C232E104K4SC000
C232E104K4SC000
    FARATRONIC(法拉)
    CAP_10.5X3.5MM_TM
    薄膜电容 CAP_10.5X3.5MM_TM 100nF ±10% 250V 10.50 x 3.50mm
C232E104K4SC000 数据手册
C23 ® CL23 series 塑料外壳金属化聚酯膜电容器 Metallized polyester film capacitor(Box-type) ■ 外形图 Outline Drawing W±0.4, H±0.4, T±0.4 ■ 特点 っ Features ● 可靠性高 ● 金属化酯膜,无感卷绕结构 ● 塑料外壳(UL94 V-0),阻燃环氧填充 む High reliability む Metallized polyester film, non-inductive wound construction む Plastic case(UL94 V-0), epoxy resin sealing ■ 主要用途 っ Typical Applications ● 旁路,隔直,耦合,退耦 ● 脉冲,逻辑,定时,振荡电路 む By-passing,blocking,coupling,decoupling む Pulse,logic,timing,oscillator circuits ■ 技术要求 Specifications 引用标准 Reference Standard GB/T 7332 (IEC 60384-2) 气候类别 Climatic Category 55/105/56 额定温度 Rated Temperature 85Ⓘ 工作温度 Operating Temperature Range -55Ⓘ~105Ⓘ (+85Ⓘ to +105Ⓘ 额定电压 Rated Voltage 63V, 100V, 160V,250V, 400V, 630V, 1 000V 电容量范围 Capacitance Range 0.0010μF~ 47.0μF 电容量偏差 Capacitance Tolerance ±5(J), ±10(K),±20(M) 耐电压 Voltage Proof 1.6UR (5s) 损耗角正切 Dissipation Factor 1.0% (20Ⓘ, 1kHz) UR>100V R 15 000MΩ, CN 0.33μF RCN 5 000s, CN >0.33μF (20Ⓘ, 100V, 1min) UR R 3 750MΩ, CN 0.33μF RCN 1 250s, CN >0.33μF (20Ⓘ, 10V, 1min) 绝缘电阻 Insulation Resistance 最大脉冲爬升速率 Maximum Pulse Rise Time(dV/ dt):若实际工作电压 U 比额定电压 UR 低,电容器可工 作在更高的 dV/dt 场合,这样 dV/dt 允许值应为右表值 乘以 UR/Uㄌ If the working voltage(U) is lower than the rated voltage(UR),the capacitor can be worked at a higher dV/dt. In this case, the maximum allowed dV/dt is obtain by multiplying the right value with UR /U. 50 decreasing factor 1.25% per Ⓘ for UR ) 100V UR(V) dV/dt(V/μs) P=7.5 P=10.0 P=15.0 P=22.5 P=27.5 63 7.5 6 3 2 1 100 15 9 5 3 2 250 30 20 12 8 5 400 40 30 20 10 7 630 50 40 25 12 10 1000 70 60 30 15 12 C23 CL23 series ■ 产品编码说明 Part number system  15 位产品代码如下: The 15 digits part number is formed as follow: 1 2 3 C 2 3 第 1~3 位 4 5 6 7 8 9 10 11 12 13 型号代码 14 15 Digit 1 to 3 C23= CL23 第 4~5 位 C23=CL23 直流额定电压 1J=63V Digit 4 to 5 2A=100V 2C=160V 2E=250V Digit 6 to 8 3 for example: 103=10×10 pF=0.01μF 容量偏差 Digit 9 Capacitance tolerance J=±5%, K=±10%, M=±20% J=±5%, K=±10%, M=±20% 引线脚距 P 3=7.5mm Digit 10 4=10.0mm 6=15.0mm Pitch 3=7.5mm 9=22.5mm B=27.5mm 第 11 位 Rated capacitance value 3 举例:103=10×10 pF=0.01μF 第 10 位 2A=100V 2C=160V 2E=250V 2G=400V 2J=630V 3A=1 000V 标称容量 第9位 D.C. rated voltage 