XHP70D-00-0000-0D0UK40E5
    CREELED
    2828(7070公制)
    LED 照明 XLamp® XHP70.3 白色,天然 4000K 11.2V 1.05A 120° 2828(7070 公制)
XHP70D-00-0000-0D0UK40E5 数据手册
PRODUCT FAMILY DATA SHEET XLamp® XHP70.3 LEDs XHP70.3 High Density XHP70.3 High Intensity PRODUCT DESCRIPTION FEATURES The XLamp® XHP70.3 LEDs are the third generation of Extreme • Available in white, configurable to 6 V or 12 V by PCB layout High Power LEDs that deliver the best lumen density, reliability and • Available in 5-step EasyWhite® bins at 3000 K to 5000 K optical control available in their size. By leveraging the XHP family advantages, lighting manufacturers can significantly reduce their CCT, 3-step EasyWhite bins at 2700 K to 5000 K and 2-step EasyWhite bins at 2700 K to 4000 K CCT system cost by using fewer optics, PCBs and heat sinks than • Available in ANSI white bins at 3000 K to 7000 K CCT possible with standard LEDs. • Broadcast color option at 5700 K provides maximum performance for TV events that require extremely high TLCI The third generation XHP family LEDs deliver improved optical performance versus the previous generations, with higher intensity • Available in standard, 70-, 80-, 90-, and 95‑minimum CRI options through optics than the second generation and the XHP family’s • Binned at 85 °C highest on-axis intensity. • Maximum drive current: 7200 mA (6 V), 3600 mA (12 V) • Low thermal resistance: 0.2 °C/W XLamp XHP70.3 LEDs are optimized for outdoor and premium • Wide viewing angle: 120° (HD), 115 (HI) indoor lighting applications that require large amounts of light • Unlimited floor life at ≤ 30 ºC/85% RH output from small luminaires, such as stadium, outdoor area and • Reflow solderable - JEDEC J‑STD‑020C architectural spotlight. • RoHS and REACH compliant • UL® recognized component (E349212) Cree LED / 4001 E. Hwy. 54, Suite 2000 / Durham, NC 27709 USA / +1.919.313.5330 / www.cree-led.com © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 1 XLAMP ® XHP70.3 LED TABLE OF CONTENTS Characteristics........................................................................................................................................................................................................ 3 Flux Characteristics, High Density EasyWhite® Order Codes and Bins............................................................................................................... 4 Flux Characteristics, High Density ANSI White Order Codes and Bins................................................................................................................ 7 Flux Characteristics, High Density Broadcast Order Codes and Bins............................................................................................................... 10 Flux Characteristics, High Intensity EasyWhite® Order Codes and Bins........................................................................................................... 11 Flux Characteristics, High Intensity ANSI White Order Codes and Bins............................................................................................................ 14 Flux Characteristics, High Intensity Broadcast Order Codes and Bins.............................................................................................................. 16 Relative Spectral Power Distribution................................................................................................................................................................... 17 Relative Flux vs. Junction Temperature............................................................................................................................................................... 17 Electrical Characteristics (TJ = 85 °C).................................................................................................................................................................. 18 Relative Flux vs. Current (TJ = 85 °C)................................................................................................................................................................... 19 Relative Chromaticity vs Current (Warm White)................................................................................................................................................. 20 Relative Chromaticity vs Temperature (Warm White)......................................................................................................................................... 21 Typical Spatial Distribution................................................................................................................................................................................... 21 Thermal Design..................................................................................................................................................................................................... 22 Performance Groups - Luminous Flux (TJ = 85 °C)............................................................................................................................................. 23 Performance Groups - Chromaticity.................................................................................................................................................................... 23 EasyWhite® Chromaticity Regions Plotted on the 1931 CIE Curve.................................................................................................................... 27 ANSI Standard Cool White Kits Plotted on ANSI Standard Chromaticity Regions........................................................................................... 28 Standard Warm and Neutral White Kits Plotted on ANSI Standard Chromaticity Regions.............................................................................. 