LCW E6SG-V2BA-4J8K-Z 数据手册
2014-04-04
Power TOPLED
Datasheet
Version 1.1 (not for new design)
LCW E6SG
PowerTOPLED, a powerful member of the TOPLED
family. Thanks to their high luminous efficacy, the
LEDs are ideal for rear light clusters and indicators on
vehicles and for display panels for traffic control
systems.
PowerTOPLED, ein leistungsstarkes Mitglied der
TOPLED Familie. Dank der hohen Lichtausbeute
eignen sie sich ideal für Heckleuchten und Indikatoren
an Fahrzeugen und für Display-Panels in
Verkehrsleitsysteme.
Features:
Besondere Merkmale:
• Package: white PLCC-4 package, colored
diffused silicone resin
• Technology: ThinGaN
• Viewing angle at 50 % IV: 120° (Lambertian
Emitter)
• Color: Cx = 0.42, Cy = 0.40 acc. to CIE 1931
(warm white); CTR = 2700 K - 4500 K
• Gehäusetyp: weisses PLCC-4 Gehäuse, farbiger
diffuser Silikon-Verguss
• Technologie: ThinGaN
• Abstrahlwinkel bei 50 % IV: 120° (Lambertscher
Strahler)
• Farbe: Cx = 0.42, Cy = 0.40 nach CIE 1931
(warmweiß); CTR = 2700 K - 4500 K
Applications
Anwendungen
Automotive Interior Lighting
Aircraft Interior Lighting
White Goods Lighting
Pushbuttons and Switches
Signal and Symbol Luminary
2014-04-04
1
Automobilbeleuchtung innen
Flugzeugbeleuchtung innen
Weiße Ware
Schalter und Taster
Signal- und Symbolleuchten
LCW E6SG
Ordering Information
Bestellinformation
Type:
Color
Temperature
Luminous
Intensity 1) page 25
Ordering Code
Typ:
Farbtemperatur
Lichtstärke
Bestellnummer
1) Seite 25
IF = 30 mA
[K]
IV [mcd]
LCW E6SG-V1AB-4U9X
2700
710 ... 1800
Q65110A7736
LCW E6SG-V1AB-4R9T
3000
710 ... 1800
Q65110A7737
LCW E6SG-V2BA-4O9Q
3500
900 ... 2240
Q65110A7733
LCW E6SG-V2BA-4L8N
4000
900 ... 2240
Q65110A7734
LCW E6SG-V2BA-4J8K
4500
900 ... 2240
Q65110A7735
Note:
The above Type Numbers represent the order groups which include only a few brightness groups (see page 5). Only one group will be shipped on each
packing unit (there will be no mixing of two groups on each packing unit). E. g. LCW E6SG-V2BA-4O9Q means that only one group AA, AB, BA, V2 will
be shippable for any packing unit. In order to ensure availability, single brightness groups will not be orderable.
In a similar manner for colors where color chromaticity coordinate groups are measured and binned, single groups will be shipped on any one packing
unit. LCW E6SG-V2BA-4O9Q means that the device will be shipped within the specified limits. In order to ensure availability, single color chromaticity
groups groups will not be orderable (see page 6).
In a similar manner for colors where forward voltage groups are measured and binned, single forward voltage groups will be shipped on any packing
unit. E. g. LCW E6SG-V2BA-4O9Q means that only one forward voltage group will be shippable. In order to ensure availability, single forward voltage
groups will not be orderable (see page 5).
Anm.:
Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen (siehe Seite 5). Es
wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. LCW E6SG-V2BA-4O9Q bedeutet, dass in einer Verpackungseinheit
nur eine der Helligkeitsgruppen AA, AB, BA, V2 enhalten ist. Um die Liefersicherheit zu gewährleisten, können einzelne Helligkeitsgruppen nicht
bestellt werden.
Gleiches gilt für die Farben, bei denen Farbortgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine Farbortgruppe geliefert.
Z.B. LCW E6SG-V2BA-4O9Q bedeutet, dass in einer Verpackungseinheit nur eine der Farbortgruppen enthalten ist (siehe Seite 6). LCW
E6SG-V2BA-4O9Q bedeutet, dass das Bauteil innerhalb der spezifizierten Grenzen geliefert wird. Um die Liefersicherheit zu gewährleisten, können
einzelne Farbortgruppen nicht bestellt werden.
Gleiches gilt für die LEDs, bei denen die Durchlassspannungsgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine
Durchlassspannungsgruppe geliefert. Z. B. LCW E6SG-V2BA-4O9Q bedeutet, dass nach Durchlassspannungsgruppen gruppiert wird. In einer
Verpackungseinheit ist nur eine der Durchlassspannungsgruppen enthalten (siehe Seite 5). Um die Liefersicherheit zu gewährleisten, können einzelne
Durchlassspannungsgruppen nicht direkt bestellt werden.