1J=63V 2G=400V 2J=630V 3A=1 000V 第 6~8 位 Series code 4=10.0mm 6=15.0mm 9=22.5mm B=27.5mm 内部特征码 第 12~15 位 引线加工和包装代码 Digit 11 Internal use Digit 12 to 15 Lead form and packaging code  Table 1 引线加工和包装代码 lead form and packaging code ⺮ 12 呕 Digit 12 ⺮ 13 呕 Digit 13 ⺮ 14 呕 Digit 14 代码 说明 代码 说明 代码 Code explanation Code explanation Code A 弹带包装 ammo-pack C 3 F=7.5mm 4 F=10.0mm 6 F=15.0mm 直脚 代码 straight lead C in the figure above Code 00 0 说明 ⺮ 15 呕 Digit 15 代码 说明 explanation Code 表示直脚 1 straight 说明 explanation explanation 产品在连续的两个载带孔之间 each cap. among two consecutive holes P3=12.7mm, H=18.5mm (For pitch=7.5mm) 5 P3=25.4mm; H=18.5mm (For pitch=10/15mm) (Detail parameter refer to page 16) 0 引线长度偏差 ±0.5mm Length tolerance ±0.5mm 标准的引线长度(18mm ~26 mm) standard lead length 45 引线长度 4.5mm lead length 4.5mm 51 C23 ® CL23 series ■ 外形尺寸 Dimensions(mm) Pattern II(Reduced sizes) 63Vdc (40Vac) CN (μF) W H T P d 100Vdc (63Vac) Part number CN (μF) W H T P 250Vdc (160Vac) d Part number CN (μF) 0.068 10.5 W H T P d Part number 0.47 10.5 8.5 3.5 7.5 0.5 C231J474-3S**** 0.22 10.5 8.5 3.5 7.5 0.5 C232A224-3S**** 8.5 3.5 7.5 0.5 C232E683-3S**** 0.68 10.5 9.0 4.0 7.5 0.6 C231J684-3S**** 0.33 10.5 9.0 4.0 7.5 0.6 C232A334-3S**** 0.10 10.5 8.5 3.5 7.5 0.5 C232E104-3S**** 10.5 11.0 5.0 7.5 0.6 C231J105-3S**** 0.39 10.5 9.0 4.0 7.5 0.6 C232A394-3S**** 0.15 10.5 9.0 4.0 7.5 0.6 C232E154-3S**** 1.5 10.5 12.0 6.0 7.5 0.6 C231J155-3S**** 0.47 10.5 9.0 4.0 7.5 0.6 C232A474-3S**** 0.18 10.5 11.0 5.0 7.5 0.6 C232E184-3S**** 1.8 10.5 12.0 6.0 7.5 0.6 C231J185-3S**** 0.68 10.5 11.0 5.0 7.5 0.6 C232A684-3S**** 0.22 10.5 11.0 5.0 7.5 0.6 C232E224-3S**** 1.0 0.10 13.0 9.0 4.0 10.0 0.6 C231J104-4S**** 1.0 10.5 12.0 6.0 7.5 0.6 C232A105-3S**** 0.27 10.5 12.0 6.0 7.5 0.6 C232E274-3S**** 0.15 13.0 9.0 4.0 10.0 0.6 C231J154-4S**** 0.10 13.0 9.0 4.0 10.0 0.6 C232A104-4S**** 0.33 10.5 12.0 6.0 7.5 0.6 C232E334-3S**** 0.22 13.0 9.0 4.0 10.0 0.6 C231J224-4S**** 0.15 13.0 9.0 4.0 10.0 0.6 C232A154-4S**** 0.033 13.0 9.0 4.0 10.0 0.6 C232E333-4S**** 0.33 13.0 9.0 4.0 10.0 0.6 C231J334-4S**** 0.22 13.0 9.0 4.0 10.0 0.6 C232A224-4S**** 0.047 13.0 9.0 4.0 10.0 0.6 C232E473-4S**** 0.47 13.0 9.0 4.0 10.0 0.6 C231J474-4S**** 0.33 13.0 9.0 4.0 10.0 0.6 C232A334-4S**** 0.068 13.0 9.0 4.0 10.0 0.6 C232E683-4S**** 