XPGDWT-H1-0000-00H7E
    CREELED
    LED-3P_3.45X3.45MM_SM
    LED 照明 XLamp® XP-G3 白色,暖色 3000K 2.73V 350mA 125° 1414(3535 公制)
XPGDWT-H1-0000-00H7E 数据手册
PRODUCT FAMILY DATA SHEET XLamp® XP-G3 LEDs XP-G3 White XP-G3 Royal Blue XP-G3 Photo Red PRODUCT DESCRIPTION FEATURES XLamp® XP-G3 LEDs are optimized for directional, high‑lumen • Available in no CRI minimum white, 70-, 80- and 90-CRI white, lighting applications where efficacy and optical control are critical, royal blue & photo red such as roadway, portable and horticulture. The compact and • Broadcast color option at 5700 K proven 3.45‑mm XP platform has an excellent ecosystem of optics • ANSI-compatible chromaticity bins and system solutions available, enabling lighting manufacturers to • 3‑step and 5‑step options simplify their design process and shorten time‑to‑market. • White binned at 85 °C, royal blue & photo red binned at 25 °C • Maximum drive current: white, royal blue: 2000 mA, photo red: XP-G3 LEDs are available in Royal Blue and two different White and Photo Red versions: Standard & S Line. The White Standard version delivers best-in-class TM‑21 lifetimes and color stability over time. 1500 mA • Low thermal resistance: white: 1.1 °C/W, royal blue: 0.9 °C/W, photo red: 1.0 °C/W The S Line versions of White and Photo Red deliver improved • Wide viewing angle: 125°–130° efficiency, best-in-class sulfur resistance and better system-level • Unlimited floor life at ≤ 30 ºC/85% RH reliability through switching and dimming cycles. With these S • Reflow solderable - JEDEC J‑STD‑020C Line versions, Cree LED delivers high‑power LED technology that • Electrically neutral thermal path is optimized for both general and horticulture lighting applications • RoHS and REACH compliant where sensors and switching are becoming common. • UL® recognized component (E349212) In this document, the terms White and Photo Red denote the white or photo red XP-G3 LED without regard to its Standard or S Line features. The terms Standard and S Line are used when necessary to differentiate the performace of the Standard XP-G3 LED from the XP-G3 LED with the S Line option. Cree LED / 4001 E. Hwy. 54, Suite 2000 / Durham, NC 27709 USA / +1.919.313.5330 / www.cree-led.com © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 1 XLAMP ® XP-G3 LED TABLE OF CONTENTS Characteristics........................................................................................................................................................................................................ 3 Order Codes Suggested for New Designs - White (Standard)............................................................................................................................. 4 Order Codes Suggested for New Designs - White (S Line)................................................................................................................................ 10 Flux Characteristics - Color (Standard)............................................................................................................................................................... 12 Flux Characteristics - Color (S Line).................................................................................................................................................................... 12 Flux Characteristics - Broadcast Order Codes and Bins.................................................................................................................................... 13 Relative Spectral Power Distribution - White (Standard).................................................................................................................................... 14 Relative Spectral Power Distribution - White (S Line)......................................................................................................................................... 14 Relative Spectral Power Distribution - Color....................................................................................................................................................... 15 Relative Flux vs. Junction Temperature - White (Standard)............................................................................................................................... 15 Relative Flux vs. Junction Temperature - White (S Line).................................................................................................................................... 16 Relative Flux vs. Junction Temperature - Color................................................................................................................................................... 16 Electrical Characteristics - White (Standard)...................................................................................................................................................... 17 Electrical Characteristics - White (S Line)........................................................................................................................................................... 