www.osram-os.com
Produktdatenblatt | Version 1.1
SFH 3100 F
SFH 3100 F
Radial Mini Sidelooker
Silicon NPN Phototransistor with Daylight - Cutoff
Filter
Applications
——Industrial Automation (Machine Controls, Light
Barriers, Vision Controls)
Features:
——Package: black epoxy
——ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2)
——Spectral range of sensitivity: (typ) 850 ... 1100 nm
——Narrow half angle
——Small outline dimensions
——Same package as IRED SFH 4141
——High coupling factor in light barriers with SFH 4141
——Easy identification of SFH 3100 F (black package) and SFH 4141 (clear package)
Ordering Information
Type
Photocurrent
VCE = 5 V; λ = 950 nm; Ee = 0.5 mW/cm²
IPCE
Ordering Code
SFH 3100 F
400 ... 5000 µA
Q62702P5073
SFH 3100 F-2/3/4
630 ... 3200 µA
Q62702P5475
Discontinued
Only one bin within one packing unit (variation less than 2:1)
1 Version 1.6 | 2019-07-16
SFH 3100 F
Maximum Ratings
TA = 25 °C
Parameter
Symbol
Operating temperature
Top
min.
max.
-40 °C
85 °C
Storage temperature
Tstg
min.
max.
-40 °C
85 °C
Collector-emitter voltage
VCE
max.
35 V
Collector current
IC
max.
50 mA
Collector surge current
τ ≤ 10 µs
ICS
max.
100 mA
Emitter-collector voltage
VEC
max.
7V
Total power dissipation
Ptot
max.
150 mW
ESD withstand voltage
VESD
max.
2 kV
Discontinued
2 Version 1.6 | 2019-07-16
Values
SFH 3100 F
Characteristics
TA = 25 °C
Parameter
Symbol
Wavelength of max sensitivity
λS max
typ.
920 nm
λ10%
typ.
850 ... 1100
nm
Dimensions of chip area
LxW
typ.
0.55 x 0.55
mm x mm
Radiant sensitive area
A
typ.
0.11 mm²
Half angle
φ
typ.
14 °
Dark current
VCE = 20 V; E = 0
ICE0
typ.
max.
Rise time
IC = 1 mA; VCC = 5 V; RL = 1 kΩ
tr
typ.
7 µs
Fall time
tf
typ.
9 µs
Collector-emitter saturation voltage 1)
Threefold saturated
VCEsat
typ.
max.
Capacitance
VCE = 5 V; f = 1 MHz; E = 0
CCE
typ.
4 pF
Capacitance
VCE = 0 V; f = 1 MHz; E = 0
CCE
typ.
7.5 pF
Thermal resistance junction ambient real
RthJA
max.
Discontinued
3 Version 1.6 | 2019-07-16
Values
1 nA
50 nA
140 mV
400 mV
280 K / W
SFH 3100 F
Photocurrent Groups
TA = 25 °C
Group
Photocurrent
min.
IPCE
Photocurrent
max.
IPCE
1
400 µA
800 µA
2
630 µA
1250 µA
3
1000 µA
2000 µA
4
1600 µA
3200 µA
5
2500 µA
5000 µA
Relative Spectral Sensitivity
2), 3)
Srel = f (λ)
OHF04046
100
Srel %
80
70
60
50
40
30
Discontinued
800
900
1000 nm 1100
λ
4 Version 1.6 | 2019-07-16
SFH 3100 F
Photocurrent
Photocurrent
2), 3)
IPCE = f (Ee) ; VCE = 5 V
2), 3)
IPCE = f (VCE); Ee = Parameter
OHF00378
10 1
mA
Ι PCE
OHF00386
2.0
mA
Ι PCE 1.8
1.0 mW/cm 2
0.5 mW/cm 2
0.25 mW/cm 2
0.1 mW/cm 2
1.6
10 0
1.4
1.2
10 -1
1.0
0.8
0.6
10 -2
0.4
0.2
10 -3 -3
10
2
10 -2
Dark Current
10 -1 mW/cm 10 0
Ee
2), 3)
ICE0 = f (VCE) ; E = 0 ;
OHF04049
10 1
nA
I CEO
10 0
10 -1
Discontinued
10 -2
10
15
30 V 35
VCE
5 Version 1.6 | 2019-07-16
V 40
V CE
SFH 3100 F
Collector-Emitter Capacitance
2), 3)
CCE = f (VCE); f = 1 MHz; E = 0
OHF04051
8
pF
C CE
7
6
5
4
3
2
1
0 -3
10
10 -2
10 -1
10 0
10 1 V 10 2
VCE
Dark Current
Photocurrent
2)
ICE0 = f (TA); E = 0
IPCE,rel = f (TA); VCE = 5 V
OHF04050
10 4
nA
Ι PCE
I CEO
Ι PCE 25
10 3
10
2)
2
OHF01524
1.6
1.4
1.2
1.0
10 1
0.8
0.6
10 0
0.4
Discontinued
10 -1
10 -2
-25
0.2
50
75 ˚C 100
TA
6 Version 1.6 | 2019-07-16
50
75 C 100
TA
SFH 3100 F
Power Consumption
Ptot = f (TA)
OHF00381
160
mW
Ptot
140
120
100
80
60
40
80 ˚C 100
TA
60
Discontinued
7 Version 1.6 | 2019-07-16
SFH 3100 F
Approximate Weight:
156.0 mg
Package marking:
Collector
Discontinued
8 Version 1.6 | 2019-07-16
0.5 (0.020) x 45˚
4.1 (0.161)
3.9 (0.154)
0.84 (0.033)
3.0 (0.118)
2.8 (0.110)
1.04 (0.041)
0.84 (0.033)
17.77 (0.700)
17.27 (0.680)
Further Information
R 0.9 (0.035)
R 0.7 (0.028)
