XPLBWT-00-0000-000HV340G
    CREELED
    LED-3P_3.45X3.45MM_SM
    LED 照明 XLamp® XP-L2 白色,天然 4000K 3 阶麦克亚当椭圆 2.82V 1.05A 125° 1414(3535 公制)
XPLBWT-00-0000-000HV340G 数据手册
PRODUCT FAMILY DATA SHEET XLamp® XP-L2 LEDs PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS The XLamp® XP-L2 LED is Cree LED’s • Available in white, 70-CRI white, 80‑CRI Characteristics................................................ 2 highest performing high-density discrete Order Codes Suggested for New Designs - white and 90‑CRI white LED. Leveraging key elements of Cree LED’s • Broadcast color option at 5700 K EasyWhite® Order Codes and Bins................. 3 SC5 Technology® Platform, the high‑power provides maximum performance for TV Order Codes Suggested for New Designs - XP-L2 LED improves the lumen density, events that require extremely high TLCI ANSI Order Codes and Bins............................ 6 voltage characteristics and reliability of the • ANSI‑compatible chromaticity bins Flux Characteristics - Broadcast Order XP-L LED in the same 3.45 mm x 3.45 mm • Binned at 85 °C Codes and Bins............................................. 10 package. This best‑in‑class performance • Maximum drive current: 3000 mA Relative Spectral Power Distribution........... 11 enables lighting manufacturers to deliver • Low thermal resistance: 0.6 °C/W Relative Flux vs. Junction Temperature....... 11 differentiated solutions at lower system • Wide viewing angle: 125° Electrical Characteristics.............................. 12 costs for applications such as roadway, • Unlimited floor life at ≤ 30 ºC/85% RH Relative Flux vs. Current............................... 12 outdoor area, spot and high‑bay lighting. • Reflow solderable - JEDEC J‑STD‑020C Relative Chromaticity vs. Current................. 13 • Electrically neutral thermal path Relative Chromaticity vs. Temperature........ 13 • RoHS and REACH compliant Typical Spatial Distribution........................... 14 • UL recognized component (E349212) Thermal Design............................................. 14 ® Performance Groups - Luminous Flux......... 15 Performance Groups - Chromaticity............ 16 EasyWhite® Kits Plotted on ANSI Standard Chromaticity Regions................................... 18 ANSI Kits Plotted on ANSI Standard Chromaticity Regions................................... 19 Standard Chromaticity Kits.......................... 21 Bin and Order Code Formats........................ 21 Reflow Soldering Characteristics................. 22 Notes............................................................. 23 Mechanical Dimensions............................... 25 Tape and Reel................................................ 26 Packaging...................................................... 28 Appendix - Order Codes Not for New Designs.......................................................... 29 Cree LED / 4001 E. Hwy. 54, Suite 2000 / Durham, NC 27709 USA / +1.919.313.5330 / www.cree-led.com © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 1 XLAMP ® XP-L2 LED CHARACTERISTICS Characteristics Unit Thermal resistance, junction to solder point◊ °C/W 0.6 degrees 125 mV/°C -1.3 Viewing angle (FWHM) Temperature coefficient of voltage ESD withstand voltage (HBM per Mil-Std-883D) Minimum Typical Maximum V 8000 mA 3000 Reverse voltage V 1 Forward voltage (@ 1050 mA, 85 °C) V LED junction temperature °C DC forward current 2.79 3.10 150 Note: ◊ Thermal resistance measurement was performed per the JEDEC JESD51-14 standard. See the Thermal Resistance Measurement application note for more details. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 2 XLAMP ® XP-L2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - EASYWHITE® ORDER CODES AND BINS (TJ = 85 °C) The following table provides order codes for XLamp XP-L2 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 21). For definitions of the chromaticity kits, please see the Standard Chromaticity Kits section (page 21). CRI Nominal CCT Min 70 5000 K 80 90 70 4500 K Typ Minimum Luminous Flux @1050 mA 2-Step 3-Step Flux Bin Flux (lm) @ 85 °C Flux (lm) @ 25 °C* W3 520 571 W2 500 549 V6 480 527 V6 480 527 V5 460 505 V4 440 483 XPLBWT-00-0000000HV450G V3 420 461 XPLBWT-00-0000000UV350G V2 400 439 U6 380 417 W3 520 571 W2 500 549 V6 480 527 V5 460 505 V4 440 483 XPLBWT-00-0000000HV445G V2 400 439 XPLBWT-00-0000000UV245G U6 380 417 80 Group Order Code Group Group Order Code XPLBWT-00-0000000BW350E 50E XPLBWT-00-0000000BW250E XPLBWT-00-0000000BV650E XPLBWT-00-0000000HV650G 50G 50G XPLBWT-00-0000000HV550G XPLBWT-00-0000000UV250G XPLBWT-00-0000000UU650G XPLBWT-00-0000000BW345E 45E XPLBWT-00-0000000BW245E XPLBWT-00-0000000BV645E 45G 90 Order Code 5-Step 45G XPLBWT-00-0000000HV545G XPLBWT-00-0000000UU645G Notes • • • * For additional order codes NOT recommended for new designs please see the Appendix section starting on page 29 . Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 23). XLamp XP-L2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 3 XLAMP ® XP-L2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - EASYWHITE® ORDER CODES AND BINS (TJ = 85 °C) - CONTINUED CRI Nominal CCT Min 70 4000 K Typ Minimum Luminous Flux @1050 mA Flux Bin Flux (lm) @ 85 °C Flux (lm) @ 25 °C* W3 520 571 W2 500 549 V6 480 527 V5 460 505 V4 440 483 V2 400 439 U6 380 417 V6 480 527 V5 460 505 V6 480 527 V5 460 505 U6 380 417 U5 360 395 V6 480 527 V5 460 505 V4 440 483 V3 420 461 U5 360 395 U4 340 373 2-Step Group Order Code 3-Step Group 40E 40G 40H XPLBWT-00-0000000UV240H XPLBWT-00-0000000UU640H 40G XPLBWT-00-0000000HV440G XPLBWT-00-0000000UV240G XPLBWT-00-0000000UU640G 80 35G 35H XPLBWT-00-0000000UU635H XPLBWT-00-0000000UU535H 35G 30G 90 30H XPLBWT-00-0000000UU530H XPLBWT-00-0000000UU430H 30G XPLBWT-00-0000000BV535E XPLBWT-00-0000000HV435G XPLBWT-00-0000000UU635G XPLBWT-00-0000000UU535G 30E 80 XPLBWT-00-0000000BV635E XPLBWT-00-0000000HV535G 70 3000 K XPLBWT-00-0000000BW240E XPLBWT-00-0000000HV540G 35E 90 Order Code XPLBWT-00-0000000BV640E 70 3500 K Group XPLBWT-00-0000000BW340E 80 90 Order Code 5-Step XPLBWT-00-0000000BV630E XPLBWT-00-0000000BV530E XPLBWT-00-0000000HV430G XPLBWT-00-0000000HV330G XPLBWT-00-0000000UU530G XPLBWT-00-0000000UU430G Notes • • • * For additional order codes NOT recommended for new designs please see the Appendix section starting on page 29 . Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 23). XLamp XP-L2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 4 XLAMP ® XP-L2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - EASYWHITE® ORDER CODES AND BINS (TJ = 85 °C) - CONTINUED CRI Nominal CCT Min Typ Minimum Luminous Flux @1050 mA Flux Bin Flux (lm) @ 85 °C Flux (lm) @ 25 °C* V3 420 461 2-Step Group Order Code 80 3-Step Group 27G V2 400 439 U4 340 373 U3 320 351 2700 K 90 27H XPLBWT-00-0000000UU427H XPLBWT-00-0000000UU327H 27G Order Code 5-Step Group Order Code XPLBWT-00-0000000HV327G XPLBWT-00-0000000HV227G XPLBWT-00-0000000UU427G XPLBWT-00-0000000UU327G Notes • • • * For additional order codes NOT recommended for new designs please see the Appendix section starting on page 29 . Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 23). XLamp XP-L2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 5 XLAMP ® XP-L2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - ANSI ORDER CODES AND BINS (TJ = 85 °C) The following table provides order codes for XLamp XP-L2 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 21). For definitions of the chromaticity kits, please see the Standard Chromaticity Kits section (page 21). Chromaticity Kit DT CB E1 CCT Minimum Luminous Flux (lm) @ 1050 mA Flux Bin Flux (lm) @ 85 °C Flux (lm) @ 25 °C* No Minimum CRI 70 CRI Minimum W2 500 549 XPLBWT-00-00000000W20DT XPLBWT-00-0000000BW20DT V6 480 527 XPLBWT-00-00000000V60DT XPLBWT-00-0000000BV60DT V5 460 505 XPLBWT-00-0000000HV50DT V4 440 483 XPLBWT-00-0000000HV40DT W3 520 571 XPLBWT-00-00000000W30CB XPLBWT-00-0000000BW30CB W2 500 549 XPLBWT-00-00000000W20CB XPLBWT-00-0000000BW20CB V6 480 527 V5 460 505 XPLBWT-00-0000000HV50CB V4 440 483 XPLBWT-00-0000000HV40CB V3 420 461 XPLBWT-00-0000000UV30CB V2 400 439 XPLBWT-00-0000000UV20CB W3 520 571 XPLBWT-00-00000000W30E1 XPLBWT-00-0000000BW30E1 W2 500 549 XPLBWT-00-00000000W20E1 XPLBWT-00-0000000BW20E1 V6 480 527 V5 460 505 XPLBWT-00-0000000HV50E1 V4 440 483 XPLBWT-00-0000000HV40E1 7000 K 6500 K 6500 K Order Codes 80 CRI Minimum 90 CRI Minimum XPLBWT-00-0000000BV60CB XPLBWT-00-0000000BV60E1 Notes • • • * For additional order codes NOT recommended for new designs please see the Appendix section starting on page 29 . Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 23). XLamp XP-L2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 6 XLAMP ® XP-L2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - ANSI ORDER CODES AND BINS (TJ = 85 °C) - CONTINUED Chromaticity Kit DV E2 CCT 5700 K Minimum Luminous Flux (lm) @ 1050 mA Order Codes Flux Bin Flux (lm) @ 85 °C Flux (lm) @ 25 °C* No Minimum CRI 70 CRI Minimum W3 520 571 XPLBWT-00-00000000W30DV XPLBWT-00-0000000BW30DV W2 500 549 XPLBWT-00-00000000W20DV XPLBWT-00-0000000BW20DV V6 480 527 V5 460 505 XPLBWT-00-0000000HV50DV V4 440 483 XPLBWT-00-0000000HV40DV V3 420 461 XPLBWT-00-0000000UV30DV V2 400 439 XPLBWT-00-0000000UV20DV W3 520 571 XPLBWT-00-00000000W30E2 XPLBWT-00-0000000BW30E2 W2 500 549 XPLBWT-00-00000000W20E2 XPLBWT-00-0000000BW20E2 V6 480 527 V5 460 505 XPLBWT-00-0000000HV50E2 V4 440 483 XPLBWT-00-0000000HV40E2 V3 420 461 XPLBWT-00-0000000UV30E2 V2 400 439 XPLBWT-00-0000000UV20E2 U6 380 417 XPLBWT-00-0000000UU60E2 5700 K XPLBWT-00-0000000BV60DV XPLBWT-00-0000000BV60E2 80 CRI Minimum 90 CRI Minimum XPLBWT-00-0000000HV60DV XPLBWT-00-0000000HV60E2 Notes • • • * For additional order codes NOT recommended for new designs please see the Appendix section starting on page 29 . Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 23). XLamp XP-L2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 7 XLAMP ® XP-L2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - ANSI ORDER CODES AND BINS (TJ = 85 °C) - CONTINUED Chromaticity Kit E3 E4 E5 E6 CCT 5000 K 4500 K 4000 K 3500 K Minimum Luminous Flux (lm) @ 1050 mA Order Codes Flux Bin Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 70 CRI Minimum W3 520 571 XPLBWT-00-0000-000BW30E3 W2 500 549 XPLBWT-00-0000-000BW20E3 V6 480 527 XPLBWT-00-0000-000BV60E3 V5 460 505 XPLBWT-00-0000-000HV50E3 V4 440 483 XPLBWT-00-0000-000HV40E3 V3 420 461 80 CRI Minimum 90 CRI Minimum XPLBWT-00-0000-000HV60E3 XPLBWT-00-0000-000UV30E3 V2 400 439 XPLBWT-00-0000-000UV20E3 U6 380 417 XPLBWT-00-0000-000UU60E3 W3 520 571 XPLBWT-00-0000-000BW30E4 W2 500 549 XPLBWT-00-0000-000BW20E4 V6 480 527 XPLBWT-00-0000-000BV60E4 V5 460 505 XPLBWT-00-0000-000HV50E4 V4 440 483 XPLBWT-00-0000-000HV40E4 V3 420 461 V2 400 439 XPLBWT-00-0000-000UV20E4 U6 380 417 XPLBWT-00-0000-000UU60E4 W3 520 571 XPLBWT-00-0000-000BW30E5 W2 500 549 XPLBWT-00-0000-000BW20E5 V6 480 527 XPLBWT-00-0000-000BV60E5 V5 460 505 XPLBWT-00-0000-000HV50E5 V4 440 483 XPLBWT-00-0000-000HV40E5 V3 420 461 V2 400 439 XPLBWT-00-0000-000UV20E5 U6 380 417 XPLBWT-00-0000-000UU60E5 V6 480 527 XPLBWT-00-0000-000BV60E6 V5 460 505 XPLBWT-00-0000-000BV50E6 V4 440 483 V3 420 461 XPLBWT-00-0000-000HV50E6 XPLBWT-00-0000-000HV40E6 V2 400 439 U6 380 417 XPLBWT-00-0000-000UU60E6 U5 360 395 XPLBWT-00-0000-000UU50E6 Notes • • • * For additional order codes NOT recommended for new designs please see the Appendix section starting on page 29 . Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 23). XLamp XP-L2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 8 XLAMP ® XP-L2 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - ANSI ORDER CODES AND BINS (TJ = 85 °C) - CONTINUED Chromaticity Kit E7 E8 CCT 3000 K 2700 K Minimum Luminous Flux (lm) @ 1050 mA Order Codes Flux Bin Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 70 CRI Minimum V6 480 527 XPLBWT-00-0000-000BV60E7 V5 460 505 XPLBWT-00-0000-000BV50E7 V4 440 483 XPLBWT-00-0000-000HV40E7 V3 420 461 XPLBWT-00-0000-000HV30E7 V2 400 439 U6 380 417 U5 360 395 XPLBWT-00-0000-000UU50E7 U4 340 373 XPLBWT-00-0000-000UU40E7 V3 420 461 XPLBWT-00-0000-000HV30E8 V2 400 439 XPLBWT-00-0000-000HV20E8 U6 380 417 U5 360 395 U4 340 373 XPLBWT-00-0000-000UU40E8 U3 320 351 XPLBWT-00-0000-000UU30E8 80 CRI Minimum 90 CRI Minimum Notes • • • * For additional order codes NOT recommended for new designs please see the Appendix section starting on page 29 . Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 23). XLamp XP-L2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 9 XLAMP ® XP-L2 LED FLUX CHARACTERISTICS - BROADCAST ORDER CODES AND BINS (TJ = 85 °C) The following table provides order codes for XLamp XP-L2 Broadcast LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 21). For definitions of the chromaticity kits, please see the Standard Chromaticity Kits section (page 21). Chromaticity Kit E2 CCT 5700 K Minimum Luminous Flux (lm) @ 1050 mA Flux Bin Flux (lm) @ 85 °C Flux (lm) @ 25 °C* Order Codes 90 CRI Minimum 90 TLCI Minimum 95 CRI Minimum 95 TLCI Minimum V2 400 439 XPLBWT-00-B001-A00UV20E2 U6 380 417 XPLBWT-00-B001-A00UU60E2 U5 360 395 XPLBWT-00-B001-A00ZU50E2 U4 340 373 XPLBWT-00-B001-A00ZU40E2 Notes • • • * TLCI refers to the European Broadcast Union’s Television Lighting Consistency Index 2012, which aids broadcasters in assessing the colorimetric quality of lighting in their production environment. Cree LED maintains a tolerance of ±2 on TLCI measurements. See the Measurements section (page 23). Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI. See the Measurements section (page 23). XLamp XP-L2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 10 XLAMP ® XP-L2 LED Relative Spectral Power RELATIVE SPECTRAL POWER DISTRIBUTION 100% Relative Radiant Power 80% 60% 5700 K, 70 CRI 3000 K, 80 CRI 40% 20% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Relative Flux Output vs. Junction Temperature RELATIVE FLUX VS. JUNCTION TEMPERATURE (IF = 1050 mA) 120% Relative Luminous Flux 100% 80% 60% 40% 20% 0% 25 50 75 100 125 150 Junction Temperature (ºC) © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 11 XLAMP ® XP-L2 LED Electrical Characteristics (Tj = 85°C) ELECTRICAL CHARACTERISTICS (TJ = 85 °C) 3000 Forward Current (mA) 2500 2000 1500 1000 500 0 2.55 2.60 2.65 2.70 2.75 2.80 2.85 Relative