WMZ12A-75S222NUP600B3.5-G5B
    TYOHM(幸亚电阻)
    插件,P=5mm
    PTC热敏电阻 2.2KΩ ±30% 电源电压 220V PTC_D4.8X4.8MM_TM
WMZ12A-75S222NUP600B3.5-G5B 数据手册
Spec. No.20191224 Page (s): 1/4 Model No: PTC THERMISTOR Part No.: WMZ12A Series Rev: 0/A(Dec. 24th.2019) 1. APPEARANCE 外观 1-2. Marking 标志 ■ □ No marking 1-3.Coating 包封 □ No coating 无包封 ■ Coating 包封 Material 包封材料 ■PF resin 酚醛树脂 ■Silicon 硅树脂 ■Epoxy 改良树脂 ■Others 其他 1-1. Dimensions (mm)尺寸 See WMZ12A series Spec. Table attached 参见所附 WMZ12A 系列规格表 Color 颜色 ■Green 绿色 ■Red 红色 ■Tan 黄色 ■Black 黑色 ■Blue 兰色 1-4. Leads 引线 Tin-plated copper wire 镀锡铜线 Tin-plated steel wire 镀锡钢线 Straight 直线 Axis Formed 轴弯 In-Forming 内弯 2. RATINGS 额定参数 2-1. Rated Operating Voltage 额定工作电压 UR: 220Vrms 2-2. Max Working Voltage 最大工作电压 Umax:265Vrms 2-3. Max Working Current 最大工作电流 Imax: 0.1~2.0A 2-4. Operating Temperature 工作温度: -40℃~+85℃ (U=0) -40℃~+85℃ (U=Umax) 3. MECHANICAL CHARACTERISTICS 机械性能 Specification Test Conditions & Methods Item 指标项目 技术要求 测试条件/方法 Dipping the PTC terminals to a depth of 15mm in a soldering bath of 245℃±5℃ and to the place of 6mm far The terminals shall be uniformly tinned, and its from PTC body for 3±0.5s (See IEC68-2-20 /GB2423.28 Ta ) area≥95% 3-1. Solder-ability 可焊性 将引出端沾助焊剂后,浸入到温度为 245℃±5℃、深度为 浸润部分上锡均匀, 上锡面积≥95% 15mm 的锡槽中锡面距 PTC 本体下端 6mm 处,持续 3±0.5 秒。(参见 IEC68-2-20 /GB2423.28 试验 Ta) Dipping the terminals to a depth of 15mm in a soldering bath of 260℃±5℃ and to the place of 6mm far from PTC body for 3 3-2. Resistance To Soldering Heat 耐焊接热 No visible mechanical ± 0.5s. After recovering for 4~5 hours under normal damage. temperature. The resistance (RN') shall be measured. (See 无可见损伤 IEC68-2-20 /GB2423.28 Tb) ΔR/RN ≤20% 将引出端沾助焊剂后,浸入到温度为 260℃±5℃、深度为 (ΔR =∣RN-RN'∣) 15mm 的锡槽中锡面距 PTC 本体下端 6mm 处,持续 3±0.5 秒。在常温条件下恢复 4~5 小时后,复测额定零功率电阻值 RN'。(参见 IEC68-2-20 /GB2423.28 试验 Tb) Spec. No. 20191224 Page (s): 2/4 Model No: PTC THERMISTOR Rev: 0/A(Dec. 24th.2019) Part No.: WMZ12A Series 3-3. Strength of lead terminal 引出端强度 No break out 无损坏 Fasten the body and apply a force gradually to each lead until 10 N and then keep for 10sec, Hold the body and apply a force to each lead until 90°slowly at 5 N in the direction of lead axis and then keep for 10sec, and do this in the opposite direction repeat for other terminal. (See IEC68-2-21/GB2423.29 Ua / Ub) 根据 IEC68-2-21(GB2423 .29)试验 U 进行试验。 