XHP50B-00-0000-0D0HH230G
    CREELED
    LED-5P_5X5MM_SM
    LED 照明 XLamp® XHP50.2 白色,暖色 3000K 3 阶麦克亚当椭圆 6V,12V 1.4A,700mA 120° 2020(5050 公制)
XHP50B-00-0000-0D0HH230G 数据手册
PRODUCT FAMILY DATA SHEET XLamp® XHP50.2 LEDs PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS The XLamp® XHP50.2 LED is the next • Available in white, configurable to 3 V, Characteristics................................................ 2 generation of Extreme High Power LEDs Flux Characteristics, EasyWhite® Order 6 V or 12 V by PCB layout that delivers the lowest system cost • Available in 5-step EasyWhite® bins Codes and Bins............................................... 3 through the best lumen density, reliability at 3000 K to 5000 K CCT, 3-step Flux Characteristics, ANSI White Order and color consistency. Built on Cree LED’s EasyWhite bins at 2700 K to 5000 K Codes and Bins............................................... 5 latest high‑power LED technology, the and 2-step EasyWhite bins at 2700 K to Flux Characteristics - Broadcast Order XHP50.2 LED improves the lumen density, 4000 K CCT Codes and Bins............................................... 8 voltage characteristics, reliability and • Available in ANSI white bins at 3000 K optical performance of the XHP50 LED in to 7000 K CCT Relative Spectral Power Distribution............. 9 Relative Flux vs. Junction Temperature......... 9 the same 5.0 mm x 5.0 mm footprint. The • Available in standard, 70-, 80-, and Electrical Characteristics.............................. 10 new XHP50.2 LED provides an easy drop‑in Relative Flux vs. Current............................... 11 90‑minimum CRI options upgrade to achieve higher system LPW • Broadcast color option at 5700 K Relative Chromaticity vs Current.................. 13 for lighting manufacturers with existing provides maximum performance for TV Relative Chromaticity vs Temperature......... 14 XHP50 designs, eliminating redesign costs. events that require extremely high TLCI Typical Spatial Distribution........................... 15 Its unparalleled lumen density and longer • Binned at 85 °C Thermal Design............................................. 15 lifetime at higher operating temperatures • Maximum drive current: 6000 mA (3 V), Performance Groups – Luminous Flux....... 17 also enables new and innovative lighting Performance Groups – Chromaticity........... 17 designs at lower system costs. 3000 mA (6 V), 1500 mA (12 V) • Low thermal resistance: 0.6 °C/W EasyWhite® Chromaticity Regions Plotted • Wide viewing angle: 120° on the 1931 CIE Curve.................................. 20 • Unlimited floor life at ≤ 30 ºC/85% RH ANSI Cool White Kits Plotted on ANSI • Reflow solderable - JEDEC J‑STD‑020C Standard Chromaticity Regions................... 21 • RoHS and REACH compliant ANSI Warm and Neutral White Kits Plotted • UL® recognized component (E349212) on ANSI Standard Chromaticity Regions..... 22 Bin and Order Code Formats........................ 23 Reflow Soldering Characteristics................. 24 Notes............................................................. 25 Mechanical Dimensions............................... 27 Electrical Configuration................................ 28 Tape and Reel................................................ 29 Packaging...................................................... 31 Cree LED / 4001 E. Hwy. 54, Suite 2000 / Durham, NC 27709 USA / +1.919.313.5330 / www.cree-led.com © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 1 1 XLAMP ® XHP50.2 LED CHARACTERISTICS XLamp XHP50.2 LEDs are tested and binned in production in the 12‑V configuration. See the Mechanical Dimensions section on page 27 for pad layout options. Characteristics Unit Thermal resistance, junction to solder point Minimum Typical °C/W 0.6 degrees 120 Temperature coefficient of voltage (3 V)* mV/°C -1.5 Temperature coefficient of voltage (6 V)* mV/°C -3 Temperature coefficient of voltage (12 V) mV/°C -6 ◊ Viewing angle (FWHM) ESD withstand voltage (HBM per Mil-Std-883D) Maximum V 8000 DC forward current (3 V)* mA 6000 DC forward current (6 V)* mA 3000 DC forward current (12 V) mA 