GW CSSRM1.PC-MSMU-5R8T-1-700-R18 数据手册
2014-02-15
OSLON Square®
Datasheet
Draft Version 0.0
GW CSSRM1.PC
Higher performance. Lower thermal resistance.
Extended range of driving conditions. This is the
second generation OSLON Square.
Features:
Besondere Merkmale:
• Package: SMT ceramic package with silicone
resin and silicone lens
• Viewing angle at 50 % IV: 120°
• Color: 3000 K - 6500 K ( white )
• CRI: min. 70 ( typ. 72 )
• Luminous Flux: typ. 272 lm @ 5000 K, 85 °C
• Luminous efficacy: typ. 134 lm/W @ 5000 K,
85 °C
• Corrosion Robustness: Superior Corrosion
Robustness
• Lumen Maintenance: Testing according to
IESNA LM-80 in progress
• Gehäusetyp: SMT-Keramikgehäuse mit
Silikonverguss und -linse
• Abstrahlwinkel bei 50 % IV: 120°
• Farbe: 3000 K - 6500 K ( weiß )
• Lichtstrom: typ. 272 lm @ 5000 K, 85 °C
• Lichtausbeute: typ. 134 lm/W @ 5000 K, 85 °C
• Korrosionsstabilität: Höchste
Korrosionsbeständigkeit
• Lichtstromerhaltung: Tests nach IESNA LM-80
im Gange
Applications
Anwendungen
• Industrial lighting
• Outdoor lighting
• Street and tunnel lighting
2014-02-15
DRAFT – For Reference only.
Subject to change.
• Industriebeleuchtung
• Außenbeleuchtung
• Straßen und Tunnel
1
Draft Version 0.0
GW CSSRM1.PC
Ordering Information
Bestellinformation
Type:
Color
Temperature
Luminous Flux
Ordering Code
Typ:
Farbtemperatur
Lichtstrom
Bestellnummer
1) page 26
1) Seite 26
IF = 700 mA,
TS = 85 °C
[K]
ΦV [lm]
GW CSSRM1.PC-MUNQ-5C7E-1
6500
259 ... 330
Q65111A5842
GW CSSRM1.PC-MUNQ-5F7G-1
5700
259 ... 330
Q65111A5841
GW CSSRM1.PC-MTNP-5H7I-1
5000
240 ... 304
Q65111A5845
GW CSSRM1.PC-MTNP-5J7K-1
4500
240 ... 304
Q65111A5844
GW CSSRM1.PC-MTNP-5L7N-1
4000
240 ... 304
Q65111A5843
GW CSSRM1.PC-MSMU-5O8Q-1
3500
224 ... 280
Q65111A5847
3000
224 ... 280
Q65111A5846
Note:
The above Type Numbers represent the order groups which include only a few brightness groups (see page 5). Only one group will be shipped on each
packing unit (there will be no mixing of two groups on each packing unit). E. g. GW CSSRM1.PC-MTNP-5H7I-1 means that only one group MT, MU,
NP will be shippable for any packing unit. In order to ensure availability, single brightness groups will not be orderable.
In a similar manner for colors where color chromaticity coordinate groups are measured and binned, single groups will be shipped on any one packing
unit. GW CSSRM1.PC-MTNP-5H7I-1 means that the device will be shipped within the specified limits. In order to ensure availability, single color
chromaticity groups groups will not be orderable (see page 7).
In a similar manner for colors where forward voltage groups are measured and binned, single forward voltage groups will be shipped on any packing
unit. E. g. GW CSSRM1.PC-MTNP-5H7I-1 means that only one forward voltage group K2,L1,L2,M1,M2 will be shippable. In order to ensure availability,
single forward voltage groups will not be orderable (see page 5).
Anm.:
Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen (siehe Seite 5). Es
wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. GW CSSRM1.PC-MTNP-5H7I-1 bedeutet, dass in einer
Verpackungseinheit nur eine der Helligkeitsgruppen MT, MU, NP enhalten ist. Um die Liefersicherheit zu gewährleisten, können einzelne
Helligkeitsgruppen nicht bestellt werden.
Gleiches gilt für die Farben, bei denen Farbortgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine Farbortgruppe geliefert.
Z.B. GW CSSRM1.PC-MTNP-5H7I-1 bedeutet, dass in einer Verpackungseinheit nur eine der Farbortgruppen enthalten ist (siehe Seite 7). GW
CSSRM1.PC-MTNP-5H7I-1 bedeutet, dass das Bauteil innerhalb der spezifizierten Grenzen geliefert wird. Um die Liefersicherheit zu gewährleisten,
können einzelne Farbortgruppen nicht bestellt werden.
Gleiches gilt für die LEDs, bei denen die Durchlassspannungsgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine
Durchlassspannungsgruppe geliefert. Z. B. GW CSSRM1.PC-MTNP-5H7I-1 bedeutet, dass nach Durchlassspannungsgruppen gruppiert wird. In einer
Verpackungseinheit ist nur eine der Durchlassspannungsgruppen K2,L1,L2,M1,M2 enthalten (siehe Seite 5). Um die Liefersicherheit zu gewährleisten,
können einzelne Durchlassspannungsgruppen nicht direkt bestellt werden.
2014-02-15
Subject to change.
2
Draft Version 0.0
GW CSSRM1.PC
Maximum Ratings
Grenzwerte
Parameter
Symbol
Values
Unit
Bezeichnung
Symbol
Werte
Einheit
Operating temperature range
Betriebstemperatur
Top
-40 ... 125
°C
Storage temperature range
Lagertemperatur
Tstg
-40 ... 125
°C
Junction temperature absolute *
Sperrschichttemperatur absolut *
Tj, abs
150
°C
Tj
135
°C
Forward current
Durchlassstrom
(TS = 85 °C)
IF
200 ... 1800
mA
Surge current
Stoßstrom
IFM
2000
mA
Reverse current 2) page 26
Sperrstrom 2) Seite 26
IR
200
mA
8
kV
VESD
ESD withstand voltage
ESD Festigkeit
(acc. to ANSI/ESDA/JEDEC JS-001 - HBM, Class
3B)
Note: * This is verified by testing 30 pieces. Pass criteria: No catastrophic failures allowed, luminous flux
must be better than L70B50 after 1000 h.
