Product Guide
Single Port ICMs
1xN Harmonica ICMs
2xN Stacked ICMs
Specialty ICMs
+1 858.676.9650
TechHelp@belf.com
MagJack®
Bel invented and is the largest supplier of Integrated Connector Modules (ICM), which combines
the Ethernet filtering solution within the connector. With several acquisitions, Bel has the broadest
portfolio of MagJack® ICM products available.
Networking Equipment
Applications
• Storage
• 10/100BT AutoMDIX
• Switches
• 1GBT (10/100/1000BT)
• Routers
• 2.5GBT, 5GBT and 10GBT
• Servers
• Power over Ethernet, 30W, 60W and 100W
• Workstations
• Extended Temperature Range of -40° to +85° C
• Motherboards
• RoHS Compliant, Soldering = 260° C for
10 Seconds
ICMs combo devices provide a mix of RJ45 and USB connectors for greater design flexibility.
Product Guide
e
om
Mechanical
Options
Mechanical
Options
Single Port Designs
• Plug Tab Up and Plug Tab Down
• Plug tab up and plug tab down
• With or •Without
LEDs
With or without
LEDs
and
Bi-Color
and
bi-color
• RJ45 and USB port combinations
• Multi-Port Configurations: 2x1 / 2x4 / 2x6 / 2x8
• Vertical mount packaging
• RJ45 and
USB Port Combinations
• Low profile versions under 0.50” height
• MicroVersions
height versionsUnder
under 0.45”
height Height
• Low Profile
0.50”
Optimized for 1U Advanced TCA rack applications,
Compressor MagJack breaks the 1” height barrier
• Mid-plane mount versions under 0.40” height
• Micro Height Versions Under 0.45” Height
with its two-tier, 0.785” (19.94mm) height package.
Multi-Port Designs
• Mid-Plane Mount Versions Under 0.40” Height
• With or without LEDs
and bi-color
• Two-Tier Stacked Designs
Under 0.785”
• Multi-port configurations:
2x1 / 2x3Height
/ 2x4 / 2x6 / 2x8
• Two-tier stacked designs under 0.785” height
• Vertical Mount Packaging
MagJack’s mechanical evolution continues to provide more efficient space utilization with ultra-low profile packages
and mid-plane mount versions.
Bel ICMs Mechanical Evolution Continues to Provide More Efficient Space Utilization with Ultra-Low Profile
Packages and Mid-Plane Mount Versions.
Vertical-mount MagJack is
optimized for space-critical
Electrical
Options
• IR reflow compatible, 230° C for 90 seconds
devices such as SBCs
(single-board computers),
motherboards, daughter
cards, NICs (network
• Surge protection for GR1089 intra-building and ESD
interface cards), switches,
• Extended temperature range -40° to +85° C
hubs, and bridges. Applications include industrial PCs, printers,
VoIP phones, remote sensor and transducer devices, security
camera equipment, and wireless systems.
Compressor ICMs breaks the 1”
height barrier with its two-tier port
configuration within a package
height of only 0.785” (19.94mm).
Bel Stewart Connector 11118 Susquehanna Trail South, Glen Rock, PA 17327 • Tel 717-235-7512 • Fax 717-235-4675 • www.belstewart.com
Vertical-mount ICMs are optimized for space-critical devices such as SBCs
(single-board computers), motherboards, daughter cards, NICs (network
interface cards), switches, hubs, and bridges. Applications include industrial
PCs, printers, VoIP phones, remote sensor and transducer devices, security
Low Profile, Mid-Plane Mounted, Single Port Magjack® ICM
The MagJack® brand of low profile ICMs support 10/100Base-T, 1GBase-T and 10GBase-T Ethernet applications.
This product type is aimed at customers who need very low profile height connectors or want to mount mezzanine
cards above these connectors and are limited by height.
As systems become smaller and implement faster speeds, the Ethernet connectors must adapt and become smaller
and faster. This ICM product family combines small form factor with speed to provide ultimate combination of both
allowing customers to put Ethernet ports where never possible before.
Features & Benefits
• Low profile height, less than .400” off the PCB
• High speed capable, from 10/100BT up to 10GBT
• Can be used in low profile applications
• Can be used in half U height applications
• Compatible with up to OCP 3.0 mechanical card requirements
Applicaitons
• Blade servers or cards
• Network Interface cards
• Laptop computers
• Storage systems
• Mezzanine cards
Specifications
• Meets all IEEE 802.3 10/100Base-T thru 10GBase-T electrical requirements including RL, IL, Hi-pot and Common
Mode parameters
• 100% hi-pot tested in production
• Comes with many different LED color combinations and options
• 50 micro-inches of gold plated contacts as required by the TIA 1096/FCC 47, Part 68.
• Lead-free wave-solder compatible, with some IR reflow compatible designs
• UL recognized
• RoHS 6/6 compliant
Bel Magnetic Solutions
12700 Stowe Drive
Suite 200
Poway, CA 92064 USA
+1 858.676.9650
techhelp@belf.com
belfuse.com/magnetic-solutions
© 2017 Bel Fuse Inc. br-mag-magJack-icm_12272017_6
很抱歉,暂时无法提供与“SS-60300-080”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+25.494631+3.16260
- 10+19.4850310+2.41711
- 25+17.5500125+2.17707
- 40+16.6443740+2.06473
- 80+15.4117880+1.91183
- 230+13.74763230+1.70539
- 770+12.12328770+1.50389
- 1540+11.310271540+1.40304
- 3080+10.574493080+1.31176
