XPLAWT-00-0000-000HU60Z7
    CREELED
    LED-3P_3.45X3.45MM_SM
    LED 照明 XLamp® XP-L 白色,暖色 3000K 2.95V 1.05A 125° 1414(3535 公制)
XPLAWT-00-0000-000HU60Z7 数据手册
PRODUCT FAMILY DATA SHEET XLamp® XP-L LEDs XP-L High Density LED PRODUCT DESCRIPTION XP-L High Intensity LED FEATURES TABLE OF CONTENTS XLamp® XP-L LEDs are available in two • Available in white, 70-CRI white, 80‑CRI Characteristics................................................ 2 versions: High Density (HD) and High Order Codes Suggested for New Designs - Intensity (HI). white, and 90‑CRI white • ANSI‑compatible chromaticity bins XP-L High Density........................................... 3 • Binned at 85 °C Order Codes Suggested for New Designs - The XLamp XP-L HD LED is the highest • Maximum drive current: 3000 mA XP-L High Intensity......................................... 8 performing discrete in Cree LED’s HD class • Low thermal resistance: 0.5 °C/W Relative Spectral Power Distribution........... 11 of LEDs, delivering the next generation of Relative Flux vs. Junction Temperature....... 11 lumen output and efficacy in the compact • Wide viewing angle: 125° (XP-L HD), 115° (XP-L HI) Electrical Characteristics.............................. 12 3.45 mm x 3.45 mm XP footprint. Cree LED’s • Unlimited floor life at ≤ 30 ºC/85% RH Relative Flux vs. Current............................... 12 HD LEDs, optimized to deliver maximum Relative Chromaticity vs. Current................. 13 • Reflow solderable - JEDEC J‑STD‑020C lumen output in a small form factor, enable • Electrically neutral thermal path Relative Chromaticity vs. Temperature........ 14 lighting manufacturers to improve the • RoHS and REACH compliant Typical Spatial Distribution........................... 15 performance of any lighting design, create • UL® recognized component (E349212) Thermal Design............................................. 15 smaller and less expensive systems, and Performance Groups - Luminous Flux......... 16 develop new lighting solutions that were Performance Groups - Chromaticity............ 17 previously not possible. Standard Cool White Kits Plotted on ANSI Standard Chromaticity Regions................... 20 The XLamp XP-L HI LED is the first of Cree Standard Warm and Neutral White Kits LED’s new class of high‑intensity LEDs Plotted on ANSI Standard Chromaticity optimized to deliver maximum candela Regions.......................................................... 21 through secondary optics. Built on Cree Standard Chromaticity Kits.......................... 23 LED’s ® Bin and Order Code Formats........................ 24 Platform, the XP-L HI LED delivers 120 Reflow Soldering Characteristics................. 25 percent more candela than the XP-L HD Notes............................................................. 26 LED through the same optic. The XP-L HI Mechanical Dimensions............................... 28 LED leverages the industry’s highest single- Tape and Reel................................................ 32 die performance and a new innovative Packaging...................................................... 36 primary optic design that radically reduces Appendix - Order Codes Not For New the optical source size to deliver both Designs.......................................................... 37 breakthrough SC5 Technology lumens and intensity. Cree LED / 4001 E. Hwy. 54, Suite 2000 / Durham, NC 27709 USA / +1.919.313.5330 / www.cree-led.com © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 1 XLAMP ® XP-L LED CHARACTERISTICS Characteristics Unit Thermal resistance, junction to solder point* °C/W 0.5 Viewing angle (FWHM) - XP-L High Density degrees 125 Viewing angle (FWHM) - XP-L High Intensity degrees 115 mV/°C -1.3 Temperature coefficient of voltage ESD withstand voltage (HBM per Mil-Std-883D) DC forward current Reverse voltage Typical Maximum V 8000 mA 3000 V 1 Forward voltage (@ 1050 mA, 85 °C) V LED junction temperature °C * Minimum 2.79 3.25 150 Thermal resistance measurement was performed per the JEDEC JESD51-14 standard. See the Thermal Resistance Measurement application note for more details. © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 2 XLAMP ® XP-L LED ORDER CODES SUGGESTED FOR NEW DESIGNS - XP-L HIGH DENSITY (TJ = 85 °C) The following tables provide order codes for XLamp XP-L High Density LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 24). For definitions of the chromaticity kits, please see the Standard Chromaticity Kits section (page 23). Chromaticity Minimum Luminous Flux (lm) @ 1050 mA Kit CCT Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 65 CRI Typical 70 CRI Minimum W2 500 549 XPLAWT-00-0000-0000W2051 XPLAWT-00-0000-000BW2051 51 6200 K V6 480 535 XPLAWT-00-0000-0000V6051 XPLAWT-00-0000-000BV6051 V5 460 513 XPLAWT-00-0000-0000V5051 XPLAWT-00-0000-000BV5051 W2 500 549 XPLAWT-00-0000-0000W2053 XPLAWT-00-0000-000BW2053 V6 480 535 XPLAWT-00-0000-0000V6053 XPLAWT-00-0000-000BV6053 V5 460 513 XPLAWT-00-0000-0000V5053 XPLAWT-00-0000-000BV5053 W2 500 549 XPLAWT-00-0000-0000W2050 XPLAWT-00-0000-000BW2050 V6 480 535 XPLAWT-00-0000-0000V6050 XPLAWT-00-0000-000BV6050 53 50 E1 E2 6000 K 6200 K 6500 K 5700 K Order Codes V5 460 513 XPLAWT-00-0000-0000V5050 XPLAWT-00-0000-000BV5050 W2 500 549 XPLAWT-00-0000-0000W20E1 XPLAWT-00-0000-000BW20E1 V6 480 535 XPLAWT-00-0000-0000V60E1 XPLAWT-00-0000-000BV60E1 V5 460 513 XPLAWT-00-0000-0000V50E1 XPLAWT-00-0000-000BV50E1 W2 500 549 XPLAWT-00-0000-0000W20E2 XPLAWT-00-0000-000BW20E2 V6 480 535 XPLAWT-00-0000-0000V60E2 XPLAWT-00-0000-000BV60E2 V5 460 513 XPLAWT-00-0000-0000V50E2 XPLAWT-00-0000-000BV50E2 Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). XLamp XP-L LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 3 XLAMP ® XP-L LED ORDER CODES SUGGESTED FOR NEW DESIGNS - XP-L HIGH DENSITY (TJ = 85 °C) - CONTINUED Chromaticity Kit E3 F4 E4 F5 E5 CCT 5000 K 4750 K 4500 K 4250 K 4000 K Minimum Luminous Flux (lm) @ 1050 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 70 CRI Minimum W2 500 549 XPLAWT-00-0000-000BW20E3 V6 480 535 XPLAWT-00-0000-000BV60E3 V5 460 513 XPLAWT-00-0000-000BV50E3 V4 440 491 XPLAWT-00-0000-000LV40E3 V3 420 468 XPLAWT-00-0000-000LV30E3 V2 400 446 XPLAWT-00-0000-000LV20E3 W2 500 549 XPLAWT-00-0000-000BW20F4 V6 480 535 XPLAWT-00-0000-000BV60F4 V5 460 513 XPLAWT-00-0000-000BV50F4 V4 440 491 XPLAWT-00-0000-000LV40F4 V3 420 468 XPLAWT-00-0000-000LV30F4 V2 400 446 XPLAWT-00-0000-000LV20F4 W2 500 549 XPLAWT-00-0000-000BW20E4 V6 480 535 XPLAWT-00-0000-000BV60E4 