Anm:
* Dieser Wert wird durch den Test von 30 Bauteilen abgesichert. Dabei dürfen keine Totalausfälle
auftreten und der Lichtstrom muß nach 1000 h über L70B50 liegen.
2014-02-15
Subject to change.
3
Draft Version 0.0
GW CSSRM1.PC
Characteristics (TS = 85 °C; IF = 700 mA)
Kennwerte
Parameter
Symbol
Values
Unit
Bezeichnung
Symbol
Werte
Einheit
(typ.)
2ϕ
120
Forward voltage 3) page 26
Durchlassspannung 3) Seite 26
(min.)
(typ.)
(max.)
VF
VF
VF
2.70
2.90
3.20
V
V
V
Reverse voltage
Sperrspannung
(IR = 20 mA)
(max.)
VR
1.2
V
Color reproduction index 4) page 26
Farbwiedergabe Index 4) Seite 26
(typ.)
(min.)
Ra
Ra
72
70
Real thermal resistance junction / solder point
(typ.)
(max.)
Rth JS real
Rth JS real
3
3.9
K/W
K/W
(typ.)
(max.)
Rth JS el
Rth JS el
1.7
2.3
K/W
K/W
5) page 26
Realer Wärmewiderstand Sperrschicht / Lötpad
5) Seite 26
"Electrical" thermal resistance junction / solder
point 5) page 26
"Elektrischer" Wärmewiderstand Sperrschicht /
Lötpad 5) Seite 26
(with efficiency η e = 42 %)
Note:
Individual forward voltage groups see next page
Anm.:
Durchlassspannungsgruppen siehe nächste Seite
2014-02-15
Subject to change.
4
Draft Version 0.0
GW CSSRM1.PC
Brightness Groups
Helligkeitsgruppen
Group
Luminous Flux
Luminous Flux
1) page 26
1) page 26
1) Seite 26
Lichtstrom
1) Seite 26
Luminous Intensity
6) page 26
Lichtstärke 6) Seite 26
Gruppe
Lichtstrom
(min.) ΦV [lm]
(max.) ΦV [lm]
(typ.) IV [cd]
MS
224
240
77
MT
240
259
82
MU
259
280
89
NP
280
304
96
NQ
304
330
105
Note:
The standard shipping format for serial types includes either a lower family group, an upper family group or
a grouping of all individual brightness groups of only a few brightness groups. Individual brightness groups
cannot be ordered.
Anm.:
Die Standardlieferform von Serientypen beinhaltet entweder eine untere Familiengruppe, eine obere
Familiengruppe oder eine Sammelgruppe, die aus nur wenigen Helligkeitsgruppen besteht. Einzelne
Helligkeitsgruppen sind nicht bestellbar.
Forward Voltage Groups 3) page 26
Durchlassspannungsgruppen 3) Seite 26
Group
Gruppe
(min.) VF [V]
(max.) VF [V]
K2
2.70
2.80
L1
2.80
2.90
L2
2.90
3.00
M1
3.00
3.10
M2
3.10
3.20
2014-02-15
Subject to change.
5
Draft Version 0.0
GW CSSRM1.PC
Chromaticity Coordinate Groups 7) page 26
Farbortgruppen 7) Seite 26
Cy 0.900
520
515
525
0.800
530
540
510
0.700
550
505
560
0.600
570
500
0.500
580
590
495
0.400
600
0.300
610
620
630
700
490
0.200
485
480
0.100
475
470
450
460
0.000
0.000
0.100
0.200
0.300
0.400
0.500
0.600
0.700
0.800
Cx
Coordinates in reference to CIE 1931 (cx cy)
Cy
0.440
4000 K
3000 K
3500 K
0.420
8T
8S
8R
8Q
0.400
7Q
8O
7P
7N
4500 K
0.380
7J
7I
5500 K
0.360
6000 K
0.340
6500 K 7E
7000 K 7D
7C
0.320
7G
7F
6G
6F
5G
6E
6H
5H
6L
5L
6J
5K
6I
5J
5I
5P
5N
5M
6K
5R
5Q
5S
5T
7W 7X
7U 7V
6W 6X
6U 6V
5W 5X
5U 5V
2700 K
0K
300
5O
0K
350
K
00
40
warm white
K
00
45
K
00
50
5F
6D
6C
7H
6P
6O
6M
7K
5000 K
6N
7L
6T
6S
6R
6Q
7O
7M
7T
7S
7R
8P
neutral white
8U
2400 K
8X
8V 8W
5E
5D
K
00
57
5C
K
00
65
cool white
0.300
0.300
0.320
0.340
0.360
0.380
0.400
0.420
2014-02-15
Subject to change.