Intensity vs. Current (TjForward = 85°C) Voltage (V) 2.90 2.95 3.00 3.05 data from: graphics/SA products Vf data sheet update.xlsx RELATIVE FLUX VS. CURRENT (TJ = 85 °C) 250% Relative Luminous Flux 200% 150% 100% 50% 0% 0 500 1000 1500 2000 2500 3000 Forward Current (mA) © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 12 XLAMP ® XP-L2 LED Relative Chromaticity Vs. Current RELATIVE CHROMATICITY VS. CURRENT (WARM WHITE) 0.020 0.016 0.012 0.008 0.004 ΔCCx 0.000 ΔCCy -0.004 -0.008 -0.012 -0.016 -0.020 0 500 1000 1500 2000 2500 3000 Current (mA) RELATIVE CHROMATICITY VS.Vs.TEMPERATURE (WARM WHITE) Relative Chromaticity Temperature 0.020 0.016 0.012 0.008 0.004 ΔCCx 0.000 ΔCCy -0.004 -0.008 -0.012 -0.016 -0.020 25 50 75 100 125 150 Tsp (°C) © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 13 XLAMP ® XP-L2 LED Typical Radiation TYPICAL SPATIALSpatial DISTRIBUTION Pattern 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) THERMAL DESIGN The maximum forward current is determined by the thermal resistance between the LED junction and ambient. It is crucial for the end Thermal Design product to be designed in a manner that minimizes the thermal resistance from the solder point to ambient in order to optimize lamp life and optical characteristics. 3500 Maximum Current (mA) 3000 2500 2000 1500 Rj-a = 4°C/W 1000 Rj-a = 7°C/W Rj-a = 10°C/W 500 Rj-a = 15°C/W 0 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 14 XLAMP ® XP-L2 LED PERFORMANCE GROUPS - LUMINOUS FLUX XLamp XP-L2 LEDs are tested for luminous flux and placed into one of the following luminous‑flux bins. The flux bins, with a 0 appended, are used in the Bin Code “Minimum luminous flux bin.” Luminous Flux Bin Minimum Luminous Flux (lm) @ 1050 mA Maximum Luminous Flux (lm) @ 1050 mA T6 280 300 U2 300 320 U3 320 340 U4 340 360 U5 360 380 U6 380 400 V2 400 420 V3 420 440 V4 440 460 V5 460 480 V6 480 500 W2 500 520 W3 520 540 W4 540 560 © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 15 XLAMP ® XP-L2 LED PERFORMANCE GROUPS - CHROMATICITY Region 0A 0R 1A 1R 2A 2R 3A 4A 5A x y 0.2950 0.2970 0.2920 0.3060 0.2984 0.3133 0.3009 Region x y 0.2920 0.3060 x y x y 0.2984 0.3133 0.2984 0.3133 0.2895 0.3135 0.2962 0.3220 0.2962 0.3220 0.3028 0.3304 0.3048 0.3207 0.3068 0.3113 0.3042 0.2984 0.3133 0.3048 0.3207 0.3009 0.3042 0.2980 0.2880 0.2895 0.3135 0.2962 0.3220 0.3037 0.2937 0.2950 0.2970 0.2870 0.3210 0.2937 0.3312 0.3009 0.3042 0.3009 0.3042 0.2937 0.3312 0.3005 0.3415 0.3068 0.3113 0.3037 0.2937 0.2962 0.3220 0.3028 0.3304 0.3093 0.2993 0.3048 0.3207 0.3028 0.3304 0.3115 0.3391 0.3130 0.3290 0.3130 0.3290 0.3115 0.3391 0.3205 0.3481 0.3213 0.3373 0.3144 0.3186 0.3130 0.3290 0.3213 0.3373 0.3221 0.3261 0.3068 0.3113 0.3048 0.3207 0.3130 0.3290 0.3144 0.3186 0.3068 0.3113 0.3005 0.3415 0.3099 0.3509 0.3144 0.3186 0.3144 0.3186 0.3099 0.3509 0.3196 0.3602 0.3221 0.3261 0.3161 0.3059 0.3115 0.3391 0.3205 0.3481 0.3231 0.3120 0.3093 0.2993 0.3028 0.3304 0.3115 0.3391 0.3161 0.3059 0.3215 0.3350 0.3207 0.3462 0.3290 0.3538 0.3290 0.3417 0.3290 0.3417 0.3290 0.3538 0.3376 0.3616 0.3371 0.3490 0.3290 0.3300 0.3290 0.3417 0.3371 0.3490 0.3366 0.3369 0.3222 0.3243 0.3215 0.3350 0.3290 0.3417 0.3290 0.3300 0.3222 0.3243 0.3196 0.3602 0.3290 0.3690 0.3290 0.3300 0.3290 0.3300 0.3290 0.3690 0.3381 0.3762 0.3366 0.3369 0.3290 0.3180 0.3290 0.3538 0.3376 0.3616 0.3361 0.3245 0.3231 0.3120 0.3207 0.3462 0.3290 0.3538 0.3290 0.3180 0.3371 0.3490 0.3376 0.3616 0.3463 0.3687 0.3451 0.3554 0.3451 0.3554 0.3463 0.3687 0.3551 0.3760 0.3533 0.3620 0.3440 0.3427 0.3451 0.3554 0.3533 0.3620 0.3515 0.3487 0.3366 0.3369 0.3371 0.3490 0.3451 0.3554 0.3440 0.3427 0.3530 0.3597 0.3548 0.3736 0.3641 0.3804 0.3615 0.3659 0.3615 0.3659 0.3641 0.3804 0.3736 0.3874 0.3702 0.3722 0.3590 0.3521 0.3615 0.3659 0.3702 0.3722 0.3670 0.3578 0.3512 0.3465 0.3530 0.3597 0.3615 0.3659 0.3590 0.3521 0B 0S 1B 1S 2B 2S 3B 4B Region 0C 0T 1C 1T 2C 2T 3C 4C Region 0D 0U 1D 1U 2D 2U 3D 4D 0.3702 0.3722 0.3736 0.3874 0.3870 0.3958 0.3825 0.3798 0.3825 0.3798 0.387 0.3958 0.4006 0.4044 0.3951 0.3876 0.3783 0.3646 0.3825 0.3798 0.3951 0.3876 0.3898 0.3716 0.367 0.3578 0.3702 0.3722 0.3825 0.3798 0.3783 0.3646 5B 5C © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. 