MTGBEZ-01-0000-0N0UH030F
    CREELED
    SMD2
    LED XLAMP 3000K EASY WHT SMD
MTGBEZ-01-0000-0N0UH030F 数据手册
PRODUCT FAMILY DATA SHEET XLamp® MT-G2 EasyWhite® LEDs PRODUCT DESCRIPTION The XLamp® FEATURES MT-G2 EasyWhite® LED • EasyWhite color temperatures from builds on the breakthrough performance 2700 K to 5000 K CCT TABLE OF CONTENTS Characteristics................................................ 2 Flux Characteristics, Standard Order Codes, of the original MT-G by increasing lumen • 85 °C binning and characterization Bins, 6-Volt MT-G2........................................... 3 output up to 25%, while providing a small, • Three voltage options: 6 V, 9 V, 36 V Flux Characteristics, Standard Order Codes, uniform, single point source for precise • 80 and 90 minimum CRI options Bins, 9-Volt MT-G2........................................... 4 optical control. The MT-G2 shares the same • Low thermal resistance: 0.4 °C/W Flux Characteristics, Standard Order Codes, mechanical footprint as the original MT‑G, • High lumen density Bins, 36-Volt MT-G2......................................... 5 providing customers with a seamless • Small, uniform emitting area for Relative Spectral Power Distribution............. 6 upgrade path and shortening the LED Relative Luminous Flux vs. Junction luminaire and retrofit lamp design cycle. excellent optical control • Electrically neutral thermal path Temperature.................................................... 6 • RoHS and REACH compliant Electrical Characteristics................................ 7 MT-G2 LEDs are designed for high-output, • UL recognized component (E349212) Relative Luminous Flux vs. Current................ 8 directional lighting applications and are the Typical Spatial Distribution........................... 10 ® ideal replacement for lighting applications APPLICATIONS that currently use inefficient halogen • MR, PAR, BR, AR and other directional lamps. MT-G2 LEDs are optimized for use retrofit lamps in track, accent, lamp retrofit, downlighting • Commercial/residential directional and other applications where color quality, consistency required. and optical control lighting are • General illumination Performance Groups – Brightness.............. 10 Performance Groups – Chromaticity........... 11 EasyWhite® Color Temperatures Plotted on the 1931 CIE Curve....................................... 12 Bin and Order Code Formats........................ 13 Reflow Soldering Characteristics................. 14 Notes............................................................. 15 Mechanical Dimensions............................... 17 Tape and Reel................................................ 19 Packaging...................................................... 21 Cree LED / 4001 E. Hwy. 54, Suite 2000 / Durham, NC 27709 USA / +1.919.313.5330 / www.cree-led.com © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS49 REV 6 1 XLAMP ® MT-G2 EASYWHITE ® LED CHARACTERISTICS Characteristics Viewing angle (FWHM) ESD withstand voltage (HBM per Mil-Std-883D) Thermal resistance, junction to solder point◊ Unit Minimum Typical degrees 125 V Class 2 °C/W 0.4 Maximum LED junction temperature °C 150 DC forward current (6 V) mA 3000 DC forward current (9 V) mA 2000 DC forward current (36 V) mA 500 Forward voltage (6 V, 1100 mA, 85 °C) V Forward voltage (6 V, 1100 mA, 25 °C) V Forward voltage (9 V, 735 mA, 85 °C) V Forward voltage (9 V, 735 mA, 25 °C) V Forward voltage (36 V, 185 mA, 85 °C) V Forward voltage (36 V, 185 mA, 25 °C) V 5.6 7 8.4 10.5 33.6 42 Temperature coefficient of voltage (6 V) mV/°C -3 Temperature coefficient of voltage (9 V) mV/°C -4 Temperature coefficient of voltage (36 V) mV/°C -16 Reverse voltage (6 V) V 1 Reverse current (6 V, 9 V, 36 V)  A 0.1 Note: ◊ Thermal resistance measurement was performed per the JEDEC JESD51-14 standard. See the Thermal Resistance Measurement application note for more details. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS49 REV 6 2 XLAMP ® MT-G2 EASYWHITE ® LED FLUX CHARACTERISTICS, STANDARD ORDER CODES, BINS, 6-VOLT MT-G2 (1100 mA, Tj = 85 °C) The following table provides several base order codes for 6-volt XLamp MT-G2 EasyWhite LEDs. For a complete description of the ordercode nomenclature, please reference page 13 of this document. Color CCT Range 5000 K 4000 K Standard CRI EasyWhite 3500 K 3000 K 2700 K 5000 K 80 CRI EasyWhite 4000 K 3000 K 90 CRI EasyWhite 2700 K Minimum Luminous Flux (lm) @ 1100 mA 2-Step 4-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* N0 750 863 P0 800 920 K0 650 748 M0 700 805 N0 750 863 MTGBEZ-00-0000-0B00N040H MTGBEZ-00-0000-0B00N040F K0 650 748 MTGBEZ-00-0000-0B00K035H MTGBEZ-00-0000-0B00K035F M0 700 805 N0 750 863 MTGBEZ-00-0000-0B00N035H MTGBEZ-00-0000-0B00N035F J0 600 690 MTGBEZ-00-0000-0B00J030H MTGBEZ-00-0000-0B00J030F K0 650 748 M0 700 805 MTGBEZ-00-0000-0B00M030H MTGBEZ-00-0000-0B00M030F H0 560 644 MTGBEZ-00-0000-0B00H027H MTGBEZ-00-0000-0B00H027F J0 600 690 K0 650 748 M0 700 805 N0 750 863 J0 600 690 K0 650 748 M0 700 805 F0 480 552 G0 520 598 E0 440 506 F0 480 552 Chromaticity Region 50H Order Code MTGBEZ-00-0000-0B00N050H MTGBEZ-00-0000-0B00P050H Chromaticity Region 50F MTGBEZ-00-0000-0B00K040H 40H 35H 30H 27H MTGBEZ-00-0000-0B00M040H MTGBEZ-00-0000-0B00M035H MTGBEZ-00-0000-0B00K030H MTGBEZ-00-0000-0B00J027H MTGBEZ-00-0000-0B0HM050H MTGBEZ-00-0000-0B0HN050H 40f 35F 30F 27F MTGBEZ-00-0000-0B0HK040H 50F 27H MTGBEZ-00-0000-0B0UF030H MTGBEZ-00-0000-0B0UG030H MTGBEZ-00-0000-0B0UE027H MTGBEZ-00-0000-0B0UF027H MTGBEZ-00-0000-0B00M040F MTGBEZ-00-0000-0B00M035F MTGBEZ-00-0000-0B00K030F MTGBEZ-00-0000-0B00J027F MTGBEZ-00-0000-0B0HM050F MTGBEZ-00-0000-0B0HN050F MTGBEZ-00-0000-0B0HJ040F 40F MTGBEZ-00-0000-0B0HM040H 30H MTGBEZ-00-0000-0B00P050F MTGBEZ-00-0000-0B00K027F MTGBEZ-00-0000-0B0HJ040H 40H MTGBEZ-00-0000-0B00N050F MTGBEZ-00-0000-0B00K040F MTGBEZ-00-0000-0B00K027H 50H Order Code MTGBEZ-00-0000-0B0HK040F MTGBEZ-00-0000-0B0HM040F 30F 27F MTGBEZ-00-0000-0B0UF030F MTGBEZ-00-0000-0B0UG030F MTGBEZ-00-0000-0B0UE027F MTGBEZ-00-0000-0B0UF027F Notes: • • • • • * Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 15). XLamp MT-G2 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Minimum CRI for standard EasyWhite color temperatures 27F, 27H, 30F, 30H, 35F, 35H is 80. Minimum CRI for standard EasyWhite color temperatures, 40F, 40H, 50F, 50H is 70. Typical CRI for standard EasyWhite color temperatures 40F, 40H, 50F, 50H is 75. Flux values @ 25 °C are calculated and for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS49 REV 6 3 XLAMP ® MT-G2 EASYWHITE ® LED FLUX CHARACTERISTICS, STANDARD ORDER CODES, BINS, 9-VOLT MT-G2 (735 mA, Tj = 85 °C) The following table provides several