67PAC-030-K
67PAC-030-K
    STEWARTCONNECTOR
    模块化电缆 插头至插头 8p8c(RJ45,以太网) 9.84'(3.00m) 屏蔽
67PAC-030-K 数据手册
Stewart Connector Product Specification PR041-01 Revision A0 (Date 4-3-2017) Modular Connectors with Circular Shells Stewart Connector 11118 Susquehanna Trail South Glen Rock, Pa. 17327-9199 Ph: (717) 235-7512 Fax: (717) 235-4675 http://www.stewartconnector.com Product Specification PR0410-01 Page 1 of 12 Stewart Connector 1.0 Objective This document establishes the performance requirements and outlines qualification tests for modular connectors produced by Stewart Connector. These products are intended to be terminated onto a cable and mated to a compatible Stewart modular product. 2.0 Scope This specification is applicable to modular products in circular shells. 3.0 General This document is comprised of the following sections (specifications subject to change without notice): Paragraph Title 1.0 2.0 3.0 Table 1 4.0 5.0 6.0 Table 2 7.0 8.0 Table 3 Figure 1 Figure 2 Figure 3 Table 4 Table 5 Table 6 9.0 Table 7 Table 8 Table 9 10.0 Table 10 Table 11 Table 12 Objective Scope General Qualification Test Matrix Applicable Documents General Requirements Quality Assurance Provisions Inspection Conditions Requalification of Products Electrical Requirements LLCR Bulk Contact Interface LLCR Measurement Bulk Shield Interface LLCR Measurement LLCR Measurement Configuration Insulation Resistance DWV (Adjacent Contacts) DWV (Contacts to Shield ) Mechanical Requirements Mechanical Shock Sinusoidal Vibration Random Vibration Environmental Conditions Temperature Life Thermal Shock Temperature / Humidity Modular Connectors with Circular Shells http://www.stewartconnector.com Product Specification PR041-01 Page 2 of 12 Stewart Connector Table 1 Qualification Testing Matrix Qualification Test Groups Testing Matrix 1 Test 2 3 4 5 6 7 1,3 Testing Sequence 3 Para. Examination of Product 5.5 1,5 1,7 1,5 1,6 1,8 1,3,6 Low Level Contact Resistance 8.1 2,4 2,6 2,4 2,4 2,4 2,5 Temperature Rise vs. Current 8.2 3 Mechanical Shock 9.1 3 Vibration (Sinusoidal) 9.2 4 Vibration (Radom) 9.3 5 Temperature Life 10.1 Thermal Shock 10.2 Temperature/Humidity 10.3 Insulation Resistance 8.3 D. W. V. (Adj. Contacts) 2 D. W. V. (Contacts-Shield) 1,2 Durability 3 3 3 5 5 8.4 6 8.5 7 9.4 Ingress protection 10.4 Note: 4 8 6 7 9 (4) (4) (4) (4) 1 Applies to Shield and Shell 2 DWV stands for Dielectric Withstand Voltage 3 Numbers indicate sequence in which tests are performed. 4 Test is recorded on separate test Modular Connectors with Circular Shells http://www.stewartconnector.com 2 (4) Product Specification PR041-01 Page 3 of 12 Stewart Connector 4.0 Applicable Documents 4.1 Bel Stewart Specifications: 4.1.1 Product Drawings 4.1.2 Customer Drawings 4.1.3 Test Specifications 4.2 Other Standards and Specifications (Applicable in Part): 4.2.1 UL94V-0 Flammability 4.2.2 EIA-364 4.2.3 EIA/TIA-568 4.2.4 EIA/TIA-570 4.2.5 IEC 60603-7 4.2.6 IEEE 802.3 Additional specifications and standards may be referenced as applicable. The latest revisions of the above specifications available at the date of issue of this specification are used unless otherwise indicated. 5.0 General Requirements 5.1 Qualification: Connectors furnished under this specification shall be capable of meeting the qualification test requirements specified herein. 5.2 Material: 5.3 5.4 5.2.1 5.2.2 5.2.3 5.2.4 Plastic Housings: UL94V-0 Contacts: Copper Alloy Shield: Copper Alloy Shell: Plastic UL94V-0 5.3.1 5.3.2 5.3.3 5.3.4 Contacts: Gold Selectively Plated Contacts: Nickel Plated All Over Shield: Tin or Nickel Plated All Over Shell: N/A Finish: Design and Construction: Connectors shall be of the design, construction and physical dimensions as specified on the Modular Connectors with Circular Shells http://www.stewartconnector.com Product Specification PR041-01 Page 4 of 12 Stewart Connector applicable product drawing and TIA 1096 specifications. In case of conflict between this specification and product drawings, the drawings shall take precedence. 50 inch (1.27 m) gold plated connectors compliant with TIA 1096 specifications. 