MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
KY
Low impedance, 105℃
KZH
Series
Lower Z
KZE
・Newly innovative electrolyte is employed to minimize ESR
・Endurance with ripple current : 6,000 to 10,000 hours at 105℃
・Non solvent resistant type
・RoHS2 Compliant
Lower Z
KY
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-40 to +105℃
6.3 to 100Vdc
(at 20℃, 120Hz)
±20% (M)
I=0.01CV or 3µA, whichever is greater.
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
(at 20℃ after 2 minutes)
Rated voltage (Vdc)
6.3V 10V 16V 25V 35V 50V 63V 80V 100V
tanδ (Max.)
0.22 0.19 0.16 0.14 0.12 0.10 0.09 0.09 0.08
When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase.
(at 20℃, 120Hz)
Rated voltage (Vdc)
Z(-25℃)/Z(+20℃)
4
3
2
2
2
2
2
2
2
Z(-40℃)/Z(+20℃)
8
6
4
3
3
3
3
3
3
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated
ripple current is applied (the peak voltage shall not exceed the rated voltage) for the specified period of time at 105℃.
6.3 to 10Vdc
φ10 : 6,000hours φ12.5 to 18 : 8,000hours
Time
16 to 100Vdc
φ10 : 7,000hours φ12.5 to 18 : 10,000hours
Capacitance change
≦±25% of the initial value
D.F. (tanδ)
≦200% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 500 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
D.F. (tanδ)
Leakage current
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
Shelf Life
◆DIMENSIONS [mm]
φd
Sleeve (PET : Brown)
F±0.5
Code : E
F±0.5
●Terminal
φD
φd
φD'
F
φD'
L'
Vent
15min.
4min.
(φ10)
(φ12.5 to φ18)
L'
10 12.5 16
18
0.6 0.6 0.8 0.8
5.0 5.0 7.5 7.5
φD+0.5max.
L+1.5max.
Gas escape end seal
◆PART NUMBERING SYSTEM
1
2
3
4
E KY-
5
6
7
8
E
9
10
11
12
13
14
M
15
16
17
18
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 47µF:470,100µF:101)
Lead forming·taping code
Terminal code
Voltage code (ex. 6.3V:6R3,50V:500)
Series code
Category
Please refer to "Product code guide (radial lead type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001V Ver.3 2021
Low impedance, 105℃
KYSeries
◆STANDARD RATINGS
WV
(Vdc)
Cap
(µF)
Case size
φD×L(mm)
20℃
820
1,200
1,500
1,800
2,200
2,700
2,700
3,300
3,900
3,900
4,700
6.3 5,600
5,600
6,800
6,800
6,800
8,200
10,000
10,000
12,000
12,000
15,000
18,000
680
1,000
1,200
1,500
1,500
2,200
2,200
2,200
2,700
3,300
3,900
10 3,900
4,700
5,600
5,600
5,600
6,800
6,800
8,200
8,200
10,000
10,000
12,000
470
680
1,000
1,000
1,200
1,500
1,500
1,500
2,200
2,200
16 2,700
2,700
3,300
3,900
3,900
3,900
4,700
4,700
5,600
5,600
6,800
10×12.5
10×16
10×20
12.5×15
10×25
10×30
16×15
12.5×20
12.5×25
18×15
12.5×30
12.5×35