29 Bin and Order-Code Format.................................................................................................................................................................................. 30 Reflow Soldering Characteristics......................................................................................................................................................................... 31 Notes..................................................................................................................................................................................................................... 32 Mechanical Dimensions....................................................................................................................................................................................... 34 Electrical Configuration........................................................................................................................................................................................ 36 Tape and Reel........................................................................................................................................................................................................ 37 Packaging.............................................................................................................................................................................................................. 39 © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 2 XLAMP ® XHP70.3 LED CHARACTERISTICS XHP70.3 LEDs are tested and binned in the 12‑V configuration. See the Mechanical Dimensions section on page 34 for pad layout options. Characteristics Thermal resistance, junction to solder point Unit Minimum Typical °C/W 0.2 Viewing angle (FWHM) - High Density degrees 120 Viewing angle (FWHM) - High Intensity degrees 115 Temperature coefficient of voltage (6 V)* mV/°C -2.5 Temperature coefficient of voltage (12 V) mV/°C -5.0 ◊ ESD withstand voltage (HBM per Mil-Std-883D) Maximum V 8000 DC forward current (6 V)* mA 7200 DC forward current (12 V) mA 3600 Reverse voltage V 1 Forward voltage (6 V, @ 2100 mA, 85 °C)* V 5.6 6.1 Forward voltage (12 V, @ 1050 mA, 85 °C) V 11.2 12.2 LED junction temperature °C 150 Note: ◊ * Thermal resistance measurement was performed per the JEDEC JESD51-14 standard. See the Thermal Resistance Measurement application note for more details. Data for the 6‑V configuration is calculated and for reference only. © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 3 XLAMP ® XHP70.3 LED FLUX CHARACTERISTICS, HIGH DENSITY EASYWHITE® ORDER CODES AND BINS The following table provides order codes for XLamp XHP70.3 High Density LEDs. For a complete description of how the flux and chromaticity groups are reflected in the bin code and order code nomenclature, please see the Bin and Order Code Formats section (page 30). Binning condition: TJ = 85 °C; 12 V, IF = 1050 mA Reference condition: TJ = 85 °C; 6 V, IF = 2100 mA Nominal CCT CRI Min 70 5000 K Typ Minimum Luminous Flux 3-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* P4 1965 2164 P2 1830 2015 N4 1710 1883 P2 1830 2015 XHP70D-00-00000D0HP250G N4 1710 1883 XHP70D-00-00000D0HN450G N2 1590 1751 XHP70D-00-00000D0HN250G M4 1485 1635 XHP70D-00-00000D0HM450G N2 1590 1751 XHP70D-00-00000D0UN250G M4 1485 1635 M2 1380 1520 80 90 2-Step Group Order Code Group Order Code 5-Step Group Order Code XHP70D-00-00000D0BP450E 50E XHP70D-00-00000D0BP250E XHP70D-00-00000D0BN450E 50G 50G XHP70D-00-00000D0UM450G XHP70D-00-00000D0UM250G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 32). • XLamp XHP70.3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. • Flux values @ 25 °C are calculated and for reference only. © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 4 XLAMP ® XHP70.3 LED FLUX CHARACTERISTICS, HIGH DENSITY EASYWHITE® ORDER CODES AND BINS - CONTINUED Nominal CCT CRI Min 70 4500 K 80 90 70 4000 K 80 90 Typ Minimum Luminous Flux 2-Step 3-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* P4 1965 2164 P2 1830 2015 N4 1710 1883 N4 1710 1883 N2 1590 1751 M4 1485 1635 XHP70D-00-00000D0HM445G M4 1485 1635 XHP70D-00-00000D0UM445G M2 1380 1520 K4 1290 1420 P4 1965 2164 P2 1830 2015 N4 1710 1883 N4 1710 1883 N2 1590 1751 M4 1485 1635 XHP70D-00-00000D0HM440H XHP70D-00-00000D0HM440G M4 1485 1635 XHP70D-00-00000D0UM440H XHP70D-00-00000D0UM440G M2 1380 1520 K4 1290 1420 Group Order Code Group Order Code 5-Step Group Order Code XHP70D-00-00000D0BP445E 45E XHP70D-00-00000D0BP245E XHP70D-00-00000D0BN445E XHP70D-00-00000D0HN445G 45G 45G XHP70D-00-00000D0HN245G XHP70D-00-00000D0UM245G XHP70D-00-00000D0UK445G XHP70D-00-00000D0BP440E 40E XHP70D-00-00000D0BP240E XHP70D-00-00000D0BN440E XHP70D-00-00000D0HN440H 40H 40H XHP70D-00-00000D0HN240H XHP70D-00-00000D0UM240H XHP70D-00-00000D0UK440H XHP70D-00-00000D0HN440G 40G 40G XHP70D-00-00000D0HN240G XHP70D-00-00000D0UM240G XHP70D-00-00000D0UK440G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 32). • XLamp XHP70.3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. • Flux values @ 25 °C are calculated and for reference only. © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 5 XLAMP ® XHP70.3 LED FLUX CHARACTERISTICS, HIGH DENSITY EASYWHITE® ORDER CODES AND BINS - CONTINUED Nominal CCT CRI Min 70 3500 K 80 90 70 3000 K Typ Minimum Luminous Flux Flux (lm) @ 85 °C Flux (lm) @ 25 °C* P2 1830 2015 N4 1710 1883 N2 1590 1751 N4 1710 1883 N2 1590 1751 M4 1485 1635 XHP70D-00-00000D0HM435H XHP70D-00-00000D0HM435G M4 1485 1635 XHP70D-00-00000D0UM435H XHP70D-00-00000D0UM435G M2 1380 1520 K4 1290 1420 P2 1830 2015 N4 1710 1883 N2 1590 1751 N2 1590 1751 M4 1485 1635 XHP70D-00-00000D0HM430H M2 1380 1520 