5D CLD-DS149 REV 6 16 XLAMP ® XP-L2 LED PERFORMANCE GROUPS – CHROMATICITY - CONTINUED Region 6A 7A 8A x y 0.3941 0.3848 0.4080 0.3916 0.4017 0.3752 0.3889 Region x y 0.3996 0.4015 0.4146 0.4089 0.4080 0.3916 0.3690 0.3941 0.4221 0.3985 0.4342 0.4028 0.4260 0.3853 0.4147 0.3814 0.4465 0.4071 0.4582 0.4099 0.4483 0.3918 0.4373 0.3893 6B 7B 8B Region x y 0.4146 0.4089 0.4299 0.4165 0.4221 0.3985 0.3848 0.4080 0.4299 0.4165 0.4430 0.4212 0.4342 0.4028 0.4221 0.3985 0.4562 0.4260 0.4687 0.4289 0.4582 0.4099 0.4465 0.4071 6C 7C 8C Region x y 0.4080 0.3916 0.4221 0.3985 0.4147 0.3814 0.3916 0.4017 0.3752 0.4430 0.4212 0.4342 0.4028 0.4562 0.4260 0.4465 0.4071 0.4465 0.4071 0.4373 0.3893 0.4342 0.4028 0.4260 0.3853 0.4687 0.4289 0.4582 0.4099 0.4813 0.4319 0.4700 0.4126 0.4700 0.4126 0.4593 0.3944 0.4582 0.4099 0.4483 0.3918 6D 7D 8D EasyWhite Color Temperatures – 2-Step Bin Code 40H 35H 30H 27H CCT 4000 K 3500 K 3000 K 2700 K x y 0.3777 0.3739 0.3797 0.3816 0.3861 0.3855 0.3838 0.3777 0.4022 0.3858 0.4053 0.3942 0.4125 0.3977 0.4091 0.3891 0.4287 0.3975 0.4328 0.4064 0.4390 0.4086 0.4347 0.3996 0.4524 0.4048 0.4574 0.4140 0.4633 0.4154 0.4581 0.4062 © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 17 XLAMP ® XP-L2 LED PERFORMANCE GROUPS – CHROMATICITY (CONTINUED) EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 50G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.00840 0.00312 65.0 45G 4500 K 0.3611 0.3658 0.00852 0.00330 61.5 40G 4000 K 0.3818 0.3797 0.00939 0.00402 53.7 35G 3500 K 0.4073 0.3917 0.00927 0.00414 54.0 30G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 27G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 EasyWhite Color Temperatures – 5-Step Ellipse Bin Code CCT 50E 45E Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5000 K 0.3447 0.3553 0.01400 0.00520 65.0 4500 K 0.3611 0.3658 0.01420 0.00550 61.5 40E 4000 K 0.3818 0.3797 0.01565 0.00670 53.7 35E 3500 K 0.4073 0.3917 0.01545 0.00690 54.0 30E 3000 K 0.4338 0.4030 0.01390 0.00680 53.2 EASYWHITE® KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.44 0.43 0.42 2700 K ANSI C78.377 Quadrangle 3000 K EasyWhite 5-Step EasyWhite 3-Step 3500 K EasyWhite 2-Step 0.41 4000 K 0.40 4500 K CCy 0.39 0.38 5000 K 0.37 0.36 0.35 0.34 0.33 0.32 0.33 0.34 0.35 0.36 0.37 0.38 0.39 0.40 0.41 0.42 0.43 0.44 0.45 0.46 0.47 0.48 0.49 CCx © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 18 XLAMP ® XP-L2 LED ANSI KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.40 0.40 5000 K 0.39 0.38 0.38 5700 K 0.37 2U ANSI C78.377A 2R 1U 0D 0A 1R 0U 0.36 0.35 CCx 0.34 0.28 0.36 0.35 0.34 0.33 0.32 0.28 0.31 0.28 0.33 0R 0.29 0.30 2A 1D 1A 0.30 0R 0.29 0C 2D 1C 1B 0B 0.31 1R 0.29 0.28 0S 0.32 0U 0.30 1S 0T 0.32 0A 1U 2B 0.31 0D ANSI C78.377A 2R 1A 0.34 0.33 2U 2C 1T 0.30 0C 0B 0.31 2A 1D DT 8000 K 0.29 0S 0.32 2D 1C 1B 2S 0.35 2B CCy CCy 2C 1T 1S 0T 0.33 2T 0.36 2S 8000 K 0.34 6500 K 2T CB 0.35 5700 K 0.37 6500 K 0.36 5000 K 0.39 CCx 0.40 5000 K 0.39 0.38 5700 K DV 0.37 6500 K 0.36 0.35 CCy 2T 2S 2C 1T 8000 K 0.34 2B 1S 0T 0.33 0S 0.32 0B 0.31 2A 1B 0C 1D 2U ANSI C78.377A 2R 1A 1U 0D 0A 2D 1C 1R 0U 0.30 0R 0.29 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.28 CCx © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 19 XLAMP ® XP-L2 LED ANSI KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS - CONTINUED 0.46 0.45 3000 K 0.44 0.43 0.42 4000 K 0.41 5000 K 0.39 CCy 0.38 5700 K 0.37 6500 K 0.36 0.34 E6 4500 K 0.40 0.35 E7 3500 K 8000 K E1 0.33 1B 0.32 1A E2 1C 1D 2B E3 3C 2C 3A 3D 5B 4B 4A 6B 5C E4 4C 3B 6C E5 5D 6D 7D 7A 8B 7C 7B 2700 K E8 8C 8D 8A 6A 5A 4D ANSI C78.377A 2D 2A 0.31 0.30 0.29 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.28 CCx © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 20 XLAMP ® XP-L2 LED STANDARD CHROMATICITY KITS The following table provides the chromaticity bins associated with chromaticity kits. Color Cool White Neutral White Warm White CCT Kit Chromaticity Bins 7000 K DT 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U 6500 K CB 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U 6500 K E1 1A, 1B, 1C, 1D 5700 K DV 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U 5700 K E2 2A, 2B, 2C, 2D 5000 K E3 3A, 3B, 3C, 3D 4500 K E4 4A, 4B, 4C, 4D 4000 K E5 5A, 5B, 5C, 5D 3500 K E6 6A, 6B, 6C, 6D 3000 K E7 7A, 7B, 7C, 7D 2700 K E8 8A, 8B, 8C, 8D BIN AND ORDER CODE FORMATS XP-L2 bin codes and order codes are configured in the following manner: Order Code Bin Code Series XPL = XP-L Series XPL = XP-L CRI specification 0 = No minimum CRI B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Z = 95 CRI minimum Internal code Minimum luminous flux bin CRI specification 0 = No minimum CRI B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Z = 95 CRI minimum Chromaticity group SSSCCC-BD-HHHH-HHHNFFNNN Minimum luminous flux bin SSSCCC-B-WWW-FFF-GN-AAAA Internal code Internal code Color BWT = Gen 2 White Chromaticity group © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. Color BWT = Gen 2 White CLD-DS149 REV 6 21 XLAMP ® XP-L2 LED REFLOW SOLDERING CHARACTERISTICS In testing, Cree LED has found XLamp XP-L2 LEDs to be compatible with JEDEC J‑STD‑020C, using the parameters listed below. As a general guideline, Cree LED recommends that users follow the recommended soldering profile provided by