XHP35B-00-0000-0D0HE20E5
    WOLFSPEED
    LED-3P_3.45X3.45MM_SM
    XLAMP XHP35B WHITE LED
XHP35B-00-0000-0D0HE20E5 数据手册
PRODUCT FAMILY DATA SHEET XLamp® XHP35.2 LEDs XHP35.2 High‑Density LED PRODUCT DESCRIPTION XHP35.2 High‑Intensity LED FEATURES TABLE OF CONTENTS The XLamp® XHP35.2 LED is the next • Available in 5-step EasyWhite® Characteristics................................................ 2 generation of Extreme High Power LEDs bins at 2700 K—5700 K CCT and Order Codes Suggested for New Designs - available in the XP footprint. Built on 3-step & 2‑step EasyWhite bins at High Density EasyWhite®................................ 3 Cree LED’s latest high‑power LED array 2700 K—4000 K CCT Order Codes Suggested for New Designs - technology, the XHP35.2 LED improves • Available in ANSI white bins at 2700 K High Density ANSI........................................... 6 the voltage characteristics, efficacy and Order Codes Suggested for New Designs - to 7000 K CCT reliability of the XHP35 LED in the same • Available in standard, 70, 80, 90, and 95 High Intensity EasyWhite®.............................. 9 3.45  mm x 3.45  mm footprint. The new Order Codes Suggested for New Designs - CRI minimum options XHP35.2 LED provides an easy drop‑in • Binned at 85 °C High Intensity ANSI....................................... 13 upgrade so that lighting manufacturers • Maximum drive current: 1500 mA Relative Spectral Power Distribution........... 16 can achieve higher system LPW on existing • Low thermal resistance: 0.7 °C/W Relative Flux vs. Junction Temperature....... 16 XHP35 designs with minimal system • Wide viewing angle - High Density:135°, Electrical Characteristics.............................. 17 redesign cost. Relative Flux vs. Current............................... 17 High Intensity: 120° • Unlimited floor life at ≤ 30 ºC/85% RH Relative Chromaticity vs. Current................. 18 The XHP35.2 LED offers a high‑intensity • Reflow solderable - JEDEC J‑STD‑020C Relative Chromaticity vs. Temperature........ 18 option. In this document, the term XHP35.2 • RoHS and REACH compliant Typical Spatial Distribution........................... 19 denotes the XHP35.2 LED without regard • UL recognized component (E349212) Thermal Design............................................. 19 to high density or high intensity. The Performance Groups - Luminous Flux......... 20 terms High Density and High Intensity are Performance Groups - Chromaticity............ 21 used when necessary to differentiate the Standard Cool White Kits Plotted on ANSI performance of the two options. Standard Chromaticity Regions................... 26 ® Standard Warm and Neutral White Kits Plotted on ANSI Standard Chromaticity Regions.......................................................... 27 Bin and Order Code Formats........................ 28 Reflow Soldering Characteristics................. 29 Notes............................................................. 30 Mechanical Dimensions............................... 32 Tape and Reel................................................ 34 Packaging...................................................... 37 Appendix - Order Codes Not For New Designs.......................................................... 38 Cree LED / 4001 E. Hwy. 54, Suite 2000 / Durham, NC 27709 USA / +1.919.313.5330 / www.cree-led.com © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 1 XLAMP ® XHP35.2 LED CHARACTERISTICS Characteristics Thermal resistance, junction to solder point Unit Minimum Typical °C/W 0.7 Viewing angle (FWHM) - High Density degrees 135 Viewing angle (FWHM) - High Intensity degrees 120 mV/°C -5 Temperature coefficient of voltage ESD withstand voltage (HBM per Mil-Std-883D) DC forward current Maximum 8000 mA 1500 Reverse voltage V 1 Forward voltage (@ 350 mA, 85 °C) V LED junction temperature °C 11.2 12.2 150 Note • Thermal resistance measurement was performed per the JEDEC JESD51-14 standard. See the Thermal Resistance Measurement application note for more details. © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 2 XLAMP ® XHP35.2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - HIGH DENSITY EASYWHITE® (TJ = 85 °C) The following table provides order codes for XLamp XHP35.2 High‑Density LEDs. For a complete description of how the flux and chromaticity groups are reflected in the bin code and order code nomenclature, please see the Bin and Order Code Formats section (page 28). Minimum Luminous Flux @350 mA CRI Nominal CCT Min Typ Group Flux (lm) @ 85 °C E4 635 2-Step Group Order Code 3-Step Group Order Code 70 90 E2 590 E2 590 57E XHP35B-00-00000D0BE457E XHP35B-00-00000D0BE257E XHP35B-00-00000D0HE257E 550 XHP35B-00-00000D0HD457E D2 510 XHP35B-00-00000D0UD257E C4 475 C2 440 XHP35B-00-00000D0UC257E E4 635 XHP35B-00-00000D0BE450E E2 590 XHP35B-00-00000D0BE250E E2 590 XHP35B-00-00000D0HE250E D4 550 XHP35B-00-00000D0HD450E D2 510 XHP35B-00-00000D0UD250E C4 475 C2 440 57E 50E 80 90 Order Code D4 70 5000 K Group 57E 80 5700 K 5-Step 50E 50E XHP35B-00-00000D0UC457E XHP35B-00-00000D0UC450E XHP35B-00-00000D0UC250E Notes: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp XHP35.