XHP70D-00-00000D0UM230H K4 1290 1420 K2 1200 1321 M4 1485 1635 90 Group Order Code Group Order Code 5-Step Group Order Code XHP70D-00-00000D0BP235E 35E XHP70D-00-00000D0BN435E XHP70D-00-00000D0BN235E XHP70D-00-00000D0HN435H 35H 35H XHP70D-00-00000D0HN235H XHP70D-00-00000D0UM235H XHP70D-00-00000D0HN435G 35G 35G XHP70D-00-00000D0UK435H XHP70D-00-00000D0HN235G XHP70D-00-00000D0UM235G XHP70D-00-00000D0UK435G XHP70D-00-00000D0BP230E 30E XHP70D-00-00000D0BN430E XHP70D-00-00000D0BN230E 30H 80 2700 K 3-Step Group 80 90 2-Step 30H XHP70D-00-00000D0HN230H XHP70D-00-00000D0UK430H 30G XHP70D-00-00000D0HM427H M2 1380 1520 XHP70D-00-00000D0HM227H K4 1290 1420 XHP70D-00-00000D0UK427H K2 1200 1321 J4 1120 1233 27H XHP70D-00-00000D0UK227H XHP70D-00-00000D0UJ427H XHP70D-00-00000D0HM430G XHP70D-00-00000D0UM230G 30G XHP70D-00-00000D0UK230H 27H XHP70D-00-00000D0HN230G XHP70D-00-00000D0UK430G XHP70D-00-00000D0UK230G 27G XHP70D-00-00000D0HM427G XHP70D-00-00000D0HM227G XHP70D-00-00000D0UK427G 27G XHP70D-00-00000D0UK227G XHP70D-00-00000D0UJ427G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 32). • XLamp XHP70.3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. • Flux values @ 25 °C are calculated and for reference only. © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 6 XLAMP ® XHP70.3 LED FLUX CHARACTERISTICS, HIGH DENSITY ANSI WHITE ORDER CODES AND BINS The following table provides order codes for XLamp XHP70.3 High Density LEDs. For a complete description of how the flux and chromaticity groups are reflected in the bin code and order code nomenclature, please see the Bin and Order Code Formats section (page 30). Binning condition: TJ = 85 °C; 12 V, IF = 1050 mA Reference condition: TJ = 85 °C; 6 V, IF = 2100 mA Nominal CCT 7000 K CRI Chromaticity Regions 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U Minimum Luminous Flux Group P2 1830 2015 XHP70D-00-0000-0D00P20DT 0 68 N4 1710 1883 XHP70D-00-0000-0D00N40DT N2 1590 1751 XHP70D-00-0000-0D00N20DT P2 1830 2015 XHP70D-00-0000-0D0BP20DT N4 1710 1883 XHP70D-00-0000-0D0BN40DT N2 1590 1751 XHP70D-00-0000-0D0BN20DT 70 0 1A, 1B, 1C, 1D 68 70 80 0 6000 K 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U Order Code Typ 80 6500 K Flux (lm) Flux (lm) @ 85 °C @ 25 °C* Min 70 80 90 68 N2 1590 1751 XHP70D-00-0000-0D0HN20DT M4 1485 1635 XHP70D-00-0000-0D0HM40DT P2 1830 2015 XHP70D-00-0000-0D00P20E1 N4 1710 1883 XHP70D-00-0000-0D00N40E1 N2 1590 1751 XHP70D-00-0000-0D00N20E1 P2 1830 2015 XHP70D-00-0000-0D0BP20E1 N4 1710 1883 XHP70D-00-0000-0D0BN40E1 N2 1590 1751 XHP70D-00-0000-0D0BN20E1 N2 1590 1751 XHP70D-00-0000-0D0HN20E1 M4 1485 1635 XHP70D-00-0000-0D0HM40E1 P2 1830 2015 XHP70D-00-0000-0D00P20DV N4 1710 1883 XHP70D-00-0000-0D00N40DV P2 1830 2015 XHP70D-00-0000-0D0BP20DV N4 1710 1883 XHP70D-00-0000-0D0BN40DV N2 1590 1751 XHP70D-00-0000-0D0HN20DV M4 1485 1635 XHP70D-00-0000-0D0HM40DV M4 1485 1635 XHP70D-00-0000-0D0UM40DV M2 1380 1520 XHP70D-00-0000-0D0UM20DV Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 32). • XLamp XHP70.3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. • Flux values @ 25 °C are calculated and for reference only. © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 7 XLAMP ® XHP70.3 LED FLUX CHARACTERISTICS, HIGH DENSITY ANSI WHITE ORDER CODES AND BINS - CONTINUED Nominal CCT CRI Chromaticity Regions Min 0 Minimum Luminous Flux Typ 68 70 5700 K 2A, 2B, 2C, 2D 80 90 0 68 70 5000 K 3A, 3B, 3C, 3D 80 90 0 70 4500 K 4A, 4B, 4C, 4D 80 90 68 Group Flux (lm) Flux (lm) @ 85 °C @ 25 °C* P4 1965 2164 Order Code XHP70D-00-0000-0D00P40E2 P2 1830 2015 XHP70D-00-0000-0D00P20E2 N4 1710 1883 XHP70D-00-0000-0D00N40E2 P4 1965 2164 XHP70D-00-0000-0D0BP40E2 P2 1830 2015 XHP70D-00-0000-0D0BP20E2 N4 1710 1883 XHP70D-00-0000-0D0BN40E2 N4 1710 1883 XHP70D-00-0000-0D0HN40E2 N2 1590 1751 XHP70D-00-0000-0D0HN20E2 M4 1485 1635 XHP70D-00-0000-0D0HM40E2 N2 1590 1751 XHP70D-00-0000-0D0UN20E2 M4 1485 1635 XHP70D-00-0000-0D0UM40E2 M2 1380 1520 XHP70D-00-0000-0D0UM20E2 P4 1965 2164 XHP70D-00-0000-0D00P40E3 P2 1830 2015 XHP70D-00-0000-0D00P20E3 N4 1710 1883 XHP70D-00-0000-0D00N40E3 P4 1965 2164 XHP70D-00-0000-0D0BP40E3 P2 1830 2015 XHP70D-00-0000-0D0BP20E3 N4 1710 1883 XHP70D-00-0000-0D0BN40E3 P2 1830 2015 XHP70D-00-0000-0D0HP20E3 N4 1710 1883 XHP70D-00-0000-0D0HN40E3 N2 1590 1751 XHP70D-00-0000-0D0HN20E3 M4 1485 1635 XHP70D-00-0000-0D0HM40E3 N2 1590 1751 XHP70D-00-0000-0D0UN20E3 M4 1485 1635 XHP70D-00-0000-0D0UM40E3 M2 1380 1520 XHP70D-00-0000-0D0UM20E3 P4 1965 2164 XHP70D-00-0000-0D00P40E4 P2 1830 2015 XHP70D-00-0000-0D00P20E4 N4 1710 1883 XHP70D-00-0000-0D00N40E4 P4 1965 2164 XHP70D-00-0000-0D0BP40E4 P2 1830 2015 XHP70D-00-0000-0D0BP20E4 N4 1710 1883 XHP70D-00-0000-0D0BN40E4 N4 1710 1883 XHP70D-00-0000-0D0HN40E4 N2 1590 1751 XHP70D-00-0000-0D0HN20E4 M4 1485 1635 XHP70D-00-0000-0D0HM40E4 M4 1485 1635 XHP70D-00-0000-0D0UM40E4 M2 1380 1520 XHP70D-00-0000-0D0UM20E4 K4 1290 1420 XHP70D-00-0000-0D0UK40E4 Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 32). • XLamp XHP70.3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. • Flux values @ 25 °C are calculated and for reference only. © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 8 XLAMP ® XHP70.3 LED FLUX CHARACTERISTICS, HIGH DENSITY ANSI WHITE ORDER CODES AND BINS - CONTINUED Nominal CCT CRI Chromaticity Regions Min Typ 0 68 70 4000 K 5A, 5B, 5C, 5D 80 90 3500 K 3000 K 6A, 6B, 6C, 6D 7A, 7B, 7C, 7D Minimum Luminous Flux 70 70 Group Flux (lm) Flux (lm) @ 85 °C @ 25 °C* Order Code P2 1830 2015 XHP70D-00-0000-0D00N20E5 N4 1710 1883 XHP70D-00-0000-0D00N40E5 P4 1965 2164 XHP70D-00-0000-0D0BP40E5 P2 1830 2015 XHP70D-00-0000-0D0BP20E5 N4 1710 1883 XHP70D-00-0000-0D0BN40E5 N4 1710 1883 XHP70D-00-0000-0D0HN40E5 N2 1590 1751 XHP70D-00-0000-0D0HN20E5 M4 1485 1635 XHP70D-00-0000-0D0HM40E5 M4 1485 