KW3 CGLNM1.TG-Z6QF6-EBVFFCBB46-DFGA 数据手册
www.osram-os.com
Produktdatenblatt | Version 1.1
KW3 CGLNM1.TG
KW3 CGLNM1.TG
OSLON ® Compact PL
Compact light source with isolated thermal pad for
improved heat dissipation and small z-tolerance (+/35 µm).
Applications
——Headlamps, LED & Laser & Night Vision
Features:
——Package: Ceramic package
——Chip technology: UX:3
——Typ. Radiation: 120° (Lambertian emitter)
——Color: Cx = 0.32, Cy = 0.33 acc. to CIE 1931 (● white)
——Corrosion Robustness Class: 3B
——Qualifications: The product qualification test plan is based on the guidelines of IEC60810, Lamps for
road vehicles – Performance requirements – Requirements and test conditions for LED packages.
——ESD: 8 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 3B)
1 Version 1.3 | 2018-07-26
KW3 CGLNM1.TG
Ordering Information
Type
Luminous Flux 1)
IF = 1000 mA
ΦV
KW3 CGLNM1.TG-Z6QF6-ebvFfcbB46-DFGA
2 Version 1.3 | 2018-07-26
849 ... 1250 lm
Ordering Code
Q65112A1567
KW3 CGLNM1.TG
Maximum Ratings
Parameter
Symbol
Operating Temperature
Top
min.
max.
-40 °C
125 °C
Storage Temperature
Tstg
min.
max.
-40 °C
125 °C
Junction Temperature
Tj
max.
150 °C
Junction Temperature for short time applications*
Tj
max.
175 °C
Forward Current
TS = 25 °C
IF
min.
max.
50 mA
1500 mA
Surge Current
t ≤ 10 µs; D = 0.005 ; TS = 25 °C
IFS
max.
4000 mA
ESD withstand voltage
VESD
Reverse current 2)
IR
*The median lifetime (L70/B50) for Tj =175°C is 100h.
3 Version 1.3 | 2018-07-26
Values
8 kV
max.
200 mA
KW3 CGLNM1.TG
Characteristics
IF = 1000 mA; TS = 25 °C
Parameter
Symbol
Chromaticity Coordinate 3)
Cx
Cy
typ.
typ.
0.32
0.33
Viewing angle at 50 % IV
2φ
typ.
120 °
Forward Voltage 4)
IF = 1000 mA
VF
min.
typ.
max.
8.15 V
9.05 V
10.15 V
Reverse voltage (ESD device)
VR ESD
min.
45 V
Reverse voltage
IR = 20 mA
VR
max.
1.2 V
Real thermal resistance junction/solderpoint 5)
RthJS real
typ.
max.
2.6 K / W
3.3 K / W
Electrical thermal resistance junction/solderpoint 5)
with efficiency ηe = 26 %
RthJS elec.
typ.
max.
1.9 K / W
2.4 K / W
2)
4 Version 1.3 | 2018-07-26
Values
KW3 CGLNM1.TG
Brightness Groups
Group
Luminous Flux 1)
IF = 1000 mA
min.
ΦV
Luminous Flux 1)
IF = 1000 mA
max.
ΦV
6QF
849 lm
949 lm
7Q
900 lm
1000 lm
7QF
949 lm
1060 lm
8Q
1000 lm
1120 lm
8QF
1060 lm
1180 lm
5R
1120 lm
1250 lm
Forward Voltage Groups
Group
Forward Voltage 4)
IF = 1000 mA
min.
VF
Forward Voltage 4)
IF = 1000 mA
max.
VF
DF
8.15 V
8.90 V
UF
8.90 V
9.65 V
GA
9.65 V
10.15 V
5 Version 1.3 | 2018-07-26
KW3 CGLNM1.TG
Chromaticity Coordinate Groups
3)
0,90
0,37
520
0,80
Cy
525
515
530
Cy
540
510
0,70
0,36
550
505
0,35
560
fcbB46
0,60
570
500
0,34
0,50
580
ebzB46
590
495
0,40
0,33
600
ebxD46
610
0,30
620
630
650
700
490
0,20
0,32
ebvF46
485
480
0,10
0,00
0,00
0,31
475
470
465
460
455
450
400
0,10
0,20
0,30
0,40
0,50
0,60
0,30
0,29
0,70
0,30
Cx
Group
Cx
Cy
Group
Cx
Cy
ebvF46
0.3127
0.3093
ebzB46
0.3203
0.3274
0.3212
0.3175
0.3299
0.3361
0.3199
0.3325
0.3298
0.3526
0.3104
0.3234
0.3190
0.3430
0.3163
0.3181
0.3248
0.3370
0.3253
0.3266
0.3350
0.3460
0.3246
0.3424
0.3355
0.3633
0.3145
0.3330
0.3241
0.3534
6 Version 1.3 | 2018-07-26
fcbB46
0,32
0,33
0,34
Cx
Color Chromaticity Groups 3)
ebxD46
0,31
KW3 CGLNM1.TG
Group Name on Label
Example: 5R-ebvF46-DF
Brightness
Color Chromaticity
Forward Voltage
5R
ebvF46
DF
7 Version 1.3 | 2018-07-26
KW3 CGLNM1.TG
Relative Spectral Emission
6)
Φrel = f (λ); IF = 1000 mA; TS = 25 °C
Φrel
KW3 CGLNM1.TG
1,0
: Vλ
0,8
0,6
0,4
0,2
0,0
350
400
450
500
550
600
650
700
750
Note: Percentage of red: >5% acc. to ECE regulation
Percentage of UV:
KW3 CGLNM1.TG-Z6QF6-EBVFFCBB46-DFGA 价格&库存
很抱歉,暂时无法提供与“KW3 CGLNM1.TG-Z6QF6-EBVFFCBB46-DFGA”相匹配的价格&库存,您可以联系我们找货
