfer heat from LED emitter to heat sink, a thermally conductive material is required when
mounting the MCPCB on to the heat sink.
There are several varieties of such material: thermal paste, thermal pads, phase change materials and thermal
epoxies. An example of such material is Electrolube EHTC.
It is critical to verify the material’s thermal resistance to be sufficient for the selected emitter and its operating
conditions.
Wire soldering
To ease soldering wire to MCPCB process, it is advised to preheat the MCPCB on a hot plate of 125‐150oC.
Subsequently, apply the solder and additional heat from the solder iron will initiate a good solder reflow. It is
recommended to use a solder iron of more than 60W.
It is advised to use lead‐free, no‐clean solder. For example: SN‐96.5 AG‐3.0 CU 0.5 #58/275 from Kester (pn:
24‐7068‐7601)
17
LZ1‐1xxxxx
1 channel, Standard Star MCPCB (1x1) Dimensions (mm)
Notes:
Unless otherwise noted, the tolerance = ± 0.2 mm.
Slots in MCPCB are for M3 or #4‐40 mounting screws.
LED Engin recommends plastic washers to electrically insulate screws from solder pads and electrical traces.
LED Engin recommends using thermal interface material when attaching the MCPCB to a heat sink.
The thermal resistance of the MCPCB is: RΘC‐B 1.5°C/W
Components used
MCPCB:
HT04503
(Bergquist)
ESD/TVS Diode: BZT52C5V1LP‐7
(Diodes, Inc., for 1 LED die)
VBUS05L1‐DD1
(Vishay Semiconductors, for 1 LED die)
Pad layout
MCPCB
Ch.
String/die Function
Pad
1,2,3
Cathode ‐
1
1/A
4,5,6
Anode +
18
About LED Engin
LED Engin, an OSRAM business based in California’s Silicon Valley, develops, manufactures, and sells advanced LED
emitters, optics and light engines to create uncompromised lighting experiences for a wide range of
entertainment, architectural, general lighting and specialty applications. LuxiGenTM multi‐die emitter and
secondary lens combinations reliably deliver industry‐leading flux density, upwards of 5000 quality lumens to a
target, in a wide spectrum of colors including whites, tunable whites, multi‐color and UV LEDs in a unique patented
compact ceramic package. Our LuxiTuneTM series of tunable white lighting modules leverage our LuxiGen emitters
and lenses to deliver quality, control, freedom and high density tunable white light solutions for a broad range of
new recessed and downlighting applications. The small size, yet remarkably powerful beam output and superior in‐
source color mixing, allows for a previously unobtainable freedom of design wherever high‐flux density, directional
light is required. LED Engin is committed to providing products that conserve natural resources and reduce
greenhouse emissions; and reserves the right to make changes to improve performance without notice.
For more information, please contact LEDE‐Sales@osram.com or +1 408 922‐7200.
19
