MLCAWT-A1-0000-0000F4
    CREELED
    SMD-4P
    LED XLAMP NEUTRAL WHT 4750K 4SMD
MLCAWT-A1-0000-0000F4 数据手册
PRODUCT FAMILY DATA SHEET XLamp® ML-C LEDs PRODUCT DESCRIPTION FEATURES The XLamp® ML-C LED brings lighting-class reliability and • Available in white (2600 K to 8300 K CCT), 80-, 85- and 90‑CRI performance to 1/3-watt LEDs. The XLamp ML-C LED expands minimum Cree LED’s lighting-class leadership to LED bulbs and linear • Available in both parallel and series and distributed lighting applications. With XLamp LED lighting- • ANSI-compatible sub-bins class reliability, a wide viewing angle, uniform light output, and • Maximum drive current: 350 mA for parallel, 175 mA for series industry‑leading chromaticity binning in a 3.5‑mm X 3.5-mm • 120° viewing angle, uniform chromaticity profile package, the XLamp ML-C LED continues Cree LED’s history • Electrically neutral thermal path of segment-focused product innovation in LEDs for lighting • RoHS and REACH compliant applications. • UL® recognized component (E349212) The XLamp ML-C LED brings high performance and a smooth look to a wide range of lighting applications, including linear lighting, fluorescent retrofits and retail-display lighting. Cree LED / 4001 E. Hwy. 54, Suite 2000 / Durham, NC 27709 USA / +1.919.313.5330 / www.cree-led.com © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 1 XLAMP ® ML-C LED TABLE OF CONTENTS Characteristics........................................................................................................................................................................................................ 3 Flux Characteristics - ML-C Parallel....................................................................................................................................................................... 4 Flux Characteristics - ML-C Series......................................................................................................................................................................... 9 Relative Spectral Power Distribution................................................................................................................................................................... 14 Relative Luminous Flux vs. Junction Temperature............................................................................................................................................. 14 Electrical Characteristics - ML-C Parallel............................................................................................................................................................ 15 Electrical Characteristics - ML-C Series.............................................................................................................................................................. 15 Relative Luminous Flux vs. Current - ML-C Parallel............................................................................................................................................ 16 Relative Luminous Flux vs. Current - ML-C Series.............................................................................................................................................. 16 Typical Spatial Distribution................................................................................................................................................................................... 17 Thermal Design - ML-C Parallel............................................................................................................................................................................ 18 Thermal Design - ML-C Series.............................................................................................................................................................................. 18 Performance Groups – Luminous Flux............................................................................................................................................................... 19 Performance Groups – Chromaticity................................................................................................................................................................... 19 Standard Cool White Kits Plotted on ANSI Standard Chromaticity Regions..................................................................................................... 23 Warm and Neutral White Kits Plotted on ANSI Standard Chromaticity Regions.............................................................................................. 25 Standard Chromaticity Kits.................................................................................................................................................................................. 27 Bin and Order Code Formats................................................................................................................................................................................ 28 Reflow Soldering Characteristics......................................................................................................................................................................... 29 Notes..................................................................................................................................................................................................................... 