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 3 XLAMP ® XHP35.2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - HIGH DENSITY EASYWHITE® (TJ = 85 °C) - CONTINUED Minimum Luminous Flux @350 mA CRI Nominal CCT Min Typ 2-Step 3-Step Group Flux (lm) @ 85 °C E4 635 E2 590 XHP35B-00-00000D0BE245E E2 590 XHP35B-00-00000D0HE245E D4 550 XHP35B-00-00000D0HD445E D2 510 XHP35B-00-00000D0UD245E C4 475 C2 440 XHP35B-00-00000D0UC245E E4 635 XHP35B-00-00000D0BE440E E2 590 E2 590 D4 550 C4 475 C2 440 B4 410 E2 590 D4 550 D4 550 D2 510 C4 475 C2 440 B4 410 Group Order Code Group Order Code 70 90 45E 45E 70 40E 80 4000 K 90 40G XHP35B-00-00000D0UC440H 40H XHP35B-00-00000D0UC240H XHP35B-00-00000D0HE240G XHP35B-00-00000D0HD440G 40G XHP35B-00-00000D0UB440H XHP35B-00-00000D0UC240G 40E XHP35B-00-00000D0UB440G 35G XHP35B-00-00000D0UC435H 35H XHP35B-00-00000D0UC235H XHP35B-00-00000D0UB435H XHP35B-00-00000D0HD435G XHP35B-00-00000D0HD235G XHP35B-00-00000D0UC235G XHP35B-00-00000D0UB435G XHP35B-00-00000D0BE445E XHP35B-00-00000D0UC445E XHP35B-00-00000D0BE240E XHP35B-00-00000D0HE240E XHP35B-00-00000D0HD440E XHP35B-00-00000D0UC240E XHP35B-00-00000D0UB440E 35E XHP35B-00-00000D0UC435G 35G Order Code XHP35B-00-00000D0UC440E 35E 80 90 40E XHP35B-00-00000D0UC440G 70 3500 K Group 45E 80 4500 K 5-Step XHP35B-00-00000D0BE235E XHP35B-00-00000D0BD435E XHP35B-00-00000D0HD435E XHP35B-00-00000D0HD235E XHP35B-00-00000D0UC435E 35E XHP35B-00-00000D0UC235E XHP35B-00-00000D0UB435E Notes: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp XHP35.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 4 XLAMP ® XHP35.2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - HIGH DENSITY EASYWHITE® (TJ = 85 °C) - CONTINUED Nominal CCT Min 70 3000 K Minimum Luminous Flux @350 mA CRI Typ Group Flux (lm) @ 85 °C E2 590 D4 550 D2 510 D4 550 D2 510 C2 440 B4 410 B2 380 D2 510 C4 475 B4 410 B2 380 2-Step Group Order Code Group Group 30E Order Code XHP35B-00-00000D0BD430E XHP35B-00-00000D0BD230E 30G XHP35B-00-00000D0UC230H 30H XHP35B-00-00000D0UB430H 30G 27G 2700 K 27H XHP35B-00-00000D0UB427H XHP35B-00-00000D0UB227H XHP35B-00-00000D0HD430G XHP35B-00-00000D0HD230G 30E XHP35B-00-00000D0UC230G XHP35B-00-00000D0UB230H 80 90 Order Code 5-Step XHP35B-00-00000D0BE230E 80 90 3-Step 27G XHP35B-00-00000D0UB430G XHP35B-00-00000D0HD430E XHP35B-00-00000D0HD230E XHP35B-00-00000D0UC230E 30E XHP35B-00-00000D0UB430E XHP35B-00-00000D0UB230G XHP35B-00-00000D0UB230E XHP35B-00-00000D0HD227G XHP35B-00-00000D0HD227E XHP35B-00-00000D0HC427G XHP35B-00-00000D0UB427G XHP35B-00-00000D0UB227G 27E 27E XHP35B-00-00000D0HC427E XHP35B-00-00000D0UB427E XHP35B-00-00000D0UB227E Notes: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp XHP35.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 5 XLAMP ® XHP35.2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - HIGH DENSITY ANSI (TJ = 85 °C) The following table provides order codes for XLamp XHP35.2 High‑Density LEDs. For a complete description of how the flux and chromaticity groups are reflected in the bin code and order code nomenclature, please see the Bin and Order Code Formats section (page 28). Nomimal CCT 7000 K Minimum Luminous Flux @ 350 mA CRI Chromaticity Regions 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U Min Typ 0 68 70 80 90 0 68 70 6500 K 1A, 1B, 1C, 1D 80 90 0 6000 K 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U 70 80 90 68 Group Flux (lm) @ 85 °C Order Code E2 590 XHP35B-00-0000-0D00E20DT D4 550 XHP35B-00-0000-0D00D40DT E2 590 XHP35B-00-0000-0D0BE20DT D4 550 XHP35B-00-0000-0D0BD40DT D4 550 XHP35B-00-0000-0D0HD40DT D2 510 XHP35B-00-0000-0D0HD20DT D2 510 XHP35B-00-0000-0D0UD20DT C4 475 XHP35B-00-0000-0D0UC40DT C2 440 XHP35B-00-0000-0D0UC20DT E2 590 XHP35B-00-0000-0D00E20E1 D4 550 XHP35B-00-0000-0D00D40E1 E2 590 XHP35B-00-0000-0D0BE20E1 D4 550 XHP35B-00-0000-0D0BD40E1 D4 550 XHP35B-00-0000-0D0HD40E1 D2 510 XHP35B-00-0000-0D0HD20E1 D2 510 XHP35B-00-0000-0D0UD20E1 C4 475 XHP35B-00-0000-0D0UC40E1 C2 440 XHP35B-00-0000-0D0UC20E1 E2 590 XHP35B-00-0000-0D00E20DV D4 550 XHP35B-00-0000-0D00D40DV E2 590 XHP35B-00-0000-0D0BE20DV D4 550 XHP35B-00-0000-0D0BD40DV D4 550 XHP35B-00-0000-0D0HD40DV D2 510 XHP35B-00-0000-0D0HD20DV D2 510 XHP35B-00-0000-0D0UD20DV C4 475 XHP35B-00-0000-0D0UC40DV C2 440 XHP35B-00-0000-0D0UC20DV Notes: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp XHP35.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 6 XLAMP ® XHP35.2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - HIGH DENSITY ANSI (TJ = 85 °C) - CONTINUED Nomimal CCT Minimum Luminous Flux @ 350 mA CRI Chromaticity Regions Min Typ 0 68 70 5700 K 2A, 2B, 2C, 2D 80 90 0 68 70 5000 K 3A, 3B, 3C, 3D 80 90 0 70 4500 K 4A, 4B, 4C, 4D 80 90 68 Order Code Group Flux (lm) @ 85 °C E4 635 XHP35B-00-0000-0D00E40E2 E2 590 XHP35B-00-0000-0D00E20E2 E4 635 XHP35B-00-0000-0D0BE40E2 E2 590 XHP35B-00-0000-0D0BE20E2 E2 590 XHP35B-00-0000-0D0HE20E2 D4 550 XHP35B-00-0000-0D0HD40E2 D2 510 XHP35B-00-0000-0D0UD20E2 C4 475 XHP35B-00-0000-0D0UC40E2 C2 440 XHP35B-00-0000-0D0UC20E2 E4 635 XHP35B-00-0000-0D00E40E3 E2 590 XHP35B-00-0000-0D00E20E3 E4 635 XHP35B-00-0000-0D0BE40E3 E2 590 XHP35B-00-0000-0D0BE20E3 E2 590 XHP35B-00-0000-0D0HE20E3 D4 550 XHP35B-00-0000-0D0HD40E3 D2 510 XHP35B-00-0000-0D0UD20E3 C4 475 XHP35B-00-0000-0D0UC40E3 C2 440 XHP35B-00-0000-0D0UC20E3 E4 635 XHP35B-00-0000-0D00E40E4 E2 590 XHP35B-00-0000-0D00E20E4 E4 635 XHP35B-00-0000-0D0BE40E4 E2 590 XHP35B-00-0000-0D0BE20E4 E2 590 XHP35B-00-0000-0D0HE20E4 D4 550 XHP35B-00-0000-0D0HD40E4 D2 510 XHP35B-00-0000-0D0UD20E4 C4 475 XHP35B-00-0000-0D0UC40E4 C2 440 XHP35B-00-0000-0D0UC20E4 Notes: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp XHP35.