0.440
0.460
0.480
0.500
Cx
6
Draft Version 0.0
GW CSSRM1.PC
Color Chromaticity Groups 7) page 26
Group
Gruppe
5C
6C
7C
5D
6D
7D
5E
Cx
Cy
Group
Gruppe
0.3055
0.3177
0.3456
0.3601
0.3068
0.3113
0.3464
0.3688
0.3108
0.3229
0.3539
0.3669
0.3551
0.3760
0.3512
0.3465
7I
Cx
Cy
0.3731
0.4006
0.3815
0.4061
0.3773
0.3858
0.3555
0.4036
0.3898
0.3522
0.4095
0.3858
0.3616
0.4130
0.3944
0.4036
0.3898
0.4067
0.3982
0.4130
0.3944
0.3177
0.3524
0.3098
0.3296
0.3591
0.3108
0.3229
0.3608
0.3028
0.3304
0.3524
0.3555
0.3041
0.3240
0.3536
0.3646
0.3087
0.3363
0.3608
0.3616
0.3625
0.3711
0.3536
0.3646
6P
7P
0.4164
0.4029
0.4067
0.3982
0.3736
0.4097
0.4065
0.3711
0.4164
0.4029
0.3642
0.3805
0.4198
0.4115
0.3591
0.3522
0.4061
0.3773
0.3608
0.3616
0.4095
0.3858
0.3670
0.3578
0.4147
0.3814
0.3098
0.3296
0.3108
0.3229
0.3119
0.3162
0.3548
0.3162
0.3282
0.3625
0.3170
0.3212
0.3098
0.3296
0.3108
0.3229
0.3154
0.3352
5K
0.3975
0.3815
0.3055
7J
Cy
0.4095
0.3162
0.3240
6J
5P
Cx
0.4006
0.3119
0.3041
5J
Group
Gruppe
0.3692
0.3677
0.3608
0.3616
0.3296
0.3625
0.3422
0.3692
0.3154
0.3352
0.3162
0.3282
0.3170
0.3212
0.3216
0.3221
8P
5Q
0.4185
0.3902
0.4095
0.3858
0.3711
0.4130
0.3944
0.3677
0.4185
0.3902
0.3714
0.3775
0.4223
0.3990
0.3625
0.3711
0.4130
0.3944
0.3642
0.3805
0.4164
0.4029
0.3334
0.3714
0.3775
0.4223
0.3990
0.3262
0.3736
0.3874
0.4261
0.4077
0.3162
0.3282
0.3087
0.3363
0.3098
0.3146
6K
7K
2014-02-15
Subject to change.
7
6Q
7Q
Draft Version 0.0
Group
Gruppe
6E
7E
5F
6F
7F
5G
6G
7G
GW CSSRM1.PC
Cx
Cy
0.3154
0.3352
0.3162
0.3282
0.3210
0.3408
Group
Gruppe
5L
Cx
Cy
0.3670
0.3578
0.3692
0.3677
0.3746
0.3624
0.3773
0.3726
0.3692
0.3677
0.3352
0.3714
0.3481
0.3773
0.3408
0.3216
0.3334
0.3146
0.3422
0.3154
0.3205
0.3210
6L
7L
Group
Gruppe
8Q
Cx
Cy
0.4164
0.4029
0.4198
0.4115
0.4261
0.4077
0.4299
0.4165
0.4147
0.3814
0.3775
0.4185
0.3902
0.3726
0.4222
0.3840
0.3799
0.3828
0.4263
0.3929
5R
0.3217
0.3316
0.3714
0.3775
0.4185
0.3902
0.3222
0.3243
0.3736
0.3874
0.4223
0.3990
0.3293
0.3384
0.3799
0.3828
0.4263
0.3929
0.3294
0.3306
0.3212
0.3389
0.3217
0.3292
0.3293
0.3826
0.3931
0.3746
0.3624
0.3316
0.3773
0.3461
0.3822
0.3384
5M
6M
6R
0.4305
0.4019
0.4223
0.3990
0.3726
0.4261
0.4077
0.3670
0.4305
0.4019
0.3853
0.3776
0.4346
0.4108
7R
0.3206
0.3462
0.3773
0.3726
0.4261
0.4077
0.3212
0.3389
0.3799
0.3828
0.4299
0.4165
0.3292
0.3461
0.3853
0.3776
0.4346
0.4108
0.3885
0.3882
0.3799
0.3828
0.3306
0.3826
0.3369
0.3885
0.3369
0.3451
0.3292
0.3461
0.3293
0.3384
0.3369
0.3451
0.3292
0.3539
0.3293
0.3384
0.3294
0.3366
7M
5N
0.4387
0.4197
0.4222
0.3840
0.3931
0.4263
0.3929
0.3882
0.4298
0.3867
0.3916
0.3987
0.4342
0.3957
0.3822
0.3670
0.4263
0.3929
0.3853
0.3776
0.4305
0.4019
0.3898
0.3716
0.4342
0.3957
0.3934
0.3825
0.3853
0.3776
0.3539
0.3885
0.3534
0.3934
0.3616
0.3970
0.3373
0.3534
0.3292
0.3461
0.3292
0.3373
0.3376
6N
2014-02-15
Subject to change.
8R
8
5S
6S
0.4386
0.4048
0.4305
0.4019
0.3882
0.4346
0.4108
0.3825
0.4386
0.4048
0.3935
0.4430
0.4138
7S
Draft Version 0.0
Group
Gruppe
5H
6H
7H
5I
6I
GW CSSRM1.PC
Cx
Cy
0.3366
0.3369
0.3369
0.3451
0.3441
0.3428
Group
Gruppe
7N
Cx
Cy
0.3885
0.3882
0.3916
0.3987
0.3970
0.3935
0.4006
0.4044
0.3890
0.3690
0.3534
0.3916
0.3515
0.3975
0.3456
0.3601
0.3373
0.3534
0.3376
0.3616
0.3456
0.3601
0.3464
0.3688
0.3441
0.3428
0.3448
0.3515
0.3527
0.3448
0.3515
0.3369
0.3451
0.3373
0.3448
5O
6O
Cy
0.4346
0.4108
0.4387
0.4197
0.4430
0.4138
0.4474
0.4228
0.3867
0.3772
0.4342
0.3957
0.3731
0.4373
0.3893
0.4006
0.3815
0.4420
0.3985
0.3916
0.3772
0.4342
0.3957
0.3943
0.3853
0.4386
0.4048
0.4006
0.3815
0.4420
0.3985
0.4036
0.3898
0.3853
0.3515
0.3970
0.3487
0.4036
0.3578
8O
8S
Cx
0.4298
0.3943
7O
Group
Gruppe
5T
6T
0.4468
0.4077
0.4386
0.4048
0.3934
0.4430
0.4138
0.3898
0.4468
0.4077
0.4067
0.3982
0.4515
0.4168
7T
0.3448
0.3515
0.3970
0.3934
0.4430
0.4138
0.3456
0.3601
0.3997
0.4015
0.4474
0.4228
0.3527
0.3578
0.4067
0.3982
0.4515
0.4168
0.3539
0.3669
0.4097
0.4065
0.4562
0.4260
2014-02-15
Subject to change.