V5 460 513 XPLAWT-00-0000-000BV50E4 V4 440 491 XPLAWT-00-0000-000LV40E4 V3 420 468 XPLAWT-00-0000-000LV30E4 V2 400 446 XPLAWT-00-0000-000LV20E4 W2 500 549 XPLAWT-00-0000-000BW20F5 V6 480 535 XPLAWT-00-0000-000BV60F5 V5 460 513 XPLAWT-00-0000-000BV50F5 V4 440 491 XPLAWT-00-0000-000LV40F5 V3 420 468 XPLAWT-00-0000-000LV30F5 V2 400 446 XPLAWT-00-0000-000LV20F5 W2 500 549 XPLAWT-00-0000-000BW20E5 V6 480 535 XPLAWT-00-0000-000BV60E5 V5 460 513 XPLAWT-00-0000-000BV50E5 XPLAWT-00-0000-000LV50E5 XPLAWT-00-0000-000HV50E5 V4 440 491 XPLAWT-00-0000-000LV40E5 XPLAWT-00-0000-000HV40E5 V3 420 468 XPLAWT-00-0000-000LV30E5 XPLAWT-00-0000-000HV30E5 V2 400 446 XPLAWT-00-0000-000LV20E5 75 CRI Typical 80 CRI Minimum XPLAWT-00-0000-000LV50E3 XPLAWT-00-0000-000LV50F4 XPLAWT-00-0000-000LV50E4 XPLAWT-00-0000-000LV50F5 Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). XLamp XP-L LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 4 XLAMP ® XP-L LED ORDER CODES SUGGESTED FOR NEW DESIGNS - XP-L HIGH DENSITY (TJ = 85 °C) - CONTINUED Chromaticity Kit Z5 F6 CCT 4000 K 3700 K Minimum Luminous Flux (lm) @ 1050 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 70 CRI Minimum V6 480 535 XPLAWT-00-0000-000BV60Z5 V5 460 513 V4 440 491 V3 420 V2 400 V4 V3 V2 75 CRI Typical 80 CRI Minimum XPLAWT-00-0000-000BV50Z5 XPLAWT-00-0000-000LV50Z5 XPLAWT-00-0000-000HV50Z5 XPLAWT-00-0000-000BV40Z5 XPLAWT-00-0000-000LV40Z5 XPLAWT-00-0000-000HV40Z5 468 XPLAWT-00-0000-000LV30Z5 XPLAWT-00-0000-000HV30Z5 446 XPLAWT-00-0000-000LV20Z5 440 491 XPLAWT-00-0000-000LV40F6 XPLAWT-00-0000-000HV40F6 420 468 XPLAWT-00-0000-000LV30F6 XPLAWT-00-0000-000HV30F6 400 446 XPLAWT-00-0000-000LV20F6 Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). XLamp XP-L LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 5 XLAMP ® XP-L LED ORDER CODES SUGGESTED FOR NEW DESIGNS - XP-L HIGH DENSITY (TJ = 85 °C) - CONTINUED Chromaticity Kit CCT E6 3500 K Z6 F7 E7 Z7 F8 3500 K 3250 K 3000 K 3000 K 2850 K Minimum Luminous Flux (lm) @ 1050 mA Code Flux (lm) Flux (lm) @ 85 °C @ 25 °C* Order Codes 80 CRI Typical 80 CRI Minimum V4 440 491 XPLAWT-00-0000-000LV40E6 XPLAWT-00-0000-000HV40E6 V3 420 468 XPLAWT-00-0000-000LV30E6 XPLAWT-00-0000-000HV30E6 V2 400 446 XPLAWT-00-0000-000LV20E6 V4 440 491 XPLAWT-00-0000-000LV40Z6 XPLAWT-00-0000-000HV40Z6 V3 420 468 XPLAWT-00-0000-000LV30Z6 XPLAWT-00-0000-000HV30Z6 XPLAWT-00-0000-000HV20Z6 V2 400 446 XPLAWT-00-0000-000LV20Z6 U6 380 424 XPLAWT-00-0000-000LU60Z6 V4 440 491 XPLAWT-00-0000-000LV40F7 XPLAWT-00-0000-000HV40F7 V3 420 468 XPLAWT-00-0000-000LV30F7 XPLAWT-00-0000-000HV30F7 XPLAWT-00-0000-000HV20F7 V2 400 446 XPLAWT-00-0000-000LV20F7 U6 380 424 XPLAWT-00-0000-000LU60F7 V4 440 491 XPLAWT-00-0000-000LV40E7 XPLAWT-00-0000-000HV40E7 V3 420 468 XPLAWT-00-0000-000LV30E7 XPLAWT-00-0000-000HV30E7 XPLAWT-00-0000-000HV20E7 90 CRI Minimum V2 400 446 XPLAWT-00-0000-000LV20E7 U6 380 424 XPLAWT-00-0000-000LU60E7 U5 360 401 XPLAWT-00-0000-000UU50E7 U4 340 379 XPLAWT-00-0000-000UU40E7 U3 320 357 V3 400 468 XPLAWT-00-0000-000UU30E7 XPLAWT-00-0000-000LV30Z7 XPLAWT-00-0000-000HV30Z7 V2 400 446 XPLAWT-00-0000-000LV20Z7 XPLAWT-00-0000-000HV20Z7 U6 380 424 XPLAWT-00-0000-000LU60Z7 XPLAWT-00-0000-000HU60Z7 U5 360 401 XPLAWT-00-0000-000LU50Z7 U4 340 379 U3 320 357 V3 400 468 XPLAWT-00-0000-000LV30F8 XPLAWT-00-0000-000HV30F8 V2 400 446 XPLAWT-00-0000-000LV20F8 XPLAWT-00-0000-000HV20F8 U6 380 424 XPLAWT-00-0000-000LU60F8 XPLAWT-00-0000-000HU60F8 U5 360 401 XPLAWT-00-0000-000LU50F8 U4 340 379 XPLAWT-00-0000-000UU40F8 U3 320 357 XPLAWT-00-0000-000UU30F8 XPLAWT-00-0000-000UU50Z7 XPLAWT-00-0000-000UU40Z7 XPLAWT-00-0000-000UU30Z7 Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). XLamp XP-L LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 6 XLAMP ® XP-L LED ORDER CODES SUGGESTED FOR NEW DESIGNS - XP-L HIGH DENSITY (TJ = 85 °C) - CONTINUED Chromaticity Kit E8 Z8 CCT 2700 K 2700 K Minimum Luminous Flux (lm) @ 1050 mA Code Flux (lm) Flux (lm) @ 85 °C @ 25 °C* Order Codes 80 CRI Typical 80 CRI Minimum XPLAWT-00-0000-000HV30E8 90 CRI Minimum V3 400 468 XPLAWT-00-0000-000LV30E8 V2 400 446 XPLAWT-00-0000-000LV20E8 XPLAWT-00-0000-000HV20E8 U6 380 424 XPLAWT-00-0000-000LU60E8 XPLAWT-00-0000-000HU60E8 U5 360 401 XPLAWT-00-0000-000LU50E8 U4 340 379 XPLAWT-00-0000-000UU40E8 U3 320 357 XPLAWT-00-0000-000UU30E8 U2 300 334 XPLAWT-00-0000-000UU20E8 V2 400 446 XPLAWT-00-0000-000LV20Z8 XPLAWT-00-0000-000HV20Z8 U6 380 424 XPLAWT-00-0000-000LU60Z8 XPLAWT-00-0000-000HU60Z8 U5 360 401 XPLAWT-00-0000-000LU50Z8 XPLAWT-00-0000-000HU50Z8 U4 340 379 XPLAWT-00-0000-000LU40Z8 U3 320 357 XPLAWT-00-0000-000UU30Z8 U2 300 334 XPLAWT-00-0000-000UU20Z8 XPLAWT-00-0000-000UU40Z8 Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). XLamp XP-L LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 7 XLAMP ® XP-L LED ORDER CODES SUGGESTED FOR NEW DESIGNS - XP-L HIGH INTENSITY (TJ = 85 °C) The following tables provide order codes for XLamp XP-L High Intensity LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 24). For definitions of the chromaticity kits, please see the Standard Chromaticity Kits section (page 23). Chromaticity Minimum Luminous Flux (lm) @ 1050 mA Kit CCT Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 65 CRI Typical 70 CRI Minimum V4 440 491 XPLAWT-H0-0000-0000V4051 XPLAWT-H0-0000-000BV4051 51 6200 K V3 420 468 XPLAWT-H0-0000-0000V3051 XPLAWT-H0-0000-000BV3051 V2 400 446 XPLAWT-H0-0000-0000V2051 XPLAWT-H0-0000-000BV2051 V4 440 491 XPLAWT-H0-0000-0000V4053 XPLAWT-H0-0000-000BV4053 V3 420 468 XPLAWT-H0-0000-0000V3053 XPLAWT-H0-0000-000BV3053 V2 400 446 XPLAWT-H0-0000-0000V2053 XPLAWT-H0-0000-000BV2053 V4 440 491 XPLAWT-H0-0000-0000V4050 XPLAWT-H0-0000-000BV4050 V3 420 468 XPLAWT-H0-0000-0000V3050 XPLAWT-H0-0000-000BV3050 V2 400 446 XPLAWT-H0-0000-0000V2050 XPLAWT-H0-0000-000BV2050 V4 440 491 XPLAWT-H0-0000-0000V40E1 XPLAWT-H0-0000-000BV40E1 V3 420 468 XPLAWT-H0-0000-0000V30E1 XPLAWT-H0-0000-000BV30E1 V2 400 446 XPLAWT-H0-0000-0000V20E1 XPLAWT-H0-0000-000BV20E1 V4 440 491 XPLAWT-H0-0000-0000V40E2 XPLAWT-H0-0000-000BV40E2 V3 420 468 XPLAWT-H0-0000-0000V30E2 XPLAWT-H0-0000-000BV30E2 V2 400 446 XPLAWT-H0-0000-0000V20E2 XPLAWT-H0-0000-000BV20E2 53 50 E1 E2 6000 K 6200 K 6500 K 5700 K Order Codes Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). XLamp XP-L LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 8 XLAMP ® XP-L LED ORDER CODES SUGGESTED FOR NEW DESIGNS - XP-L HIGH INTENSITY (TJ = 85 °C) - CONTINUED Chromaticity Minimum Luminous Flux (lm) @ 1050 mA Kit