MHDEWT-0000-000N0UF235G
    CREELED
    2828(7070公制)
    LED XLAMP 3500K WHITE 36V SMD
MHDEWT-0000-000N0UF235G 数据手册
PRODUCT FAMILY DATA SHEET XLamp® MHD-E LEDs PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS The XLamp® MHD-E LED is a new generation • Flexible 9‑V, 18‑V or 36‑V options Characteristics................................................ 2 of high‑power LED that delivers a more • Maximum drive current: 1400 mA (9 V), Flux Characteristics, EasyWhite® Order effective way to achieve low‑cost systems Codes and Bins - 9 V/18 V.............................. 3 700 mA (18 V), 350 mA (36 V) than mid‑power (MP) LEDs. Built using • Viewing angle: 115° Flux Characteristics, EasyWhite® Order Cree LED’s high‑reliability ceramic‑package Codes and Bins - 36 V..................................... 5 technology, the XLamp MHD-E LED is able • Available in 70‑CRI, 80‑CRI and 90‑CRI options Relative Spectral Power Distribution............. 7 to operate at higher temperatures than MP • Unlimited floor life at ≤ 30 ºC/85% RH Relative Flux vs. Junction Temperature......... 7 LEDs with no reduction in rated lifetime, • Reflow solderable - JEDEC J‑STD‑020C Electrical Characteristics................................ 8 enabling an impressive 60% reduction in • Electrically neutral thermal path Relative Flux vs. Current................................. 9 heat sink size and cost. Using many times • RoHS and REACH compliant Relative Chromaticity vs. Current................. 11 fewer LEDs than MP LEDs to achieve the • UL® recognized component (E349212) Relative Chromaticity vs. Temperature........ 12 same performance, the XLamp MHD-E Typical Spatial Distribution........................... 13 LED is optimized to simplify LED system Thermal Design............................................. 13 designs for directional and semi‑directional Performance Groups - Luminous Flux......... 15 applications. Performance Groups - Chromaticity............ 15 Standard White Chromaticity Regions Plotted on the 1931 CIE Curve..................... 16 Bin and Order Code Format.......................... 17 Reflow Soldering Characteristics................. 18 Notes............................................................. 19 Mechanical Dimensions............................... 21 Electrical Configuration................................ 23 Tape and Reel................................................ 24 Packaging...................................................... 26 Cree LED / 4001 E. Hwy. 54, Suite 2000 / Durham, NC 27709 USA / +1.919.313.5330 / www.cree-led.com © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 1 XLAMP ® MHD-E LED CHARACTERISTICS MHD-E 9‑V/18‑V LEDs are tested and binned in production in the 18‑V configuration. MHD-E 36‑V LEDs are tested and binned in production in the 36‑V configuration. See the Mechanical Dimensions section on page 21 for pad layout options. Characteristics Unit Thermal resistance, junction to solder point Minimum Typical °C/W 2.6 degrees 115 Temperature coefficient of voltage (9 V)* mV/°C -3.75 Temperature coefficient of voltage (18 V) mV/°C -7.5 Temperature coefficient of voltage (36 V) mV/°C -15 ◊ Viewing angle (FWHM) ESD withstand voltage (HBM per Mil-Std-883D) Maximum V 8000 DC forward current (9 V)* mA 1400 DC forward current (18 V) mA 700 DC forward current (36 V) mA 350 Reverse current (9 V, 18 V, 36 V)* mA -0.1 