base order codes for 9-volt XLamp MT-G2 EasyWhite LEDs. For a complete description of the ordercode nomenclature, please reference page 13 of this document. Color CCT Range 5000 K 4000 K Standard CRI EasyWhite 3500 K 3000 K 2700 K 5000 K 80 CRI EasyWhite 4000 K 3000 K 90 CRI EasyWhite 2700 K Minimum Luminous Flux (lm) @ 735 mA 2-Step 4-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* N0 750 863 P0 800 920 K0 650 748 M0 700 805 N0 750 863 MTGBEZ-00-0000-0C00N040H MTGBEZ-00-0000-0C00N040F K0 650 748 MTGBEZ-00-0000-0C00K035H MTGBEZ-00-0000-0C00K035F M0 700 805 N0 750 863 MTGBEZ-00-0000-0C00N035H MTGBEZ-00-0000-0C00N035F J0 600 690 MTGBEZ-00-0000-0C00J030H MTGBEZ-00-0000-0C00J030F K0 650 748 M0 700 805 MTGBEZ-00-0000-0C00M030H MTGBEZ-00-0000-0C00M030F H0 560 644 MTGBEZ-00-0000-0C00H027H MTGBEZ-00-0000-0C00H027F J0 600 690 K0 650 748 M0 700 805 N0 750 863 J0 600 690 K0 650 748 M0 700 805 F0 480 552 G0 520 598 E0 440 506 F0 480 552 Chromaticity Region 50H Order Code MTGBEZ-00-0000-0C00N050H MTGBEZ-00-0000-0C00P050H Chromaticity Region 50F MTGBEZ-00-0000-0C00K040H 40H 35H 30H 27H MTGBEZ-00-0000-0C00M040H MTGBEZ-00-0000-0C00M035H MTGBEZ-00-0000-0C00K030H MTGBEZ-00-0000-0C00J027H MTGBEZ-00-0000-0C0HM050H MTGBEZ-00-0000-0C0HN050H 40F 35F 30F 27F MTGBEZ-00-0000-0C0HK040H 50F 27H MTGBEZ-00-0000-0C0UF030H MTGBEZ-00-0000-0C0UG030H MTGBEZ-00-0000-0C0UE027H MTGBEZ-00-0000-0C0UF027H MTGBEZ-00-0000-0C00M040F MTGBEZ-00-0000-0C00M035F MTGBEZ-00-0000-0C00K030F MTGBEZ-00-0000-0C00J027F MTGBEZ-00-0000-0C0HM050F MTGBEZ-00-0000-0C0HN050F MTGBEZ-00-0000-0C0HJ040F 40F MTGBEZ-00-0000-0C0HM040H 30H MTGBEZ-00-0000-0C00P050F MTGBEZ-00-0000-0C00K027F MTGBEZ-00-0000-0C0HJ040H 40H MTGBEZ-00-0000-0C00N050F MTGBEZ-00-0000-0C00K040F MTGBEZ-00-0000-0C00K027H 50H Order Code MTGBEZ-00-0000-0C0HK040F MTGBEZ-00-0000-0C0HM040F 30F 27F MTGBEZ-00-0000-0C0UF030F MTGBEZ-00-0000-0C0UG030F MTGBEZ-00-0000-0C0UE027F MTGBEZ-00-0000-0C0UF027F Notes: • • • • • * Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 15). XLamp MT-G2 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Minimum CRI for standard EasyWhite color temperatures 27F, 27H, 30F, 30H, 35F, 35H is 80. Minimum CRI for standard EasyWhite color temperatures, 40F, 40H, 50F, 50H is 70. Typical CRI for standard EasyWhite color temperatures 40F, 40H, 50F, 50H is 75. Flux values @ 25 °C are calculated and for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS49 REV 6 4 XLAMP ® MT-G2 EASYWHITE ® LED FLUX CHARACTERISTICS, STANDARD ORDER CODES, BINS, 36-VOLT MT-G2 (185 mA, Tj = 85 °C) The following table provides several base order codes for 36-volt XLamp MT-G2 EasyWhite LEDs. For a complete description of the ordercode nomenclature, please reference page 13 of this document. Color CCT Range 5000 K 4000 K Standard CRI EasyWhite 3500 K 3000 K 2700 K 5000 K 80 CRI EasyWhite 4000 K 3000 K 90 CRI EasyWhite 2700 K Minimum Luminous Flux (lm) @ 185 mA 2-Step 4-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* N0 750 863 P0 800 920 K0 650 748 M0 700 805 N0 750 863 MTGBEZ-00-0000-0N00N040H MTGBEZ-00-0000-0N00N040F K0 650 748 MTGBEZ-00-0000-0N00K035H MTGBEZ-00-0000-0N00K035F M0 700 805 N0 750 863 MTGBEZ-00-0000-0N00N035H MTGBEZ-00-0000-0N00N035F J0 600 690 MTGBEZ-00-0000-0N00J030H MTGBEZ-00-0000-0N00J030F K0 650 748 M0 700 805 MTGBEZ-00-0000-0N00M030H MTGBEZ-00-0000-0N00M030F H0 560 644 