1635 XHP70D-00-0000-0D0UM40E5 M2 1380 1520 XHP70D-00-0000-0D0UM20E5 XHP70D-00-0000-0D0UK40E5 K4 1290 1420 P2 1830 2015 XHP70D-00-0000-0D0BP20E6 N4 1710 1883 XHP70D-00-0000-0D0BN40E6 N2 1590 1751 XHP70D-00-0000-0D0BN20E6 N4 1710 1883 XHP70D-00-0000-0D0BN40E7 N2 1590 1751 XHP70D-00-0000-0D0BN20E7 Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 32). • XLamp XHP70.3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. • Flux values @ 25 °C are calculated and for reference only. © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 9 XLAMP ® XHP70.3 LED FLUX CHARACTERISTICS, HIGH DENSITY BROADCAST ORDER CODES AND BINS The following table provides order codes for XLamp XHP70.3 High Density Broadcast LEDs. For a complete description of how the flux and chromaticity groups are reflected in the bin code and order code nomenclature, please see the Bin and Order Code Formats section (page 30). Binning condition: TJ = 85 °C; 12 V, IF = 1050 mA Reference condition: TJ = 85 °C; 6 V, IF = 2100 mA Chromaticity Kit CCT E2 5700 K Minimum Luminous Flux (lm) @ 1050 mA Order Codes Flux Bin Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 90 CRI Minimum 90 TLCI Minimum M2 1380 1520 XHP70D-00-B001-AD0UM20E2 K4 1290 1420 95 CRI Minimum 95 TLCI Minimum XHP70D-00-B001-AD0ZK40E2 Notes • • • • TLCI refers to the European Broadcast Union’s Television Lighting Consistency Index 2012, which aids broadcasters in assessing the colorimetric quality of lighting in their production environment. Cree LED maintains a tolerance of ±2 on TLCI measurements. See the Measurements section (page 32). Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 32). XLamp XHP70.3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 10 XLAMP ® XHP70.3 LED FLUX CHARACTERISTICS, HIGH INTENSITY EASYWHITE® ORDER CODES AND BINS The following table provides order codes for XLamp XHP70.3 High Intensity LEDs. For a complete description of how the flux and chromaticity groups are reflected in the bin code and order code nomenclature, please see the Bin and Order Code Formats section (page 30). Binning condition: TJ = 85 °C; 12 V, IF = 1050 mA Reference condition: TJ = 85 °C; 6 V, IF = 2100 mA Nominal CCT CRI Min Typ Minimum Luminous Flux Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* P2 1830 2015 N4 1710 1883 N2 1590 1751 2-Step Group Order Code 3-Step Group Order Code 70 5000 K Group 50E 80 50G 1485 1635 XHP70D-H0-00000D0HM450G M4 1485 1635 XHP70D-H0-00000D0UM450G M2 1380 1520 P2 1830 2015 50G 45E 1710 1883 N2 1590 1751 M4 1485 1635 M2 1380 1520 80 45G 90 45G K4 1290 1420 XHP70D-H0-00000D0BP250E XHP70D-H0-00000D0BN450E XHP70D-H0-00000D0UM250G 70 N4 Order Code XHP70D-H0-00000D0HN250G M4 90 4500 K 5-Step XHP70D-H0-00000D0BP245E XHP70D-H0-00000D0BN445E XHP70D-H0-00000D0HN245G XHP70D-H0-00000D0HM445G XHP70D-H0-00000D0UM245G XHP70D-H0-00000D0UK445G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 32). • XLamp XHP70.3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. • Flux values @ 25 °C are calculated and for reference only. © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 11 XLAMP ® XHP70.3 LED FLUX CHARACTERISTICS, HIGH INTENSITY EASYWHITE® ORDER CODES AND BINS - CONTINUED Nominal CCT CRI Min Typ Minimum Luminous Flux Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* P2 1830 2015 N4 1710 1883 N2 1590 1751 2-Step Group Order Code 3-Step Group Order Code 70 40H XHP70D-H0-00000D0HN240H 40G 1485 1635 XHP70D-H0-00000D0HM440H M2 1380 1520 XHP70D-H0-00000D0UM240H K4 1290 1420 XHP70D-H0-00000D0UK440H K4 1290 1420 XHP70D-H0-00000D0ZK440H K2 1200 1321 J4 1120 1233 N4 1710 1883 N2 1590 1751 N2 1590 1751 M4 1485 1635 XHP70D-H0-00000D0HM435H K4 1290 1420 XHP70D-H0-00000D0UK435H K2 1200 1321 XHP70D-H0-00000D0UK235H K2 1200 1321 XHP70D-H0-00000D0ZK235H XHP70D-H0-00000D0ZK235G J4 1120 1233 XHP70D-H0-00000D0ZJ435H XHP70D-H0-00000D0ZJ435G J2 1040 1145 XHP70D-H0-00000D0ZJ235H H4 970 1068 XHP70D-H0-00000D0ZH435H 40H 40H XHP70D-H0-00000D0ZK240H 40G XHP70D-H0-00000D0UM240G XHP70D-H0-00000D0UK440G 40G XHP70D-H0-00000D0ZK240G XHP70D-H0-00000D0ZJ440G 35E 3500 K 35H 90 35H 95 35H XHP70D-H0-00000D0BN440E XHP70D-H0-00000D0HM440G 70 80 XHP70D-H0-00000D0BP240E XHP70D-H0-00000D0ZK440G XHP70D-H0-00000D0ZJ440H XHP70D-H0-00000D0HN235H Order Code XHP70D-H0-00000D0HN240G M4 90 95 Group 40E 80 4000 K 5-Step 35G 35G 35G XHP70D-H0-00000D0BN435E XHP70D-H0-00000D0BN235E XHP70D-H0-00000D0HN235G XHP70D-H0-00000D0HM435G XHP70D-H0-00000D0UK435G XHP70D-H0-00000D0UK235G XHP70D-H0-00000D0ZJ235G XHP70D-H0-00000D0ZH435G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 32). • XLamp XHP70.3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. • Flux values @ 25 °C are calculated and for reference only. © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 12 XLAMP ® XHP70.3 LED FLUX CHARACTERISTICS, HIGH INTENSITY EASYWHITE® ORDER CODES AND BINS - CONTINUED Nominal CCT CRI Min Typ Minimum Luminous Flux Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* N4 1710 1883 N2 1590 1751 N2 1590 1751 2-Step Group Order Code 3-Step Group Order Code 70 Group 30E 80 3000 K 5-Step 30H XHP70D-H0-00000D0HN230H 30G 1485 1635 XHP70D-H0-00000D0HM430H K4 1290 1420 XHP70D-H0-00000D0UK430H K2 1200 1321 XHP70D-H0-00000D0UK230H K2 1200 1321 XHP70D-H0-00000D0ZK230H XHP70D-H0-00000D0ZK230G J4 1120 1233 XHP70D-H0-00000D0ZJ430H XHP70D-H0-00000D0ZJ430G J2 1040 1145 XHP70D-H0-00000D0ZJ230H H4 970 1068 XHP70D-H0-00000D0ZH430H M4 1485 1635 30H 95 30H 80 27H XHP70D-H0-00000D0HM427H 30G 30G XHP70D-H0-00000D0UK430G XHP70D-H0-00000D0UK230G XHP70D-H0-00000D0ZJ230G XHP70D-H0-00000D0ZH430G 27G XHP70D-H0-00000D0HM427G 1380 1520 XHP70D-H0-00000D0HM227H K2 1200 1321 XHP70D-H0-00000D0UK227H J4 1120 1233 XHP70D-H0-00000D0UJ427H J4 1120 1233 XHP70D-H0-00000D0ZJ427H XHP70D-H0-00000D0ZJ427G J2 1040 