1500 Reverse voltage (6V) V Forward voltage (3 V, @ 2800 mA, 85 °C)* V 2.8 3.1 1 Forward voltage (6 V, @ 1400 mA, 85 °C)* V 5.6 6.2 Forward voltage (12 V, @ 700 mA, 85 °C) V 11.2 12.4 LED junction temperature °C 150 Note: ◊ Thermal resistance measurement was performed per the JEDEC JESD51-14 standard. See the Thermal Resistance Measurement application note for more details. * Data for the 3‑V and 6‑V configurations are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 2 2 XLAMP ® XHP50.2 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS The following table provides order codes for XLamp XHP50.2 LEDs. For a complete description of how the flux and chromaticity groups are reflected in the bin code and order code nomenclature, please see the Bin and Order Code Formats section (page 23). Binning condition: TJ = 85 °C; 12 V, IF = 700 mA Reference condition: TJ = 85 °C; 6 V, IF = 1400 mA CRI Nominal CCT Min Typ Minimum Luminous Flux Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* K2 1200 1328 2-Step Group Order Code 3-Step Group Order Code 70 5000 K J4 1120 1239 J4 1120 1239 J2 1040 1151 H4 970 1073 80 50G 50G H2 900 996 K2 1200 1328 J4 1120 1239 J4 1120 1239 45G XHP50B-00-00000D0UH250G 1151 XHP50B-00-00000D0HJ245G H4 970 1073 XHP50B-00-00000D0UH445G H2 900 996 K2 1200 1328 40E 1120 1239 J4 1120 1239 J2 1040 1151 H4 970 1073 80 40H 90 40H H2 900 996 XHP50B-00-00000D0HJ440H XHP50B-00-00000D0HJ240H XHP50B-00-00000D0UH440H XHP50B-00-00000D0UH240H 40G 40G XHP50B-00-00000D0BJ445E XHP50B-00-00000D0UH245G 70 J4 XHP50B-00-00000D0BK245E XHP50B-00-00000D0HJ445G 1040 45G XHP50B-00-00000D0BJ450E XHP50B-00-00000D0UH450G J2 90 XHP50B-00-00000D0BK250E XHP50B-00-00000D0HJ250G 45E 80 Order Code XHP50B-00-00000D0HJ450G 70 4000 K Group 50E 90 4500 K 5-Step XHP50B-00-00000D0BK240E XHP50B-00-00000D0BJ440E XHP50B-00-00000D0HJ440G XHP50B-00-00000D0HJ240G XHP50B-00-00000D0UH440G XHP50B-00-00000D0UH240G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 25). • XLamp XHP50.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 3 3 XLAMP ® XHP50.2 LED FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS - CONTINUED CRI Nominal CCT Min Typ Minimum Luminous Flux Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* K2 1200 1328 2-Step Group Order Code 3-Step Group Order Code 70 3500 K Group 35E J4 1120 1239 J2 1040 1151 H4 970 1073 H4 970 1073 80 35H 90 35H H2 900 996 J4 1120 1239 J2 1040 1151 J2 1040 1151 XHP50B-00-00000D0HJ235H XHP50B-00-00000D0HH435H XHP50B-00-00000D0UH435H XHP50B-00-00000D0UH235H 35G 35G 30H XHP50B-00-00000D0HJ230H H4 970 1073 XHP50B-00-00000D0HH430H H2 900 996 XHP50B-00-00000D0UH230H G4 840 930 H4 970 1073 90 30H 80 27H XHP50B-00-00000D0UG430H XHP50B-00-00000D0HH427H H2 900 996 XHP50B-00-00000D0HH227H G4 840 930 XHP50B-00-00000D0UG427H G2 780 863 2700 K 90 27H XHP50B-00-00000D0UG227H 30G 30G 27G 27G XHP50B-00-00000D0BK235E XHP50B-00-00000D0BJ435E XHP50B-00-00000D0HH435G XHP50B-00-00000D0UH435G XHP50B-00-00000D0UH235G 30E 80 Order Code XHP50B-00-00000D0HJ235G 70 3000 K 5-Step XHP50B-00-00000D0BJ430E XHP50B-00-00000D0BJ230E XHP50B-00-00000D0HJ230G XHP50B-00-00000D0HH430G XHP50B-00-00000D0UH230G XHP50B-00-00000D0UG430G XHP50B-00-00000D0HH427G XHP50B-00-00000D0HH227G XHP50B-00-00000D0UG427G XHP50B-00-00000D0UG227G Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 25). • XLamp XHP50.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 4 4 XLAMP ® XHP50.2 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS The following table provides order codes for XLamp XHP50.2 LEDs. For a complete description of how the flux and chromaticity groups are reflected in the bin code and order code nomenclature, please see the Bin and Order Code Formats section (page 23). Binning condition: TJ = 85 °C; 12 V, IF = 700 mA Reference condition: TJ = 85 °C; 6 V, IF = 1400 mA Reference condition: TJ = 85 °C; 3 V, IF = 2800 mA 3‑V XHP50.2 LEDs CRI Nominal CCT Chromaticity Regions 7000 K 6200 K Minimum Luminous Flux Order Code Min Typ Group Flux l(m) @ 85 °C Flux (lm) @ 25 °C* 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U 0 68 K2 1200 1328 XHP50B-00-0000-0A00K20DT 