MTGBEZ-00-0000-0N00H027H MTGBEZ-00-0000-0N00H027F J0 600 690 K0 650 748 M0 700 805 N0 750 863 J0 600 690 K0 650 748 M0 700 805 F0 480 552 G0 520 598 E0 440 506 F0 480 552 Chromaticity Region 50H Order Code MTGBEZ-00-0000-0N00N050H MTGBEZ-00-0000-0N00P050H Chromaticity Region 50F MTGBEZ-00-0000-0N00K040H 40H 35H 30H 27H MTGBEZ-00-0000-0N00M040H MTGBEZ-00-0000-0N00M035H MTGBEZ-00-0000-0N00K030H MTGBEZ-00-0000-0N00J027H MTGBEZ-00-0000-0N0HM050H MTGBEZ-00-0000-0N0HN050H 40F 35F 30F 27F MTGBEZ-00-0000-0N0HK040H 50F 27H MTGBEZ-00-0000-0N0UF030H MTGBEZ-00-0000-0N0UG030H MTGBEZ-00-0000-0N0UE027H MTGBEZ-00-0000-0N0UF027H MTGBEZ-00-0000-0N00M040F MTGBEZ-00-0000-0N00M035F MTGBEZ-00-0000-0N00K030F MTGBEZ-00-0000-0N00J027F MTGBEZ-00-0000-0N0HM050F MTGBEZ-00-0000-0N0HN050F MTGBEZ-00-0000-0N0HJ040F 40F MTGBEZ-00-0000-0N0HM040H 30H MTGBEZ-00-0000-0N00P050F MTGBEZ-00-0000-0N00K027F MTGBEZ-00-0000-0N0HJ040H 40H MTGBEZ-00-0000-0N00N050F MTGBEZ-00-0000-0N00K040F MTGBEZ-00-0000-0N00K027H 50H Order Code MTGBEZ-00-0000-0N0HK040F MTGBEZ-00-0000-0N0HM040F 30F 27F MTGBEZ-00-0000-0N0UF030F MTGBEZ-00-0000-0N0UG030F MTGBEZ-00-0000-0N0UE027F MTGBEZ-00-0000-0N0UF027F Notes: • • • • • * Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 15). XLamp MT-G2 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Minimum CRI for standard EasyWhite color temperatures 27F, 27H, 30F, 30H, 35F, 35H is 80. Minimum CRI for standard EasyWhite color temperatures, 40F, 40H, 50F, 50H is 70. Typical CRI for standard EasyWhite color temperatures 40F, 40H, 50F, 50H is 75. Flux values @ 25 °C are calculated and for reference only. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS49 REV 6 5 XLAMP ® MT-G2 EASYWHITE ® LED Relative Spectral Power Distribution White RELATIVE SPECTRAL POWER DISTRIBUTION (6 V, 1100 mA; 735 mA; 185 mA; TJ = 85 °C) The following graph represents typical spectral output of each die9 V, of the MT-G Gen36 V, II Cool white to be added The following graph represents typical spectral output of the XLamp MT-G2 EasyWhite LED. 100% 90% Relative Spectral Power (%) 80% 70% 60% Neutral White Warm White 50% 40% 30% 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Relative Flux Output vs. Junction Temperature The following graph represents typical performance of each LED die in the XLamp MT-G Gen II RELATIVE LUMINOUS FLUX VS. JUNCTION TEMPERATURE (6 V, 1100 mA; 9 V, 735 mA; 36 V, 185 mA) The following graph represents typical performance of the XLamp MT-G2 EasyWhite LED. 120% Relative Luminous Flux 100% 80% 60% 40% 20% 0% 25 50 75 100 125 150 Junction Temperature (ºC) © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS49 REV 6 6 XLAMP ® MT-G2 EASYWHITE ® LED Characteristics ELECTRICALElectrical CHARACTERISTICS (TJ = 85 °C) (Tsp = 85ºC) 6V 3000 MT-G2 6 V 2500 Current (mA) 2000 1500 1000 500 0 5.1 5.2 5.3 5.4 5.5 5.6 Electrical Characteristics (Tsp = 85ºC) 5.7 5.8 5.9 Forward Voltage V 6.0 9V 2000 MT-G2 9 V Current (mA) 1600 1200 800 400 0 7.750 7.875 8.000 8.125 8.250 8.375 8.500 8.625 8.750 8.875 9.000 Forward Voltage V © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS49 REV 6 7 XLAMP ® MT-G2 EASYWHITE ® LED Electrical Characteristics (Tsp -=CONTINUED 85ºC) ELECTRICAL CHARACTERISTICS (TJ = 85 °C) 36V 500 MT-G2 36 V 450 400 Current (mA) 350 300 250 200 150 100 50 0 31.0 31.5 32.0 32.5 33.0 33.5 34.0 34.5 35.0 35.5 36.0 