1145 XHP70D-H0-00000D0ZJ227H XHP70D-H0-00000D0ZJ227G H4 970 1068 XHP70D-H0-00000D0ZH427H H2 900 991 XHP70D-H0-00000D0ZH227H 27H 2700 K 95 27H XHP70D-H0-00000D0BN230E XHP70D-H0-00000D0HM430G M2 90 XHP70D-H0-00000D0BN430E XHP70D-H0-00000D0HN230G M4 90 Order Code 27G 27G XHP70D-H0-00000D0HM227G XHP70D-H0-00000D0UK227G XHP70D-H0-00000D0UJ427G XHP70D-H0-00000D0ZH427G XHP70D-H0-00000D0ZH227G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 32). • XLamp XHP70.3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. • Flux values @ 25 °C are calculated and for reference only. © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 13 XLAMP ® XHP70.3 LED FLUX CHARACTERISTICS, HIGH INTENSITY ANSI WHITE ORDER CODES AND BINS The following table provides order codes for XLamp XHP70.3 High Intensity LEDs. For a complete description of how the flux and chromaticity groups are reflected in the bin code and order code nomenclature, please see the Bin and Order Code Formats section (page 30). Binning condition: TJ = 85 °C; 12 V, IF = 1050 mA Reference condition: TJ = 85 °C; 6 V, IF = 2100 mA Nominal CCT 7000 K CRI Chromaticity Regions 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U Minimum Luminous Flux Group P2 1830 2015 XHP70D-H0-0000-0D00P20DT 0 68 N4 1710 1883 XHP70D-H0-0000-0D00N40DT N2 1590 1751 XHP70D-H0-0000-0D00N20DT P2 1830 2015 XHP70D-H0-0000-0D0BP20DT N4 1710 1883 XHP70D-H0-0000-0D0BN40DT N2 1590 1751 XHP70D-H0-0000-0D0BN20DT 70 0 1A, 1B, 1C, 1D 68 70 80 0 6000 K 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U Order Code Typ 80 6500 K Flux (lm) Flux (lm) @ 85 °C @ 25 °C* Min 70 80 90 68 N2 1590 1751 XHP70D-H0-0000-0D0HN20DT M4 1485 1635 XHP70D-H0-0000-0D0HM40DT P2 1830 2015 XHP70D-H0-0000-0D00P20E1 N4 1710 1883 XHP70D-H0-0000-0D00N40E1 N2 1590 1751 XHP70D-H0-0000-0D00N20E1 N4 1710 1883 XHP70D-H0-0000-0D0BN40E1 N2 1590 1751 XHP70D-H0-0000-0D0BN20E1 N2 1590 1751 XHP70D-H0-0000-0D0HN20E1 M4 1485 1635 XHP70D-H0-0000-0D0HM40E1 P2 1830 2015 XHP70D-H0-0000-0D00P20DV N4 1710 1883 XHP70D-H0-0000-0D00N40DV P2 1830 2015 XHP70D-H0-0000-0D0BP20DV N4 1710 1883 XHP70D-H0-0000-0D0BN40DV N2 1590 1751 XHP70D-H0-0000-0D0HN20DV M4 1485 1635 XHP70D-H0-0000-0D0HM40DV M4 1485 1635 XHP70D-H0-0000-0D0UM40DV M2 1380 1520 XHP70D-H0-0000-0D0UM20DV Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 32). • XLamp XHP70.3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. • Flux values @ 25 °C are calculated and for reference only. © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 14 XLAMP ® XHP70.3 LED FLUX CHARACTERISTICS, HIGH INTENSITY ANSI WHITE ORDER CODES AND BINS - CONTINUED Nominal CCT CRI Chromaticity Regions Minimum Luminous Flux Min Typ 0 68 70 5700 K 2A, 2B, 2C, 2D 80 90 0 68 70 5000 K 3A, 3B, 3C, 3D 80 90 0 68 70 4500 K 4A, 4B, 4C, 4D 80 90 0 70 4000 K 5A, 5B, 5C, 5D 80 90 3500 K 3000 K 6A, 6B, 6C, 6D 7A, 7B, 7C, 7D 70 70 68 Group Flux (lm) Flux (lm) @ 85 °C @ 25 °C* Order Code P2 1830 2015 XHP70D-H0-0000-0D00P20E2 N4 1710 1883 XHP70D-H0-0000-0D00N40E2 P2 1830 2015 XHP70D-H0-0000-0D0BP20E2 N4 1710 1883 XHP70D-H0-0000-0D0BN40E2 N2 1590 1751 XHP70D-H0-0000-0D0HN20E2 M4 1485 1635 XHP70D-H0-0000-0D0HM40E2 M4 1485 1635 XHP70D-H0-0000-0D0UM40E2 M2 1380 1520 XHP70D-H0-0000-0D0UM20E2 P2 1830 2015 XHP70D-H0-0000-0D00P20E3 N4 1710 1883 XHP70D-H0-0000-0D00N40E3 P2 1830 2015 XHP70D-H0-0000-0D0BP20E3 N4 1710 1883 XHP70D-H0-0000-0D0BN40E3 N2 1590 1751 XHP70D-H0-0000-0D0HN20E3 M4 1485 1635 XHP70D-H0-0000-0D0HM40E3 M4 1485 1635 XHP70D-H0-0000-0D0UM40E3 M2 1380 1520 XHP70D-H0-0000-0D0UM20E3 P2 1830 2015 XHP70D-H0-0000-0D00P20E4 N4 1710 1883 XHP70D-H0-0000-0D00N40E4 P2 1830 2015 XHP70D-H0-0000-0D0BP20E4 N4 1710 1883 XHP70D-H0-0000-0D0BN40E4 N2 1590 1751 XHP70D-H0-0000-0D0HN20E4 M4 1485 1635 XHP70D-H0-0000-0D0HM40E4 M2 1380 1520 XHP70D-H0-0000-0D0UM20E4 K4 1290 1420 XHP70D-H0-0000-0D0UK40E4 P2 1830 2015 XHP70D-H0-0000-0D00N20E5 N4 1710 1883 XHP70D-H0-0000-0D00N40E5 P2 1830 2015 XHP70D-H0-0000-0D0BP20E5 N4 1710 1883 XHP70D-H0-0000-0D0BN40E5 N2 1590 1751 XHP70D-H0-0000-0D0HN20E5 M4 1485 1635 XHP70D-H0-0000-0D0HM40E5 M2 1380 1520 XHP70D-H0-0000-0D0UM20E5 K4 1290 1420 XHP70D-H0-0000-0D0UK40E5 N4 1710 1883 XHP70D-H0-0000-0D0BN40E6 N2 1590 1751 XHP70D-H0-0000-0D0BN20E6 N4 1710 1883 XHP70D-H0-0000-0D0BN40E7 N2 1590 1751 XHP70D-H0-0000-0D0BN20E7 Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 32). • XLamp XHP70.3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. • Flux values @ 25 °C are calculated and for reference only. © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 15 XLAMP ® XHP70.3 LED FLUX CHARACTERISTICS, HIGH INTENSITY BROADCAST ORDER CODES AND BINS The following table provides order codes for XLamp XHP70.3 High Intensity Broadcast LEDs. For a complete description of how the flux and chromaticity groups are reflected in the bin code and order code nomenclature, please see the Bin and Order Code Formats section (page 30). Binning condition: TJ = 85 °C; 12 V, IF = 1050 mA Reference condition: TJ = 85 °C; 6 V, IF = 2100 mA Chromaticity Kit CCT E2 5700 K Minimum Luminous Flux (lm) @ 1050 mA Order Codes Flux Bin Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 90 CRI Minimum 90 TLCI Minimum K4 1290 1420 XHP70D-H0-B001-AD0UK40E2 K2 1200 1321 95 CRI Minimum 95 TLCI Minimum XHP70D-H0-B001-AD0ZK20E2 Notes • • • • TLCI refers to the European Broadcast Union’s Television Lighting Consistency Index 2012, which aids broadcasters in assessing the colorimetric quality of lighting in their production environment. Cree LED maintains a tolerance of ±2 on TLCI measurements. See the Measurements section (page 32). Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 32). XLamp XHP70.3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 16 XLAMP ® XHP70.3 LED Relative Spectral Power RELATIVE SPECTRAL POWER DISTRIBUTION 100% Relative Radiant Power 80% 60% 6500 K, 68 CRI 3000 K, 80 CRI 40% 20% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) RELATIVE FLUX VS. JUNCTION TEMPERATURE Relative Flux Output vs. Junction Temperature Reference condition: 6 V, IF = 2100 mA; 12 V, IF = 1050 mA 120% Relative Luminous Flux 100% 80% 60% 40% 20% 0% 25 50 75 100 125 150 Junction Temperature (ºC) © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 17 XLAMP ® XHP70.3 LED ELECTRICAL CHARACTERISTICS (TJ = 85 °C) 7200 6400 Forward Current (mA) 5600 4800 4000 6V 3200 2400 1600 800 0 5.00 5.25 Electrical Characteristics (Tj = 85°C) 5.50 5.75 6.00 6.25 Forward Voltage (V) 3600 3200 Forward Current (mA) 2800 2400 2000 12 V 1600 1200 800 400 0 10.0 10.5 11.0 11.5 12.0 12.5 Forward Voltage (V) © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 18 XLAMP ® XHP70.3 LED RELATIVE FLUX VS. CURRENT (TJ = 85 °C) 300% Relative Luminous Flux 250% 200% 150% 6V 100% 50% 0% Relative Intensity vs. Current (Tj = 85°C) Forward Current (mA) 0 800 1600 2400 3200 4000 4800 5600 6400 7200 300% Relative Luminous Flux 250% 200% 12 V 150% 100% 50% 0% 0 400 800 1200 1600 2000 2400 2800 3200 3600 Forward Current (mA) © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 19 XLAMP ® XHP70.3 LED Relative Chromaticity Vs. Current,(WARM WW - HD WHITE) RELATIVE CHROMATICITY VS CURRENT 0.020 0.016 0.012 6V 0.008 0.004 ΔCCx 0.000 ΔCCy -0.004 -0.008 -0.012 -0.016 -0.020 0 800 1600 2400 Relative Chromaticity Vs. Current, WW - HD 3200 4000 4800 5600 6400 7200 Current (mA) 0.020 0.016 0.012 12 V 0.008 0.004 ΔCCx 0.000 ΔCCy -0.004 -0.008 -0.012 -0.016 -0.020 0 400 800 1200 1600 2000 2400 2800 3200 3600 Current (mA) © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 20 XLAMP ® XHP70.3 LED RELATIVE CHROMATICITY VS TEMPERATURE (WARM WHITE) Relative Chromaticity Vs. Temperature WW Reference condition: 6 V, IF = 2100 mA; 12 V, IF = 1050 mA 0.020 0.016 0.012 0.008 0.004 ΔCCx 0.000 ΔCCy -0.004 -0.008 -0.012 -0.016 -0.020 25 50 75 100 125 150 Tj (°C) TYPICAL SPATIAL DISTRIBUTION Typical Spatial Radiation Pattern Reference condition: TJ = 85 °C; 6 V, IF = 2100 mA; 12 V, IF = 1050 mA 100% Relative Luminous Intensity 80% 60% HD HI 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 21 XLAMP ® XHP70.3 LED THERMAL DESIGN The maximum forward current is determined by the thermal resistance between the LED junction and ambient. It is crucial for the end product to be designed in a manner that minimizes the thermal resistance from the solder point to ambient in order to optimize lamp life and optical characteristics. 7500 7000 Maximum Current (mA) 6500 6000 5500 5000 4500 4000 6V 3500 3000 2500 Rj-a = 0.5°C/W 2000 Rj-a = 1°C/W 1500 Rj-a = 2°C/W 1000 Rj-a = 3°C/W 500 0 0 20 Thermal Design 40 60 80 100 120 140 160 Ambient Temperature (ºC) 3750 3500 Maximum Current (mA) 3250 3000 2750 2500 2250 2000 12 V 1750 1500 1250 Rj-a = 0.5°C/W 1000 Rj-a = 1°C/W 750 Rj-a = 2°C/W 500 Rj-a = 3°C/W 250 0 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 22 XLAMP ® XHP70.3 LED PERFORMANCE GROUPS - LUMINOUS FLUX (TJ = 85 °C) XLamp XHP70.3 LEDs are tested for luminous flux and placed into one of the following luminous-flux groups. Group Code Minimum Luminous Flux Maximum Luminous Flux H2 900 970 H4 970 1040 J2 1040 1120 J4 1120 1200 K2 1200 1290 K4 1290 1380 M2 1380 1485 M4 1485 1590 N2 1590 1710 N4 1710 1830 P2 1830 1965 P4 1965 2100 Q2 2100 2260 PERFORMANCE GROUPS - CHROMATICITY XLamp XHP70.3 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 40H 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3777 0.3739 0.3797 0.3816 0.3861 0.3855 0.3838 0.3777 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 23 XLAMP ® XHP70.3 LED PERFORMANCE GROUPS - CHROMATICITY (CONTINUED) EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 50G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 45G 4500 K 0.3611 0.3658 0.00852 0.00330 61.5 40G 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 EasyWhite Color Temperatures – 5-Step Ellipse Bin Code CCT 50E Center Point Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.01400 0.00520 65.0 45E 4500 K 0.3611 0.3658 0.01420 0.00550 61.5 40E 4000 K 0.3818 0.3797 0.01565 0.00670 53.7 35E 3500 K 0.4073 0.3917 0.01545 0.00690 54.0 30E 3000 K 0.4338 0.4030 0.01390 0.00680 53.2 ANSI White Bins CCT Major Axis Bin Code 0A0 0B0 7000 K 0C0 0D0 ANSI White Bins x y 0.2950 0.2920 0.2984 0.3133 0.3009 0.3042 0.2920 0.2895 0.2962 0.3220 0.2984 0.3133 0.2984 0.3133 0.2962 0.3220 0.3028 0.3304 0.3048 0.3207 0.2984 0.3048 0.3068 0.3113 0.3009 0.3042 CCT Bin Code ANSI White Bins x y 0.2970 0.2980 0.3060 0.2950 0.3009 0.3042 0.3037 0.2937 0.3060 0.2895 0.3135 0.2870 0.2937 0.3312 0.2962 0.3220 0.2962 0.3220 0.2937 0.3312 0.3005 0.3415 0.3028 0.3304 0.3133 0.3037 0.3207 0.3009 0.3068 0.3113 0.3093 0.2993 0R0 0S0 7000 K 0T0 0U0 CCT Bin Code x y 0.2880 0.3048 0.3207 0.2970 0.3130 0.3290 0.3144 0.3186 0.3068 0.3113 0.3135 0.3028 0.3304 0.3210 0.3115 0.3391 0.3130 0.3290 0.3048 0.3207 0.3115 0.3391 0.3205 0.3481 0.3213 0.3373 0.3130 0.3290 0.2937 0.3130 0.3290 0.3042 0.3213 0.3373 0.3221 0.3261 0.3144 0.3186 1A0 1B0 7000 K © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 1C0 1D0 CLD-DS266 REV 6 24 XLAMP ® XHP70.3 LED PERFORMANCE GROUPS - CHROMATICITY (CONTINUED) ANSI White Bins CCT Bin Code 1R0 1S0 7000 K 1T0 1U0 ANSI White Bins x y CCT 0.3068 0.3113 0.3144 0.3186 0.3161 0.3059 0.3093 0.3005 0.3099 0.3509 0.3115 0.3391 0.3028 0.3304 0.3099 0.3509 0.3196 0.3602 0.3205 0.3481 0.3115 0.3144 0.3221 0.3261 0.3231 0.3120 0.3161 0.3059 Bin Code x y 0.3215 0.3350 0.3290 0.3417 0.3290 0.3300 0.2993 0.3222 0.3415 0.3207 0.3290 0.3538 0.3290 0.3417 0.3215 0.3350 0.3290 0.3538 0.3376 0.3616 0.3371 0.3490 0.3391 0.3290 0.3186 0.3290 0.3371 0.3490 0.3366 