DATA SHEET
THICK FILM CHIP RESISTORS
Precision grade
RE series
0.1%, 0.5%, 1%, TC 50
sizes 0201/0402/0603/0805/1206
Product specification – June 01, 2017 V.6
RoHS compliant & Halogen Free
Chip Resistor Surface Mount
RE
2
7
0201 to 1206
SERIES
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC
This specification describes
RE0201 to RE1206 ultra precision
chip resistors with lead-free
terminations made by thick film
process.
Both part numbers are identified by the series, size, tolerance, packing
type, temperature coefficient, taping reel and resistance value.
YAGEO BRAND ordering code
GLOBAL PART NUMBER (PREFERRED )
RE XXXX X X X XX XXXX L
APPLICATIONS
Converters
Printer equipment
Server board
Telecom
Consumer
FEATURES
Halogen Free Epoxy
RoHS compliant
Reducing environmentally
hazardous wastes
High component and equipment
reliability
Non-forbidden material used in
products/production
Moisture sensitivity level: MSL 1
(1)
(2) (3) (4)
(5)
(6)
(7)
(1) SIZE
0201 / 0402 / 0603 / 0805 / 1206
(2) TOLERANCE
B = ± 0.1%
D = ± 0.5%
F = ± 1%
(3) PACKAGING TYPE
R = Paper/PE taping reel
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
E = ± 50 ppm/°C
(5) TAPING REEL
07 = 7 inch dia. Reel
10 = 10 inch dia. Reel
13 = 13 inch dia. Reel
(6) RESISTANCE VALUE
There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point, no need
to mention the last zero after R/K/M, e.g.1K2, not 1K20.
Detailed resistance rules show in table of “Resistance rule of global part number”.
(7) DEFAULT CODE
Letter L is system default code for order only (Note)
number
Resistance code rule
Example
XXRX
(10 to 97.6 Ω)
10R = 10 Ω
97R6 = 97.6 Ω
XXXR
(100 to 976 Ω)
100R = 100 Ω
XKXX
(1 to 9.76 KΩ)
1K = 1,000 Ω
9K76 = 9760 Ω
XMXX
(1 MΩ)
1M = 1,000,000 Ω
O RDERING EXAMPLE
The ordering code of a RE0603
chip resistor, TC 50 value 56Ω with
±0.5% tolerance, supplied in 7-inch
tape reel is: RE0603DRE0756RL.
NOTE
1. All our R-Chip products meet RoHS
compliant and Halogen Free. "LFP" of
the internal 2D reel label mentions
"Lead Free Process"
2. On customized label, "LFP" or specific
symbol can be printed
www.yageo.com
Jun. 01, 2017 V.6
RE
3
7
0201 to 1206
SERIES
MARKING
RE0805 / RE1206
Either resistance in E-24 or E-96: 4 digits
00
Fig. 1 Value = 10 kΩ
First three digits for significant figure and 4th digit for number of zeros
RE0603
1%, 0.5%, 0.1% E24 exception values 10/11/13/15/20/75 of E24 series
Fig. 2 Value = 24 Ω
1%, 0.5%, 0.1% E96 refer to EIA-96 marking method, including values
Fig. 3 Value = 12.4 kΩ
RE0201/0402
No marking
Fig. 4
For further marking information, please see special data sheet “Chip resistors marking”.
CONSTRUCTION
The resistors are constructed out of a high-grade ceramic
body. Internal metal electrodes are added at each end and
connected by a resistive layer. The resistive layer is adjusted
to give the approximate required resistance and laser cutting
of this resistive layer that achieves tolerance trims the value.
The resistive layer is covered with a protective coat and
printed with the resistance value. Finally, the two external
terminations (matte tin) are added. See fig. 5.