the manufacturer of the solder paste used, and therefore it is the lamp or luminaire manufacturer’s responsibility to determine applicable soldering requirements. Note that this general guideline may not apply to all PCB designs and configurations of reflow soldering equipment. tP TP Critical Zone TL to TP Temperature Ramp-up TL tL Tsmax Tsmin Ramp-down ts Preheat 25 t 25˚C to Peak Profile Feature Average Ramp-Up Rate (Tsmax to Tp) IPC/JEDEC J-STD-020C Time Lead-Free Solder 1.2 °C/second Preheat: Temperature Min (Tsmin) 120 °C Preheat: Temperature Max (Tsmax) 170 °C Preheat: Time (Tsmin to Tsmax) 65-150 seconds Time Maintained Above: Temperature (TL) Time Maintained Above: Time (tL) 217 °C 45-90 seconds Peak/Classification Temperature (Tp) 235 - 245 °C Time Within 5 °C of Actual Peak Temperature (tp) 20-40 seconds Ramp-Down Rate 1 - 6 °C/second Time 25 °C to Peak Temperature 4 minutes max. Note: All temperatures refer to the topside of the package, measured on the package body surface. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 22 XLAMP ® XP-L2 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. Moisture Sensitivity Cree LED recommends keeping XLamp LEDs in the provided, resealable moisture-barrier packaging (MBP) until immediately prior to soldering. Unopened MBPs that contain XLamp LEDs do not need special storage for moisture sensitivity. Once the MBP is opened, XLamp XP-L2 LEDs may be stored as MSL 1 per JEDEC J-STD-033, meaning they have unlimited floor life in conditions of ≤ 30 ºC/85% relative humidity (RH). Regardless of the storage condition, Cree LED recommends sealing any unsoldered LEDs in the original MBP. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACH Compliance REACH substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACH Declaration. REACH banned substance information (REACH Article 67) is also available upon request. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 23 XLAMP ® XP-L2 LED NOTES - CONTINUED UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 24 XLAMP ® XP-L2 LED MECHANICAL DIMENSIONS 87 7 6 6 65 5 5 4 4 43 3 3 2 2 1 All measurements are ±.13 mm unless otherwise indicated. OPTICAL MODEL ORIGIN OPTICAL MODEL ORIGIN 3.45 3.45 3.45 0.50 4 ANODE SIDE 0.50 CATHODE SIDE 0.50 0.18 TYP 0.83 (2 PLACES) 0.08 0.08 0.18 0.50 RECOMMENDED PCB FOOTPRINT PCB Footprint 0.50 Recommended 1.30 0.50 0.56 0.18 0.29 TYP 0.29 TYP 0.18 TYP 3.30 3.30 0.29 TYP 0.08 0.08 0.50 1.30 1.30 0.56 0.83 (2 PLACES) 0.43 0.43 0.43 0.18 TYP 3.30 0.29 TYP 3.30 3.30 3.30 0.50 BOTTOM VIEW 0.56 0.56 0.50 C B 3.30 0.50 0.56 B 0.08 0.50 0.56 SIDE VIEW 0.83 (2 PLACES) 0.50 0.50 0.43 0.50 0.56 0.56 0.18 0.18 0.50 3.30 3.30 3.30 0.58 BOTTOM BottomVIEW View 3.30 0.83 (2 PLACES) Side View TOP VIEW 3.30 SIDE VIEW 0.08 Top View R1.95 SIDE VIEW SIDE VIEW CEN IS E ISO CENTER PAD IS ELECTRICALLY ISOLATED 1.30 BOTTOM VIEW 0.18 3.45 0.18 TYP TOP VIEW 0.08 TOP VIEW 1.30 1.300.58 0.58 0.18 3.45 0.18 3.45 0.50 0.50 R1.95 0.58 0.18 3.45 R1.95 R1.95 D 2.30 ANODE SIDE E 3.30 CATHODE ANODE SIDE SIDE 3.30 ANODE SOLDERMASK SIDE MAY BE PRESENT ANODE SIDE 2.68 0 0.50 2 0.50 3 0.08 F 0.50 5 2.30 2.30 2.68 6 SOLDERMASK 3.30 MAY BE PRESENT 0.18 CATHODE SIDE SOLDERMASK 3.30 MAY BE PRESENT 2.68 2.68 ANODE SIDE 7 ANODE SIDE 8 ANODE SIDE OPTICAL MODEL SOLDERMASK ORIGIN MAY BE PRESENT 3.30 OPTICAL MODEL ORIGIN OPTICAL MODEL ORIGIN OPTICAL MODEL ORIGIN 0.18 0.50 Recommended Stencil Openings* RECOMMENDED STENCIL OPENING 0.50 0.18 0.50 0.50 UNLESS OTHERWISE SPECIFIED NAME DAT DIMENSIONS ARE IN MILLIMET TLING DRAWN 24AU TOLERANCES: 0.5° 1° BEND ANGULAR: MACH ••• TWO ONE PLACE 0.5 DECIMAL T CHECKED PLACE 0.05 DECIMAL A • INSIDE BEND RADII EQUAL Notes: MATERIAL ENG APPR. • MACHINE/CASTING RADII 0.5 NDED PCB FOOTPRINT RECOMMENDED STENCIL OPENING MFG APPR. RECOMMENDED PCB FOOTPRINT RECOMMENDED STENCIL OPENING • RADII AND 0.10 DIA: RECOMMENDED STENCIL OPENING • Cree LED recommends using thermal pad kickouts to maximize component thermal performance. Q.A. INTERPRET GEOMETRIC PROPRIETARY AND CONFIDENTIAL TOLERANCING PER: ANGLE PR B UPDATED OPTICAL THIRD THE INFORMATION CONTAINED INOF THISMODEL ORIGIN MATERIAL S DRAWING IS THEREPRODUCTION PROPERTY • Cree LED recommends using white solder mask material to minimize system optical loss. ASOLE DRAWING INITIATED CREE LED. ANY IN MATERIAL UNLESS OTHERWISE SPECIFIED: UNLESS NAME DATE O PART OR AS A WHOLE WITHOUT UNLESS OTHERWISE SPECIFIED: NAME CreeLED, DATE FINISH ® WRITTEN PERMISSION OF CREE LEDFor DIMENSIONS ARE IN MILLIMETERS DESCRIPTION DIMENSIO 4400 SILIC IS PROHIBITED. * This stencil has been tested and optimized for the avoidance of voiding when using ALPHA® LUMET P30 Maxrel solder paste. other solder FINISH DIMENSIONS ARE IN REV MILLIMETERS TLING DRAWN 24AUG22 TOLERANCES: TOLERANC DURHAM © 2022 CreeLED, Inc. a subsidiary TLING DRAWN 24AUG22 TOLERANCES: 0.5° BEND 1° • ANGULAR: MACH ANGULAR of SMART Holdings, Inc. APPLICATION 0.5° BEND 1°Global ANGULAR: MACH ONE PLACE 0.5 DECIMAL TIT ONE PLA CHECKED ••• TWO pastes, a “window pane” design for the Contact your local Cree Field Applications •• TWO ONE PLACE 0.5 DECIMAL TITLE: CHECKED ••2TWO PLACE DECIMAL PLA 4 7 thermal pad stencil 6may result in a lower 5voiding percentage. 