XBHAWT-00-0000-000HT20E6
    CREELED
    LED XLAMP WARM WHITE 3500K 2SMD
XBHAWT-00-0000-000HT20E6 数据手册
PRODUCT FAMILY DATA SHEET XLamp® XB-H LEDs PRODUCT DESCRIPTION The XLamp ® XB-H LED delivers a breakthrough combination of lumen output FEATURES TABLE OF CONTENTS • Available in white, outdoor white and Characteristics................................................ 2 80-, 85- and 90-CRI white Flux Characteristics........................................ 3 and efficacy in a small package. Delivering • ANSI-compatible chromaticity bins Relative Spectral Power Distribution............. 7 more than 500 lumens at 1.5 A, 25 °C in a • Binned at 85 °C Relative Flux vs. Junction Temperature......... 7 2.45  mm2 package, the XB-H LED offers • Maximum drive current: 1500 mA Electrical Characteristics................................ 8 triple the lumen density of competing • Low thermal resistance: 3.5 °C/W Relative Flux vs. Current................................. 8 high‑power LEDs to significantly increase • Wide viewing angle: 110° Relative Chromaticity vs Current and the performance of today’s lighting designs. • Unlimited floor life at ≤ 30 ºC/85% RH Temperature.................................................... 9 The XB-H LED joins a new generation of • Reflow solderable - JEDEC J‑STD‑020C Typical Spatial Distribution........................... 10 directionally optimized LEDs that offers • Electrically neutral thermal path Thermal Design............................................. 10 the industry’s highest optical control factor • RoHS and REACH compliant Performance Groups – Luminous Flux....... 11 (OCF), a measurement of how LED size and • UL® recognized component (E349212) Performance Groups – Chromaticity........... 11 performance benefit directional lighting Standard Cool White Kits Plotted on ANSI applications. Standard Chromaticity Regions................... 14 High‑OCF LEDs enable lighting manufacturers to improve the Standard Warm and Neutral White Kits performance of any lighting design, create Plotted on ANSI Standard Chromaticity smaller and less expensive systems, and Regions.......................................................... 15 develop new lighting solutions that were Standard Chromaticity Kits.......................... 17 previously not possible. Bin and Order Code Formats........................ 17 Reflow Soldering Characteristics................. 18 Notes............................................................. 19 Mechanical Dimensions............................... 21 Tape and Reel................................................ 23 Packaging...................................................... 25 Cree LED / 4001 E. Hwy. 54, Suite 2000 / Durham, NC 27709 USA / +1.919.313.5330 / www.cree-led.com © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS90 REV 6 1 XLAMP ® XB-H LED CHARACTERISTICS Characteristics Unit Thermal resistance, junction to solder point◊ °C/W 3.5 degrees 110 mV/°C -1.3 Viewing angle (FWHM) Temperature coefficient of voltage ESD withstand voltage (HBM per Mil-Std-883D) Minimum Typical Maximum V 8000 mA 1500 Reverse voltage V 1 Forward voltage (@ 700 mA, 85 °C) V 2.86 Forward voltage (@ 1000 mA, 85 °C) V 2.95 Forward voltage (@ 1500 mA, 85 °C) V 3.08 LED junction temperature °C DC forward current 3.3 150 Note: ◊ Thermal resistance measurement was performed per the JEDEC JESD51-14 standard. See the Thermal Resistance Measurement application note for more details. © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS90 REV 6 2 XLAMP ® XB-H LED FLUX CHARACTERISTICS (TJ = 85 °C) The following tables provide order codes for XLamp XB-H LEDs. For a complete description of the order‑code nomenclature, please consult the Bin and Order Code Formats section (page 17). Chromaticity