2014-04-04
2
LCW E6SG
Maximum Ratings
Grenzwerte
Parameter
Symbol
Values
Unit
Bezeichnung
Symbol
Werte
Einheit
Operating temperature range
Betriebstemperatur
Top
-40 ... 110
°C
Storage temperature range
Lagertemperatur
Tstg
-40 ... 110
°C
Junction temperature
Sperrschichttemperatur
Tj
125
°C
Junction Temperature
Tj
>150 for short term
applications
°C
Forward current
Durchlassstrom
(TS = 25 °C)
IF
5 ... 50
mA
Surge current
Stoßstrom
(t ≤ 10 µs; D = 0.005; TS = 25 °C)
IFM
300
mA
Reverse voltage
Sperrspannung
(TS = 25 °C)
VR
not designed for reverse
operation
V
2
kV
ESD withstand voltage
VESD
ESD Festigkeit
(acc. to ANSI/ESDA/JEDEC JS-001 - HBM, Class
2)
2014-04-04
3
LCW E6SG
Characteristics (TS = 25 °C; IF = 30 mA)
Kennwerte
Parameter
Symbol
Values
Unit
Bezeichnung
Symbol
Werte
Einheit
Chromaticity coordinates acc. to CIE 1931
(typ.)
(typ.)
Cx
Cy
0.42
0.4
(typ.)
2ϕ
120
Forward voltage 3) page 25
Durchlassspannung 3) Seite 25
(min.)
(typ.)
(max.)
VF
VF
VF
2.90
3.40
3.80
V
V
V
IR
not designed for
reverse operation
2) page 25
Farbkoordinaten nach CIE 1931 2) Seite 25
Reverse current
Sperrstrom
Real thermal resistance junction / ambient
(max.)
Rth JA real
300
K/W
(max.)
Rth JS real
180
K/W
4) page 25 , 5) page 25
Realer Wärmewiderstand Sperrschicht /
Umgebung 4) Seite 25 , 5) Seite 25
Real thermal resistance junction / solder point
5) page 25
Realer Wärmewiderstand Sperrschicht / Lötpad
5) Seite 25
Note:
Individual forward voltage groups see next page
Anm.:
Durchlassspannungsgruppen siehe nächste Seite
2014-04-04
4
LCW E6SG
Brightness Groups
Helligkeitsgruppen
Group
Luminous Intensity
Luminous Intensity
1) page 25
1) page 25
1) Seite 25
Luminous Flux 6) page 25
Lichtstärke 1) Seite 25
Lichtstrom 6) Seite 25
(min.) Iv [mcd]
(max.) Iv [mcd]
(typ.) ΦV [mlm]
710
900
2415
Gruppe
Lichtstärke
V1
V2
900
1120
3030
AA
1120
1400
3780
AB
1400
1800
4800
BA
1800
2240
6060
Note:
The standard shipping format for serial types includes either a lower family group, an upper family group or a grouping of all individual brightness groups
of only a few brightness groups. Individual brightness groups cannot be ordered.
Anm.:
Die Standardlieferform von Serientypen beinhaltet entweder eine untere Familiengruppe, eine obere Familiengruppe oder eine Sammelgruppe, die aus
nur wenigen Helligkeitsgruppen besteht. Einzelne Helligkeitsgruppen sind nicht bestellbar.
Forward Voltage Groups 3) page 25
Durchlassspannungsgruppen 3) Seite 25
Group
Gruppe
(min.) VF [V]
(max.) VF [V]
4
2.90
3.20
5
3.20
3.50
6
3.50
3.80
2014-04-04
5
LCW E6SG
Chromaticity Coordinate Groups 2) page 25
Farbortgruppen 2) Seite 25
Cy 0.54
0.52
0.50
0.9
520
0.48
530
Cy 0.8
540
0.46
510
550
0.7
2700 K
0.42
570
0.5
580
590
600
610
620
630
E
0.3
490
0.2
0.40
4000 K
7
6
4500 K
5
4
0.38
0.36
0.34
480
470
460
450
0.1
9
3500 K
500
0.4
3000 K
0.44
560
0.6
8
7
6
5
4
J
K
L
M
N
O
P
UV
S T
Q R
WX
0.32
0.30
0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9