1.04 (0.041)
2.2 (0.087)
2.0 (0.079)
0.84 (0.033)
0.64 (0.025)
0.3 (0.012)
16.5 (0.650)
16.0 (0.630)
60˚
0.5 (0.020)
1.42 (0.056)
1.22 (0.048)
0.6 (0.024)
0.4 (0.016)
2.54 (0.100)
Emitter/
Cathode
3.1 (0.122)
2.9 (0.114)
4)
0.9 (0.035)
0.7 (0.028)
Dimensional Drawing
1.6 (0.063)
1.4 (0.055)
1.3 (0.051)
1.1 (0.043)
GEOY6976
SFH 3100 F
Recommended Solder Pad
4)
Pad 1: emitter
TTW Soldering
IEC-61760-1 TTW
OHA04645
300
10 s max., max. contact time 5 s per wave
˚C
T 250
235 ˚C - 260 ˚C
First wave
Second wave
Continuous line: typical process
Dotted line: process limits
∆T < 150 K
200
Cooling
Preheating
ca. 3.5 K/s typical
150
ca. 2 K/s
130 ˚C
120 ˚C
100 ˚C
100
ca. 5 K/s
Typical
50
Discontinued
60
80
100
120
140
160
180
200
220 s 240
t
9 Version 1.6 | 2019-07-16
SFH 3100 F
Notes
The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of
lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this
data sheet falls into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the
eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light
sources have a high secondary exposure potential due to their blinding effect. When looking at bright light
sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation.
Subcomponents of this device contain, in addition to other substances, metal filled materials including silver.
Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage,
production, and use. Devices that showed visible discoloration when tested using the described tests above
did show no performance deviations within failure limits during the stated test duration. Respective failure
limits are described in the IEC60810.
For further application related information please visit www.osram-os.com/appnotes
Discontinued
10 Version 1.6 | 2019-07-16
SFH 3100 F
Disclaimer
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may
contain dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version on the OSRAM OS website.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest
sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of
transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we
shall have to invoice you for any costs incurred.
Product and functional safety devices/applications or medical devices/applications
OSRAM OS components are not developed, constructed or tested for the application as safety relevant
component or for the application in medical devices.
OSRAM OS products are not qualified at module and system level for such application.
In case buyer – or customer supplied by buyer – considers using OSRAM OS components in product safety
devices/applications or medical devices/applications, buyer and/or customer has to inform the local sales
partner of OSRAM OS immediately and OSRAM OS and buyer and /or customer will analyze and coordinate the customer-specific request between OSRAM OS and buyer and/or customer.
Discontinued
11 Version 1.6 | 2019-07-16
SFH 3100 F
Glossary
1)
IPCEmin: IPCEmin is the min. photocurrent of the specified group.
2)
Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures.
These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g.
because of technical improvements, these typ. data will be changed without any further notice.
3)
Testing temperature: TA = 25°C (unless otherwise specified)
4)
Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
Discontinued
12 Version 1.6 | 2019-07-16
SFH 3100 F
Revision History
Version
Date
Change
1.6
2019-07-15
Discontinued
Discontinued
13 Version 1.6 | 2019-07-16
SFH 3100 F
Discontinued
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
14 Version 1.6 | 2019-07-16
很抱歉,暂时无法提供与“SFH 3100 F-2/3/4”相匹配的价格&库存,您可以联系我们找货
