XHP70B-00-0000-0D0BN40E2
    CREELED
    LED-5P_7X7MM_SM
    LED 照明 XLamp® XHP70.2 白色,冷色 5700K 6V,12V 2.1A,1.05A 125° 2828(7070 公制)
XHP70B-00-0000-0D0BN40E2 数据手册
PRODUCT FAMILY DATA SHEET XLamp® XHP70.2 LEDs PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS The XLamp XHP70.2 LED is the next • Available in white, configurable to 6 V Characteristics................................................ 2 generation of Extreme High Power LEDs Flux Characteristics, EasyWhite® Order or 12 V by PCB layout that delivers the lowest system cost • Available in 5-step EasyWhite bins Codes and Bins............................................... 3 through the best lumen density, reliability at 3000 K to 5000 K CCT, 3-step Flux Characteristics, ANSI White Order and color consistency. Built on Cree LED’s EasyWhite bins at 2700 K to 5000 K Codes and Bins............................................... 6 latest high‑power LED technology, the and 2-step EasyWhite bins at 2700 K to Relative Spectral Power Distribution............. 9 XHP70.2 LED improves the lumen density, 4000 K CCT Relative Flux vs. Junction Temperature......... 9 ® voltage characteristics, reliability and • Available in ANSI white bins at 3000 K optical performance of the XHP70 LED in to 7000 K CCT Electrical Characteristics.............................. 10 Relative Flux vs. Current............................... 11 the same 7.0 mm x 7.0 mm footprint. The • Available in standard, 70-, 80-, and Relative Chromaticity vs Current.................. 12 new XHP70.2 LED provides an easy drop‑in Relative Chromaticity vs Temperature......... 13 90‑minimum CRI options upgrade to achieve higher system LPW • Binned at 85 °C Typical Spatial Distribution........................... 13 for lighting manufacturers with existing • Maximum drive current: 4800 mA (6 V), Thermal Design............................................. 14 XHP70 designs, eliminating redesign costs. Performance Groups - Luminous Flux......... 15 2400 mA (12 V) Its unparalleled lumen density and longer • Low thermal resistance: 0.3 °C/W Performance Groups - Chromaticity............ 15 lifetime at higher operating temperatures • Wide viewing angle: 125° Standard White Chromaticity Regions also enable new and innovative lighting • Unlimited floor life at Plotted on the CIE 1931 Curve..................... 19 designs at lower system costs. Standard Cool White Kits Plotted on ANSI ≤ 30 ºC/85% RH • Reflow solderable - JEDEC J‑STD‑020C Standard Chromaticity Regions................... 22 • RoHS and REACH compliant Standard Warm and Neutral White Kits • UL recognized component (E349212) Plotted on ANSI Standard Chromaticity ® Regions.......................................................... 23 Bin and Order-Code Format.......................... 24 Reflow Soldering Characteristics................. 25 Notes............................................................. 26 Mechanical Dimensions............................... 28 Electrical Configuration................................ 30 Tape and Reel................................................ 31 Packaging...................................................... 33 Cree LED / 4001 E. Hwy. 54, Suite 2000 / Durham, NC 27709 USA / +1.919.313.5330 / www.cree-led.com © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 1 XLAMP ® XHP70.2 LED CHARACTERISTICS XHP70.2 LEDs are tested and binned in the 12‑V configuration. See the Mechanical Dimensions section on page 28 for pad layout options. Characteristics Thermal resistance, junction to solder point Unit Minimum Typical °C/W 0.3 degrees 125 Temperature coefficient of voltage (6 V)* mV/°C -2.9 Temperature coefficient of voltage (12 V) mV/°C -5.8 ◊ Viewing angle (FWHM) ESD withstand voltage (HBM per Mil-Std-883D) Maximum V 8000 DC forward current (6 V)* mA 4800 DC forward