17 Electrical Characteristics - Color.......................................................................................................................................................................... 18 Relative Luminous Flux vs. Current - White (Standard)...................................................................................................................................... 18 Relative Luminous Flux vs. Current - White (S Line)........................................................................................................................................... 19 Relative Radiant Flux vs. Current - Color............................................................................................................................................................. 19 Relative Chromaticity vs. Current and Temperature........................................................................................................................................... 20 Typical Spatial Distribution - White (Standard)................................................................................................................................................... 21 Typical Spatial Distribution - White (S Line)........................................................................................................................................................ 21 Typical Spatial Distribution - Color....................................................................................................................................................................... 22 Thermal Design..................................................................................................................................................................................................... 23 Performance Groups - Luminous Flux................................................................................................................................................................. 24 Performance Groups - Radiant Flux..................................................................................................................................................................... 25 Performance Groups - Peak Wavelength............................................................................................................................................................ 26 Performance Groups - Forward Voltage.............................................................................................................................................................. 26 Performance Groups - Chromaticity.................................................................................................................................................................... 27 Standard Cool White Kits Plotted on ANSI Standard Chromaticity Regions..................................................................................................... 31 Standard Warm and Neutral White Kits Plotted on ANSI Standard Chromaticity Regions.............................................................................. 32 EasyWhite® White Kits Plotted on ANSI Standard Chromaticity Regions......................................................................................................... 34 Standard Chromaticity Kits.................................................................................................................................................................................. 35 Bin and Order Code Formats................................................................................................................................................................................ 36 Reflow Soldering Characteristics......................................................................................................................................................................... 37 Notes..................................................................................................................................................................................................................... 38 Mechanical Dimensions....................................................................................................................................................................................... 40 Tape and Reel........................................................................................................................................................................................................ 42 Packaging.............................................................................................................................................................................................................. 44 Appendix - Order Codes Not For New Designs................................................................................................................................................... 