30 Mechanical Dimensions....................................................................................................................................................................................... 32 Tape and Reel........................................................................................................................................................................................................ 33 Packaging.............................................................................................................................................................................................................. 34 © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 2 XLAMP ® ML-C LED CHARACTERISTICS (TJ = 25 °C) Characteristics Unit Thermal resistance, junction to solder point °C/W 13 degrees 120 Temperature coefficient of voltage - parallel mV/°C -3.4 Temperature coefficient of voltage - series mV/°C -6.8 Viewing angle (FWHM) ESD classification (HBM per Mil-Std-883D) - parallel ESD withstand voltage (HBM per Mil-Std-883D) - series Minimum Typical Maximum Class 2 V 8000 DC forward current - parallel mA 350 DC forward current - series mA 175 Reverse voltage V 1 Forward voltage (@ 100 mA) - parallel V 3.2 3.4 Forward voltage (@ 50 mA) - series V 6.4 7.0 LED junction temperature °C © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 150 CLD-DS46 REV 7 3 XLAMP ® ML-C LED FLUX CHARACTERISTICS - ML-C PARALLEL (TJ = 25 °C) The following table provides order codes for XLamp ML-C LEDs. For a complete description of the order‑code nomenclature, please consult the Bin and Order Code Formats section (page 28). Chromaticity Minimum Luminous Flux (lm) @ 100 mA Kit Code Flux (lm) K3 35.2 72.6 MLCAWT-A1-00000001DT K2 30.6 63.1 MLCAWT-A1-00000000DT J3 26.8 55.2 MLCAWT-A1-0000000XDT K3 35.2 72.6 MLCAWT-A1-00000001E0 K2 30.6 63.1 MLCAWT-A1-00000000E0 J3 26.8 55.2 MLCAWT-A1-0000000XE0 K3 35.2 72.6 MLCAWT-A1-0000000151 K2 30.6 63.1 MLCAWT-A1-0000000051 J3 26.8 55.2 MLCAWT-A1-0000000X51 K3 35.2 72.6 MLCAWT-A1-00000001E1 K2 30.6 63.1 MLCAWT-A1-00000000E1 MLCAWT-H1-00000000E1 J3 26.8 55.2 MLCAWT-A1-0000000XE1 MLCAWT-H1-0000000XE1 K3 35.2 72.6 MLCAWT-A1-0000000150 K2 30.6 63.1 MLCAWT-A1-0000000050 J3 26.8 55.2 MLCAWT-A1-0000000X50 CCT DT 7000 K E0 7000 K 51 6500 K E1 6500 K 50 6200 K Calculated Minimum Luminous Flux (lm) @ 300 mA* Order Codes 75 CRI Typical 80 CRI Typical 80 CRI Minimum 85 CRI Minimum 90 CRI Minimum Notes: • • • • • • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp ML-C LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Typical CRI for Cool White (4300 K – 8300 K CCT) is 75. Typical CRI for Warm White (2600 K – 4300 K CCT) is 80. Minimum CRI for 80-CRI White is 80. Minimum CRI for 85-CRI White is 85. Minimum CRI for 90-CRI White is 90 Calculated flux values are for reference only. © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 4 XLAMP ® ML-C LED FLUX CHARACTERISTICS - ML-C PARALLEL (TJ = 25 °C) - CONTINUED Chromaticity Minimum Luminous Flux (lm) @ 100 mA Kit Code Flux (lm) K3 35.2 72.6 MLCAWT-A1-00000001DV K2 30.6 63.1 MLCAWT-A1-00000000DV J3 26.8 55.2 MLCAWT-A1-0000000XDV K3 35.2 72.6 MLCAWT-A1-00000001E2 K2 30.6 63.1 MLCAWT-A1-00000000E2 J3 26.8 55.2 MLCAWT-A1-0000000XE2 K3 35.2 72.6 MLCAWT-A1-00000001DY K2 30.6 63.1 MLCAWT-A1-00000000DY J3 26.8 55.2 MLCAWT-A1-0000000XDY K3 35.2 72.6 MLCAWT-A1-00000001DZ K2 30.6 63.1 MLCAWT-A1-00000000DZ J3 26.8 55.2 MLCAWT-A1-0000000XDZ K3 35.2 72.6 MLCAWT-A1-00000001E3 K2 30.6 63.1 MLCAWT-A1-00000000E3 MLCAWT-H1-00000000E3 J3 26.8 55.2 MLCAWT-A1-0000000XE3 MLCAWT-H1-0000000XE3 K3 35.2 72.6 MLCAWT-A1-00000001F4 K2 30.6 63.1 MLCAWT-A1-00000000F4 J3 26.8 55.2 MLCAWT-A1-0000000XF4 CCT DV 6000 K E2 5750 K DY 5500 K DZ 5000 K E3 5000 K F4 4750 K Calculated Minimum Luminous Flux (lm) @ 300 mA* Order Codes 75 CRI Typical 80 CRI Typical 80 CRI Minimum 85 CRI Minimum 90 CRI Minimum Notes: • • • • • • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp ML-C LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Typical CRI for Cool White (4300 K – 8300 K CCT) is 75. Typical CRI for Warm White (2600 K – 4300 K CCT) is 80. Minimum CRI for 80-CRI White is 80. Minimum CRI for 85-CRI White is 85. Minimum CRI for 90-CRI White is 90 Calculated flux values are for reference only. © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 5 XLAMP ® ML-C LED FLUX CHARACTERISTICS - ML-C PARALLEL (TJ = 25 °C) - CONTINUED Chromaticity Minimum Luminous Flux (lm) @ 100 mA Kit Code Flux (lm) K3 35.2 K2 30.6 63.1 MLCAWT-A1-00000000E4 J3 26.8 55.2 MLCAWT-A1-0000000XE4 K2 30.6 63.1 MLCAWT-A1-00000000F5 J3 26.8 55.2 MLCAWT-A1-0000000XF5 K2 30.6 63.1 MLCAWT-A1-00000000E5 MLCAWT-H1-00000000E5 J3 26.8 55.2 MLCAWT-A1-0000000XE5 MLCAWT-H1-0000000XE5 J2 23.5 23.5 H0 18.1 18.1 K2 30.6 63.1 MLCAWT-A1-00000000Z5 MLCAWT-H1-00000000Z5 J3 26.8 55.2 MLCAWT-A1-0000000XZ5 MLCAWT-H1-0000000XZ5 J2 23.5 23.5 H0 18.1 18.1 K2 30.6 63.1 MLCAWT-A1-00000000F6 MLCAWT-H1-00000000F6 J3 26.8 55.2 MLCAWT-A1-0000000XF6 MLCAWT-H1-0000000XF6 J2 23.5 23.5 MLCAWT-H1-0000000WF6 MLCAWT-P1-0000000WF6 MLCAWT-U1-0000000WF6 H0 18.1 18.1 MLCAWT-H1-0000000VF6 MLCAWT-P1-0000000VF6 MLCAWT-U1-0000000VF6 CCT E4 4500 K F5 Calculated Minimum Luminous Flux (lm) @ 300 mA* 72.6 4250 K E5 4000 K Z5 4000 K F6 3750 K Order Codes 75 CRI