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U, 3A, 3B, 3R, 3S 0 68 K2 1200 1328 XHP50B-00-0000-0A00K2051 6-V & 12‑V XHP50.2 LEDs Nominal CCT 7000 K CRI Chromaticity Regions 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U Minimum Luminous Flux Min Typ 0 68 70 80 6500 K 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U 0 70 80 68 Group Flux l(m) @ 85 °C Flux (lm) @ 25 °C* K2 1200 1328 Order Code XHP50B-00-0000-0D00K20DT J4 1120 1239 XHP50B-00-0000-0D00J40DT K2 1200 1328 XHP50B-00-0000-0D0BK20DT J4 1120 1239 XHP50B-00-0000-0D0BJ40DT J4 1120 1239 XHP50B-00-0000-0D0HJ40DT J2 1040 1151 XHP50B-00-0000-0D0HJ20DT K2 1200 1328 XHP50B-00-0000-0D00K20CB J4 1120 1239 XHP50B-00-0000-0D00J40CB K2 1200 1328 XHP50B-00-0000-0D0BK20CB J4 1120 1239 XHP50B-00-0000-0D0BJ40CB J4 1120 1239 XHP50B-00-0000-0D0HJ40CB J2 1040 1151 XHP50B-00-0000-0D0HJ20CB Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 25). • XLamp XHP50.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 5 5 XLAMP ® XHP50.2 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS - CONTINUED Nominal CCT 6500 K CRI Chromaticity Regions 1A, 1B, 1C, 1D Minimum Luminous Flux Min Typ 0 68 70 80 0 6000 K 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U 68 70 80 90 0 68 70 5700 K 2A, 2B, 2C, 2D 80 90 0 70 5000 K 3A, 3B, 3C, 3D 80 90 68 Group Flux l(m) @ 85 °C Flux (lm) @ 25 °C* K2 1200 1328 Order Code XHP50B-00-0000-0D00K20E1 J4 1120 1239 XHP50B-00-0000-0D00J40E1 K2 1200 1328 XHP50B-00-0000-0D0BK20E1 J4 1120 1239 XHP50B-00-0000-0D0BJ40E1 J4 1120 1239 XHP50B-00-0000-0D0HJ40E1 J2 1040 1151 XHP50B-00-0000-0D0HJ20E1 K2 1200 1328 XHP50B-00-0000-0D00K20DV J4 1120 1239 XHP50B-00-0000-0D00J40DV K2 1200 1328 XHP50B-00-0000-0D0BK20DV J4 1120 1239 XHP50B-00-0000-0D0BJ40DV J4 1120 1239 XHP50B-00-0000-0D0HJ40DV J2 1040 1151 XHP50B-00-0000-0D0HJ20DV J2 1040 1151 XHP50B-00-0000-0D0UJ20DV H4 970 1073 XHP50B-00-0000-0D0UH40DV K2 1200 1328 XHP50B-00-0000-0D00K20E2 J4 1120 1239 XHP50B-00-0000-0D00J40E2 K2 1200 1328 XHP50B-00-0000-0D0BK20E2 J4 1120 1239 XHP50B-00-0000-0D0BJ40E2 J4 1120 1239 XHP50B-00-0000-0D0HJ40E2 J2 1040 1151 XHP50B-00-0000-0D0HJ20E2 J2 1040 1151 XHP50B-00-0000-0D0UJ20E2 H4 970 1073 XHP50B-00-0000-0D0UH40E2 K2 1200 1328 XHP50B-00-0000-0D00K20E3 J4 1120 1239 XHP50B-00-0000-0D00J40E3 K2 1200 1328 XHP50B-00-0000-0D0BK20E3 J4 1120 1239 XHP50B-00-0000-0D0BJ40E3 J4 1120 1239 XHP50B-00-0000-0D0HJ40E3 J2 1040 1151 XHP50B-00-0000-0D0HJ20E3 J2 1040 1151 XHP50B-00-0000-0D0UJ20E3 H4 970 1073 XHP50B-00-0000-0D0UH40E3 Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 25). • XLamp XHP50.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 6 6 XLAMP ® XHP50.2 LED FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS - CONTINUED Nominal CCT CRI Chromaticity Regions Minimum Luminous Flux Min Typ 0 68 70 4500 K 4A, 4B, 4C, 4D 80 90 0 70 4000 K 5A, 5B, 5C, 5D 80 90 3500 K 3000 K 6A, 6B, 6C, 6D 7A, 7B, 7C, 7D 70 70 68 Group Flux l(m) @ 85 °C Flux (lm) @ 25 °C* K2 1200 1328 Order Code XHP50B-00-0000-0D00K20E4 J4 1120 1239 XHP50B-00-0000-0D00J40E4 K2 1200 1328 XHP50B-00-0000-0D0BK20E4 J4 1120 1239 XHP50B-00-0000-0D0BJ40E4 J4 1120 1239 XHP50B-00-0000-0D0HJ40E4 J2 1040 1151 XHP50B-00-0000-0D0HJ20E4 H4 970 1073 XHP50B-00-0000-0D0UH40E4 H2 900 996 XHP50B-00-0000-0D0UH20E4 K2 1200 1328 XHP50B-00-0000-0D00K20E5 J4 1120 1239 XHP50B-00-0000-0D00J40E5 K2 1200 1328 XHP50B-00-0000-0D0BK20E5 J4 1120 1239 XHP50B-00-0000-0D0BJ40E5 J4 1120 1239 XHP50B-00-0000-0D0HJ40E5 J2 1040 1151 XHP50B-00-0000-0D0HJ20E5 H4 970 1073 XHP50B-00-0000-0D0UH40E5 H2 900 996 XHP50B-00-0000-0D0UH20E5 K2 1200 1328 XHP50B-00-0000-0D0BK20E6 J4 1120 1239 XHP50B-00-0000-0D0BJ40E6 J4 1120 1239 XHP50B-00-0000-0D0BJ40E7 J2 1040 1151 XHP50B-00-0000-0D0BJ20E7 Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 25). • XLamp XHP50.