current (12 V) mA 2400 Reverse voltage V 1 Forward voltage (6 V, @ 2100 mA, 85 °C)* V 5.6 6.1 Forward voltage (12 V, @ 1050 mA, 85 °C) V 11.2 12.2 LED junction temperature °C 150 Note: ◊ Thermal resistance measurement was performed per the JEDEC JESD51-14 standard. See the Thermal Resistance Measurement * application note for more details. Data for the 6‑V configuration is calculated and for reference only. © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 2 XLAMP ® XHP70.2 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS The following table provides order codes for XLamp XHP70.2 LEDs. For a complete description of how the flux and chromaticity groups are reflected in the bin code and order code nomenclature, please see the Bin and Order Code Formats section (page 24). Binning condition: TJ = 85 °C; 12 V, IF = 1050 mA Reference condition: TJ = 85 °C; 6 V, IF = 2100 mA Nominal CCT CRI Min 70 5000 K 80 90 70 4500 K 80 90 Typ Minimum Luminous Flux 2-Step 3-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* P4 1965 2164 P2 1830 2015 N4 1710 1883 P2 1830 2015 N4 1710 1883 N2 1590 1751 XHP70B-00-00000D0HN250G N2 1590 1751 XHP70B-00-00000D0UN250G M4 1485 1635 M2 1380 1520 P4 1965 2164 P2 1830 2015 N4 1710 1883 N4 1710 1883 N2 1590 1751 M4 1485 1635 XHP70B-00-00000D0HM445G N2 1590 1751 XHP70B-00-00000D0UM445G M4 1485 1635 M2 1380 1520 Group Order Code Group Order Code 5-Step Group Order Code XHP70B-00-00000D0BP450E 50E XHP70B-00-00000D0BP250E XHP70B-00-00000D0BN450E XHP70B-00-00000D0HP250G 50G 50G XHP70B-00-00000D0HN450G XHP70B-00-00000D0UM450G XHP70B-00-00000D0UM250G XHP70B-00-00000D0BP445E 45E XHP70B-00-00000D0BP245E XHP70B-00-00000D0BN445E XHP70B-00-00000D0HN445G 45G 45G XHP70B-00-00000D0HN245G XHP70B-00-00000D0UM245G XHP70B-00-00000D0UK445G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • XLamp XHP70.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. • Flux values @ 25 °C are calculated and for reference only. © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 3 XLAMP ® XHP70.2 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - CONTINUED Nominal CCT CRI Min 70 4000 K 80 90 70 3500 K 80 90 Typ Minimum Luminous Flux 2-Step 3-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* P4 1965 2164 P2 1830 2015 N4 1710 1883 N4 1710 1883 N2 1590 1751 M4 1485 1635 XHP70B-00-00000D0HM440H XHP70B-00-00000D0HM440G M4 1485 1635 XHP70B-00-00000D0UM440H XHP70B-00-00000D0UM440G M2 1380 1520 K4 1290 1420 P2 1830 2015 N4 1710 1883 N2 1590 1751 N4 1710 1883 N2 1590 1751 M4 1485 1635 XHP70B-00-00000D0HM435H XHP70B-00-00000D0HM435G M4 1485 1635 XHP70B-00-00000D0UM435H XHP70B-00-00000D0UM435G M2 1380 1520 K4 1290 1420 Group Order Code Group Order Code 5-Step Group Order Code XHP70B-00-00000D0BP440E 40E XHP70B-00-00000D0BP240E XHP70B-00-00000D0BN440E XHP70B-00-00000D0HN440H 40H 40H XHP70B-00-00000D0HN240H XHP70B-00-00000D0UM240H XHP70B-00-00000D0HN440G 40G 40G XHP70B-00-00000D0UK440H XHP70B-00-00000D0HN240G XHP70B-00-00000D0UM240G XHP70B-00-00000D0UK440G XHP70B-00-00000D0BP235E 35E XHP70B-00-00000D0BN435E XHP70B-00-00000D0BN235E XHP70B-00-00000D0HN435H 35H 35H XHP70B-00-00000D0HN235H XHP70B-00-00000D0UM235H XHP70B-00-00000D0UK435H XHP70B-00-00000D0HN435G 35G 35G XHP70B-00-00000D0HN235G XHP70B-00-00000D0UM235G XHP70B-00-00000D0UK435G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • XLamp XHP70.