9
8T
Draft Version 0.0
GW CSSRM1.PC
Group Name on Label
Gruppenbezeichnung auf Etikett
Example: MT-5H-K2
Beispiel: MT-5H-K2
Brightness
Helligkeit
Farbort
Forward Voltage
Durchlassspannung
MT
5H
K2
Note:
No packing unit / tape ever contains more than one group for each selection.
Anm.:
In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Selektion enthalten.
2014-02-15
Subject to change.
10
Draft Version 0.0
GW CSSRM1.PC
Relative Spectral Emission - V(λ) = Standard eye response curve 6) page 26
Relative spektrale Emission - V(λ) = spektrale Augenempfindlichkeit 6) Seite 26
Φrel = f (λ); TS = 85 °C; IF = 700 mA
Irel
GW CSSRM1.PC
1.0
: Vλ
: white
0.8
0.6
0.4
0.2
0.0
350
400
450
500
550
600
650
700
750
800
λ [nm]
Radiation Characteristics 6) page 26
Abstrahlcharakteristik 6) Seite 26
Irel = f (ϕ); TS = 85 °C
GW CSSRM1.PC
ϕ [°]
-10°
0°
10°
20°
30°
40°
50°
60°
70°
80°
-20°
-30°
90°
1.0
: 0°
: 45°
-40°
0.8
-50°
0.6
-60°
0.4
-70°
0.2
-80°
-90°
0.0
-100°
2014-02-15
Subject to change.
11
Irel
Draft Version 0.0
GW CSSRM1.PC
Relative Luminous Flux 6) page 26 , 8) page 26
Relativer Lichtstrom 6) Seite 26 , 8) Seite 26
ΦV/ΦV (700 mA) = f(IF); TS = 85 °C
Forward Current 6) page 26
Durchlassstrom 6) Seite 26
IF = f (VF); TS = 85 °C
IF [mA]
ΦV
GW CSSRM1.PC
1800
GW CSSRM1.PC
ΦV(700mA)
: white
: white
2.0
1600
1400
1.5
1200
1000
1.0
800
0.5
600
400
VF [V]
: Cx
: Cy
0.355
0.350
0.345
18
00
16
00
14
00
12
00
10
00
60
40
IF [mA]
2014-02-15
Subject to change.
00
18
00
00
00
16
14
00
IF [mA]
GW CSSRM1.PC
Cx
Cy
12
Chromaticity Coordinate Shift
Farbortverschiebung 6) Seite 26
Cx, Cy = f(IF); TS = 85 °C
6) page 26
80
10
3.2
60
40
200
2.6
12
Draft Version 0.0
GW CSSRM1.PC
Relative Lichtstrom 6) Seite 26
ΦV/ΦV (85 °C) = f(Tj); IF = 700 mA
Relative Forward Voltage 6) page 26
Relative Vorwärtsspannung 6) Seite 26
ΔVF = VF - VF(85 °C) = f(Tj); IF = 700 mA
ΔVF [V]
Φv
GW CSSRM1.PC
0.3
Φv(85°C )
: white
: white
0.2
1.0
0.1
0.8
0.0
0.6
-0.1
0.4
-0.2
0.2
-0.3
-40 -20
60
0.0
-40 -20
80 100 120
Tj [°C]
GW CSSRM1.PC
: Cx
: Cy
0.352
0.350
0.348
0.346
0.344
-40 -20
60
80 100 120
Tj [°C]
2014-02-15
Subject to change.
60
80 100 120
T j [°C ]
Chromaticity Coordinate Shift 6) page 26
Cx, Cy = f(Tj); IF = 700 mA
Cx
Cy 0.354
G W C S S R M1.P C
1.2
13
Draft Version 0.0
GW CSSRM1.PC
Max. Permissible Forward Current
Max. zulässiger Durchlassstrom
IF = f (T)
IF [mA]
GW CSSRM1.PC
1900
1800
1700
1600
1500
1400
1300
1200
1100
1000
900
800
700
600
500
400
300
200
Do not use below 200 mA
100
60
80
100
120
140
Ts [°C]
2014-02-15
Subject to change.
14
Draft Version 0.0
GW CSSRM1.PC
Package Outline 9) page 26
Maßzeichnung 9) Seite 26
Approximate Weight:
29 mg
Gewicht:
29 mg
Mark:
Cathode
Markierung:
Kathode
ESD information:
LED is protected by ESD device which is
connected in parallel to LED-Chip.
ESD Information:
Die LED enthält ein ESD-Bauteil, das parallel
zum Chip geschaltet ist.
Corrosion robustness:
Test conditions: 40 °C / 90 % rh / 15 ppm H2S /
336 h
= Stricter than IEC 60068-2-43 (H 2S) [25°C / 75
% rh / 10 ppm H 2S / 21 days]
= Regarding relevant gas (H2S) stricter than EN
60068-2-60 (method 4) [25 °C / 75 % rh / 200
ppb SO2, 200 ppb NO2,10 ppb Cl2 / 21 days]
2014-02-15
Subject to change.
15
Draft Version 0.0
GW CSSRM1.PC
Korrosionsfestigkeit:
2014-02-15
Subject to change.
