NH-Z1415RGBA-SG
NH-Z1415RGBA-SG
    NATIONSTAR(国星光电)
    LED指示灯 三色 RBG红绿蓝 0606 共阳极 正贴
NH-Z1415RGBA-SG 数据手册
表单编号:FGH/BD-0053.01-15A 佛山市国星 RGB 器件事业部 FOSHAN NATIONSTAR RGB DIVISION 产品规格书 S P E C I F I C AT I O N 顾客名称 产品名称 Customer Product 顾客型号 产品型号 Customer Type Type 顾客部品号 版本号 Customer No. Version NO TOP LED NH-Z1415RGBA-SG A1 版 地址:广东省佛山市禅城区华宝南路 18 号 Add: NO.18 South Huabao Rd, Foshan, Guangdong, China 电话(Tel) : 0757-83985605; 83985607; 82100231; 82100230 传真(Fax): 0757-82100223;82100200 邮编(Zip) :528000 http://www.nationstar.com 研 发 中 心 客户(加盖公章) Research & Development Center Customer(Stamp) 制 定 审 核 DRAW CHECK 批 准 APPROVE 确 认 CONFIRM 发放日期 (Release Date):2020-04-24 保存期限:长期 表单编号:FGH/BD-0053.01-15A TOP 彩色发光二极管 NH-Z1415RGBA-SG TOP Full-color LED 技术数据表 Technical Data Sheet 本产品属于表面贴装全彩器件,采用外黑内白设计,高对比度,哑光封装,无镜面反射。 拥有多重防水功能,高可靠性、长寿命、宽视角等特点,是全户外显示装饰领域的理想选择。 These products are full-color SMD components with black frame and white refractor, high contrast, matt packaging and non-mirror reflection, which are featured by multiple waterproof performance, good reliability, long lifespan and wide viewing angle.They are designed for outdoor display and decoration applications. 特性:  管芯材料: Material: 红色 Red AlGaInP 绿色 Green InGaN 蓝色 Blue InGaN Features: 封装材料:环氧树脂 Encapsulation: Epoxy Resin 焊接方法:无铅回流焊 Soldering methods: Pb-Free reflow soldering 光强高,功耗低,可靠性好,寿命长 High Luminous Intensity ,Low Power Dissipation, good Reliability and Long Life  符合欧盟公布的 ROHS 指令要求 Complied With ROHS Directive 目录 Catalogue 电性参数 Electrical Characteristics.............................................................................................................................2 典型特性曲线 Typical Characteristic Curves.....................................................................................................................3 可靠性实验 Reliability Test Items and Conditions........................................................................................................4 产品设计及操作建议 Product design and operating recommendation...........................................................................5 包装 Packaging......................................................................................................................................................6 焊接指导 Guideline for Soldering................................................................................................................................8 使用注意事项 Precautions....................................................................................................................................................10 * 产品规格如因工艺改进而有所改变,恕不另行通知。 * The specifications of the product may be modified for improvement without notice. 