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 7 7 XLAMP ® XHP50.2 LED FLUX CHARACTERISTICS - BROADCAST ORDER CODES AND BINS The following table provides order codes for XLamp XHP50.2 Broadcast LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 23). Binning condition: TJ = 85 °C; 12 V, IF = 700 mA Reference condition: TJ = 85 °C; 6 V, IF = 1400 mA Chromaticity Kit CCT E2 5700 K Minimum Luminous Flux (lm) @ 1050 mA Order Codes Flux Bin Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 90 CRI Minimum 90 TLCI Minimum H2 900 996 XHP50B-00-B001-AD0UH20E2 G4 840 930 95 CRI Minimum 95 TLCI Minimum XHP50B-00-B001-AD0ZG40E2 Notes • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 25). • XLamp XHP50.2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. * Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 8 8 XLAMP ® XHP50.2 LED Relative Spectral Power RELATIVE SPECTRAL POWER DISTRIBUTION 100% Relative Radiant Power 80% 60% 6500 K, 68 CRI 3000 K, 80 CRI 40% 20% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) RELATIVE FLUX VS. JUNCTION TEMPERATURE Relative Flux Output vs. Junction Temperature Reference condition: 3‑V, IF = 2800 mA; 6 V, IF = 1400 mA; 12 V, IF = 700 mA 120% Relative Luminous Flux 100% 80% 60% 40% 20% 0% 25 50 75 100 125 150 Junction Temperature (ºC) © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 9 9 XLAMP ® XHP50.2 LED ELECTRICAL CHARACTERISTICS (TJ = 85 °C) 6000 5500 Forward Current (mA) 5000 4500 4000 3500 3V 3000 2500 2000 1500 1000 500 0 2.55 2.60 2.65 2.70 2.75 2.80 2.85 2.90 2.95 Forward Voltage (V) 3000 2750 Forward Current (mA) 2500 2250 2000 1750 6V 1500 1250 1000 750 500 250 0 5.15 5.25 5.35 5.45 5.55 5.65 5.75 5.85 Forward Voltage (V) © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 10 10 XLAMP ® XHP50.2 LED Electrical Characteristics (Tj = 85°C) ELECTRICAL CHARACTERISTICS (TJ = 85 °C) - CONTINUED 1500 1375 Forward Current (mA) 1250 1125 1000 875 750 12 V 625 500 375 250 125 0 10.3 10.5 10.7 10.9 11.1 11.3 11.5 11.7 Forward Voltage (V) RELATIVE FLUX VS. CURRENT (TJ = 85 °C) 200% 180% Relative Luminous Flux 160% 140% 120% 100% 3V 80% 60% 40% 20% 0% 0 500 1000 1500 2000 2500 3000 3500 4000 4500 5000 5500 6000 Forward Current (mA) © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 11 11 XLAMP ® XHP50.2 LED RELATIVE FLUX VS. CURRENT (TJ = 85 °C) - CONTINUED 200% 180% Relative Luminous Flux 160% 140% 120% 100% 6V 80% 60% 40% 20% 0% Relative Intensity vs. Current (Tj = 85°C) Forward Current (mA) 0 250 500 750 1000 1250 1500 1750 2000 2250 2500 2750 3000 200% Relative Luminous Flux 180% 160% 140% 120% 100% 12 V 80% 60% 40% 20% 0% 0 125 250 375 500 625 750 875 1000 1125 1250 1375 1500 Forward Current (mA) © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 12 12 XLAMP ® XHP50.2 LED RELATIVE CHROMATICITY VS CURRENT (WARM WHITE) 0.020 0.016 0.012 3V 0.008 0.004 ΔCCx 0.000 ΔCCy -0.004 -0.008 -0.012 -0.016 -0.020 0 500 1000 1500 2000 2500 3000 3500 4000 4500 5000 5500 6000 Current (mA) 0.020 0.016 0.012 6V 0.008 0.004 ΔCCx 0.000 ΔCCy -0.004 -0.008 -0.012 -0.016 -0.020 0 250 500 750 1000 1250 1500 1750 2000 2250 2500 2750 3000 Current (mA) © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 13 13 XLAMP ® XHP50.2 LED RELATIVE CHROMATICITY VS CURRENT WHITE) - CONTINUED Relative Chromaticity Vs. Current,(WARM WW 0.020 0.016 0.012 12 V 0.008 0.004 ΔCCx 0.000 ΔCCy -0.004 -0.008 -0.012 -0.016 -0.020 0 125 250 375 500 625 750 875 1000 1125 1250 1375 1500 Current (mA) RELATIVE CHROMATICITY VS TEMPERATURE (WARM WHITE) Relative Chromaticity Vs. Temperature WW Reference condition: 3 V, IF = 2800 mA; 6 V, IF = 1400 mA; 12 V, IF = 700 mA 0.020 0.016 0.012 0.008 0.004 ΔCCx 0.000 ΔCCy -0.004 -0.008 -0.012 -0.016 -0.020 25 50 75 100 125 150 Tj (°C) © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 14 14 XLAMP ® XHP50.2 LED TYPICAL SPATIAL DISTRIBUTION Typical Spatial Radiation Pattern Reference condition: TJ = 85 °C; 3 V, IF = 2800 mA; 6 V, IF = 1400 mA; 12 V, IF = 700 mA Relative Luminous Intensity 100% 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) THERMAL DESIGN The maximum forward current is determined by the thermal resistance between the LED junction and ambient. It is crucial for the end product to be designed in a manner that minimizes the thermal resistance from the solder point to ambient in order to optimize lamp life and optical characteristics. 