SFH 203 FA RN18A
SFH 203 FA RN18A
    AMSOSRAM(艾迈斯半导体)
    径向
    SENSOR PHOTODIODE 900NM RADIAL
SFH 203 FA RN18A 数据手册
2015-12-23 Silicon PIN Photodiode Version 1.3 SFH 203 FA Features: • Wavelength range (S10%) 750 nm to 1100 nm • Short switching time (typ. 5 ns) • 5 mm LED plastic package Applications Photointerrupters • • Industrial electronics • For control and drive circuits Ordering Information Type: Photocurrent Ordering Code IP [µA] VR = 5 V, λ = 870 nm, Ee = 1 mW/cm2 SFH 203 FA 2015-12-23 50 (≥ 30) Q62702P0956 1 Version 1.3 SFH 203 FA Maximum Ratings (TA = 25 °C) Parameter Symbol Values Unit Operating and storage temperature range Top; Tstg -40 ... 100 °C Reverse voltage VR 20 V Reverse voltage (t < 2 min) VR 50 V Total Power dissipation Ptot 150 mW ESD withstand voltage (acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM) VESD 2000 V Characteristics (TA = 25 °C) Parameter Symbol Values Unit Photocurrent (VR = 5 V, λ = 870 nm, Ee = 1 mW/cm2) (typ (min)) IP Wavelength of max. sensitivity (typ) λS max Spectral range of sensitivity (typ) λ10% Radiant sensitive area (typ) A 1.00 mm2 Dimensions of radiant sensitive area (typ) LxW 1x1 mm x mm Half angle (typ) ϕ ± 20 ° Dark current (VR = 20 V) (typ (max)) IR Spectral sensitivity of the chip (typ) Sλ typ 0.62 A/W Quantum yield of the chip (λ = 850 nm) (typ) η 0.90 Electro ns /Photon Open-circuit voltage (Ee = 0.5 mW/cm2, λ = 870 nm) (typ (min)) VO 370 (≥ 300) mV Short-circuit current (Ee = 0.5 mW/cm2, λ = 870 nm) (typ) ISC 25 µA Rise and fall time (VR = 20 V, RL = 50 Ω, λ = 850 nm) (typ) tr, tf 0.005 µs Forward voltage (IF = 100 mA, E = 0) (typ) VF 1.3 V Capacitance (VR = 0 V, f = 1 MHz, E = 0) (typ) C0 11 pF Temperature coefficient of VO (typ) TCV 2015-12-23 2 50 (≥ 30) µA 900 nm (typ) 750 ... 1100 1 (≤ 5) -2.6 nm nA mV / K Version 1.3 SFH 203 FA Parameter Symbol Values Unit Temperature coefficient of ISC (λ = 870 nm) (typ) TCI 0.1 %/K Noise equivalent power (VR = 20 V, ) (typ) NEP 0.029 pW / Hz½ Detection limit (typ) D* 3.5e12 cm x Hz½ / W Relative Spectral Sensitivity 1) page 8 Srel = f(λ) Photocurrent / Open-Circuit Voltage 1) page 8 IP (VR = 5 V) / VO = f(Ee) OHF01773 100 ΙP S rel % 80 OHF01128 10 3 µA 10 2 10 4 mV 10 3 VO 60 10 1 10 2 ΙP 40 10 0 10 1 20 0 400 2015-12-23 600 800 10 -1 10 -3 1000 nm 1200 λ 3 10 -2 10 -1 2 mW/cm Ee 10 0 10 1 VO Version 1.3 SFH 203 FA Dark Current 1) page 8 IR = f(VR), E = 0 Capacitance 1) page 8 C = f(VR), f = 1 MHz, E = 0 Dark Current 1) page 8 IR = f(TA), VR = 20 V, E = 0 2015-12-23 4 Version 1.3 SFH 203 FA Package Outline Dimensions in mm. Package 5mm Radial (T 1 ¾), Epoxy Approximate Weight: 0.3 g Note Packing information is available on the internet (online product catalog). 2015-12-23 5 Version 1.3 SFH 203 FA Recommended Solder Pad Dimensions in mm. Note: pad 1: anode TTW Soldering IEC-61760-1 TTW OHA04645 300 10 s max., max. contact time 5 s per wave ˚C T 250 235 ˚C - 260 ˚C First wave Second wave Continuous line: typical process Dotted line: process limits ∆T < 150 K 200 Cooling Preheating ca. 3.5 K/s typical 150 ca. 2 K/s 130 ˚C 120 ˚C 100 ˚C 100 ca. 5 K/s Typical 50 0 0 20 40 60 80 100 120 140 160 180 200 220 s 240 t 2015-12-23 6 Version 1.3 SFH 203 FA Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2015-12-23 7 Version 1.3 SFH 203 FA Glossary 1) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 2015-12-23 8 Version 1.3 SFH 203 FA Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2015-12-23 9
SFH 203 FA RN18A 价格&库存
很抱歉,暂时无法提供与“SFH 203 FA RN18A”相匹配的价格&库存,您可以联系我们找货