发放日期:20200424TYBA1 1 / 12 保存期限:长期 表单编号:FGH/BD-0053.01-15A TOP 彩色发光二极管 光电参数 Electro-Optical Characteristics  极限参数(温度=25℃) Absolute Maximum Ratings (Temperature=25°C) 参数名称 Parameter 正向电流 Forward Current 正向脉冲电流* Pulse Forward Current* 反向电压 Reverse Voltage 工作温度 Operating Temperature 贮存温度 Storage Temperature 符号 Symbol 数值 Rating 单位 Unit IF 25 mA IFP 50 mA VR 5 V Tamd -30 ~ +85 ℃ Tstg -40 ~ +100 ℃ 红 Red 功耗 Power Dissipation 62.5 绿 Green 85 Ptot 蓝 Blue 85 * 注:脉冲宽度≤0.1ms,占空比≤1/10  mW * Note: Pulse Width≤0.1ms, Duty≤1/10 光电参数(温度=25℃) Electro-Optical Characteristics (Temperature=25°C) 参数名称 Parameter 符号 Symbol 条件 Condition 反向电流 Reverse Current IR VR=5 V 正向电压 Forward Voltage 主波长 Dominant Wavelength 半波宽度 Spectrum Radiation Bandwidth 光强 Luminous Intensity 视角度 View Angle VF λD Δλ IV 颜色 Color 最小值 Min. 典型值 Typ. 最大值 Max. 红 Red 10 绿 Green 10 蓝 Blue 10 IF=15mA 红 Red 1.8 2.1 2.5 IF=8mA 绿 Green 2.4 2.9 3.4 IF=5mA 蓝 Blue 2.4 2.9 3.4 IF=15mA 红 Red 615 622 630 IF=8mA 绿 Green 515 528 540 460 469 480 IF=5mA 蓝 Blue IF=15mA 红 Red 24 IF=8mA 绿 Green 38 IF=5mA 蓝 Blue 28 IF=15mA 红 Red 200 370 560 IF=8mA 绿 Green 320 560 850 IF=5mA 蓝 Blue 40 80 130 2θ1/2 110 单位 Unit μA V nm nm mcd deg. * 注:以上参数仅供参考,请以实物标签为准。我司给出的参数均由国星测试系统测得。 * Note: The parameters above only for your reference. In case of any discrepancy, please adhere to the label of our actual products. All parameters tested by the standard testing system of NationStar. 发放日期:20200424TYBA1 2 / 12 保存期限:长期 表单编号:FGH/BD-0053.01-15A TOP 彩色发光二极管 典型特性曲线 Typical Characteristics Curves 伏安特性 相对光强与正向电流特性 Volt-Ampere Characteristics Relative Luminous Intensity VS Forward Current 1 Blue 1.5 1.8 2.1 2.4 2.7 3.0 正向电压 (F orward Voltage )(V ) 3.3 6 5 4 3 2 Green Red 0 20 30 40 50 60 光强与环境温度曲线 正向电流降额曲线 Luminous Intensity VS Ambient Temperature 1.4 40 10 15 0 5 Blue 1.2 1.0 Red 0 0.2 0.4 0.6 0.8 Blue Green 350 400 450 500 550 600 650 700 750 1.2 Green -40 -20 0 20 40 60 环境温度(Ambient Temperature )(℃) a . u .) 光谱分布特性曲线 R elative Spectral Dis tribution 相 对 光 强( R ela ti ve Lu mi nous In t en si ty )( a . u. ) 环境温度(Ambient Temperature )(℃) 1.0 Red Blue 0.8 20 25 Green 0 .6 30 35 相对光强(Relative Luminous Intensity) Red 0 10 20 30 40 50 60 70 80 90 100 相 对 光 强( Rel ati v e Lu m ino us In tens ity )( 10 正向电流(Forward Current )(mA ) Forward Current Derating Curve 正向电流(Forward Current)(mA) Green Blue 1 10 Red TAmbient =25℃ 0 正向电流(Forward Current)(mA) 1 00 相对光强(Relative Luminous Intensity)(a. u.) TAmbient =25℃ 80 光强分布特性曲线 Typical Spatial Distribution 1 0° 10° 20° 30° 40° 50° 60° 0.5 70° 80° 0 -90 °-80°-70°-60°-50°-40°-30°-20°-10° 0 90° 0 .5 1 角度(Angle )(Deg .) 波长(Wavelength )(nm ) 发放日期:20200424TYBA1 3 / 12 保存期限:长期 表单编号:FGH/BD-0053.01-15A TOP 彩色发光二极管 可靠性试验 Reliability Test Items And Conditions 实验项目 参考标准 实验条件 时间 样品数 合格判据 Test Items Reference Test Conditions Time Quantity Criterion 冷热冲击 Thermal Shock MIL-STD-202G -65℃(15min)←→150℃(15min) 100 0/100 常温寿命试验 Room Temperature Operating Life JESD22-A108D 循环 100 次 100 cycles 见下表 Ta=25℃ 1000h 20 See Table below IFR =5mA,IFG=5mA,IFB =5mA 高温高湿寿命试验 Temperature & Humidity Operating Life JEITA ED-4701 100 103 Ta=85℃ RH=85% JESD22-A108D IFR =5mA,IFG=5mA,IFB =5mA 耐焊接热 Resistance to Soldering Heat JEITA ED-4701 300 301 见下表 500h 20 See Table below 2次 Tsol*=260℃ 10sec. 100 0/100 100 0/100 2 times 防水试验 Water Proof Test IEC 60529:2001 紫外老化 UV aging ASTM-G154 Immersing in 1m water 24h (0.89±0.1)W/m2@340nm,60℃, 循环 14 次 寿命试验合格判断标准 见下表 20 8h ←→50℃,4h/ cycle 14 cycles See Table below Criteria For Passing Qualification Of Lifespan Test 测试项目 符号 测试条件 判定标准 Test Items Symbol Test Conditions Criteria For Judging Damage 正向电压 Forward Voltage VF IF= IFT 初始值±10% Initial Data±10% 反向电流 Reverse Current IR VR= 5V IR≤10μA IF = IFT 平均 IV 衰减≤30%,单个 IV 衰减≤50% Average IV degradation≤30%; Single LED IV degradation≤50% 光强 Luminous Intensity IV * 注:Tsol-锡液温度;IFT:典型电流 * Note: Tsol-Temperature of tin liquid; IFT:Typical current. 发放日期:20200424TYBA1 4 / 12 保存期限:长期 表单编号:FGH/BD-0053.01-15A TOP 彩色发光二极管 产品设计及操作建议 Product design and operational recommendation 1、产品设计(单位:mm) Product design(Unit: mm) Note: A :缺口标志 A :Nick Mark 公差: X.X ±0.1 mm X.XX ±0.05mm Tolerances:X.X ±0.1 mm X.XX ±0.05mm 极性 Polarity 2、参考焊盘(单位:mm) Reference soldering pad (Unit: mm) 3、灌胶建议:灌胶高度须大于等于 0.60mm 以上 Recommendation for glue filling: filling height must be higher than or equal to 0.60mm 发放日期:20200424TYBA1 5 / 12 保存期限:长期 表单编号:FGH/BD-0053.01-15A TOP 彩色发光二极管 包装(1) Packaging (1)  载带 Carrier Tape 单位:mm,未注公差:±0.10mm All dimensions in mm, tolerances unless mentioned is ±0.10 mm.  编带细节 Details Of Carrier Tape 前进方向Progressive Direction  A:引导,空带,500mm;B:编载产品 10000 只;C:尾部,空带,100mm A: Leader, Empty, 500mm; B: 10000 Lamps Loaded; C: Trailer, Empty, 100mm.  带盘 Reel Dimension 前进方向Progressive Direction  二维码 Qr code TOP LED XXXX TYPE: XX-XXXXX-XX QTY: XXXX BIN: XXX SC: XXX LOT: |||||||||||||||||||||||||||||||| XXXX IV(mcd) λd(nm) R:( xxx-xxx) ( xxx-xxx) G:( xxx-xxx) ( xxx-xxx) B:( xxx-xxx) ( xxx-xxx) VF(V) IF(mA) ( xx-xx) ( xx) ( xx-xx) ( xx) ( xx-xx) ( xx) QC QC: PASS FOSHAN NATIONSTAR OPTOELECTRONICS CO., LTD 佛山市国星光电股份有限公司 标签 Label 发放日期:20200424TYBA1 6 / 12 保存期限:长期 表单编号:FGH/BD-0053.01-15A TOP 彩色发光二极管 包装(2) Packaging( 2) 防潮抗静电包装 Moisture Proof and Anti-Electrostatic Foil Bag 标签 Label 防潮抗静电包装袋 Moisture Proof and Anti-Electrostatic Foil Bag 干燥剂 密封 标签 Moisture Absorbent Material Sealed Label 外包装箱 Cardboard Box 二维码 Qr code TOP LED XXXX TYPE: XX-XXXXX-XX QTY: XXXX IV(mcd) λd(nm) R:( xxx-xxx) ( xxx-xxx) G:( xxx-xxx) ( xxx-xxx) SC: XXX B:( xxx-xxx) LOT: XXXXXXXX ( xxx-xxx) BIN: XXX 20XX - XX - XX VF(V) IF(mA) ( xx-xx) ( xx) ( xx-xx) ( xx) ( xx-xx) ( xx) QC QC: PASS FOSHAN NATIONSTAR OPTOELECTRONICS CO., LTD 佛山市国星光电股份有限公司 佛山市国星光电股份有限公司 FOSHAN NATIONSTAR OPTOELECTRONICS CO.,LTD 地址:佛山市禅城区华宝南路18号 TEL:(86-757)83980208 邮编:528000 FAX:(86-757)82100206 标签说明 Label Explanation TYPE:产品型号 二维码 Qr code TOP LED QTY:数量 Quantity BIN:分档 Rank XXXX TYPE: XX-XXXXX-XX QTY: XXXX SC: 分档代码 Bin Code BIN: XXX LOT:批号 Lot Number SC: λd:波长范围 Wavelength Range LOT: XXXXXXXX XXXX XXX IV(mcd) λd(nm) VF(V) IF(mA) R:( xxx-xxx) ( xxx-xxx) ( xx-xx) ( xx) G:( xxx-xxx) ( xxx-xxx) ( xx-xx) ( xx) B:( xxx-xxx) ( xxx-xxx) ( xx-xx) ( xx) QC QC: PASS FOSHAN NATIONSTAR OPTOELECTRONICS CO., LTD 佛山市国星光电股份有限公司 IV:光强范围 Luminous Intensity Range VF:正向电压范围 Forward Voltage Range IF:测试电流 Test Current 发放日期:20200424TYBA1 7 / 12 保存期限:长期 表单编号:FGH/BD-0053.01-15A TOP 彩色发光二极管 焊接指导(1) Guideline for Soldering (1) 使用烙铁人手焊接 1. Hand Soldering  如使用手工焊接,建议使用小于25瓦的电烙铁,烙铁温度必须控制在315℃以下,焊接时间需控制在3 秒钟之内,且每个电极只能焊接一次。 