Forward voltage (9 V, @ 800 mA, 85 °C)* V 9.1 10 Forward voltage (18 V, @ 400 mA, 85 °C) V 18.2 20 Forward voltage (36 V, @ 200 mA, 85 °C) V 36.3 40 LED junction temperature °C 150 Note: ◊ Thermal resistance measurement was performed per the JEDEC JESD51-14 standard. See the Thermal Resistance Measurement * application note for more details. Data for the 9‑V configuration is calculated and for reference only. © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 2 XLAMP ® MHD-E LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 9 V/18 V The following table provides order codes for XLamp MHD-E LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 17). Test condition: TJ = 85 °C, 18 V, IF = 400 mA Reference condition: TJ = 85 °C, 9 V, IF = 800 mA Nominal CCT CRI Min Minimum Luminous Flux 2-Step 3-Step 5-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* H2 900 1007 H4 970 1085 MHDEWT-0000000C0BH465E G4 840 940 MHDEWT-0000000C0HG465E H2 900 1007 MHDEWT-0000000C0HH265E H2 900 1007 MHDEWT-0000000C0BH257E H4 970 1085 MHDEWT-0000000C0BH457E G4 840 940 MHDEWT-0000000C0HG457E H2 900 1007 MHDEWT-0000000C0HH257E H2 900 1007 MHDEWT-0000000C0BH250E H4 970 1085 G4 840 940 H2 900 1007 MHDEWT-0000000C0HH250G F4 730 817 MHDEWT-0000000C0UF450G G2 780 873 Group Order Code Group Order Code 70 Group 65E 6500 K 80 65E 70 57E 5700 K 80 57E 70 5000 K 50E 80 50G 90 50G MHDEWT-0000000C0HG450G MHDEWT-0000000C0UG250G 50E 50E Order Code MHDEWT-0000000C0BH265E MHDEWT-0000000C0BH450E MHDEWT-0000000C0HG450E MHDEWT-0000000C0HH250E MHDEWT-0000000C0UF450E MHDEWT-0000000C0UG250E Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 19). MHD-E LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 3 XLAMP ® MHD-E LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 9 V/18 V - CONTINUED Nominal CCT CRI Min 70 Minimum Luminous Flux Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* G4 840 940 H2 900 1007 H4 970 1085 G2 780 873 G4 840 940 H2 900 1007 F2 680 761 2-Step Group 90 MHDEWT-0000000C0HG240H 40H MHDEWT-0000000C0HG440H MHDEWT-0000000C0UF240H 817 MHDEWT-0000000C0UF440H G2 780 873 MHDEWT-0000000C0HG235H G4 840 940 F2 680 761 35H 3500 K 35H MHDEWT-0000000C0HG435H MHDEWT-0000000C0UF235H F4 730 817 MHDEWT-0000000C0UF435H G2 780 873 MHDEWT-0000000C0HG230H G4 840 940 F2 680 761 30H 3000 K 90 30H MHDEWT-0000000C0HG430H MHDEWT-0000000C0UF230H F4 730 817 MHDEWT-0000000C0UF430H G2 780 873 MHDEWT-0000000C0HG227H G4 840 940 E4 635 710 80 27H 2700 K 90 27H F2 680 761 Order Code MHDEWT-0000000C0BH240E MHDEWT-0000000C0HG240G 40G MHDEWT-0000000C0HH240H 730 80 Group MHDEWT-0000000C0BH440E F4 90 Order Code 40E 40H 80 Group 5-Step MHDEWT-0000000C0BG440E 4000 K 80 Order Code 3-Step MHDEWT-0000000C0HG427H MHDEWT-0000000C0UE427H MHDEWT-0000000C0UF227H MHDEWT-0000000C0HG440G MHDEWT-0000000C0HH240G 40G 35G 35G 30G 30G 27G 27G MHDEWT-0000000C0UF240G MHDEWT-0000000C0UF440G MHDEWT-0000000C0HG235G MHDEWT-0000000C0HG435G MHDEWT-0000000C0UF235G MHDEWT-0000000C0UF435G MHDEWT-0000000C0HG230G MHDEWT-0000000C0HG430G MHDEWT-0000000C0UF230G MHDEWT-0000000C0UF430G MHDEWT-0000000C0HG227G MHDEWT-0000000C0HG427G MHDEWT-0000000C0UE427G MHDEWT-0000000C0UF227G Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 19). MHD-E LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 4 XLAMP ® MHD-E LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V The following table provides order codes for XLamp