Cx
0.28
0.48
0.50
0.46
0.42
0.44
0.38
0.40
0.34
0.24
0.36
0.26
Cx
OHA03621
Color Chromaticity Groups
Group
Gruppe
4J
5J
6J
2014-04-04
2) page 25
Cx
Cy
Group
Gruppe
0.3500
0.3375
0.3969
0.3934
0.3512
0.3465
0.3996
0.4015
0.3574
0.3427
0.4067
0.3982
0.4097
0.4065
0.3996
0.4015
8O
Cx
Cy
0.3591
0.3522
0.3512
0.3465
0.3524
0.3555
0.4023
0.3591
0.3522
0.3608
0.3616
0.3524
0.3555
0.3945
0.3648
0.3536
0.3646
0.3975
0.3731
0.3608
0.3616
0.4027
0.3625
0.3711
0.4061
9O
4P
Group
Gruppe
7T
Cx
Cy
0.4386
0.4047
0.4430
0.4138
0.4467
0.4076
0.4515
0.4168
0.4430
0.4138
0.4096
0.4474
0.4228
0.4097
0.4065
0.4515
0.4168
0.4128
0.4148
0.4562
0.4260
0.4474
0.4228
0.4518
0.4319
0.3687
0.4562
0.4260
0.3773
0.4609
0.4352
6
8T
9T
Group
Gruppe
7J
8J
4K
5K
6K
7K
8K
4L
2014-04-04
Group
Gruppe
LCW E6SG
Cx
Cy
0.3536
0.3646
0.3975
0.3731
0.3548
0.3736
0.4006
0.3815
0.3625
0.3711
0.4061
0.3773
0.4095
0.3858
0.4006
0.3815
5P
Cx
Cy
0.3642
0.3805
0.3548
0.3736
0.3560
0.3826
0.4036
0.3642
0.3805
0.4095
0.3659
0.3899
0.4129
0.3574
0.3427
0.4036
0.3898
0.3591
0.3522
0.4067
0.3982
0.3648
0.3479
0.4129
0.3944
0.4164
0.4029
0.4067
0.3982
6P
7P
0.4420
0.3985
0.4428
0.3906
0.3944
0.4477
0.3998
0.4420
0.3985
0.4467
0.4076
0.4477
0.3998
0.3616
0.4097
0.3578
0.4164
0.3692
0.3677
0.4198
0.3608
0.3616
0.4097
0.4065
0.3625
0.3711
0.4128
0.4148
0.3692
0.3677
0.4198
0.4115
0.4232
0.4201
0.4027
0.3687
0.4090
0.4076
0.4065
0.4515
0.4168
0.4029
0.4526
0.4090
0.4115
0.4576
0.4182
0.4515
0.4168
0.4562
0.4260
0.4576
0.4182
0.3775
0.3711
0.3642
0.3805
0.4061
0.3714
0.3775
0.4109
0.3736
0.3874
0.4147
0.3642
0.3805
0.4061
0.3773
0.3659
0.3899
0.4095
0.3858
0.3736
0.3874
0.4147
0.3814
0.4185
0.3902
0.4095
0.3858
0.3670
0.3578
0.4129
0.3719
0.3522
0.4185
0.3746
0.3624
0.4223
6Q
7
6U
0.4526
0.3714
0.3973
5U
0.4467
0.3625
0.3479
0.3813
0.3858
0.3670
0.3758
0.3893
0.4379
0.3898
0.3608
0.3648
0.3801
0.4373
0.3906
0.3578
5Q
0.4326
0.3893
0.3522
4Q
Cy
0.4428
0.3670
9P
4U
Cx
0.4373
0.3591
8P
Group
Gruppe
7U
8U
0.4625
0.4275
0.4562
0.4260
0.3773
0.4609
0.4352
0.3726
0.4625
0.4275
0.3814
0.4674
0.4367
0.4379
0.3813
0.4428
0.3906
0.4432
0.3826
9U
4V
0.4483
0.3918
0.4428
0.3906
0.3944
0.4477
0.3998
0.3902
0.4483
0.3918
0.3989
0.4534
0.4011
5V
Group
Gruppe
5L
6L
7L
8L
4M
5M
6M
7M
2014-04-04
Group
Gruppe
LCW E6SG
Cx
Cy
0.3670
0.3578
0.4129
0.3944
0.3692
0.3677
0.4164
0.4029
0.3746
0.3624
0.4223
0.3989
0.4261
0.4077
0.4164
0.4029
7Q
Cx
Cy
0.3773
0.3726
0.3692
0.3677
0.3714
0.3775
0.4198
0.3773
0.3726
0.4261
0.3799
0.3828
0.4299
0.3714
0.3775
0.4198
0.4115
0.3736
0.3874
0.4232
0.4201
0.3799
0.3828
0.4299
0.4165
0.4337
0.4253
0.4109
0.3726
8Q
9Q
0.4576
0.4182
0.4585
0.4104
0.4165
0.4636
0.4197
0.4576
0.4182
0.4625
0.4275
0.4636
0.4197
0.3973
0.4147
0.3931
0.4181
0.3853
0.4033
0.4222
0.3719
0.3522
0.4147
0.3814
0.3746
0.3624
0.4185
0.3902
0.3791
0.3564
0.4222
0.3840
0.4263
0.3929
0.4185
0.3902
0.4290
0.4275
0.3814
0.4674
0.4367
0.3751
0.4688
0.4290