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. • Flux values @ 25 °C are calculated and for reference only. © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 4 XLAMP ® XHP70.2 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - CONTINUED Nominal CCT CRI Min 70 3000 K Typ Minimum Luminous Flux Flux (lm) @ 85 °C Flux (lm) @ 25 °C* P2 1830 2015 N4 1710 1883 N2 1590 1751 N2 1590 1751 M4 1485 1635 XHP70B-00-00000D0HM430H M2 1380 1520 XHP70B-00-00000D0UM230H K4 1290 1420 K2 1200 1321 XHP70B-00-00000D0UK230H XHP70B-00-00000D0UK230G M4 1485 1635 XHP70B-00-00000D0HM427H XHP70B-00-00000D0HM427G M2 1380 1520 XHP70B-00-00000D0HM227H K4 1290 1420 XHP70B-00-00000D0UK427H 90 K2 1200 1321 J4 1120 1233 Group Order Code Group Order Code 5-Step Group Order Code XHP70B-00-00000D0BP230E 30E XHP70B-00-00000D0BN430E XHP70B-00-00000D0BN230E 30H 80 2700 K 3-Step Group 80 90 2-Step 30H 27H 27H XHP70B-00-00000D0HN230H XHP70B-00-00000D0UK430H XHP70B-00-00000D0UK227H XHP70B-00-00000D0UJ427H 30G XHP70B-00-00000D0HN230G XHP70B-00-00000D0HM430G XHP70B-00-00000D0UM230G 30G 27G XHP70B-00-00000D0UK430G XHP70B-00-00000D0HM227G XHP70B-00-00000D0UK427G 27G XHP70B-00-00000D0UK227G XHP70B-00-00000D0UJ427G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • XLamp XHP70.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. • Flux values @ 25 °C are calculated and for reference only. © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 5 XLAMP ® XHP70.2 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS The following table provides order codes for XLamp XHP70.2 LEDs. For a complete description of how the flux and chromaticity groups are reflected in the bin code and order code nomenclature, please see the Bin and Order Code Formats section (page 24). Binning condition: TJ = 85 °C; 12 V, IF = 1050 mA Reference condition: TJ = 85 °C; 6 V, IF = 2100 mA Nominal CCT CRI Chromaticity Regions Min 0 7000 K 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U Minimum Luminous Flux Typ 68 70 80 0 6500 K 1A, 1B, 1C, 1D 68 70 80 0 6000 K 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U 70 80 90 68 Group Flux (lm) Flux (lm) @ 85 °C @ 25 °C* Order Code P2 1830 2015 XHP70B-00-0000-0D00P20DT N4 1710 1883 XHP70B-00-0000-0D00N40DT N2 1590 1751 XHP70B-00-0000-0D00N20DT P2 1830 2015 XHP70B-00-0000-0D0BP20DT N4 1710 1883 XHP70B-00-0000-0D0BN40DT N2 1590 1751 XHP70B-00-0000-0D0BN20DT N2 1590 1751 XHP70B-00-0000-0D0HN20DT M4 1485 1635 XHP70B-00-0000-0D0HM40DT P2 1830 2015 XHP70B-00-0000-0D00P20E1 N4 1710 1883 XHP70B-00-0000-0D00N40E1 N2 1590 1751 XHP70B-00-0000-0D00N20E1 P2 1830 2015 XHP70B-00-0000-0D0BP20E1 N4 1710 1883 XHP70B-00-0000-0D0BN40E1 N2 1590 1751 XHP70B-00-0000-0D0BN20E1 N2 1590 1751 XHP70B-00-0000-0D0HN20E1 M4 1485 1635 XHP70B-00-0000-0D0HM40E1 P2 1830 2015 XHP70B-00-0000-0D00P20DV N4 1710 1883 XHP70B-00-0000-0D00N40DV P2 1830 2015 XHP70B-00-0000-0D0BP20DV N4 1710 1883 XHP70B-00-0000-0D0BN40DV N2 1590 1751 XHP70B-00-0000-0D0HN20DV M4 1485 1635 XHP70B-00-0000-0D0HM40DV M4 1485 1635 XHP70B-00-0000-0D0UM40DV M2 1380 1520 XHP70B-00-0000-0D0UM20DV Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • XLamp XHP70.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. • Flux values @ 25 °C are calculated and for reference only. © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 6 XLAMP ® XHP70.2 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS - CONTINUED Nominal CCT CRI Chromaticity Regions Min 0 Minimum Luminous Flux Typ 68 70 5700 K 2A, 2B, 2C, 2D 80 90 0 68 70 5000 K 3A, 3B, 3C, 3D 80 90 0 70 4500 K 4A, 4B, 4C, 4D 80 90 68 Group Flux (lm) Flux (lm) @ 85 °C @ 25 °C* P4 1965 2164 Order Code XHP70B-00-0000-0D00P40E2 P2 1830 2015 XHP70B-00-0000-0D00P20E2 N4 1710 1883 XHP70B-00-0000-0D00N40E2 P4 1965 2164 XHP70B-00-0000-0D0BP40E2 P2 1830 2015 XHP70B-00-0000-0D0BP20E2 N4 1710 1883 XHP70B-00-0000-0D0BN40E2 N4 1710 1883 XHP70B-00-0000-0D0HN40E2 N2 1590 1751 XHP70B-00-0000-0D0HN20E2 M4 1485 1635 XHP70B-00-0000-0D0HM40E2 N2 1590 1751 XHP70B-00-0000-0D0UN20E2 M4 1485 1635 XHP70B-00-0000-0D0UM40E2 M2 1380 1520 XHP70B-00-0000-0D0UM20E2 P4 1965 2164 XHP70B-00-0000-0D00P40E3 P2 1830 2015 XHP70B-00-0000-0D00P20E3 N4 1710 1883 XHP70B-00-0000-0D00N40E3 P4 1965 2164 XHP70B-00-0000-0D0BP40E3 P2 1830 2015 XHP70B-00-0000-0D0BP20E3 N4 1710 1883 