MHD-E LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 17). Test condition: TJ = 85 °C, 36 V, IF = 200 mA Nominal CCT CRI Min Minimum Luminous Flux Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* H2 900 1007 2-Step Group Order Code 3-Step Group Order Code 70 5-Step Group 65E MHDEWT-0000000N0BH265E H4 970 1085 MHDEWT-0000000N0BH465E G4 840 940 MHDEWT-0000000N0HG465E H2 900 1007 H2 900 1007 6500 K 80 65E 70 57E MHDEWT-0000000N0HH265E MHDEWT-0000000N0BH257E H4 970 1085 MHDEWT-0000000N0BH457E G4 840 940 MHDEWT-0000000N0HG457E H2 900 1007 H2 900 1007 5700 K 80 57E 70 5000 K Order Code 50E H4 970 1085 G4 840 940 H2 900 1007 F4 730 817 80 50G 90 50G G2 780 873 MHDEWT-0000000N0HG450G MHDEWT-0000000N0HH250G MHDEWT-0000000N0UF450G MHDEWT-0000000N0UG250G 50E 50E MHDEWT-0000000N0HH257E MHDEWT-0000000N0BH250E MHDEWT-0000000N0BH450E MHDEWT-0000000N0HG450E MHDEWT-0000000N0HH250E MHDEWT-0000000N0UF450E MHDEWT-0000000N0UG250E Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 19). MHD-E LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 5 XLAMP ® MHD-E LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - 36 V - CONTINUED Nominal CCT CRI Min 70 Minimum Luminous Flux Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* G4 840 940 H2 900 1007 H4 970 1085 G2 780 873 G4 840 940 H2 900 1007 F2 680 761 2-Step Group 90 MHDEWT-0000000N0HG240H 40H MHDEWT-0000000N0HG440H MHDEWT-0000000N0UF240H 817 MHDEWT-0000000N0UF440H G2 780 873 MHDEWT-0000000N0HG235H G4 840 940 F2 680 761 35H 3500 K 35H MHDEWT-0000000N0HG435H MHDEWT-0000000N0UF235H F4 730 817 MHDEWT-0000000N0UF435H G2 780 873 MHDEWT-0000000N0HG230H G4 840 940 F2 680 761 30H 3000 K 90 30H MHDEWT-0000000N0HG430H MHDEWT-0000000N0UF230H F4 730 817 MHDEWT-0000000N0UF430H G2 780 873 MHDEWT-0000000N0HG227H G4 840 940 E4 635 710 80 27H 2700 K 90 27H F2 680 761 Order Code MHDEWT-0000000N0BH240E MHDEWT-0000000N0HG240G 40G MHDEWT-0000000N0HH240H 730 80 Group MHDEWT-0000000N0BH440E F4 90 Order Code 40E 40H 80 Group 5-Step MHDEWT-0000000N0BG440E 4000 K 80 Order Code 3-Step MHDEWT-0000000N0HG427H MHDEWT-0000000N0UE427H MHDEWT-0000000N0UF227H MHDEWT-0000000N0HG440G MHDEWT-0000000N0HH240G 40G 35G 35G 30G 30G 27G 27G MHDEWT-0000000N0UF240G MHDEWT-0000000N0UF440G MHDEWT-0000000N0HG235G MHDEWT-0000000N0HG435G MHDEWT-0000000N0UF235G MHDEWT-0000000N0UF435G MHDEWT-0000000N0HG230G MHDEWT-0000000N0HG430G MHDEWT-0000000N0UF230G MHDEWT-0000000N0UF430G MHDEWT-0000000N0HG227G MHDEWT-0000000N0HG427G MHDEWT-0000000N0UE427G MHDEWT-0000000N0UF227G Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 19). MHD-E LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 6 XLAMP ® MHD-E LED Relative Spectral Power Distribution RELATIVE SPECTRAL POWER DISTRIBUTION 100% Relative Spectral Power 90% 80% 70% 60% 6500 K, 80 CRI 50% 5000 K, 80 CRI 40% 3000 K, 80 CRI 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) RELATIVEFlux FLUX VS. JUNCTION Relative Output vs.TEMPERATURE Junction Temperature Test condition: 9 V (for reference), If = 800 mA; 18 V, If = 400 mA; 36 V, IF = 200 mA 120% Relative Luminous Flux 100% 80% 60% 40% 20% 0% 25 50 75 100 125 150 Junction Temperature (ºC) © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 7 XLAMP ® MHD-E LED ELECTRICAL CHARACTERISTICS (TJ = 85 °C) 1400 Forward Current (mA) 1200 1000 800 9V 600 400 200 0 8.00 8.25 8.50 8.75 9.00 9.25 9.50 9.75 10.00 Forward Voltage (V) 700 600 Forward