8 3LED PLACE DECIMAL BEND0.05 RADII BE ENGEQUAL APPR. 2 • INSIDE •• INSIDE BEND0.05 RADII ENGEQUAL APPR.•• INSIDE MATERIAL MATERIA MATERIAL Engineer for consultation regarding your specific application. MACHINE/CASTING 0.50 •• MACHINE •• MACHINE/CASTING APPR. RADII AND 0.10 DIA: MFGRADII XPL2 RADII AN APPR.•0.50 RADII AND 0.10 DIA: MFGRADII Q.A. INTERPRET GEOMETRIC INTERPRET Q.A. INTERPRET GEOMETRIC PROPRIETARY TOLERANCING PER: BCONFIDENTIAL UPDATED OPTICAL MODEL ORIGIN PROPRIETARY AND TOLERANC BCONFIDENTIAL UPDATED OPTICAL OR PROPRIETARY AND BCONFIDENTIAL TOLERANCING PER: UPDATED OPTICALAND MODEL ORIGIN THIRD ANGLEMODEL PROJECT THIRD ANGLE PROJECTION THE INFORMATION CONTAINED INOF THIS IS THE INFORMATION CONTAINED INOF THIS MATERIAL MATERIAL THE INFORMATION CONTAINED INOF THIS MATERIAL SIR DRAWING IS THE SOLE PROPERTY DRAWING THE SOLE PROPERTY A DRAWING INITIATED SIZE DWG. NO. A DRAWING INITIATED DRAWING IS THE SOLE PROPERTY CREE LED. ANY REPRODUCTION IN A DRAWING INITIATED MATERIAL CREE LED. ANY REPRODUCTION IN MATERIAL CREE LED. ANY REPRODUCTION IN MATERIAL PART OR AS A WHOLE WITHOUT PART OR AS A FINISH WHOLE WITHOUT PART OR AS A WHOLE WITHOUT FINISH C WRITTEN PERMISSION OFDESCRIPTION CREE LED FINISH WRITTEN PERMISSION OFDESCRIPTION CREE LED REV WRITTEN PERMISSION OF CREE LED REV ® ® 350006 IS PROHIBITED. B C FINISH REV DESCRIPTION IS PROHIBITED. FINISH © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree , the Cree logo, the Cree LED logo, XLamp , CLD-DS149 IS PROHIBITED. FINISH © CreeLED, Inc. a subsidiary CreeLED, a subsidiary © 2022 CreeLED, a subsidiary ofof2022 SMART Holdings, Inc.© APPLICATION of 2022 SMART Global Inc. Holdings, Inc. APPLICATION EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL are registered trademarks UL LLC. Global Other trademarks, REV 6 20:1 oflogo SMART Global Inc. Holdings, Inc. APPLICATION SHEETSC SCALE: WEIGHT: and company names are the property sponsorship 7 2 43 5 42 endorsement, 7 6 5of their respective owners and do 8product, 6 5 not imply 4 specific product and/or vendor 6 12 3 2 3 2 1 0.18 25 or association. XLAMP ® XP-L2 LED TAPE AND REEL All Cree LED carrier tapes conform to EIA-481D, Automated Component Handling Systems Standard. Except as noted, all dimensions in mm. All measurements are ±0.15 mm unless otherwise indicated. Po T E Do Bo R P2 W A Anode side F A P1 B D1 "H" Ko B-B SECTION Bo (on a place in the bottom of the corner radii) Ao (on a place in the bottom of the corner radii) R "I" Ao Item Dim. ITEM Ao Dim. 3.75 Bo Ao 3.75 5.40 Ko 2.90 DETAIL"H" DETAIL"I" A-A SECTION Bo Po 5.40 4.00 Ko Po P2 3.35 8.00 4.00 2.00 P1 T P1 0.30 8.00 ITEM F Do D1 W R Dim. 5.50 1.50 1.50 12.00 3deg E 1.75 P2 F 2.00 5.50 TDo 0.36 1.50 E D1 1.75 1.50 W R 12.00 3° NOTICE 1) All Cree LED carrier tapes conform to EIA-481D, Automated Component handling Systems Standard 2) Measurement tolerances unless indicated otherwise: .xx = ±.15 mm 2402-M022 XML3 © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 26 XLAMP ® XP-L2 LED TAPE AND REEL - CONTINUED Feed Direction END START Trailer Loaded Pockets Leader Min. 160 mm empty pockets sealed with tape 500 Lamps Min. 400 mm empty pockets with min. 100 mm sealed Feed Direction Cover Tape Pocket Tape 13 mm 7” © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 27 XLAMP ® XP-L2 LED PACKAGING © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 28 XLAMP ® XP-L2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS The following order codes are active and valid order codes, but higher performance options are also available. Please see page 3 page 4 for order codes of XLamp XP-L2 LEDs that could serve as alternatives for the order codes set forth below. XP-L2 EasyWhite, TJ = 85 °C CRI Nominal CCT Minimum Luminous Flux @1050 mA 2-Step 3-Step Flux Bin Flux (lm) @ 85 °C 70 V5 460 80 V3 420 70 V5 460 80 V3 420 45G XPLBWT-00-0000000HV345G 90 U5 360 45G XPLBWT-00-0000000UU545G 70 V5 460 V3 420 Min Typ Group Order Code Group 5000 K 4500 K 4000 K 50G 80 90 40G V2 400 U5 360 V4 440 40H XPLBWT-00-0000000UU540H 40G Order Code 80 Group Order Code 50E XPLBWT-00-0000000BV550E 45E XPLBWT-00-0000000BV545E 40E XPLBWT-00-0000000BV540E XPLBWT-00-0000000HV350G XPLBWT-00-0000000HV340G XPLBWT-00-0000000HV240G XPLBWT-00-0000000UU540G 70 3500 K 5-Step 35E V3 420 V3 420 V2 400 U6 380 U4 340 