0.3840
0.4739
0.4382
0.4432
0.3826
0.4483
0.3918
0.4485
0.3838
0.3670
0.3624
0.3773
0.3726
0.4223
0.3822
0.3670
0.4263
0.3853
0.3776
0.4304
0.3773
0.3726
0.4223
0.3989
0.3799
0.3828
0.4261
0.4077
0.3853
0.3776
0.4304
0.4018
0.4346
0.4108
0.4261
0.4077
0.3826
0.3931
0.4299
0.3885
0.3882
0.4346
0.3916
0.3987
0.4387
8R
8
8V
0.4688
0.3822
0.3882
7V
0.4625
0.3746
0.3828
0.4011
0.4077
0.3826
0.3885
0.4090
0.4534
0.4115
0.3758
0.3799
0.3998
0.4526
0.4104
0.3931
7R
0.4477
0.4090
0.3874
6R
Cy
0.4585
0.3826
5R
6V
Cx
0.4526
0.3736
4R
Group
Gruppe
9V
4W
0.4538
0.3931
0.4483
0.3918
0.3989
0.4534
0.4011
0.3929
0.4538
0.3931
0.4018
0.4591
0.4024
0.4534
0.4011
0.4585
0.4104
0.4591
0.4024
5W
6W
0.4644
0.4118
0.4585
0.4104
0.4165
0.4636
0.4197
0.4108
0.4644
0.4118
0.4197
0.4697
0.4211
7W
Group
Gruppe
8M
4N
5N
6N
7N
8N
4O
5O
2014-04-04
Group
Gruppe
LCW E6SG
Cx
Cy
0.3826
0.3931
0.4299
0.4165
0.3853
0.4033
0.4337
0.4253
0.3916
0.3987
0.4387
0.4197
0.4428
0.4286
0.4181
0.3751
9R
Cx
Cy
0.3947
0.4093
0.3791
0.3564
0.3822
0.3670
0.4222
0.3862
0.3607
0.4253
0.3898
0.3716
0.4298
0.3822
0.3670
0.4222
0.3840
0.3853
0.3776
0.4263
0.3929
0.3898
0.3716
0.4298
0.3867
0.4342
0.3957
0.4263
0.3929
4S
5S
0.4739
0.4382
0.4750
0.4304
0.3867
0.4803
0.4398
0.4485
0.3838
0.4538
0.3850
0.4538
0.3931
0.3882
0.4304
0.3825
0.4342
0.3970
0.3935
0.4386
0.3885
0.3882
0.4304
0.4018
0.3916
0.3987
0.4346
0.4108
0.3970
0.3935
0.4386
0.4047
0.4430
0.4138
0.4346
0.4108
0.3944
0.3931
0.4018
0.4591
0.4024
0.3957
0.4593
0.3944
0.4047
0.4648
0.4038
0.4591
0.4024
0.4644
0.4118
0.4648
0.4038
0.4044
0.3987
0.3947
0.4093
0.4387
0.4006
0.4044
0.4430
0.4042
0.4153
0.4474
0.3862
0.3609
0.4387
0.4197
0.3889
0.3690
0.4428
0.4286
0.3945
0.3648
0.4474
0.4228
0.4518
0.4319
0.4253
0.3776
0.3916
0.3771
0.4298
0.3975
0.3731
0.4326
0.4006
0.3815
0.4373
4T
9
4X
0.4593
0.4006
0.3731
9W
0.4538
0.3916
0.3690
0.4211
0.3776
0.3934
0.3975
0.4290
0.4697
0.3840
0.3885
0.3889
0.4197
0.4688
0.4304
0.3825
9S
0.4636
0.4290
0.3776
8S
Cy
0.4750
0.3934
7S
8W
Cx
0.4688
0.3853
6S
Group
Gruppe
5X
6X
0.4703
0.4132
0.4644
0.4118
0.4197
0.4697
0.4211
0.4138
0.4703
0.4132
0.4228
0.4758
0.4225
0.4697
0.4211
0.4750
0.4304
0.4758
0.4225
7X
8X
0.4813
0.4319
0.4750
0.4304
0.3867
0.4803
0.4398
0.3801
0.4813
0.4319
0.3893
0.4868
0.4413
9X
Group
Gruppe
6O
7O
2014-04-04
Group
Gruppe
LCW E6SG
Cx
Cy
0.3916
0.3771
0.4298
0.3867
0.3943
0.3852
0.4342
0.3957
0.4006
0.3815
0.4373
0.3893
0.4420
0.3985
0.4342
0.3957
5T
Cx
Cy
0.4036
0.3898
0.3943
0.3852
0.3969
0.3934
0.4386
0.4047
0.4036
0.3898
0.4420
0.3985
0.4067
0.3982
0.4467
0.4076
6T
10
Group
Gruppe
Cx
Cy
LCW E6SG
Group Name on Label
Gruppenbezeichnung auf Etikett
Example: AA-4O-4
Beispiel: AA-4O-4
Brightness
Helligkeit
Farbort
Forward Voltage
Durchlassspannung
AA
4O
4
Note:
No packing unit / tape ever contains more than one group for each selection.
Anm.:
In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Selektion enthalten.