Current (mA) 500 400 18 V 300 200 100 0 16.0 16.5 17.0 17.5 18.0 18.5 19.0 19.5 20.0 Forward Voltage (V) © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 8 XLAMP ® MHD-E LED Electrical Characteristics (Tj = 85ºC) ELECTRICAL CHARACTERISTICS (TJ = 85 °C) - CONTINUED 350 Forward Current (mA) 300 250 200 36 V 150 100 50 0 32 33 34 35 36 37 38 39 40 Forward Voltage (V) RELATIVE FLUX VS. CURRENT (TJ = 85 °C) 160% Relative Luminous Flux 140% 120% 100% 9V 80% 60% 40% 20% 0% 0 200 400 600 800 1000 1200 1400 Forward Current (mA) © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 9 XLAMP ® MHD-E LED RELATIVE FLUX VS. CURRENT (TJ = 85 °C) - CONTINUED 160% Relative Luminous Flux 140% 120% 100% 80% 18 V 60% 40% 20% 0% 0 100 200 300 400 Relative Intensity vs. Current (Tj = 85ºC) 500 600 700 Forward Current (mA) 160% Relative Luminous Flux 140% 120% 100% 80% 36 V 60% 40% 20% 0% 0 50 100 150 200 250 300 350 Forward Current (mA) © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 10 XLAMP ® MHD-E LED RELATIVE CHROMATICITY VS. CURRENT (WARM WHITE) 0.015 9V 0.010 0.005 ΔCCx 0.000 ΔCCy -0.005 -0.010 -0.015 200 400 600 800 1000 1200 1400 Current (mA) 0.015 18 V 0.010 0.005 ΔCCx 0.000 ΔCCy -0.005 -0.010 -0.015 100 200 300 400 500 600 700 Current (mA) © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 11 XLAMP ® MHD-E LED RELATIVE CHROMATICITY VS. CURRENT (WARM WHITE) - CONTINUED 0.015 36 V 0.010 0.005 ΔCCx 0.000 ΔCCy -0.005 -0.010 -0.015 50 100 150 200 250 300 350 Current (mA) RELATIVE CHROMATICITY VS. TEMPERATURE (WARM WHITE) Test condition: 9 V (for reference), If = 800 mA; 18 V, If = 400 mA; 36 V, IF = 200 mA 0.015 0.010 0.005 ΔCCx 0.000 ΔCCy -0.005 -0.010 -0.015 25 50 75 100 125 150 Tj (°C) © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 12 XLAMP ® MHD-E LED TYPICAL SPATIAL DISTRIBUTION Test condition: 9 V (for reference), If = 800 mA; 18 V, If = 400 mA; 36 V, IF = 200 mA Far Field 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) THERMAL DESIGN The maximum forward current is determined by the thermal resistance between the LED junction and ambient. It is crucial for the end product to be designed in a manner that minimizes the thermal resistance from the solder point to ambient in order to optimize lamp life and optical characteristics. 1500 1400 1300 Maximum Current (mA) 1200 1100 1000 900 800 9V 700 600 500 Rj-a = 5 °C/W 400 Rj-a = 6.5 °C/W 300 Rj-a = 8 °C/W 200 Rj-a = 10 °C/W 100 0 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 13 XLAMP ® MHD-E LED THERMAL DESIGN - CONTINUED 750 700 650 Maximum Current (mA) 600 550 500 450 400 18 V 350 300 250 Rj-a = 5 °C/W 200 Rj-a = 6.5 °C/W 150 Rj-a = 8 °C/W 100 Rj-a = 10 °C/W 50 0 Thermal Design 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) 375 350 325 Maximum Current (mA) 300 275 250 225 200 36 V 175 150 125 Rj-a = 5 °C/W 100 Rj-a = 6.5 °C/W 75 Rj-a = 8 °C/W 50 Rj-a = 10 °C/W 25 0 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 14 XLAMP ® MHD-E LED PERFORMANCE GROUPS - LUMINOUS FLUX (TJ = 85 °C) XLamp MHD-E LEDs are tested for luminous flux and placed into one of the following bins. Group Code Minimum Luminous Flux Maximum Luminous Flux E4 635 680 F2 680 730 F4 730 780 G2 780 840 G4 840 900 H2 900 970 H4 970 1040 J2 1040 1120 PERFORMANCE GROUPS - CHROMATICITY XLamp MHD-E LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 40H 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3777 