Typical 80 CRI Typical 80 CRI Minimum 85 CRI Minimum 90 CRI Minimum MLCAWT-P1-0000000WE5 MLCAWT-U1-0000000WE5 MLCAWT-A1-00000001E4 MLCAWT-H1-0000000WE5 MLCAWT-U1-0000000VE5 MLCAWT-H1-0000000WZ5 MLCAWT-P1-0000000WZ5 MLCAWT-U1-0000000WZ5 MLCAWT-U1-0000000VZ5 Notes: • • • • • • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp ML-C LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Typical CRI for Cool White (4300 K – 8300 K CCT) is 75. Typical CRI for Warm White (2600 K – 4300 K CCT) is 80. Minimum CRI for 80-CRI White is 80. Minimum CRI for 85-CRI White is 85. Minimum CRI for 90-CRI White is 90 Calculated flux values are for reference only. © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 6 XLAMP ® ML-C LED FLUX CHARACTERISTICS - ML-C PARALLEL (TJ = 25 °C) - CONTINUED Chromaticity Minimum Luminous Flux (lm) @ 100 mA Kit Code Flux (lm) K2 30.6 J3 CCT E6 Calculated Minimum Luminous Flux (lm) @ 300 mA* 80 CRI Typical 80 CRI Minimum 63.1 MLCAWT-A1-00000000E6 MLCAWT-H1-00000000E6 26.8 55.2 MLCAWT-A1-0000000XE6 MLCAWT-H1-0000000XE6 J2 23.5 23.5 H0 18.1 18.1 K2 30.6 63.1 MLCAWT-A1-00000000Z6 MLCAWT-H1-00000000Z6 J3 26.8 55.2 MLCAWT-A1-0000000XZ6 MLCAWT-H1-0000000XZ6 J2 23.5 23.5 H0 18.1 18.1 K2 30.6 63.1 MLCAWT-A1-00000000F7 MLCAWT-H1-00000000F7 J3 26.8 55.2 MLCAWT-A1-0000000XF7 MLCAWT-H1-0000000XF7 J2 23.5 23.5 MLCAWT-A1-0000000WF7 H0 18.1 18.1 K2 30.6 63.1 MLCAWT-A1-00000000E7 MLCAWT-H1-00000000E7 J3 26.8 55.2 MLCAWT-A1-0000000XE7 MLCAWT-H1-0000000XE7 J2 23.5 23.5 MLCAWT-A1-0000000WE7 H0 18.1 18.1 3500 K Z6 3500 K F7 3250 K E7 Order Codes 3000 K 75 CRI Typical 85 CRI Minimum 90 CRI Minimum MLCAWT-H1-0000000WE6 MLCAWT-P1-0000000WE6 MLCAWT-U1-0000000WE6 MLCAWT-H1-0000000VE6 MLCAWT-P1-0000000VE6 MLCAWT-U1-0000000VE6 MLCAWT-H1-0000000WZ6 MLCAWT-P1-0000000WZ6 MLCAWT-U1-0000000WZ6 MLCAWT-H1-0000000VZ6 MLCAWT-P1-0000000VZ6 MLCAWT-U1-0000000VZ6 MLCAWT-H1-0000000WF7 MLCAWT-P1-0000000WF7 MLCAWT-U1-0000000WF7 MLCAWT-H1-0000000VF7 MLCAWT-P1-0000000VF7 MLCAWT-U1-0000000VF7 MLCAWT-H1-0000000WE7 MLCAWT-P1-0000000WE7 MLCAWT-U1-0000000WE7 MLCAWT-H1-0000000VE7 MLCAWT-P1-0000000VE7 MLCAWT-U1-0000000VE7 Notes: • • • • • • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp ML-C LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Typical CRI for Cool White (4300 K – 8300 K CCT) is 75. Typical CRI for Warm White (2600 K – 4300 K CCT) is 80. Minimum CRI for 80-CRI White is 80. Minimum CRI for 85-CRI White is 85. Minimum CRI for 90-CRI White is 90 Calculated flux values are for reference only. © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 7 XLAMP ® ML-C LED FLUX CHARACTERISTICS - ML-C PARALLEL (TJ = 25 °C) - CONTINUED Chromaticity Minimum Luminous Flux (lm) @ 100 mA Kit Code Flux (lm) K2 30.6 J3 CCT Z7 Calculated Minimum Luminous Flux (lm) @ 300 mA* 80 CRI Typical 80 CRI Minimum 63.1 MLCAWT-A1-00000000Z7 MLCAWT-H1-00000000Z7 26.8 55.2 MLCAWT-A1-0000000XZ7 MLCAWT-H1-0000000XZ7 J2 23.5 23.5 MLCAWT-A1-0000000WZ7 H0 18.1 18.1 J3 26.8 55.2 MLCAWT-A1-0000000XF8 MLCAWT-H1-0000000XF8 J2 23.5 23.5 MLCAWT-A1-0000000WF8 H0 18.1 18.1 J3 26.8 55.2 MLCAWT-A1-0000000XE8 MLCAWT-H1-0000000XE8 J2 23.5 23.5 MLCAWT-A1-0000000WE8 H0 18.1 18.1 J3 26.8 55.2 MLCAWT-A1-0000000XZ8 MLCAWT-H1-0000000XZ8 J2 23.5 23.5 MLCAWT-A1-0000000WZ8 H0 18.1 18.1 3000 K F8 2850 K E8 2700 K Z8 2700 K Order Codes 75 CRI Typical 85 CRI Minimum 90 CRI Minimum MLCAWT-H1-0000000WZ7 MLCAWT-P1-0000000WZ7 MLCAWT-U1-0000000WZ7 MLCAWT-H1-0000000VZ7 MLCAWT-P1-0000000VZ7 MLCAWT-U1-0000000VZ7 MLCAWT-H1-0000000WF8 MLCAWT-P1-0000000WF8 MLCAWT-U1-0000000WF8 MLCAWT-H1-0000000VF8 MLCAWT-P1-0000000VF8 MLCAWT-U1-0000000VF8 MLCAWT-H1-0000000WE8 MLCAWT-P1-0000000WE8 MLCAWT-U1-0000000WE8 MLCAWT-H1-0000000VE8 MLCAWT-P1-0000000VE8 MLCAWT-U1-0000000VE8 MLCAWT-H1-0000000WZ8 MLCAWT-P1-0000000WZ8 MLCAWT-U1-0000000WZ8 MLCAWT-H1-0000000VZ8 MLCAWT-P1-0000000VZ8 MLCAWT-U1-0000000VZ8 Notes: • • • • • • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp ML-C LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Typical CRI for Cool White (4300 K – 8300 K CCT) is 75. Typical CRI for Warm White (2600 K – 4300 K CCT) is 80. Minimum CRI for 80-CRI White is 80. Minimum CRI for 85-CRI White is 85. Minimum CRI for 90-CRI White is 90 Calculated flux values are for reference only. © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 8 XLAMP ® ML-C LED FLUX CHARACTERISTICS - ML-C SERIES (TJ = 25 °C) The following table provides order codes for XLamp ML-C LEDs. For a complete description of the order‑code nomenclature, please consult the Bin and Order Code Formats section (page 28). Chromaticity Minimum Luminous Flux (lm) @ 100 mA Kit Code Flux (lm) K3 35.2 72.6 MLCSWT-A1-00000001DT K2 30.6 63.1 MLCSWT-A1-00000000DT J3 26.8 55.2 MLCSWT-A1-0000000XDT K3 35.2 72.6 MLCSWT-A1-00000001E0 K2 30.6 63.1 MLCSWT-A1-00000000E0 J3 26.8 55.2 MLCSWT-A1-0000000XE0 K3 35.2 72.6 MLCSWT-A1-0000000151 K2 30.6 63.1 MLCSWT-A1-0000000051 J3 26.8 55.2 MLCSWT-A1-0000000X51 K3 35.2 72.6 MLCSWT-A1-00000001E1 K2 30.6 63.1 MLCSWT-A1-00000000E1 MLCSWT-H1-00000000E1 J3 26.8 55.2 MLCSWT-A1-0000000XE1 MLCSWT-H1-0000000XE1 K3 35.2 72.6 MLCSWT-A1-0000000150 K2 30.6 63.1 MLCSWT-A1-0000000050 J3 26.8 55.2 MLCSWT-A1-0000000X50 CCT DT 7000 K E0 7000 K 51 6500 K E1 6500 K 50 6200 K Calculated Minimum Luminous Flux (lm) @ 300 mA* Order Codes 75 CRI Typical 80 CRI Typical 80 CRI Minimum 85 CRI Minimum 90 CRI