16×20
12.5×40
16×25
18×20
16×31.5
16×35.5
18×25
16×40
18×31.5
18×35.5
18×40
10×12.5
10×16
10×20
10×25
12.5×15
10×30
12.5×20
16×15
18×15
12.5×25
12.5×30
16×20
12.5×35
12.5×40
16×25
18×20
16×31.5
18×25
16×35.5
18×31.5
16×40
18×35.5
18×40
10×12.5
10×16
10×20
12.5×15
10×25
10×30
12.5×20
16×15
12.5×25
18×15
12.5×30
16×20
12.5×35
12.5×40
16×25
18×20
16×31.5
18×25
16×35.5
18×31.5
16×40
Rated
ripple
current
(mArms/
-10℃ 105℃,
100kHz)
Impedance
(Ω max./100kHz)
0.080
0.060
0.046
0.049
0.042
0.031
0.042
0.035
0.027
0.043
0.024
0.020
0.027
0.017
0.021
0.026
0.017
0.015
0.019
0.013
0.015
0.014
0.012
0.080
0.060
0.046
0.042
0.049
0.031
0.035
0.042
0.043
0.027
0.024
0.027
0.020
0.017
0.021
0.026
0.017
0.019
0.015
0.015
0.013
0.014
0.012
0.080
0.060
0.046
0.049
0.042
0.031
0.035
0.042
0.027
0.043
0.024
0.027
0.020
0.017
0.021
0.026
0.017
0.019
0.015
0.015
0.013
0.32
0.24
0.18
0.16
0.17
0.12
0.12
0.12
0.089
0.11
0.078
0.065
0.078
0.056
0.060
0.067
0.050
0.044
0.049
0.038
0.040
0.038
0.032
0.32
0.24
0.18
0.17
0.16
0.12
0.12
0.12
0.11
0.089
0.078
0.078
0.065
0.056
0.060
0.067
0.050
0.049
0.044
0.040
0.038
0.038
0.032
0.32
0.24
0.18
0.16
0.17
0.12
0.12
0.12
0.089
0.11
0.078
0.078
0.065
0.056
0.060
0.067
0.050
0.049
0.044
0.040
0.038
865
1,210
1,400
1,450
1,650
1,910
1,940
1,900
2,230
2,210
2,650
2,880
2,530
3,350
2,930
2,860
3,450
3,610
3,140
4,080
4,170
4,220
4,280
865
1,210
1,400
1,650
1,450
1,910
1,900
1,940
2,210
2,230
2,650
2,530
2,880
3,350
2,930
2,860
3,450
3,140
3,610
4,170
4,080
4,220
4,280
865
1,210
1,400
1,450
1,650
1,910
1,900
1,940
2,230
2,210
2,650
2,530
2,880
3,350
2,930
2,860
3,450
3,140
3,610
4,170
4,080
Part No.
WV
(Vdc)
Cap
(µF)
Case size
φD×L(mm)
20℃
EKY-6R3E□□821MJC5S
EKY-6R3E□□122MJ16S
EKY-6R3E□□152MJ20S
EKY-6R3E□□182MK15S
EKY-6R3E□□222MJ25S
EKY-6R3E□□272MJ30S
EKY-6R3E□□272ML15S
EKY-6R3E□□332MK20S
EKY-6R3E□□392MK25S
EKY-6R3E□□392MM15S
EKY-6R3E□□472MK30S
EKY-6R3E□□562MK35S
EKY-6R3E□□562ML20S
EKY-6R3E□□682MK40S
EKY-6R3E□□682ML25S
EKY-6R3E□□682MM20S
EKY-6R3E□□822MLN3S
EKY-6R3E□□103MLP1S
EKY-6R3E□□103MM25S
EKY-6R3E□□123ML40S
EKY-6R3E□□123MMN3S
EKY-6R3E□□153MMP1S
EKY-6R3E□□183MM40S
EKY-100E□□681MJC5S
EKY-100E□□102MJ16S
EKY-100E□□122MJ20S
EKY-100E□□152MJ25S
EKY-100E□□152MK15S
EKY-100E□□222MJ30S
EKY-100E□□222MK20S
EKY-100E□□222ML15S
EKY-100E□□272MM15S
EKY-100E□□332MK25S
EKY-100E□□392MK30S
EKY-100E□□392ML20S
EKY-100E□□472MK35S
EKY-100E□□562MK40S
EKY-100E□□562ML25S
EKY-100E□□562MM20S
EKY-100E□□682MLN3S
EKY-100E□□682MM25S
EKY-100E□□822MLP1S
EKY-100E□□822MMN3S
EKY-100E□□103ML40S