Test Kondition: 40°C / 90 % rh / 15 ppm H 2S /
336 h
= Besser als IEC 60068-2-43 (H2S) [25°C / 75 %
rh / 10 ppm H2S / 21 Tage]
= Bezogen auf das Gas (H 2S) besser als EN
60068-2-60 (method 4) [25°C / 75 % rh / 200ppb
SO2, 200ppb NO2,10ppb Cl2 / 21 Tage]
16
Draft Version 0.0
GW CSSRM1.PC
Recommended Solder Pad 9) page 26
Empfohlenes Lötpaddesign 9) Seite 26
foot print
Cu area
2014-02-15
Subject to change.
Reflow soldering
Reflow-Löten
solder resist
17
solder stencil
Draft Version 0.0
GW CSSRM1.PC
Note:
For superior solder joint connectivity results we
recommend soldering under standard nitrogen
atmosphere. For further information please refer
to our Application Note “Handling and
Processing Details for Ceramic LEDs“.
Anm.:
Um eine verbesserte Lötstellenkontaktierung zu
erreichen, empfehlen wir, unter StandardStickstoffatmosphäre zu löten. Weitere
Informationen finden Sie in der
Applikationsschrift „Handling and Processing
2014-02-15
Subject to change.
18
Draft Version 0.0
GW CSSRM1.PC
Reflow Soldering Profile
Reflow-Lötprofil
Preconditioning: JEDEC Level 2 acc. to JEDEC J-STD-020D.01
OHA04525
300
˚C
T 250
Tp 245 ˚C
240 ˚C
tP
217 ˚C
200
tL
150
tS
100
50
25 ˚C
100
150
200
s 300
250
t
OHA04612
Profile Feature
Profil-Charakteristik
Symbol
Symbol
Pb-Free (SnAgCu) Assembly
Minimum
Ramp-up rate to preheat*)
25 °C to 150 °C
Time tS
TSmin to TSmax
tS
60
Ramp-up rate to peak*)
TSmax to TP
Recommendation
Maximum
2
3
100
120
2
3
Unit
Einheit
K/s
s
K/s
Liquidus temperature
TL
217
Time above liquidus temperature
tL
80
100
s
Peak temperature
TP
245
260
°C
Time within 5 °C of the specified peak
temperature TP - 5 K
tP
s
3
6
K/s
10
Ramp-down rate*
TP to 100 °C
480
Time
25 °C to TP
All temperatures refer to the center of the package, measured on the top of the component
* slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range
2014-02-15
Subject to change.
°C
19
s
Draft Version 0.0
GW CSSRM1.PC
Taping 9) page 26
Gurtung 9) Seite 26
2014-02-15
Subject to change.
Draft Version 0.0
GW CSSRM1.PC
Tape and Reel
Gurtverpackung
12 mm tape with 600 pcs. on ∅ 180 mm reel
W1
D0
P0
A
N
F
W
E
13.0 ±0.25
P2
Label
P1
Direction of unreeling
W2
Leader: min. 400 mm *
Trailer: min. 160 mm *
*) Dimensions acc. to IEC 60286-3; EIA 481-D
OHAY0324
Tape dimensions in mm (inch)
Tape dim ensions in m m ( inch)
W
P0
P1
P2
D0
E
F
12 +0.3/-0.1
4 ± 0.1
(0.157 ±
0.004)
4 ± 0.1
(0.157 ±
0.004)
or
8 ± 0.1
(0.315 ±
0.004)
2 ± 0.05
(0.079 ±
0.002)
1.5 ± 0.1
(0.059 +
0.004)
1.75 ± 0.1
(0.069 ±
0.004)
5.5 ± 0.05
(0.217 ±
0.002)
Reel dimensions in mm (inch)
Reel dim ensions in m m ( inch)
A
W
Nmin
W1
W2max
180 (7)
12 (0.472)
60 (2.362)
12.4 + 2 (0.488 +
0.079)
18.4 (0.724)
2014-02-15
Subject to change.
21
Draft Version 0.0
GW CSSRM1.PC
Barcode-Product-Label (BPL)
Barcode-Produkt-Etikett (BPL)
EX
AM
PL
E
OSRAM Opto
po
BIN1: XX-XX-X-XXX-X
LX XXXX
Semiconductors
tors
ors
r
RoHS Compliant
(6P) BATCH NO:
NO:: 1234567
1234567890
234
4 7890
8
890
ML Temp ST
X XXX °C X
(1T) LOT NO: 1234567890
(9D)
((9D
9D
D) D/C:
D)
D/C
D : 123
D/
1234
23
234
34
RXX
Pack: R
RX
XX
DEMY
Y
XXX
XXX
X_X123_1234.1234
X_X123_1
12 _123
123
12
234.1234 X
(X) PROD NO: 123456789(Q)QTY:
9999
(G) GROUP:
XX-XX-X-X
XX-XX
XX
XXXX-X-X
OHA04563
Dry Packing Process and Materials
Trockenverpackung und Materialien
Moisture-sensitive label or print
L
VE
LE
see
labe
(RH
idity
˚C
40
RH
hum
0%
e
tive
˚C/6
red
kag
rela
30
_
pac
infra
of
90% to ak
ns
ed (pe
or
ditio
and ject
˚C,
sing
5
con
N s IVE S
Otain
TOR
SIT
UC
TI SEN
ND
U Econ
As bag
UR ICO
CThiIST
SEM
1.
sub
ces
be
pro
ory
Barcode label
l
k,
code
blan
If
bar
˚C
e).
cod
date
r
rs
rs
rs
Hou
rs
Hou
72
Hou
48
Hou
24 6
time
time
r
time
23
will
at
l with
fact
r
ent˚C).