Kit CCT E2 Minimum Luminous Flux (lm) @ 700 mA Calculated Minimum Luminous Flux (lm)** @ 85 °C Order Codes Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 1.0 A 1.5 A T6 280 322 372 499 XBHAWT-000000-000LT60E2 T5 260 299 345 463 XBHAWT-000000-000LT50E2 T4 240 276 318 428 XBHAWT-000000-000LT40E2 T3 220 253 292 392 XBHAWT-000000-000LT30E2 T6 280 322 372 499 XBHAWT-000000-0000T60E3 XBHAWT-000000-000LT60E3 T5 260 299 345 463 XBHAWT-000000-0000T50E3 XBHAWT-000000-000LT50E3 T4 240 276 318 428 XBHAWT-000000-0000T40E3 XBHAWT-000000-000LT40E3 T3 220 253 292 392 XBHAWT-000000-0000T30E3 XBHAWT-000000-000LT30E3 T6 280 322 372 499 XBHAWT-000000-0000T60F4 T5 260 299 345 463 XBHAWT-000000-0000T50F4 T4 240 276 318 428 XBHAWT-000000-0000T40F4 T3 220 253 292 392 XBHAWT-000000-0000T30F4 T6 280 322 372 499 XBHAWT-000000-0000T60E4 XBHAWT-000000-000LT60E4 T5 260 299 345 463 XBHAWT-000000-0000T50E4 XBHAWT-000000-000LT50E4 T4 240 276 318 428 XBHAWT-000000-0000T40E4 XBHAWT-000000-000LT40E4 T3 220 253 292 392 XBHAWT-000000-0000T30E4 XBHAWT-000000-000LT30E4 No CRI Minimum 5700 K E3 5000 K F4 4750 K E4 4500 K Standard CRI 80 CRI Minimum 85 CRI Minimum 90 CRI Minimum Notes: • • • • • * ** Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 19). XLamp XB-H LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity or bin restrictions specified by the order code. Typical CRI for Cool White (5000 K - 5700 K CCT) is 70. Typical CRI for Neutral White (3700 K - 5300 K CCT) is 75. Typical CRI for Warm White (2600 K - 3700 K CCT) is 80. Flux values @ 25 °C are calculated and for reference only. Calculated flux values at 1 A and 1.5 A are for reference only. © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS90 REV 6 3 XLAMP ® XB-H LED FLUX CHARACTERISTICS (TJ = 85 °C) - CONTINUED Chromaticity Kit CCT F5 Minimum Luminous Flux (lm) @ 700 mA Calculated Minimum Luminous Flux (lm)** @ 85 °C Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 1.0 A 1.5 A No CRI Minimum T6 280 322 372 499 XBHAWT-000000-0000T60F5 T5 260 299 345 463 XBHAWT-000000-0000T50F5 XBHAWT-000000-000LT50F5 T4 240 276 318 428 XBHAWT-000000-0000T40F5 XBHAWT-000000-000LT40F5 T3 220 253 292 392 XBHAWT-000000-0000T30F5 XBHAWT-000000-000LT30F5 T6 280 322 372 499 XBHAWT-000000-0000T60E5 T5 260 299 345 463 XBHAWT-000000-0000T50E5 XBHAWT-000000-000LT50E5 T4 240 276 318 428 XBHAWT-000000-0000T40E5 XBHAWT-000000-000LT40E5 XBHAWT-000000-000HT40E5 T3 220 253 292 392 XBHAWT-000000-0000T30E5 XBHAWT-000000-000LT30E5 XBHAWT-000000-000HT30E5 T4 240 276 318 428 XBHAWT-000000-000LT40Z5 XBHAWT-000000-000HT40Z5 T3 220 253 292 392 XBHAWT-000000-000LT30Z5 XBHAWT-000000-000HT30Z5 T5 260 299 345 463 XBHAWT-000000-0000T50F6 T4 240 276 318 428 XBHAWT-000000-0000T40F6 XBHAWT-000000-000HT40F6 T3 220 253 292 392 XBHAWT-000000-0000T30F6 XBHAWT-000000-000HT30F6 T2 200 230 265 356 XBHAWT-000000-0000T20F6 XBHAWT-000000-000HT20F6 T5 260 299 345 463 XBHAWT-000000-0000T50E6 T4 240 276 318 428 XBHAWT-000000-0000T40E6 XBHAWT-000000-000HT40E6 T3 220 253 292 392 XBHAWT-000000-0000T30E6 XBHAWT-000000-000HT30E6 T2 200 230 265 356 XBHAWT-000000-0000T20E6 XBHAWT-000000-000HT20E6 4300 K E5 4000 K Z5 Order Codes 4000 K F6 3700 K E6 3500 K Standard CRI 80 CRI Minimum 85 CRI Minimum 90 CRI Minimum Notes: • • • • • * ** Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 19). XLamp XB-H LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity or bin restrictions specified by the order code. Typical CRI for Cool White (5000 K - 5700 K CCT) is 70. Typical CRI for Neutral White (3700 K - 5300 K CCT) is 75. Typical CRI for Warm White (2600 K - 3700 K CCT) is 80. Flux values @ 25 °C are calculated and for reference only. Calculated flux values at 1 A and 1.5 A are for reference only. © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS90 