EKY-100E□□103MMP1S
EKY-100E□□123MM40S
EKY-160E□□471MJC5S
EKY-160E□□681MJ16S
EKY-160E□□102MJ20S
EKY-160E□□102MK15S
EKY-160E□□122MJ25S
EKY-160E□□152MJ30S
EKY-160E□□152MK20S
EKY-160E□□152ML15S
EKY-160E□□222MK25S
EKY-160E□□222MM15S
EKY-160E□□272MK30S
EKY-160E□□272ML20S
EKY-160E□□332MK35S
EKY-160E□□392MK40S
EKY-160E□□392ML25S
EKY-160E□□392MM20S
EKY-160E□□472MLN3S
EKY-160E□□472MM25S
EKY-160E□□562MLP1S
EKY-160E□□562MMN3S
EKY-160E□□682ML40S
8,200
10,000
330
470
680
680
820
1,000
1,000
1,000
1,200
1,500
1,800
25 1,800
2,200
2,200
2,700
2,700
3,300
3,300
3,900
3,900
4,700
4,700
5,600
220
330
470
470
560
680
680
680
1,000
1,000
1,200
35 1,200
1,500
1,800
1,800
1,800
2,200
2,200
2,700
2,700
3,300
3,300
3,900
150
220
270
270
330
470
470
470
560
50
560
680
820
820
1,000
1,000
1,000
1,200
1,200
1,500
16
18×35.5
18×40
10×12.5
10×16
10×20
12.5×15
10×25
10×30
12.5×20
16×15
18×15
12.5×25
12.5×30
16×20
12.5×35
18×20
12.5×40
16×25
16×31.5
18×25
16×35.5
18×31.5
16×40
18×35.5
18×40
10×12.5
10×16
10×20
12.5×15
10×25
10×30
12.5×20
16×15
12.5×25
18×15
12.5×30
16×20
12.5×35
12.5×40
16×25
18×20
16×31.5
18×25
16×35.5
18×31.5
16×40
18×35.5
18×40
10×12.5
10×16
10×20
12.5×15
10×25
10×30
12.5×20
16×15
12.5×25
18×15
12.5×30
12.5×35
16×20
12.5×40
16×25
18×20
16×31.5
18×25
16×35.5
Rated
ripple
current
(mArms/
-10℃ 105℃,
100kHz)
Impedance
(Ω max./100kHz)
0.014
0.012
0.080
0.060
0.046
0.049
0.042
0.031
0.035
0.042
0.043
0.027
0.024
0.027
0.020
0.026
0.017
0.021
0.017
0.019
0.015
0.015
0.013
0.014
0.012
0.080
0.060
0.046
0.049
0.042
0.031
0.035
0.042
0.027
0.043
0.024
0.027
0.020
0.017
0.021
0.026
0.017
0.019
0.015
0.015
0.013
0.014
0.012
0.12
0.084
0.060
0.061
0.055
0.043
0.045
0.055
0.034
0.054
0.030
0.025
0.034
0.021
0.025
0.036
0.022
0.026
0.019
0.038
0.032
0.32
0.24
0.18
0.16
0.17
0.12
0.12
0.12
0.11
0.089
0.078
0.078
0.065
0.067
0.056
0.060
0.050
0.049
0.044
0.040
0.038
0.038
0.032
0.32
0.24
0.18
0.16
0.17
0.12
0.12
0.12
0.089
0.11
0.078
0.078
0.065
0.056
0.060
0.067
0.050
0.049
0.044
0.040
0.038
0.038
0.032
0.48
0.34
0.24
0.20
0.22
0.17
0.15
0.17
0.11
0.15
0.10
0.083
0.10
0.069
0.075
0.097
0.066
0.070
0.057
4,220
4,280
865
1,210
1,400
1,450
1,650
1,910
1,900
1,940
2,210
2,230
2,650
2,530
2,880
2,860
3,350
2,930
3,450
3,140
3,610
4,170
4,080
4,220
4,280
865
1,210
1,400
1,450
1,650
1,910
1,900
1,940
2,230
2,210
2,650
2,530
2,880
3,350
2,930
2,860
3,450
3,140
3,610
4,170
4,080
4,220
4,280
760
1,050
1,220
1,260
1,440
1,690
1,660
1,690
1,950
1,930
2,310
2,510
2,210
2,920
2,555
2,490
3,010
2,740
3,150
Part No.