6400 Maximum Current (mA) 5600 3V 4800 4000 3200 2400 Rj-a = 2°C/W Rj-a = 4°C/W 1600 Rj-a = 6°C/W 800 0 Rj-a = 8°C/W 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 15 15 XLAMP ® XHP50.2 LED THERMAL DESIGN - CONTINUED 3200 Maximum Current (mA) 2800 6V 2400 2000 1600 1200 Rj-a = 2°C/W Rj-a = 4°C/W 800 Rj-a = 6°C/W 400 Rj-a = 8°C/W 0 0 20 Thermal Design 40 60 80 100 120 140 160 Ambient Temperature (ºC) 1600 Maximum Current (mA) 1400 12 V 1200 1000 800 600 Rj-a = 2°C/W Rj-a = 4°C/W 400 Rj-a = 6°C/W 200 0 Rj-a = 8°C/W 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 16 16 XLAMP ® XHP50.2 LED PERFORMANCE GROUPS – LUMINOUS FLUX (TJ = 85 °C) XLamp XHP50.2 LEDs are tested for luminous flux and placed into one of the following luminous-flux groups. Group Code Minimum Luminous Flux Maximum Luminous Flux G2 780 840 G4 840 900 H2 900 970 H4 970 1040 J2 1040 1120 J4 1120 1200 K2 1200 1290 K4 1290 1380 PERFORMANCE GROUPS – CHROMATICITY XLamp XHP50.2 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 2-Step Bin Code 40H 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3777 0.3739 0.3797 0.3816 0.3861 0.3855 0.3838 0.3777 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 17 17 XLAMP ® XHP50.2 LED PERFORMANCE GROUPS – CHROMATICITY (CONTINUED) EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 50G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 45G 4500 K 0.3611 0.3658 0.00852 0.00330 61.5 40G 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 EasyWhite Color Temperatures – 5-Step Ellipse Bin Code CCT 50E 45E Center Point Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.01400 0.00520 65.0 4500 K 0.3611 0.3658 0.01420 0.00550 61.5 40E 4000 K 0.3818 0.3797 0.01565 0.00670 53.7 35E 3500 K 0.4073 0.3917 0.01545 0.00690 54.0 30E 3000 K 0.4338 0.4030 0.01390 0.00680 53.2 ANSI White Bins CCT Major Axis Bin Code 0A0 0B0 7000 K 0C0 0D0 ANSI White Bins x y 0.2950 0.2970 0.2920 0.3060 0.2984 0.3133 0.3009 0.2920 0.2895 0.3135 0.2962 0.3220 0.2984 0.3133 0.2984 0.3133 0.2962 0.3220 0.3028 0.3304 0.3048 0.2984 0.3048 0.3207 0.3068 0.3113 0.3009 0.3042 CCT Bin Code ANSI White Bins x y 0.2980 0.2880 0.2950 0.2970 0.3009 0.3042 0.3042 0.3037 0.3060 0.2895 0.2870 0.3210 0.2937 0.3312 0.2962 0.3220 0.2962 0.3220 0.2937 0.3312 0.3005 0.3415 0.3207 0.3028 0.3133 0.3037 0.3009 0.3042 0.3068 0.3113 0.3093 0.2993 0R0 0S0 7000 K 0T0 0U0 CCT Bin Code x y 0.3048 0.3207 0.3130 0.3290 0.3144 0.3186 0.2937 0.3068 0.3113 0.3135 0.3028 0.3304 0.3115 0.3391 0.3130 0.3290 0.3048 0.3207 0.3115 0.3391 0.3205 0.3481 0.3213 0.3373 0.3304 0.3130 0.3290 0.2937 0.3130 0.3290 0.3213 0.3373 0.3221 0.3261 0.3144 0.3186 1A0 1B0 7000 K © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 1C0 1D0 CLD-DS150 REV 6 18 18 XLAMP ® XHP50.2 LED PERFORMANCE GROUPS – CHROMATICITY (CONTINUED) ANSI White Bins CCT Bin Code 1R0 1S0 7000 K 1T0 1U0 ANSI White Bins x y CCT 0.3068 0.3113 0.3144 0.3186 0.3161 0.3059 0.3093 0.3005 0.3099 0.3509 0.3115 0.3391 0.3028 0.3304 0.3099 0.3509 0.3196 0.3602 0.3205 0.3481 0.3115 0.3144 0.3221 0.3261 0.3231 0.3120 0.3161 0.3059 Bin Code x y 0.3215 0.3350 0.3290 0.3417 0.3290 0.3300 0.2993 0.3222 0.3415 0.3207 0.3290 0.3538 0.3290 0.3417 0.3215 0.3350 0.3290 0.3538 0.3376 0.3616 0.3371 0.3490 0.3391 0.3290 0.3186 0.3290 0.3371 0.3490 0.3366 0.3369 0.3290 0.3300 2A0 2B0 6000 K 2C0 2D0 ANSI White Bins CCT ANSI White Bins Bin Code 3A0 3B0 5000 K 3C0 3D0 CCT Bin Code x y 0.3222 0.3243 0.3290 0.3300 0.3290 0.3180 0.3243 0.3231 0.3120 0.3462 0.3196 0.3602 0.3290 0.3690 0.3290 0.3538 0.3207 0.3462 0.3290 0.3690 0.3381 0.3762 0.3376 0.3616 0.3417 0.3290 0.3538 0.3417 0.3290 0.3300 0.3366 0.3369 0.3361 0.3245 0.3290 0.3180 2R0 2S0 6000 K 2T0 2U0 ANSI White Bins x y 0.3371 0.3451 0.3440 0.3427 0.3366 0.3369 0.3376 0.3463 0.3451 0.3554 0.3371 0.3490 0.3463 0.3687 0.3551 0.3760 0.3533 0.3620 0.3451 0.3554 0.3451 0.3533 0.3515 0.3487 0.3440 0.3427 CCT Bin Code x y 0.3490 0.3530 0.3597 0.3554 0.3615 0.3659 0.3512 0.3465 0.3515 0.3487 0.3616 0.3548 0.3736 0.3687 0.3641 0.3804 0.3530 0.3597 0.3533 0.362 0.3641 0.3804 0.3736 0.3874 0.3702 0.3722 0.3615 0.3659 0.3554 0.3615 0.3659 0.3620 0.3702 0.3722 0.3670 0.3578 0.3590 0.3521 4A0 4B0 4500 K 4C0 4D0 © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 19 19 XLAMP ® XHP50.2 LED PERFORMANCE GROUPS – CHROMATICITY (CONTINUED) ANSI White Bins CCT Bin Code 5A0 5B0 4000 K 5C0 5D0 ANSI White Bins x y CCT 0.3670 0.3578 0.3702 0.3722 0.3825 0.3798 0.3783 0.3702 0.3736 0.3874 0.3869 0.3958 0.3825 0.3798 0.3825 0.3798 0.3869 0.3958 0.4006 0.4044 0.3950 0.3783 0.3825 0.3798 0.3950 0.3875 0.3898 0.3716 Bin Code ANSI White Bins x y 0.3889 0.3690 0.3941 0.3848 0.4080 0.3916 0.3646 0.4017 0.3722 0.3941 0.3996 0.4015 0.4146 0.4089 0.4080 0.3916 0.4080 0.3916 0.4146 0.4089 0.4299 0.4165 0.3875 0.4221 0.3646 0.4017 0.4080 0.3916 0.4221 0.3984 0.4147 0.3814 6A0 6B0 3500 K 6C0 6D0 CCT Bin Code x y 0.4147 0.3814 0.4221 0.3984 0.4342 0.4028 0.3751 0.4259 0.3853 0.3848 0.4221 0.3984 0.4299 0.4165 0.4430 0.4212 0.4342 0.4028 0.4342 0.4028 0.4430 0.4212 0.4562 0.4260 0.3984 0.4465 0.4071 0.3751 0.4259 0.3853 0.4342 0.4028 0.4465 0.4071 0.4373 0.3893 7A0 7B0 3000 K 7C0 7D0 EASYWHITE® CHROMATICITY REGIONS PLOTTED ON THE 1931 CIE CURVE 0.44 ANSI C78.377 Quadrangle 0.43 EasyWhite 5-Step EasyWhite 3-Step 0.42 3500 K EasyWhite 2-Step 0.41 2700 K 3000 K 4000 K 0.40 4500 K 0.39 5000 K 0.38 CCy 0.37 5700 K 0.36 6500 K 0.35 0.34 8000 K 0.33 0.32 0.31 0.30 0.29 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.27 0.28 CCx © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 20 20 XLAMP ® XHP50.2 LED ANSI COOL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.40 0.40 5000 K 0.39 0.38 0.38 5700 K 5700 K 0.37 0.37 6500 K 6500 K 2T 0.36 0.36 2S DT 0.34 0T 0C 0B 2U 0A ANSI C78.377A 1U 0D 0C 2A 0B 1U 0D 1R 0U 0.36 0.35 0.34 0.33 0.28 0.36 0.35 0.34 0.33 0.32 0.31 0.28 0.30 0.28 0.32 0R 0.29 CCx 0.40 0.40 5000 K 0.39 0.38 0.38 3S 6500 K 2C 8000 K 0.34 0T 0C 1U 0A ANSI C78.377A 2R 1A 1U 1R 0U 0.36 0.35 0.34 0.28 0.36 0.35 0.34 0.33 0.32 0.28 0.31 0.28 0.30 0.29 0.33 0R 0R 0.29 2U 1D 0D 0A 0.30 0.29 0.28 0C 0B 0.31 1R 0U 0.30 0S 0.32 3R 2A 1B 0.32 0.31 ANSI C78.377A 2R 1A 0D 0T 0.33 2U 2D 1C 0.31 0B 1D 3A 2B 1S 0.30 0S 0.32 3R 2A 1B 0.34 0.29 0.33 3B 2C 1T 8000 K 2D 1C 2T 2S 0.35 3A 2B 1S 0.36 3B 2S 1T 3S 51 6500 K 2T E1 0.35 5700 K 0.37 CCy 0.36 5000 K 0.39 5700 K 0.37 CCx CCx 0.40 0.40 5000 K 0.39 0.38 0.38 5700 K DV 0.37 6500 K 0.36 6500 K 0.32 1R CCx © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 0.36 0.29 0.28 0.36 0.35 0.34 0.33 0.28 0.32 0.28 0.31 0.29 0.30 1R 0R 0R 0.29 ANSI C78.377A 2R 1U 0U 0.30 0.29 0.28 2U 1D 1A 0D 0A 0U 0.30 0C 0B 0.31 3R 2A 1B 0.35 0A CCy 1U 0S 2D 1C 0.34 0.31 ANSI C78.377A 2R 1A 0D 0T 0.33 2U 3A 2B 1S 0.32 0C 0B 1D 8000 K 0.34 0.31 0S 0.32 2A 1B 2C 1T 0.30 0T 0.33 2D 3B 2S 0.35 2B 1C 3S 2T 0.36 1T 1S E2 0.37 2C 8000 K 0.34 5700 K 2T 2S 0.35 5000 K 0.39 0.33 CCy ANSI C78.377A 2R CCx CCy 2U 1D 1A 0A 0R 0.29 0S 2D 1C 1B 0.30 0.29 0.28 0T 0.31 1R 2B 1S 0.32 0U 0.30 0.34 0.33 2R 1A 2C 1T 8000 K 0.31 0.31 2A 1D 2S 0.30 0S 0.32 2D 1C 1B 2T CB 0.35 2B 1S 0.33 2C 1T 0.29 8000 K CCy 0.35 CCy 5000 K 0.39 CCx CLD-DS150 REV 6 21 21 XLAMP ® XHP50.2 LED ANSI WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.45 0.44 2700 K 3000 K 0.43 E7 0.42 3500 K 4000 K CCy 0.40 0.39 5000 K 0.38 E4 4B 3C 0.36 3B 3D 0.35 7B 6C 6B 7D 7A 5C 6D 5B 4C E3 0.37 E5 4500 K 7C E6 0.41 6A ANSI C78.377A 5D 5A 4D 4A 3A 0.34 0.50 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.33 CCx © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 22 22 XLAMP ® XHP50.2 LED BIN AND ORDER CODE FORMATS Bin codes and order codes for XHP50.2 LEDs are configured in the following manner: Order Code Bin Code Series XHP50B = XHP50.2 Series XHP50B = XHP50.2 Internal code Chromaticity group Minimum luminous flux group Vf Class A = 3-V D = 6-V/12-V configurable SSSSSS-BD-GGGG-HJKLMMNNN Chromaticity group CRI specification 0 = No Minimum CRI B = 70 CRI Minimum H = 80 CRI Minimum U = 90 CRI Minimum CRI specification 0 = No minimum CRI B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum SSSSSS-E-NNN-MMM-JK-L-PP Vf Class A = 3-V D = 6-V/12-V configurable Internal code Configuration B = Internal code D = Reel size Luminous flux group © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Voltage performance group Internal code