Minimum Notes: • • • • • • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp ML-C LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Typical CRI for Cool White (4300 K – 8300 K CCT) is 75. Typical CRI for Warm White (2600 K – 4300 K CCT) is 80. Minimum CRI for 80-CRI White is 80. Minimum CRI for 85-CRI White is 85. Minimum CRI for 90-CRI White is 90 Calculated flux values are for reference only. © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 9 XLAMP ® ML-C LED FLUX CHARACTERISTICS - ML-C SERIES (TJ = 25 °C) - CONTINUED Chromaticity Minimum Luminous Flux (lm) @ 100 mA Kit Code Flux (lm) K3 35.2 72.6 MLCSWT-A1-00000001DV K2 30.6 63.1 MLCSWT-A1-00000000DV J3 26.8 55.2 MLCSWT-A1-0000000XDV K3 35.2 72.6 MLCSWT-A1-00000001E2 K2 30.6 63.1 MLCSWT-A1-00000000E2 J3 26.8 55.2 MLCSWT-A1-0000000XE2 K3 35.2 72.6 MLCSWT-A1-00000001DY K2 30.6 63.1 MLCSWT-A1-00000000DY J3 26.8 55.2 MLCSWT-A1-0000000XDY K3 35.2 72.6 MLCSWT-A1-00000001DZ K2 30.6 63.1 MLCSWT-A1-00000000DZ J3 26.8 55.2 MLCSWT-A1-0000000XDZ K3 35.2 72.6 MLCSWT-A1-00000001E3 K2 30.6 63.1 MLCSWT-A1-00000000E3 MLCSWT-H1-00000000E3 J3 26.8 55.2 MLCSWT-A1-0000000XE3 MLCSWT-H1-0000000XE3 K3 35.2 72.6 MLCSWT-A1-00000001F4 K2 30.6 63.1 MLCSWT-A1-00000000F4 J3 26.8 55.2 MLCSWT-A1-0000000XF4 CCT DV 6000 K E2 5750 K DY 5500 K DZ 5000 K E3 5000 K F4 4750 K Calculated Minimum Luminous Flux (lm) @ 300 mA* Order Codes 75 CRI Typical 80 CRI Typical 80 CRI Minimum 85 CRI Minimum 90 CRI Minimum Notes: • • • • • • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp ML-C LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Typical CRI for Cool White (4300 K – 8300 K CCT) is 75. Typical CRI for Warm White (2600 K – 4300 K CCT) is 80. Minimum CRI for 80-CRI White is 80. Minimum CRI for 85-CRI White is 85. Minimum CRI for 90-CRI White is 90 Calculated flux values are for reference only. © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 10 XLAMP ® ML-C LED FLUX CHARACTERISTICS - ML-C SERIES (TJ = 25 °C) - CONTINUED Chromaticity Minimum Luminous Flux (lm) @ 100 mA Kit Code Flux (lm) K3 35.2 72.6 MLCSWT-A1-00000001E4 K2 30.6 63.1 MLCSWT-A1-00000000E4 J3 26.8 55.2 MLCSWT-A1-0000000XE4 K2 30.6 63.1 MLCSWT-A1-00000000F5 J3 26.8 55.2 MLCSWT-A1-0000000XF5 K2 30.6 63.1 MLCSWT-A1-00000000E5 MLCSWT-H1-00000000E5 J3 26.8 55.2 MLCSWT-A1-0000000XE5 MLCSWT-H1-0000000XE5 J2 23.5 23.5 H0 18.1 18.1 K2 30.6 63.1 MLCSWT-A1-00000000Z5 MLCSWT-H1-00000000Z5 J3 26.8 55.2 MLCSWT-A1-0000000XZ5 MLCSWT-H1-0000000XZ5 J2 23.5 23.5 H0 18.1 18.1 K2 30.6 63.1 MLCSWT-A1-00000000F6 MLCSWT-H1-00000000F6 J3 26.8 55.2 MLCSWT-A1-0000000XF6 MLCSWT-H1-0000000XF6 J2 23.5 23.5 MLCSWT-H1-0000000WF6 MLCSWT-P1-0000000WF6 MLCSWT-U1-0000000WF6 H0 18.1 18.1 MLCSWT-H1-0000000VF6 MLCSWT-P1-0000000VF6 MLCSWT-U1-0000000VF6 CCT E4 4500 K F5 Calculated Minimum Luminous Flux (lm) @ 300 mA* 4250 K E5 4000 K Z5 4000 K F6 3750 K Order Codes 75 CRI Typical 80 CRI Typical 80 CRI Minimum MLCSWT-H1-0000000WE5 85 CRI Minimum 90 CRI Minimum MLCSWT-P1-0000000WE5 MLCSWT-U1-0000000WE5 MLCSWT-U1-0000000VE5 MLCSWT-H1-0000000WZ5 MLCSWT-P1-0000000WZ5 MLCSWT-U1-0000000WZ5 MLCSWT-U1-0000000VZ5 Notes: • • • • • • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp ML-C LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Typical CRI for Cool White (4300 K – 8300 K CCT) is 75. Typical CRI for Warm White (2600 K – 4300 K CCT) is 80. Minimum CRI for 80-CRI White is 80. Minimum CRI for 85-CRI White is 85. Minimum CRI for 90-CRI White is 90 Calculated flux values are for reference only. © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 11 XLAMP ® ML-C LED FLUX CHARACTERISTICS - ML-C SERIES (TJ = 25 °C) - CONTINUED Chromaticity Minimum Luminous Flux (lm) @ 100 mA Kit Code Flux (lm) K2 30.6 J3 CCT E6 Calculated Minimum Luminous Flux (lm) @ 300 mA* 80 CRI Typical 80 CRI Minimum 63.1 MLCSWT-A1-00000000E6 MLCSWT-H1-00000000E6 26.8 55.2 MLCSWT-A1-0000000XE6 MLCSWT-H1-0000000XE6 J2 23.5 23.5 H0 18.1 18.1 K2 30.6 63.1 MLCSWT-A1-00000000Z6 MLCSWT-H1-00000000Z6 J3 26.8 55.2 MLCSWT-A1-0000000XZ6 MLCSWT-H1-0000000XZ6 J2 23.5 23.5 H0 18.1 18.1 K2 30.6 63.1 MLCSWT-A1-00000000F7 MLCSWT-H1-00000000F7 J3 26.8 55.2 MLCSWT-A1-0000000XF7 MLCSWT-H1-0000000XF7 J2 23.5 23.5 MLCSWT-A1-0000000WF7 H0 18.1 18.1 K2 30.6 63.1 MLCSWT-A1-00000000E7 MLCSWT-H1-00000000E7 J3 26.8 55.2 MLCSWT-A1-0000000XE7 MLCSWT-H1-0000000XE7 J2 23.5 23.5 MLCSWT-A1-0000000WE7 H0 18.1 18.1 K2 30.6 63.1 MLCSWT-A1-00000000Z7 MLCSWT-H1-00000000Z7 J3 26.8 55.2 MLCSWT-A1-0000000XZ7 MLCSWT-H1-0000000XZ7 J2 23.5 23.5 MLCSWT-A1-0000000WZ7 H0 18.1 18.1 3500 K Z6 3500 K F7 3250 K E7 3000 K Z7 Order Codes 3000 K 75 CRI Typical 85 CRI Minimum 90 CRI Minimum MLCSWT-H1-0000000WE6 MLCSWT-P1-0000000WE6 MLCSWT-U1-0000000WE6 MLCSWT-H1-0000000VE6 MLCSWT-P1-0000000VE6 MLCSWT-U1-0000000VE6 MLCSWT-H1-0000000WZ6 MLCSWT-P1-0000000WZ6 MLCSWT-U1-0000000WZ6 MLCSWT-H1-0000000VZ6 MLCSWT-P1-0000000VZ6 MLCSWT-U1-0000000VZ6 MLCSWT-H1-0000000WF7 MLCSWT-P1-0000000WF7 MLCSWT-U1-0000000WF7 MLCSWT-H1-0000000VF7 MLCSWT-P1-0000000VF7 MLCSWT-U1-0000000VF7 MLCSWT-H1-0000000WE7 MLCSWT-P1-0000000WE7 MLCSWT-U1-0000000WE7 MLCSWT-H1-0000000VE7 MLCSWT-P1-0000000VE7 MLCSWT-U1-0000000VE7 MLCSWT-H1-0000000WZ7 MLCSWT-P1-0000000WZ7 MLCSWT-U1-0000000WZ7 MLCSWT-H1-0000000VZ7 MLCSWT-P1-0000000VZ7 MLCSWT-U1-0000000VZ7 Notes: • • • • • • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp ML-C LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Typical CRI for Cool White (4300 K – 8300 K CCT) is 75. Typical CRI for Warm White (2600 K – 4300 K CCT) is 80. Minimum CRI for 80-CRI White is 80. Minimum CRI for 85-CRI White is 85. Minimum CRI for 90-CRI White is 90 Calculated flux values are for reference only. © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 12 XLAMP ® ML-C LED FLUX CHARACTERISTICS - ML-C SERIES (TJ = 25 °C) - CONTINUED Chromaticity Minimum Luminous Flux (lm) @ 100 mA Kit Code Flux (lm) J3 26.8 J2 CCT F8 2850 K E8 2700 K Z8 2700 K Calculated Minimum Luminous Flux (lm) @ 300 mA* Order Codes 75 CRI Typical 80 CRI Typical 80 CRI Minimum 85 CRI Minimum 90 CRI Minimum 55.2 MLCSWT-A1-0000000XF8 MLCSWT-H1-0000000XF8 23.5 23.5 MLCSWT-A1-0000000WF8 MLCSWT-H1-0000000WF8 MLCSWT-P1-0000000WF8 MLCSWT-U1-0000000WF8 H0 18.1 18.1 MLCSWT-H1-0000000VF8 MLCSWT-P1-0000000VF8 MLCSWT-U1-0000000VF8 J3 26.8 55.2 MLCSWT-A1-0000000XE8 MLCSWT-H1-0000000XE8 J2 23.5 23.5 MLCSWT-A1-0000000WE8 MLCSWT-H1-0000000WE8 MLCSWT-P1-0000000WE8 MLCSWT-U1-0000000WE8 H0 18.1 18.1 MLCSWT-H1-0000000VE8 MLCSWT-P1-0000000VE8 MLCSWT-U1-0000000VE8 J3 26.8 55.2 MLCSWT-A1-0000000XZ8 MLCSWT-H1-0000000XZ8 J2 23.5 23.5 MLCSWT-A1-0000000WZ8 MLCSWT-H1-0000000WZ8 MLCSWT-P1-0000000WZ8 MLCSWT-U1-0000000WZ8 H0 18.1 18.1 MLCSWT-H1-0000000VZ8 MLCSWT-P1-0000000VZ8 MLCSWT-U1-0000000VZ8 Notes: • • • • • • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 30). XLamp ML-C LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Typical CRI for Cool White (4300 K – 8300 K CCT) is 75. Typical CRI for Warm White (2600 K – 4300 K CCT) is 80. Minimum CRI for 80-CRI White is 80. Minimum CRI for 85-CRI White is 85. Minimum CRI for 90-CRI White is 90 Calculated flux values are for reference only. © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 13 XLAMP ® ML-C LED Relative Spectral Power ML-B OK RELATIVE SPECTRAL POWER DISTRIBUTION Relative Radiant Power (%) 100 80 60 5000 K - 8300 K CCT 3500 K - 5000 K CCT 2600 K - 3500 K CCT 40 20 0 380 430 480 530 580 630 680 730 780 Wavelength (nm) RELATIVE LUMINOUS FLUX VS. JUNCTION TEMPERATURE - ML-C PARALLEL: IF = 100 mA, ML-C SERIES: IF = 50 mA 120% Relative Luminous Flux 100% 80% 60% 40% 20% 0% 25 50 75 100 125 150 Junction Temperature (ºC) © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 14 XLAMP ® ML-C LED ELECTRICAL CHARACTERISTICS - ML-C PARALLEL (TJ = 25 °C) 350 Forward Current (mA) 300 250 200 150 100 50 0 2.9 3.1 3.3 3.5 3.7 3.9 Forward Voltage (V) ELECTRICAL CHARACTERISTICS - ML-C SERIES (TJ = 25 °C) 175 Forward Current (mA) 150 125 100 75 50 25 0 5.9 6.4 6.9 7.4 7.9 Forward Voltage (V) © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 15 XLAMP ® ML-C LED RELATIVE LUMINOUS FLUX VS. CURRENT - ML-C PARALLEL (TJ = 25 °C) 300% Relative Luminous Flux 250% 200% 150% 100% 50% 0% 0 50 100 150 200 250 300 350 125 150 175 Forward Current (mA) RELATIVE LUMINOUS FLUX VS. CURRENT - ML-C SERIES (TJ = 25 °C) 300% Relative Luminous Flux 250% 200% 150% 100% 50% 0% 0 25 50 75 100 Forward Current (mA) © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 16 XLAMP ® ML-C LED TYPICAL SPATIAL DISTRIBUTION 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 17 XLAMP ® ML-C LED THERMAL DESIGN - ML-C PARALLEL The maximum forward current is determined by the thermal resistance between the LED junction and ambient. It is crucial for the end product to be designed in a manner that minimizes the thermal resistance from the solder point to ambient in order to optimize lamp life and optical characteristics. 400 350 Maximum Current (mA) 300 250 200 150 100 Rj-a = 20°C/W Rj-a = 30°C/W 50 Rj-a = 40°C/W Rj-a = 50°C/W 0 0 20 40 60 80 100 120 140 160 100 120 140 160 Ambient Temperature (ºC) THERMAL DESIGN - ML-C SERIES 200 180 Maximum Current (mA) 160 140 120 100 80 60 Rj-a = 20°C/W Rj-a = 30°C/W 40 Rj-a = 40°C/W 20 0 Rj-a = 50°C/W 0 20 40 60 80 Ambient Temperature (ºC) © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 18 XLAMP ® ML-C LED PERFORMANCE GROUPS – LUMINOUS FLUX White XLamp ML-C LEDs are tested for luminous flux and placed into one of the following luminous-flux groups: Group Code Minimum Luminous Flux (lm) Maximum Luminous Flux (lm) H0* 18.1 23.5 J0* H2 H3 18.1 20.6 23.5 J2 J3 20.6 23.5 30.6 23.5 26.8 K2 30.6 35.2 K3 35.2 39.8 M2 39.8 45.7 26.8 30.6 Notes: • Flux codes H0 and J0 are further subdivided into H2, H3 and J2, J3, respectively. Orders for the H0 flux code may be filled with H2 or H3 sub-codes and orders for the J0 flux code may be filled with J2 or J3 sub-codes. PERFORMANCE GROUPS – CHROMATICITY Region 0A 0R 1A 1R 2A x y 0.2950 0.2970 0.2920 0.3060 0.2984 0.3133 0.3009 0.3042 0.2980 0.2950 0.3009 0.3042 0.3037 0.3048 0.3130 0.3290 0.3144 0.3186 0.3068 Region x y 0.2920 0.3060 0.2895 0.3135 0.2962 0.3220 0.2984 0.3133 0.2880 0.2895 0.2970 0.2870 0.2937 0.3312 0.2937 0.2962 0.3207 0.3028 0.3115 0.3391 0.3130 0.3290 0.3113 0.3048 0.3068 0.3113 0.3144 0.3186 0.3161 0.3059 0.3093 0.2993 0.3215 0.3350 0.3290 0.3417 0.3290 0.3300 0.3222 0.3243 0B 0S 1B 1S 2B Region x y 0.2984 0.3133 0.2962 0.3220 0.3028 0.3304 0.3048 0.3207 0.3135 0.2962 0.3210 0.2937 0.3005 0.3415 0.3220 0.3028 0.3304 0.3115 0.3205 0.3481 0.3213 0.3373 0.3207 0.3130 0.3290 0.3005 0.3415 0.3099 0.3099 0.3509 0.3196 0.3115 0.3391 0.3205 0.3481 0.3028 0.3304 0.3115 0.3391 0.3207 0.3462 0.3290 0.3538 0.3290 0.3538 