Forward Voltage V Relative Intensity vs. Current (Tsp = 85ºC) - 6 V RELATIVE LUMINOUS FLUX VS. CURRENT (TJ = 85 °C) 250% Relative Luminous Flux (%) MT-G2 6 V 200% 150% 100% 50% 0% 0 500 1000 1500 2000 2500 3000 Forward Current, Pulsed (mA) © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS49 REV 6 8 XLAMP ® MT-G2 EASYWHITE ® LED Relative Intensity vs. Current (Tsp = 85ºC) 9 V RELATIVE LUMINOUS FLUX VS. CURRENT (TJ = 85 °C) - CONTINUED 250% Relative Luminous Flux (%) MT-G2 9 V 200% 150% 100% 50% 0% 0 400 800 1200 1600 2000 Forward(Tsp Current, = Pulsed (mA) 36 V Relative Intensity vs. Current 85ºC) 250% Relative Luminous Flux (%) MT-G2 36 V 200% 150% 100% 50% 0% 0 50 100 150 200 250 300 350 400 450 500 Forward Current, Pulsed (mA) © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS49 REV 6 9 XLAMP ® MT-G2 EASYWHITE ® LED Spatial Distribution MT-G2 TYPICAL SPATIAL DISTRIBUTION data from: MTG_Gen2 SE800 vs DA2432 DS Comparison.xlsx (post PCN) The following graph represents typical performance of the XLamp MT-G2 EasyWhite LED. 100% Relative Luminous Intensity (%) 80% 60% 40% 20% -90 -60 -30 0% 0 30 60 90 Angle (º) PERFORMANCE GROUPS – BRIGHTNESS (TJ = 85 °C) XLamp MT-G2 EasyWhite LEDs are tested for luminosity and placed into one of the following bins. Group Code Minimum Luminous Flux @ Nominal IF Maximum Luminous Flux @ Nominal IF D0 400 440 E0 440 480 F0 480 520 G0 520 560 H0 560 600 J0 600 650 K0 650 700 M0 700 750 N0 750 800 P0 800 860 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS49 REV 6 10 XLAMP ® MT-G2 EASYWHITE ® LED PERFORMANCE GROUPS – CHROMATICITY (TJ = 85 °C) XLamp MT-G2 EasyWhite LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step EasyWhite Color Temperatures – 4-Step Code 50F 40F 35F 30F 27F CCT 5000 K 4000 K 3500 K 3000 K 2700 K x y 0.3459 0.3429 0.3507 0.3586 0.3434 0.3571 0.3475 0.3604 x y 0.3407 0.3415 Code 50H CCT 5000 K 0.3499 0.3654 0.3484 0.3521 0.3469 0.3539 0.3744 0.3685 0.3784 0.3741 0.3782 0.3837 0.3804 0.3818 0.3912 0.3917 0.3867 0.3857 0.3863 0.3758 0.3844 0.3778 0.3981 0.3800 0.4030 0.3857 0.4040 0.3966 0.4061 0.3941 0.4186 0.4037 0.4132 0.3976 0.4116 0.3865 0.4099 0.3890 0.4242 0.3919 0.4291 0.3973 0.4322 0.4096 0.4333 0.4062 0.4449 0.4141 0.4395 0.4084 0.4359 0.3960 0.4351 0.3994 0.4475 0.3994 0.4528 0.4046 0.4573 0.4178 0.4578 0.4138 0.4695 0.4207 0.4638 0.4152 0.4589 0.4021 0.4586 0.4060 40H 35H 30H 27H 4000 K 3500 K 3000 K 2700 K © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS49 REV 6 11 XLAMP ® MT-G2 EASYWHITE ® LED EASYWHITE® COLOR TEMPERATURES PLOTTED ON THE 1931 CIE CURVE (TJ = 85 °C) 0.45 ANSI C78.377 Quadrangle EasyWhite 4-step EasyWhite 2-step 0.44 2700 K 3000 K 0.43 3500 K 0.42 4000 K 4500 K 0.41 CCy 0.40 5000 K 0.39 5700 K 0.38 0.37 0.36 0.35 0.34 0.33 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.32 CCx © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS49 REV 6 12 XLAMP ® MT-G2 EASYWHITE ® LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured as follows: Order Code Bin Code Series MTG = MT-G Series MTG = MT-G Internal code Internal code CRI Specification H = 80 min CRI (4000 K & 5000 K) U = 90 min CRI (2700 K & 3000 K) 0 = Standard CRI Flux bin CRI Specification B = 70 min CRI H = 80 min CRI U = 90 min CRI SSSCCC-BZ-HHHH-HVVRNNNNN Kit code Vf class B0 = 6-V class C0 = 9-V class N0 = 36-V class SSSCCC-BB-WWW-FF-VVRAAAA