XHP70B-00-0000-0D0BN40E3 P2 1830 2015 XHP70B-00-0000-0D0HP20E3 N4 1710 1883 XHP70B-00-0000-0D0HN40E3 N2 1590 1751 XHP70B-00-0000-0D0HN20E3 N2 1590 1751 XHP70B-00-0000-0D0UN20E3 M4 1485 1635 XHP70B-00-0000-0D0UM40E3 M2 1380 1520 XHP70B-00-0000-0D0UM20E3 P4 1965 2164 XHP70B-00-0000-0D00P40E4 P2 1830 2015 XHP70B-00-0000-0D00P20E4 N4 1710 1883 XHP70B-00-0000-0D00N40E4 P4 1965 2164 XHP70B-00-0000-0D0BP40E4 P2 1830 2015 XHP70B-00-0000-0D0BP20E4 N4 1710 1883 XHP70B-00-0000-0D0BN40E4 N4 1710 1883 XHP70B-00-0000-0D0HN40E4 N2 1590 1751 XHP70B-00-0000-0D0HN20E4 M4 1485 1635 XHP70B-00-0000-0D0HM40E4 M4 1485 1635 XHP70B-00-0000-0D0UM40E4 M2 1380 1520 XHP70B-00-0000-0D0UM20E4 K4 1290 1420 XHP70B-00-0000-0D0UK40E4 Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • XLamp XHP70.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. • Flux values @ 25 °C are calculated and for reference only. © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 7 XLAMP ® XHP70.2 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS - CONTINUED Nominal CCT CRI Chromaticity Regions Min 0 70 4000 K 5A, 5B, 5C, 5D 80 90 3500 K 3000 K 6A, 6B, 6C, 6D 7A, 7B, 7C, 7D 70 70 Minimum Luminous Flux Typ 68 Group Flux (lm) Flux (lm) @ 85 °C @ 25 °C* P4 1965 2164 Order Code XHP70B-00-0000-0D00P40E5 P2 1830 2015 XHP70B-00-0000-0D00P20E5 N4 1710 1883 XHP70B-00-0000-0D00N40E5 P4 1965 2164 XHP70B-00-0000-0D0BP40E5 P2 1830 2015 XHP70B-00-0000-0D0BP20E5 N4 1710 1883 XHP70B-00-0000-0D0BN40E5 N4 1710 1883 XHP70B-00-0000-0D0HN40E5 N2 1590 1751 XHP70B-00-0000-0D0HN20E5 M4 1485 1635 XHP70B-00-0000-0D0HM40E5 M4 1485 1635 XHP70B-00-0000-0D0UM40E5 M2 1380 1520 XHP70B-00-0000-0D0UM20E5 K4 1290 1420 XHP70B-00-0000-0D0UK40E5 P2 1830 2015 XHP70B-00-0000-0D0BP20E6 N4 1710 1883 XHP70B-00-0000-0D0BN40E6 N2 1590 1751 XHP70B-00-0000-0D0BN20E6 N4 1710 1883 XHP70B-00-0000-0D0BN40E7 N2 1590 1751 XHP70B-00-0000-0D0BN20E7 Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). • XLamp XHP70.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. • Flux values @ 25 °C are calculated and for reference only. © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 8 XLAMP ® XHP70.2 LED Relative Spectral Power RELATIVE SPECTRAL POWER DISTRIBUTION 100% Relative Radiant Power 80% 60% 6500 K, 68 CRI 3000 K, 80 CRI 40% 20% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) RELATIVE FLUX VS. JUNCTION TEMPERATURE Relative Flux Output vs. Junction Temperature Reference condition: 6 V, IF = 2100 mA; 12 V, IF = 1050 mA 120% Relative Luminous Flux 100% 80% 60% 40% 20% 0% 25 50 75 100 125 150 Junction Temperature (ºC) © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 9 XLAMP ® XHP70.2 LED ELECTRICAL CHARACTERISTICS (TJ = 85 °C) 4800 Forward Current (mA) 4000 3200 6V 2400 1600 800 0 Electrical Characteristics (Tj = 85°C) 5.00 5.25 5.50 5.75 6.00 Forward Voltage (V) 2400 Forward Current (mA) 2000 1600 1200 12 V 800 400 0 10.0 10.5 11.0 11.5 12.0 Forward Voltage (V) © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 10 XLAMP ® XHP70.2 LED RELATIVE FLUX VS. CURRENT (TJ = 85 °C) 200% 180% Relative Luminous Flux 160% 140% 120% 100% 6V 80% 60% 40% 20% 0% 0 800 1600 2400 Relative Intensity vs. Current (Tj = 85°C) Forward Current (mA) 3200 4000 4800 200% Relative Luminous Flux 180% 160% 140% 120% 100% 12 V 80% 60% 40% 20% 0% 0 400 800 1200 1600 2000 2400 Forward Current (mA) © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 11 XLAMP ® XHP70.2 LED RELATIVE CHROMATICITY VS CURRENT (WARM WHITE) 0.020 0.016 0.012 6V 0.008 0.004 ΔCCx 0.000 ΔCCy -0.004 -0.008 -0.012 -0.016 -0.020 0 800 1600 Relative Chromaticity Vs. Current, WW 2400 3200 4000 4800 Current (mA) 0.020 0.016 0.012 12 V 0.008 0.004 ΔCCx 0.000 ΔCCy -0.004 -0.008 -0.012 -0.016 -0.020 0 400 800 1200 1600 2000 2400 Current (mA) © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 