MO
Floo
time
TO
at
at
r
Floo
l
ths that
tica
d
ival
ure
OP
Floo
4
if: rea
w
Floo
labe
mon
iden
5
ced
equ
el
ices
g, n
e
5a
is
el
belo
or
24
pro
Lev
6
dev
ntin
el
whe
cod
e
, w,
e
Lev
el
see
e
bag
Lev
l date
mou
bak
ned
stur
e
Lev
reflo bar
re> 10%
led
stur
e
time
sea
for
ope e
Moi
r
see
stur
k,
is
Moi
sea is has k,
stur
befo
d
033
Moi
in
Floo
RH
blan
Moi
or-p blan in
bag
Car
ing,
r
TD(if
life
r
If with
r
lf
10%bak
J-S
thisvapp.
Yea
_
eks rs
r w,
met
cato
1
Yea
tem
d,
She
nted at
uire not
y
1
WeHou
DEC
Afte
Indi
4
uire
reflo
is
bod Mou red req
/JE
time
168
req
2b
r
a)
Sto ices idity
time
is IPC
r
or
time
b)
ned Floo
r
Hum ing ce
time
Dev 2a
r
Floo
a)
ope
3.
b) bakren
Floo
1
l date
Floo
If
2
refe
time el
4.
2a
el
sea
Lev
3
el
and e
Lev
el
Bag
e
e
Lev
stur
e
Lev
Dat
stur
e
Moi
stur
Moi
stur
Moi
Moi
O
S
R
A
M
2.
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
AM
OSR
Desiccant
OHA00539
Note:
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card.
Regarding dry pack you will find further information in the internet and in the Short Form Catalog in
chapter “Tape and Reel” under the topic “Dry Pack”. Here you will also find the normative references
like JEDEC.
Anm.:
Feuchteempfindliche Produkte sind verpackt in einem Trockenbeutel zusammen mit einem
Trockenmittel und einer Feuchteindikatorkarte.
Bezüglich Trockenverpackung finden Sie weitere Hinweise im Internet und in unserem Short Form
Catalog im Kapitel “Gurtung und Verpackung” unter dem Punkt “Trockenverpackung”. Hier sind
Normenbezüge, unter anderem ein Auszug der JEDEC-Norm, enthalten.
2014-02-15
Subject to change.
22
Draft Version 0.0
GW CSSRM1.PC
Transportation Packing and Materials
Kartonverpackung und Materialien
8
Q-
1
R1
lti LS
TO Y
T6
PL 76
1+
Mu
P-
44
(9D
4
3G
(6P
LO
T
00
D/C
: 01
998
NO
: 12
O
021
H1
210
BA
TC
H
Se SR
mi AM
co
nd O
uc pt
to o
rs
NO
5
14 2
110 0
(Q)
QT
Y:
see
labe
N
(1T
O
NO
TI
PR
OD
U
(X)
A
(G)
l
k,
C
GR
OU
P:
Muster
L
VE
LE
code (RH
blan
If
y
bar
idit
RH
hum
e
60%
tive d
˚C/
kag
rela are
30
E S
s
_
infr pac
OR
of
90% to ak
tainITIV
urs
CT
or
e).
ted (pe
urs
ons
Ho
con NS
g
urs
SE DU
Ho
and jec
˚C,
diti
cod
72
sin
Ho urs
5
e
bag E ON
48
˚C sub
e
Ho
con
ces
is UR
24 6
dat
e
MIC
40 be
tim
˚C
h
e
ThISTSE
pro
tory
tim
or
t
wit
23
tim e
at t will
or
fac
MO
Flo
al
len ˚C)
s
tim
TO
at
or
at
Flo
d
or
ure
iva
el
nth s tha
OP
ntic
Flo
4
if: rea
Flo
lab
ow
mo ice equ
ced
ide
5
el
e
5a
is
ingen
el
or
bel
24
pro
6
Lev
e
dev,
el
e
cod
unt wh
Lev
el
re
ow
see
bag
Lev
l dat
mo
re
bak
e
bar
ned
Lev
refl
istu
10%
re
tim
for
sea
istu
ore>
re
Mo
see
3
istu
is
or .
sea is
Mo
bef
nk,
istu
pha nk, Flo
rd
-03
Mo
in
RH
bla
Mo
orbag
ingCa
bla hin
TD
life
(if
ar
If wit
t.
vapp.
10%baktor
J-S
this
elf
Ye ar eks
_
ed
ica med, C
1
urs
Ye
erow tem
Sh
at
uire not
y
1
WeHo
DE
unt
Aft
Ind
1.
e
4
uire
refl
red req
2.
bod Mo
e
ity is
/JE
tim
168
req
e
2b
a)
Sto es
tim
or
mid
is IPC
or
tim e
vic
ned
b)
or
Hu
Flo
tim
ing ce
or
e
De
2a
Flo
a)
ope
or
3.
b) bakren
Flo
e
1
l dat
Flo
If
2
el
refe
tim
2a
4.
el
sea
3
Lev
g
el
and
Lev
el
re
Ba
te
Lev
re
Lev
istu
Da
re
istu
re
Mo
istu
Mo
istu
Mo
Mo
DE
8
Q-
1
R1
lti LS
TO Y
T6
PL 76
1+
PP:
OU
GR
(G)
: 01
O
SR
AM
rs
D/C
to
uc
(9D
00
nd
21
00
21
99
8
4
NO
23
QT
(Q)
O
SR
m A
ico M
H
H1
TC
BA
3G
: 12
(6P
(X)
PR
OD
NO
(1T
11
00
LO
T
14
2
NO
5
Se
Y:
O
pt
o
44
Mu
MY
ED Bin
Bin 1:
Bin 2: P-1
3: Q-1 -20
ML
-20
2
Te
2a
220 mp
3
240
ST
Ad 260 C R
C
R0 diti
R
ona C RT
PA 77
l TE
CK
VA
XT
R:
ope
se
Muster
led
DE
MY
Barcode label
ED Bin
Bin 1:
Bin 2: P-1
3: Q-1 -20
ML
-20
2
Tem
2a
220
3
240 p ST
Ad 260 C R
C
R0 diti
R
ona C RT
PA 77
l TE
CK
VA
XT
R:
Barcode label
Packing
Sealing label
OHA02044
Dimensions of transportation box in mm (inch):
Width / Breite
Length / Länge
Height / Höhe
195 ± 5 (7.677 ± 0.1968)
30 ± 5 (1.181 ± 0.196)
2014-02-15
Subject to change.
