SS-60300-079
SS-60300-079
    STEWARTCONNECTOR
    插件
    模块化连接器 - 插孔 8p8c(RJ45,以太网) 90°角(直角) 屏蔽
SS-60300-079 数据手册
60300 Series Jacks 2.5G, 5G and 10G Solutions Stewart Connector’s 60300 Series Jacks are designed for use in 2.5G, 5G and 10GBase-T Ethernet applications. Stewart Connector has engineered this series of connectors to accommodate all Ethernet applications in one simplistic design. Stewart Connector is the only manufacturer to provide reliable 10GBase-T Ethernet in a passive connector application. • The 60300 series is one of the only RJ45 connectors on the market today which has the electrical performance characteristics required to deliver 10GBase-T Ethernet signals. • The 60300 series gives equipment designers a connector which is capable of performing in 2.5G and 5GBase-T devices which are designed to operated over existing structured cabling systems. Unique Benefits of the 60300 Series • The unique contact design of the connector addresses cross talk and return loss issues which are common when using RJ45 connectors in high frequency applications • The compact design containing the smallest footprint available in the market provides a viable robust solution when PCB space is at a premium • 45 degree, 90 degree and 180 degree shielded and unshielded versions available • Compatible for use in applications where POE is necessary accommodating 15W through 100W power requirements • Non-LED options are IR reflow compatible • Selectively plated contacts with 50 micro-inches of gold • RoHS compliant Part Numbers Part Number Shield Type Orientation LEDs SS-60300-011 SS-60300-059 SS-60300-046 SS-60300-079 SS-60300-080 SS-60300-081 SS-60300-101 SS-60300-102 SS-60300-103 SS-60300-104 Panel Grounds Panel Grounds Panel Grounds No Panel Grounds No Panel Grounds No Panel Grounds Panel Grounds Panel Grounds No Panel Grounds No Panel Grounds Horizontal (90) 45 Degree Angled Vertical (180) Horizontal (90) Vertical (180) 45 Degree Angled Horizontal (90) Vertical (180) Horizontal (90) Vertical (180) None None None None None None Bi-Color G/Y Bi-Color G/Y Bi-Color G/Y Bi-Color G/Y Stewart Connector 11118 Susquehanna Trail South Glen Rock, PA 17327-9199 +1 717.235.7512 techhelp@belf.com belfuse.com/stewart-connector © 2020 Stewart Connector
SS-60300-079 价格&库存
很抱歉,暂时无法提供与“SS-60300-079”相匹配的价格&库存,您可以联系我们找货
SS-60300-079
  • 1+23.171601+2.78390
  • 10+16.5361010+1.98670
  • 84+12.5945084+1.51320
  • 504+11.91820504+1.43190
  • 1008+10.658701008+1.28060
库存:2409