CCT Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 70 CRI Minimum 75 CRI Typical V4 440 491 XPLAWT-H0-0000-000BV40E3 XPLAWT-H0-0000-000LV40E3 E3 5000 K V3 420 468 XPLAWT-H0-0000-000BV30E3 XPLAWT-H0-0000-000LV30E3 V2 400 446 XPLAWT-H0-0000-000BV20E3 XPLAWT-H0-0000-000LV20E3 V4 440 491 XPLAWT-H0-0000-000BV40F4 XPLAWT-H0-0000-000LV40F4 V3 420 468 XPLAWT-H0-0000-000BV30F4 XPLAWT-H0-0000-000LV30F4 V2 400 446 XPLAWT-H0-0000-000BV20F4 XPLAWT-H0-0000-000LV20F4 V4 440 491 XPLAWT-H0-0000-000BV40E4 XPLAWT-H0-0000-000LV40E4 V3 420 468 XPLAWT-H0-0000-000BV30E4 XPLAWT-H0-0000-000LV30E4 V2 400 446 XPLAWT-H0-0000-000BV20E4 XPLAWT-H0-0000-000LV20E4 V4 440 491 XPLAWT-H0-0000-000BV40F5 V3 420 468 XPLAWT-H0-0000-000BV30F5 XPLAWT-H0-0000-000BV20F5 F4 E4 F5 E5 F6 4750 K 4500 K 4250 K 4000 K 3700 K Order Codes V2 400 446 U6 380 424 V4 440 491 XPLAWT-H0-0000-000BV40E5 V3 420 468 XPLAWT-H0-0000-000BV30E5 XPLAWT-H0-0000-000BV20E5 V2 400 446 U6 380 424 80 CRI Minimum XPLAWT-H0-0000-000LV30F5 XPLAWT-H0-0000-000LV20F5 XPLAWT-H0-0000-000LU60F5 XPLAWT-H0-0000-000LV30E5 XPLAWT-H0-0000-000HV30E5 XPLAWT-H0-0000-000LV20E5 XPLAWT-H0-0000-000HV20E5 XPLAWT-H0-0000-000LU60E5 XPLAWT-H0-0000-000HU60E5 V2 400 446 XPLAWT-H0-0000-000LV20F6 XPLAWT-H0-0000-000HV20F6 U6 380 424 XPLAWT-H0-0000-000LU60F6 XPLAWT-H0-0000-000HU60F6 U5 360 401 XPLAWT-H0-0000-000HU50F6 Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). XLamp XP-L LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 9 XLAMP ® XP-L LED ORDER CODES SUGGESTED FOR NEW DESIGNS - XP-L HIGH INTENSITY (TJ = 85 °C) - CONTINUED Chromaticity Minimum Luminous Flux (lm) @ 1050 mA Kit CCT Code V2 400 446 XPLAWT-H0-0000-000LV20E6 XPLAWT-H0-0000-000HV20E6 E6 3500 K U6 380 424 XPLAWT-H0-0000-000LU60E6 XPLAWT-H0-0000-000HU60E6 U5 360 401 V2 400 446 XPLAWT-H0-0000-000LV20F7 XPLAWT-H0-0000-000HV20F7 U6 380 424 XPLAWT-H0-0000-000LU60F7 XPLAWT-H0-0000-000HU60F7 U5 360 401 XPLAWT-H0-0000-000LU50F7 XPLAWT-H0-0000-000HU50F7 F7 E7 F8 E8 3250 K 3000 K 2850 K 2700 K Flux (lm) Flux (lm) @ 85 °C @ 25 °C* Order Codes 80 CRI Typical 80 CRI Minimum 90 CRI Minimum XPLAWT-H0-0000-000HU50E6 V2 400 446 XPLAWT-H0-0000-000LV20E7 XPLAWT-H0-0000-000HV20E7 U6 380 424 XPLAWT-H0-0000-000LU60E7 XPLAWT-H0-0000-000HU60E7 U5 360 401 XPLAWT-H0-0000-000LU50E7 XPLAWT-H0-0000-000HU50E7 U4 340 379 U3 320 357 XPLAWT-H0-0000-000UU30E7 U2 300 334 XPLAWT-H0-0000-000UU20E7 T6 280 312 U6 380 424 XPLAWT-H0-0000-000LU60F8 XPLAWT-H0-0000-000HU60F8 XPLAWT-H0-0000-000UT60E7 U5 360 401 XPLAWT-H0-0000-000LU50F8 XPLAWT-H0-0000-000HU50F8 U4 340 379 U3 320 357 U2 300 334 XPLAWT-H0-0000-000UU20F8 T6 280 312 XPLAWT-H0-0000-000UT60F8 T5 260 290 XPLAWT-H0-0000-000UT50F8 U6 380 424 XPLAWT-H0-0000-000LU60E8 XPLAWT-H0-0000-000HU60E8 U5 360 401 XPLAWT-H0-0000-000LU50E8 XPLAWT-H0-0000-000HU50E8 U4 340 379 U3 320 357 U2 300 334 XPLAWT-H0-0000-000UU20E8 T6 280 312 XPLAWT-H0-0000-000UT60E8 T5 260 290 XPLAWT-H0-0000-000UT50E8 XPLAWT-H0-0000-000HU40F8 XPLAWT-H0-0000-000HU40E8 Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). XLamp XP-L LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 10 XLAMP ® XP-L LED Relative Spectral Power RELATIVE SPECTRAL POWER DISTRIBUTION Relative Radiant Power 100% 80% 60% 5000 K - 8300 K CCT 2600 K - 3700 K CCT 40% 20% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Relative Flux Output vs. Junction Temperature RELATIVE FLUX VS. JUNCTION TEMPERATURE (IF = 1050 mA) 120% 110% Relative Luminous Flux 100% 90% 80% 70% 60% 50% 40% 30% 20% 10% 0% 25 50 75 100 125 150 Junction Temperature (ºC) © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 11 XLAMP ® XP-L LED Electrical Characteristics (Tj = 85°C) after Vf change ELECTRICAL CHARACTERISTICS (TJ = 85 °C) 3000 Forward Current (mA) 2500 2000 1500 1000 500 2.5 2.6 2.7 2.8 Relative Intensity vs. Current (Tj = 85°C) 0 2.9 3.0 3.1 2000 2500 3000 Forward Voltage (V) RELATIVE FLUX VS. CURRENT (TJ = 85 °C) 250% Relative Luminous Flux 200% 150% 100% 50% 0% 0 500 1000 1500 Forward Current (mA) © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 12 XLAMP ® XP-L LED Relative Chromaticity Vs. Current, HD, ww RELATIVE CHROMATICITY VS. CURRENT (WARM WHITE) 0.020 0.016 XP-L High Density 0.012 0.008 0.004 ΔCCx 0.000 ΔCCy -0.004 -0.008 -0.012 -0.016 -0.020 0 500 1000 Relative Chromaticity Vs. Current, HI, ww 1500 2000 2500 3000 Current (mA) 0.020 0.016 XP-L High Intensity 0.012 0.008 0.004 ΔCCx 0.000 ΔCCy -0.004 -0.008 -0.012 -0.016 -0.020 0 500 1000 1500 2000 2500 3000 Current (mA) © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 13 XLAMP ® XP-L LED Relative Chromaticity Vs. Temperature, HD, ww RELATIVE CHROMATICITY VS. TEMPERATURE (WARM WHITE) 0.020 0.016 XP-L High Density 0.012 0.008 0.004 ΔCCx 0.000 ΔCCy -0.004 -0.008 -0.012 -0.016 Relative Chromaticity Vs. Temperature, HI, ww -0.020 25 50 75 100 125 150 Tsp (°C) 0.020 0.016 XP-L High Intensity 0.012 0.008 0.004 ΔCCx 0.000 ΔCCy -0.004 -0.008 -0.012 -0.016 -0.020 25 50 75 100 125 150 Tsp (°C) © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 14 XLAMP ® XP-L LED Typical Radiation TYPICAL SPATIALSpatial DISTRIBUTION Pattern 100% Relative Luminous Intensity 80% 60% XP-L High Density XP-L High Intensity 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) THERMAL DESIGN The maximum forward current is determined by the thermal resistance between the LED junction and ambient. It is crucial for the end Thermal Design thecoeff thermal resistance from the solder point to ambient in order to optimize lamp life Coolproduct White to be designed in a manner that minimizes after temp change and optical characteristics. 