5.5 Examination of Product: Connectors shall meet all specified dimensions of product drawings and internal workmanship standards. There shall be no evidence of cracking, chipping, contamination or loose parts when inspected, without magnification, to the unaided eye. 5.6 Operating and Storage Temperature Range: -40°C to 85°C 5.7 Ratings: 5.7.1 Current: 5.7.2 Voltage: 5.8 1.2 amperes maximum at 25C 150 VAC maximum Minimum Number of Mating/Unmating Operations: 5.8.1 Level I: 750 Cycles Modular Connectors with Circular Shells http://www.stewartconnector.com Product Specification PR041-01 Page 5 of 12 Stewart Connector 6.0 Quality Assurance Provisions 6.1 Equipment Calibration: All test equipment and inspection facilities used in the performance of any test shall be maintained and calibrated in accordance with Stewart Operating Procedures and/or other applicable specifications. 6.2 Inspection Conditions: Unless otherwise specified, all inspections shall be performed under the conditions noted. See Table 2 below: Table 2 Inspection Conditions Temperature (±5 ºC) 25 Barometric Pressure Local Ambient 6.3 Sample Quantity and Description: The test samples required for groups 1 through 5 in Table 1 shall be chosen to comprise a group that consists of 80 contacts (10 examples minimum) of each individual contact design. 6.4 Acceptance: 6.4.1 All samples tested in accordance with this product specification shall meet the stated requirements. 6.4.2 7.0 Relative Humidity (%) 30 to 50 Failures attributed to equipment, test set-up, sample preparation problems, contaminants or operator error, should not disqualify the product. Corrective action will be taken and samples re-submitted for qualification. Requalification of Products 7.1 Requalification Testing If changes are made to the product, design or manufacturing process after initial product qualification that are judged by the management of Stewart Connector to materially affect the product form, fit or function, then new product samples shall be subject to full or partial requalification testing. Modular Connectors with Circular Shells http://www.stewartconnector.com Product Specification PR041-01 Page 6 of 12 Stewart Connector 8.0 Electrical Requirements 8.1 Low Level Contact Resistance: LLCR of the Coupler should be measured (mated with Stewart Connector plugs) in accordance with EIA-364-23 with a test current of 100 mA and a maximum open circuit voltage of 20 mVDC (dry circuit test). See Table 5 below: Table 3 Low Level Contact Resistance Contacts Initial (m) 100* Shield Interface if applicable Final Initial Final (m) (m) (m) 100 20 100 All values listed are maximum values. * 100 m Initial LLCR Includes Bulk Low Level Contact Resistance (LLCR) is measured between the two (2) mated connectors (one plug is within the Plug Shell) and the Coupler that is within the Receptacle Shell. Measurements are generally performed before and after environmental exposure or mechanical conditioning. Bulk LLCR is measured between the signal contacts and shield connections of the Plugs that are mated through the Coupler. Signal Contact Bulk resistance consists of the sum of all interface connections between the conductors, contacts and coupler. FIGURE 1 Modular Connectors with Circular Shells http://www.stewartconnector.com Product Specification PR041-01 Page 7 of 12 Stewart Connector 8.1 Low Level Contact Resistance: (Cont.) Shield Bulk resistance consists of the sum of all interface connections between the ground interfaces of the cable shields, the Plug shields, and the Coupler shield. Stewart’s product specification requirement is a bulk contact resistance change after conditioning. In most cases, the maximum allowable change in bulk contact resistance after environmental conditioning is 100 m. LLCR measurements are conducted utilizing a four (4) wire dry circuit test method. Implementation consists of a 100 mA DC current source with a maximum open circuit voltage of 20 mV. Measurements are performed using low current and voltage levels to preserve oxides and films that may form during environmental conditioning. In practice, Jacks are typically mounted on PWB boards (although jacks can be measured manually as well), which are design to interface with automated switching and measuring equipment. Stewart Connector LLCR measuring system consists of a Micro-Ohmmeter and a Hewlett Packard Data Acquisition Switch Unit. Automation software is utilized to fully control the measurement sequence. Refer to measurement configuration in Figure 4 below. Modular Connectors with Circular Shells http://www.stewartconnector.com Product Specification PR041-01 Page 8 of 12 Stewart Connector 8.1 Low Level Contact Resistance: (Cont.) FIGURE 3 8.2 Temperature Rise versus Current: The temperature rise above ambient (25C) shall not exceed 30 C at any point on the connector when all contacts are powered in series with 1.2 Amps DC in accordance with EIA-364-70. 