2014-04-04
11
LCW E6SG
Relative Spectral Emission - V(λ) = Standard eye response curve 6) page 25
Relative spektrale Emission - V(λ) = spektrale Augenempfindlichkeit 6) Seite 25
Irel = f (λ); TS = 25 °C; IF = 30 mA
OHL03674
100
I rel
Vλ
80
60
40
450
500
550
600
650
700
750
nm 800
λ
Radiation Characteristics 6) page 25
Abstrahlcharakteristik 6) Seite 25
Irel = f (ϕ); TS = 25 °C
40˚
30˚
20˚
10˚
0˚
ϕ
50˚
OHL01660
1.0
0.8
0.6
60˚
0.4
70˚
0.2
80˚
90˚
100˚
1.0
2014-04-04
0.8
0.6
0.4
0˚
20˚
12
40˚
60˚
80˚
100˚
120˚
LCW E6SG
Forward Current 6) page 25
Durchlassstrom 6) Seite 25
IF = f (VF); TS = 25 °C
Relative Luminous Intensity 6) page 25 , 7) page 25
Relative Lichtstärke 6) Seite 25 , 7) Seite 25
IV/IV(30 mA) = f(IF); TS = 25 °C
OHL02359
10 2
IF
OHL03715
10 1
IV
mA
IV (30 mA)
5
10 0
5
10 1
5
10 -1
5
10 0
2.5
3
3.5
4
10 -2
10 0
4.5 V 5
Chromaticity Coordinate Shift 6) page 25
Farbortverschiebung 6) Seite 25
Cx, Cy = f(IF); TS = 25 °C
OHL03716
0.015
∆ Cx, ∆ Cy
0.010
∆Cy
0.005
∆ Cx
-0.005
-0.010
60
80 mA 100
IF
2014-04-04
5
10 1
mA 10 2
IF
VF
13
LCW E6SG
Relative Forward Voltage 6) page 25
Relative Vorwärtsspannung 6) Seite 25
ΔVF = VF - VF(25 °C) = f(Tj); IF = 30 mA
∆VF
IV/IV(25)°C = f(Tj); IF = 30 mA
OHL02397
0.4
V
1.2
OHL03718
IV
I V (25 ˚C)
0.3
0.2
1.0
0.1
0.9
-0.1
0.7
-0.2
-0.3
-60 -40 -20 0
20 40 60
0.6
-40 -20 0 20 40 60 80 100 ˚C 140
˚C 100
Tj
Tj
Cx, Cy = f(Tj); IF = 30 mA
6) page 25
OHL03717
0.006
∆ Cx, ∆ Cy
∆Cy
0.004
0.003
0.002
0.001
∆ Cx
-0.001
-0.002
-0.003
-0.004
Tj
2014-04-04
14
LCW E6SG
Max. Permissible Forward Current
Max. zulässiger Durchlassstrom
IF = f (T)
IF
OHL01362
60
mA
50
40
TA
TS
30
TA temp. ambient
TS temp. solder point
60
80
100 ˚C 120
T
Permissible Pulse Handling Capability
Zulässige Impulsbelastbarkeit IF = f(tp)
D: Duty cycle, TS = 85 °C
D: Duty cycle, TS = 25 °C
0.35
IF A
0.25
0.20
0.15
OHL01503
t
D = TP
0.35
IF A
tP
IF
T
D=
0.25
0.005
0.01
0.02
0.05
0.1
0.2
0.5
1
0.20
0.15
0.10
0.10
0.05
0.05
0 -5
10 10-4 10-3 10-2 10-1 100 101 s 102
t
D = TP
IF
T
D=
0.005
0.01
0.02
0.05
0.1
0.2
0.5
1
0 -5
tp
2014-04-04
OHL01503
tP
tp
15
LCW E6SG
Package Outline 8) page 25
Maßzeichnung 8) Seite 25
Approximate Weight:
30 mg
Gewicht:
30 mg
Mark:
bevelled edge (Cathode)
Markierung:
abgeschrägte Ecke (Kathode)
2014-04-04
16
LCW E6SG
Recommended Solder Pad 8) page 25
Empfohlenes Lötpaddesign 8) Seite 25
Reflow soldering
Reflow-Löten
Fläche darf bei Verwendung von TOPLED®
elektrisch nicht beschaltet werden.
For TOPLED® assembly do not use
this area for electrical contact
Padgeometrie für
verbesserte Wärmeableitung
Paddesign for
improved heat dissipation
3.3 (0.130)
3.3 (0.130)
Anode
2.3 (0.091)
11.1 (0.437)
1.5 (0.059)
1.1 (0.043)
3.7 (0.146)
0.8 (0.031)
0.7 (0.028)
Kathode/
Cathode
Cu Fläche /
re
ope e
Mo
see
istu
k,
is
or .
sea is has k,
Mo
bef
istu
d
033
Mo
in
Flo
RH
blan
Mo
or-p blan in
bag
Car
ing,
r
TDlife
(if
If with
t.
r
lf
10%bak or
J-S
thisvapp.
Yea
_
eks rs
r
ed
icat med, C
1
Yea
tem
She
ow,
at
uire not
y
1
WeHou
unt
DE
Afte
Ind
4
uire
refl
is
red req
bod Mo
/JE
time
168
req
2b
a)
Sto ices idity
time
or
is IPC
or
time
b)
ned Flo
or
Hum ing ce
time
or
Dev 2a
e
Flo
a)
ope
or
3.
b) bakren
Flo
1
l dat
Flo
If
2
refe
time el
2a
4.
el
sea
3
Lev
el
and
Lev
el
re
Bag
e
Lev
re
Lev
istu
Dat
re
istu
re
Mo
istu
Mo
istu
Mo
Mo
A
C
1.