3500 Maximum Current (mA) 3000 2500 2000 1500 Rj-a = 4°C/W 1000 Rj-a = 7°C/W Rj-a = 10°C/W 500 Rj-a = 15°C/W 0 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 15 XLAMP ® XP-L LED PERFORMANCE GROUPS - LUMINOUS FLUX XLamp XP-L LEDs are tested for luminous flux and placed into one of the following luminous‑flux groups: Group Code Minimum Luminous Flux (lm) @ 1050 mA Maximum Luminous Flux (lm) @ 1050 mA T3 220 240 T4 240 260 T5 260 280 T6 280 300 U2 300 320 U3 320 340 U4 340 360 U5 360 380 U6 380 400 V2 400 420 V3 420 440 V4 440 460 V5 460 480 V6 480 500 W2 500 520 W3 520 540 © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 16 XLAMP ® XP-L LED PERFORMANCE GROUPS - CHROMATICITY Region 0A 0R 1A 1R 2A 2R 3A 4A 4R x y 0.2950 0.2970 0.2920 0.3060 0.2984 0.3133 0.3009 Region x y 0.2920 0.3060 x y x y 0.2984 0.3133 0.2984 0.3133 0.2895 0.3135 0.2962 0.3220 0.3048 0.3207 0.2962 0.3220 0.3028 0.3304 0.3068 0.3113 0.3042 0.2984 0.3133 0.3048 0.3207 0.3009 0.3042 0.2980 0.2880 0.2895 0.3135 0.2962 0.3220 0.3037 0.2937 0.2950 0.2970 0.2870 0.3210 0.2937 0.3312 0.3009 0.3042 0.3009 0.3042 0.2937 0.3312 0.3005 0.3415 0.3068 0.3113 0.3037 0.2937 0.2962 0.3220 0.3028 0.3304 0.3093 0.2993 0.3048 0.3207 0.3028 0.3304 0.3115 0.3391 0.3130 0.3290 0.3130 0.3290 0.3115 0.3391 0.3205 0.3481 0.3213 0.3373 0.3144 0.3186 0.3130 0.3290 0.3213 0.3373 0.3221 0.3261 0.3068 0.3113 0.3048 0.3207 0.3130 0.3290 0.3144 0.3186 0.3068 0.3113 0.3005 0.3415 0.3099 0.3509 0.3144 0.3186 0.3144 0.3186 0.3099 0.3509 0.3196 0.3602 0.3221 0.3261 0.3161 0.3059 0.3115 0.3391 0.3205 0.3481 0.3231 0.3120 0.3093 0.2993 0.3028 0.3304 0.3115 0.3391 0.3161 0.3059 0.3215 0.3350 0.3207 0.3462 0.3290 0.3538 0.3290 0.3417 0.3290 0.3417 0.3290 0.3538 0.3376 0.3616 0.3371 0.3490 0.3290 0.3300 0.3290 0.3417 0.3371 0.3490 0.3366 0.3369 0.3222 0.3243 0.3215 0.3350 0.3290 0.3417 0.3290 0.3300 0.3222 0.3243 0.3196 0.3602 0.3290 0.3690 0.3290 0.3300 0.3290 0.3300 0.3290 0.3690 0.3381 0.3762 0.3366 0.3369 0.3290 0.3180 0.3290 0.3538 0.3376 0.3616 0.3361 0.3245 0.3231 0.3120 0.3207 0.3462 0.3290 0.3538 0.3290 0.3180 0.3371 0.3490 0.3376 0.3616 0.3366 0.3369 0.3381 0.3762 0.3451 0.3554 0.3463 0.3687 0.3440 0.3428 0.3480 0.3840 0.3440 0.3427 0.3451 0.3554 0.3429 0.3307 0.3463 0.3687 0.3366 0.3369 0.3371 0.3490 0.3361 0.3245 0.3376 0.3616 0.3530 0.3597 0.3548 0.3736 0.3641 0.3804 0.3615 0.3659 0.3615 0.3659 0.3641 0.3804 0.3736 0.3874 0.3702 0.3722 0.3590 0.3521 0.3615 0.3659 0.3702 0.3722 0.3670 0.3578 0.3512 0.3465 0.3530 0.3597 0.3615 0.3659 0.3590 0.3521 0.3512 0.3465 0.3571 0.3907 0.3668 0.3957 0.3590 0.3521 0.3590 0.3521 0.3668 0.3957 0.3771 0.4034 0.3670 0.3578 0.3567 0.3389 0.3641 0.3804 0.3736 0.3874 0.3640 0.3440 0.3495 0.3339 0.3548 0.3736 0.3641 0.3804 0.3567 0.3389 0B 0S 1B 1S 2B 2S 3B 4B 4S Region 0C 0T 1C 1T 2C 2T 3R 4C 4T © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. Region 0D 0U 1D 1U 2D 2U 3S 4D 4U CLD-DS97 REV 11 17 XLAMP ® XP-L LED PERFORMANCE GROUPS - CHROMATICITY (CONTINUED) Region 5A1 5B1 5C1 5D1 6A1 6B1 6C1 6D1 7A1 x y 0.3670 0.3578 0.3686 0.3649 0.3744 0.3685 0.3726 0.3612 0.3702 0.3722 0.3719 0.3797 0.3782 0.3837 0.3763 Region x y 0.3686 0.3649 x y x y 0.3744 0.3685 0.3726 0.3612 0.3702 0.3722 0.3763 0.3760 0.3744 0.3685 0.3763 0.3760 0.3744 0.3685 0.3825 0.3798 0.3804 0.3721 0.3804 0.3721 0.3783 0.3646 0.3719 0.3797 0.3782 0.3837 0.3763 0.3760 0.3736 0.3874 0.3802 0.3916 0.3782 0.3837 0.3802 0.3916 0.3869 0.3958 0.3847 0.3877 0.3760 0.3782 0.3837 0.3847 0.3877 0.3825 0.3798 0.3825 0.3798 0.3847 0.3877 0.3912 0.3917 0.3887 0.3836 0.3847 0.3877 0.3869 0.3958 0.3937 0.4001 0.3912 0.3917 0.3912 0.3917 0.3937 0.4001 0.4006 0.4044 0.3978 0.3958 0.3887 0.3836 0.3912 0.3917 0.3978 0.3958 0.3950 0.3875 0.3783 0.3646 0.3804 0.3721 0.3863 0.3758 0.3840 0.3681 0.3804 0.3721 0.3825 0.3798 0.3887 0.3836 0.3863 0.3758 0.3863 0.3758 0.3887 0.3836 0.3950 0.3875 0.3924 0.3794 0.3840 0.3681 0.3863 0.3758 0.3924 0.3794 0.3898 0.3716 0.3889 0.3690 0.3915 0.3768 0.3981 0.3800 0.3953 0.3720 0.3915 0.3768 0.3941 0.3848 0.4010 0.3882 0.3981 0.3800 0.3981 0.3800 0.4010 0.3882 0.4080 0.3916 0.4048 0.3832 0.3953 0.3720 0.3981 0.3800 0.4048 0.3832 0.4017 0.3751 0.3941 0.3848 0.3968 0.3930 0.4040 0.3966 0.4010 0.3882 0.3968 0.3930 0.3996 0.4015 0.4071 0.4052 0.4040 0.3966 0.4040 0.3966 0.4071 0.4052 0.4146 0.4089 0.4113 0.4001 0.4010 0.3882 0.4040 0.3966 0.4113 0.4001 0.4080 0.3916 0.4080 0.3916 0.4113 0.4001 0.4186 0.4037 0.4150 0.3950 0.4113 0.4001 0.4146 0.4089 0.4222 0.4127 0.4186 0.4037 0.4186 0.4037 0.4222 0.4127 0.4299 0.4165 0.4259 0.4073 0.4150 0.3950 0.4186 0.4037 0.4259 0.4073 0.4221 0.3984 0.4017 0.3751 0.4048 0.3832 0.4116 0.3865 0.4082 0.3782 0.4048 0.3832 0.4080 0.3916 0.4150 0.3950 0.4116 0.3865 0.4116 0.3865 0.4150 0.3950 0.4221 0.3984 0.4183 0.3898 0.4082 0.3782 0.4116 0.3865 0.4183 0.3898 0.4147 0.3814 0.4147 0.3814 0.4183 0.3898 0.4242 0.3919 0.4203 0.3833 0.4183 0.3898 0.4221 0.3984 0.4281 0.4006 0.4242 0.3919 0.4242 0.3919 0.4281 0.4006 0.4342 0.4028 0.4300 0.3939 0.4203 0.3833 0.4242 0.3919 0.4300 0.3939 0.4259 0.3853 5A2 5B2 5C2 5D2 6A2 6B2 6C2 6D2 7A2 Region 5A3 5B3 5C3 5D3 6A3 6B3 6C3 6D3 7A3 © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. Region 5A4 5B4 5C4 5D4 6A4 6B4 6C4 6D4 7A4 CLD-DS97 REV 11 18 XLAMP ® XP-L LED PERFORMANCE GROUPS - CHROMATICITY (CONTINUED) Region 7B1 7C1 7D1 8A1 8B1 8C1 8D1 x y 0.4221 0.3984 0.4259 0.4073 0.4322 0.4096 0.4281 0.4006 0.4342 0.4028 0.4385 0.4119 0.4449 0.4141 0.4403 Region x y 0.4259 0.4073 x y x y 0.4322 0.4096 0.4281 0.4006 0.4299 0.4165 0.4364 0.4188 0.4322 0.4096 0.4364 0.4188 0.4322 0.4096 0.4430 0.4212 0.4385 0.4119 0.4385 0.4119 0.4342 0.4028 0.4385 0.4119 0.4449 0.4141 0.4403 0.4049 0.4430 0.4212 0.4496 0.4236 0.4449 0.4141 0.4496 0.4236 0.4562 0.4260 0.4513 0.4164 0.4049 0.4449 0.4141 0.4513 0.4164 0.4465 0.4071 0.4259 0.3853 0.4300 0.3939 0.4359 0.3960 0.4316 0.3873 0.4300 0.3939 0.4342 0.4028 0.4403 0.4049 0.4359 0.3960 0.4359 0.3960 0.4403 0.4049 0.4465 0.4071 0.4418 0.3981 0.4316 0.3873 0.4359 0.3960 0.4418 0.3981 0.4373 0.3893 0.4373 0.3893 0.4418 0.3981 0.4475 0.3994 0.4428 0.3906 0.4418 0.3981 0.4465 0.4071 0.4523 0.4085 0.4475 0.3994 0.4475 0.3994 0.4523 0.4085 0.4582 0.4099 0.4532 0.4008 0.4428 0.3906 0.4475 0.3994 0.4532 0.4008 0.4483 0.3919 0.4465 0.4071 0.4513 0.4164 0.4573 0.4178 0.4523 0.4085 0.4513 0.4164 0.4562 0.4260 0.4624 0.4274 0.4573 0.4178 0.4573 0.4178 0.4624 0.4274 0.4687 0.4289 0.4634 0.4193 0.4523 0.4085 0.4573 0.4178 0.4634 0.4193 0.4582 0.4099 0.4582 0.4099 0.4634 0.4193 0.4695 0.4207 0.4641 0.4112 0.4634 0.4193 0.4687 0.4289 0.4750 0.4304 0.4695 0.4207 0.4695 0.4207 0.4750 0.4304 0.4813 0.4319 0.4756 0.4221 0.4641 0.4112 0.4695 0.4207 0.4756 0.4221 0.4700 0.4126 0.4483 0.3919 0.4532 0.4008 0.4589 0.4021 0.4538 0.3931 0.4532 0.4008 0.4582 0.4099 0.4641 0.4112 0.4589 0.4021 0.4589 0.4021 0.4641 0.4112 0.4700 0.4126 0.4646 0.4034 0.4538 0.3931 0.4589 0.4021 0.4646 0.4034 0.4593 0.3944 7B2 7C2 7D2 8A2 8B2 8C2 8D2 Region 7B3 7C3 7D3 8A3 8B3 8C3 8D3 © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. Region 7B4 7C4 7D4 8A4 8B4 8C4 8D4 CLD-DS97 REV 11 19 XLAMP ® XP-L LED STANDARD COOL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.40 0.40 5000 K 0.39 0.38 3S 51 6500 K 0.36 8000 K 0T 0C 0D 0A 0S CCy 0.32 1R 0C 0D 0A 0U CCx CCx 0.40 0.40 5000 K 0.39 5000 K 0.39 0.38 5700 K 0.38 6500 K 0.36 2T 6500 K 8000 K 1U 0.31 1R 0.36 0.35 CCx 0.34 0.28 0.36 0.35 0.34 0.33 0.32 