0.68 13.0 9.0 4.0 10.0 0.6 C231J684-4S**** 0.47 13.0 9.0 4.0 10.0 0.6 C232A474-4S**** 0.10 13.0 9.0 4.0 10.0 0.6 C232E104-4S**** 1.0 13.0 9.0 4.0 10.0 0.6 C231J105-4S**** 0.68 13.0 9.0 4.0 10.0 0.6 C232A684-4S**** 0.15 13.0 9.0 4.0 10.0 0.6 C232E154-4S**** 1.5 13.0 11.0 5.0 10.0 0.6 C231J155-4S**** 1.0 13.0 11.0 5.0 10.0 0.6 C232A105-4S**** 0.22 13.0 11.0 5.0 10.0 0.6 C232E224-4S**** 1.8 13.0 12.0 6.0 10.0 0.6 C231J185-4S**** 1.5 13.0 12.0 6.0 10.0 0.6 C232A155-4S**** 0.33 13.0 11.0 5.0 10.0 0.6 C232E334-4S**** 2.2 13.0 12.0 6.0 10.0 0.6 C231J225-4S**** 0.33 17.5 11.0 5.0 15.0 0.8 C232A334-6S**** 0.39 13.0 12.0 6.0 10.0 0.6 C232E394-4S**** 0.68 17.5 11.0 5.0 15.0 0.8 C231J684-6S**** 0.47 17.5 11.0 5.0 15.0 0.8 C232A474-6S**** 0.47 13.0 12.0 6.0 10.0 0.6 C232E474-4S**** 1.0 17.5 11.0 5.0 15.0 0.8 C231J105-6S**** 0.68 17.5 11.0 5.0 15.0 0.8 C232A684-6S**** 0.10 17.5 11.0 5.0 15.0 0.8 C232E104-6S**** 1.5 17.5 11.0 5.0 15.0 0.8 C231J155-6S**** 1.0 17.5 11.0 5.0 15.0 0.8 C232A105-6S**** 0.15 17.5 11.0 5.0 15.0 0.8 C232E154-6S**** 1.8 17.5 11.0 5.0 15.0 0.8 C231J185-6S**** 1.5 17.5 12.0 6.0 15.0 0.8 C232A155-6S**** 0.22 17.5 11.0 5.0 15.0 0.8 C232E224-6S**** 2.2 17.5 11.0 5.0 15.0 0.8 C231J225-6S**** 1.8 17.5 12.0 6.0 15.0 0.8 C232A185-6S**** 0.33 17.5 11.0 5.0 15.0 0.8 C232E334-6S**** 3.3 17.5 12.0 6.0 15.0 0.8 C231J335-6S**** 2.2 17.5 12.0 6.0 15.0 0.8 C232A225-6S**** 0.47 17.5 11.0 5.0 15.0 0.8 C232E474-6S**** 4.7 17.5 13.5 7.5 15.0 0.8 C231J475-6S**** 3.3 17.5 13.5 7.5 15.0 0.8 C232A335-6S**** 0.68 17.5 12.0 6.0 15.0 0.8 C232E684-6S**** 6.8 17.5 14.5 8.5 15.0 0.8 C231J685-6S**** 4.7 17.5 14.5 8.5 15.0 0.8 C232A475-6S**** 1.0 17.5 13.5 7.5 15.0 0.8 C232E105-6S**** 10.0 17.5 19.0 11.0 15.0 0.8 C231J106-6S**** 1.5 26.5 15.0 6.0 22.5 0.8 C232A155-9S**** 1.5 17.5 14.5 8.5 15.0 0.8 C232E155-6S**** 3.3 265 16.0 7.0 22.5 0.8 C231J335-9S**** 1.8 26.5 15.0 6.0 22.5 0.8 C232A185-9S**** 0.22 26.5 15.0 6.0 22.5 0.8 C232E224-9S**** 4.7 26.5 16.0 7.0 22.5 0.8 C231J475-9S**** 2.2 26.5 15.0 6.0 22.5 0.8 C232A225-9S**** 0.47 26.5 15.0 6.0 22.5 0.8 C232E474-9S**** 6.8 26.5 16.0 7.0 22.5 0.8 C231J685-9S**** 3.3 26.5 15.0 6.0 22.5 0.8 C232A335-9S**** 0.68 26.5 15.0 6.0 22.5 0.8 C232E684-9S**** 10.0 26.5 17.0 8.5 22.5 0.8 C231J106-9S**** 4.7 26.5 16.0 7.0 22.5 0.8 