REV 6 4 XLAMP ® XB-H LED FLUX CHARACTERISTICS (TJ = 85 °C) - CONTINUED Chromaticity Kit CCT Z6 Minimum Luminous Flux (lm) @ 700 mA Calculated Minimum Luminous Flux (lm)** @ 85 °C Order Codes Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 1.0 A 1.5 A T3 220 253 292 392 XBHAWT-000000-000HT30Z6 T2 200 230 265 356 XBHAWT-000000-000HT20Z6 T5 260 299 345 463 XBHAWT-000000-0000T50F7 T4 240 276 318 428 XBHAWT-000000-0000T40F7 T3 220 253 292 392 XBHAWT-000000-0000T30F7 XBHAWT-000000-000HT30F7 T2 200 230 265 356 XBHAWT-000000-0000T20F7 XBHAWT-000000-000HT20F7 T5 260 299 345 463 XBHAWT-000000-0000T50E7 T4 240 276 318 428 XBHAWT-000000-0000T40E7 T3 220 253 292 392 XBHAWT-000000-0000T30E7 XBHAWT-000000-000HT30E7 T2 200 230 265 356 XBHAWT-000000-0000T20E7 XBHAWT-000000-000HT20E7 S6 182 209 242 324 XBHAWT-000000-000PS60E7 XBHAWT-000000-000US60E7 S5 172 198 228 306 XBHAWT-000000-000PS50E7 XBHAWT-000000-000US50E7 S4 164 186 218 292 T3 220 253 292 392 XBHAWT-000000-000HT30Z7 T2 200 230 265 356 XBHAWT-000000-000HT20Z7 S6 182 209 242 324 XBHAWT-000000-000PS60Z7 XBHAWT-000000-000US60Z7 S5 172 198 228 306 XBHAWT-000000-000PS50Z7 XBHAWT-000000-000US50Z7 S4 164 186 218 292 No CRI Minimum 3500 K F7 3200 K E7 3000 K Z7 3000 K Standard CRI 80 CRI Minimum 85 CRI Minimum 90 CRI Minimum XBHAWT-000000-000PT20E7 XBHAWT-000000-000US40E7 XBHAWT-000000-000US40Z7 Notes: • • • • • * ** Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 19). XLamp XB-H LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity or bin restrictions specified by the order code. Typical CRI for Cool White (5000 K - 5700 K CCT) is 70. Typical CRI for Neutral White (3700 K - 5300 K CCT) is 75. Typical CRI for Warm White (2600 K - 3700 K CCT) is 80. Flux values @ 25 °C are calculated and for reference only. Calculated flux values at 1 A and 1.5 A are for reference only. © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS90 REV 6 5 XLAMP ® XB-H LED FLUX CHARACTERISTICS (TJ = 85 °C) - CONTINUED Chromaticity Kit CCT F8 2850 K E8 2700 K Z8 2700 K Minimum Luminous Flux (lm) @ 700 mA Calculated Minimum Luminous Flux (lm)** @ 85 °C Order Codes Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 1.0 A 1.5 A T3 220 253 292 392 XBHAWT-000000-000HT30F8 T2 200 230 265 356 XBHAWT-000000-000HT20F8 S6 182 209 242 324 XBHAWT-000000-000HS60F8 S5 172 198 228 S4 164 186 T3 220 T2 No CRI Minimum Standard CRI 80 CRI Minimum 85 CRI Minimum 90 CRI Minimum XBHAWT-000000-000PS60F8 XBHAWT-000000-000US60F8 306 XBHAWT-000000-000PS50F8 XBHAWT-000000-000US50F8 218 292 XBHAWT-000000-000PS40F8 XBHAWT-000000-000US40F8 253 292 392 XBHAWT-000000-000HT30E8 200 230 265 356 XBHAWT-000000-000HT20E8 S6 182 209 242 324 XBHAWT-000000-000HS60E8 XBHAWT-000000-000PS60E8 XBHAWT-000000-000US60E8 S5 172 198 228 306 XBHAWT-000000-000PS50E8 XBHAWT-000000-000US50E8 S4 164 186 218 292 XBHAWT-000000-000PS40E8 XBHAWT-000000-000US40E8 T3 220 253 292 392 XBHAWT-000000-000HT30Z8 T2 200 230 265 356 XBHAWT-000000-000HT20Z8 S6 182 209 242 324 XBHAWT-000000-000HS60Z8 S5 172 198 228 306 XBHAWT-000000-000PS50Z8 XBHAWT-000000-000US50Z8 S4 164 186 218 292 XBHAWT-000000-000PS40Z8 XBHAWT-000000-000US40Z8 XBHAWT-000000-000PS60Z8 Notes: • • • • • * ** Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 19). XLamp XB-H LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity or bin restrictions specified by the order code. Typical CRI for Cool White (5000 K - 5700 K CCT) is 70. Typical CRI for Neutral White (3700 K - 5300 K CCT) is 75. Typical CRI for Warm White (2600 K - 3700 K CCT) is 80. Flux values @ 25 °C are calculated and for reference only. Calculated flux values at 1 A and 1.5 A are for reference only. © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS90 REV 6 6 XLAMP ® XB-H LED Relative