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 7 XLAMP ® XHP35.2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - HIGH DENSITY ANSI (TJ = 85 °C) - CONTINUED Nomimal CCT Chromaticity Regions Min Typ 0 68 70 4000 K 5A, 5B, 5C, 5D 80 90 70 3500 K 6A, 6B, 6C, 6D 80 90 70 3000 K 7A, 7B, 7C, 7D 80 90 80 2700 K Minimum Luminous Flux @ 350 mA CRI 8A, 8B, 8C, 8D 90 Order Code Group Flux (lm) @ 85 °C E4 635 XHP35B-00-0000-0D00E40E5 E2 590 XHP35B-00-0000-0D00E20E5 E4 635 XHP35B-00-0000-0D0BE40E5 E2 590 XHP35B-00-0000-0D0BE20E5 E2 590 XHP35B-00-0000-0D0HE20E5 D4 550 XHP35B-00-0000-0D0HD40E5 C4 475 XHP35B-00-0000-0D0UC40E5 C2 440 XHP35B-00-0000-0D0UC20E5 B4 410 XHP35B-00-0000-0D0UB40E5 E2 590 XHP35B-00-0000-0D0BE20E6 D4 550 XHP35B-00-0000-0D0BD40E6 D4 550 XHP35B-00-0000-0D0HD40E6 D2 510 XHP35B-00-0000-0D0HD20E6 C4 475 XHP35B-00-0000-0D0UC40E6 C2 440 XHP35B-00-0000-0D0UC20E6 B4 410 XHP35B-00-0000-0D0UB40E6 E2 590 XHP35B-00-0000-0D0BE20E7 D4 550 XHP35B-00-0000-0D0BD40E7 D2 510 XHP35B-00-0000-0D0BD20E7 D4 550 XHP35B-00-0000-0D0HD40E7 D2 510 XHP35B-00-0000-0D0HD20E7 C2 440 XHP35B-00-0000-0D0UC20E7 B4 410 XHP35B-00-0000-0D0UB40E7 B2 380 XHP35B-00-0000-0D0UB20E7 D2 510 XHP35B-00-0000-0D0HD20E8 C4 475 XHP35B-00-0000-0D0HC40E8 B4 410 XHP35B-00-0000-0D0UB40E8 B2 380 XHP35B-00-0000-0D0UB20E8 Notes: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp XHP35.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 8 XLAMP ® XHP35.2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - HIGH INTENSITY EASYWHITE® (TJ = 85 °C) The following table provides order codes for XLamp XHP35.2 High‑Intensity LEDs. For a complete description of how the flux and chromaticity groups are reflected in the bin code and order code nomenclature, please see the Bin and Order Code Formats section (page 28). Nominal CCT Min 70 5700 K 80 90 70 5000 K Minimum Luminous Flux @350 mA CRI 80 90 Typ 2‑Step 3-Step 5-Step Group Flux (lm) @ 85 °C D4 550 D2 510 C4 475 XHP35B-H0-00000D0BC457E D2 510 XHP35B-H0-00000D0HD257E C4 475 C2 440 XHP35B-H0-00000D0HC257E C4 475 XHP35B-H0-00000D0UC457E C2 440 B4 410 XHP35B-H0-00000D0UB457E D4 550 XHP35B-H0-00000D0BD450E D2 510 C4 475 D2 510 C4 475 C2 440 C2 440 B4 410 B2 380 Group Order Code Group Order Code Group Order Code XHP35B-H0-00000D0BD457E 57E 57E 57E 50E XHP35B-H0-00000D0BD257E XHP35B-H0-00000D0HC457E XHP35B-H0-00000D0UC257E XHP35B-H0-00000D0BD250E XHP35B-H0-00000D0BC450E XHP35B-H0-00000D0HD250G 50G XHP35B-H0-00000D0UC250H 50H XHP35B-H0-00000D0UB450H XHP35B-H0-00000D0UB250H 50G XHP35B-H0-00000D0HC450G XHP35B-H0-00000D0HD250E 50E XHP35B-H0-00000D0HC450E XHP35B-H0-00000D0HC250G XHP35B-H0-00000D0HC250E XHP35B-H0-00000D0UC250G XHP35B-H0-00000D0UC250E XHP35B-H0-00000D0UB450G XHP35B-H0-00000D0UB250G 50E XHP35B-H0-00000D0UB450E XHP35B-H0-00000D0UB250E Notes: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp XHP35.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 9 XLAMP ® XHP35.2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - HIGH INTENSITY EASYWHITE® (TJ = 85 °C) - CONTINUED Nominal CCT Min 70 4500 K Minimum Luminous Flux @350 mA CRI 80 90 Typ 2‑Step 3-Step Group Flux (lm) @ 85 °C D4 550 D2 510 C4 475 D2 510 C4 475 C2 440 C2 440 B4 410 B2 380 D4 550 XHP35B-H0-00000D0BD440E D2 510 XHP35B-H0-00000D0BD240E C4 475 XHP35B-H0-00000D0BC440E C2 440 XHP35B-H0-00000D0BC240E D2 510 C4 475 C2 440 B4 410 B2 380 A4 355 XHP35B-H0-00000D0UA440H XHP35B-H0-00000D0UA440G B4 410 XHP35B-H0-00000D0ZB440H XHP35B-H0-00000D0ZB440G B2 380 A4 355 Group Order Code Group Order Code 4000 K 90 95 Group Order Code XHP35B-H0-00000D0BD445E 45E XHP35B-H0-00000D0BD245E XHP35B-H0-00000D0BC445E XHP35B-H0-00000D0HD245G 45G XHP35B-H0-00000D0UC245H 45H XHP35B-H0-00000D0UB445H 45G XHP35B-H0-00000D0UB245H XHP35B-H0-00000D0HC445G XHP35B-H0-00000D0HD245E 45E XHP35B-H0-00000D0HC245E XHP35B-H0-00000D0UC245G XHP35B-H0-00000D0UC245E XHP35B-H0-00000D0UB445G 45E XHP35B-H0-00000D0HB245G XHP35B-H0-00000D0HD240G XHP35B-H0-00000D0UB440H 40H 40H XHP35B-H0-00000D0UB240H XHP35B-H0-00000D0ZB240H XHP35B-H0-00000D0ZA440H 40G 40G XHP35B-H0-00000D0HC440G XHP35B-H0-00000D0UB445E XHP35B-H0-00000D0UB245E 40E 40G XHP35B-H0-00000D0HC445E XHP35B-H0-00000D0HC245G 70 80 5-Step XHP35B-H0-00000D0HD240E 40E XHP35B-H0-00000D0HC440E XHP35B-H0-00000D0HC240G XHP35B-H0-00000D0HC240E XHP35B-H0-00000D0UB440G XHP35B-H0-00000D0UB440E XHP35B-H0-00000D0UB240G 40E XHP35B-H0-00000D0UB240E XHP35B-H0-00000D0UA440E XHP35B-H0-00000D0ZB240G XHP35B-H0-00000D0ZA440G Notes: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp XHP35.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 10 XLAMP ® XHP35.2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - HIGH INTENSITY EASYWHITE® (TJ = 85 °C) - CONTINUED Minimum Luminous Flux @350 mA CRI Nominal CCT Min 70 80 3500 K 90 Typ 80 3000 K 90 3-Step Group Flux (lm) @ 85 °C D2 510 C4 475 C2 440 C4 475 C2 440 B4 410 B4 410 B2 380 A4 355 XHP35B-H0-00000D0UA435H XHP35B-H0-00000D0UA435G A4 355 XHP35B-H0-00000D0ZA435H XHP35B-H0-00000D0ZA435G A2 330 D2 510 C4 475 C2 440 C4 475 C2 440 B4 410 B4 410 B2 380 A4 355 XHP35B-H0-00000D0UA430H XHP35B-H0-00000D0UA430G A4 355 XHP35B-H0-00000D0ZA430H XHP35B-H0-00000D0ZA430G A2 330 95 70 2‑Step Group Group Order Code Group Order Code XHP35B-H0-00000D0BD235E 35E XHP35B-H0-00000D0BC435E XHP35B-H0-00000D0BC235E XHP35B-H0-00000D0HC435G 35G XHP35B-H0-00000D0UB435H 35H 35H 95 Order Code 5-Step XHP35B-H0-00000D0UB235H XHP35B-H0-00000D0ZA235H 35G 35G XHP35B-H0-00000D0HC235G XHP35B-H0-00000D0HC435E 35E XHP35B-H0-00000D0HC235E XHP35B-H0-00000D0HB435G XHP35B-H0-00000D0HB435E XHP35B-H0-00000D0UB435G XHP35B-H0-00000D0UB435E XHP35B-H0-00000D0UB235G 35E XHP35B-H0-00000D0UB235E XHP35B-H0-00000D0UA435E XHP35B-H0-00000D0ZA235G XHP35B-H0-00000D0BD230E 30E XHP35B-H0-00000D0BC430E XHP35B-H0-00000D0BC230E XHP35B-H0-00000D0HC430G 30G XHP35B-H0-00000D0UB430H 30H 30H XHP35B-H0-00000D0UB230H XHP35B-H0-00000D0ZA230H 30G 30G XHP35B-H0-00000D0HC230G XHP35B-H0-00000D0HC430E 30E XHP35B-H0-00000D0HC230E XHP35B-H0-00000D0HB430G XHP35B-H0-00000D0HB430E XHP35B-H0-00000D0UB430G XHP35B-H0-00000D0UB430E XHP35B-H0-00000D0UB230G 30E XHP35B-H0-00000D0UB230E XHP35B-H0-00000D0UA430E XHP35B-H0-00000D0ZA230G Notes: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp XHP35.