23
Draft Version 0.0
GW CSSRM1.PC
Notes
Hinweise
The evaluation of eye safety occurs according to the
standard IEC 62471:2008 ("photobiological safety of
lamps and lamp systems"). Within the risk grouping
system of this CIE standard, the LED specified in this
data sheet fall into the class Moderate risk (exposure
time 0.25 s). Under real circumstances (for exposure
time, eye pupils, observation distance), it is
assumed that no endangerment to the eye exists
from these devices. As a matter of principle,
however, it should be mentioned that intense light
sources have a high secondary exposure potential
due to their blinding effect. As is also true when
viewing other bright light sources (e.g. headlights),
temporary reduction in visual acuity and afterimages
can occur, leading to irritation, annoyance, visual
impairment, and even accidents, depending on the
situation.
Die Bewertung der Augensicherheit erfolgt nach
dem Standard IEC 62471:2008 ("photobiological
safety of lamps and lamp systems"). Im
Risikogruppensystem dieser CIE- Norm erfüllen die
in diesem Datenblatt angegebenen LEDs folgende
Gruppenanforderung - Moderate risk
(Expositionsdauer 0,25 s). Unter realen Umständen
(für Expositionsdauer, Augenpupille,
Betrachtungsabstand) geht damit von diesen
Bauelementen keinerlei Augengefährdung aus.
Grundsätzlich sollte jedoch erwähnt werden, dass
intensive Lichtquellen durch ihre Blendwirkung ein
hohes sekundäres Gefahrenpotenzial besitzen.
Nach einem Blick in eine helle Lichtquelle (z.B.
Autoscheinwerfer), kann ein temporär
eingeschränktes Sehvermögen oder auch
Nachbilder zu Irritationen, Belästigungen,
Beeinträchtigungen oder sogar Unfällen führen.
Subcomponents of this LED contain, among other
substances, goldplated and Ag-filled materials. In
spite of the improved corrosion stability of this LED,
it can be affected by environments that contain very
high concentrations of aggressive substances.
Therefore, we recommend avoiding aggressive
atmospheres during storage, production and use.
Einzelkomponenten dieser LED enthalten u.a.
goldbeschichtete und Ag-gefüllte Materialien. Trotz
der verbesserten Korrosionsstabilität dieser LED
können Einzelkomponenten durch sehr hohe
Konzentration aggressiver Substanzen angegriffen
werden. Aus diesem Grund wird empfohlen,
aggressive Umgebungen während der Lagerung,
Produktion und im Betrieb zu vermeiden.
For further application related informations
please visit www.osram-os.com/appnotes
Für weitere applikationsspezifische
Informationen besuchen Sie bitte
Change management for this component is aligned
with the requirements of the lighting market.
Das Änderungsmanagement dieses Bauteils ist an
den Anforderungen des Lichtmarktes ausgerichtet.
2014-02-15
Subject to change.
24
Draft Version 0.0
GW CSSRM1.PC
Disclaimer
Disclaimer
OSRAM OS assumes no liability whatsoever for any use
of this document or its content by recipient including, but
not limited to, for any design in activities based on this
preliminary draft version. OSRAM OS may e.g. decide at
its sole discretion to stop developing and/or finalising the
underlying design at any time.
OSRAM OS übernimmt keine wie auch immer geartete
Haftung für die Nutzung dieses Dokuments und seines
Inhaltes durch den Empfänger, insbesondere nicht für
irgendwelche Design-Aktivitäten, die auf dieser
vorläufigen Entwurfsversion basieren. OSRAM OS
behält sich beispielsweise auch vor, jederzeit die
Weiter- und Fertigentwicklung des zugrundeliegenden
Designs einseitig einzustellen.
Attention please!
The information describes the type of component and
shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved.
Due to technical requirements components may contain
dangerous substances.
For information on the types in question please contact
our Sales Organization.
If printed or downloaded, please find the latest version in
the Internet.
Packing
Please use the recycling operators known to you. We
can also help you – get in touch with your nearest sales
office.
By agreement we will take packing material back, if it is
sorted. You must bear the costs of transport. For
packing material that is returned to us unsorted or which
we are not obliged to accept, we shall have to invoice
you for any costs incurred.
Components used in life-support devices or
systems must be expressly authorized for such
purpose!
Critical components* may only be used in life-support
devices** or systems with the express written approval
of OSRAM OS.
Bitte beachten!
Lieferbedingungen und Änderungen im Design
vorbehalten. Aufgrund technischer Anforderungen
können die Bauteile Gefahrstoffe enthalten. Für weitere
Informationen zu gewünschten Bauteilen, wenden Sie
sich bitte an unseren Vertrieb. Falls Sie dieses
Datenblatt ausgedruckt oder heruntergeladen haben,
finden Sie die aktuellste Version im Internet.
Verpackung
Benutzen Sie bitte die Ihnen bekannten Recyclingwege.
Wenn diese nicht bekannt sein sollten, wenden Sie sich
bitte an das nächstgelegene Vertriebsbüro. Wir nehmen
das Verpackungsmaterial zurück, falls dies vereinbart
wurde und das Material sortiert ist. Sie tragen die
Transportkosten. Für Verpackungsmaterial, das
unsortiert an uns zurückgeschickt wird oder das wir nicht
annehmen müssen, stellen wir Ihnen die anfallenden
Kosten in Rechnung.