0.3739 0.3797 0.3816 0.3861 0.3855 0.3838 0.3777 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 15 XLAMP ® MHD-E LED PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 50G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 40G 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 53.2 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 EasyWhite Color Temperatures – 5-Step Ellipse Bin Code CCT 65E Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 6500 K 0.3123 0.3282 0.01110 0.00550 61.0 57E 5700 K 0.3287 0.3417 0.01230 0.00600 72.0 50E 5000 K 0.3447 0.3553 0.01400 0.00520 65.0 40E 4000 K 0.3818 0.3797 0.01565 0.00670 53.7 STANDARD WHITE CHROMATICITY REGIONS PLOTTED ON THE 1931 CIE CURVE 0.44 ANSI C78.377 Quadrangle 0.43 EasyWhite 5-Step 0.42 EasyWhite 3-Step 0.41 EasyWhite 2-Step 2700 K 3000 K 3500 K 4000 K 0.40 4500 K 0.39 5000 K 0.38 CCy 0.37 5700 K 0.36 6500 K 0.35 0.34 8000 K 0.33 0.32 0.31 0.30 0.29 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.27 0.28 CCx © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 16 XLAMP ® MHD-E LED BIN AND ORDER CODE FORMAT Bin codes and order codes for MHD-E LEDs are configured in the following manner: Order Code Bin Code Series MHDE = MHD-E Series MHDE = MHD-E Internal code Chromaticity bin CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Vf class C0 = 9-V/18-V class N0 = 36-V class Chromaticity region Internal code SSSSCC-WWW-FF-GGN-AAAAA SSSSCC-HHHH-HHHGGNFFDDD Flux Vf class C0 = 9-V/18-V class N0 = 36-V class Color WT = White © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CRI Specification B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Flux bin Color WT = White CLD-DS112 REV 3 17 XLAMP ® MHD-E LED REFLOW SOLDERING CHARACTERISTICS In testing, Cree LED has found XLamp MHD-E LEDs to be compatible with JEDEC J-STD-020C, using the parameters listed below. As a general guideline, Cree LED recommends that users follow the recommended soldering profile provided by the manufacturer of the solder paste used, and therefore it is the lamp or luminaire manufacturer’s responsibility to determine applicable soldering requirements. Note that this general guideline may not apply to all PCB designs and configurations of reflow soldering equipment. tP TP Critical Zone TL to TP Temperature Ramp-up TL tL Tsmax Tsmin Ramp-down ts Preheat 25 t 25˚C to Peak Profile Feature Average Ramp-Up Rate (Tsmax to Tp) Time Lead-Free Solder 1.2 °C/second Preheat: Temperature Min (Tsmin) 120 °C Preheat: Temperature Max (Tsmax) 170 °C Preheat: Time (tsmin to tsmax) 65-150 seconds Time Maintained Above: Temperature (TL) Time Maintained Above: Time (tL) 217 °C 45-90 seconds Peak/Classification Temperature (Tp) 235 - 245 °C Time Within 5 °C of Actual Peak Temperature (tp) 20-40 seconds Ramp-Down Rate 1 - 6 °C/second Time 25 °C to Peak Temperature 4 minutes max. Note: All temperatures refer to the topside of the package, measured on the package body surface. © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 18 XLAMP ® MHD-E LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. Moisture Sensitivity Cree LED recommends keeping XLamp LEDs in the provided, resealable moisture-barrier packaging (MBP) until immediately prior to soldering. Unopened MBPs that contain XLamp LEDs do not need special storage for moisture sensitivity. Once the MBP is opened, XLamp MHD-E LEDs may be stored as MSL 1 per JEDEC J-STD-033, meaning they have unlimited floor life in conditions of ≤ 30 ºC/85% relative humidity (RH). Regardless of the storage condition, Cree LED recommends sealing any unsoldered LEDs in the original MBP. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACH Compliance REACH substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACH Declaration. REACH banned substance information (REACH Article 67) is also available upon request. © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 19 XLAMP ® MHD-E LED NOTES - CONTINUED UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 20 XLAMP ® MHD-E LED 67 78 8 45 56 23 34 MECHANICAL DIMENSIONS Thermal vias, if present, are not shown on these drawings. F F OPTICAL MODEL ORIGIN CATHODE SIDE E SOLDERMASK MAY 0.75 BE PRESENT 0.2 7.00 CATHODE SIDE 6.70 5.30 5.30 6.7 0.5 0.50 0.71 ANODE SIDE ANODE SIDE 6.70 CATHODE SIDE 6.70 7.00 7.00 D 5 6 4 5 0.35 0.2 3 0.35 0.2 2 3 4 Top TOPView VIEW C 7.00 C SOLDERMASK MAY BE0.75 PRESENT 0.2 SOLDERMASK 6.70 MAY BE PRESENT 6.70 5.30 0.50 4.30 CENTER PAD IS ELECTRICALLY ISOLATED 6.70 REF. F BOTTOM VIEW BOTTOM VIEW CENTER PAD IS ELECTRICALLY SOLDERMASK MAY BEISOLATED PRESENT E 6.70 REF. 0.80 6.70 6.70 TOP VIEW A SIDE VIEW 8 BOTTOMView VIEW Bottom 78 U UNLESS OTHERWISE SPECIF NAME D D DIMENSIONS ARE IN MILLIM T TLING DRAWN 26 TOLERANCES: 0.5° 1° BEND ANGULAR: MACH •• ••• TWO ONE PLACE 0.5 DECIMAL CHECKED • PLACE 0.05DECIMAL • INSIDE BEND RADII EQUAL•• ENG APPR. MATERIAL MACHINE/CASTING RADII• MFG APPR. •• RADII AND 0.10DIA: CENTER PAD CENTER PAD IN Q.A. INTERPRET GEOMETRIC PROPRIETARY AND CONFIDENTIAL B UPDATED OPTICA T PROPRIETARY AND CONFIDENTIAL B UPDATED OPTICAL MODEL ORIGIN TOLERANCING PER: ANGLE THIRD THE INFORMATION CONTAINED IN OF TH IS ELECTRICALLY M IS ELECTRICALLY THE INFORMATION CONTAINED IN THIS DRAWING ISANY THEREPRODUCTION SOLE PROPERTY MATERIAL A DRAWING INITIAT DRAWING IS THE SOLE PROPERTY OF CREE LED. IN M A DRAWING INITIATED CREE LED. ANY REPRODUCTION IN MATERIAL PART OR AS A WHOLE WITHOUT ISOLATED ISOLATED FI PART OR AS A WHOLE WITHOUT WRITTEN PERMISSION OF CREE LED REVDESCRIPTION F WRITTEN PERMISSION OF CREE LEDFINISH IS © PROHIBITED. REVDESCRIPTION IS © PROHIBITED. FINISH 2021 CreeLED, Inc. a subsidiary 2021 CreeLED, Inc. a subsidiary of SMART Global Holdings, Inc. APPLICATION of SMARTBOTTOM Global Holdings, Inc. APPLICATION BOTTOM VIEW ALTERNATE VIEW BOTTOM VIEW ALTERNATE Alternate Bottom View 5 2 23 56 4 67 2 34 4.30 © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. C C B B UNLESS OTHERWISE SPECIFIED: UNLESS OTHERWISE SPECIFIED: NAME DATEDR NAME CreeLED, Inc. DATE 4400 SILICON DIMENSIONS ARE IN MILLIMETERS DIMENSIONS ARE IN MILLIMETERS DURHAM, NC 27703 TLING DRAWN 26AUG22 TOLERANCES: TLING DRAWN 26AUG22 TOLERANCES: 0.5° 1° BEND • TITLE: ANGULAR: MACH 0.5° 1° BEND ANGULAR: MACH • ONE PLACE 0.5 DECIMAL CHECKED ••• TWO ONE PLACE 0.5 DECIMAL A TITLE: CHECKED • TWO PLACE 0.05DECIMAL PLACE 0.05DECIMAL CLD-DS112 REV 3 ENAME 0001 MHD-E OPTICAL MODEL ORIGIN 4.30 0.70 ENAME 0001 MHD-E A ALTERNA CENTER PAD IS ELECTRICALLY ISOLATED D 0.70 CEN IS EL ISOL 6.70 REF. CATHODE SIDE B B 0.70 1 4.30 2 F 0.71 ANODE SIDE ANODE SIDE 0.701 Side SIDEView VIEW TOP VIEW 5.30 ANODE SIDE OPTICAL MODEL ORIGIN 6.70 REF. D 7 6.70 0.80 E OPTICAL MODEL 7.00 ORIGIN All measurements are ±.13mm unless otherwise