2.
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
AM
Desiccant
OSR
OHA00539
Note:
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card.
Regarding dry pack you will find further information in the internet and in the Short Form Catalog in
chapter “Tape and Reel” under the topic “Dry Pack”. Here you will also find the normative references
like JEDEC.
Anm.:
Feuchteempfindliche Produkte sind verpackt in einem Trockenbeutel zusammen mit einem
Trockenmittel und einer Feuchteindikatorkarte.
Bezüglich Trockenverpackung finden Sie weitere Hinweise im Internet und in unserem Short Form
Catalog im Kapitel “Gurtung und Verpackung” unter dem Punkt “Trockenverpackung”. Hier sind
Normenbezüge, unter anderem ein Auszug der JEDEC-Norm, enthalten.
2014-04-04
21
LCW E6SG
Transportation Packing and Materials
Kartonverpackung und Materialien
Barcode label
DE
MY
8
1
T6
PL 76
R1
Q-
lti LS
TO Y
1+
POU
GR
(G)
Mu
: 01
(9D
D/C
21
00
21
99
8
4
Y:
23
LO
(X)
PR
OD
NO
11
00
(1T
QT
(Q)
H
Se
3G
H1
BA
TC
: 12
(6P
5
NO
T
14
2
O
SR
mi AM
co
nd O
uc pt
to o
rs
NO
see
labe
44
l
k,
N
O
TI
U
A
C
00
L
VE
LE
code (RH
blan
If
y
bar
idit
RH
hum
60%
e
tive d
˚C/
kag
rela are
30
E S
s
_
infr pac
OR
of
tainITIV
90% to ak
urs
CT
e).
or
urs
ted (pe
ons
con NS
Ho
g
urs
SE DU
Ho
and jec
diti
cod
˚C,
72
sin
Ho urs
e
5
bag E ON
48
˚C sub
e
Ho
con
s UR
ces
24 6
dat
e
MIC
40 be
tim
˚C
e
ThiISTSE
pro
tory
tim
or
t
with
23
tim e
at t will ˚C)
or
fac
MO
Flo
al
len
tim
s
TO
at
or
at
Flo
d
or
iva
ure
el
nth s tha
OP
ntic
Flo
4
if: rea
Flo
lab
ow
mo ice equ
ide
5
ced
el
e
5a
is
el
ingen
bel
or
24
pro
6
Lev
e
dev,
el
cod
e
unt wh
Lev
el
re
ow
see
bag
Lev
l dat
re
mo
bak
e
bar
ned
Lev
refl
istu
10%
re
tim
sea
for
istu
ore>
re
ope e
Mo
see
3
istu
is
or .
sea is has
Mo
nk,
bef
istu
nk, Flo
rd
-03
Mo
in
RH
bla
Mo
or-p bla in
bag
ingCa
r
TD
life
(if
If with
t.
r
lf
vapp.
10%baktor
J-S
this
Yea
_
eks
r
ed
ica med, C
1
urs
Yea
tem
She
ow
at
uire not
y
1
WeHo
unt
DE
Afte
Ind
1.
e
4
uire
refl
red req
2.
bod Mo
e
ity is
/JE
tim
s
168
req
e
2b
a)
Sto
tim
or
mid
is IPC
tim e
vice or
b)
ned Flo
or
Hu
tim
ing ce
or
De
e
2a
Flo
a)
ope
or
3.
b) bakren
Flo
e
1
l dat
Flo
If
2
el
refe
tim
2a
4.
el
sea
3
Lev
el
and
Lev
el
re
Bag
te
Lev
re
Lev
istu
Da
re
istu
re
Mo
istu
Mo
istu
Mo
Mo
P:
Muster
ED Bin
Bin 1:
Bin 2: P-1
3: Q-1 -20
ML
-20
2
Tem
2a
220
3
240 p ST
Ad 260 C R
C
R0 diti
R
ona C RT
PA 77
l TE
CK
VA
XT
R:
Barcode label
DE
MY
1
T6
PL 76
R1
8
lti LS
TO Y
Mu
1+
Q-
P:
PGR
(G)
44
: 01
D/C
(9D
QT
Y:
LO
(1T
OD
NO
M
RA
OS
(X)
PR
5
14 2
110 0
(Q)
ico AM
nd O
uc pt
to o
rs
SR
NO
23
4
m
O
H
H1
Se
3G
TC
998
NO
: 12
BA
021
T
(6P
210
OU
Muster
ED Bin
Bin 1:
Bin 2: P-1
3: Q-1 -20
ML
-20
2
Te
2a
220 mp
3
240
ST
Ad 260 C R
C
R0 diti
R
ona C RT
PA 77
l TE
CK
VA
XT
R:
led
Packing
Sealing label
OHA02044
Dimensions of transportation box in mm (inch):
Width / Breite
Length / Länge
Height / Höhe
200 ± 5 (7.874 ± 0.196)
195 ± 5 (7.677 ± 0.1968)
30 ± 5 (1.181 ± 0.196)
2014-04-04
22
LCW E6SG
Notes
Hinweise
The evaluation of eye safety occurs according to the
standard IEC 62471:2008 ("photobiological safety of
lamps and lamp systems"). Within the risk grouping
system of this CIE standard, the LED specified in this
data sheet fall into the class Exempt group
(exposure time 10000 s). Under real circumstances
(for exposure time, eye pupils, observation
distance), it is assumed that no endangerment to the
eye exists from these devices. As a matter of
principle, however, it should be mentioned that
intense light sources have a high secondary
exposure potential due to their blinding effect. As is
also true when viewing other bright light sources
(e.g. headlights), temporary reduction in visual
acuity and afterimages can occur, leading to
irritation, annoyance, visual impairment, and even
accidents, depending on the situation.