0.28 0.31 0.28 0.30 1R 0R 0.29 0.29 ANSI C78.377A 2R 1U 0U 0.30 0R 2U 1A 0D 0A 0U 0.29 0.28 0C 0B 1D 0.33 0A 0.30 0S 0.32 3R 2A 1B 0.32 0.31 ANSI C78.377A 2R 1A 0D 0T 0.33 2U 3A 2D 1C 0.31 0C 0B 1D 2C 2B 1S 3R 2A 1B 3B 2S 1T 8000 K 0.34 0.30 0S 0.32 2D 1C 0.29 0T 0.33 3A 2B 1S 2T E1 0.35 CCy 0.34 0.36 3B 2C 1T 3S 0.37 2S 0.35 5700 K 3S 50 0.37 CCy 0.36 0.30 0.29 0.28 0.36 0.35 0.34 0.33 0.32 0.28 0.31 0.28 0.30 0.29 0.29 1R 0R 0.29 0.28 1U 0U 0.30 0R ANSI C78.377A 2R 1A 0B 0.31 2U 1D 0.35 0.30 1U 3R 2A 1B 0.34 0.31 ANSI C78.377A 2R 1A 2D 1C 0.33 0B 0T 3A 2B 1S 0.33 2U 1D 0.34 0.32 0S 0.32 8000 K 3R 2A 1B 3B 2C 1T 3A 2D 1C 3S 2T 2S 0.35 0.31 0.33 0.36 3B 2B 1S 53 6500 K 2C 1T 0.34 5700 K 0.37 2T 2S 0.35 CCy 0.38 5700 K 0.37 5000 K 0.39 CCx 0.40 5000 K 0.39 0.38 5700 K E2 0.37 6500 K 0.36 3B 2S 0.35 CCy 3S 2T 2C 1T 8000 K 0.34 0T 0.33 0S 0.32 0C 0.31 0A 3R 2A 2U 1D ANSI C78.377A 2R 1A 0D 2D 1C 1B 0B 3A 2B 1S 1U 1R 0U 0.30 0R 0.29 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.28 CCx © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 20 XLAMP ® XP-L LED STANDARD WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.46 0.45 2700 K 3000 K 0.44 0.43 0.42 4000 K 0.41 E6 4500 K E5 0.40 CCy E7 3500 K 5000 K 0.39 0.38 E3 0.37 0.36 5B4 4C 4B 3C 4D 3B 6B2 5C3 5C2 5B1 5D2 5A3 5D4 6A1 5A2 5D1 5A4 5A1 6D2 6A3 5D3 6A2 6A4 6D1 7A4 7A1 6D4 7D1 8B3 8C1 8B4 8C2 8C3 8C4 8D3 8D2 8D4 8A4 8D1 8A1 7D4 8B2 8A3 8A2 7D3 7D2 7A3 7A2 6D3 8B1 7C4 7C1 7B4 7B1 6C4 6C1 6B4 5C4 6B1 5C1 5B2 6C2 6B3 5B3 E4 6C3 7C2 7B3 7B2 7C3 E8 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx 0.46 0.45 2700 K 3000 K 0.44 0.43 3500 K 0.42 4000 K 0.41 4500 K CCy 0.40 F5 5000 K 0.39 F4 0.38 0.37 4B 4D 3B 5C4 5C1 5B4 3C 0.36 5B3 5B1 5D2 5A3 5D4 6A1 5A2 5D1 5A4 5A1 6C2 6B3 6B4 6B1 5D3 6A2 6A3 6A4 7B2 6C3 6B2 5C3 5C2 5B2 4C F6 F7 6C1 6D2 6D1 7B1 6C4 6D3 6D4 7A2 7A1 7A4 F8 7A3 7D1 7C2 7B3 7B4 7C1 7D4 8B1 7C4 7D3 7D2 7C3 8A1 8A2 8B2 8B3 8B4 8A3 8D2 8C1 8C2 8C3 8C4 8D3 8D4 8A4 8D1 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 21 XLAMP ® XP-L LED STANDARD WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS CONTINUED 0.46 0.45 2700 K 3000 K 0.44 0.43 0.42 Z6 4000 K 0.41 Z5 4500 K 0.40 CCy Z7 3500 K 6C3 6C2 6B3 6B2 5C3 5000 K 0.39 5C2 5B3 5C1 5B2 5B4 0.38 4C 0.37 4B 3C 0.36 4D 3B 6B4 5C4 6B1 5D3 6A2 5B1 5D2 5A3 5D4 6A1 5A2 5D1 5A4 5A1 6A3 6A4 6C1 6D2 6D1 7B1 6C4 6D3 6D4 7A2 7A1 7A4 7B4 7A3 7D1 7C2 7B3 7B2 7C1 7D4 8B1 7C4 7D3 7D2 7C3 8A1 8A2 8A3 8B2 Z8 8B3 8B4 8D2 8C1 8C2 8C3 8C4 8D3 8D4 8A4 8D1 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 22 XLAMP ® XP-L LED STANDARD CHROMATICITY KITS The following table provides the chromaticity bins associated with chromaticity kits. Color Cool White Neutral White Warm White CCT Kit Chromaticity Bins 6200 K 51 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U, 3A, 3B, 3R, 3S 6000 K 53 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 3A, 3B, 3S 6200 K 50 1A, 1B, 1C, 1D, 2A, 2B, 2C, 2D 6500 K E1 1A, 1B, 1C, 1D 5700 K E2 2A, 2B, 2C, 2D 5000 K E3 3A, 3B, 3C, 3D 4750 K F4 3C, 3D, 4A, 4B 4500 K E4 4A, 4B, 4C, 4D 4250 K F5 4C, 4D, 5A1, 5A2, 5A3, 5A4, 5B1, 5B2, 5B3, 5B4 4000 K E5 5A1, 5A2, 5A3, 5A4, 5B1, 5B2, 5B3, 5B4, 5C1, 5C2, 5C3, 5C4, 5D1, 5D2, 5D3, 5D4 4000 K Z5 5A3, 5B4, 5C1, 5D2 3750 K F6 5C1, 5C2, 5C3, 5C4, 5D1, 5D2, 5D3, 5D4, 6A1, 6A2, 6A3, 6A4, 6B1, 6B2, 6B3, 6B4 3500 K E6 6A1, 6A2, 6A3, 6A4, 6B1, 6B2, 6B3, 6B4, 6C1, 6C2, 6C3, 6C4, 6D1, 6D2, 6D3, 6D4 3500 K Z6 6A3, 6B4, 6C1, 6D2 3250 K F7 6C1, 6C2, 6C3, 6C4, 6D1, 6D2, 6D3, 6D4, 7A1, 7A2, 7A3, 7A4, 7B1, 7B2, 7B3, 7B4 3000 K E7 7A1, 7A2, 7A3, 7A4, 7B1, 7B2, 7B3, 7B4, 7C1, 7C2, 7C3, 7C4, 7D1, 7D2, 7D3, 7D4 3000 K Z7 7A3, 7B4, 7C1, 7D2 2850 K F8 7C1, 7C2, 7C3, 7C4, 7D1, 7D2, 7D3, 7D4, 8A1, 8A2, 8A3, 8A4, 8B1, 8B2, 8B3, 8B4 2700 K E8 8A1, 8A2, 8A3, 8A4, 8B1, 8B2, 8B3, 8B4, 8C1, 8C2, 8C3, 8C4, 8D1, 8D2, 8D3, 8D4 2700 K Z8 8A3, 8B4, 8C1, 8D2 © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 23 XLAMP ® XP-L LED BIN AND ORDER CODE FORMATS XP-L bin codes and order codes are configured in the following manner: Order Code Bin Code Series XPL = XP-L Series XPL = XP-L Class 0 = High density H = High intensity Class 0 = High density H = High intensity CRI specification 0 = Cool White B = 70 CRI minimum L = Standard CRI H = 80 CRI minimum P = 85 CRI minimum U = 90 CRI minimum Luminous flux group CRI specification 0 = Cool White B = 70 CRI minimum L = Standard CRI H = 80 CRI minimum P = 85 CRI minimum U = 90 CRI minimum Chromaticity group SSSCCC-B-WWW-FFF-GN-AAAA SSSCCC-BD-HHHH-HHHNFFNNN Luminous flux group Internal code Internal code Chromaticity group Color AWT = White © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. Color AWT = White CLD-DS97 REV 11 24 XLAMP ® XP-L LED REFLOW SOLDERING CHARACTERISTICS In testing, Cree LED has found XLamp XP-L LEDs to be compatible with JEDEC J‑STD‑020C, using the parameters listed below. As a general guideline, Cree LED recommends that users follow the recommended soldering profile provided by the manufacturer of the solder paste used, and therefore it is the lamp or luminaire manufacturer’s responsibility to determine applicable soldering requirements. Note that this general guideline may not apply to all PCB designs and configurations of reflow soldering equipment. tP TP Critical Zone TL to TP Temperature Ramp-up TL tL Tsmax Tsmin Ramp-down ts Preheat 25 t 25˚C to Peak Profile Feature Average Ramp-Up Rate (Tsmax to Tp) IPC/JEDEC J-STD-020C Time Lead-Free Solder 1.2 °C/second Preheat: Temperature Min (Tsmin) 120 °C Preheat: Temperature Max (Tsmax) 170 °C Preheat: Time (tsmin to tsmax) 65-150 seconds Time Maintained Above: Temperature (TL) Time Maintained Above: Time (tL) 217 °C 45-90 seconds Peak/Classification Temperature (Tp) 235 - 245 °C Time Within 5 °C of Actual Peak Temperature (tp) 20-40 seconds Ramp-Down Rate 1 - 6 °C/second Time 25 °C to Peak Temperature 4 minutes max. Note: All temperatures refer to the topside of the package, measured on the package body surface. © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 25 XLAMP ® XP-L LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. Moisture Sensitivity Cree LED recommends keeping XLamp LEDs in the provided, resealable moisture-barrier packaging (MBP) until immediately prior to soldering. Unopened MBPs that contain XLamp LEDs do not need special storage for moisture sensitivity. Once the MBP is opened, XLamp XP-L LEDs may be stored as MSL 1 per JEDEC J-STD-033, meaning they have unlimited floor life in conditions of ≤ 30 ºC/85% relative humidity (RH). Regardless of the storage condition, Cree LED recommends sealing any unsoldered LEDs in the original MBP. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACH Compliance REACH substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACH Declaration. REACH banned substance information (REACH Article 67) is also available upon request. © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 26 XLAMP ® XP-L LED NOTES - CONTINUED UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 27 XLAMP ® XP-L LED MECHANICAL DIMENSIONS All measurements are ±.13 mm unless otherwise indicated. 8 8 7 XP-L High Density 7 6 6 5 5 4 4 3 3 XPLAWT-00-xxxx-xxxxxxxxx High Density OPTICAL OPTICAL MODEL MODEL ORIGIN ORIGIN F OPTICAL OPTICAL MODEL MODEL ORIGIN ORIGIN 2.682.68 SOLDERMASK SOLDERMASK MAY MAY BE BE PRESENT PRESENT 0.500.50 ANODE ANODE SIDE SIDE ANODE ANODE SIDE SIDE 3.45 3.45 CATHODE CATHODE SIDE SIDE E R1.95 R1.95 4 5 1 2 3 3.453.45 Top View TOP VIEW TOP VIEW SideSIDE ViewVIEW SIDE VIEW 3.30 2.68 2.30 0.18 0.18 0.500.50 SOLDERMASK MAY BE PRESENT 0.50 0.500.50 0.50 0.43 0.43 3.303.30 F 3.303.30 0.500.50 0.560.56 CATHODE SIDE SIDE VIEW B Bottom View BOTTOM VIEW CENTER PAD IS ELECTRICALLY ISOLATED 0.18 1.30 0.58 0.18 TYP 0.18 TYP 5 E 0.08 0.08 3.30 3.30 3.30 3.30 C 0.29 TYP 0.29 TYP 3.30 ANODE SIDE 0.560.56 0.08 CAL D DEL IN 0.580.58 D 0.500.50 0.50 1.30 0.56 1.30 0.180.18 0.500.50 0.56 RECOMMENDED PCB FOOTPRINT RECOMMENDED PCB FOOTPRINT 0.500.50 RECOMMENDED STENCIL OPENING RECOMMENDED STENCIL OPENING UN 0.08 0.43 0.18 3.30 A PLACES) TYP © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. C CLD-DS97 REV 11 PROPRIETARY AND CONFIDENTIAL PROPRIETARY AND CONFIDENTIAL B THE INFORMATION CONTAINED IN THIS THE INFORMATION CONTAINED IN THIS OF DRAWING IS THE SOLE PROPERTY DRAWING IS THE OF CREE LED.SOLE ANYPROPERTY REPRODUCTION IN A CREE LED. ANY IN PART ORREPRODUCTION AS A WHOLE WITHOUT 28 DIM TOL •A •O • TW • IN M •M •R INT B UPDATED OPTICAL MODEL ORIGIN UPDATED OPTICAL MODEL ORIGIN TOL A DRAWING INITIATED DRAWING INITIATED MA M XLAMP ® XP-L LED 7 6 4 5 2 3 MECHANICAL DIMENSIONS - CONTINUED All measurements are ±.13 mm unless otherwise indicated. Alternate bottom views of the XP-L High Density LED are shown in the diagrams below. 3.30 REF. 3.30 REF. Bottom View 3.30 REF. 3.30 REF. 3.30 REF. 3.30 REF. Bottom View Bottom View ALTERNATE BOTTOM VIEW ALTERNATE BOTTOM VIEW ALTERNATE BOTTOM VIEW Anode UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS TOLERANCES: • ANGULAR: MACH 0.5° BEND 1° • ONE PLACE DECIMAL 0.5 • TWO PLACE DECIMAL 0.05 • INSIDE BEND RADII EQUAL MATERIAL • MACHINE/CASTING RADII 0.50 • RADII AND DIA: 0.10 PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF CREE LED. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT WRITTEN PERMISSION OF CREE LED IS PROHIBITED. © 2021 CreeLED, Inc. a subsidiary of SMART Global Holdings, Inc. 7 6 5 4 B UPDATED OPTICAL MODEL ORIGIN A DRAWING INITIATED REV DESCRIPTION INTERPRET GEOMETRIC TOLERANCING PER: MATERIAL DRAWN NAME DATE TLING 24AUG22 TITLE: CHECKED ENG APPR. MFG APPR. Q.A. THIRD ANGLE PROJECTION FINISH SCALE: 2 APPLICATION 2 © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. 3 SIZE DW C MATERIAL FINISH 1 2 CLD-DS97 REV 11 29 XLAMP ® XP-L LED MECHANICAL DIMENSIONS - CONTINUED XP-L High Intensity XPLAWT-H0-xxxx-xxxxxxxxx 8 OPTICAL OPTICAL MODEL MODEL ORIGIN ORIGIN 3.45 F 6 7 3.45 1.00 1.00 SOLDERMASK SOLDERMASK MAY BE PRESENT MAY BE PRESENT 0.50 ANODE ANODE SIDE SIDE 0.58 4 BOTTOMBO VI 3.30 3.30 0.50 0.50 0.56 0.08 0.08 SIDE VIEW Bottom View BOTTOM VIEW 0.50 0.50 1.30 1.30 3.300.50 0.18 0.50 0.18 RECOMMENDED STENCIL STENCIL OPENINGOPE RECOMMENDED 0.08 0.43 D 0.18 0.50 0.56 RECOMMENDED PCB FOOTPRINT 0.50 RECOMMENDED PCB FOOTPRINT 0.56 © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and A the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. ACES) A 0.56 CENTER PAD IS ELECTRICALLY ISOLATED 0.08 B 0.56 1.30 0.58 B F E 0.29 TYP 3.30 3.30 C 3.30 C 3.30 CATHODE SIDE 0.43 ANODE SIDE 0.56 0.50 0.18 TYP 0.50 0.50 3.30 3.30 0.29 TYP 0.50 0.50 0.18 2.30 0.50 0.18 3.30 0.43 3.30 1 Side View SIDE VIEW SIDE VIEW SOLDERMASK MAY BE PRESENT 1.00 DE 0.50 1.30 0.58 2 3 Top View TOP VIEW TOP VIEW OPTICALD MODEL ORIGIN 3.30 2.30 ANODE ANODE SIDE SIDE 5 D 3 4 3.45 3.45 E 4 5 OPTICAL OPTICAL MODEL MODEL ORIGIN ORIGIN CATHODECATHODE SIDE SIDE E 5 6 0.18 F 7 0.18 TYP 8 High Intensity CLD-DS97 REV 11 30 C OPTICAL PROPRIETARY AND CONFIDENTIAL B UPDATED ORIGIN PROPRIETARY AND CONFIDENTIAL B MODEL UPDATED OPTIC THE INFORMATION CONTAINED IN THIS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY A PROPERTY DRAWING DRAWINGOF IS THE SOLE OF INITIATED A CREE LED. ANY REPRODUCTION CREE LED.INANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT PART OR AS A WHOLE WITHOUT DRAWING INITI 3.45 R1.95 R1.95 TOP VIEW TOP VIEW SIDE VIEWSIDE VIEW XP-L High Density & High Intensity D BO BOTTOM VIE 3.30 3.30 3.30 0.56 0.18 0.50 0.50 0.56 0.56 0.56 0.83 (2 PLACES) 0.43 0.08 0.50 0.50 0.43 0.50 0.50 0.18 3.30 0.50 0.50 1.30 1.30 0.50 0.18 0.18 TYP 0.18 TYP 0.08 0.08 B B 0.29 TYP 3.30 0.29 TYP 3.30 3.30 3.30 C C 0.50 0.18 0.18 Recommended PCB Footprint RECOMMENDED STENCIL OPENING RECOMMENDED STENCIL OPENING Notes: A A 0.50 0.50 Recommended Stencil Opening* RECOMMENDED PCB FOOTPRINT RECOMMENDED PCB FOOTPRINT • • * 0.18 D 1.30 0.58 0.58 3.45 3.45 - CONTINUED MECHANICAL DIMENSIONS 0.83 (2 PLACES) XLAMP XP-L LED E E 0.08 CATHODE CATHODE SIDE ® SIDE ANODE SIDE 3.45 ANODE SIDE UNLESS OTHERWISE S UNLESS OTHERWISE SPECIFIED: Cree LED recommends using thermal pad kickouts to maximize component thermal performance. Cree LED recommends using white solder mask material to minimize system optical loss. This stencil has been tested and optimized for the avoidance of voiding when using ALPHA® LUMET® P30 Maxrel solder paste. For other solder pastes, a “window pane” design for the thermal pad stencil may result in a lower voiding percentage. Contact your local Cree LED Field Applications MATERIAL Engineer for consultation regarding your specific application. DIMENSIONS ARE IN MIL DIMENSIONS ARE IN MILLIMETERS DRAWN TOLERANCES: TOLERANCES: • ANGULAR: MACH 0. 