OUTLINES
For dimension see Table 1
DIMENSION
Table 1 For outlines see fig. 5
TYPE
L (mm)
W (mm)
H (mm)
RE0201 0.60 ± 0.03 0.30 ± 0.03 0.23 ± 0.03
RE0402 1.00 ± 0.05 0.50 ± 0.05 0.32 ± 0.05
RE0603 1.60 ± 0.10 0.80 ± 0.10 0.45 ± 0.10
RE0805 2.00 ± 0.10 1.25 ± 0.10 0.50 ± 0.10
I1 (mm)
I2 (mm)
0.10 ± 0.05 0.15 ± 0.05
0.20 ± 0.10 0.25 ± 0.10
0.25 ± 0.15 0.25 ± 0.15
0.35 ± 0.20 0.35 ± 0.20
RE1206 3.10 ± 0.10 1.60 ± 0.10 0.55 ± 0.10 0.45 ± 0.20 0.40 ± 0.20
Fig. 5 Chip resistor outlines
www.yageo.com
Jun. 01, 2017 V.6
RE
SERIES
4
7
0201 to 1206
ELECTRICAL CHARACTERISTICS
Table 2
RESISTANCE
RANGE
TYPE
(E24/E96)
OPERATING
TEMPERATURE RANGE
MAXIMUM
WORKING
RATING VOLTAGE
POWER
DIELECTRIC
WITHSTAND
VOLTAGE
MAXIMUM
OVERLOAD
VOLTAGE
TEMPERATURE
COEFFICIENT OF
RESISTANCE
RE0201
100 Ω to 1 MΩ
–55 °C to +155 °C
1/20W
25 V
50 V
50 V
± 50 ppm/°C
RE0402
10 Ω to 1 MΩ
–55 °C to +155 °C
1/16 W
50 V
100 V
100 V
± 50 ppm/°C
RE0603
10 Ω to 1 MΩ
–55 °C to +155 °C
1/10 W
75 V
150 V
150 V
± 50 ppm/°C
RE0805
10 Ω to 1 MΩ
–55 °C to +155 °C
1/8 W
150 V
300 V
300 V
± 50 ppm/°C
RE1206
10 Ω to 1 MΩ
–55 °C to +155 °C
1/4 W
200 V
500 V
400 V
± 50 ppm/°C
NOTE
The maximum working voltage that may be continuously applied to the resistor element, see “IEC publication 60115-8”
FOOTPRINT AND SOLDERING PROFILES
For recommended footprint and soldering profiles, please see the special data sheet “Chip resistors mounting”.
PACKING STYLE AND PACKAGING QUANTITY
Table 3 Packing style and packaging quantity
PACKING STYLE
REEL DIMENSION
Paper/PE taping reel (R)
RE0201
RE0402
RE0603
RE0805
RE1206
7" (178 mm)
10,000
10,000
5,000
5,000
5,000
10" (254 mm)
20,000
20,000
10,000
10,000
10,000
13" (330 mm)
50,000
50,000
20,000
20,000
20,000
NOTE
1. For Paper/PE tape and reel specification/dimensions, please see the special data sheet “Chip resistors packing”
FUNCTIONAL DESCRIPTION
POWER RATING
Each type rated power at 70°C:
RE0201=1/20W, RE0402=1/16W, RE0603=1/10 W,
RE0805=1/8 W, RE1206=1/4W
R ATED VOLTAGE
The DC or AC (rms) continuous working voltage
corresponding to the rated power is determined by
the following formula:
V=√(P X R)
or max. working voltage whichever is less
Where
Fig. 6 Maximum dissipation (P) in percentage of rated power as a
function of the operating ambient temperature (T amb )
V=Continuous rated DC or
AC (rms) working voltage (V)
P=Rated power (W)
R=Resistance value (Ω )
www.yageo.com
Jun. 01, 2017 V.6
RE
SERIES
5
7
0201 to 1206
TESTS AND REQUIREMENTS
Table 4 Test condition, procedure and requirements
TEST
TEST METHOD
PROCEDURE
Life/Endurance
IEC 60115-1 4.25.1
REQUIREMENTS
MIL-STD-202 Method 108A
At 70± 2 °C for 1,000 hours, RCWV applied for ± (3%+0.05 Ω)
1.5 hours on, 0.5 hour off, still air required
High
Temperature
Exposure
IEC 60068-2-2
1,000 hours at 155± 5 °C, unpowered
± (3%+0.05 Ω)
Moisture
Resistance
MIL-STD-202 Method 106G
Each temperature / humidity cycle is defined at 8
hours, 3 cycles / 24 hours for 10d. with 25 °C /
65 °C 95% R.H, without steps 7a & 7b,
unpowered
± (3%+0.05 Ω)
Parts mounted on test-boards, without
condensation on parts
Measurement at 24± 2 hours after
test conclusion
Thermal Shock
MIL-STD-202 Method 107G
-55/+125 °C
Number of cycles required is 300.
± (1%+0.05 Ω)
Devices mounted
Maximum transfer time is 20 seconds. Dwell time
is 15 minutes. Air – Air
Short Time
Overload
IEC60115-1 4.13
Board Flex/
Bending
IEC 60115-1 4.33
2.5 times of rated voltage or maximum overload
voltage whichever is less for 5 sec at room
temperature
± (1%+0.05 Ω)
Chips mounted on a 90mm glass epoxy resin
PCB (FR4)
± (1%+0.05 Ω)
No visible damage
No visible damage
Bending: see table 5 for each size
Bending time: 60± 5 seconds
www.yageo.com
Jun. 01, 2017 V.6
RE
SERIES
6
7
0201 to 1206
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Humidity
IEC 60115-1 4.24.2
Steady state for 1000 hours at 40 °C / 95% ± (3%+0.05 Ω )
R.H. RCWV applied for 1.5 hours on and 0.5
hour off
Solderability
- Wetting
J-STD-002 test B
Electrical Test not required
Well tinned (≥95% covered)
No visible damage
Magnification 50X
SMD conditions:
1st step: method B, aging 4 hours at 155°C
dry heat
2nd step: leadfree solder bath at 245± 3°C
Dipping time: 3± 0.5 seconds
- Leaching
- Resistance to
Soldering Heat
J-STD-002 test D
Leadfree solder, 260 °C, 30 seconds
immersion time
No visible damage
IEC 60115-1 4.18
Condition B, no pre-heat of samples.