0.3376 0.3616 0.3290 0.3417 0.3371 0.3490 0.3215 0.3350 0.3290 0.3417 0C 0T 1C 1T 2C x y 0.2984 0.3133 0.3048 0.3207 0.3068 0.3113 0.3009 0.3042 0.3220 0.3037 0.2937 0.3312 0.3009 0.3042 0.3068 0.3113 0.3304 0.3093 0.2993 0.3391 0.3130 0.3290 0.3213 0.3373 0.3221 0.3261 0.3144 0.3186 0.3509 0.3144 0.3186 0.3602 0.3221 0.3261 0.3231 0.3120 0.3161 0.3059 0.3290 0.3417 0.3371 0.3490 0.3366 0.3369 0.3290 0.3300 © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Region 0D 0U 1D 1U 2D CLD-DS46 REV 7 19 XLAMP ® ML-C LED PERFORMANCE GROUPS – CHROMATICITY (CONTINUED) Region 2R 3A 3R 4A 4R 5A1 5B1 5C1 5D1 6A1 x y 0.3222 0.3243 0.3290 0.3300 0.3290 0.3180 0.3231 0.3120 0.3371 0.3451 0.3440 0.3427 0.3366 0.3366 0.3440 0.3428 0.3429 0.3307 0.3361 Region x y 0.3196 0.3602 x y 0.3290 0.3690 0.3290 0.3690 0.3381 0.3762 0.3290 0.3538 0.3207 0.3462 0.3376 0.3616 0.3290 0.3538 0.3490 0.3376 0.3554 0.3463 0.3616 0.3463 0.3687 0.3551 0.3451 0.3554 0.3533 0.3620 0.3369 0.3371 0.3369 0.3381 0.3490 0.3451 0.3762 0.3480 0.3480 0.3840 0.3463 0.3687 0.3571 0.3907 0.3551 0.3760 0.3245 0.3376 0.3616 0.3463 0.3687 0.3530 0.3597 0.3615 0.3659 0.3548 0.3736 0.3641 0.3641 0.3804 0.3736 0.3590 0.3521 0.3512 0.3465 0.3615 0.3659 0.3702 0.3722 0.3530 0.3597 0.3615 0.3659 0.3512 0.3465 0.3571 0.3907 0.3668 0.3957 0.3590 0.3521 0.3567 0.3389 0.3668 0.3957 0.3771 0.4034 0.3641 0.3804 0.3736 0.3874 0.3495 0.3670 0.3339 0.3548 0.3736 0.3641 0.3578 0.3686 0.3649 0.3744 0.3686 0.3649 0.3702 0.3722 0.3763 0.3760 0.3744 0.3685 0.3726 0.3612 0.3763 0.3760 0.3825 0.3798 0.3744 0.3685 0.3804 0.3721 0.3702 0.3719 0.3722 0.3719 0.3797 0.3782 0.3797 0.3736 0.3874 0.3802 0.3782 0.3837 0.3763 0.3760 0.3802 0.3916 0.3869 0.3958 0.3782 0.3837 0.3847 0.3877 0.3825 0.3798 0.3847 0.3877 0.3912 0.3917 0.3847 0.3877 0.3912 0.3917 0.3869 0.3958 0.3937 0.4001 0.3937 0.4001 0.4006 0.4044 0.3887 0.3783 0.3836 0.3912 0.3917 0.3978 0.3646 0.3804 0.3721 0.3863 0.3804 0.3721 0.3825 0.3798 0.3887 0.3836 0.3863 0.3758 0.3840 0.3681 0.3887 0.3836 0.3950 0.3875 0.3863 0.3758 0.3924 0.3794 0.3889 0.3915 0.3690 0.3915 0.3768 0.3981 0.3768 0.3941 0.3848 0.4010 0.3981 0.3800 0.4010 0.3882 0.4080 0.3916 0.3953 0.3720 0.3981 0.3800 0.4048 0.3832 2S 3B 3S 4B 4S 5A2 5B2 5C2 5D2 6A2 Region 2T 3C 3T 4C 4T 5A3 5B3 5C3 5D3 6A3 x y 0.3290 0.3300 0.3366 0.3369 0.3361 0.3245 0.3290 0.3180 0.3687 0.3451 0.3554 0.3760 0.3533 0.3620 0.3515 0.3487 0.3554 0.3440 0.3427 0.3840 0.3440 0.3428 0.3515 0.3487 0.3495 0.3339 0.3429 0.3307 0.3804 0.3615 0.3659 0.3874 0.3702 0.3722 0.3670 0.3578 0.3590 0.3521 0.3590 0.3521 0.3670 0.3578 0.3640 0.3440 0.3804 0.3567 0.3389 0.3685 0.3726 0.3612 0.3744 0.3685 0.3804 0.3721 0.3783 0.3646 0.3837 0.3763 0.3760 0.3916 0.3782 0.3837 0.3847 0.3877 0.3825 0.3798 0.3887 0.3836 0.3912 0.3917 0.3978 0.3958 0.3958 0.3950 0.3875 0.3758 0.3840 0.3681 0.3863 0.3758 0.3924 0.3794 0.3898 0.3716 0.3800 0.3953 0.3720 0.3882 0.3981 0.3800 0.4048 0.3832 0.4017 0.3751 © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Region 2U 3D 3U 4D 4U 5A4 5B4 5C4 5D4 6A4 CLD-DS46 REV 7 20 XLAMP ® ML-C LED PERFORMANCE GROUPS – CHROMATICITY (CONTINUED) Region 6B1 6C1 6D1 7A1 7B1 7C1 7D1 8A1 8B1 8C1 x y 0.3941 0.3848 0.3968 0.3930 0.4040 0.3966 0.4010 0.3882 0.4080 0.4113 0.4186 0.4037 0.4150 0.4017 0.4048 0.3832 0.4116 0.3865 0.4082 Region x y 0.3968 0.3930 x y 0.4040 0.3966 0.3996 0.4015 0.4071 0.4052 0.4071 0.4052 0.4040 0.3966 0.4146 0.4089 0.4113 0.4001 0.3916 0.4113 0.4001 0.4146 0.4001 0.4186 0.4089 0.4222 0.4222 0.4127 0.4299 0.4165 0.3950 0.4186 0.3751 0.4048 0.4037 0.4259 0.3832 0.4116 0.4080 0.3916 0.4150 0.3950 0.4150 0.3950 0.4221 0.3984 0.3782 0.4116 0.3865 0.4183 0.3898 0.4147 0.3814 0.4183 0.3898 0.4183 0.3898 0.4242 0.4221 0.3984 0.4281 0.4242 0.3919 0.4203 0.3833 0.4281 0.4006 0.4342 0.4028 0.4242 0.3919 0.4300 0.3939 0.4221 0.3984 0.4259 0.4073 0.4322 0.4096 0.4259 0.4073 0.4322 0.4096 0.4299 0.4165 0.4364 0.4188 0.4364 0.4188 0.4430 0.4212 0.4281 0.4342 0.4006 0.4322 0.4096 0.4385 0.4028 0.4385 0.4119 0.4449 0.4385 0.4119 0.4430 0.4212 0.4496 0.4236 0.4449 0.4141 0.4403 0.4049 0.4496 0.4236 0.4562 0.4260 0.4449 0.4141 0.4513 0.4164 0.4259 0.4300 0.3853 0.4300 0.3939 0.4359 0.3939 0.4342 0.4028 0.4403 0.4359 0.3960 0.4316 0.3873 0.4403 0.4049 0.4465 0.4071 0.4359 0.3960 0.4418 0.3981 0.4373 0.3893 0.4418 0.3981 0.4475 0.3994 0.4418 0.3981 0.4475 0.3994 0.4465 0.4071 0.4523 0.4085 0.4523 0.4085 0.4582 0.4099 0.4428 0.4465 0.3906 0.4475 0.3994 0.4532 0.4071 0.4513 0.4164 0.4573 0.4513 0.4164 0.4562 0.4260 0.4624 0.4274 0.4573 0.4178 0.4523 0.4085 0.4624 0.4274 0.4687 0.4289 0.4573 0.4178 0.4634 0.4193 0.4582 0.4634 0.4099 0.4634 0.4193 0.4695 0.4193 0.4687 0.4289 0.4750 0.4695 0.4207 0.4750 0.4304 0.4813 0.4319 0.4641 0.4112 0.4695 0.4207 0.4756 0.4221 6B2 6C2 6D2 7A2 7B2 7C2 7D2 8A2 8B2 8C2 Region 6B3 6C3 6D3 7A3 7B3 7C3 7D3 8A3 8B3 8C3 x y 0.4010 0.3882 0.4040 0.3966 0.4113 0.4001 0.4080 0.3916 0.4037 0.4150 0.3950 0.4127 0.4186 0.4037 0.4259 0.4073 0.4073 0.4221 0.3984 0.3865 0.4082 0.3782 0.4116 0.3865 0.4183 0.3898 0.4147 0.3814 0.3919 0.4203 0.3833 0.4006 0.4242 0.3919 0.4300 0.3939 0.4259 0.3853 0.4281 0.4006 0.4322 0.4096 0.4385 0.4119 0.4119 0.4342 0.4028 0.4141 0.4403 0.4049 0.4449 0.4141 0.4513 0.4164 0.4465 0.4071 0.3960 0.4316 0.3873 0.4049 0.4359 0.3960 0.4418 0.3981 0.4373 0.3893 0.4428 0.3906 0.4475 0.3994 0.4532 0.4008 0.4008 