60300 Series Jacks
2.5G, 5G and 10G Solutions
Stewart Connector’s 60300 Series Jacks are designed for use in 2.5G, 5G
and 10GBase-T Ethernet applications. Stewart Connector has engineered
this series of connectors to accommodate all Ethernet applications in one
simplistic design. Stewart Connector is the only manufacturer to provide
reliable 10GBase-T Ethernet in a passive connector application.
• The 60300 series is one of the only RJ45 connectors on the market
today which has the electrical performance characteristics required to
deliver 10GBase-T Ethernet signals.
• The 60300 series gives equipment designers a connector which
is capable of performing in 2.5G and 5GBase-T devices which are
designed to operated over existing structured cabling systems.
Unique Benefits of the 60300 Series
• The unique contact design of the connector addresses cross talk and
return loss issues which are common when using RJ45 connectors in
high frequency applications
• The compact design containing the smallest footprint available in
the market provides a viable robust solution when PCB space is at a
premium
• 45 degree, 90 degree and 180 degree shielded and unshielded
versions available
• Compatible for use in applications where POE is necessary accommodating 15W through 100W power requirements
• Non-LED options are IR reflow compatible
• Selectively plated contacts with 50 micro-inches of gold
• RoHS compliant
Part Numbers
Part Number
Shield Type
Orientation
LEDs
SS-60300-011
SS-60300-059
SS-60300-046
SS-60300-079
SS-60300-080
SS-60300-081
SS-60300-101
SS-60300-102
SS-60300-103
SS-60300-104
Panel Grounds
Panel Grounds
Panel Grounds
No Panel Grounds
No Panel Grounds
No Panel Grounds
Panel Grounds
Panel Grounds
No Panel Grounds
No Panel Grounds
Horizontal (90)
45 Degree Angled
Vertical (180)
Horizontal (90)
Vertical (180)
45 Degree Angled
Horizontal (90)
Vertical (180)
Horizontal (90)
Vertical (180)
None
None
None
None
None
None
Bi-Color G/Y
Bi-Color G/Y
Bi-Color G/Y
Bi-Color G/Y
Stewart Connector
11118 Susquehanna Trail South
Glen Rock, PA 17327-9199
+1 717.235.7512
techhelp@belf.com
belfuse.com/stewart-connector
© 2020 Stewart Connector
很抱歉,暂时无法提供与“SS-60300-104”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+29.190841+3.48812
- 10+23.7963010+2.84351
- 25+21.9399725+2.62169
- 40+21.0419640+2.51438
- 84+19.7019384+2.35426
- 252+17.87316252+2.13573
- 504+16.80835504+2.00849
- 1008+15.807271008+1.88887
- 2436+15.447892436+1.84593