Reel size 0 = 500 (standard) 1 = 100 (non-standard) Color BEZ = EasyWhite © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Internal Code Vf class: B0 = 6-V class C0 = 9-V class N0 = 36-V class Chromaticity bin Color BEZ = EasyWhite CLD-DS49 REV 6 13 XLAMP ® MT-G2 EASYWHITE ® LED REFLOW SOLDERING CHARACTERISTICS In testing, Cree LED has found XLamp MT-G2 EasyWhite LEDs to be compatible with JEDEC J-STD-020C, using the parameters listed below. As a general guideline, Cree LED recommends that users follow the recommended soldering profile provided by the manufacturer of the solder paste used, and therefore it is the lamp or luminaire manufacturer’s responsibility to determine applicable soldering requirements. Note that this general guideline may not apply to all PCB designs and configurations of reflow soldering equipment. tP TP Critical Zone TL to TP Temperature Ramp-up TL tL Tsmax Tsmin Ramp-down ts Preheat 25 t 25˚C to Peak Profile Feature Average Ramp-Up Rate (Tsmax to Tp) IPC/JEDEC J-STD-020C Time Lead-Free Solder 1.2 °C/second Preheat: Temperature Min (Tsmin) 120 °C Preheat: Temperature Max (Tsmax) 170 °C Preheat: Time (tsmin to tsmax) 65-150 seconds Time Maintained Above: Temperature (TL) Time Maintained Above: Time (tL) 217 °C 45-90 seconds Peak/Classification Temperature (Tp) 235 - 245 °C Time Within 5 °C of Actual Peak Temperature (tp) 20-40 seconds Ramp-Down Rate 1 - 6 °C/second Time 25 °C to Peak Temperature 4 minutes max. Note: All temperatures refer to the topside of the package, measured on the package body surface. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS49 REV 6 14 XLAMP ® MT-G2 EASYWHITE ® LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Moisture Sensitivity Cree LED recommends keeping XLamp LEDs in the provided, resealable moisture-barrier packaging (MBP) until immediately prior to soldering. Unopened MBPs that contain XLamp LEDs do not need special storage for moisture sensitivity. Once the MBP is opened, XLamp MT-G2 EasyWhite LEDs may be stored as MSL 1 per JEDEC J-STD-033, meaning they have unlimited floor life in conditions of ≤ 30 ºC/85% relative humidity (RH). Regardless of storage condition, Cree LED recommends sealing any unsoldered LEDs in the original MBP. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACH Compliance REACH substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACH Declaration. REACH banned substance information (REACH Article 67) is also available upon request. UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS49 REV 6 15 XLAMP ® MT-G2 EASYWHITE ® LED NOTES - CONTINUED Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS49 REV 6 16 XLAMP ® MT-G2 EASYWHITE ® LED MECHANICAL DIMENSIONS Thermal vias, if present, are not on these7drawings. 8 7 8 shown 6 6 5 5 4 4 3 3 2 All measurements are ±.13 mm unless otherwiseSOLDERMASK indicated. SOLDERMASK SOLDERMASK ANODEANODE SIDE SIDE 8.90 7.00 7.00 BE PRESENT MAY BEMAY PRESENT 0.95 0.95 CATHODE CATHODE SIDE SIDE 8.90 CATHODE SIDE 9.11 9.11 E E 0.65 ANODE SIDE 0.65 8.90 8.90 OPTICAL OPTICAL F MODELMODEL ORIGINORIGIN F MAY BE PRESENT 4.85 0.25 4.85 0.25 9.11 9.11 R4.10 4 5 3 4 SOLDERMASK MAY BE PRESENT 4.85 0.254.85 0.25 8.90 8.90 8.907.00 7.00 8.90 7.00 SIDE VIEW 1.23 BOTTO 1.23 F 0.25 0.25 0.58 0.58 1.35 E 7.01 0.50 1.23 7 8 D 6 D UNLESSUNLESS OTHERWISE SPEC NA OTHERWI