U3 320 90 XPLBWT-00-0000000BV435E XPLBWT-00-0000000BV335E XPLBWT-00-0000000HV335G 35G XPLBWT-00-0000000HV235G XPLBWT-00-0000000HU635G 35H XPLBWT-00-0000000UU435H XPLBWT-00-0000000UU335H 35G XPLBWT-00-0000000UU435G XPLBWT-00-0000000UU335G Notes • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 23). XLamp XP-L2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 29 XLAMP ® XP-L2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED CRI Nominal CCT Min Typ Minimum Luminous Flux @1050 mA Flux Bin Flux (lm) @ 85 °C V4 440 V3 420 V2 400 2-Step Group Order Code 3-Step Group Order Code 70 3000 K 5-Step Group 30E 80 30G U6 380 U3 320 U2 300 U6 380 U5 360 U2 300 90 30H XPLBWT-00-0000000UU330H XPLBWT-00-0000000UU230H 80 30G 27G 2700 K 90 27H T6 280 XPLBWT-00-0000000UU227H XPLBWT-00-0000000UT627H 27G Order Code XPLBWT-00-0000000BV430E XPLBWT-00-0000000BV330E XPLBWT-00-0000000HV230G XPLBWT-00-0000000HU630G XPLBWT-00-0000000UU330G XPLBWT-00-0000000UU230G XPLBWT-00-0000000HU627G XPLBWT-00-0000000HU527G XPLBWT-00-0000000UU227G XPLBWT-00-0000000UT627G Notes • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 23). XLamp XP-L2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 30 XLAMP ® XP-L2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 6 page 8 for order codes of XLamp XP-L2 LEDs that could serve as alternatives for the order codes set forth below. XP-L2 ANSI, TJ = 85 °C Chromaticity Minimum Luminous Flux (lm) @ 1050 mA Kit Flux Bin Flux (lm) @ 85 °C No Minimum CRI 70 CRI Minimum V5 460 XPLBWT-00-00000000V50DT XPLBWT-00-0000000BV50DT V4 440 XPLBWT-00-00000000V40DT XPLBWT-00-0000000BV40DT V3 420 XPLBWT-00-0000000HV30DT V2 400 XPLBWT-00-0000000HV20DT V6 480 XPLBWT-00-00000000V60CB V5 460 XPLBWT-00-00000000V50CB XPLBWT-00-0000000BV50CB V4 440 XPLBWT-00-00000000V40CB XPLBWT-00-0000000BV40CB V3 420 XPLBWT-00-0000000HV30CB V2 400 XPLBWT-00-0000000HV20CB U6 380 XPLBWT-00-0000000UU60CB U5 360 XPLBWT-00-0000000UU50CB V6 480 XPLBWT-00-00000000V60E1 V5 460 XPLBWT-00-00000000V50E1 XPLBWT-00-0000000BV50E1 V4 440 XPLBWT-00-00000000V40E1 XPLBWT-00-0000000BV40E1 V3 420 XPLBWT-00-0000000HV30E1 V2 400 XPLBWT-00-0000000HV20E1 DT CB E1 CCT 7000 K 6500 K 6500 K Order Codes 80 CRI Minimum 90 CRI Minimum Notes • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 23). XLamp XP-L2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 31 XLAMP ® XP-L2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED Chromaticity Minimum Luminous Flux (lm) @ 1050 mA Kit Flux Bin Flux (lm) @ 85 °C No Minimum CRI V6 480 XPLBWT-00-00000000V60DV V5 460 XPLBWT-00-00000000V50DV XPLBWT-00-0000000BV50DV V4 440 XPLBWT-00-00000000V40DV XPLBWT-00-0000000BV40DV V3 420 XPLBWT-00-0000000HV30DV V2 400 XPLBWT-00-0000000HV20DV U6 380 XPLBWT-00-0000000UU60DV U5 360 XPLBWT-00-0000000UU50DV V6 480 XPLBWT-00-00000000V60E2 V5 460 XPLBWT-00-00000000V50E2 V4 440 V3 420 DV E2 CCT 5700 K 5700 K Order Codes 70 CRI Minimum 80 CRI Minimum XPLBWT-00-0000000BV50E2 XPLBWT-00-0000000HV30E2 Chromaticity Minimum Luminous Flux (lm) @ 1050 mA Kit CCT Flux Bin Flux (lm) @ 85 °C 70 CRI Minimum V5 460 XPLBWT-00-0000-000BV50E3 E3 5000 K V4 440 V3 420 V5 460 V4 440 V3 420 V2 400 U6 380 U5 360 V5 460 XPLBWT-00-0000-000BV50E5 V4 440 XPLBWT-00-0000-000BV40E5 V3 420 XPLBWT-00-0000-000HV30E5 V2 400 XPLBWT-00-0000-000HV20E5 U6 380 U5 360 E4 E5 4500 K 4000 K 90 CRI Minimum Order Codes 80 CRI Minimum 90 CRI Minimum XPLBWT-00-0000-000HV30E3 XPLBWT-00-0000-000BV50E4 XPLBWT-00-0000-000HV30E4 XPLBWT-00-0000-000UU50E4 XPLBWT-00-0000-000UU50E5 Notes • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 23). XLamp XP-L2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 32 XLAMP ® XP-L2 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED Chromaticity Minimum Luminous Flux (lm) @ 1050 mA Kit Flux Bin Flux (lm) @ 85 °C 70 CRI Minimum V4 440 XPLBWT-00-0000-000BV40E6 V3 420 XPLBWT-00-0000-000BV30E6 V2 400 XPLBWT-00-0000-000HV20E6 U6 380 XPLBWT-00-0000-000HU60E6 U5 360 U4 340 XPLBWT-00-0000-000UU40E6 U3 320 XPLBWT-00-0000-000UU30E6 V4 440 XPLBWT-00-0000-000BV40E7 V3 420 XPLBWT-00-0000-000BV30E7 V2 400 XPLBWT-00-0000-000HV20E7 U6 380 XPLBWT-00-0000-000HU60E7 U5 360 U4 340 U3 320 U6 380 XPLBWT-00-0000-000HU60E8 U5 360 XPLBWT-00-0000-000HU50E8 U4 340 U3 320 U2 300 XPLBWT-00-0000-000UU20E8 T6 280 XPLBWT-00-0000-000UT60E8 E6 E7 E8 CCT 3500 K 3000 K 2700 K Order Codes 80 CRI Minimum 90 CRI Minimum XPLBWT-00-0000-000HV30E6 XPLBWT-00-0000-000UU30E7 Notes • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 23). XLamp XP-L2 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, the Cree LED logo, XLamp®, EasyWhite® and SC5 Technology® are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS149 REV 6 33
XPLBWT-00-0000-000HV340G 价格&库存
很抱歉,暂时无法提供与“XPLBWT-00-0000-000HV340G”相匹配的价格&库存,您可以联系我们找货