Spectral Power RELATIVE SPECTRAL POWER DISTRIBUTION 100% Relative Radiant Power 80% 60% Cool White Warm White 40% 20% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Relative Flux Output vs. Junction Temperature RELATIVE FLUX VS. JUNCTION TEMPERATURE (IF = 700 mA) 120% Relative Luminous Flux 100% 80% 60% 40% 20% 0% 25 50 75 100 125 150 Junction Temperature (ºC) © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS90 REV 6 7 XLAMP ® XB-H LED Electrical Characteristics (Tj = 25ºC) ELECTRICAL CHARACTERISTICS (TJ = 85 °C) 1500 Forward Current (mA) 1200 900 600 300 0 2.65 2.75 2.85 2.95 3.05 3.15 1200 1500 Forward Voltage (V) Relative Intensity vs. Current (Tj = 85ºC) RELATIVE FLUX VS. CURRENT (TJ = 85 °C) 200% 180% Relative Luminous Flux 160% 140% 120% 100% 80% 60% 40% 20% 0% 0 300 600 900 Forward Current (mA) © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS90 REV 6 8 XLAMP ® XB-H LED Delta CCT vs. Current RELATIVE CHROMATICITY VS CURRENT AND TEMPERATURE (WARM WHITE*) 0.020 0.015 0.010 0.005 ΔCCx 0.000 ΔCCy -0.005 -0.010 Delta CCT vs Temp -0.015 -0.020 100 300 500 700 900 1100 1300 1500 Current (mA) 0.020 0.015 0.010 0.005 ΔCCx 0.000 ΔCCy -0.005 -0.010 -0.015 -0.020 25 50 75 100 125 150 Tsp (°C) * Warm White XLamp XB-H LEDs have a typical CRI of 80. © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS90 REV 6 9 XLAMP ® XB-H LED Typical Spatial Radiation Pattern TYPICAL SPATIAL DISTRIBUTION 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -60 0% -30 0 30 60 90 Angle (º) THERMAL DESIGN The maximum forward current is determined by the thermal resistance between the LED junction and ambient. It is crucial for the end Thermal Design product to be designed in a manner that minimizes the thermal resistance from the solder point to ambient in order to optimize lamp life and optical characteristics. 1600 Maximum Current (mA) 1400 1200 1000 800 600 Rj-a = 10 °C/W 400 Rj-a = 15 °C/W Rj-a = 20 °C/W 200 0 Rj-a = 25 °C/W 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS90 REV 6 10 XLAMP ® XB-H LED PERFORMANCE GROUPS – LUMINOUS FLUX XLamp XB-H LEDs are tested for luminous flux and placed into one of the following luminous‑flux groups. These groups, appended with a 0, are used in the Bin Code “Luminous or radiant flux group.” Group Code Minimum Luminous Flux (lm) @ 700 mA Maximum Luminous Flux (lm) @ 700 mA S4 164 172 S5 172 182 S6 182 200 T2 200 220 T3 220 240 T4 240 260 T5 260 280 T6 280 300 U2 300 320 PERFORMANCE GROUPS – CHROMATICITY Region 2A 2R 3A 3R 4A x y 0.3215 0.3290 0.3290 0.3300 0.3222 0.3222 0.3290 0.3300 0.3290 0.3180 0.3231 0.3371 0.3451 0.3554 0.3440 0.3427 0.3366 0.3369 0.3366 0.3440 0.3429 0.3307 0.3361 0.3530 0.3615 0.3659 0.3590 0.3521 0.3512 0.3465 Region x y 0.3350 0.3207 0.3417 0.3290 0.3290 0.3417 0.3243 0.3215 0.3243 0.3196 0.3290 0.3690 0.3290 0.3538 0.3120 0.3207 0.3490 0.3376 0.3463 0.3687 0.3451 0.3554 0.3371 0.3490 0.3369 0.3381 0.3428 0.3480 0.3463 0.3687 0.3245 0.3376 0.3597 0.3548 0.3641 0.3804 0.3615 0.3659 0.3530 0.3597 2B 2S 3B 3S 4B Region x y 0.3462 0.3290 0.3538 0.3376 0.3371 0.3490 0.3350 0.3290 0.3602 0.3290 0.3381 0.3762 0.3376 0.3616 0.3462 0.3290 0.3616 0.3463 0.3551 0.3760 0.3533 0.3620 0.3451 0.3554 0.3762 0.3480 0.3840 0.3571 0.3551 0.3760 0.3616 0.3463 0.3736 0.3641 0.3736 0.3874 0.3702 0.3722 0.3615 0.3659 2C 2T 3C 3T 4C x y 0.3538 0.3290 0.3417 0.3616 0.3371 0.3490 0.3366 0.3369 0.3417 0.3290 0.3300 0.3690 0.3290 0.3300 0.3366 0.3369 0.3361 0.3245 0.3538 0.3290 0.3180 0.3687 0.3451 0.3554 0.3533 0.3620 0.3515 0.3487 0.3440 0.3427 0.3840 0.3440 0.3428 0.3907 0.3515 0.3487 0.3495 0.3339 0.3687 0.3429 0.3307 0.3804 0.3615 0.3659 0.3702 0.3722 0.3670 0.3578 0.3590 0.3521 © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Region 2D 2U 3D 3U 4D CLD-DS90 REV 