DIMENSIONS ARE IN MILLI TL DIMENSIONS ARE TOLERANCES: DR TOLERANCES: 0.5°0.5 BEND 1°DRAWN ANGULAR: MACH 0.5° BEND 1° • ANGULAR: MACH ••• TWO ONE PLACE DECIMAL CHECKED • ONE PLACE 0.5 DECIM PLACE 0.05 DECIMAL CH TWO PLACE 0.05 DECI • INSIDE RADII EQUA ENG APPR. ••BEND INSIDE BEND RAD MATERIAL ENG MATERIAL •• MACHINE/CASTING RADI MFG APPR. MACHINE/CASTIN RADII AND DIA: MF •• 0.10 RADII AND 0.10DIA: Q.A. INTERPRET GEOMETRIC Q.A INTERPRET PROPRIETARY AND CONFIDENTIAL TOLERANCING PER:GEOME BOTTOM VIEW ALTERNATE BOTTOM VIEW THE THIRD ANG PROPRIETARY AND CONFIDENTIAL TOLERANCING PER INFORMATION CONTAINED INOF THISMATERIAL THI VIEW BOTTOM VIEW ALTERNATE BOTTOM THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY MATERIAL A DRAWING INITIATED DRAWING IS THE SOLE PROPERTY CREE LED. ANY REPRODUCTION IN MATERIAL A DRAWING INITIATED CREE ANY REPRODUCTION INOF MATERIAL PART OR AS ALED. WHOLE WITHOUT FINISH PART OR AS A DESCRIPTION WHOLE WRITTEN PERMISSION OF CREEWITHOUT LED REV WRITTEN PERMISSION OF CREE LED IS PROHIBITED. FINISH FINISH REVDESCRIPTION IS PROHIBITED. FINISH © CreeLED, Inc. a APPLICATION subsidiary of 2021 SMART Global Holdings, Inc. © 2021 CreeLED, Inc. a APPLICATION subsidiary of SMART Global Holdings, Inc. 5 4 2 2 3 2 3 5 4 6 C C 0.58 0.58 0.30 0.30 8.90 1.35 1.35 1.23 7 0.25 8 7.01 0.25 RECOMMENDED STENCILSTENCIL OPENING 8.90 REF. RECOMMENDED OPENING Alternate Bottom View 8.91 1.35 8.90 REF. 0.25 0.95 0.25 A 1.35 8.90 7.01 1.35 8.90 REF. 0.30 0.95 8.91Bottom View B 0.95 0.25 B 0.25 RECOMMENDED STENCIL OPENING RECOMMENDED STENCIL OPENING FILENAME 01 MT-G2 EasyWhite 0.95 G FILENAME 0001 MT-G2 EasyWhite PRINT 8.90 REF. 8.90 8.90 6.00 RECOMMENDED PCB FOOTPRINT RECOMMENDED PCB FOOTPRINT CENTER PAD 0.50 IS ELECTRICALLY ISOLATED 0.50 0.50 8.91 7.01 B R4.10 A 8.91 F CATHODE SIDE 6.00 R4.10 0.50 1 CENTER PADCENTER PAD IS ELECTRICALLY IS ELECTRICALLY ISOLATED ISOLATED 1.35 0.95 8.90 B 0.50 CENTERCENTER PAD PAD IS ELECTRICALLY IS ELECTRICALLY ISOLATED ISOLATED 0.50 7.00 0.65 ANODE CSIDE 8.90 CATHODE SIDE SOLDERMASK MAY BE PRESENT 1 2 8.90 C 2 3 1.35 5 6 0.50 SIDE VIEW SIDE VIEW Side View 0.30 6 TOP VIEW TOP VIEW Top View D 8.90 D © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and UNLESS OTHERWISE SPECIFIED: NAMEDATE CreeLED, Inc. DR EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 4400 SILICON DIMENSIONS ARE INOTHERWISE MILLIMETERS DURHAM, NC TLING DRAWN 27AUG22 TOLERANCES: UNLESS SPECIFIED: NAMEDATE CreeLED, A 27703 Inc. PROPRIETARY AND CONFIDENTIAL 0.5° BEND 1°CHECKEDARE IN MILLIMETERS ANGULAR: MACH DIMENSIONS •• TWO ONE PLACE 0.5 DECIMAL TITLE: TLING 27AUG22 TOLERANCES: PLACE 0.05 DECIMAL 0.5° BEND 1°DRAWN ANGULAR: MACH •• INSIDE BEND RADII EQUAL ENG APPR. •• TWO ONE PLACE 0.5 DECIMAL TITLE: MT-G2 CHECKED MATERIAL PLACE 0.05 DECIMAL MACHINE/CASTING RADII 0.50APPR. MFG APPR. •• DIA: INSIDE BEND RADII EQUAL •• RADII AND 0.10 ENG MATERIAL EASYWHITE • MACHINE/CASTING RADII 0.50 Q.A. INTERPRET GEOMETRIC MFG APPR. • RADII 0.10 DIA: TOLERANCING PER:AND THIRD ANGLE PROJECTION 4400 SILICON DR DURHAM, NC A 27703 MT-G2 CLD-DS49 REV 6 17 8.90 8.90 7.00 7.00 0.50 0.50 8.91 8.91 7.01 7.01 1.35 1.35 0.50 0.50 1.35 8.90 REF. CENTER PAD IS ELECTRICALLY ISOLATED BOTTOMB BOTTOM VIEW ALTERNATE 0.58 0.30 8.90 1.35 0.30 8.90 8.90 8.90 1.23 1.23 0.25 C C CENTER PAD IS ELECTRICALLY ISOLATED SIDE VIEW SIDE VIEW 0.25 