If manual soldering is used, the use of a soldering iron of less than 25W is recommended. The temperature of the iron must be kept below 315℃,with soldering time within 3 seconds and each electrode can be only soldered at one time.  手工焊接时电烙铁不可触及SMD LED表面。 The epoxy resin of the SMD LED should not contact the tip of the soldering iron.  焊接期间,不可以对器件施加机械压力。 No mechanical stress should be exerted on the resin portion by the tip of the soldering iron.  器件外部温度在 40℃以下时,才可以对其进行处理。避免高温时操作对 LED 造成损伤。 Handing of the SMD LED should be done when the temperature of environment is below 40℃, in case of LED failures caused by thermal-mechanical stress in condition of high temperature . 2. 回流焊接:推荐使用以下无铅回流焊接温度图进行。 Reflow Soldering: Use the conditions shown in the under Figure of Pb-Free Reflow Soldering. 发放日期:20200424TYBA1 8 / 12 保存期限:长期 表单编号:FGH/BD-0053.01-15A TOP 彩色发光二极管 焊接指导(2) Guideline for Soldering (2) · 回流焊接最多只能进行一次。 · Reflow soldering should not be done more than one time. · 在回流焊接升温过程中,请不要对 LED 施加任何压力。 · Stress on the LEDs should be avoided during heating in the reflow soldering process. · 在焊接完成后,待产品温度下降到室温之后,再进行其他处理。 · After soldering, do not deal with the product before its temperature drop down to room temperature. 3. 清洗: Cleaning · 在焊接后推荐使用酒精(无水乙醇)进行清洗,在温度不高于 30℃的条件下持续 3 分钟,不高于 50℃ 的条件下持续 30 秒。使用其他类似溶剂清洗前,请先确认使用的溶剂不会对 LED 的封装和环氧树脂部 分造成损伤。 It is recommended that alcohol(Anhydrous ethanol) be used as a solvent for cleaning after soldering. Cleaning is to go under 30℃ for 3 minutes or 50℃ for 30 seconds. When using other solvents, it should be confirmed beforehand whether the solvents will dissolve the package and the resin or not. · 超声波清洗也是有效的方法,一般最大功率不应超过 300W,否则可能对 LED 造成损伤。请根据具体 的情况预先测试清洗条件是否会对 LED 造成损伤。 Ultrasonic cleaning is also an effective way for cleaning. The influence of Ultrasonic cleaning on LED depends on factors such as ultrasonic power. Generally, the ultrasonic power should not be higher than 300W, otherwise it will cause LED damage. Before cleaning, a pre-test should be done to confirm if any damage to LEDs will occur. * 注意:此一般指导原则并不适用于所有 PCB 设计和焊接设备的配置。具体工艺受到诸多因素的影响,请根据特定的PCB设计和焊 接设备来确定焊接方案。 * Note: This general guideline may not apply to all PCB designs and configurations of all soldering equipment. The technique in practice is influenced by many factors, it should be specialized base on the PCB designs and configurations of the soldering equipment. 发放日期:20200424TYBA1 9 / 12 5 保存期限:长期 表单编号:FGH/BD-0053.01-15A TOP 彩色发光二极管 使用注意事项(1) Precautions (1) 贮存: 1. Storage  本产品使用密封防潮抗静电袋包装,并附有干燥剂,湿度卡。 Moisture proof, anti-electrostatic package and moisture absorbent material are used, to keep moisture to a minimum. Humidity indicator card inside to test if the products are moisted.  贮存环境为:开封前,产品贮存在温度
NH-Z1415RGBA-SG 价格&库存
很抱歉,暂时无法提供与“NH-Z1415RGBA-SG”相匹配的价格&库存,您可以联系我们找货
NH-Z1415RGBA-SG
  • 20+0.18630
  • 200+0.15833
  • 600+0.14278
  • 2000+0.13349
  • 12500+0.11459
  • 25000+0.11016
库存:1966
NH-Z1415RGBA-SG
  • 1+0.42262
  • 500+0.14012
  • 6250+0.09707
  • 12500+0.07696
库存:20537
