CSR0207FTDT5R10
CSR0207FTDT5R10
    VIKING(光颉)
    AXIAL_D2.2X5.9MM_SM
    贴片电阻 AXIAL_D2.2X5.9MM_SM 5.1Ω ±1% 1W ±50ppm/℃
CSR0207FTDT5R10 数据手册
Data Sheet Customer: Product: Metal Film Precision Resistor-CSR Series Size: 0204/ 0207 Issued Date: 30-Jun-20 Edition: REV.C8 VIKING TECH CORPORATION VIKING TECH CORPORATION KAOHSIUNG BRANCH VIKING ELECTRONICS (WUXI) CO., LTD. ( ) No.70 Guangfu N. Rd., Hukou Township, Hsinchu County 303, Taiwan No.248-3, Sin-Sheng Rd., Cian-Jhen Dist., Kaohsiung, 806, Taiwan TEL:886-3-5972931 FAX:886-3-5972935•886-3-5973494 E-mail:sales@viking.com.tw TEL:886-7-8217999 FAX:886-7-8228229 E-mail:sales@viking.com.tw No.22 Xixia Road, Machinery & Industry Park, National Hi-Tech Industrial Development Zone of Wuxi, Wuxi, Jiangsu Province, China Zip Code:214028 TEL:86-510-85203339 FAX:86-510-85203667•86-510-85203977 E-mail:china@viking.com.tw Produced by (QC) Checked (QC) Approved by (QC) Prepared by (Sales) 30-Jun-20 30-Jun-20 30-Jun-20 30-Jun-20 Susan Huang J.C. Liu J.C. Liu Accepted by (Customer) CSR Series Metal Film Precision Resistor Metal Film Precision Resistor Features Excellent overall stability Tight tolerance down to ±0.1% Extremely low TCR down to ±5 PPM/°C High power rating up to 1 Watts Applications Telecommunication Medical Equipment Measurement/Testing Equipment Construction & Dimension Derating Curve Derating Curve Power ratio (%) . 100  Insulation Coating  Electrode Cap  Trimming Line  Resistor Layer  Ceramic Rod  Marking 80 Except for 5ppm 60 5ppm 40 20 0 0 20 40 60 80 100 120 140 160 Ambient Temperature ( ℃ ) Type L (mm) L1 min. (mm) ΦD (mm) ΦD1 (mm) K (mm) Weight 1,000EA (g) CSR0204 3.50±0.2 1.7 1.40±0.15 D +0/-0.2 0.8±0.1 18.7 CSR0207 5.90±0.2 2.9 2.20±0.20 D +0/-0.2 1.3±0.1 80.9 Part Numbering CSR 0204 D T D Product Dimensions Resistance Packaging TCR Power Type (L×ΦD) Tolerance Code (PPM/°C) Rating 0204: 3.5x1.4 0207: 5.9x2.2 B: ±0.1% C: ±0.25% D: ±0.5% F: ±1% J: ±5% T: Taping Reel S: ±5 B: ±10 N: ±15 C: ±25 D: ±50 E: ±100 - : No Specified V T: 1W U: 1/2W V: 1/4W G: 2/5W ** Letter “R” is a decimal point. www.viking.com.tw For detail questions, contact sales@viking.com.tw 1 1000 Resistance 0010: 1Ω 0100: 10Ω 1000: 100Ω 2201: 2200Ω 1001: 1KΩ 1004: 1MΩ R0R0: 0Ω R050: 0.05Ω R100: 0.1Ω 22R1: 22.1Ω Edition: REV.C8 Revision: 30-Jun-2020 CSR Series Metal Film Precision Resistor Soldering Condition IR Reflow Soldering Wave Soldering (For R>10Ω) (1) Time of IR reflow soldering at maximum temperature point 260C:10s (2) Time of wave soldering at maximum temperature point 260C:10s (3) Time of soldering iron at maximum temperature point 410C:5s Standard Electrical Specifications Item Type 0204 Power Rating at 70 C Operating Temp. Range Max. Operating Voltage Max. Overload Voltage -55 ~ +125C 200V 400V Resistance Range ±0.1% 200V 400V -55 ~ +125C 300V 600V ±1% 10Ω-1MΩ ±5% - 1/4W -55 ~ +155C ±0.5% 10Ω-332KΩ Jumper:2A 0207 ±0.25% ±5 10Ω-20KΩ ±10 10Ω-300KΩ ±15 10Ω-1MΩ 1Ω-1MΩ - 10Ω-332KΩ 1Ω-4.7MΩ 0.2Ω-10MΩ 0.1Ω-10MΩ 0Ω(
CSR0207FTDT5R10
物料型号:CSR Series Metal Film Precision Resistor
器件简介:CSR系列金属膜精密电阻器,由Viking Tech Corporation生产。
引脚分配:文档中未明确提供引脚分配信息,但通常这类电阻器为直插式引脚。
参数特性: - 尺寸:0204/0207 - 发布日期:2017年6月1日 - 版本:REV.C4 - 特点:极佳的整体稳定性、紧密的公差可至±0.1%、极低的温度系数可至±10 PPM/°C、高功率等级可至1瓦特 - 应用:通信、医疗设备、测量/测试设备
功能详解: - 电阻器结构包括绝缘涂层、电极帽、修调线、电阻层、陶瓷棒和标记。 - 电阻器具有优异的稳定性和低温度系数,适用于精密测量和高可靠性要求的应用。 - 提供了电阻值和公差、功率等级、尺寸和TCR(温度系数)的详细规格。
应用信息: - 适用于通信设备、医疗设备和测量测试设备等对电阻稳定性和精度要求较高的领域。
封装信息: - 提供了CSR0204和CSR0207两种尺寸的封装信息,包括重量、直径、中径、长度等尺寸参数。 - 还提供了电阻器的包装数量和卷轴规格。
CSR0207FTDT5R10 价格&库存
很抱歉,暂时无法提供与“CSR0207FTDT5R10”相匹配的价格&库存,您可以联系我们找货
CSR0207FTDT5R10
  • 2000+0.27600
库存:24000
