Multi Axis Punch Down Plugs
Cat6 and Cat6a Ethernet Solutions
Stewart Connector’s Multi Axis Punch Down Plugs offer time saving
solutions for unique Ethernet connections that require field terminations.
These plugs have a termination option with a top, bottom or side entry.
Features & Benefits
The Multi Axis Punch Down Plugs are designed for quick and easy
field terminations
The Cat6 punch down plug is suitable for use in 1G Base-T networks
and the Cat6a for 10G Base-T networks
Contact designed for use on solid or stranded conductor cable
50 micro-inches of gold plating on contacts for increased cycle life
Easy to use color coded conductor pre-load wire manager
Terminates 22-26 AWG cable with a diameter over the insulation of
up to 1.6mm (.063in)
Accepts an overall cable OD of 6mm (.236in) to 8mm (.315in)
IP20 rated
Applications
Suitable for both shielded and unshielded applications
Compression strain relief
No termination tooling required
Adequate for Power Over Ethernet applications
Utilizes robust zinc die-cast housings and latch protectors
Each plug kits includes termination instructions
Part Numbers
Part Number
Lan Category
Wire Gauge
Cable OD
in
mm
SS-39300-003
Cat6
22-26 AWG
.236-.315in
6-8mm
SS-39300-004
Cat6a
22-26 AWG
.236-.315in
6-8mm
Stewart Connector
11118 Susquehanna Trail South
Glen Rock, PA 17327-9199
+1 717.235.7512
techhelp@belf.com
belfuse.com/stewart-connector
© 2019 Stewart Connector
很抱歉,暂时无法提供与“SS-39300-004”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 4+152.61263
- 16+149.77125
- 31+146.91777
- 61+144.16102