EKY-160E□□822MMP1S
EKY-160E□□103MM40S
EKY-250E□□331MJC5S
EKY-250E□□471MJ16S
EKY-250E□□681MJ20S
EKY-250E□□681MK15S
EKY-250E□□821MJ25S
EKY-250E□□102MJ30S
EKY-250E□□102MK20S
EKY-250E□□102ML15S
EKY-250E□□122MM15S
EKY-250E□□152MK25S
EKY-250E□□182MK30S
EKY-250E□□182ML20S
EKY-250E□□222MK35S
EKY-250E□□222MM20S
EKY-250E□□272MK40S
EKY-250E□□272ML25S
EKY-250E□□332MLN3S
EKY-250E□□332MM25S
EKY-250E□□392MLP1S
EKY-250E□□392MMN3S
EKY-250E□□472ML40S
EKY-250E□□472MMP1S
EKY-250E□□562MM40S
EKY-350E□□221MJC5S
EKY-350E□□331MJ16S
EKY-350E□□471MJ20S
EKY-350E□□471MK15S
EKY-350E□□561MJ25S
EKY-350E□□681MJ30S
EKY-350E□□681MK20S
EKY-350E□□681ML15S
EKY-350E□□102MK25S
EKY-350E□□102MM15S
EKY-350E□□122MK30S
EKY-350E□□122ML20S
EKY-350E□□152MK35S
EKY-350E□□182MK40S
EKY-350E□□182ML25S
EKY-350E□□182MM20S
EKY-350E□□222MLN3S
EKY-350E□□222MM25S
EKY-350E□□272MLP1S
EKY-350E□□272MMN3S
EKY-350E□□332ML40S
EKY-350E□□332MMP1S
EKY-350E□□392MM40S
EKY-500E□□151MJC5S
EKY-500E□□221MJ16S
EKY-500E□□271MJ20S
EKY-500E□□271MK15S
EKY-500E□□331MJ25S
EKY-500E□□471MJ30S
EKY-500E□□471MK20S
EKY-500E□□471ML15S
EKY-500E□□561MK25S
EKY-500E□□561MM15S
EKY-500E□□681MK30S
EKY-500E□□821MK35S
EKY-500E□□821ML20S
EKY-500E□□102MK40S
EKY-500E□□102ML25S
EKY-500E□□102MM20S
EKY-500E□□122MLN3S
EKY-500E□□122MM25S
EKY-500E□□152MLP1S
□□ : Enter the appropriate lead forming or taping code.
Low impedance, 105℃
KYSeries
◆STANDARD RATINGS
WV
(Vdc)
Cap
(µF)
Case size
φD×L(mm)
20℃
1,800
1,800
2,200
2,700
82
120
180
180
220
270
390
470
470
560
63
680
680
680
820
820
1,000
1,200
1,200
1,500
1,800
68
100
120
150
80
150
220
330
330
50
16×40
18×31.5
18×35.5
18×40
10×12.5
10×16
10×20
12.5×16
10×25
12.5×20
12.5×25
12.5×30
16×20
12.5×35
12.5×40
16×25
18×20
16×31.5
18×25
16×35.5
16×40
18×31.5
18×35.5
18×40
10×12.5
10×16
10×20
10×25
12.5×16
12.5×20
12.5×25
16×20
Rated
ripple
current
(mArms/
-10℃ 105℃,
100kHz)
Impedance
(Ω max./100kHz)
0.016
0.021
0.017
0.014
0.11
0.076
0.056
0.072
0.046
0.041
0.031
0.028
0.032
0.024
0.021
0.025
0.030
0.021
0.024
0.019
0.018
0.020
0.018
0.017
0.17
0.11
0.084
0.069
0.11
0.062
0.047
0.048
0.048
0.057
0.046
0.038
0.44
0.31
0.23
0.29
0.19
0.13
0.093
0.084
0.096
0.072
0.063
0.075
0.090
0.063
0.072
0.057
0.054
0.060
0.054
0.051
0.66
0.47
0.34
0.28
0.34
0.18
0.14
0.15
3,710
3,635
3,680
3,800
690
950
1,150
1,150
1,350
1,500
1,900
2,300
2,000
2,500
2,800
2,600
2,500
2,850
2,800
2,900
3,400
3,300
3,400
3,500
480
600
800
900
750
1,100
1,250
1,350
Part No.