Die Bewertung der Augensicherheit erfolgt nach
dem Standard IEC 62471:2008 ("photobiological
safety of lamps and lamp systems"). Im
Risikogruppensystem dieser CIE- Norm erfüllen die
in diesem Datenblatt angegebenen LEDs folgende
Gruppenanforderung - Exempt group
(Expositionsdauer 10000 s). Unter realen
Umständen (für Expositionsdauer, Augenpupille,
Betrachtungsabstand) geht damit von diesen
Bauelementen keinerlei Augengefährdung aus.
Grundsätzlich sollte jedoch erwähnt werden, dass
intensive Lichtquellen durch ihre Blendwirkung ein
hohes sekundäres Gefahrenpotenzial besitzen.
Nach einem Blick in eine helle Lichtquelle (z.B.
Autoscheinwerfer), kann ein temporär
eingeschränktes Sehvermögen oder auch
Nachbilder zu Irritationen, Belästigungen,
Beeinträchtigungen oder sogar Unfällen führen.
Subcomponents of this LED are silverplated. Silver
is discoloring when being exposed to environments
containing high concentrations of aggressive
substances. Corroded silver may lead to a
worsening of the optical performance of the LED and
can in the worst case lead to a failure of the LED. Do
not expose this LED to aggressive atmospheres.
Note, that corrosive gases may as well be emitted
from materials close to the LED in the final product.
Einzelkomponenten dieser LED sind
silberbeschichtet. Silberoberflächen werden durch
korrosive Substanzen verändert. Korrodiertes Silber
kann zu einer Verschlechterung der optischen
Eigenschaften und im schlimmsten Fall zum Ausfall
der LED führen. Diese LED darf aggressiven
Bedingungen nicht ausgesetzt werden. Es ist zu
beachten, dass korrosive Gase auch von
Materialien emittiert werden können, die sich im
Endprodukt in unmittelbarer Umgebung der LED
befinden.
For further application related informations
please visit www.osram-os.com/appnotes
Für weitere applikationsspezifische
Informationen besuchen Sie bitte
2014-04-04
23
LCW E6SG
Disclaimer
Disclaimer
Attention please!
The information describes the type of component and
shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved.
Due to technical requirements components may contain
dangerous substances.
For information on the types in question please contact
our Sales Organization.
If printed or downloaded, please find the latest version in
the Internet.
Packing
Please use the recycling operators known to you. We
can also help you – get in touch with your nearest sales
office.
By agreement we will take packing material back, if it is
sorted. You must bear the costs of transport. For
packing material that is returned to us unsorted or which
we are not obliged to accept, we shall have to invoice
you for any costs incurred.
Components used in life-support devices or
systems must be expressly authorized for such
purpose!
Critical components* may only be used in life-support
devices** or systems with the express written approval
of OSRAM OS.
Bitte beachten!
Lieferbedingungen und Änderungen im Design
vorbehalten. Aufgrund technischer Anforderungen
können die Bauteile Gefahrstoffe enthalten. Für weitere
Informationen zu gewünschten Bauteilen, wenden Sie
sich bitte an unseren Vertrieb. Falls Sie dieses
Datenblatt ausgedruckt oder heruntergeladen haben,
finden Sie die aktuellste Version im Internet.
Verpackung
Benutzen Sie bitte die Ihnen bekannten Recyclingwege.
Wenn diese nicht bekannt sein sollten, wenden Sie sich
bitte an das nächstgelegene Vertriebsbüro. Wir nehmen
das Verpackungsmaterial zurück, falls dies vereinbart
wurde und das Material sortiert ist. Sie tragen die
Transportkosten. Für Verpackungsmaterial, das
unsortiert an uns zurückgeschickt wird oder das wir nicht
annehmen müssen, stellen wir Ihnen die anfallenden
Kosten in Rechnung.
Bauteile, die in lebenserhaltenden Apparaten und
Systemen eingesetzt werden, müssen für diese
Zwecke ausdrücklich zugelassen sein!