Leadfree solder, 260 °C, 10 seconds
immersion time
Procedure 2 for SMD: devices fluxed and
cleaned with isopropanol
± (1%+0.05 Ω)
No visible damage
Table 5 Bending for sizes 0201 to 1206
TYPE
Specification (mm)
RE0201
RE0402
RE0603
RE0805
RE1206
5
5
3
3
2
www.yageo.com
Jun. 01, 2017 V.6
RE
SERIES
7
7
0201 to 1206
REVISION HISTORY
REVISION DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 6
May 31, 2017
-Add 10" packing
Version 5
Feb 24, 2017
-Delete 125℃ in derating curve
Version 4
May 03, 2016
-Update 0201 resistor value
Version 3
Jan. 26, 2015
- Update Working Voltage
Version 2
May 11, 2015
- Update test and requirements
Version 1
Jan 23, 2014
- Add RE0201
- Add 0.1%
- Update TEST AND REQUIREMENTS, add Humidity test
Version 0
Dec 10, 2010
- New datasheet for thick film ultra precision chip resistors sizes of
0402/0603/0805/1206, 0.5%, 1%, TC50 with lead-free terminations
“ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itself are unchanged. Any
product change will be announced by PCN.”
www.yageo.com
Jun. 01, 2017 V.6
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
YAGEO:
RE0805FRE078K45L RE0402DRE076K2L RE0402DRE07270RL RE0805FRE07196KL RE0402DRE0713KL
RE0402DRE071K1L RE1206FRE071K5L RE0603DRE077K5L RE0402FRE07200KL RE0402DRE071K8L
RE0402DRE0739KL RE0402DRE07110KL RE0402DRE07180RL RE0603DRE076K8L RE0402BRE072K87L
RE0402DRE075K6L RE0603DRE0749R9L RE0805FRE073K9L RE0805FRE07200KL RE0402DRE072K4L
RE0402DRE07665RL RE0805FRE07150KL RE0402DRE07100RL RE0402DRE071KL RE0603DRE0710KL
RE0603DRE0733KL RE0402DRE07301RL RE0603FRE071KL RE0805FRE07100KL RE0402DRE0736KL
RE0603DRE07150KL RE0402DRE0747KL RE0805FRE078K2L RE0603DRE073K9L RE0402DRE0711KL
RE0805FRE074K7L RE0402DRE0720KL RE1206FRE07100KL RE0402DRE071K3L RE0402DRE07953RL
RE0402DRE0722KL RE0402BRE074K75L RE0402DRE07330RL RE0402DRE0756KL RE0402DRE07430RL
RE0603DRE0720KL RE0805FRE0733KL RE0603DRE071K5L RE0402DRE07845RL RE0402DRE0724KL
RE0603DRE071K05L RE0402DRE07470KL RE0603DRE0782KL RE0402DRE07750RL RE0603DRE07100KL
RE0402DRE0768KL RE0805FRE0718KL RE0402DRE077K87L RE0805FRE0722KL RE0603DRE071K3L
RE0402DRE0724K9L RE0402DRE07196RL RE0805FRE073K3L RE0402DRE07270KL RE0603DRE071KL
RE0603DRE0747KL RE0402DRE07300RL RE0603DRE075K1L RE0603FRE0782KL RE0402DRE076K8L
RE0402BRE07470KL RE0402DRE07360KL RE0805FRE0714KL RE0402DRE07100KL RE0603DRE072K8L
RE1206FRE0727RL RE0402BRE07158KL RE0603FRE0710KL RE0603DRE073K3L RE0603DRE0712KL
RE0402DRE07200RL RE0402DRE073K9L RE0603DRE07820RL RE0603DRE0768KL RE0805FRE071KL
RE0402DRE078K2L RE0603DRE0718KL RE0603DRE072KL RE0805FRE07332RL RE0402DRE0782KL
RE1206DRE0710RL RE0402DRE07560RL RE0402DRE075K1L RE0402DRE0744K2L RE0402DRE07220RL
RE0603DRE074K99L RE0603DRE0727KL RE0603DRE0724KL RE0805FRE07220KL RE0402DRE0715KL