试验 Ua:拉力 10N,持续 10 S; 试验 Ub:弯曲 90°,拉力 5N,连续两次; 试验 Uc:扭转 180℃,连续两次。 在常温常湿条件下恢复 4~5 h 后,复测额定零功率电阻 Rn′ 4. ELECTRICAL CHARACTERISTICS 电气性能 Item 指标项目 Specification 技术要求 4-1. Rated Zero-power Resistance 额定零功率电阻 (RN) 4-2. Curie Temperature 居里温度 (TC) (For information only) 4-3. Non-operating Current The resistance at TC is twice of RN 电阻为零功率电阻的 2 倍时所对应的温度为 TC。 See WMZ12A Series Spec. Table attached 参见所附 WMZ12A 系列 规格表 不动作电流 (IN) Ambient temp. Range 环境温度: 60℃±2℃ In static air 静止空气中 Voltage of power supply 电源电压: 220Vrms. Hold current 电流 65mA Energized time 持续时间: 60min, Resistance (RN') shall be measured Ambient temp. Range 环境温度: 25℃±2℃ In static air 静止空气中 Voltage of power supply 电源电压: 220Vrms. Hold current 电流: 230mA Energized time 持 续 时 间 : 5min, Resistance (RN') shall be measured 4-4. Trip Current 动作电流 (ISW) 4-5. Over-Vol. Withstanding 耐电压能力 (Ub) Test Conditions & Methods 测试条件/方法 Ambient temp. TA: 25℃±2℃ Testing voltage: 1.5VDC After placing for 1~2 hours under TA, the resistance value shall be measured. 环境温度 TA: 25℃±2℃(Tc=50℃时 25℃±1℃) 测试电压: 1.5VDC 在常温 TA 条件下,放置 1~2 小时 后测得阻值 RN。 See WMZ12A Series Spec. Table attached 参见所附 WMZ12A 系列 规格表 ΔR/ RN≤20% (ΔR =∣RN-RN'∣) TA: 25℃±2℃ Initial Current 起始电流 Imax: 0.1~2.0A Test vol. 测试电压: 220Vrms / 10s→Ub/ 10s After recovering for 4~5 hours under normal temperature. The resistance (RN’)shall be measured. 在常温条件下,放置 4~5 小时 后测得阻值 RN Spec. No.20191224 Page (s): 3/4 Model No: Part No.: PTC THERMISTOR Rev: 0/A(Dec. 24th.2019) WMZ12A Series Item 指标项目 Item 指标项目 IL AQL 5-1. Appearance 外观 Ⅱ 1.5 5-4.Over Voltage Withstanding 耐电压能力 8PCS/Lot 0 Ⅱ 0.65 5-5. Solder-ability 可焊性 5PCS/Lot 0 5-2. Rated Zero-power Resistance 额定零功率电阻 (RN) 5-3. Non-operating Current 不动作电流(IN) 5PCS/Lot Ac IL AQL Ac 0 6. NUMBERING SYSTEM AND PACKING 编号方法和包装方式 6-1. Part Numbering 料号编号方法 WMZ12A - 115 B 45R M U P 065 B 3.5 - E 6 B ① ② ③ ④ ⑤ ⑥ ⑦ ⑧ ⑨ ⑩ ⑪ ⑫ ⑬ ① Series 系列:WMZ12A- PTC thermistors for over-current protection 过电流保护系列 PTC 热敏电阻。 ② Curie temperature 居里温度 115: 115℃ (120 : 120℃ 85: 85℃ ……) ③ Diameter 外径 Dmax B:8.5 (A: 6.5mm M: 11.5mm S: 4.5mm L: 5.5mm……) ④ Rated zero power resistance 额定零功率电阻(RN) 35R:35Ω ( 401: 400Ω; 202: 2KΩ 153:10KΩ … ) ⑤ ⑥ ⑦ ⑧ ⑨ ⑩ ⑪ Tolerance 电阻允差 X:Else 其它(M: ±20% N:±30% V: ±25% P: ±50% ; …… ) Leads form 引线形状 A: Axis wind 轴弯(U: Inside kink 内弯 S: Straight 直形 F: No coating 无包封) Leads 引线材质 P:铜包钢线( U:Tin-plated copper wire 镀锡铜线) Non-operating current 不动作电流 065:65mA 120: 120mA 330: 330mA…… ) Packing Type 包装方式 B: Bulk 散装 ( A: Ammo 条带 C: Reel 盘带 ……) Leads length 引线长度:10: 10.0±1.0mm 3.5: 3.5±0.5mm 5: 5.0±1.0mm 20:20mm(最小值) Coating Material 包封材料:S - Black Silicone 硅树脂 G – Green Silicone 绿色硅树脂 N - No Coating 无包封 P - PF Resin 酚酫树脂 ⑫ Leads Diameter 引线直径:5 – Φ0.5mm ⑬ Leads Distance 引线间距:A – 2.5mm E - Epoxy 环氧树脂 6 – Φ0.6mm B – 5.0mm 8 – Φ0.8mm C – 7.5mm 1 – Φ1.0mm D –10.0mm 6-2.Lot Numbering 批号编号方法 115 B A 1407226 1/2 ① ② ③ ④ ⑤ ① Curie temperature 居里温度 115: 115℃( 105 : 105℃ 85: 85℃ ……). ② Diameter 外径 Dmax B : 8.5mm (M: 11.5mm S: 4.5mm L: 5.5mm……). ③ Series 系列:WMZ12A- PTC thermistors for over-current protection 过电流保护系列 PTC 热敏电阻。 ④ Pipelined batch number 流水批号: 1407226 : ⑤ Shipment branch card batch number 分卡号:1/2 ; Spec. No. 20191224 Page (s): 4/4 Model No: PTC THERMISTOR Rev: 0/A(Dec. 24th.2019) Part No.: WMZ12A Series 6-3. PACKING TYPE 包装方式 ■ Bulk ■ Ammo ■ Reel Pcs / Bag Pcs / Bar Pcs / Reel KPcs, KPcs, KPcs, × × × × × × mm, mm, mm, Kg/Ctn Kg/Ctn Kg/Ctn 7. STORAGE CONDITIONS 贮存环境条件 7-1.Temperature 温度: -10℃~+40℃ 7-2. Humidity 湿度: ≤70%RH 7-2. Term 期限: ≤6 months (First-in/ First-out 先进先出) 7-3. Place 地点: Do not exposing PTC components to the following conditions, otherwise, it may result to deterioration of characteristics. 不要暴露在下列环境条件下,否则将导致性能衰退或参数飘移: 1) Corrosive gas or deoxidizing gas. 腐蚀性或易氧化气体 2) Flammable and explosive gases. 易燃易爆气体 3) Oil, water and chemical liquid. 油、水和化学溶液 4) Under the sunlight. 太阳光下 7-4. Handling after seal open 开封后的处理: After unpacking of the minimum package, reseal it promptly or store it inside a sealed container with a drying agent. 尽量保证开口最小化,立即重新封好,并贮存在密封、带有干燥剂的容器中。 8. WARNING 注意.警告 ! Do not apply the components under the following conditions, otherwise, it may result in deterioration of characteristics, destruction of product or in the worst case, to catching fire. 请不要在下列条件下使用本元件,否则将可能导致产品性能衰退或产品损毁,甚至引发火灾: 1) Exceeding Imax or Vmax. 