C232A475-9S**** 1.0 26.5 15.0 6.0 22.5 0.8 C232E105-9S**** 15.0 26.5 20.0 11.0 22.5 0.8 C231J156-9S**** 6.8 26.5 18.5 10.0 22.5 0.8 C232A685-9S**** 1.5 26.5 16.0 7.0 22.5 0.8 C232E155-9S**** 4.7 32.0 18.0 9.0 27.5 0.8 C231J475-BS**** 10.0 26.5 22.0 12.0 22.5 0.8 C232A106-9S**** 1.8 26.5 16.0 7.0 22.5 0.8 C232E185-9S**** 6.8 32.0 18.0 9.0 27.5 0.8 C231J685-BS**** 4.7 32.0 18.0 9.0 27.5 0.8 C232A475-BS**** 2.2 26.5 17.0 8.5 22.5 0.8 C232E225-9S**** 10.0 32.0 18.0 9.0 27.5 0.8 C231J106-BS**** 6.8 32.0 18.0 9.0 27.5 0.8 C232A685-BS**** 3.3 26.5 20.0 11.0 22.5 0.8 C232E335-9S**** 15.0 32.0 18.0 9.0 27.5 0.8 C231J156-BS**** 10.0 32.0 20.0 11.0 27.5 0.8 C232A106-BS**** 1.5 32.0 18.0 9.0 27.5 0.8 C232E155-BS**** 22.0 32.0 22.0 13.0 27.5 0.8 C231J226-BS**** 15.0 32.0 20.0 11.0 27.5 0.8 C232A156-BS**** 1.8 32.0 18.0 9.0 27.5 0.8 C232E185-BS**** 33.0 32.0 24.5 15.0 27.5 0.8 C231J336-BS**** 22.0M 32.0 25.0 13.0 27.5 0.8 C232A226MBS**** 2.2 32.0 18.0 9.0 27.5 0.8 C232E225-BS**** 47.0 32.0 30.0 16.0 27.5 0.8 C231J476-BS**** C232A336-BS**** 3.3 32.0 18.0 9.0 27.5 0.8 C232E335-BS**** 4.7 32.0 20.0 11.0 27.5 0.8 C232E475-BS**** 6.8 32.0 22.0 13.0 27.5 0.8 C232E685-BS**** 10.0 32.0 24.5 15.0 27.5 0.8 C232E106-BS**** 33.0 32.0 30.0 16.0 27.5 0.8 备注 Note 1.“-”表示容量偏差。 - =capacitance tolerance code. M=±20%, K=±10%, J=±5%. 2.“****”表示引线加工和包装代码(见表 1)。 **** =lead form and packing code(refer to table 1). 52 C23 CL23 series ■ 外形尺寸 Dimensions(mm) Pattern II(Reduced sizes) 400Vdc (200Vac) CN (μF) W H T P d 630Vdc (220Vac) Part number CN (μF) W H T P d 1 000Vdc (300Vac) Part number CN (μF) W H T P d Part number 0.022 10.5 8.5 3.5 7.5 0.5 C232G223-3S**** 0.0022 10.5 8.5 3.5 7.5 0.5 C232J222-3S**** 0.0010 10.5 8.5 3.5 7.5 0.5 C233A102-3S**** 0.033 10.5 8.5 3.5 7.5 0.5 C232G333-3S**** 0.0047 10.5 8.5 3.5 7.5 0.5 C232J472-3S**** 0.0015 10.5 8.5 3.5 7.5 0.5 C233A152-3S**** 0.047 10.5 9.0 4.0 7.5 0.6 C232G473-3S**** 0.0068 10.5 8.5 3.5 7.5 0.5 C232J682-3S**** 0.0022 10.5 8.5 3.5 7.5 0.5 C233A222-3S**** 0.068 10.5 11.0 5.0 7.5 0.6 C232G683-3S**** 0.010 10.5 8.5 3.5 7.5 0.5 C232J103-3S**** 0.0033 10.5 8.5 3.5 7.5 0.5 C233A332-3S**** 0.082 10.5 12.0 6.0 7.5 0.6 C232G823-3S**** 0.015 10.5 9.0 4.0 7.5 0.6 C232J153-3S**** 0.0047 10.5 8.5 3.5 7.5 0.5 C233A472-3S**** 0.10 10.5 12.0 6.0 