Bauteile, die in lebenserhaltenden Apparaten und
Systemen eingesetzt werden, müssen für diese
Zwecke ausdrücklich zugelassen sein!
Kritische Bauteile* dürfen in lebenserhaltenden
Apparaten und Systemen** nur dann eingesetzt
werden, wenn ein schriftliches Einverständnis von
OSRAM OS vorliegt.
*) A critical component is a component used in a
life-support device or system whose failure can
reasonably be expected to cause the failure of that
life-support device or system, or to affect its safety or the
effectiveness of that device or system.
**) Life support devices or systems are intended (a) to be
implanted in the human body, or (b) to support and/or
maintain and sustain human life. If they fail, it is
reasonable to assume that the health and the life of the
user may be endangered.
*) Ein kritisches Bauteil ist ein Bauteil, das in
lebenserhaltenden
Apparaten
oder
Systemen
eingesetzt wird und dessen Defekt voraussichtlich zu
einer Fehlfunktion dieses lebenserhaltenden Apparates
oder Systems führen wird oder die Sicherheit oder
Effektivität
dieses
Apparates
oder
Systems
beeinträchtigt.
**) Lebenserhaltende Apparate oder Systeme sind für
(a) die Implantierung in den menschlichen Körper oder
(b) für die Lebenserhaltung bestimmt. Falls Sie
versagen, kann davon ausgegangen werden, dass die
Gesundheit und das Leben des Patienten in Gefahr ist.
2014-02-15
Subject to change.
25
Draft Version 0.0
GW CSSRM1.PC
Glossary
Glossar
1)
Brightness: Brightness values are measured during
a current pulse of typically 25 ms, with an internal
reproducibility of ± 8 % and an expanded uncertainty
of ± 11 % (acc. to GUM with a coverage factor of
k = 3).
1)
Helligkeit: Helligkeitswerte werden während eines
Strompulses einer typischen Dauer von 25 ms, mit
einer internen Reproduzierbarkeit von ± 8 % und
einer erweiterten Messunsicherheit von ± 11 %
gemessen (gemäß GUM mit Erweiterungsfaktor
k = 3).
2)
Reverse Operation: A minimum of 10 hours of
reverse operation is permisable in total.
2)
Betrieb in Sperrrichtung: Eine Gesamtbetriebszeit
von wenigstens 10 Stunden in Sperrrichtung ist
gewährleistet.
3)
Forward Voltage: The forward voltage is measured
during a current pulse of typically 8 ms, with an
internal reproducibility of ± 0.05 V and an expanded
uncertainty of ± 0.1 V (acc. to GUM with a coverage
factor of k = 3).
3)
Durchlassspannung: Vorwärtsspannungen
werden während eines Strompulses einer typischen
Dauer
von
8 ms,
mit
einer
internen
Reproduzierbarkeit von ± 0,05 V und einer
erweiterten Messunsicherheit von ± 0,1 V gemessen
(gemäß GUM mit Erweiterungsfaktor k = 3).
4)
Color reproduction index: Color
reproduction
index values (CRI-RA) are measured during a
reproducibility of ± 2 and an expanded uncertainty of
± 3 (acc. to GUM with a coverage factor of k = 3).
4)
Farbwiedergabe Index: Werte
des
Farbwiedergabe Index (CRI-RA) werden während
eines Strompulses einer typischen Dauer von 25 ms,
mit einer internen Reproduzierbarkeit von ± 2 und
einer erweiterten Messunsicherheit von ± 3
k = 3).
5)
Thermal Resistance: Rth max is based on statistic
values (6σ).
5)
Wärmewiderstand: Rth
statistischen Werten (6σ).
6)
Typical Values: Due to the special conditions of the
manufacturing processes of LED, the typical data or
calculated correlations of technical parameters can
only reflect statistical figures. These do not
necessarily correspond to the actual parameters of
each single product, which could differ from the
typical data and calculated correlations or the typical
characteristic line. If requested, e.g. because of
technical improvements, these typ. data will be
changed without any further notice.
6)
Typische Werte: Wegen
der
besonderen
Prozessbedingungen bei der Herstellung von LED
können typische oder abgeleitete technische
Parameter nur aufgrund statistischer Werte
wiedergegeben werden. Diese stimmen nicht
notwendigerweise mit den Werten jedes einzelnen
Produktes überein, dessen Werte sich von typischen
und abgeleiteten Werten oder typischen Kennlinien
unterscheiden können. Falls erforderlich, z.B.
aufgrund technischer Verbesserungen, werden
diese typischen Werte ohne weitere Ankündigung
geändert.
7)
Chromaticity coordinate groups: Chromaticity
coordinates are measured during a current pulse of
typically 25 ms, with an internal reproducibility of
± 0.005 and an expanded uncertainty of ± 0.01 (acc.
7)
Farbortgruppen: Farbkoordinaten werden während
mit einer internen Reproduzierbarkeit von ± 0,005
und einer erweiterten Messunsicherheit von ± 0,01
k = 3).
8)
Relative Brightness Curve: In the range where the
line of the graph is broken, you must expect higher
brightness differences between single LEDs within
one packing unit.
8)
Relative Helligkeitskurve: Im
gestrichelten
Bereich der Kennlinien muss mit erhöhten
Helligkeitsunterschieden zwischen Leuchtdioden
innerhalb einer Verpackungseinheit gerechnet
werden.
9)
Tolerance of Measure: Unless otherwise noted in
drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
9)
Maßtoleranz: Wenn in der Zeichnung nicht anders
angegeben, gilt eine Toleranz von ±0,1. Maße
werden in mm angegeben.
2014-02-15
Subject to change.
26
max
basiert
auf
Draft Version 0.0
GW CSSRM1.PC
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
2014-02-15
Subject to change.
27