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 11 XLAMP ® XHP35.2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - HIGH INTENSITY EASYWHITE® (TJ = 85 °C) - CONTINUED Minimum Luminous Flux @350 mA CRI Nominal CCT Min 80 2700 K 90 95 Typ Group Flux (lm) @ 85 °C C2 440 B4 410 B2 380 B2 380 A4 355 A2 330 A2 330 2‑Step Group Order Code 3-Step Group Order Code 5-Step Group XHP35B-H0-00000D0HC227G 27G XHP35B-H0-00000D0UB227H 27H XHP35B-H0-00000D0UA427H 27G XHP35B-H0-00000D0UA227H 27H XHP35B-H0-00000D0ZA227H XHP35B-H0-00000D0HB427G XHP35B-H0-00000D0HC227E 27E XHP35B-H0-00000D0HB427E XHP35B-H0-00000D0HB227G XHP35B-H0-00000D0HB227E XHP35B-H0-00000D0UB227G XHP35B-H0-00000D0UB227E XHP35B-H0-00000D0UA427G XHP35B-H0-00000D0UA227G 27G Order Code 27E XHP35B-H0-00000D0UA427E XHP35B-H0-00000D0UA227E XHP35B-H0-00000D0ZA227G Notes: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp XHP35.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 12 XLAMP ® XHP35.2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - HIGH INTENSITY ANSI (TJ = 85 °C) The following table provides order codes for XLamp XHP35.2 High-Intensity LEDs. For a complete description of how the flux and chromaticity groups are reflected in the bin code and order code nomenclature, please see the Bin and Order Code Formats section (page 28). Nomimal CCT Chromaticity Regions Min 7000- K 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U 80 70 6500 K 1A, 1B, 1C, 1D 80 90 70 5700 K 2A, 2B, 2C, 2D 80 90 70 5000 K Minimum Luminous Flux @ 350 mA CRI 3A, 3B, 3C, 3D 80 90 Typ Order Code Group Flux (lm) @ 85 °C D2 510 XHP35B-H0-0000-0D0HD20DV D4 550 XHP35B-H0-0000-0D0BD40E1 D2 510 XHP35B-H0-0000-0D0BD20E1 C4 475 XHP35B-H0-0000-0D0BC40E1 D2 510 XHP35B-H0-0000-0D0HD20E1 C4 475 XHP35B-H0-0000-0D0HC40E1 C2 440 XHP35B-H0-0000-0D0HC20E1 C4 475 XHP35B-H0-0000-0D0UC40E1 C2 440 XHP35B-H0-0000-0D0UC20E1 B4 410 XHP35B-H0-0000-0D0UB40E1 D4 550 XHP35B-H0-0000-0D0BD40E2 D2 510 XHP35B-H0-0000-0D0BD20E2 C4 475 XHP35B-H0-0000-0D0BC40E2 D2 510 XHP35B-H0-0000-0D0HD20E2 C4 475 XHP35B-H0-0000-0D0HC40E2 C2 440 XHP35B-H0-0000-0D0HC20E2 C4 475 XHP35B-H0-0000-0D0UC40E2 C2 440 XHP35B-H0-0000-0D0UC20E2 B4 410 XHP35B-H0-0000-0D0UB40E2 D4 550 XHP35B-H0-0000-0D0BD40E3 D2 510 XHP35B-H0-0000-0D0BD20E3 C4 475 XHP35B-H0-0000-0D0BC40E3 D2 510 XHP35B-H0-0000-0D0HD20E3 C4 475 XHP35B-H0-0000-0D0HC40E3 C2 440 XHP35B-H0-0000-0D0HC20E3 C2 440 XHP35B-H0-0000-0D0UC20E3 B4 410 XHP35B-H0-0000-0D0UB40E3 B2 380 XHP35B-H0-0000-0D0UB20E3 Notes: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp XHP35.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 13 XLAMP ® XHP35.2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - HIGH INTENSITY ANSI (TJ = 85 °C) - CONTINUED Nomimal CCT Chromaticity Regions Min 70 4500 K 4A, 4B, 4C, 4D 80 90 70 4000 K 5A, 5B, 5C, 5D 80 90 70 3500 K Minimum Luminous Flux @ 350 mA CRI 6A, 6B, 6C, 6D 80 90 Typ Order Code Group Flux (lm) @ 85 °C D4 550 XHP35B-H0-0000-0D0BD40E4 D2 510 XHP35B-H0-0000-0D0BD20E4 C4 475 XHP35B-H0-0000-0D0BC40E4 D2 510 XHP35B-H0-0000-0D0HD20E4 C4 475 XHP35B-H0-0000-0D0HC40E4 C2 440 XHP35B-H0-0000-0D0HC20E4 C2 440 XHP35B-H0-0000-0D0UC20E4 B4 410 XHP35B-H0-0000-0D0UB40E4 B2 380 XHP35B-H0-0000-0D0UB20E4 D4 550 XHP35B-H0-0000-0D0BD40E5 D2 510 XHP35B-H0-0000-0D0BD20E5 C4 475 XHP35B-H0-0000-0D0BC40E5 C2 440 XHP35B-H0-0000-0D0BC20E5 D2 510 XHP35B-H0-0000-0D0HD20E5 C4 475 XHP35B-H0-0000-0D0HC40E5 C2 440 XHP35B-H0-0000-0D0HC20E5 B4 410 XHP35B-H0-0000-0D0UB40E5 B2 380 XHP35B-H0-0000-0D0UB20E5 A4 355 XHP35B-H0-0000-0D0UA40E5 D2 510 XHP35B-H0-0000-0D0BD20E6 C4 475 XHP35B-H0-0000-0D0BC40E6 C2 440 XHP35B-H0-0000-0D0BC20E6 C4 475 XHP35B-H0-0000-0D0HC40E6 C2 440 XHP35B-H0-0000-0D0HC20E6 B4 410 XHP35B-H0-0000-0D0HB40E6 B4 410 XHP35B-H0-0000-0D0UB40E6 B2 380 XHP35B-H0-0000-0D0UB20E6 A4 355 XHP35B-H0-0000-0D0UA40E6 Notes: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp XHP35.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 14 XLAMP ® XHP35.2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - HIGH INTENSITY ANSI (TJ = 85 °C) - CONTINUED Nomimal CCT Chromaticity Regions Min 70 3000 K 7A, 7B, 7C, 7D 80 90 80 2700 K Minimum Luminous Flux @ 350 mA CRI 8A, 8B, 8C, 8D 90 Typ Order Code Group Flux (lm) @ 85 °C D2 510 XHP35B-H0-0000-0D0BD20E7 C4 475 XHP35B-H0-0000-0D0BC40E7 C2 440 XHP35B-H0-0000-0D0BC20E7 C4 475 XHP35B-H0-0000-0D0HC20E7 C2 440 XHP35B-H0-0000-0D0HB40E7 B4 410 XHP35B-H0-0000-0D0HB20E7 B4 410 XHP35B-H0-0000-0D0UB40E7 B2 380 XHP35B-H0-0000-0D0UB20E7 A4 355 XHP35B-H0-0000-0D0UA40E7 C2 440 XHP35B-H0-0000-0D0HC20E8 B4 410 XHP35B-H0-0000-0D0HB40E8 B2 380 XHP35B-H0-0000-0D0HB20E8 B2 380 XHP35B-H0-0000-0D0UB20E8 A4 355 XHP35B-H0-0000-0D0UA40E8 A2 330 XHP35B-H0-0000-0D0UA20E8 Notes: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp XHP35.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 15 XLAMP ® XHP35.2 LED Relative Spectral Power RELATIVE SPECTRAL POWER DISTRIBUTION Relative Radiant Power 100% 80% 60% 6000 K, 70 CRI 5000 K, 70 CRI 40% 3000 K, 80 CRI 20% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Relative Flux Output vs. Junction Temperature RELATIVE FLUX VS. JUNCTION TEMPERATURE (IF = 350 mA) 120% Relative Luminous Flux 100% 80% 60% 40% 20% 0% 25 50 75 100 125 150 Junction Temperature (ºC) © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 16 XLAMP ® XHP35.2 LED Electrical Characteristics (Tj = (T 85°C) ELECTRICAL CHARACTERISTICS = 85 °C) J 1500 Forward Current (mA) 1250 1000 750 500 250 0 9.6 9.8 10.0 10.2 10.4 10.6 10.8 11.0 11.2 11.4 11.6 11.8 12.0 12.2 12.4 12.6 12.8 13.0 13.2 Forward Voltage (V) Relative Intensity vs. Current (Tj = 85°C) RELATIVE FLUX VS. CURRENT (TJ = 85 °C) 325% 300% Relative Luminous Flux 275% 250% 225% 200% 175% 150% 125% 100% 75% 50% 25% 0% 0 250 500 750 1000 1250 1500 Forward Current (mA) © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 