Kritische Bauteile* dürfen in lebenserhaltenden
Apparaten und Systemen** nur dann eingesetzt
werden, wenn ein schriftliches Einverständnis von
OSRAM OS vorliegt.
*) A critical component is a component used in a
life-support device or system whose failure can
reasonably be expected to cause the failure of that
life-support device or system, or to affect its safety or the
effectiveness of that device or system.
**) Life support devices or systems are intended (a) to be
implanted in the human body, or (b) to support and/or
maintain and sustain human life. If they fail, it is
reasonable to assume that the health and the life of the
user may be endangered.
*) Ein kritisches Bauteil ist ein Bauteil, das in
lebenserhaltenden
Apparaten
oder
Systemen
eingesetzt wird und dessen Defekt voraussichtlich zu
einer Fehlfunktion dieses lebenserhaltenden Apparates
oder Systems führen wird oder die Sicherheit oder
Effektivität
dieses
Apparates
oder
Systems
beeinträchtigt.
**) Lebenserhaltende Apparate oder Systeme sind für
(a) die Implantierung in den menschlichen Körper oder
(b) für die Lebenserhaltung bestimmt. Falls Sie
versagen, kann davon ausgegangen werden, dass die
Gesundheit und das Leben des Patienten in Gefahr ist.
2014-04-04
24
LCW E6SG
Glossary
Glossar
1)
Brightness: Brightness values are measured during
a current pulse of typically 25 ms, with an internal
reproducibility of ± 8 % and an expanded uncertainty
of ± 11 % (acc. to GUM with a coverage factor of
k = 3).
1)
Helligkeit: Helligkeitswerte werden während eines
Strompulses einer typischen Dauer von 25 ms, mit
einer internen Reproduzierbarkeit von ± 8 % und
einer erweiterten Messunsicherheit von ± 11 %
gemessen (gemäß GUM mit Erweiterungsfaktor
k = 3).
2)
Chromaticity coordinate groups: Chromaticity
coordinates are measured during a current pulse of
typically 25 ms, with an internal reproducibility of
± 0.005 and an expanded uncertainty of ± 0.01 (acc.
to GUM with a coverage factor of k = 3).
2)
Farbortgruppen: Farbkoordinaten werden während
eines Strompulses einer typischen Dauer von 25 ms,
mit einer internen Reproduzierbarkeit von ± 0,005
und einer erweiterten Messunsicherheit von ± 0,01
k = 3).
3)
Forward Voltage: The forward voltage is measured
during a current pulse of typically 8 ms, with an
internal reproducibility of ± 0.05 V and an expanded
uncertainty of ± 0.1 V (acc. to GUM with a coverage
factor of k = 3).
3)
Durchlassspannung: Vorwärtsspannungen
werden während eines Strompulses einer typischen
Dauer
von
8 ms,
mit
einer
internen
Reproduzierbarkeit von ± 0,05 V und einer
erweiterten Messunsicherheit von ± 0,1 V gemessen
(gemäß GUM mit Erweiterungsfaktor k = 3).
4)
Thermal Resistance: RthJA results from mounting
on PC board FR 4 (pad size 16mm² per pad)
4)
Wärmewiderstand: RthJA ergibt sich bei Montage
auf PC-Board FR 4 (Padgröße 16mm² je pad)
5)
Thermal Resistance: Rth max is based on statistic
values (6σ).
5)
statistischen Werten (6σ).
6)
Typical Values: Due to the special conditions of the
manufacturing processes of LED, the typical data or
calculated correlations of technical parameters can
only reflect statistical figures. These do not
necessarily correspond to the actual parameters of
each single product, which could differ from the
typical data and calculated correlations or the typical
characteristic line. If requested, e.g. because of
technical improvements, these typ. data will be
changed without any further notice.
6)
Typische Werte: Wegen
der
besonderen
Prozessbedingungen bei der Herstellung von LED
können typische oder abgeleitete technische
Parameter nur aufgrund statistischer Werte
wiedergegeben werden. Diese stimmen nicht
notwendigerweise mit den Werten jedes einzelnen
Produktes überein, dessen Werte sich von typischen
und abgeleiteten Werten oder typischen Kennlinien
unterscheiden können. Falls erforderlich, z.B.
aufgrund technischer Verbesserungen, werden
diese typischen Werte ohne weitere Ankündigung
geändert.
7)
Relative Brightness Curve: In the range where the
line of the graph is broken, you must expect higher
brightness differences between single LEDs within
one packing unit.
7)
Relative Helligkeitskurve: Im
gestrichelten
Bereich der Kennlinien muss mit erhöhten
Helligkeitsunterschieden zwischen Leuchtdioden
innerhalb einer Verpackungseinheit gerechnet
werden.
8)
Tolerance of Measure: Unless otherwise noted in
drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
8)
Maßtoleranz: Wenn in der Zeichnung nicht anders
angegeben, gilt eine Toleranz von ±0,1. Maße
werden in mm angegeben.
2014-04-04
25
max
basiert
auf
LCW E6SG
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
2014-04-04
26