7.5 0.6 C232G104-3S**** 0.022 10.5 11.0 5.0 7.5 0.6 C232J223-3S**** 0.0068 10.5 9.0 4.0 7.5 0.6 C233A682-3S**** 0.010 13.0 9.0 4.0 10.0 0.6 C232G103-4S**** 0.033 10.5 12.0 6.0 7.5 0.6 C232J333-3S**** 0.010 10.5 11.0 5.0 7.5 0.6 C233A103-3S**** 0.015 13.0 9.0 4.0 10.0 0.6 C232G153-4S**** 0.047 10.5 12.0 6.0 7.5 0.6 C232J473-3S**** 0.015 10.5 12.0 6.0 7.5 0.6 C233A153-3S**** 0.022 13.0 9.0 4.0 10.0 0.6 C232G223-4S**** 0.0047 13.0 9.0 4.0 10.0 0.6 C232J472-4S**** 0.0010 13.0 9.0 4.0 10.0 0.6 C233A102-4S**** 0.033 13.0 9.0 4.0 10.0 0.6 C232G333-4S**** 0.0068 13.0 9.0 4.0 10.0 0.6 C232J682-4S**** 0.0015 13.0 9.0 4.0 10.0 0.6 C233A152-4S**** 0.047 13.0 9.0 4.0 10.0 0.6 C232G473-4S**** 0.010 13.0 9.0 4.0 10.0 0.6 C232J103-4S**** 0.0022 13.0 9.0 4.0 10.0 0.6 C233A222-4S**** 0.056 13.0 9.0 4.0 10.0 0.6 C232G563-4S**** 0.015 13.0 9.0 4.0 10.0 0.6 C232J153-4S**** 0.0033 13.0 9.0 4.0 10.0 0.6 C233A332-4S**** 0.068 13.0 11.0 5.0 10.0 0.6 C232G683-4S**** 0.022 13.0 9.0 4.0 10.0 0.6 C232J223-4S**** 0.0047 13.0 9.0 4.0 10.0 0.6 C233A472-4S**** 0.10 13.0 11.0 5.0 10.0 0.6 C232G104-4S**** 0.033 13.0 11.0 5.0 10.0 0.6 C232J333-4S**** 0.0056 13.0 9.0 4.0 10.0 0.6 C233A562-4S**** 0.15 13.0 12.0 6.0 10.0 0.6 C232G154-4S**** 0.047 13.0 11.0 5.0 10.0 0.6 C232J473-4S**** 0.0068 13.0 9.0 4.0 10.0 0.6 C233A682-4S**** 0.047 17.5 11.0 5.0 15.0 0.8 C232G473-6S**** 0.068 13.0 12.0 6.0 10.0 0.6 C232J683-4S**** 0.010 13.0 9.0 4.0 10.0 0.6 C233A103-4S**** 0.068 17.5 11.0 5.0 15.0 0.8 C232G683-6S**** 0.033 17.5 11.0 5.0 15.0 0.8 C232J333-6S**** 0.015 13.0 11.0 5.0 10.0 0.6 C233A153-4S**** 0.10 17.5 11.0 5.0 15.0 0.8 C232G104-6S**** 0.047 17.5 11.0 5.0 15.0 0.8 C232J473-6S**** 0.022 13.0 11.0 5.0 10.0 0.6 C233A223-4S**** 0.15 17.5 11.0 5.0 15.0 0.8 C232G154-6S**** 0.068 17.5 11.0 5.0 15.0 0.8 C232J683-6S**** 0.010 17.5 11.0 5.0 15.0 0.8 C233A103-6S**** 0.22 17.5 12.0 6.0 15.0 0.8 C232G224-6S**** 0.10 17.5 12.0 6.0 15.0 0.8 C232J104-6S**** 0.015 17.5 11.0 5.0 15.0 0.8 C233A153-6S**** 0.33 17.5 13.5 7.5 15.0 0.8 C232G334-6S**** 0.15 17.5 13.5 7.5 15.0 0.8 C232J154-6S**** 0.022 17.5 11.0 5.0 15.0 0.8 C233A223-6S**** 0.47 17.5 14.5 8.5 15.0 0.8 C232G474-6S**** 0.22 17.5 16.0 10.0 15.0 0.8 C232J224-6S**** 0.033 17.5 12.0 6.0 15.0 0.8 C233A333-6S**** 0.56 17.5 16.0 10.0 15.0 0.8 