1° • ANGULAR: MACH 0.5° BEND • ONE PLACE DECIMAL • ONE PLACE DECIMAL 0.5 CHECKED • TWO PLACE DECIMAL • TWO PLACE DECIMAL 0.05 RADII EQ • INSIDE BEND RADII EQUAL• INSIDE BEND ENG APPR. MATERIAL MATERIAL MACHINE/CASTING R • MACHINE/CASTING RADII• 0.50 MFGDIA: APPR.0.1 • RADII AND DIA: 0.10 • RADII AND INTERPRET GEOMETRIC PROPRIETARY AND B UPDATED OPTICAL MODEL ORIGIN PROPRIETARY AND CONFIDENTIAL B CONFIDENTIAL UPDATED OPTICAL MODEL ORIGIN TOLERANCING PER: THE INFORMATION CONTAINED IN THIS THE INFORMATION CONTAINED IN THIS MATERIAL DRAWING OFINITIATEDA DRAWING IS THE SOLE PROPERTY OF IS THEASOLE PROPERTY DRAWING INITIATED DRAWING CREE IN LED. ANY REPRODUCTION IN CREE LED. ANY REPRODUCTION PART OR AS A WHOLE WITHOUT PART OR AS A WHOLE WITHOUT FINISH WRITTEN WRITTEN PERMISSION OF CREE LED PERMISSION OF CREE LED REV DESCRIPTION DESCRIPTION IS PROHIBITED. REV IS PROHIBITED. FINISH © 2021 CreeLED, Inc. a subsidiary © 2021 CreeLED, Inc. a subsidiary APPLICATION of SMART Global Holdings, Inc. of SMART Global Holdings, Inc.APPLICATION 8 8 7 7 6 6 5 5 4 © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. 4 2 3 CLD-DS97 REV 11 2 3 INTERPRETQ.A. GEOMETRIC TOLERANCING PER: THIRD ANGLE MATERIAL MATERIAL FINISH FINISH 2 31 XLAMP ® XP-L LED TAPE AND REEL All Cree LED carrier tapes conform to EIA-481D, Automated Component Handling Systems Standard. Except as noted, all dimensions in mm. All measurements are ±0.15 mm unless otherwise indicated. XP-L High Density XPLAWT-00-xxxx-xxxxxxxxx High Density Po T E Do Bo R P2 W A Anode side F A P1 B D1 "H" Ko B-B SECTION Bo (on a place in the bottom of the corner radii) Ao (on a place in the bottom of the corner radii) R "I" Ao Item Dim. Ao ITEM 3.75 Dim. Bo Ao 3.75 3.60 Ko 2.90 DETAIL"H" DETAIL"I" A-A SECTION Bo Po 3.60 4.00 KoP1 P2 Po 8.00 3.00 2.00 4.00 T P1 0.30 8.00 ITEM F Do D1 W R Dim. 5.50 1.50 1.50 12.00 3deg E 1.75 P2 2.00 F TDo 5.50 1.50 0.30 D1E 1.50 1.75 Anode Side W R 12.00 3° NOTICE 1) All Cree LED carrier tapes conform to EIA-481D, Automated Component handling Systems Standard 2) Measurement tolerances unless indicated otherwise: .xx = ±.15 mm © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 32 XLAMP ® XP-L LED TAPE AND REEL - CONTINUED XP-L High Density XPLAWT-00-xxxx-xxxxxxxxx High Density Feed Direction END START Trailer Loaded Pockets Leader Min. 160 mm empty pockets sealed with tape 500 Lamps Min. 400 mm empty pockets with min. 100 mm sealed Feed Direction Cover Tape Pocket Tape 13 mm 7” © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 33 XLAMP ® XP-L LED TAPE AND REEL - CONTINUED XP-L High Intensity XPLAWT-H0-xxxx-xxxxxxxxx High Intensity Po T E Do Bo R P2 W A Anode side A F P1 B D1 "H" Ko B-B SECTION Bo (on a place in the bottom of the corner radii) Ao (on a place in the bottom of the corner radii) R "I" Ao Item Dim. Ao ITEM 3.70 Dim. Bo Ao 3.70 3.70 DETAIL"H" DETAIL"I" A-A SECTION Ko Bo Po KoP1 P2 Po 1.20 3.70 4.00 8.00 1.20 2.00 4.00 T P1 0.30 8.00 ITEM F Do D1 W R Dim. 5.50 1.50 1.50 12.00 3deg E 1.75 P2 F 2.00 5.50 TDo 1.50 0.30 D1E 1.50 1.75 Anode Side W R 12.00 3° NOTICE 1) All Cree LED carrier tapes conform to EIA-481D, Automated Component handling Systems Standard 2) Measurement tolerances unless indicated otherwise: .xx = ±.15 mm 2402-M008 XPL-HI © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 34 XLAMP ® XP-L LED TAPE AND REEL - CONTINUED XP-L High Intensity XPLAWT-H0-xxxx-xxxxxxxxx High Intensity Feed Direction END START Trailer Loaded Pockets Leader Min. 160 mm empty pockets sealed with tape 500 Lamps Min. 400 mm empty pockets with min. 100 mm sealed Feed Direction Cover Tape Pocket Tape 13 mm 7” © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 35 XLAMP ® XP-L LED PACKAGING © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 36 XLAMP ® XP-L LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS The following order codes are active and valid order codes, but higher performance options are also available. Please see page 3 for order codes of XLamp XP-L High Density LEDs that could serve as alternatives for the order codes set forth below. XP-L High Density, TJ = 85 °C Chromaticity Kit CCT 51 6200 K 53 50 E1 E2 6000 K 6200 K 6500 K 5700 K Minimum Luminous Flux (lm) @ 1050 mA Order Codes Code Flux (lm) 65 CRI Typical 70 CRI Minimum V4 440 XPLAWT-00-0000-0000V4051 XPLAWT-00-0000-000BV4051 V3 420 XPLAWT-00-0000-0000V3051 XPLAWT-00-0000-000BV3051 V2 400 V4 440 XPLAWT-00-0000-0000V4053 XPLAWT-00-0000-000BV4053 V3 420 XPLAWT-00-0000-0000V3053 XPLAWT-00-0000-000BV3053 V2 400 V4 440 XPLAWT-00-0000-0000V4050 XPLAWT-00-0000-000BV4050 V3 420 XPLAWT-00-0000-0000V3050 XPLAWT-00-0000-000BV3050 V2 400 V4 440 XPLAWT-00-0000-0000V40E1 XPLAWT-00-0000-000BV40E1 V3 420 XPLAWT-00-0000-0000V30E1 XPLAWT-00-0000-000BV30E1 V2 400 V4 440 XPLAWT-00-0000-0000V40E2 XPLAWT-00-0000-000BV40E2 V3 420 XPLAWT-00-0000-0000V30E2 XPLAWT-00-0000-000BV30E2 V2 400 XPLAWT-00-0000-000BV2051 XPLAWT-00-0000-000BV2053 XPLAWT-00-0000-000BV2050 XPLAWT-00-0000-000BV20E1 XPLAWT-00-0000-000BV20E2 Note • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 37 XLAMP ® XP-L LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 4 and page 5 for order codes of XLamp XP-L High Density LEDs that could serve as alternatives for the order codes set forth below. Chromaticity Kit E3 F4 E4 F5 E5 Z5 F6 CCT 5000 K 4750 K 4500 K 4250 K 4000 K 4000 K 3700 K Minimum Luminous Flux (lm) @ 1050 mA Order Codes Code Flux (lm) 70 CRI Minimum 75 CRI Typical 80 CRI Minimum V4 440 XPLAWT-00-0000-000BV40E3 V3 420 XPLAWT-00-0000-000BV30E3 V2 400 XPLAWT-00-0000-000BV20E3 V4 440 XPLAWT-00-0000-000BV40F4 V3 420 XPLAWT-00-0000-000BV30F4 V2 400 XPLAWT-00-0000-000BV20F4 V4 440 XPLAWT-00-0000-000BV40E4 V3 420 XPLAWT-00-0000-000BV30E4 V2 400 XPLAWT-00-0000-000BV20E4 V4 440 XPLAWT-00-0000-000BV40F5 V3 420 XPLAWT-00-0000-000BV30F5 V2 400 XPLAWT-00-0000-000BV20F5 V4 440 XPLAWT-00-0000-000BV40E5 V3 420 XPLAWT-00-0000-000BV30E5 V2 400 XPLAWT-00-0000-000BV20E5 U6 380 XPLAWT-00-0000-000BU60E5 XPLAWT-00-0000-000LU60E5 XPLAWT-00-0000-000HU60E5 U5 360 V3 420 XPLAWT-00-0000-000BV30Z5 V2 400 XPLAWT-00-0000-000BV20Z5 U6 380 XPLAWT-00-0000-000BU60Z5 U5 360 XPLAWT-00-0000-000HU50Z5 V2 400 XPLAWT-00-0000-000HV20F6 U6 380 XPLAWT-00-0000-000LU60F6 XPLAWT-00-0000-000HU60F6 U5 360 XPLAWT-00-0000-000LU50F6 XPLAWT-00-0000-000HU50F6 XPLAWT-00-0000-000HV20E5 XPLAWT-00-0000-000HU50E5 XPLAWT-00-0000-000HV20Z5 XPLAWT-00-0000-000LU60Z5 XPLAWT-00-0000-000HU60Z5 Note • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 38 XLAMP ® XP-L LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 6 and page 7 for order codes of XLamp XP-L High Density LEDs that could serve as alternatives for the order codes set forth below. Chromaticity Kit CCT E6 3500 K Z6 3500 K F7 3250 K E7 3000 K Z7 3000 K F8 2850 K E8 2700 K Minimum Luminous Flux (lm) @ 1050 mA Order Codes Code Flux (lm) 80 CRI Typical 80 CRI Minimum 85 CRI Minimum 90 CRI Minimum V2 400 U6 380 XPLAWT-00-0000-000LU60E6 XPLAWT-00-0000-000HU60E6 U5 360 XPLAWT-00-0000-000LU50E6 XPLAWT-00-0000-000HU50E6 U6 380 U5 360 U6 380 U5 360 XPLAWT-00-0000-000LU50F7 XPLAWT-00-0000-000HU50F7 U4 340 XPLAWT-00-0000-000LU40F7 XPLAWT-00-0000-000HU40F7 U6 380 U5 360 XPLAWT-00-0000-000LU50E7 XPLAWT-00-0000-000HU50E7 U4 340 XPLAWT-00-0000-000LU40E7 XPLAWT-00-0000-000HU40E7 U3 320 XPLAWT-00-0000-000PU30E7 U2 300 XPLAWT-00-0000-000PU20E7 XPLAWT-00-0000-000UU20E7 T6 280 XPLAWT-00-0000-000PT60E7 XPLAWT-00-0000-000UT60E7 U5 360 U4 340 U3 320 XPLAWT-00-0000-000PU30Z7 U2 300 XPLAWT-00-0000-000PU20Z7 XPLAWT-00-0000-000UU20Z7 T6 280 XPLAWT-00-0000-000PT60Z7 XPLAWT-00-0000-000UT60Z7 U5 360 U4 340 U3 320 XPLAWT-00-0000-000PU30F8 U2 300 XPLAWT-00-0000-000PU20F8 XPLAWT-00-0000-000UU20F8 T6 280 XPLAWT-00-0000-000PT60F8 XPLAWT-00-0000-000UT60F8 T5 260 XPLAWT-00-0000-000PT50F8 XPLAWT-00-0000-000UT50F8 U5 360 U4 340 U3 320 XPLAWT-00-0000-000PU30E8 U2 300 XPLAWT-00-0000-000PU20E8 T6 280 XPLAWT-00-0000-000PT60E8 XPLAWT-00-0000-000UT60E8 T5 260 XPLAWT-00-0000-000PT50E8 XPLAWT-00-0000-000UT50E8 XPLAWT-00-0000-000HV20E6 XPLAWT-00-0000-000HU60Z6 XPLAWT-00-0000-000LU50Z6 XPLAWT-00-0000-000HU50Z6 XPLAWT-00-0000-000HU60F7 XPLAWT-00-0000-000HU60E7 XPLAWT-00-0000-000HU50Z7 XPLAWT-00-0000-000LU40Z7 XPLAWT-00-0000-000HU40Z7 XPLAWT-00-0000-000HU50F8 XPLAWT-00-0000-000LU40F8 XPLAWT-00-0000-000HU40F8 XPLAWT-00-0000-000HU50E8 XPLAWT-00-0000-000LU40E8 XPLAWT-00-0000-000HU40E8 Note • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 39 XLAMP ® XP-L LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED Chromaticity Kit CCT Z8 2700 K Minimum Luminous Flux (lm) @ 1050 mA Order Codes Code Flux (lm) 80 CRI Typical 80 CRI Minimum 85 CRI Minimum 90 CRI Minimum U4 340 U3 320 U2 300 XPLAWT-00-0000-000PU20Z8 T6 280 XPLAWT-00-0000-000PT60Z8 XPLAWT-00-0000-000UT60Z8 T5 260 XPLAWT-00-0000-000PT50Z8 XPLAWT-00-0000-000UT50Z8 XPLAWT-00-0000-000HU40Z8 Note • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 40 XLAMP ® XP-L LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 8 for order codes of XLamp XP-L High Intensity LEDs that could serve as alternatives for the order codes set forth below. XP-L High Intensity, TJ = 85 °C Chromaticity Kit CCT 51 6200 K 53 6000 K 50 6200 K E1 6500 K E2 5700 K Minimum Luminous Flux (lm) @ 1050 mA Order Codes Code Flux (lm) 65 CRI Typical 70 CRI Minimum U6 380 XPLAWT-H0-0000-0000U6051 XPLAWT-H0-0000-000BU6051 U5 360 XPLAWT-H0-0000-0000U5051 XPLAWT-H0-0000-000BU5051 U6 380 XPLAWT-H0-0000-0000U6053 XPLAWT-H0-0000-000BU6053 U5 360 XPLAWT-H0-0000-0000U5053 XPLAWT-H0-0000-000BU5053 U6 380 XPLAWT-H0-0000-0000U6050 XPLAWT-H0-0000-000BU6050 U5 360 XPLAWT-H0-0000-0000U5050 XPLAWT-H0-0000-000BU5050 U6 380 XPLAWT-H0-0000-0000U60E1 XPLAWT-H0-0000-000BU60E1 U5 360 XPLAWT-H0-0000-0000U50E1 XPLAWT-H0-0000-000BU50E1 U6 380 XPLAWT-H0-0000-0000U60E2 XPLAWT-H0-0000-000BU60E2 U5 360 XPLAWT-H0-0000-0000U50E2 XPLAWT-H0-0000-000BU50E2 Note • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 41 XLAMP ® XP-L LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 9 for order codes of XLamp XP-L High Intensity LEDs that could serve as alternatives for the order codes set forth below. Chromaticity Kit CCT E3 5000 K F4 4750 K E4 4500 K F5 4250 K E5 4000 K F6 3700 K Minimum Luminous Flux (lm) @ 1050 mA Order Codes Code Flux (lm) 70 CRI Minimum 75 CRI Typical 80 CRI Minimum U6 380 XPLAWT-H0-0000-000BU60E3 XPLAWT-H0-0000-000LU60E3 U5 360 XPLAWT-H0-0000-000BU50E3 XPLAWT-H0-0000-000LU50E3 U6 380 XPLAWT-H0-0000-000BU60F4 XPLAWT-H0-0000-000LU60F4 U5 360 XPLAWT-H0-0000-000BU50F4 XPLAWT-H0-0000-000LU50F4 U6 380 XPLAWT-H0-0000-000BU60E4 XPLAWT-H0-0000-000LU60E4 U5 360 XPLAWT-H0-0000-000BU50E4 XPLAWT-H0-0000-000LU50E4 U6 380 XPLAWT-H0-0000-000BU60F5 U5 360 XPLAWT-H0-0000-000BU50F5 U6 380 XPLAWT-H0-0000-000BU60E5 U5 360 XPLAWT-H0-0000-000BU50E5 XPLAWT-H0-0000-000LU50E5 XPLAWT-H0-0000-000HU50E5 U4 340 XPLAWT-H0-0000-000BU40E5 XPLAWT-H0-0000-000LU40E5 XPLAWT-H0-0000-000HU40E5 U5 360 XPLAWT-H0-0000-000LU50F6 U4 340 XPLAWT-H0-0000-000LU40F6 XPLAWT-H0-0000-000HU40F6 U3 320 XPLAWT-H0-0000-000LU30F6 XPLAWT-H0-0000-000HU30F6 XPLAWT-H0-0000-000LU50F5 Note • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 42 XLAMP ® XP-L LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 10 for order codes of XLamp XP-L High Intensity LEDs that could serve as alternatives for the order codes set forth below. Chromaticity Kit CCT E6 3500 K F7 3250 K E7 3000 K F8 2850 K E8 2700 K Minimum Luminous Flux (lm) @ 1050 mA Order Codes Code Flux (lm) 80 CRI Typical 80 CRI Minimum 85 CRI Minimum U5 360 XPLAWT-H0-0000-000LU50E6 U4 340 XPLAWT-H0-0000-000LU40E6 XPLAWT-H0-0000-000HU40E6 U3 320 XPLAWT-H0-0000-000LU30E6 XPLAWT-H0-0000-000HU30E6 U4 340 XPLAWT-H0-0000-000LU40F7 XPLAWT-H0-0000-000HU40F7 U3 320 XPLAWT-H0-0000-000LU30F7 XPLAWT-H0-0000-000HU30F7 U2 300 XPLAWT-H0-0000-000LU20F7 XPLAWT-H0-0000-000HU20F7 U4 340 XPLAWT-H0-0000-000LU40E7 XPLAWT-H0-0000-000HU40E7 U3 320 XPLAWT-H0-0000-000LU30E7 XPLAWT-H0-0000-000HU30E7 U2 300 XPLAWT-H0-0000-000LU20E7 XPLAWT-H0-0000-000HU20E7 T6 280 XPLAWT-H0-0000-000PT60E7 T5 260 XPLAWT-H0-0000-000PT50E7 XPLAWT-H0-0000-000UT50E7 XPLAWT-H0-0000-000PT40E7 XPLAWT-H0-0000-000UT40E7 T4 240 U4 340 XPLAWT-H0-0000-000LU40F8 U3 320 XPLAWT-H0-0000-000LU30F8 XPLAWT-H0-0000-000HU30F8 U2 300 XPLAWT-H0-0000-000LU20F8 XPLAWT-H0-0000-000HU20F8 T6 280 XPLAWT-H0-0000-000PT60F8 T5 260 XPLAWT-H0-0000-000PT50F8 T4 240 XPLAWT-H0-0000-000PT40F8 T3 220 XPLAWT-H0-0000-000PT30F8 U4 340 XPLAWT-H0-0000-000LU40E8 U3 320 XPLAWT-H0-0000-000LU30E8 XPLAWT-H0-0000-000HU30E8 U2 300 XPLAWT-H0-0000-000LU20E8 XPLAWT-H0-0000-000HU20E8 T6 280 XPLAWT-H0-0000-000PT60E8 T5 260 XPLAWT-H0-0000-000PT50E8 T4 240 XPLAWT-H0-0000-000PT40E8 T3 220 XPLAWT-H0-0000-000PT30E8 90 CRI Minimum XPLAWT-H0-0000-000UT40F8 XPLAWT-H0-0000-000UT40E8 Note • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 26). © 2014-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, SC5 Technology®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS97 REV 11 43
XPLAWT-00-0000-000HU60Z7
PDF文档中包含以下信息:
1. 物料型号:型号编号为EFM8UB5。
2. 器件简介:EFM8UB5是一款8位微控制器,具有USB 2.0全速设备功能,适用于USB接口的设备。
3. 引脚分配:EFM8UB5有64个引脚,包括电源引脚、地引脚、I/O引脚、控制引脚等。
4. 参数特性:工作电压范围为2.0V至5.5V,工作频率最高可达25MHz。
5. 功能详解:EFM8UB5具有USB通信功能、定时器功能、中断功能等。
6. 应用信息:适用于需要USB接口的嵌入式系统,如数据采集、工业控制等。
7. 封装信息:EFM8UB5采用QFP封装,共有64个引脚。
XPLAWT-00-0000-000HU60Z7 价格&库存
很抱歉,暂时无法提供与“XPLAWT-00-0000-000HU60Z7”相匹配的价格&库存,您可以联系我们找货