12 XLAMP ® XHP70.2 LED RELATIVE CHROMATICITY VS TEMPERATURE (WARM WHITE) Relative Chromaticity Vs. Temperature WW Reference condition: 6 V, IF = 2100 mA; 12 V, IF = 1050 mA 0.020 0.016 0.012 0.008 0.004 0.000 ΔCCx -0.004 ΔCCy -0.008 -0.012 -0.016 -0.020 25 50 75 100 125 150 Tj (°C) TYPICAL SPATIAL DISTRIBUTION Typical Spatial Radiation Pattern Reference condition: TJ = 85 °C; 6 V, IF = 2100 mA; 12 V, IF = 1050 mA 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 13 XLAMP ® XHP70.2 LED THERMAL DESIGN The maximum forward current is determined by the thermal resistance between the LED junction and ambient. It is crucial for the end product to be designed in a manner that minimizes the thermal resistance from the solder point to ambient in order to optimize lamp life and optical characteristics. 5000 Maximum Current (mA) 4500 6V 4000 3500 3000 2500 2000 Rj-a = 1°C/W 1500 Rj-a = 2°C/W 1000 Rj-a = 3°C/W 500 0 Rj-a = 4°C/W 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) Thermal Design 2500 Maximum Current (mA) 2250 12 V 2000 1750 1500 1250 1000 Rj-a = 1°C/W 750 Rj-a = 2°C/W 500 Rj-a = 3°C/W 250 0 Rj-a = 4°C/W 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 14 XLAMP ® XHP70.2 LED PERFORMANCE GROUPS - LUMINOUS FLUX (TJ = 85 °C) XLamp XHP70.2 LEDs are tested for luminous flux and placed into one of the following luminous-flux groups. Group Code Minimum Luminous Flux Maximum Luminous Flux J4 1120 1200 K2 1200 1290 K4 1290 1380 M2 1380 1485 M4 1485 1590 N2 1590 1710 N4 1710 1830 P2 1830 1965 P4 1965 2100 Q2 2100 2260 PERFORMANCE GROUPS - CHROMATICITY XLamp XHP70.2 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Code 40H 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3777 0.3739 0.3797 0.3816 0.3861 0.3855 0.3838 0.3777 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 15 XLAMP ® XHP70.2 LED PERFORMANCE GROUPS - CHROMATICITY (CONTINUED) EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 50G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 45G 4500 0.3611 0.3658 0.00852 0.00330 61.5 40G 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 EasyWhite Color Temperatures – 5-Step Ellipse Bin Code CCT 50E Center Point Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.01400 0.00520 65.0 45E 4500 K 0.3611 0.3658 0.01420 0.00550 61.5 40E 4000 K 0.3818 0.3797 0.01565 0.00670 53.7 35E 3500 K 0.4073 0.3917 0.01545 0.00690 54.0 30E 3000 K 0.4338 0.4030 0.01390 0.00680 53.2 ANSI White Bins CCT Major Axis Bin Code 0A0 0B0 7000 K 0C0 0D0 ANSI White Bins x y 0.2950 0.2920 0.2984 0.3133 0.3009 0.3042 0.2920 0.2895 0.2962 0.3220 0.2984 0.3133 0.2984 0.3133 0.2962 0.3220 0.3028 0.3304 0.3048 0.3207 0.2984 0.3048 0.3068 0.3113 0.3009 0.3042 CCT Bin Code ANSI White Bins x y 0.2970 0.2980 0.3060 0.2950 0.3009 0.3042 0.3037 0.2937 0.3060 0.2895 0.3135 0.2870 0.2937 0.3312 0.2962 0.3220 0.2962 0.3220 0.2937 0.3312 0.3005 0.3415 0.3028 0.3304 0.3133 0.3037 0.3207 0.3009 0.3068 0.3113 0.3093 0.2993 0R0 0S0 7000 K 0T0 0U0 CCT Bin Code x y 0.2880 0.3048 0.3207 0.2970 0.3130 0.3290 0.3144 0.3186 0.3068 0.3113 0.3135 0.3028 0.3304 0.3210 0.3115 0.3391 0.3130 0.3290 0.3048 0.3207 0.3115 0.3391 0.3205 0.3481 0.3213 0.3373 0.3130 0.3290 0.2937 0.3130 0.3290 0.3042 0.3213 0.3373 0.3221 0.3261 0.3144 0.3186 1A0 1B0 7000 K © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 1C0 1D0 CLD-DS170 REV 4 16 XLAMP ® XHP70.2 LED PERFORMANCE GROUPS - CHROMATICITY (CONTINUED) ANSI White Bins CCT Bin Code 1R0 1S0 7000 K 1T0 1U0 ANSI White Bins x y CCT 0.3068 0.3113 0.3144 0.3186 0.3161 0.3059 0.3093 0.3005 0.3099 0.3509 0.3115 0.3391 0.3028 0.3304 0.3099 0.3509 0.3196 0.3602 0.3205 0.3481 0.3115 0.3144 0.3221 0.3261 0.3231 0.3120 0.3161 0.3059 Bin Code x y 0.3215 0.3350 0.3290 0.3417 0.3290 0.3300 0.2993 0.3222 0.3415 0.3207 0.3290 0.3538 0.3290 0.3417 0.3215 0.3350 0.3290 