SS-74810-004
SS-74810-004
    STEWARTCONNECTOR
    插件
    模块化连接器 - 插孔 8p8c(RJ45,以太网) 90°角(直角) 屏蔽式,EMI指
SS-74810-004 数据手册
RJ45 Press-Fit Connectors Stewart Connector’s RJ45 Press-Fit connectors are designed to eliminate the use of soldering in the assembly process, effectively lowering manufacturing costs and improving the reliability of the connector during the product’s life cycle. By removing the need for soldering in the assembly process, Stewart’s Press-Fit series eliminates the chances of cold solder joints and solder flux contamination. Stewart’s RJ45 Press-Fit connectors can achieve 1G through 2.5G Base-T Ethernet speeds. Features • • • • • • • • Operating temperature: -40°C to 85°C Current rating: 1.5 A (maximum) @ 25°C All available options are shielded All configurations are right-angle (90°) Multiple LED and port configurations Low profile tab up design 50 micro inches gold plating RoHS compliant Applications • • • • • • • Networking equipment Home and office equipment Security systems Video game systems IOT applications Portable storage devices Printers and scanners Part Number Selection Guide Part Number Tab Orientation Port Configuration Orientation Termination Shielded LEDs SS-74810-004 Up 1x2 Horizontal Press-fit Yes Y/G SS-74810-003 Up 1 Horizontal Press-fit Yes Y/G SS-74810-002 Up 1x2 Horizontal Press-fit Yes Bi-color Y/G SS-74810-001 Up 1 Horizontal Press-fit Yes Bi-color Y/G Stewart Connector 11118 Susquehanna Trail South Glen Rock, PA 17327-9199 +1 717.235.7512 techhelp@belf.com belfuse.com/stewart-connector © 2019 Stewart Connector
SS-74810-004
物料型号为:SS-74810-004, SS-74810-003, SS-74810-002, SS-74810-001。
器件简介:Stewart Connector的RJ45 Press-Fit连接器设计用于在组装过程中消除焊接的使用,有效降低制造成本,并提高连接器在产品生命周期中的可靠性。
引脚分配:1x2水平。
参数特性: - 操作温度范围:-40°C至85°C - 最大电流额定值:1.5A @ 25°C - 所有选项均提供屏蔽 - 所有配置均为直角(90°) - 多种LED和端口配置 - 低轮廓标签向上设计 - 50微英寸金镀层 - RoHS合规
功能详解: - Stewart的RJ45 Press-Fit连接器可以支持1G至2.5G Base-T以太网速度。
应用信息: - 网络设备 - 家庭和办公设备 - 安全系统 - 视频游戏系统 - 物联网应用 - 便携式存储设备 - 打印机和扫描仪
封装信息:低轮廓标签向上设计,50微英寸金镀层,所有配置均为直角(90°),多种LED和端口配置,并且所有选项均提供屏蔽。
以上信息摘自PDF文档。
SS-74810-004 价格&库存
很抱歉,暂时无法提供与“SS-74810-004”相匹配的价格&库存,您可以联系我们找货
SS-74810-004
  • 1+94.462981+11.34186
  • 10+84.9845310+10.20382
  • 25+80.0566025+9.61213
  • 40+78.0024240+9.36550
  • 144+75.95028144+9.11910
  • 288+67.73947288+8.13326
  • 576+63.63390576+7.64031
  • 1008+56.244221008+6.75306
库存:139