0.3369 0.3290 0.3300 2A0 2B0 6000 K 2C0 2D0 ANSI White Bins CCT ANSI White Bins Bin Code 3A0 3B0 5000 K 3C0 3D0 CCT Bin Code x y 0.3222 0.3243 0.3290 0.3300 0.3290 0.3180 0.3243 0.3231 0.3120 0.3462 0.3196 0.3602 0.3290 0.3690 0.3290 0.3538 0.3207 0.3462 0.3290 0.3690 0.3381 0.3762 0.3376 0.3616 0.3417 0.3290 0.3538 0.3417 0.3290 0.3300 0.3366 0.3369 0.3361 0.3245 0.3290 0.3180 2R0 2S0 6000 K 2T0 2U0 ANSI White Bins x y 0.3371 0.3490 0.3451 0.3554 0.3440 0.3427 0.3366 0.3376 0.3463 0.3687 0.3451 0.3554 0.3371 0.3490 0.3463 0.3687 0.3551 0.3760 0.3533 0.3620 0.3451 0.3451 0.3533 0.3620 0.3515 0.3487 0.3440 0.3427 CCT Bin Code x y 0.3530 0.3597 0.3615 0.3659 0.3512 0.3465 0.3369 0.3515 0.3487 0.3616 0.3548 0.3736 0.3641 0.3804 0.3530 0.3597 4A0 4B0 0.3533 0.362 0.3641 0.3804 0.3736 0.3874 0.3702 0.3722 0.3554 0.3615 0.3659 0.3554 0.3615 0.3659 0.3702 0.3722 0.3670 0.3578 0.3590 0.3521 4500 K 4C0 4D0 © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 25 XLAMP ® XHP70.3 LED PERFORMANCE GROUPS - CHROMATICITY (CONTINUED) ANSI White Bins CCT Bin Code 5A0 5B0 4000 K 5C0 5D0 ANSI White Bins x y 0.3670 0.3578 0.3702 0.3722 0.3825 0.3798 0.3783 0.3702 0.3736 0.3874 0.3869 0.3958 0.3825 0.3798 0.3825 0.3798 0.3869 0.3958 0.4006 0.4044 0.3950 0.3783 0.3825 0.3798 0.3950 0.3875 0.3898 0.3716 CCT Bin Code ANSI White Bins x y 0.3889 0.3690 0.3941 0.3848 0.4080 0.3916 0.3646 0.4017 0.3722 0.3]941 0.3996 0.4015 0.4146 0.4089 0.4080 0.3916 0.4080 0.3916 0.4146 0.4089 0.4299 0.4165 0.3875 0.4221 0.3646 0.4017 0.4080 0.3916 0.4221 0.3984 0.4147 0.3814 6A0 6B0 3500 K 6C0 6D0 CCT Bin Code x y 0.4147 0.3814 0.4221 0.3984 0.4342 0.4028 0.3751 0.4259 0.3853 0.3848 0.4221 0.3984 0.4299 0.4165 0.4430 0.4212 0.4342 0.4028 0.4342 0.4028 0.4430 0.4212 0.4562 0.4260 0.3984 0.4465 0.4071 0.3751 0.4259 0.3853 0.4342 0.4028 0.4465 0.4071 0.4373 0.3893 7A0 7B0 3000 K © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 7C0 7D0 CLD-DS266 REV 6 26 XLAMP ® XHP70.3 LED EASYWHITE® CHROMATICITY REGIONS PLOTTED ON THE 1931 CIE CURVE 0.44 ANSI C78.377 Quadrangle 0.43 EasyWhite 5-Step EasyWhite 3-Step 0.42 3500 K EasyWhite 2-Step 0.41 2700 K 3000 K 4000 K 0.40 4500 K 0.39 5000 K 0.38 CCy 0.37 5700 K 0.36 6500 K 0.35 0.34 8000 K 0.33 0.32 0.31 0.30 0.29 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.27 0.28 CCx © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 27 XLAMP ® XHP70.3 LED ANSI STANDARD COOL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.40 5000 K 0.39 0.38 5700 K 0.37 6500 K 2T 0.36 2S DT 0.35 CCy 8000 K 2B 1S 0T 0.33 0C 0B 0.31 2D 1C 2A 1B 0S 0.32 2C 1T 0.34 1D 2U 1U 0D 0A ANSI C78.377A 2R 1A 1R 0U 0.30 0R 0.29 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.28 CCx 0.40 0.40 5000 K 0.39 0.38 DV 6500 K 0.36 0.36 2C 8000 K 0A 0R 1R 0U CCx 0.36 0.35 0.34 0.28 0.36 0.35 0.34 0.33 0.32 0.28 0.31 0.28 0.30 ANSI C78.377A 2R 1U 0R 0.29 0.29 2U 1A 0D 0.30 0.29 0.28 0C 0B 0.31 1R 0U 0.30 0S 0.32 1D 0.33 0A CCy 1U 3R 2A 1B 0.32 0.31 ANSI C78.377A 2R 1A 0D 0T 0.33 2U 3A 2D 1C 0.31 0C 0B 1D 2C 2B 1S 0.30 0S 0.32 2A 1B 3B 2S 1T 8000 K 0.34 0.29 0T 0.33 2D 1C 2T E1 0.35 2B 1S 3S 6500 K 2T 1T 0.34 5700 K 0.37 2S 0.35 CCy 0.38 5700 K 0.37 5000 K 0.39 CCx 0.40 5000 K 0.39 0.38 5700 K E2 0.37 6500 K 0.36 3B 2S 0.35 CCy 3S 2T 2C 1T 8000 K 0.34 0T 0.33 0S 0.32 0C 0A 3R 2A 2U 1D ANSI C78.377A 2R 1A 0D 2D 1C 1B 0B 0.31 3A 2B 1S 1U 1R 0U 0.30 0R 0.29 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.28 CCx © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 28 XLAMP ® XHP70.3 LED STANDARD WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.45 0.44 2700 K 3000 K 0.43 E7 0.42 3500 K 4000 K CCy 0.40 0.39 5000 K 0.38 E4 4B 3C 0.36 3B 3D 0.35 7B 6C 6B 7D 7A 5C 6D 5B 4C E3 0.37 E5 4500 K 7C E6 0.41 6A ANSI C78.377A 5D 5A 4D 4A 3A 0.34 0.50 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.33 CCx © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 29 XLAMP ® XHP70.3 LED BIN AND ORDER-CODE FORMAT Bin codes and order codes for XHP70.3 LEDs are configured in the following manner: Order Code Bin Code Series XHP70D = XHP70.3 Series XHP70D = XHP70.3 Internal code Chromaticity group Minimum luminous flux group Vf Class D = 6-V/12-V configurable Chromaticity group CRI specification 0 = No minimum CRI B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Z = 95 CRI minimum SSSSSS-BD-GGGG-HJKLMMNNN CRI specification 0 = No minimum CRI B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Z = 95 CRI minimum SSSSSS-E-NNN-MMM-JK-L-PP Vf Class D = 6-V/12-V configurable Configuration B = Version 0 = High density H = High intensity D = Reel size © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Internal code Voltage performance group Luminous flux group Version 0 = High density H = High intensity CLD-DS266 REV 6 30 XLAMP ® XHP70.3 LED REFLOW SOLDERING CHARACTERISTICS In testing, Cree LED has found XLamp XHP70.3 LEDs to be compatible with JEDEC J‑STD‑020C, using the parameters listed below. As a general guideline, Cree LED recommends that users follow the recommended soldering profile provided by the manufacturer of the solder paste used, and therefore it is the lamp or luminaire manufacturer’s responsibility to determine applicable soldering requirements. Note that this general guideline may not apply to all PCB designs and configurations of reflow soldering equipment. tP TP Critical Zone TL to TP Temperature Ramp-up TL tL Tsmax Tsmin Ramp-down ts Preheat 25 t 25˚C to Peak Profile Feature Average Ramp-Up Rate (Tsmax to Tp) Time Lead-Free Solder 1.2 °C/second Preheat: Temperature Min (Tsmin) 120 °C Preheat: Temperature Max (Tsmax) 170 °C Preheat: Time (tsmin to tsmax) 65-150 seconds Time Maintained Above: Temperature (TL) Time Maintained Above: Time (tL) 217 °C 45-90 seconds Peak/Classification Temperature (Tp) 235 - 245 °C Time Within 5 °C of Actual Peak Temperature (tp) 20-40 seconds Ramp-Down Rate 1 - 6 °C/second Time 25 °C to Peak Temperature 4 minutes max. Note: All temperatures refer to the topside of the package, measured on the package body surface. © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 31 XLAMP ® XHP70.3 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Cree LED did not perform Room Temperature Operating Life (RTOL) testing on the XHP70.3 LED. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. Moisture Sensitivity Cree LED recommends keeping XLamp LEDs in the provided, resealable moisture-barrier packaging (MBP) until immediately prior to soldering. Unopened MBPs that contain XLamp LEDs do not need special storage for moisture sensitivity. Once the MBP is opened, XLamp XHP70.3 LEDs may be stored as MSL 1 per JEDEC J-STD-033, meaning they have unlimited floor life in conditions of ≤ 30 ºC/85% relative humidity (RH). Regardless of the storage condition, Cree LED recommends sealing any unsoldered LEDs in the original MBP. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACH Compliance REACH substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACH SVHC Declaration. REACH banned substance information (REACH Article 67) is also available upon request. © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 32 XLAMP ® XHP70.3 LED NOTES - CONTINUED UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 33 4 3 7.00 OPTICAL MODEL ORIG XLAMP ® XHP70.3 LED B MECHANICAL DIMENSIONS 7.00 ANODE SIDE CATHODE SIDE Thermal vias, if present, are not shown on these drawings. R3.76 AllOPTICAL dimensions are ±.13 mm unless otherwise indicated. MODEL ORIGIN TOP VIEW XHP70.3 High Density 4 3 2 5.40 4.00 OPTICAL MODEL ORIGIN 0.56 ANODE SIDE 3 7.00 6.80 7.00 B 4 3.15 7.00 CATHODE SIDE 1 6.80 A CATHODE SIDE OPTICAL MODEL OR B4.49 TOP VIEW CENTER PAD IS ELECTRICALLY ISOLATED SIDE VIEW Side View Top View 6.80 3 ANODE SIDE OPTICAL MODEL ORIGIN 4.00 TOP VIEW XHP70.3 High Intensity 3.15 3 2 7.00 0.56 6.80 1 6.80 4.00 0.70 A 3.15 CATHODE SIDE 7.00 CENTER PAD IS ELECTRICALLY ISOLATED 4 6.80 OPTICAL MODEL ORIGIN SOLDERMASK MAY BE PRESENT BOTTOM VIEW 3 A ANODE SIDE 2610-700002 XHP70D 1.00 OPTICAL MODEL ORIGIN 2 Top View Side View 6.80 4.00 1 CENTER PAD IS ELECTRICALLY ISOLATED SIDE VIEW TOP VIEW B 4 SOLDERMASK MAY BE PRESENT BOTTOM VIEW Bottom View 3 0.70 6.80 3.15 A SOLDERMASK MAY BE PRESENT BOTTOM VIEW Bottom View 4 5.40 4 7.00 R3.76 OPTICAL MODEL ORIGIN © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 34 A XLAMP ® XHP70.3 LED 3 0.70 3.15 6.80 0.70 6.80 0.70 6.80 0.24 0.70 3.15 RECOMMENDED 12V PCB RECOMMENDED 12V PCB FOOTPRINT Recommended 12‑V PCBFOOTPRINT Footprint (center pad is connected to anode and 6.70 6.70 cathode and is not electrically isolated) 0.24 0.41 4X RECOMMENDED 6V PCB FOOTPRINT RECOMMENDED 6VPCB PCB FOOTPRINT Recommended 6‑V Footprint (center pad is electrically isolated) RECOMMENDED 6V PCB FOOTPRINT 0.80 28X 0.11 6.76 6.76 0.80 28X 0.50 6.76 0.50 B 0.50 A 0.70 16X 0.31 0.70 16X 0.55 8X A 0.55 8X 3.15 0.55 8X 0.70 6.80 6.80 A 0.24 4.00 0.83 24X 6.70 6.80 0.70 RECOMMENDED STENCIL OPENING RECOMMENDED STENCIL OPENING CB FOOTPRINT 4 3 RECOMMENDED 6V AND 12V PCB SOLDER MASK Recommended 6‑VOPENING & 12‑V PCB Solder Mask Opening 4 (solid area is open) 30.70 16X 0.80 28X 2 0.31 4 RECOMME RECOMMENDED PCB SOLDE PCB SOLDER MA RECOMMENDED 12V PCB FOOTPRINT 1 0.31 2 0.70 3.15 3.15 3.15 6.80 0.11 6.80 4.00 2 6.80 B 3 4.00 0.41 4X 0.11 B 0.70 6.80 B 6.80 3.15 4 0.70 0.70 0.70 6.80 0.70 6.80 4.00 0.70 0.83 24X 4.00 6.80 6.80 6.80 0.70 2 2 6.80 3 0.83 24X 0.70 4 0.41 4X 4 6.80 MECHANICAL DIMENSIONS - CONTINUED 261 2610-70 2 RECOMMENDED STENCIL OPENING Recommended Stencil Openings 6 V & 12 V Configurations (solid 3 area is open) 2 A 2610-700002 XHP70D © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 2 1 CLD-DS266 REV 6 35 NEGATIVE B XLAMP ® XHP70.3 LED POSITIVE A ELECTRICAL CONFIGURATION 12 V 6V SOLDER PAD LINK NEGATIVE A POSITIVE A NEGATIVE B POSITIVE B NEGATIVE B POSITIVE A 6-V Configuration 12-V Configuration 6V NEGATIVE A POSITIVE A NEGATIVE B POSITIVE B © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 36 XLAMP ® XHP70.3 LED TAPE AND REEL All Cree LED carrier tapes conform to EIA-481D, Automated Component Handling Systems Standard. All dimensions are ±.13 mm unless otherwise indicated. XHP70.3 High Density Item Ao Bo Ko Po P1 P2 T E F Do D1 W R Dim. 7.40 7.40 4.60 4.00 12.00 2.00 0.36 1.75 7.50 1.50 1.50 16.00 5° XHP70.3 High Intensity Item Ao Bo Ko Po P1 P2 T E F Do D1 W R Dim. 7.60 7.60 1.70 4.00 12.00 2.00 0.30 1.75 7.50 1.50 1.50 16.00 3° © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 37 XLAMP ® XHP70.3 LED TAPE AND REEL - CONTINUED Feed Direction END START Trailer Loaded Pockets Leader Min. 160 mm empty pockets sealed with tape 1000 Lamps Min. 400 mm empty pockets with min. 100 mm sealed Feed Direction Cover Tape Pocket Tape 13 mm 13” © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 38 XLAMP ® XHP70.3 LED PACKAGING © 2021-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, EasyWhite®, and the Cree LED logo are registered trademarks Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS266 REV 6 39
物料型号:XLamp® XHP70.3 LED
器件简介:XHP70.3是CREE的第三代Extreme High Power LED,以其尺寸提供最佳的光通量密度、可靠性和光学控制。这些LED利用XHP家族的优势,通过使用更少的光学元件、PCB和散热器,显著降低照明制造商的系统成本。
引脚分配:文档中提供了6V和12V配置的电气配置图,展示了各个引脚的连接方式。
参数特性: - 热阻:0.2°C/W - 视场角:高密度版120°,高密度版115° - 工作电流:6V时最大7200mA,12V时最大3600mA - 正向电压:6V配置下2100mA时5.6V至6.1V,12V配置下1050mA时11.2V至12.2V - ESD承受电压:8000V
功能详解:XHP70.3 LED提供高密度和高亮度两种版本,适用于户外和高端室内照明应用,如体育场馆、户外区域和建筑聚光灯等。
应用信息:适用于需要从小型照明设备中输出大量光的场合。
封装信息:提供了详细的机械尺寸图,包括顶部视图、侧视图和底部视图,以及推荐的PCB焊盘布局和模板开口。
XHP70D-00-0000-0D0UK40E5 价格&库存
很抱歉,暂时无法提供与“XHP70D-00-0000-0D0UK40E5”相匹配的价格&库存,您可以联系我们找货