8.3 Insulation Resistance: The insulation resistance of the unmated connectors shall be measured in accordance with EIA-364-21. See Table 6 below: Table 4 Insulation Resistance Test Voltage (VDC) 500 500 Test Duration (Minutes) 1 1 Modular Connectors with Circular Shells http://www.stewartconnector.com Requirement (M) 500 500 Points of Measurement Between adjacent contacts Between contacts and shield Product Specification PR041-01 Page 9 of 12 Stewart Connector 8.4 Dielectric Withstanding Voltage (DWV) Adjacent Contacts: There shall be no arc over, insulation breakdown or excessive leakage (>1 mA) when tested in accordance with EIA-364-20 on mated connectors. See Table 7 below: Table 5 DWV – Adjacent Contacts Test Voltage Test Duration (Minutes) 1 1000 VDC 8.5 Points of Measurement Between adjacent contacts Dielectric Withstanding Voltage (DWV) Contact to Shield: There shall be no arc over, insulation breakdown or excessive leakage (>1 mA) when tested in accordance with EIA-364-20 on mated connectors. See Table 8 below: Table 6 DWV – Contact to Shield Connector All Connectors Test Voltage Test Duration (Minutes) 1500 VACRMS or 2121 VDC 1 Modular Connectors with Circular Shells http://www.stewartconnector.com Points of Measurement Between contacts and shield Product Specification PR041-01 Page 10 of 12 Stewart Connector 9.0 Mechanical Requirements 9.1 Mechanical Shock: Mechanical Shock shall be measured in accordance with EIA-364-27, condition A, with assembled connectors mounted rigidly to table and no discontinuities of >1 microsecond. See Table 12 below: Table 7 Mechanical Shock Velocity Change (ft/s) 11.3 Wave Type Half Sine 9.2 9.3 Duration Each Face (milliseconds) 11 Applied Energy (g) 50 Mutually Perpendicular Axis 3 Vibration (Sinusoidal): Sinusoidal Vibration shall be measured in accordance with EIA-364-28 Test Condition I, with assembled connectors mounted rigidly to vibrating table and no discontinuities of >1 microsecond. See Table 13 below: Table 8 Sinusoidal Vibration Wave Type Amplitude Frequency (Hz) Sine .06 in. DA 10 to 55 Duration Each Face (hours) 2 Mutually Perpendicular Axis 3 Vibration (Random): Random Vibration shall be measured in accordance with EIA-364-28 Test Condition V Letter D, with assembled connectors mounted rigidly to vibrating table and no discontinuities of >1 microsecond. See Table 14 below: Table 9 Random Vibration Frequency (Hz) 50 to 2000 9.4 Number of shocks per direction 6 Duration Each Face (minutes) 90 Overall rms (g) 11.95 Mutually Perpendicular Axis 3 Durability: Cycles (number of times) 500 mated and unmated There to be no evidence of any damage or negative impact to form, fit or function. Modular Connectors with Circular Shells http://www.stewartconnector.com Product Specification PR041-01 Page 11 of 12 Stewart Connector 10.0 Environmental Conditions Note: Unless otherwise specified, all environmental testing is to be done with the connector in the mated state. 10.1 Temperature Life: Temperature life shall be measured in accordance with EIA-364-17, per method A. See Table 16 below: Table 10 Temperature Life Temperature (ºC) 85±2 10.2 Duration (hours) 500 Thermal Shock: Thermal Shock shall be measured in accordance with EIA/TIA-568. See Table 17 below: Table 11 Thermal Shock Temperature (±3 ºC) -40 to +85 10.3 Duration at Each Extreme (Minutes) 30 Test Condition 1 Temperature / Humidity: Temperature / Humidity shall be measured in accordance with EIA-364-31, Method IV. See Table 18 below: Table 12 Temperature / Humidity Relative Humidity (±3 %) 93 10.4 Number of Cycles 25 Low Temperature (±2 ºC) 25 High Temperature (±2 ºC) 65 Cold Sub-cycle (±2 ºC) -10 Cycle Time (hours) 24 Number Of Cycles 21 Ingress protection: Tested per IEC/EN 60529, section 14.2.8. Depth up to 1 meter, duration 30 minutes (IP67 versions only). Modular Connectors with Circular Shells http://www.stewartconnector.com Product Specification PR041-01 Page 12 of 12
67PAC-030-K 价格&库存
很抱歉,暂时无法提供与“67PAC-030-K”相匹配的价格&库存,您可以联系我们找货
67PAC-030-K
  • 4+336.21813
库存:8