0.4483 0.3919 0.4178 0.4523 0.4085 0.4573 0.4178 0.4634 0.4193 0.4582 0.4099 0.4207 0.4641 0.4112 0.4304 0.4695 0.4207 0.4756 0.4221 0.4700 0.4126 © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Region 6B4 6C4 6D4 7A4 7B4 7C4 7D4 8A4 8B4 8C4 CLD-DS46 REV 7 21 XLAMP ® ML-C LED PERFORMANCE GROUPS – CHROMATICITY (CONTINUED) Region 8D1 x y 0.4483 0.3919 0.4532 0.4008 0.4589 0.4021 0.4538 0.3931 Region 8D2 x y 0.4532 0.4008 0.4582 0.4099 0.4641 0.4112 0.4589 0.4021 Region 8D3 x y 0.4589 0.4021 0.4641 0.4112 0.4700 0.4126 0.4646 0.4034 © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Region 8D4 x y 0.4538 0.3931 0.4589 0.4021 0.4646 0.4034 0.4593 0.3944 CLD-DS46 REV 7 22 XLAMP ® ML-C LED STANDARD COOL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.40 0.40 5000 K 0.39 0.38 0.38 5700 K 0.37 6500 K DT 1T 0.34 0T 0C 0B 0A ANSI C78.377A 2R 1A 1U 0D 0.31 1R 0R 1R 0A 0U 0.36 0.35 0.34 0.33 0.32 0.28 0.36 0.35 0.34 0.33 0.32 0.31 0.28 0.30 0.28 0.29 1U 0R 0.29 CCx 0.40 0.40 5000 K 0.39 0.38 0.38 DV 6500 K 0.36 0.36 1T 0C 0B 0.31 2A 1B 0S 0.32 1D 2U 1U 0S 2D 1C 0C 1D 2U ANSI C78.377A 2R 1A 1U 0D 0A 3R 2A 1B 0B 0.31 1R 0U 0.30 0T 0.33 3A 2B 1S 0.32 ANSI C78.377A 2R 1A 0D 0A 8000 K CCy 0T 0.33 3B 2C 1T 0.34 2D 1C 2T 2S 0.35 2B 1S 3S 50 6500 K 2T 2C 8000 K 0.34 5700 K 0.37 2S 0.35 5000 K 0.39 5700 K 0.37 1R 0U 0.30 0R 0R 0.29 0.29 0.36 0.35 0.34 0.33 0.32 0.31 0.28 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.30 0.28 0.28 0.29 CCx CCx 0.40 0.42 5000 K E3 0.41 0C 0B 0.31 1C 1D 1R 0.30 0R 0.36 0.35 0.34 0.33 0.32 0.31 0.28 0.30 0.28 0.29 0.29 0.28 0.29 0D 0A 1D 1A 4U 4R 3U 3R 2A 1B 0C 0B 0.31 0U 0.30 0T 0S 0.32 3A 2D 1C 4A 3D 2C 2B 1S 0.33 ANSI C78.377A 2R 1U 8000 K 4D 3B 2S 1T 0.34 2U 1A 0D 0A 3R 2A 1B 0.35 ANSI C78.377A 2U 2R 1U 1R 0U 0R CCx © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 0.38 0S 0.32 2D 0.37 0T 0.36 3A 2B 4B 3C 2T 0.36 E0 0.33 2C 1T 1S 6500 K 0.29 8000 K 0.34 4C 3S 0.37 3D 0.28 0.35 3C 3B 2S 4T 4S 3T 0.35 E1 DZ 5700 K 0.38 CCy 0.36 2T 0.34 6500 K 5000 K 0.39 3S 0.32 E2 0.37 4500 K 0.40 5700 K 0.31 0.38 0.30 0.39 0.33 CCy ANSI C78.377A 2R 1A CCx CCy 2U 1D 0D 0.30 0.29 0.28 0C 0B 3R 2A 1B 0S 0.32 0U 0.30 0T 0.33 2U 2D 1C 0.31 0.31 1D 3A 2B 1S 0.30 0S 0.32 2A 1B 0.34 0.29 0.33 8000 K 2D 1C 3B 2C 1T 2B 1S 2T 2S 0.35 CCy CCy 8000 K 2C 3S 51 6500 K 0.36 2S 0.35 5700 K 0.37 2T 0.36 5000 K 0.39 CCx CLD-DS46 REV 7 23 XLAMP ® ML-C LED STANDARD COOL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS - CONTINUED 0.42 0.41 4500 K 0.40 5000 K 0.39 6500 K 4C 0T 0.33 0S 0.32 0B 0.31 0.30 4U 4R 3U 3R 2A 1D 1A 0D 0A 2D 1C 1B 0C 3A 2B 1S 4A 3D 2C 1T 8000 K 4D 3B 2S 0.34 4B 3C 2T 0.36 CCy 4T 4S 3T 3S 0.37 0.35 DY 5700 K 0.38 ANSI C78.377A 2U 2R 1U 1R 0U 0R 0.29 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.28 CCx © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 24 XLAMP ® ML-C LED WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.46 0.45 2700 K 3000 K 0.44 0.43 0.42 4000 K 0.41 E6 4500 K E5 0.40 CCy E7 3500 K 5000 K 0.39 0.38 0.37 5B4 4B 3C 0.36 4D 3B 6A3 5D3 6A2 5B1 5D2 5A3 5D4 6A1 5A2 5D1 5A4 5A1 6A4 6D2 6D1 6D3 6D4 7D1 7A4 7A1 8A2 7D3 7D2 7A3 7A2 7C1 7B4 7B1 6C4 6C1 6B4 5C4 6B1 5C1 5B2 4C 6B2 5C3 5C2 5B3 E4 6C2 6B3 8A3 8C2 8C3 8C4 8D3 8D2 8D4 8A4 8D1 8A1 7D4 8C1 8B4 8B1 7C4 8B3 8B2 7C3 7C2 7B3 7B2 6C3 E8 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx 0.46 0.45 2700 K 3000 K 0.44 0.43 3500 K 0.42 4000 K 0.41 4500 K CCy 0.40 F5 5000 K 0.39 F4 0.38 0.37 4B 3C 0.36 4D 3B 5B3 5C4 5C1 5B4 5D3 6A2 5B1 5D2 5A3 5D4 6A1 5A2 5D1 5A4 5A1 6C2 6B3 6B4 6B1 6A3 6A4 7B2 6C3 6B2 5C3 5C2 5B2 4C F6 F7 6C1 6D2 6D1 7B1 6C4 6D3 6D4 7A2 7A1 7A4 F8 7A3 7D1 7C2 7B3 7B4 7C1 7D4 8B1 7C4 7D3 7D2 7C3 8A1 8A2 8A3 8B2 8B3 8B4 8D2 8C1 8C2 8C3 8C4 8D3 8D4 8A4 8D1 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 25 XLAMP ® ML-C LED STANDARD WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS CONTINUED 0.46 0.45 2700 K 3000 K 0.44 0.43 0.42 Z6 4000 K 0.41 Z5 4500 K 0.40 CCy Z7 3500 K 6C3 6C2 6B3 6B2 5C3 5000 K 0.39 5C2 5B3 5D3 6A2 5B4 0.38 5B1 4C 0.37 3C 0.36 4D 3B 5D2 5A3 5A2 4B 5A1 5C4 6B1 5C1 5B2 6B4 5D4 6A1 6A3 6A4 6C4 6C1 6D2 6D1 7B1 6D3 6D4 7A2 7A1 7A4 7B4 7A3 7D1 7C2 7B3 7B2 7C1 7D4 8B1 7C4 7D3 7D2 7C3 8A1 8A2 8A3 8B2 Z8 8B3 8B4 8D2 8C1 8C2 8C3 8C4 8D3 8D4 8A4 8D1 5D1 ANSI C78.377A 5A4 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 26 XLAMP ® ML-C LED STANDARD CHROMATICITY KITS The following table provides the chromaticity bins associated with chromaticity kits for the ML-C LEDs. Color Cool White Warm White CCT Kit Chromaticity Bins 7000 K DT 0A, 0B, 0C,0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U 7000 K E0 0A, 0B, 0C, 0D 6500 K 51 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U, 3A, 3B, 3R, 3S 6500 K E1 1A, 1B, 1C, 1D 6200 K 50 1A, 1B, 1C, 1D, 2A, 2B, 2C, 2D 6000 K DV 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U 5700 K E2 2A, 2B, 2C, 2D 5500 K DY 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U, 3A, 3B, 3C, 3D, 3R, 3S, 3T, 3U 5000 K DZ 2C, 2D, 2T, 2U, 3A, 3B, 3C, 3D, 3R, 3S, 3T, 3U, 4A, 4B, 4R, 4S 5000 K E3 3A, 3B, 3C, 3D 4750 K F4 3C, 3D, 4A, 4B 4500 K E4 4A, 4B, 4C, 4D 4250 K F5 4C, 4D, 5A1, 5A2, 5A3, 5A4, 5B1, 5B2, 5B3, 5B4 4000 K E5 5A1, 5A2, 5A3, 5A4, 5B1, 5B2, 5B3, 5B4, 5C1, 5C2, 5C3, 5C4, 5D1, 5D2, 5D3, 5D4 4000 K Z5 5A3, 5B4, 5C1, 5D2 3750 K F6 5C1, 5C2, 5C3, 5C4, 5D1, 5D2, 5D3, 5D4, 6A1, 6A2, 6A3, 6A4, 