TMS1104NL
TMS1104NL
    TAIMAO(台茂)
    X-FMR_12.8X6.8MM_SM
    网口/脉冲变压器 10/100 BASE-T 1CT:1CT 1.5KVrms
TMS1104NL 数据手册
ShenzhenTaimaoTechnology Co.,Ltd. 10/100 BASE-T SINGLE PORT SMD TRANSFORMER MODULE Designed To Meet IEEE 802.3 & ANSI X 3.263 Standards. Lead-Free&Designed To Meet RoHS Requirement. 10/100 Base-T,Surface Mount Type,Open Header . Operating temperature range: 0 ℃ to +70 ℃ . Electrical Specifications @25°C Part Number TMS1104NL Return Loss CMRR Insertion Loss Cross talk OCL(uH Min) Turns Ratio (dB Max) (dB Min) (dB Min) (dB Min) @100KHz,0.1V (±5%) 60.1-80MHz 0.5-40MHz 40.1-100MHz 0.5-100MHz 0.5-100MHz 0.5-30MHz 30.1-60MHz -18+20*log(f/30) 1CT:1CT -12 350 -1.1 -18 -35 -33+20*log(f/50) -30 HI-POT (Vrms) 1500 MECHANICAL 12.8±0.3 0.76 TMSEMI 6.80±0.3 TMS1104NL 9.45±0.3 2.03 10.65 DATE COED 1.27 0.46 1.27 8.89 SUGGESTED PAD LAYOUT 6.5±0.2 0.3±0.15 0.10 16 SURFACES 0°-8° Unless otherwise specified all tolerances are:±0.25 in mm SCHEMATICS TX RX
TMS1104NL 价格&库存
很抱歉,暂时无法提供与“TMS1104NL”相匹配的价格&库存,您可以联系我们找货