超过最大工作电流或工作电压 2) Exceeding rated temperature range. 超过许可工作温度范围 3) Inferior thermal dissipation (Due to badly inferior thermal dissipation, some part of the components will become overheated and then be damaged.) 散热不良(由于散热不良,本元件可能因部分过热而导致破坏) ■ SPECIFICATIONS TABLE 规格表 零功率电 商品编 号 商品名称 厂家型号 阻值 居里温 不动作 度 电流 R25(Ω) Tc(℃) IN60(mA) C471723 热敏电阻 WMZ12A-75S70RXSU 50-100 75±7 C471548 热敏电阻 WMZ12A-75S251XSU 200-350 75±7 C471662 热敏电阻 WMZ12A-75S200-350SU 200-350 75±7 C471642 热敏电阻 WMZ12A-75S301MSU 240-360 75±7 C471541 热敏电阻 WMZ12A-75S102XSU 850-1100 75±7 C471708 热敏电阻 WMZ12A-75S880-1100SU 880-1100 75±7 C471537 热敏电阻 WMZ12A-95L22RMUP 22±20% 95±7 C471731 热敏电阻 WMZ12A-85A70RMUU 70±20% 85±7 C471559 热敏电阻 WMZ12A-85A70RMUP 70±20% 85±7 C471545 热敏电阻 WMZ12A-85A30-60AP 30-60 85±7 C471525 热敏电阻 WMZ12A-130A20RMUU 20±20% 130±7 C471532 热敏电阻 WMZ12A-115A200-400AP 200-400 115±7 C471712 热敏电阻 WMZ12A-115A(300-600)AP 300-600 115±7 C471534 热敏电阻 WMZ12A-115A300-600AP 115±7 C471700 热敏电阻 WMZ12A-130A501MSP 500±20% 130±7 C471558 热敏电阻 WMZ12A-115A681XUP 500-800 C471734 热敏电阻 WMZ12A-105A102VAP C471710 热敏电阻 WMZ12A-85B50RMUU 50±20% 85±7 C471720 热敏电阻 WMZ12A-85B70RMUU 70±20% 85±7 C471620 热敏电阻 WMZ12A-105B35RMAU 35±20% 105±7 C471626 热敏电阻 WMZ12A-120B62RMAU 62±20% 120±7 C471760 热敏电阻 WMZ12A-108B35RMAU 35±20% 108±7 C471562 热敏电阻 WMZ12A-120B62RMUU 62±20% 120±7 C471538 热敏电阻 WMZ12A-115B(150-300)AP 150-300 115±7 C471630 热敏电阻 WMZ12A-85LB10RM 10±20% 85±7 C471640 热敏电阻 WMZ12A-85LB20-50 20-50 85±7 C471550 热敏电阻 WMZ12A-85LB50RM 50±20% 85±7 C471526 热敏电阻 WMZ12A-83LB50RM 50±20% 83±7 C471555 热敏电阻 WMZ12A-83LB(30-60) 30-60 83±7 C471669 热敏电阻 WMZ12A-85LB30-60 30-60 85±7 C471530 热敏电阻 WMZ12A-95LB70RMUP 70±20% 95±7 C471716 热敏电阻 WMZ12A-125LB39RMAU 39±20% 125±7 C471627 热敏电阻 WMZ12A-140LB39RNSP 39±30% 140±7 C471711 热敏电阻 WMZ12A-120SL24XUP 18-30 120±7 C471619 压敏电阻 WMZ12A-115SL15RMUP 15±20% 115±7 300-600 外型尺寸 动作电流 耐电压 IT25(mA) Vb(VAC) Dmax ±0.05 F ±1 Tmax d 5.0 4.8 0.5 5.0 5.5 5.0 0.6 5.0 6.5 5.5 0.6 5.0 300 4~20 20~75 400 450 55 160 300 10~90 50~240 420 115±7 1000±25% 105±7 25~70 120~180 300 8.5 5.5 0.6 5.0 25~110 120~300 300 10.5 5.5 0.6 5.0 100~150 300~450 300 15.5 5.5 0.6 5.0 7.5
WMZ12A-75S222NUP600B3.5-G5B 价格&库存
很抱歉,暂时无法提供与“WMZ12A-75S222NUP600B3.5-G5B”相匹配的价格&库存,您可以联系我们找货