D R4.10 R4.10 TOP VIEW TOP VIEW CATHODE SIDE CATHODE SIDE 0.58 MECHANICAL DIMENSIONS - CONTINUED D 8.90 E 9.11 9.11 XLAMP ® MT-G2 EASYWHITE ® LED E SIDE SIDE CATHODE SIDE CATHODE SIDE 8.90 ANODE SIDE ANODE SIDE B B 6.00 6.00 0.95 0.95 A 8 8 7 7 6 0.25 RECOMMENDED STENCIL OPENING Recommended Stencil Opening RECOMMENDED STENCIL OPENING RECOMMENDED PCBPCB FOOTPRINT RECOMMENDED PCB FOOTPRINT Recommended Footprint A 0.25 6 5 5 UNLESS OTHERWISE SPECIFIE NAM UNLESS OTHERWISE DIMENSIONS SPECIFIED: NAMEDATE ARE IN MILLIME DIMENSIONS ARE IN MILLIMETERS TLING 2 TOLERANCES: TLING 27AUG22 TOLERANCES: 0.5°0.5 BEND 1°DRAWN • ONE ANGULAR: MACH 0.5°0.5 BEND 1°DRAWN ANGULAR: MACH • PLACE DECIMAL CHECKED ••• TWO ONE PLACE DECIMAL TITLE: CHECKED TWO PLACE 0.05 DECIMAL PLACE 0.05 DECIMAL •• INSIDE BEND RADII EQUAL ENG APPR. • INSIDE BEND RADII EQUAL MATERIAL ENG APPR. MT-G2 MATERIAL • MACHINE/CASTING RADII 0 MFG APPR. MACHINE/CASTING •RADII RADII 0.50 AND 0.10DIA: MFG APPR. •• RADII AND 0.10DIA: Q.A.EASYWHIT GEOMETRIC Q.A. INTERPRET INTERPRET GEOMETRIC PROPRIETARY AND CONFIDENTIAL TOLERANCING PER: PROPRIETARY AND THE CONFIDENTIAL THIRD ANGLE TOLERANCING PER: THIRD ANGLE PROJECTION INFORMATION CONTAINED IN THISMATERIAL THE INFORMATION CONTAINED IN THIS MATERIAL DRAWING IS THE SOLE PROPERTY OF A DRAWING INITIATED DRAWING IS THEREPRODUCTION SOLE PROPERTY OFREPRODUCTION CREE LED. ANY IN A PART DRAWING INITIATED MATERIAL SIZEDWG. NO. CREE ANY IN MATERIAL OR AS A WHOLE WITHOUT FINISH PART LED. OR AS A WHOLE WITHOUT WRITTEN PERMISSION OF CREE LED FINISH REV DESCRIPTION WRITTEN PERMISSION OF CREE LED ISDESCRIPTION PROHIBITED. 890001 C FINISH REV IS PROHIBITED. © 2021 CreeLED,FINISH Inc. a APPLICATION subsidiary © 2021 CreeLED, a APPLICATION subsidiary of SMART Inc. of SMART Global Inc. Holdings, Inc. Global Holdings, SCALE: 10:1 WEIGHT 4 2 3 2 3 4 1 2 2 1 © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS49 REV 6 18 XLAMP ® MT-G2 EASYWHITE ® LED TAPE AND REEL All Cree LED carrier tapes conform to EIA-481D, Automated Component Handling Systems Standard. All dimensions in mm All dimensions are ±.13 mm unless otherwise indicated. Po T E Do Bo R P2 W A Anode side A F P1 B D1 "H" Ko B-B SECTION Bo (on a place in the bottom of the corner radii) Ao (on a place in the bottom of the corner radii) R "I" Ao Item Dim. Ao ITEM 9.40 Dim. Bo Ao 9.40 9.40 DETAIL"H" DETAIL"I" A-A SECTION Ko Bo Po KoP1 P2 Po 5.25 9.40 4.00 12.00 5.25 2.00 4.00 T P1 E 0.36 12.00 1.75 ITEM F Do D1 W R Dim. 7.50 1.50 1.50 16.00 5deg P2 F 2.00 7.50 TDo 1.50 0.36 D1E 1.50 1.75 W R 16.00 5° NOTICE 1) All Cree LED carrier tapes conform to EIA-481D, Automated Component handling Systems Standard 2) Measurement tolerances unless indicated otherwise: .xx = ±.15 mm 2402-M019 MTGB © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS49 REV 6 19 XLAMP ® MT-G2 EASYWHITE ® LED TAPE AND REEL - CONTINUED Feed Direction END START Trailer Loaded Pockets Leader Min. 160 mm empty pockets sealed with tape 1000 Lamps Min. 400 mm empty pockets with min. 100 mm sealed Feed Direction Cover Tape Pocket Tape 13 mm 13” © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS49 REV 6 20 XLAMP ® MT-G2 EASYWHITE ® LED PACKAGING © 2012-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS49 REV 6 21
MTGBEZ-01-0000-0N0UH030F 价格&库存
很抱歉,暂时无法提供与“MTGBEZ-01-0000-0N0UH030F”相匹配的价格&库存,您可以联系我们找货