17 XLAMP ® XHP35.2 LED RELATIVE CHROMATICITY VS. CURRENT WHITE) Relative Chromaticity Vs. Current, (WARM WW 0.020 0.016 0.012 0.008 0.004 ΔCCx 0.000 ΔCCy -0.004 -0.008 -0.012 -0.016 -0.020 0 250 500 750 1000 1250 1500 Current (mA) RELATIVE CHROMATICITY VS. TEMPERATURE (WARM WHITE) Relative Chromaticity Vs. Temperature WW 0.020 0.016 0.012 0.008 0.004 ΔCCx 0.000 ΔCCy -0.004 -0.008 -0.012 -0.016 -0.020 25 50 75 100 125 150 Tsp (°C) © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 18 XLAMP ® XHP35.2 LED Typical Spatial Radiation Pattern TYPICAL SPATIAL DISTRIBUTION 100% Relative Luminous Intensity 80% 60% XHP35.2 High Density XHP35.2 High Intensity 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) THERMAL DESIGN The maximum forward current is determined by the thermal resistance between the LED junction and ambient. It is crucial for the end Thermal Design product to be designed in a manner that minimizes the thermal resistance from the solder point to ambient in order to optimize lamp life and optical characteristics. 1600 Maximum Current (mA) 1400 1200 1000 800 600 Rj-a = 3°C/W 400 Rj-a = 4°C/W Rj-a = 6°C/W 200 0 Rj-a = 8°C/W 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 19 XLAMP ® XHP35.2 LED PERFORMANCE GROUPS - LUMINOUS FLUX (TJ = 85 °C) XLamp XHP35.2 LEDs are tested for luminous flux and placed into one of the following luminous-flux groups. Group Code Minimum Luminous Flux (lm) @ 350 mA Maximum Luminous Flux (lm) @ 350 mA A2 330 355 A4 355 380 B2 380 410 B4 410 440 C2 440 475 C4 475 510 D2 510 550 D4 550 590 E2 590 635 E4 635 680 © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 20 XLAMP ® XHP35.2 LED PERFORMANCE GROUPS - CHROMATICITY XLamp XHP35.2 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Bin Code 50H 45H 40H 35H 30H 27H CCT 5000 K 4500 K 4000 K 3500 K 3000 K 2700 K x y 0.3429 0.3507 0.3434 0.3571 0.3475 0.3604 0.3469 0.3539 0.3643 0.3720 0.3597 0.3689 0.3587 0.3620 0.3628 0.3647 0.3777 0.3739 0.3797 0.3816 0.3861 0.3855 0.3838 0.3777 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 50G 45G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 4500 K 0.3611 0.3658 0.00852 0.00330 61.5 40G 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 21 XLAMP ® XHP35.2 LED PERFORMANCE GROUPS – CHROMATICITY (CONTINUED) EasyWhite Color Temperatures – 5-Step Ellipse Bin Code CCT 57E Center Point Minor Axis Rotation Angle (°) x y a b 5700 K 0.3287 0.3417 0.01230 0.00600 72.0 50E 5000 K 0.3447 0.3553 0.01400 0.00520 65.0 45E 4500 K 0.3611 0.3658 0.01420 0.00550 61.5 40E 4000 K 0.3818 0.3797 0.01565 0.00670 53.7 35E 3500 K 0.4073 0.3917 0.01545 0.00690 54.0 30E 3000 K 0.4338 0.4030 0.01390 0.00680 53.2 27E 2700 K 0.4577 0.4099 0.01350 0.00700 48.5 ANSI White Bins CCT Major Axis Bin Code 0A0 0B0 7000 K 0C0 0D0 ANSI White Bins x y 0.2950 0.2920 0.2984 0.3133 0.3009 0.3042 0.2920 0.2895 0.2962 0.3220 0.2984 0.3133 0.2984 0.3133 0.2962 0.3220 0.3028 0.3304 0.3048 0.3207 0.2984 0.3048 0.3068 0.3113 0.3009 0.3042 CCT Bin Code ANSI White Bins x y 0.2970 0.2980 0.3060 0.2950 0.3009 0.3042 0.3037 0.2937 0.3060 0.2895 0.3135 0.2870 0.2937 0.3312 0.2962 0.3220 0.2962 0.3220 0.2937 0.3312 0.3005 0.3415 0.3028 0.3304 0.3133 0.3037 0.3207 0.3009 0.3068 0.3113 0.3093 0.2993 0R0 0S0 7000 K 0T0 0U0 CCT Bin Code x y 0.2880 0.3048 0.3207 0.2970 0.3130 0.3290 0.3144 0.3186 0.3068 0.3113 0.3135 0.3028 0.3304 0.3210 0.3115 0.3391 0.3130 0.3290 0.3048 0.3207 0.3115 0.3391 0.3205 0.3481 0.3213 0.3373 0.3130 0.3290 0.2937 0.3130 0.3290 0.3042 0.3213 0.3373 0.3221 0.3261 0.3144 0.3186 1A0 1B0 7000 K © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. 1C0 1D0 CLD-DS199 REV 7 22 XLAMP ® XHP35.2 LED PERFORMANCE GROUPS – CHROMATICITY (CONTINUED) ANSI White Bins CCT Bin Code 1R0 1S0 7000 K 1T0 1U0 ANSI White Bins x y 0.3068 0.3144 0.3161 0.3059 0.3093 0.2993 0.3005 0.3099 0.3115 0.3391 0.3028 0.3304 0.3099 0.3509 0.3196 0.3602 0.3205 0.3481 0.3115 0.3391 0.3144 0.3221 0.3231 0.3120 0.3161 0.3059 CCT x y 0.3113 0.3215 0.3186 0.3290 0.3290 0.3300 0.3222 0.3243 0.3415 0.3207 0.3509 0.3290 0.3290 0.3417 0.3215 0.3350 0.3290 0.3538 0.3376 0.3616 0.3371 0.3490 0.3290 0.3417 0.3186 0.3290 0.3261 0.3371 0.3366 0.3369 0.3290 0.3300 2A0 2B0 6000 K 2C0 2D0 ANSI White Bins CCT Bin Code 3A0 3B0 5000 K 3C0 3D0 Bin Code ANSI White Bins CCT x y 0.3350 0.3222 0.3243 0.3417 0.3290 0.3300 0.3290 0.3180 0.3231 0.3120 0.3462 0.3196 0.3602 0.3538 0.3290 0.3690 0.3290 0.3538 0.3207 0.3462 0.3290 0.3690 0.3381 0.3762 0.3376 0.3616 0.3290 0.3538 0.3417 0.3290 0.3300 0.3490 0.3366 0.3369 0.3361 0.3245 0.3290 0.3180 2R0 2S0 6000 K 2T0 2U0 ANSI White Bins x y 0.3371 0.3490 0.3451 0.3554 0.3440 0.3427 0.3366 0.3376 0.3463 0.3687 0.3451 0.3554 0.3371 0.3490 0.3463 0.3687 0.3551 0.3760 0.3533 0.3620 0.3451 0.3451 0.3533 0.3620 0.3515 0.3487 0.3440 0.3427 CCT Bin Code ANSI White Bins x y 0.3530 0.3597 0.3615 0.3659 0.3512 0.3465 0.3369 0.3515 0.3616 0.3548 0.3641 0.3804 0.3530 0.3597 4A0 4B0 Bin Code CCT Bin Code x y 0.3670 0.3578 0.3702 0.3722 0.3825 0.3798 0.3487 0.3783 0.3646 0.3736 0.3702 0.3722 0.3736 0.3874 0.3869 0.3958 0.3825 0.3798 0.3825 0.3798 0.3869 0.3958 0.4006 0.4044 5A0 5B0 0.3533 0.362 0.3641 0.3804 0.3736 0.3874 0.3702 0.3722 0.3554 0.3615 0.3659 0.3950 0.3875 0.3554 0.3615 0.3659 0.3783 0.3646 0.3702 0.3722 0.3825 0.3798 0.3670 0.3578 0.3950 0.3875 0.3590 0.3521 0.3898 0.3716 4500 K 4C0 4D0 4000 K © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. 