0.3538 0.3376 0.3616 0.3371 0.3490 0.3391 0.3290 0.3186 0.3290 0.3371 0.3490 0.3366 0.3369 0.3290 0.3300 2A0 2B0 6000 K 2C0 2D0 ANSI White Bins CCT ANSI White Bins Bin Code 3A0 3B0 5000 K 3C0 3D0 CCT Bin Code x y 0.3222 0.3243 0.3290 0.3300 0.3290 0.3180 0.3243 0.3231 0.3120 0.3462 0.3196 0.3602 0.3290 0.3690 0.3290 0.3538 0.3207 0.3462 0.3290 0.3690 0.3381 0.3762 0.3376 0.3616 0.3417 0.3290 0.3538 0.3417 0.3290 0.3300 0.3366 0.3369 0.3361 0.3245 0.3290 0.3180 2R0 2S0 6000 K 2T0 2U0 ANSI White Bins x y 0.3371 0.3490 0.3451 0.3554 0.3440 0.3427 0.3366 0.3376 0.3463 0.3687 0.3451 0.3554 0.3371 0.3490 0.3463 0.3687 0.3551 0.3760 0.3533 0.3620 0.3451 0.3451 0.3533 0.3620 0.3515 0.3487 0.3440 0.3427 CCT Bin Code x y 0.3530 0.3597 0.3615 0.3659 0.3512 0.3465 0.3369 0.3515 0.3487 0.3616 0.3548 0.3736 0.3641 0.3804 0.3530 0.3597 4A0 4B0 0.3533 0.362 0.3641 0.3804 0.3736 0.3874 0.3702 0.3722 0.3554 0.3615 0.3659 0.3554 0.3615 0.3659 0.3702 0.3722 0.3670 0.3578 0.3590 0.3521 4500 K 4C0 4D0 © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 17 XLAMP ® XHP70.2 LED PERFORMANCE GROUPS - CHROMATICITY (CONTINUED) ANSI White Bins CCT Bin Code 5A0 5B0 4000 K 5C0 5D0 ANSI White Bins x y 0.3670 0.3578 0.3702 0.3722 0.3825 0.3798 0.3783 0.3702 0.3736 0.3874 0.3869 0.3958 0.3825 0.3798 0.3825 0.3798 0.3869 0.3958 0.4006 0.4044 0.3950 0.3783 0.3825 0.3798 0.3950 0.3875 0.3898 0.3716 CCT Bin Code ANSI White Bins x y 0.3889 0.3690 0.3941 0.3848 0.4080 0.3916 0.3646 0.4017 0.3722 0.3]941 0.3996 0.4015 0.4146 0.4089 0.4080 0.3916 0.4080 0.3916 0.4146 0.4089 0.4299 0.4165 0.3875 0.4221 0.3646 0.4017 0.4080 0.3916 0.4221 0.3984 0.4147 0.3814 6A0 6B0 3500 K 6C0 6D0 CCT Bin Code x y 0.4147 0.3814 0.4221 0.3984 0.4342 0.4028 0.3751 0.4259 0.3853 0.3848 0.4221 0.3984 0.4299 0.4165 0.4430 0.4212 0.4342 0.4028 0.4342 0.4028 0.4430 0.4212 0.4562 0.4260 0.3984 0.4465 0.4071 0.3751 0.4259 0.3853 0.4342 0.4028 0.4465 0.4071 0.4373 0.3893 7A0 7B0 3000 K © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 7C0 7D0 CLD-DS170 REV 4 18 XLAMP ® XHP70.2 LED STANDARD WHITE CHROMATICITY REGIONS PLOTTED ON THE CIE 1931 CURVE ANSI Cool White 0.40 5000 K 0.39 5700 K 0.38 0.37 6500 K 2T 0.36 2S CCy 8000 K 2B 1S 0.34 0T 0.33 0S 0.32 2C 1T 0.35 0B 0.31 1D 2U 2R 1A 0D 0A 0.30 2A 1B 0C 2D 1C ANSI C78.377A 1U 1R 0U 0R 0.29 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.28 CCx © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 19 XLAMP ® XHP70.2 LED STANDARD WHITE CHROMATICITY REGIONS PLOTTED ON THE CIE 1931 CURVE - CONTINUED ANSI Neutral White and ANSI Warm White 0.45 0.44 2700 K 3000 K 0.43 0.42 3500 K 0.41 4000 K 6C 0.40 CCy 7C 7B 0.39 5000 K 0.38 4C 0.37 3C 3B 3D 0.35 4B 7D 7A 5C 6D 5B 5700 K 0.36 6B 4500 K 5D 6A 5A ANSI C78.377A 4D 4A 3A 0.34 0.50 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.33 CCx © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 20 XLAMP ® XHP70.2 LED STANDARD WHITE CHROMATICITY REGIONS PLOTTED ON THE CIE 1931 CURVE - CONTINUED 0.44 ANSI C78.377 Quadrangle 0.43 EasyWhite 5-Step EasyWhite 3-Step 0.42 3500 K EasyWhite 2-Step 0.41 2700 K 3000 K 4000 K 0.40 4500 K 0.39 5000 K 0.38 CCy 0.37 5700 K 0.36 6500 K 0.35 0.34 8000 K 0.33 0.32 0.31 0.30 0.29 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.27 0.28 CCx © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 21 XLAMP ® XHP70.2 LED STANDARD COOL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.40 5000 K 0.39 0.38 5700 K 0.37 6500 K 2T 0.36 2S DT 0.35 CCy 8000 K 2B 1S 0T 0.33 0C 0B 0.31 2D 1C 2A 1B 0S 0.32 2C 1T 0.34 1D 2U 1U 0D 0A ANSI C78.377A 2R 1A 1R 0U 0.30 0R 0.29 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.28 CCx 0.40 0.40 5000 K 0.39 0.38 DV 6500 K 0.36 0.36 2C 8000 K 0A 0R 1R 0U CCx 0.36 0.35 0.34 0.28 0.36 0.35 0.34 0.33 0.32 0.28 0.31 0.28 0.30 ANSI C78.377A 2R 1U 0R 0.29 0.29 