6 11 XLAMP ® XB-H LED PERFORMANCE GROUPS – CHROMATICITY (CONTINUED) Region 4R 5A1 5B1 5C1 5D1 5R 6A1 6B1 6C1 6D1 x y 0.3512 0.3465 0.3590 0.3521 0.3567 0.3389 0.3495 0.3339 0.3670 0.3686 0.3744 0.3685 0.3726 0.3702 0.3719 0.3797 0.3782 0.3837 0.3763 0.3760 0.3825 0.3847 0.3912 0.3917 0.3887 0.3836 0.3783 0.3646 0.3804 0.3721 0.3863 0.3758 0.3840 0.3670 0.3783 0.3646 0.3743 0.3502 0.3640 0.3440 0.3889 0.3915 0.3981 0.3800 0.3953 0.3720 0.3941 0.3848 0.3968 0.3930 0.4040 0.3966 0.4010 0.4080 0.4113 0.4001 0.4186 0.4037 0.4150 0.3950 0.4017 0.4048 0.4116 0.3865 0.4082 0.3782 Region x y 0.3571 0.3907 0.3668 0.3957 0.3641 0.3804 0.3548 0.3736 0.3578 0.3686 0.3649 0.3702 0.3763 0.3760 0.3612 0.3744 0.3722 0.3719 0.3736 0.3874 0.3802 0.3916 0.3782 0.3837 0.3798 0.3847 0.3877 0.3869 0.3937 0.4001 0.3912 0.3917 0.3804 0.3721 0.3825 0.3798 0.3887 0.3836 0.3681 0.3863 0.3578 0.3771 0.3916 0.4127 0.3869 0.3958 0.3736 0.3874 0.3690 0.3915 0.3768 0.3941 0.4010 0.3882 0.3981 0.3800 0.3968 0.3930 0.3996 0.4015 0.4071 0.4052 0.3882 0.4040 0.3916 0.4113 0.4146 0.4089 0.4222 0.4127 0.4186 0.4037 0.3751 0.4048 0.3832 0.4080 0.4150 0.3950 0.4116 0.3865 4S 5A2 5B2 5C2 5D2 5S 6A2 6B2 6C2 6D2 Region x y 0.3668 0.3957 0.3771 0.4034 0.3736 0.3874 0.3641 0.3804 0.3649 0.3744 0.3722 0.3763 0.3825 0.3798 0.3685 0.3804 0.3797 0.3782 0.3802 0.3916 0.3869 0.3958 0.3847 0.3877 0.3958 0.4006 0.4044 0.3978 0.3958 0.3863 0.3758 0.3887 0.3836 0.3950 0.3875 0.3758 0.3924 0.4034 0.3916 0.4064 0.4221 0.4006 0.4044 0.3869 0.3958 0.3768 0.3981 0.3848 0.4010 0.4080 0.3916 0.4048 0.3832 0.4040 0.3966 0.4071 0.4052 0.4146 0.4089 0.3966 0.4113 0.4001 0.4186 0.4222 0.4127 0.4299 0.4165 0.4259 0.4073 0.3832 0.4116 0.3916 0.4150 0.4221 0.3984 0.4183 0.3898 4T 5A3 5B3 5C3 5D3 5T 6A3 6B3 6C3 6D3 x y 0.3590 0.3521 0.3670 0.3578 0.3640 0.3440 0.3567 0.3389 0.3685 0.3726 0.3612 0.3760 0.3744 0.3685 0.3804 0.3721 0.3721 0.3783 0.3646 0.3837 0.3763 0.3760 0.3782 0.3837 0.3847 0.3877 0.3877 0.3825 0.3798 0.3912 0.3917 0.3887 0.3836 0.3937 0.4001 0.3912 0.3917 0.3978 0.3958 0.3950 0.3875 0.3840 0.3681 0.3863 0.3758 0.3924 0.3794 0.3794 0.3898 0.3716 0.4127 0.3783 0.3646 0.3898 0.3716 0.3848 0.3565 0.3743 0.3502 0.3800 0.3953 0.3720 0.3882 0.3981 0.3800 0.4048 0.3832 0.4017 0.3751 0.4010 0.3882 0.4040 0.3966 0.4113 0.4001 0.4001 0.4080 0.3916 0.4037 0.4150 0.3950 0.4186 0.4037 0.4259 0.4073 0.4221 0.3984 0.3865 0.4082 0.3782 0.3950 0.4116 0.3865 0.4183 0.3898 0.4147 0.3814 © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Region 4U 5A4 5B4 5C4 5D4 5U 6A4 6B4 6C4 6D4 CLD-DS90 REV 6 12 XLAMP ® XB-H LED PERFORMANCE GROUPS – CHROMATICITY (CONTINUED) Region 6R 7A 7A1 7B1 7C1 7D1 8A 8A1 8B1 8C1 x y 0.3889 0.3690 0.4017 0.3751 0.3957 0.3596 0.3840 0.3540 0.4221 0.4342 0.4260 0.3853 0.4147 0.4147 0.4183 0.3898 0.4242 0.3919 0.4203 0.3833 0.4221 0.4259 0.4322 0.4096 0.4281 0.4006 0.4342 0.4028 0.4385 0.4119 0.4449 0.4141 0.4403 0.4259 0.4300 0.3939 0.4359 0.3960 0.4316 0.3873 0.4465 0.4582 0.4483 0.3918 0.4373 0.3893 0.4373 0.3893 0.4418 0.3981 0.4475 0.3994 0.4428 0.4465 0.4513 0.4164 0.4573 0.4178 0.4523 0.4085 0.4582 0.4634 0.4695 0.4207 0.4641 0.4112 Region x y 0.4054 0.4191 0.4217 0.4273 0.4146 0.4089 0.3996 0.4015 0.3985 0.4299 0.4028 0.4430 0.4342 0.4028 0.3814 0.4221 0.3814 0.4183 0.4221 0.3984 0.4281 0.4006 0.4242 0.3919 0.3984 0.4259 0.4073 0.4299 0.4364 0.4188 0.4322 0.4096 0.4385 0.4119 0.4430 0.4212 0.4496 0.4236 0.4049 0.4449 0.3853 0.4300 0.4342 0.4028 0.4403 0.4049 0.4359 0.3960 0.4071 0.4562 0.4099 0.4687 0.4582 0.4099 0.4465 0.4071 0.4418 0.3981 0.4465 0.4071 0.4523 0.4085 0.3906 0.4475 0.4071 0.4513 0.4562 0.4260 0.4624 0.4274 0.4573 0.4178 0.4099 0.4634 0.4193 0.4687 0.4750 0.4304 0.4695 0.4207 6S 7B 7A2 7B2 7C2 7D2 8B 8A2 8B2 8C2 Region x y 0.4217 