indicated. CreeLED, Inc. DR 4400 SILICON DURHAM, NC 27703 A 21 XLAMP ® MHD-E LED MECHANICAL DIMENSIONS - CONTINUED 9‑V/18‑V Class - 9‑V Configuration 9‑V/18‑V Class - 18‑V Configuration 36‑V Class This configuration should not be used for 36‑V class MHD-E 7 7 6 6 5 5 4 4 3 3 4 3 8 7 6 5 4 3 8 LEDs. 7 6 5 9-V/18-V CLASS - 9-V CONFIGURATION 8-V CLASS - 9-V CONFIGURATION 9-V/18-V CLASS - 18-V CONFIGURATION 9-V/18-V CLASS - 18-V CONFIGURATION 36-V CLASS CLASS 6.70 6.70 6.70 6.70 8-V9-V/18-V CLASS -CLASS 9-V CONFIGURATION - 9-V CONFIGURATION 9-V/18-V9-V/18-V CLASS -CLASS 18-V CONFIGURATION 5.30 5.30 - 18-V CONFIGURATION CLASS 36-V CLASS 6.70 6.70 0.70 0.70 6.70 6.70 5.30 5.30 0.70 2 0.70 0.70 0.70 8 8 7 7 7 6 6 6 6 0.40 5 5 1.29 0.80 0.40 0.80 0.25 0.40 0.25 1.29 1.29 1.29 2.95 2.95 1.24 RECOMMENDED Recommended Stencil Opening RECOMMENDED UNLESS OTHERWISE SPECIFIED: UNLESS OTHERWISE SPECIFIED: NAME DATE NAME DATE SOLDERMASK OPENING SOLDERMASK OPENING 7 1.24 0.25 1.24RECOMMENDED 0.25 1.24 RECOMMENDED STENCIL OPENING STENCIL OPENING Recommended Soldermask Opening RECOMMENDED RECOMMENDED 8 1.29 6.70 2.95 4.30 4.30 RECOMMENDED RECOMMENDED SOLDERMASK SOLDERMASK OPENINGOPENING 8 2.95 6.70 6.70 6.70 2.95 2.95 4.30 2.95 2.95 6.70 4.30 1.29 0.25 0.25 0.50 0.80 0.50 0.80 6.70 0.50 0.50 0.80 5.30 5.30 6.70 1.29 1.29 5.30 5.30 5.30 6.70 0.40 6.70 0.80 0.80 0.80 6.70 6.70 5.30 0.25 5.30 RECOMMENDED PCB FOOTPRINT RECOMMENDED PCB FOOTPRINT 6.70 6.70 0.25 6.70 0.70 0.70Recommended PCBFOOTPRINT Footprint RECOMMENDED PCB FOOTPRINT RECOMMENDED PCB 0.70 RECOMMENDED PCB FOOTPRINT RECOMMENDED PCB FOOTPRINT 6.70 6.70 5.30 0.50 0.50 0.50 Recommended PCBFOOTPRINT Footprint RECOMMENDED PCB RECOMMENDED PCB FOOTPRINT 3.90 3.90 1 3.13 0.70 3.90 1 3.13 6.76 6.76 3.13 3.13 6.76 6.76 6.76 6.76 6.76 6.76 3.90 1 2 0.70 0.70 1 2 2 0.50 8 8 5 5 CreeLED 4400 SIL DIMENSIONS ARE IN MILLIMETERS DIMENSIONS ARE IN MILLIMETERS STENCILSTENCIL OPENING TLING DRAWN 26AUG22 DURHAM TLING TOLERANCES: DRAWN 26AUG22 TOLERANCES: 0.5° 1° BEND ANGULAR: MACH 0.5° 1° BEND •OPENING ANGULAR: MACH •• 0.05 ONE PLACE 0.5 DECIMAL ONE PLACE 0.5 DECIMAL CHECKED TITLE: TITLE: CHECKED • TWO PLACE 0.05 DECIMAL ••• INSIDE TWO PLACE DECIMAL • INSIDE BEND RADII EQUAL BEND RADII EQUAL ENG APPR. ENG APPR. MATERIAL RADII 0.50 MATERIAL •• MACHINE/CASTING RADII 0.50 ••UNLESS MACHINE/CASTING OTHERWISE SPECIFIED: MHD-E MFGDATE APPR. NAME MHD-E CreeLED MFG APPR. RADII AND 0.10 DIA: RADII AND 0.10 DIA: UNLESS OTHERWISE SPECIFIED: 4400 SIL NAME DATE DIMENSIONS ARE IN MILLIMETERS DURHAM Q.A. TLING DRAWN 26AUG22 INTERPRET GEOMETRIC Q.A. TOLERANCES: INTERPRET GEOMETRIC DIMENSIONS ARE IN MILLIMETERS TLING DRAWN 26AUG22 PROPRIETARY AND CONFIDENTIAL 0.5° 1° BEND •• ONE ANGULAR: MACH TOLERANCES: TOLERANCING PER: B UPDATED OPTICAL MODEL ORIGIN PROPRIETARY AND CONFIDENTIAL TOLERANCING PER: B UPDATED OPTICAL MODEL ORIGIN THIRD ANGLE PROJECTION THIRD ANGLE PROJECTION PLACE 0.5DECIMAL TITLE: 0.5° 1° BEND •THIS ANGULAR: MACH CHECKED THE INFORMATION CONTAINED IN THE INFORMATION CONTAINED IN THIS MATERIAL MATERIAL • TWO PLACE 0.05 DECIMAL • ONE PLACE 0.5 DECIMAL TITLE: CHECKED DRAWING IS THE PROPERTY SIZEDWG. SIZE NO.DWG. NO.R DRAWING ISANY THE PROPERTY ASOLE DRAWING INITIATED • INSIDE BEND RADII EQUAL ASOLE DRAWING INITIATED TWOENG PLACE 0.05 DECIMAL APPR. LED. ANY REPRODUCTION IN••OF MATERIAL CREE LED. REPRODUCTION INOF MATERIAL MATERIAL