C232G564-6S**** 0.33 17.5 19.0 11.0 15.0 0.8 C232J334-6S**** 0.047 17.5 12.0 6.0 15.0 0.8 C233A473-6S**** 0.68 17.5 16.0 10.0 15.0 0.8 C232G684-6S**** 0.10 26.5 15.0 6.0 22.5 0.8 C232J104-9S**** 0.068 17.5 13.5 7.5 15.0 0.8 C233A683-6S**** 0.22 26.5 15.0 6.0 22.5 0.8 C232G224-9S**** 0.15 26.5 15.0 6.0 22.5 0.8 C232J154-9S**** 0.10 17.5 14.5 8.5 15.0 0.8 C233A104-6S**** 0.33 26.5 15.0 6.0 22.5 0.8 C232G334-9S**** 0.22 26.5 16.0 7.0 22.5 0.8 C232J224-9S**** 0.033 26.5 15.0 6.0 22.5 0.8 C233A333-9S**** 0.47 26.5 15.0 6.0 22.5 0.8 C232G474-9S**** 0.33 26.5 16.0 7.0 22.5 0.8 C232J334-9S**** 0.047 26.5 15.0 6.0 22.5 0.8 C233A473-9S**** 0.68 26.5 16.0 7.0 22.5 0.8 C232G684-9S**** 0.47 26.5 17.0 8.5 22.5 0.8 C232J474-9S**** 0.068 26.5 15.0 6.0 22.5 0.8 C233A683-9S**** 1.0 26.5 18.50 10.0 22.5 0.8 C232G105-9S**** 0.68 26.5 22.0 12.0 22.5 0.8 C232J684-9S**** 0.10 26.5 15.0 6.0 22.5 0.8 C233A104-9S**** 1.5 26.5 22.0 12.0 22.5 0.8 C232G155-9S**** 26.5 16.0 7.0 22.5 0.8 C233A154-9S**** 0.33 32.0 18.0 9.0 27.5 0.8 C232J334-BS**** 0.15 0.68 32.0 18.0 9.0 27.5 0.8 C232G684-BS**** 0.47 32.0 18.0 9.0 27.5 0.8 C232J474-BS**** 0.22 26.5 17.0 8.5 22.5 0.8 C233A224-9S**** 1.0 32.0 18.0 9.0 27.5 0.8 C232G105-BS**** 0.68 32.0 20.0 11.0 27.5 0.8 C232J684-BS**** 0.33 26.5 20.0 11.0 22.5 0.8 C233A334-9S**** 1.5 32.0 20.0 11.0 27.5 0.8 C232G155-BS**** 1.0K 32.0 20.0 11.0 27.5 0.8 C232J105KBS**** 0.15 32.0 18.0 9.0 27.5 0.8 C233A154-BS**** 1.8 32.0 20.0 11.0 27.5 0.8 C232G185-BS**** 0.22 32.0 18.0 9.0 27.5 0.8 C233A224-BS**** 2.2 32.0 22.0 13.0 27.5 0.8 C232G225-BS**** 0.33 32.0 20.0 11.0 27.5 0.8 C233A334-BS**** 3.3 32.0 24.5 15.0 27.5 0.8 C232G335-BS**** 0.47 32.0 20.0 11.0 27.5 0.8 C233A474-BS**** 4.7 32.0 30.0 16.0 27.5 0.8 C232G475-BS**** 0.68 32.0 28.0 14.0 27.5 0.8 C233A684-BS**** 6.8 32.0 33.0 18.0 27.5 0.8 C232G685-BS**** 1.0 32.0 30.0 16.0 27.5 0.8 C233A105-BS**** 1.5 32.0 37.0 22.0 27.5 0.8 C233A155-BS**** 备注 Note 1.“-”表示容量偏差。 - =capacitance tolerance code. M=±20%, K=±10%, J=±5%. 2.“****”表示引线加工和包装代码(见表 1)。 **** =lead form and packing code(refer to table 1). 3. @ 不用作跨线,请参见抗干扰电容器(Page 109)。 @ Not suitable for across-the-line applications. Pls refer to interference Suppression Capacitors(Page 109). 53
C232E104K4SC000 价格&库存
很抱歉,暂时无法提供与“C232E104K4SC000”相匹配的价格&库存,您可以联系我们找货