WV
(Vdc)
Cap
(µF)
Case size
φD×L(mm)
20℃
EKY-500E□□182ML40S
EKY-500E□□182MMN3S
EKY-500E□□222MMP1S
EKY-500E□□272MM40S
EKY-630E□□820MJC5S
EKY-630E□□121MJ16S
EKY-630E□□181MJ20S
EKY-630E□□181MK16S
EKY-630E□□221MJ25S
EKY-630E□□271MK20S
EKY-630E□□391MK25S
EKY-630E□□471MK30S
EKY-630E□□471ML20S
EKY-630E□□561MK35S
EKY-630E□□681MK40S
EKY-630E□□681ML25S
EKY-630E□□681MM20S
EKY-630E□□821MLN3S
EKY-630E□□821MM25S
EKY-630E□□102MLP1S
EKY-630E□□122ML40S
EKY-630E□□122MMN3S
EKY-630E□□152MMP1S
EKY-630E□□182MM40S
EKY-800E□□680MJC5S
EKY-800E□□101MJ16S
EKY-800E□□121MJ20S
EKY-800E□□151MJ25S
EKY-800E□□151MK16S
EKY-800E□□221MK20S
EKY-800E□□331MK25S
EKY-800E□□331ML20S
390
470
470
470
560
680
80
680
820
820
1,000
1,000
1,200
47
68
82
100
120
150
220
220
270
330
100
330
330
390
470
470
560
560
680
680
820
12.5×30
12.5×35
16×25
18×20
12.5×40
16×31.5
18×25
16×35.5
18×31.5
16×40
18×35.5
18×40
10×12.5
10×16
10×20
12.5×16
10×25
12.5×20
12.5×25
16×20
12.5×30
12.5×35
16×25
18×20
12.5×40
16×31.5
18×25
16×35.5
18×31.5
16×40
18×35.5
18×40
Rated
ripple
current
(mArms/
-10℃ 105℃,
100kHz)
Impedance
(Ω max./100kHz)
0.042
0.036
0.038
0.045
0.032
0.032
0.036
0.029
0.030
0.027
0.027
0.026
0.17
0.11
0.084
0.11
0.069
0.062
0.047
0.048
0.042
0.036
0.038
0.045
0.032
0.032
0.036
0.029
0.030
0.027
0.027
0.026
0.13
0.11
0.12
0.14
0.095
0.095
0.11
0.086
0.090
0.081
0.081
0.077
0.66
0.47
0.34
0.34
0.28
0.18
0.14
0.15
0.13
0.11
0.12
0.14
0.095
0.095
0.11
0.086
0.090
0.081
0.081
0.077
1,500
1,650
1,700
1,500
1,800
1,850
1,750
2,000
1,900
2,200
2,200
2,700
480
600
800
750
900
1,100
1,250
1,350
1,500
1,650
1,700
1,500
1,800
1,850
1,750
2,000
1,900
2,200
2,200
2,700
Part No.
EKY-800E□□391MK30S
EKY-800E□□471MK35S
EKY-800E□□471ML25S
EKY-800E□□471MM20S
EKY-800E□□561MK40S
EKY-800E□□681MLN3S
EKY-800E□□681MM25S
EKY-800E□□821MLP1S
EKY-800E□□821MMN3S
EKY-800E□□102ML40S
EKY-800E□□102MMP1S
EKY-800E□□122MM40S
EKY-101E□□470MJC5S
EKY-101E□□680MJ16S
EKY-101E□□820MJ20S
EKY-101E□□101MK16S
EKY-101E□□121MJ25S
EKY-101E□□151MK20S
EKY-101E□□221MK25S
EKY-101E□□221ML20S
EKY-101E□□271MK30S
EKY-101E□□331MK35S
EKY-101E□□331ML25S
EKY-101E□□331MM20S
EKY-101E□□391MK40S
EKY-101E□□471MLN3S
EKY-101E□□471MM25S
EKY-101E□□561MLP1S
EKY-101E□□561MMN3S
EKY-101E□□681ML40S
EKY-101E□□681MMP1S
EKY-101E□□821MM40S
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Frequency(Hz)
Capacitance(µF)
47
220
680
2,200
4,700
to
to
to
to
to
180
560
1,800
3,900
120
0.40
0.50
0.60
0.75
0.85
1k
0.75
0.85
0.87
0.90
0.95
10k
0.90
0.94
0.95
0.95
0.98
100k
1.00
1.00
1.00
1.00
1.00
The endurance of capacitors is reduced with internal heating produced by ripple
current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple current has to
be reduced.