0.4273 0.4382 0.4356 0.4299 0.4165 0.4146 0.4089 0.4165 0.4430 0.4212 0.4562 0.4465 0.4071 0.3985 0.4342 0.3898 0.4242 0.4281 0.4006 0.4342 0.4028 0.4300 0.4073 0.4165 0.4430 0.4212 0.4385 0.4119 0.4449 0.4141 0.4496 0.4236 0.4562 0.4260 0.4141 0.4513 0.3939 0.4359 0.4403 0.4049 0.4465 0.4071 0.4418 0.3981 0.4260 0.4687 0.4289 0.4813 0.4700 0.4126 0.4582 0.4099 0.4475 0.3994 0.4523 0.4085 0.4582 0.4099 0.3994 0.4532 0.4164 0.4573 0.4624 0.4274 0.4687 0.4289 0.4634 0.4193 0.4193 0.4695 0.4289 0.4750 0.4813 0.4319 0.4756 0.4221 6T 7C 7A3 7B3 7C3 7D3 8C 8A3 8B3 8C3 x y 0.4017 0.3751 0.4147 0.3814 0.4077 0.3652 0.3957 0.3596 0.4212 0.4342 0.4028 0.426 0.4465 0.4071 0.4373 0.3893 0.4028 0.4260 0.3853 0.3919 0.4203 0.3833 0.4242 0.3919 0.4300 0.3939 0.3939 0.4259 0.3853 0.4322 0.4096 0.4281 0.4006 0.4364 0.4188 0.4322 0.4096 0.4385 0.4119 0.4342 0.4028 0.4403 0.4049 0.4449 0.4141 0.4513 0.4164 0.4164 0.4465 0.4071 0.3960 0.4316 0.3873 0.4359 0.3960 0.4418 0.3981 0.4373 0.3893 0.4289 0.4582 0.4099 0.4319 0.4700 0.4126 0.4593 0.3944 0.4483 0.3918 0.4428 0.3906 0.4475 0.3994 0.4532 0.4008 0.4008 0.4483 0.3919 0.4178 0.4523 0.4085 0.4573 0.4178 0.4634 0.4193 0.4582 0.4099 0.4207 0.4641 0.4112 0.4304 0.4695 0.4207 0.4756 0.4221 0.4700 0.4126 © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Region 6U 7D 7A4 7B4 7C4 7D4 8D 8A4 8B4 8C4 CLD-DS90 REV 6 13 XLAMP ® XB-H LED PERFORMANCE GROUPS – CHROMATICITY (CONTINUED) Region 8D1 x y 0.4483 0.3919 Region 0.4532 0.4008 0.4589 0.4021 0.4538 0.3931 8D2 x y 0.4532 0.4008 Region 0.4582 0.4099 0.4641 0.4112 0.4589 0.4021 8D3 x y 0.4589 0.4021 Region 0.4641 0.4112 0.4700 0.4126 0.4646 0.4034 8D4 x y 0.4538 0.3931 0.4589 0.4021 0.4646 0.4034 0.4593 0.3944 STANDARD COOL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.40 5000 K 0.39 0.38 5700 K E2 0.37 6500 K 0.36 3B 2S 0.35 CCy 3S 2T 2C 1T 8000 K 0.34 0T 0.33 0S 0.32 0C 0A 3R 2A 2U 1D ANSI C78.377A 2R 1A 0D 2D 1C 1B 0B 0.31 3A 2B 1S 1U 1R 0U 0.30 0R 0.29 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.28 CCx © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS90 REV 6 14 XLAMP ® XB-H LED STANDARD WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.46 0.45 2700 K 3000 K 0.44 0.43 0.42 4000 K 0.41 E6 4500 K E5 0.40 CCy E7 3500 K 5000 K 0.39 0.38 E3 0.37 0.36 E4 4B 3C 4D 3B 6B2 5C3 5C2 5B1 5D3 6A2 5D2 5A3 5D4 6A1 5A2 5D1 5A4 5A1 6D2 6A3 6A4 6D1 7A4 7A1 6D4 7D1 8B2 8C1 8B4 8C2 8C3 8C4 8D3 8D2 8D4 8A4 8D1 8A1 7D4 8A3 8A2 7D3 7D2 7A3 7A2 6D3 8B1 7C4 7C1 7B4 7B1 6C4 6C1 6B4 5C4 6B1 5C1 5B4 4C 6C2 6B3 5B3 5B2 6C3 7C2 7B3 7B2 7C3 E8 8B3 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx 0.46 0.45 2700 K 3000 K 0.44 0.43 3500 K 0.42 4000 K 0.41 4500 K CCy 0.40 F5 5000 K 0.39 F4 0.38 0.37 4B 3C 0.36 4D 3B 5B3 5C4 5C1 5B4 5D3 6A2 5B1 5D2 5A3 5D4 6A1 5A2 5D1 5A4 5A1 6C2 6B3 6B4 6B1 6A3 6A4 7B2 6C3 6B2 5C3 5C2 5B2 4C F6 F7 6C1 6D2 6D1 7B1 6C4 6D3 6D4 7A2 7A1 7A4 F8 7A3 7D1 7C2 7B3 7B4 7C1 7D4 8B1 7C4 7D3 7D2 7C3 8A1 8A2 8A3 8B2 8B3 8B4 8D2 8C1 8C2 8C3 8C4 8D3 8D4 8A4 8D1 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS90 REV 6 15 XLAMP ® XB-H LED STANDARD WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS CONTINUED 0.46 0.45 2700 K 3000 K 0.44 0.43 0.42 Z6 4000 K 0.41 Z5 4500 K 0.40 CCy Z7 3500 K 6C3 6C2 6B3 6B2 5C3 5000 K 0.39 5C2 5B3 5D3 6A2 5B4 0.38 5B1 4C 0.37 4D 3B 5D4 6A1 6A3 6A4 6C4 6C1 6D2 6D1 6D3 6D4 7A2 7A1 7A4 7B4 7A3 7D1 7C1 7D3 7D2 7D4 8B1 7C4 8A1 8A2 8A3 8B2 8B3 8B4 8D2 8C1 8C2 8C3 8C4 8D3 8D4 8A4 8D1 5D1 ANSI C78.377A 5A4 3C 0.36 5D2 5A3 5A2 4B 5C4 6B1 5C1 5B2 6B4 7B1 7C2 7B3 7B2 7C3 Z8 5A1 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS90 REV 6 16 XLAMP ® XB-H LED STANDARD CHROMATICITY KITS The following table provides the chromaticity bins associated with chromaticity kits, which are specified