6B1, 6B2, 6B3, 6B4 3500 K E6 6A1, 6A2, 6A3, 6A4, 6B1, 6B2, 6B3, 6B4, 6C1, 6C2, 6C3, 6C4, 6D1, 6D2, 6D3, 6D4 3500 K Z6 6A3, 6B4, 6C1, 6D2 3250 K F7 6C1, 6C2, 6C3, 6C4, 6D1, 6D2, 6D3, 6D4, 7A1, 7A2, 7A3, 7A4, 7B1, 7B2, 7B3, 7B4 3000 K E7 7A1, 7A2, 7A3, 7A4, 7B1, 7B2, 7B3, 7B4, 7C1, 7C2, 7C3, 7C4, 7D1, 7D2, 7D3, 7D4 3000 K Z7 7A3, 7B4, 7C1, 7D2 2850 K F8 7C1, 7C2, 7C3, 7C4, 7D1, 7D2, 7D3, 7D4, 8A1, 8A2, 8A3, 8A4, 8B1, 8B2, 8B3, 8B4 2700 K E8 8A1, 8A2, 8A3, 8A4, 8B1, 8B2, 8B3, 8B4, 8C1, 8C2, 8C3, 8C4, 8D1, 8D2, 8D3, 8D4 2700 K Z8 8A3, 8B4, 8C1, 8D2 © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 27 XLAMP ® ML-C LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured in the following manner: Order Code Bin Code Series MLC = ML-C Series MLC = ML-C CRI Configuration A1 = Typical CRI H1 = 80 CRI minimum P1 = 85 CRI minimum U1 = 90 CRI minimum CRI Configuration A1 = Typical CRI H1 = 80 CRI minimum P1 = 85 CRI minimum U1 = 90 CRI minimum Luminous Flux SSSCCC-BB-HHHH-NNNFGG Chromaticity Luminous flux group SSSCCC-BB-WWW-FF-A-AAAAA Internal code Internal code Chromaticity code Color/Configuration AWT = White - Parallel SWT = White - Series Color/Configuration AWT = White - Parallel SWT = White - Series © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 28 XLAMP ® ML-C LED REFLOW SOLDERING CHARACTERISTICS In testing, Cree LED has found XLamp ML-C LEDs to be compatible with JEDEC J-STD-020C, using the parameters listed below. As a general guideline, Cree LED recommends that users follow the recommended soldering profile provided by the manufacturer of the solder paste used, and therefore it is the lamp or luminaire manufacturer’s responsibility to determine applicable soldering requirements. Note that this general guideline may not apply to all PCB designs and configurations of reflow soldering equipment. tP TP Critical Zone TL to TP Temperature Ramp-up TL tL Tsmax Tsmin Ramp-down ts Preheat 25 t 25˚C to Peak IPC/JEDEC J-STD-020C Time Profile Feature Average Ramp-Up Rate (Tsmax to Tp) Lead-Free Solder 1.2 °C/second Preheat: Temperature Min (Tsmin) 120 °C Preheat: Temperature Max (Tsmax) 170 °C Preheat: Time (tsmin to tsmax) 65-150 seconds Time Maintained Above: Temperature (TL) Time Maintained Above: Time (tL) Peak/Classification Temperature (Tp) 217 °C 45-90 seconds 235 - 245 °C Time Within 5 °C of Actual Peak Temperature (tp) 20-40 seconds Ramp-Down Rate 1 - 6 °C/second Time 25 °C to Peak Temperature 4 minutes max. Note: All temperatures refer to topside of the package, measured on the package body surface. Note: While the high reflow temperatures (above) have been approved, Cree LED’s best practice guideline for reflow is to use as low a temperature as possible during the reflow soldering process for these LEDs. © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 29 XLAMP ® ML-C LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. Moisture Sensitivity Cree LED recommends keeping XLamp ML-C LEDs in the provided, resealable moisture-barrier packaging (MBP) until immediately prior to soldering. Unopened MBPs that contain XLamp LEDs do not need special storage for moisture sensitivity. Once the MBP is opened, XLamp ML-C LEDs should be handled and stored as MSL 2a per JEDEC J-STD-033, meaning they have limited Temp. Maximum Percent Relative Humidity 30% 40% 50% 60% 70% 80% 90% 35 ºC - - - 17 1 .5 .5 30 ºC - - - 28 1 1 1 in days depending on temperature and humidity conditions. LEDs with 25 ºC - - - - 2 1 1 exposure time longer than the specified maximums must be baked 20 ºC - - - - 2 1 1 exposure time before damage to the LED may occur during the soldering operation. The table on the right specifies the maximum exposure time according to the baking conditions listed below. Baking Conditions It is not necessary to bake all XLamp ML-C LEDs. Only the LEDs that meet all of the following criteria must be baked: 1. LEDs that have been removed from the original MBP. 2. LEDs that have been exposed to a humid environment longer than listed in the Moisture Sensitivity section above. 3. LEDs that have not been soldered. © 2011-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo and XLamp® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS46 REV 7 30 XLAMP ® ML-C LED NOTES - CONTINUED LEDs should be baked at 70 ºC for 24 hours. LEDs may be baked on the original reels. Remove LEDs from the MBP before baking. Do not bake parts at temperatures higher than 70 ºC. This baking operation resets the exposure time as defined in the Moisture Sensitivity section above. Storage Conditions XLamp ML-C LEDs that have been removed from the original MBP but not soldered should be stored in one of the following ways: • Store the parts in a rigid metal container with a tight-fitting lid. Verify that the storage temperature is
1. 物料型号:文档描述的是CREE公司的XLamp® ML-C系列LED产品。 2. 器件简介:XLamp® ML-C LED是一款1/3瓦LED,具有照明级可靠性和性能,适用于LED灯泡、线性和分布式照明应用。 3. 引脚分配:文档中没有直接提供引脚分配图,但通常这类LED会有正负两个引脚,具体分配需要查看产品的具体型号或数据手册。 4. 参数特性:文档提供了详细的电气特性和光学特性,例如: - 热阻(结到焊接点):最小值为13°C/W - 视场角:120° - 驱动电流:并联最大350 mA,串联最大175 mA - 正向电压:并联在100mA时3.2V至3.4V,串联在50mA时6.4V至7.0V - LED结温:最大150°C 5. 功能详解:XLamp ML-C LED具有高可靠性、宽视角、均匀的光输出和行业领先的色度分选,提供多种色温选项,包括白色(2600K至8300K CCT)和不同的CRI(80、85、90)。 6. 应用信息:适用于线性照明、荧光灯替代和零售展示照明等多种照明应用。 7. 封装信息:文档提供了详细的机械尺寸图和推荐焊盘设计,以及胶带和卷轴包装信息。
MLCAWT-A1-0000-0000F4 价格&库存
很抱歉,暂时无法提供与“MLCAWT-A1-0000-0000F4”相匹配的价格&库存,您可以联系我们找货