5C0 5D0 CLD-DS199 REV 7 23 XLAMP ® XHP35.2 LED PERFORMANCE GROUPS – CHROMATICITY (CONTINUED) ANSI White Bins CCT Bin Code 6A0 6B0 3500 K 6C0 6D0 ANSI White Bins x y 0.3889 0.3941 0.4080 0.3916 0.4017 0.3751 0.3941 0.3996 0.4146 0.4089 0.4080 0.3916 0.4080 0.3916 0.4146 0.4089 0.4299 0.4165 0.4221 0.3984 0.4017 0.4080 0.4221 0.3984 0.4147 0.3814 CCT Bin Code ANSI White Bins x y 0.3690 0.4147 0.3848 0.4221 0.4342 0.4028 0.4259 0.3853 0.3848 0.4221 0.4015 0.4299 0.4430 0.4212 0.4342 0.4028 0.4342 0.4028 0.4430 0.4212 0.4562 0.4260 0.4465 0.4071 0.3751 0.4259 0.3916 0.4342 0.4465 0.4071 0.4373 0.3893 7A0 7B0 3000 K 7C0 7D0 CCT Bin Code x y 0.3814 0.4373 0.3893 0.3984 0.4465 0.4071 0.4582 0.4099 0.4483 0.3919 0.3984 0.4465 .04071 0.4165 0.4562 0.4260 0.4687 0.4289 .04582 0.4099 0.4582 0.4099 0.4687 0.4289 0.4813 0.4319 0.4700 0.4126 0.3853 0.4483 0.3919 0.4028 0.4582 0.4099 0.4700 0.4126 0.4593 0.3944 8A0 8B0 2700 K © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. 8C0 8D0 CLD-DS199 REV 7 24 XLAMP ® XHP35.2 LED EASYWHITE® CHROMATICITY REGIONS PLOTTED ON THE 1931 CIE CURVE 0.44 ANSI C78.377 Quadrangle 0.43 EasyWhite 5-Step EasyWhite 3-Step 0.42 3500 K EasyWhite 2-Step 0.41 XHP35.2 High Density 2700 K 3000 K 4000 K 0.40 4500 K 0.39 5000 K 0.38 CCy 0.37 5700 K 0.36 6500 K 0.35 0.34 8000 K 0.33 0.32 0.31 0.30 0.29 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.27 0.28 CCx 0.44 ANSI C78.377 Quadrangle 0.43 EasyWhite 5-Step EasyWhite 3-Step 0.42 3500 K EasyWhite 2-Step 0.41 XHP35.2 High Intensity 2700 K 3000 K 4000 K 0.40 4500 K 0.39 5000 K 0.38 CCy 0.37 5700 K 0.36 6500 K 0.35 0.34 8000 K 0.33 0.32 0.31 0.30 0.29 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.27 0.28 CCx © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 25 XLAMP ® XHP35.2 LED STANDARD COOL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.40 0.40 5000 K 0.39 0.38 0.38 5700 K 5700 K DV 0.37 0.37 6500 K 6500 K 2T 0.36 0.36 2S DT 0.34 1D ANSI C78.377A 1U 0D 0A 0.31 1R 0C 0B 1D 0A ANSI C78.377A 1R 0U 0.36 0.35 0.30 0.29 0.28 0.36 0.35 0.34 0.33 0.32 0.31 0.28 0.30 0.28 0.34 0R 0.29 CCx CCx 0.40 0.40 5000 K 0.39 0.38 0.38 3S 6500 K 0.35 1T 0T 0.33 0S 0.32 0C 0.31 3R 2A 1D 0T 0S 1R 0C 0A 3R 2A 2U 1D ANSI C78.377A 2R 1A 0D 2D 1C 1B 0B 3A 2B 1S 0.31 1U 1R 0U 0.30 0U 0.30 8000 K 0.34 0.32 ANSI C78.377A 2R 1U 2C 1T 0.33 2U 1A 0D 0A 2D 1C 1B 0B 3A 2B 1S 3B 2S 0.35 2C 3S 2T 0.36 3B 2S 8000 K 0.34 6500 K 2T E1 5700 K E2 0.37 CCy 0.36 5000 K 0.39 5700 K 0.37 0R 0R 0.29 0.29 CCx © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.29 0.28 0.28 0.28 CCy 2U 2R 1U 0D 0R 0.29 2A 1A 0.30 0.29 0.28 2D 1C 1B 0S 0.32 0U 0.30 1S 0T 0.33 2U 2R 1A 0.34 2B 0.33 0.31 2A 1B 0C 0B 2D 1C 2C 1T 8000 K 0.32 0S 0.32 0.35 2B 1S 0T 0.33 2C 1T 2T 2S 0.31 8000 K CCy 0.35 CCy 5000 K 0.39 CCx CLD-DS199 REV 7 26 XLAMP ® XHP35.2 LED STANDARD WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.45 0.44 0.43 E7 0.42 3500 K 4000 K 0.40 0.39 5000 K 0.38 4500 K E4 4B 3C 0.36 3B 3D 0.35 2700 K 8C 7B 6C 6B 8A 7D 7A 5C 8D 6D 5B 4C E3 0.37 E5 8B 7C E6 0.41 CCy E8 3000 K 6A ANSI C78.377A 5D 5A 4D 4A 3A 0.34 0.50 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.33 CCx © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 27 XLAMP ® XHP35.2 LED BIN AND ORDER CODE FORMATS Bin codes and order codes for XHP35.2 LEDs are configured in the following manner: Order Code SSSSSS-BD-GGGG-HJKLMMNNN Bin Code Series XHP35B = XHP35.2 Series XHP35B = XHP35.2 Internal code Chromaticity group Minimum luminous flux group Luminous flux group Chromaticity group Voltage performance group CRI specification 0 = No minimum CRI B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Z = 95 CRI minimum CRI specification 0 = No minimum CRI B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Z = 95 CRI minimum Vf class SSSSSS-B-NNN-MMM-JK-L-PP Configuration B: Version 0 = High density H = High intensity D: Reel size © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. Internal code Vf class Version 0 = High density H = High intensity CLD-DS199 REV 7 28 XLAMP ® XHP35.2 LED REFLOW SOLDERING CHARACTERISTICS In testing, Cree LED has found XLamp XHP35.2 LEDs to be compatible with JEDEC J‑STD‑020C, using the parameters listed below. As a general guideline, Cree LED recommends that users follow the recommended soldering profile provided by the manufacturer of the solder paste used, and therefore it is the lamp or luminaire manufacturer’s responsibility to determine applicable soldering requirements. Note that this general guideline may not apply to all PCB designs and configurations of reflow soldering equipment. tP TP Critical Zone TL to TP Temperature Ramp-up TL tL Tsmax Tsmin Ramp-down ts Preheat 25 t 25˚C to Peak Profile Feature Average Ramp-Up Rate (Tsmax to Tp) IPC/JEDEC J-STD-020C Time Lead-Free Solder 1.2 °C/second Preheat: Temperature Min (Tsmin) 120 °C Preheat: Temperature Max (Tsmax) 170 °C Preheat: Time (tsmin to tsmax) 65-150 seconds Time Maintained Above: Temperature (TL) Time Maintained Above: Time (tL) 217 °C 45-90 seconds Peak/Classification Temperature (Tp) 235 - 245 °C Time Within 5 °C of Actual Peak Temperature (tp) 20-40 seconds Ramp-Down Rate 1 - 6 °C/second Time 25 °C to Peak Temperature 4 minutes max. Note: All temperatures refer to the topside of the package, measured on the package body surface. © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 29 XLAMP ® XHP35.2 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. Moisture Sensitivity Cree LED ecommends keeping XLamp LEDs in the provided, resealable moisture-barrier packaging (MBP) until immediately prior to soldering. Unopened MBPs that contain XLamp LEDs do not need special storage for moisture sensitivity. Once the MBP is opened, XLamp XHP35.2 LEDs may be stored as MSL 1 per JEDEC J-STD-033, meaning they have unlimited floor life in conditions of ≤ 30 ºC/85% relative humidity (RH). Regardless of the storage condition, Cree LED recommends sealing any unsoldered LEDs in the original MBP. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACH Compliance REACH substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACH SVHC Declaration. REACH banned substance information (REACH Article 67) is also available upon request. © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 30 XLAMP ® XHP35.2 LED NOTES - CONTINUED UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 31 XLAMP ® XHP35.2 LED MECHANICAL DIMENSIONS Thermal vias, if present, are not shown on these drawings. All dimensions are ±.13 mm unless otherwise indicated. XHP35.2 High Density 8 7 6 4 5 OPTICAL MODEL ORIGIN 3.30 2.65 3.45 1 2 3 2.30 0.56 1.30 F 3.45 3.30 F E E CATHODE SIDE R1.85 SIDE VIEW Side View 0.50 XHP35.2 High Intensity 7 8 6 0.50 0.56 0.18 0.83 3.30 2.30 1.30 C F 3.30 3.45 B E 3.30 CATHODE SIDE RECOMMENDED STENCIL OPENING ANODE SIDE A OPTICAL MODEL ORIGIN UNLESS OTHERWISE SPECIFIED: R0.05 SIDE VIEW Side View 7 5 0.50 B 1.30 3.30 REV UPDATE TO OPTICAL ORIGIN INITIAL DRAWING RELEASED INTERPRET GEOMETRIC TOLERANCING PER: MATERIAL DRAWN TLING 24NOV21 TITLE: CHECKED 2610-350007 XHP35 HD ENG APPR. MFG APPR. Q.A. THIRD ANGLE PROJECTION SIZE DWG. NO. FINISH B SHEET 1 OF 1 SCALE: 50:1 WEIGHT: APPLICATION 3 1 2 1 0.18 2 REV C MATERIAL FINISH DESCRIPTION D C 0.56 0.29 3.30 3.30 C A Bottom View 0.184 0.83 6 0.56 B DIMENSIONS ARE IN MILLIMETERS TOLERANCES: • ANGULAR: MACH 0.5° BEND 1° • ONE PLACE DECIMAL 0.5 • TWO PLACE DECIMAL 0.05 • INSIDE BEND RADII EQUAL MATERIAL • MACHINE/CASTING RADII 0.50 • RADII AND DIA: 0.10 CreeLED, Inc. 4400 SILICON DR DURHAM, NC 27703 B 3.30 © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree RECOMMENDED PCB FOOTPRINT RECOMMENDED STENCIL OPENING LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 32 A UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS TOLERANCES: DRAWN NAME DATE TLING 24NOV21 CreeLED, Inc. 4400 SILICON DR DURHAM, NC 27703 HI 0.50 PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF CREE LED. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT WRITTEN PERMISSION OF CREE LED IS PROHIBITED. © 2021 CreeLED, Inc. a subsidiary of SMART Global Holdings, Inc. 0.09 0.43 Top View 0.50 8 SOLDERMASK MAY BE PRESENT BOTTOM VIEW DATE 0.18 TOP VIEW A D NAME 2610-350007 XHP35 HD RECOMMENDED PCB FOOTPRINT DRAWING FILENAME 3.30 0.18 1.30 E 0.09 B 1 2 3 0.56 F 0.29 3.30 3.30 1.00 D Bottom View 4 OPTICAL MODEL ORIGIN C BOTTOM VIEW 5 3.45 SOLDERMASK MAY BE PRESENT 0.18 0.50 TOP VIEW Top View 0.43 D 0.50 ANODE SIDE R0.05 OPTICAL MODEL ORIGIN 1.30 3.30 F 3.45 XLAMP ® XHP35.2 LED E CATHODE SID MECHANICAL DIMENSIONS - CONTINUED 0.50 0.56 0.18 1.30 3.30 0.18 0.56 0.29 3.30 3.30 0.83 0.50 BOTTOM VIEW 3.30 0.18 0.43 0.50 B SOLDERMASK MAY BE PRESENT SIDE VIEW D C 0.50 ANODE SIDE R0.05 OPTICAL MODEL ORIGIN 0.09 XHP35.2 High Density and XHP35.2 High Intensity TOP VIEW R1.85 RECOMMENDED PCB FOOTPRINT RECOMMENDED STENCIL OPENING Recommended PCB Footprint Recommended Stencil Openings* UNLESS OTHERWISE SPECIFIED: Notes: • • * DIMENSIONS ARE IN MILLIMETERS TOLERANCES: • ANGULAR: MACH 0.5° BEND 1° • ONE PLACE DECIMAL 0.5 • TWO PLACE DECIMAL 0.05 • INSIDE BEND RADII EQUAL MATERIAL • MACHINE/CASTING RADII 0.50 • RADII AND DIA: 0.10 A DRAWN NAME DATE TLING 24NOV21 CHECKED Cree LED recommends using thermal pad kickouts to maximize component thermal performance. Cree LED recommends using white solder mask material to minimize system optical loss. This stencil has been tested and optimized for the avoidance of voiding when using ALPHA® LUMET® P30 Maxrel solder paste. For other solder 5 4 7 8 6 3LED Field Applications 2 2 pastes, a “window pane” design for the thermal pad stencil may result in a lower voiding percentage. Contact your local Cree Engineer for consultation regarding your specific application. PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF CREE LED. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT WRITTEN PERMISSION OF CREE LED IS PROHIBITED. © 2021 CreeLED, Inc. a subsidiary of SMART Global Holdings, Inc. © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. B UPDATE TO OPTICAL ORIGIN A INITIAL DRAWING RELEASED REV DESCRIPTION INTERPRET GEOMETRIC TOLERANCING PER: MATERIAL MFG APPR. Q.A. THIRD ANGLE PROJECTION MATERIAL FINISH FINISH APPLICATION CLD-DS199 REV 7 TITLE: ENG APPR. 33 SIZE DW C SCALE: 5 1 XLAMP ® XHP35.2 LED TAPE AND REEL All Cree LED carrier tapes conform to EIA-481D, Automated Component Handling Systems Standard. Except as noted, all dimensions in mm [inches] Po T E Do Bo R P2 W Anode side A F A P1 B D1 "H" Ko B-B SECTION Bo (on a place in the bottom of the corner radii) Ao (on a place in the bottom of the corner radii) R "I" Ao ITEM Dim. XHP35.2 High Density Item Dimension 3.60 P2 T E 3.35 4.00 8.00 2.00 0.36 1.75 D1 W R 1.50 12.00 3deg Ko 5.40 5.40 Do Dim. NOTICE P1 Bo XHP35.2 High Density 1.50 5.50 Ao Po Ao XHP35B-0x-xxxx-xxxxxxxxx ITEM F DETAIL"H" DETAIL"I" A-A SECTION Bo Ko Po P1 P2 T E F Do D1 W R 3.60 3.00 4.00 8.00 2.00 0.30 1.75 5.50 1.50 1.50 12.00 3° 1) All Cree LED carrier tapes conform to EIA-481D, Automated Component handling Systems Standard 2) Measurement tolerances unless indicated otherwise: .xx = ±.15 mm XHP35.2 High Intensity XHP35B-Hx-xxxx-xxxxxxxxx Item Dimension XHP35.2 High Intensity Ao Bo Ko Po P1 P2 T E F Do D1 W R 3.70 3.70 1.20 4.00 8.00 2.00 0.30 1.75 5.50 1.50 1.50 12.00 3° 2402-M022 XML3 © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 34 XLAMP ® XHP35.2 LED TAPE AND REEL - CONTINUED XHP35.2 High Density Feed Direction END START Trailer Loaded Pockets Leader Min. 160 mm empty pockets sealed with tape 500 Lamps Min. 400 mm empty pockets with min. 100 mm sealed Feed Direction Cover Tape Pocket Tape 13 mm 7” © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 35 XLAMP ® XHP35.2 LED