CLD-DS150 REV 6 23 23 XLAMP ® XHP50.2 LED REFLOW SOLDERING CHARACTERISTICS In testing, Cree LED has found XLamp XHP50.2 LEDs to be compatible with JEDEC J‑STD‑020C, using the parameters listed below. As a general guideline, Cree LED recommends that users follow the recommended soldering profile provided by the manufacturer of the solder paste used, and therefore it is the lamp or luminaire manufacturer’s responsibility to determine applicable soldering requirements. Note that this general guideline may not apply to all PCB designs and configurations of reflow soldering equipment. tP TP Critical Zone TL to TP Temperature Ramp-up TL tL Tsmax Tsmin Ramp-down ts Preheat 25 t 25˚C to Peak Profile Feature Average Ramp-Up Rate (Tsmax to Tp) Time Lead-Free Solder 1.2 °C/second Preheat: Temperature Min (Tsmin) 120 °C Preheat: Temperature Max (Tsmax) 170 °C Preheat: Time (tsmin to tsmax) 65-150 seconds Time Maintained Above: Temperature (TL) Time Maintained Above: Time (tL) 217 °C 45-90 seconds Peak/Classification Temperature (Tp) 235 - 245 °C Time Within 5 °C of Actual Peak Temperature (tp) 20-40 seconds Ramp-Down Rate 1 - 6 °C/second Time 25 °C to Peak Temperature 4 minutes max. Note: All temperatures refer to the topside of the package, measured on the package body surface. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 24 24 XLAMP ® XHP50.2 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Cree LED did not perform Room Temperature Operating Life (RTOL) testing on the XHP50.2 LED. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. Moisture Sensitivity Cree LED recommends keeping XLamp LEDs in the provided, resealable moisture-barrier packaging (MBP) until immediately prior to soldering. Unopened MBPs that contain XLamp LEDs do not need special storage for moisture sensitivity. Once the MBP is opened, XLamp XHP50.2 LEDs may be stored as MSL 1 per JEDEC J-STD-033, meaning they have unlimited floor life in conditions of ≤ 30 ºC/85% relative humidity (RH). Regardless of the storage condition, Cree LED recommends sealing any unsoldered LEDs in the original MBP. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACH Compliance REACH substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACH SVHC Declaration. REACH banned substance information (REACH Article 67) is also available upon request. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 25 25 XLAMP ® XHP50.2 LED NOTES - CONTINUED UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 26 26 XLAMP ® XHP50.2 LED MECHANICAL DIMENSIONS Thermal vias, if present, are not shown on these drawings. All dimensions are ±.13 mm unless otherwise indicated. 8 7 6 4 5 5.00 . 1 2 3 4.78 3.58 2.78 0.56 0.50 F F 5.00 0.50 ANODE SIDE E 4.78 E 2.14 CATHODE SIDE R2.85 D OPTICAL MODEL ORIGIN OPTICAL MODEL ORIGIN TOP VIEW Top View 8 CENTER PAD IS ELECTRICALLY ISOLATED SOLDERMASK MAY BE PRESENT SIDE VIEW Bottom View Side View 7 6 4 5 1 2 3 4.78 4.78 C D BOTTOM VIEW C 2.78 0.50 F B 4.78 4.78 B 0.50 2.14 F E E 0.50 0.50 D 3V AND 6V PCB FOOTPRINT 7 6 UPDATE TO MODEL ORIGIN A INITIAL DRAWING RELEASED REV DESCRIPTION 24NOV21 TITLE: CHECKED 2610-500006 XHP50.3 HD ENG APPR. MFG APPR. Q.A. INTERPRET GEOMETRIC TOLERANCING PER: THIRD ANGLE PROJECTION MATERIAL SIZE DWG. NO. REV C MATERIAL FINISH FINISH B SHEET 1 OF 2 SCALE: 50:1 WEIGHT: 12V PCB FOOTPRINT2 3 APPLICATION D 12‑V PCB Footprint 4.78 (Thermal pad is connected to anode and cathode 0.50 0.76 0.50 and is not electrically isolated) 0.25 5 4 2 1 1 1.26 3‑V and 6‑V PCB Footprint 4.78 Depending2.78 on Vf Class (Thermal pad is electrically isolated) THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF CREE LED. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT WRITTEN PERMISSION OF CREE LED IS PROHIBITED. © 2021 CreeLED, Inc. a subsidiary of SMART Global Holdings, Inc. B TLING CreeLED, Inc. 4400 SILICON DR DURHAM, NC 27703 0.25 B 0.76 0.25 B C 0.50 4.78 4.78 0.52 0.50 C 0.29 0.76 8 PROPRIETARY AND CONFIDENTIAL DRAWN DATE DRAWING FILENAME A NAME 2610-500005 XHP50 HD 2.14 A UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS TOLERANCES: • ANGULAR: MACH 0.5° BEND 1° • ONE PLACE DECIMAL 0.5 • TWO PLACE DECIMAL 0.05 • INSIDE BEND RADII EQUAL MATERIAL • MACHINE/CASTING RADII 0.50 • RADII AND DIA: 0.10 0.76 A RECOMMENDED STENCIL OPENING UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS TOLERANCES: • ANGULAR: MACH 0.5° BEND 1° • ONE PLACE DECIMAL 0.5 • TWO PLACE DECIMAL 0.05 • INSIDE BEND RADII EQUAL MATERIAL • MACHINE/CASTING RADII 0.50 • RADII AND DIA: 0.10 A PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF CREE LED. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT WRITTEN PERMISSION OF CREE LED IS PROHIBITED. © 2021 CreeLED, Inc. a subsidiary of SMART Global Holdings, Inc. 8 7 6 5 4 INTERPRET GEOMETRIC TOLERANCING PER: A INITIAL DRAWING RELEASED REV DESCRIPTION MATERIAL DRAWN © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. TLING 24NOV21 CreeLED, Inc. 4400 SILICON DR DURHAM, NC 27703 TITLE: CHECKED 2610-500006 XHP50 HD MFG APPR. Q.A. THIRD ANGLE PROJECTION SIZE DWG. NO. REV C MATERIAL FINISH FINISH 3 DATE ENG APPR. A SHEET 2 OF 2 SCALE: 50:1 WEIGHT: APPLICATION 2 NAME 2 1 CLD-DS150 REV 6 1 27 27 2610-500005 XHP50 HD 3V, 6V AND 12V PCB SOLDER MASK OPENING DRAWING FILENAME 0.50 F 4.78 4.78 XLAMP ® XHP50.2 LED 0.50 2.14 F E 2.14 E 0.50 3V AND 6V PCB FOOTPRINT D 12V PCB FOOTPRINT 4.78 0.50 0.76 0.25 4.78 2.78 POSITIVE A 0.50 0.76 3V, 6V AND 12V PCB SOLDER MASK OPENING UNLESS OTHERWISE SPECIFIED: Recommended Stencil Opening DIMENSIONS ARE IN MILLIMETERS TOLERANCES: • ANGULAR: MACH 0.5° BEND 1° • ONE PLACE DECIMAL 0.5 • TWO PLACE DECIMAL 0.05 • INSIDE BEND RADII EQUAL MATERIAL • MACHINE/CASTING RADII 0.50 • RADII AND DIA: 0.10 A PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF CREE LED. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT WRITTEN PERMISSION OF CREE LED IS PROHIBITED. © 2021 CreeLED, Inc. a subsidiary of SMART Global Holdings, Inc. 7 6 A RECOMMENDED STENCIL OPENING NEGATIVE B 3‑V, 6‑V, and 12‑V PCB Soldermask Opening 8 B 0.76 0.25 B 0.25 SOLDER PAD LINK C 0.50 0.52 12 V 4.78 4.78 0.50 C 0.29 0.76 1.26 0.50 5 INTERPRET GEOMETRIC TOLERANCING PER: A INITIAL DRAWING RELEASED REV DESCRIPTION MATERIAL DRAWN 2 DATE TLING 24NOV21 CreeLED, Inc. 4400 SILICON DR DURHAM, NC 27703 TITLE: CHECKED 2610-500006 XHP50 HD ENG APPR. MFG APPR. Q.A. THIRD ANGLE PROJECTION FINISH 3 SIZE DWG. NO. REV C MATERIAL FINISH A SHEET 2 OF 2 SCALE: 50:1 WEIGHT: APPLICATION 4 NAME 2 1 1 ELECTRICAL CONFIGURATION 12 V 6V SOLDER PAD LINK NEGATIVE A POSITIVE A NEGATIVE B POSITIVE B POSITIVE A NEGATIVE B 6-V Configuration 12-V Configuration 6V NEGATIVE A POSITIVE A NEGATIVE B POSITIVE B © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 28 28 2610-500005 XHP50 HD 0.50 D DRAWING FILENAME MECHANICAL DIMENSIONS - CONTINUED XLAMP ® XHP50.2 LED TAPE AND REEL All Cree LED carrier tapes conform to EIA-481D, Automated Component Handling Systems Standard. All dimensions are ±.13 mm unless otherwise indicated. Po T E Do Bo R P2 W A Anode side F A P1 B D1 "H" Ko B-B SECTION Bo (on a place in the bottom of the corner radii) Ao (on a place in the bottom of the corner radii) R "I" Ao Item Dim. ITEM Ao Dim. 5.30 Bo Ao 5.30 5.40 Ko 3.70 DETAIL"H" DETAIL"I" A-A SECTION Bo Po 5.40 4.00 Ko Po P2 3.35 8.00 4.00 2.00 P1 T P1 E 0.36 8.00 1.75 ITEM F Do D1 W R Dim. 5.50 1.50 1.50 12.00 3deg P2 F 2.00 5.50 TDo 0.36 1.50 E D1 1.75 1.50 W R 12.00 5° NOTICE 1) All Cree LED carrier tapes conform to EIA-481D, Automated Component handling Systems Standard 2) Measurement tolerances unless indicated otherwise: .xx = ±.15 mm 2402-M022 XML3 © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 29 29 XLAMP ® XHP50.2 LED TAPE AND REEL - CONTINUED Feed Direction END START Trailer Loaded Pockets Leader Min. 160 mm empty pockets sealed with tape 500 Lamps Min. 400 mm empty pockets with min. 100 mm sealed Feed Direction Cover Tape Pocket Tape 13 mm 7” © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 30 30 XLAMP ® XHP50.2 LED PACKAGING © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp® and EasyWhite® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS150 REV 6 31 31
XHP50B-00-0000-0D0HH230G 价格&库存
很抱歉,暂时无法提供与“XHP50B-00-0000-0D0HH230G”相匹配的价格&库存,您可以联系我们找货