2U 1A 0D 0.30 0.29 0.28 0C 0B 0.31 1R 0U 0.30 0S 0.32 1D 0.33 0A CCy 1U 3R 2A 1B 0.32 0.31 ANSI C78.377A 2R 1A 0D 0T 0.33 2U 3A 2D 1C 0.31 0C 0B 1D 2C 2B 1S 0.30 0S 0.32 2A 1B 3B 2S 1T 8000 K 0.34 0.29 0T 0.33 2D 1C 2T E1 0.35 2B 1S 3S 6500 K 2T 1T 0.34 5700 K 0.37 2S 0.35 CCy 0.38 5700 K 0.37 5000 K 0.39 CCx 0.40 5000 K 0.39 0.38 5700 K E2 0.37 6500 K 0.36 3B 2S 0.35 CCy 3S 2T 2C 1T 8000 K 0.34 0T 0.33 0S 0.32 0C 0A 3R 2A 2U 1D ANSI C78.377A 2R 1A 0D 2D 1C 1B 0B 0.31 3A 2B 1S 1U 1R 0U 0.30 0R 0.29 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.28 CCx © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 22 XLAMP ® XHP70.2 LED STANDARD WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.45 0.44 2700 K 3000 K 0.43 E7 0.42 3500 K 4000 K CCy 0.40 0.39 5000 K 0.38 E4 4B 3C 0.36 3B 3D 0.35 7B 6C 6B 7D 7A 5C 6D 5B 4C E3 0.37 E5 4500 K 7C E6 0.41 6A ANSI C78.377A 5D 5A 4D 4A 3A 0.34 0.50 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.33 CCx © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 23 XLAMP ® XHP70.2 LED BIN AND ORDER-CODE FORMAT Bin codes and order codes for XHP70.2 LEDs are configured in the following manner: Order Code Bin Code Series XHP70B = XHP70.2 Series XHP70B = XHP70.2 Internal code Chromaticity group Minimum luminous flux group Vf Class D = 6-V/12-V configurable Chromaticity group CRI specification 0 = No minimum CRI B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum SSSSSS-BD-GGGG-HJKLMMNNN CRI specification 0 = No minimum CRI B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum SSSSSS-E-NNN-MMM-JK-L-PP Vf Class D = 6-V/12-V configurable Configuration B = Internal code D = Reel size © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Internal code Voltage performance group Luminous flux group Internal code CLD-DS170 REV 4 24 XLAMP ® XHP70.2 LED REFLOW SOLDERING CHARACTERISTICS In testing, Cree LED has found XLamp XHP70.2 LEDs to be compatible with JEDEC J‑STD‑020C, using the parameters listed below. As a general guideline, Cree LED recommends that users follow the recommended soldering profile provided by the manufacturer of the solder paste used, and therefore it is the lamp or luminaire manufacturer’s responsibility to determine applicable soldering requirements. Note that this general guideline may not apply to all PCB designs and configurations of reflow soldering equipment. tP TP Critical Zone TL to TP Temperature Ramp-up TL tL Tsmax Tsmin Ramp-down ts Preheat 25 t 25˚C to Peak Profile Feature Average Ramp-Up Rate (Tsmax to Tp) Time Lead-Free Solder 1.2 °C/second Preheat: Temperature Min (Tsmin) 120 °C Preheat: Temperature Max (Tsmax) 170 °C Preheat: Time (tsmin to tsmax) 65-150 seconds Time Maintained Above: Temperature (TL) Time Maintained Above: Time (tL) 217 °C 45-90 seconds Peak/Classification Temperature (Tp) 235 - 245 °C Time Within 5 °C of Actual Peak Temperature (tp) 20-40 seconds Ramp-Down Rate 1 - 6 °C/second Time 25 °C to Peak Temperature 4 minutes max. Note: All temperatures refer to the topside of the package, measured on the package body surface. © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 25 XLAMP ® XHP70.2 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Cree LED did not perform Room Temperature Operating Life (RTOL) testing on the XHP70.2 LED. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. Moisture Sensitivity Cree LED recommends keeping XLamp LEDs in the provided, resealable moisture-barrier packaging (MBP) until immediately prior to soldering. Unopened MBPs that contain XLamp LEDs do not need special storage for moisture sensitivity. Once the MBP is opened, XLamp XHP70.2 LEDs may be stored as MSL 1 per JEDEC J-STD-033, meaning they have unlimited floor life in conditions of ≤ 30 ºC/85% relative humidity (RH). Regardless of the storage condition, Cree LED recommends sealing any unsoldered LEDs in the original MBP. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACH Compliance REACH substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACH SVHC Declaration. REACH banned substance information (REACH Article 67) is also available upon request. © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 26 XLAMP ® XHP70.2 LED NOTES - CONTINUED UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 27 XLAMP ® XHP70.2 LED MECHANICAL DIMENSIONS Thermal vias, if present, are not shown on these drawings. 4 3 All dimensions are ±.13 mm unless 2 otherwise indicated. 47.00 3 7.00 2 0.56 OPTICAL MODEL ORIGIN 0.56 OPTICAL MODEL ORIGIN ANODE SIDE B 7.00 7.00 B ANODE SIDE CATHODE SIDE R3.76 4.34 R3.76 CATHODE SIDE OPTICAL MODEL ORIGIN TOP MODEL VIEWORIGIN OPTICAL SIDE VIEW Side View Top View 6.80 5.40 4.00 TOP VIEW 4.34 SIDE VIEW 6.80 5.40 6.80 3.15 3.15 4.00 6.80 A A CENTER PAD IS ELECTRICALLY ISOLATED SOLDERMASK MAY BE PRESENT CENTER PAD IS BOTTOM VIEW ELECTRICALLY ISOLATED 4 4 2610- SOLDERMASK MAY BE PRESENT BOTTOM3VIEW Bottom View 2 3 © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 2 CLD-DS170 REV 4 28 XLAMP ® XHP70.2 LED MECHANICAL DIMENSIONS - CONTINUED 4 3 6 6.80 4 0.70 3 0.70 0.70 6.80 0.70 4.00 0.70 3.15 3.15 3.15 6.80 6.80 0.70 6.80 6.80 B 2 6.80 4.00 3.15 0.70 B 2 6.80 0.70 RECOMMENDED STENCIL OPENING V PCB FOOTPRINT 0.70 16X 4 RECOMMENDED 6V AND 12V PCB SOLDER MASK OPENING Recommended 6‑V & 12‑V PCB Solder Mask Opening 3 4 0.50 0.80 28X 0.70 16X 0.80 28X 0.31 A 0.55 8X 6.80 B 6.76 0.50 0.55 3.15 8X 6.76 0.70 A 6.80 0.11 0.24 4.00 0.31 0.70 0.83 24X 6.70 6.80 0.41 4X 1 0.41 4X 2 0.83 24X RECOMMENDED 12V PCB FOOTPRINT RECOMMEND Recommended 12‑V PCB Footprint PCB SOLDER (Thermal pad is connected to anode and 6.70 cathode and is not electrically isolated) RECOMMENDED 6V PCB RECOMMENDED 12V PCB FOOTPRINT 0.24 FOOTPRINT 0.11 RECOMMENDED 6V PCB FOOTPRINT Recommended 6‑V PCB Footprint 6.80 (Thermal pad is electrically isolated) RECOMMENDED STENCIL OPENING Recommended 6‑V & 12‑V Stencil Openings 2610 2 3 2 A 2610-700001 XHP70B 2 1 © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 29 POSITIVE A XLAMP ® XHP70.2 LED NEGATIVE B ELECTRICAL CONFIGURATION 12 V 6V SOLDER PAD LINK NEGATIVE A POSITIVE A NEGATIVE B POSITIVE B POSITIVE A NEGATIVE B 6-V Configuration 12-V Configuration 6V NEGATIVE A POSITIVE A NEGATIVE B POSITIVE B © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 30 XLAMP ® XHP70.2 LED TAPE AND REEL All Cree LED carrier tapes conform to EIA-481D, Automated Component Handling Systems Standard. All dimensions are ±.13 mm unless otherwise indicated. Po T E Do Bo R P2 W A Anode side F A P1 B D1 "H" Ko B-B SECTION Bo (on a place in the bottom of the corner radii) Ao (on a place in the bottom of the corner radii) R "I" Ao Item Dim. ITEM Ao Dim. 7.40 Bo Ao 7.40 5.40 Ko 4.60 DETAIL"H" DETAIL"I" A-A SECTION Bo Po 5.40 4.00 Ko Po P2 3.35 12.00 4.00 2.00 P1 T P1 E 0.36 8.00 1.75 ITEM F Do D1 W R Dim. 5.50 1.50 1.50 12.00 3deg P2 F 2.00 7.50 TDo 0.36 1.50 E D1 1.75 1.50 W R 16.00 5° NOTICE 1) All Cree LED carrier tapes conform to EIA-481D, Automated Component handling Systems Standard 2) Measurement tolerances unless indicated otherwise: .xx = ±.15 mm 2402-M022 XML3 © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 31 XLAMP ® XHP70.2 LED TAPE AND REEL - CONTINUED Feed Direction END START Trailer Loaded Pockets Leader Min. 160 mm empty pockets sealed with tape 1000 Lamps Min. 400 mm empty pockets with min. 100 mm sealed Feed Direction Cover Tape Pocket Tape 13 mm 13” © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 32 XLAMP ® XHP70.2 LED PACKAGING © 2017-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS170 REV 4 33
XHP70B-00-0000-0D0BN40E2 价格&库存
很抱歉,暂时无法提供与“XHP70B-00-0000-0D0BN40E2”相匹配的价格&库存,您可以联系我们找货