TAPE AND REEL - CONTINUED XHP35.2 High Intensity Feed Direction END START Trailer Loaded Pockets Leader Min. 160 mm empty pockets sealed with tape 1000 Lamps Min. 400 mm empty pockets with min. 100 mm sealed Feed Direction Cover Tape Pocket Tape 13 mm 7” © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 36 XLAMP ® XHP35.2 LED PACKAGING © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 37 XLAMP ® XHP35.2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS The following order codes are active and valid order codes, but higher performance options are also available. Please see page 3— page 5 for order codes of XLamp XHP35.2 High Density LEDs that could serve as alternatives for the order codes set forth below. XHP35.2 High Density EasyWhite®, TJ = 85 °C Group Flux (lm) @ 85 °C 70 D4 80 Min 5700 K 5000 K 4500 K Minimum Luminous Flux @350 mA CRI Nominal CCT Typ 2-Step Group Order Code 3-Step Group Order Code 5-Step Group Order Code 550 57E XHP35B-00-00000D0BD457E D2 510 57E XHP35B-00-00000D0HD257E 90 B4 410 57E XHP35B-00-00000D0UB457E 70 D4 550 50E XHP35B-00-00000D0BD450E 80 D2 510 50E XHP35B-00-00000D0HD250E 90 B4 410 50E XHP35B-00-00000D0UB450E 70 D4 550 45E XHP35B-00-00000D0BD445E 80 D2 510 45E XHP35B-00-00000D0HD245E 90 B4 410 45E XHP35B-00-00000D0UB445E D4 550 70 4000 K 40E D2 510 80 D2 510 70 D2 510 80 C4 475 35G 3000 K 80 C4 475 2700 K 80 C2 440 XHP35B-00-00000D0BD240E 40E XHP35B-00-00000D0HD240E 35E XHP35B-00-00000D0BD235E XHP35B-00-00000D0HC435G 35E XHP35B-00-00000D0HC435E 30G XHP35B-00-00000D0HC430G 30E XHP35B-00-00000D0HC430E 27G XHP35B-00-00000D0HC227G 27E XHP35B-00-00000D0HC227E 40G 3500 K XHP35B-00-00000D0HD240G XHP35B-00-00000D0BD440E Notes: • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 38 XLAMP ® XHP35.2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 6— page 8 for order codes of XLamp XHP35.2 High Density LEDs that could serve as alternatives for the order codes set forth below. XHP35.2 High Density ANSI, TJ = 85 °C Nomimal CCT Minimum Luminous Flux @ 350 mA CRI Chromaticity Regions Min Typ Group Flux (lm) @ 85 °C Order Code 7000 K 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U 90 B4 410 XHP35B-00-0000-0D0UB40DT 6500 K 1A, 1B, 1C, 1D 90 B4 410 XHP35B-00-0000-0D0UB40E1 6000 K 1A, 1B, 1C, 1D 90 B4 410 XHP35B-00-0000-0D0UB40DV D4 550 XHP35B-00-0000-0D00D40E2 70 D4 550 XHP35B-00-0000-0D0BD40E2 80 D2 510 XHP35B-00-0000-0D0HD20E2 0 5700 K 2A, 2B, 2C, 2D 68 90 B4 410 XHP35B-00-0000-0D0UB40E2 D4 550 XHP35B-00-0000-0D00D40E3 70 D4 550 XHP35B-00-0000-0D0BD40E3 80 D2 510 XHP35B-00-0000-0D0HD20E3 0 5000 3A, 3B, 3C, 3D 68 90 B4 410 XHP35B-00-0000-0D0UB40E3 D4 550 XHP35B-00-0000-0D00D40E4 70 D4 550 XHP35B-00-0000-0D0BD40E4 80 D2 510 XHP35B-00-0000-0D0HD20E4 0 4500 K 4A, 4B, 4C, 4D 68 90 0 4000 K 5A, 5B, 5C, 5D 70 68 B4 410 XHP35B-00-0000-0D0UB40E4 D4 550 XHP35B-00-0000-0D00D40E5 D2 510 XHP35B-00-0000-0D00D20E5 D4 550 XHP35B-00-0000-0D0BD40E5 D2 510 XHP35B-00-0000-0D0BD20E5 80 D2 510 XHP35B-00-0000-0D0HD20E5 70 D2 510 XHP35B-00-0000-0D0BD20E6 80 C4 475 XHP35B-00-0000-0D0HC40E6 3500 K 6A, 6B, 6C, 6D 3000 K 7A, 7B, 7C, 7D 80 C4 475 XHP35B-00-0000-0D0HC40E7 2700 K 8A, 8B, 8C, 8D 80 C2 440 XHP35B-00-0000-0D0HC20E8 Notes: • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 39 XLAMP ® XHP35.2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 9— page 12 for order codes of XLamp XHP35.2 High Intensity LEDs that could serve as alternatives for the order codes set forth below. XHP35.2 High Intensity EasyWhite®, TJ = 85 °C Minimum Luminous Flux @350 mA CRI Nominal CCT Group Flux (lm) @ 85 °C B4 410 B2 380 A4 355 80 B4 410 90 A4 355 80 B4 410 90 A4 355 4000 K 80 B4 410 3500 K 90 A2 330 80 B2 380 90 A2 330 Min 80 5700 K Typ 2‑Step Group Order Code 3-Step Group Order Code 90 5-Step Group Order Code 57E XHP35B-H0-00000D0HB457E 57E 5000 K 50H 4500 K 45H 35H 3000 K 30H XHP35B-H0-00000D0UA450H XHP35B-H0-00000D0UA445H XHP35B-H0-00000D0UA235H XHP35B-H0-00000D0UA230H XHP35B-H0-00000D0UB257E XHP35B-H0-00000D0UA457E 50G XHP35B-H0-00000D0HB450G 50E XHP35B-H0-00000D0HB450E 50G XHP35B-H0-00000D0UA450G 50E XHP35B-H0-00000D0UA450E 45G XHP35B-H0-00000D0HB445G 45E XHP35B-H0-00000D0HB445E 45G XHP35B-H0-00000D0HB445G 45E XHP35B-H0-00000D0UA445E 40G XHP35B-H0-00000D0HB440G 40E XHP35B-H0-00000D0HB440E 35G XHP35B-H0-00000D0UA235G 35E XHP35B-H0-00000D0UA235E 30G XHP35B-H0-00000D0HB230G 30E XHP35B-H0-00000D0HB230E 30G XHP35B-H0-00000D0UA230G 30E XHP35B-H0-00000D0UA230E Notes: • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 40 XLAMP ® XHP35.2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 13 —page 15 for order codes of XLamp XHP35.2 High Intensity LEDs that could serve as alternatives for the order codes set forth below. XHP35.2 High Intensity ANSI, TJ = 85 °C Nomimal CCT Chromaticity Regions Min 80 6500 K 1A, 1B, 1C, 1D 90 80 5700 K Minimum Luminous Flux @ 350 mA CRI 2A, 2B, 2C, 2D Typ Order Code Group Flux (lm) @ 85 °C B4 410 XHP35B-H0-0000-0D0HB40E1 B2 380 XHP35B-H0-0000-0D0UB20E1 A4 355 XHP35B-H0-0000-0D0UA40E1 B4 410 XHP35B-H0-0000-0D0HB40E2 B2 380 XHP35B-H0-0000-0D0UB20E2 A4 355 XHP35B-H0-0000-0D0UA40E2 80 B4 410 XHP35B-H0-0000-0D0HB40E3 90 A4 355 XHP35B-H0-0000-0D0UA40E3 80 B4 410 XHP35B-H0-0000-0D0HB40E4 90 A4 355 XHP35B-H0-0000-0D0UA40E4 90 5000 K 3A, 3B, 3C, 3D 4500 K 4A, 4B, 4C, 4D 4000 K 5A, 5B, 5C, 5D 80 B4 410 XHP35B-H0-0000-0D0HB40E5 3500 K 6A, 6B, 6C, 6D 90 A2 330 XHP35B-H0-0000-0D0UA20E6 3000 K 7A, 7B, 7C, 7D 80 B2 380 XHP35B-H0-0000-0D0HB20E7 90 A2 330 XHP35B-H0-0000-0D0UA20E7 Notes: • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). © 2018-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS199 REV 7 41
XHP35B-00-0000-0D0HE20E5 价格&库存
很抱歉,暂时无法提供与“XHP35B-00-0000-0D0HE20E5”相匹配的价格&库存,您可以联系我们找货