as part of the order code. Color Kit Chromaticity Bins Cool White E2 2A, 2B, 2C, 2D E3 3A, 3B, 3C, 3D Neutral White Warm White F4 3C, 3D, 4A, 4B E4 4A, 4B, 4C, 4D F5 4C, 4D, 5A1, 5A2, 5A3, 5A4, 5B1, 5B2, 5B3, 5B4 E5 5A1, 5A2, 5A3, 5A4, 5B1, 5B2, 5B3, 5B4, 5C1, 5C2, 5C3, 5C4, 5D1, 5D2, 5D3, 5D4 Z5 5A3, 5B4, 5C1, 5D2 F6 5C1, 5C2, 5C3, 5C4, 5D1, 5D2, 5D3, 5D4, 6A1, 6A2, 6A3, 6A4, 6B1, 6B2, 6B3, 6B4 E6 6A1, 6A2, 6A3, 6A4, 6B1, 6B2, 6B3, 6B4, 6C1, 6C2, 6C3, 6C4, 6D1, 6D2, 6D3, 6D4 Z6 6A3, 6B4, 6C1, 6D2 F7 6C1, 6C2, 6C3, 6C4, 6D1, 6D2, 6D3, 6D4, 7A1, 7A2, 7A3, 7A4, 7B1, 7B2, 7B3, 7B4 E7 7A1, 7A2, 7A3, 7A4, 7B1, 7B2, 7B3, 7B4, 7C1, 7C2, 7C3, 7C4, 7D1, 7D2, 7D3, 7D4 Z7 7A3, 7B4, 7C1, 7D2 F8 7C1, 7C2, 7C3, 7C4, 7D1, 7D2, 7D3, 7D4, 8A1, 8A2, 8A3, 8A4, 8B1, 8B2, 8B3, 8B4 E8 8A1, 8A2, 8A3, 8A4, 8B1, 8B2, 8B3, 8B4, 8C1, 8C2, 8C3, 8C4, 8D1, 8D2, 8D3, 8D4 Z8 8A3, 8B4, 8C1, 8D2 BIN AND ORDER CODE FORMATS Bin codes and order codes for XB-H LEDs are configured in the following manner: Order Code Bin Code Series XBH = XB-H Series XBH = XB-H Internal code Internal code Luminous flux group Luminous flux group Chromaticity group Color specification 0 = No CRI minimum L = Standard CRI H = 80 CRI minimum P = 85 CRI minimum U = 90 CRI minimum SSSCCC-BD-HHHH-NNNGFFWWW Color specification 0 = No CRI minimum L = Standard CRI H = 80 CRI minimum P = 85 CRI minimum U = 90 CRI minimum SSSCCC-B-WWW-FFF-GG-AAAA Internal code Internal code Chromaticity group Color AWT = White Color AWT = White Example Order Code: XBHAWT-00-0000-000HT20E7 Example Bin Code: XBHAWT-0-7A3-T20-0H-0001 © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS90 REV 6 17 XLAMP ® XB-H LED REFLOW SOLDERING CHARACTERISTICS In testing, Cree LED has found XLamp XB-H LEDs to be compatible with JEDEC J-STD-020C, using the parameters listed below. As a general guideline, Cree LED recommends that users follow the recommended soldering profile provided by the manufacturer of the solder paste used, and therefore it is the lamp or luminaire manufacturer’s responsibility to determine applicable soldering requirements. Note that this general guideline may not apply to all PCB designs and configurations of reflow soldering equipment. tP TP Critical Zone TL to TP Temperature Ramp-up TL tL Tsmax Tsmin Ramp-down ts Preheat 25 t 25˚C to Peak IPC/JEDEC J-STD-020C Time Profile Feature Average Ramp-Up Rate (Tsmax to Tp) Lead-Free Solder 1.2 °C/second Preheat: Temperature Min (Tsmin) 120 °C Preheat: Temperature Max (Tsmax) 170 °C Preheat: Time (tsmin to tsmax) 65-150 seconds Time Maintained Above: Temperature (TL) Time Maintained Above: Time (tL) Peak/Classification Temperature (Tp) 217 °C 45-90 seconds 235 - 245 °C Time Within 5 °C of Actual Peak Temperature (tp) 20-40 seconds Ramp-Down Rate 1 - 6 °C/second Time 25 °C to Peak Temperature 4 minutes max. Note: All temperatures refer to topside of the package, measured on the package body surface. © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS90 REV 6 18 XLAMP ® XB-H LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. Moisture Sensitivity Cree LED recommends keeping XLamp LEDs in the provided, resealable moisture-barrier packaging (MBP) until immediately prior to soldering. Unopened MBPs that contain XLamp LEDs do not need special storage for moisture sensitivity. Once the MBP is opened, XLamp XB-H LEDs may be stored as MSL 1 per JEDEC J-STD-033, meaning they have unlimited floor life in conditions of ≤ 30 ºC/85% relative humidity (RH). Regardless of storage condition, Cree LED recommends sealing any unsoldered LEDs in the original MBP. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACH Compliance REACH substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACH SVHC Declaration. REACH banned substance information (REACH Article 67) is also available upon request. © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS90 REV 6 19 XLAMP ® XB-H LED NOTES - CONTINUED UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS90 REV 6 20 4 4 4DIMENSIONS MECHANICAL 2.45 3 3 3 2 2 2 2 All measurements are ±.13 mm. unless otherwise indicated. 2.28 2.28 2.45 2.28 2.28 0.75 2.45 2.45 0.75 2.45 0.75 0.75 R1.53 ORIGIN OPTICAL MODEL ORIGIN A 3 Thermal vias, if present, are not shown on these drawings. R1.53 R1.53R1.53 OPTICAL MODEL ORIGIN OPTICAL MODEL ORIGIN TOP VIEW TOP VIEW Top View TOP VIEW TOP VIEW 2.29 0.58 OPTICAL MODEL ORIGIN MODEL ORIGIN SIDEOPTICAL VIEW SIDE VIEW View SIDESide VIEW 2.29 2.29 2.29 0.46 0.46 0.46 ANODE SIDE 0.58 0.58 SIDE VIEW 2.29 0.46 0.58 OPTICAL MODEL ORIGIN OPTICAL MODEL ORIGIN ANODE SIDE 2.29 2.29 2.29 ANODE SIDE ANODE ANODE SIDE SIDE CATHODE SIDE CATHODE SIDE CATHODE SIDE 2.29 2.29 2.29 2.29 2.29 2.29 ANODE ANODE SIDE SIDE 2.29 2.29 2.45 2.45 B XLAMP ® XB-H LED C CATHODE CATHODE SIDE SIDE 0.92 0.36 0.33 0.92 0.36 0.36 0.92 0.92 Bottom View BOTTOM VIEW BOTTOM VIEW BOTTOM VIEW BOTTOM VIEW CENTER PAD IS CENTER PAD IS ELECTRICALLY ISOLATED ELECTRICALLY ISOLA CENTER PAD I CENTER PAD IS 0.33 0.33 0.33 ELECTRICALLY ELECTRICALLY ISOL Alternate Bottom View ALTERNATE BOTTOM ALTERNATE VIEW BOTTOM VIEW ALTERNATE BOTTOM VIEW ALTERNATE BOTTOM VIEW 2610 4 4 4 3 3 3 3 2 © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 2 2 2 CLD-DS90 REV 6 21 XLAMP ® XB-H LED MECHANICAL DIMENSIONS - CONTINUED 2.29 2.29 0.36 2.29 0.36 0.33 0.92 0.33 0.39 0.85 0.85 0.17 0.17 0.25 0.25 2.29 2.29 2.29 2.29 ENDED PCB FOOTPRINT RECOMMENDED PCB FOOTPRINT Recommended PCB Footprint 4 0.39 0.85 0.85 0.92 2.29 RECOMMENDED STENCIL RECOMMENDED SOLDER STENC Recommended SOLDER Solder Stencil 2610-250002 X 3 3 2 © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 1 2 CLD-DS90 REV 6 22 XLAMP ® XB-H LED TAPE AND REEL All Cree LED carrier tapes conform to EIA-481D, Automated Component Handling Systems Standard. All dimensions are ±.15 mm unless otherwise indicated. Po T E Do Bo R P2 W A Anode side A F P1 B D1 "H" Ko B-B SECTION Bo (on a place in the bottom of the corner radii) Ao (on a place in the bottom of the corner radii) R "I" Ao Item ITEM Ao Dim. 2.60 Dim. Bo Ao 2.60 2.60 DETAIL"H" DETAIL"I" A-A SECTION Ko Bo Po KoP1 P2 Po 2.05 2.60 4.00 8.00 2.05 2.00 4.00 T P1 0.30 8.00 ITEM F Do D1 W R Dim. 5.50 1.50 1.50 12.00 4deg E 1.75 P2 F 2.00 5.50 TDo 1.50 0.30 E D1 1.50 1.75 W R 12.00 4° NOTICE 1) All Cree LED carrier tapes conform to EIA-481D, Automated Component handling Systems Standard 2) Measurement tolerances unless indicated otherwise: .xx = ±.15 mm 2402-M010 XBH © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS90 REV 6 23 XLAMP ® XB-H LED TAPE AND REEL - CONTINUED Feed Direction END START Trailer Loaded Pockets Leader Min. 160 mm empty pockets sealed with tape 1000 Lamps Min. 400 mm empty pockets with min. 100 mm sealed Feed Direction Cover Tape Pocket Tape 13 mm 7” © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS90 REV 6 24 XLAMP ® XB-H LED PACKAGING © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS90 REV 6 25
1. 物料型号:文档中提到的物料型号为XLamp® XB-H LED。
2. 器件简介:XLamp® XB-H LED是一款高功率LED,以其小尺寸、高光效和高光通量(在1.5A电流下,25°C时可达500流明)而著称。它具有三倍于竞争产品的光密度,低热阻(3.5°C/W),宽视角(110°),并且是JEDEC J-STD-020C标准的回流焊接兼容产品。
3. 引脚分配:文档中未明确列出具体的引脚分配图,但提到了中心焊盘是电气上隔离的,这通常意味着它是一个热管理或接地焊盘。
4. 参数特性:文档提供了详细的电气和热特性参数,例如热阻(3.5°C/W)、视场角(110°)、电压温度系数(-1.3 mV/°C)、正向电流(最大1500 mA)、反向电压(最大1V)和正向电压在不同电流下的典型值。
5. 功能详解:XB-H LED具有高光学控制因子(OCF),这使得照明制造商能够提高任何照明设计的性能,创建更小、成本更低的系统,并开发以前不可能的新照明解决方案。
6. 应用信息:文档中提到XB-H LED适用于方向性照明应用,并且由于其高OCF,可以用于提高照明设计的性能。
7. 封装信息:文档提供了详细的机械尺寸图和封装信息,包括推荐PCB焊盘设计和模板尺寸。
XBHAWT-00-0000-000HT20E6 价格&库存
很抱歉,暂时无法提供与“XBHAWT-00-0000-000HT20E6”相匹配的价格&库存,您可以联系我们找货
