Qwik RJ45TM Cat6/Cat5E
Modular Plugs
Stewart Connector’s Qwik RJ45TM CAT6/CAT5E Modular Plugs are
designed to be terminated to industry standard CAT5E and CAT6 cables
while reducing assembly time and improving termination quality in the field.
Qwik RJ45TM CAT6/CAT5E Modular Plugs allow the installer to insert the
cable into the connector prior to trimming conductors to required
length. Stewart Connector’s 2940263-02 termination tool trims the cable
conductors to required length while terminating the plug contacts. The
Qwik RJ45TM Modular Plug eliminates the pre-trim step needed to assemble
traditional RJ45 Modular Plugs reducing termination time.
Features & Benefits
Designed for quick and easy field termination
CAT5E and CAT6 performance rated
50 micro inches of gold plating on contacts
Contact designed for use on solid or stranded conductor cable
Terminates to cable diameter of up to .235”
Accommodates conductor diameters of .037” to .042”
Designed to terminate 24AWG and 26AWG conductors
Optional snagless slimline strain relief boot available
Capable of field or factory termination with Stewart Connector
2940263-02 or other available quick termination tools
Part Number
Description
SS-39500-001
Qwik RJ45TM CAT6/CAT5E Plug Pack of 50
SS-39500-002
Qwik RJ45TM CAT6/CAT5E Plug Pack of 100
SS-39500-003
Strain Relief Boot CAT6/CAT5E, Pack of 50
SS-39500-004
Strain Relief Boot CAT6/CAT5E, Pack of 100
SS-39500-005
Qwik RJ45TM CAT6/CAT5E Plug With boot, Pack of 50
SS-39500-006
Qwik RJ45TM CAT6/CAT5E Plug With boot, Pack of 100
2940263-02
Qwik RJ45TM Termination Tool
2905090-02
Qwik RJ45™ Replacement Trim Blades for Termination Tool
Stewart Connector
11118 Susquehanna Trail South
Glen Rock, PA 17327-9199
+1 717.235.7512
techhelp@belf.com
belfuse.com/stewart-connector
© 2018 Stewart Connector
ds-stw-qwik-cat6-cat5e-rj45-modular-plugs
很抱歉,暂时无法提供与“SS-39500-002”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+303.813931+36.47794
- 10+255.6790710+30.69854