INSIDE BEND RADII EQUAL ENG APPR. PART OR AS AWITHOUT WHOLE WITHOUT PART OR CREE AS A WHOLE FINISH •• MACHINE/CASTING RADII 0.50 MATERIAL WRITTEN PERMISSION OF FINISH CREE MHD-E MFG APPR. WRITTEN PERMISSION OF CREE LED 7M0001 C RADIILED AND DIA: 7M0001 REV DESCRIPTION ••0.10 MACHINE/CASTING RADII 0.50 C REV DESCRIPTION IS PROHIBITED. MHD-E B FINISH IS PROHIBITED. MFG APPR. FINISH RADII AND 0.10DIA: © 2021 CreeLED, Inc. a subsidiary Q.A. INTERPRET GEOMETRIC © 2021 CreeLED, Inc. a subsidiary ofGlobal SMART Global Holdings, Inc. APPLICATION SCALE: WEIGHT 12:1 Q.A. of SMART Inc. APPLICATION SHEET INTERPRET GEOMETRIC SCALE: WEIGHT: 12:1 PROPRIETARY AND CONFIDENTIAL TOLERANCING PER:ORIGIN B Holdings, UPDATED OPTICAL MODEL ORIGIN THIRD ANGLE PROPRIETARY AND CONFIDENTIAL TOLERANCING PER: PROJECTION B UPDATED OPTICAL MODEL THE INFORMATION CONTAINED IN THIS MATERIAL THIRD ANGLE PROJECTION SIZE DWG. NO. DRAWING IS THE SOLE PROPERTY OF THE INFORMATION CONTAINED IN THIS 4 11 NO. 1R 3INITIATED 2 2 MATERIAL 4 1 SIZEDWG. 3 2ASOLE MATERIAL2 A ISDRAWING INITIATED CREE ANY REPRODUCTION IN THE PROPERTY DRAWING PART LED. ORDRAWING AS ALED. WHOLE WITHOUT CREE ANY REPRODUCTION INOF MATERIAL FINISH WRITTEN PERMISSION OF CREE LED PART OR AS A WHOLE WITHOUT 7M0001 C REV DESCRIPTION IS © PROHIBITED. WRITTEN PERMISSION OF CREE LEDFINISH FINISH 7M0001 B C DESCRIPTION IS CreeLED, PROHIBITED. FINISH Inc. aREV subsidiary of 2021 SMART GlobalCreeLED, Holdings, Inc. APPLICATION SHEET SCALE: WEIGHT: 12:1 © 2021 Inc. a subsidiary of SMART Global Holdings, Inc. APPLICATION SCALE: WEIGHT 12:1 4 1 3 2 1 2 4 1 2 1 2 3 © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 22 POSITIVE (+) XLAMP ® MHD-E LED NEGATIVE (-) ELECTRICAL CONFIGURATION 18 V 9V SOLDER PAD LINK NEGATIVE (-) POSITIVE (+) NEGATIVE (-) POSITIVE (+) POSITIVE (+) NEGATIVE (-) 9-V Configuration 36 V 18-V Configuration 9V POSITIVE (+) NEGATIVE (-) POSITIVE (+) NEGATIVE (-) POSITIVE (+) NEGATIVE (-) 36-V Configuration © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 23 XLAMP ® MHD-E LED TAPE AND REEL All Cree LED carrier tapes conform to EIA-481D, Automated Component Handling Systems Standard. All dimensions are ±.15 mm unless otherwise indicated. Po T E Do Bo R P2 W A Anode side F A P1 B D1 "H" Ko B-B SECTION Bo (on a place in the bottom of the corner radii) Ao (on a place in the bottom of the corner radii) R "I" Ao Item Dim. ITEM Ao Dim. 7.60 Bo Ao 7.60 7.60 Ko 1.70 DETAIL"H" DETAIL"I" A-A SECTION Bo Po 7.604.00 Ko Po P2 1.70 12.00 4.00 2.00 P1 T P1 E 0.30 12.00 1.75 ITEM F Do D1 W R Dim. 7.50 1.50 1.50 16.00 3deg P2 F 2.00 7.50 TDo 0.30 1.50 E D1 1.75 1.50 W R 16.00 3° NOTICE 1) All Cree LED carrier tapes conform to EIA-481D, Automated Component handling Systems Standard 2) Measurement tolerances unless indicated otherwise: .xx = ±.15 mm 2402-M027 MHDE © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 24 XLAMP ® MHD-E LED TAPE AND REEL - CONTINUED Feed Direction END START Trailer Loaded Pockets Leader Min. 160 mm empty pockets sealed with tape 1000 Lamps Min. 400 mm empty pockets with min. 100 mm sealed Feed Direction Cover Tape Pocket Tape 13 mm 13” © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 25 XLAMP ® MHD-E LED PACKAGING © 2015-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS112 REV 3 26
MHDEWT-0000-000N0UF235G 价格&库存
很抱歉,暂时无法提供与“MHDEWT-0000-000N0UF235G”相匹配的价格&库存,您可以联系我们找货