45 © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 2 XLAMP ® XP-G3 LED CHARACTERISTICS Characteristics Unit Thermal resistance, junction to solder point- white◊ Thermal resistance, junction to solder point - royal blue ◊ Thermal resistance, junction to solder point - photo red Minimum Typical °C/W 1.1 °C/W 0.9 °C/W 1.0 Viewing angle (FWHM) - white degrees 125 Viewing angle (FWHM) - royal blue degrees 130 Viewing angle (FWHM) - photo red degrees 125 Temperature coefficient of voltage mV/°C -1.6 ◊ ESD withstand voltage (HBM per Mil-Std-883D) Maximum Class 3A DC forward current - white, royal blue mA 2000 DC forward current - photo red mA 1500 Reverse voltage V 1 Forward voltage (@ 350 mA, 85 °C) - white V 2.70 2.90 Forward voltage (@ 350 mA, 25 °C) - royal blue V 2.79 3.0 Forward voltage (@ 350 mA, 25 °C) - photo red (Standard) V 1.99 2.2 Forward voltage (@ 350 mA, 25 °C) - photo red (S Line) V 1.95 2.2 Forward voltage (@ 700 mA, 85 °C) - white V 2.80 Forward voltage (@ 700 mA, 25 °C) - royal blue V 2.90 Forward voltage (@ 700 mA, 25 °C) - photo red (Standard) V 2.18 Forward voltage (@ 700 mA, 25 °C) - photo red (S Line) V 2.13 Forward voltage (@ 1000 mA, 85 °C) - white V 2.87 Forward voltage (@ 1000 mA, 25 °C) - royal blue V 2.99 Forward voltage (@ 1000 mA, 25 °C) - photo red (Standard) V 2.36 Forward voltage (@ 1000 mA, 25 °C) - photo red (S Line) V 2.26 Forward voltage (@ 1500 mA, 85 °C) - white V 2.97 Forward voltage (@ 1500 mA, 25 °C) - royal blue V 3.11 Forward voltage (@ 1500 mA, 25 °C) - photo red (Standard) V 2.65 Forward voltage (@ 1500 mA, 25 °C) - photo red (S Line) V 2.46 Forward voltage (@ 2000 mA, 85 °C) - white V 3.06 Forward voltage (@ 2000 mA, 25 °C) - royal blue V 3.20 LED junction temperature °C 150 Note: ◊ Thermal resistance measurement was performed per the JEDEC JESD51-14 standard. See the Thermal Resistance Measurement application note for more details. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 3 XLAMP ® XP-G3 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - WHITE (STANDARD) - TJ = 85 °C The following table provides order codes for XLamp XP-G3 White (Standard) LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 36). For definitions of the chromaticity kits, please see the Standard Chromaticity Kits section (page 35). Chromaticity Kit CCT DT 7000 K CB 6500 K E0 >6500 K E1 6500 K DV 6000 K 50 6000 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @25 °C* S6 180 196 S5 172 187 XPGDWT-01-0000-00MDT XPGDWT-B1-0000-00MDT S4 164 179 XPGDWT-01-0000-00LDT XPGDWT-B1-0000-00LDT XPGDWT-H1-0000-00LDT S3 156 170 XPGDWT-01-0000-00KDT XPGDWT-B1-0000-00KDT XPGDWT-H1-0000-00KDT S2 148 161 XPGDWT-01-0000-00JDT S4 164 179 XPGDWT-H1-0000-00LCB S3 156 170 XPGDWT-H1-0000-00KCB S5 172 187 XPGDWT-01-0000-00ME0 XPGDWT-B1-0000-00ME0 S4 164 179 XPGDWT-01-0000-00LE0 XPGDWT-B1-0000-00LE0 S3 156 170 S5 172 187 XPGDWT-01-0000-00ME1 XPGDWT-B1-0000-00ME1 S4 164 179 XPGDWT-01-0000-00LE1 XPGDWT-B1-0000-00LE1 XPGDWT-H1-0000-00LE1 S3 156 170 XPGDWT-B1-0000-00KE1 XPGDWT-H1-0000-00KE1 S6 180 196 XPGDWT-B1-0000-00NDV S5 172 187 XPGDWT-01-0000-00MDV S4 164 179 XPGDWT-01-0000-00LDV S3 156 170 S2 148 161 XPGDWT-U1-0000-00JDV R5 139 152 XPGDWT-U1-0000-00HDV R4 130 142 XPGDWT-U1-0000-00GDV S5 172 187 XPGDWT-01-0000-00M50 XPGDWT-B1-0000-00M50 S4 164 179 XPGDWT-01-0000-00L50 XPGDWT-B1-0000-00L50 XPGDWT-H1-0000-00L50 S3 156 170 XPGDWT-B1-0000-00K50 XPGDWT-H1-0000-00K50 S2 148 161 XPGDWT-U1-0000-00J50 R5 139 152 XPGDWT-U1-0000-00H50 R4 130 142 XPGDWT-U1-0000-00G50 70 CRI Typical 70 CRI Minimum 80 CRI Minimum 90 CRI Minimum XPGDWT-B1-0000-00NDT XPGDWT-B1-0000-00KE0 XPGDWT-H1-0000-00KE0 XPGDWT-B1-0000-00MDV XPGDWT-B1-0000-00LDV XPGDWT-H1-0000-00LDV XPGDWT-B1-0000-00KDV XPGDWT-H1-0000-00KDV Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 38). XLamp XP-G3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 4 XLAMP ® XP-G3 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - WHITE (STANDARD) - TJ = 85 °C (CONTINUED) Chromaticity Kit CCT E2 5700 K 2E 5700 K 3E 5000 K E3 5000 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @25 °C* 70 CRI Typical 70 CRI Minimum S6 180 196 XPGDWT-01-0000-00NE2 XPGDWT-B1-0000-00NE2 S5 172 187 XPGDWT-01-0000-00ME2 XPGDWT-B1-0000-00ME2 S4 164 179 XPGDWT-01-0000-00LE2 XPGDWT-B1-0000-00LE2 XPGDWT-H1-0000-00LE2 S3 156 170 XPGDWT-B1-0000-00KE2 XPGDWT-H1-0000-00KE2 S2 148 161 XPGDWT-U1-0000-00JE2 R5 139 152 XPGDWT-U1-0000-00HE2 R4 130 142 XPGDWT-U1-0000-00GE2 S6 180 196 XPGDWT-B1-0000-00N2E S5 172 187 XPGDWT-B1-0000-00M2E S4 164 179 XPGDWT-B1-0000-00L2E XPGDWT-H1-0000-00L2E S3 156 170 XPGDWT-B1-0000-00K2E XPGDWT-H1-0000-00K2E 80 CRI Minimum 90 CRI Minimum S2 148 161 XPGDWT-U1-0000-00J2E R5 139 152 XPGDWT-U1-0000-00H2E R4 130 142 XPGDWT-U1-0000-00G2E S6 180 196 XPGDWT-B1-0000-00N3E S5 172 187 XPGDWT-B1-0000-00M3E S4 164 179 XPGDWT-B1-0000-00L3E XPGDWT-H1-0000-00L3E S3 156 170 XPGDWT-B1-0000-00K3E XPGDWT-H1-0000-00K3E S2 148 161 XPGDWT-U1-0000-00J3E R5 139 152 XPGDWT-U1-0000-00H3E R4 130 142 XPGDWT-U1-0000-00G4E S6 180 196 XPGDWT-01-0000-00NE3 XPGDWT-B1-0000-00NE3 S5 172 187 XPGDWT-01-0000-00ME3 XPGDWT-B1-0000-00ME3 S4 164 179 XPGDWT-01-0000-00LE3 XPGDWT-B1-0000-00LE3 S3 156 170 S2 148 161 XPGDWT-U1-0000-00EJE3 R5 139 152 XPGDWT-U1-0000-00HE3 R4 130 142 XPGDWT-U1-0000-00GE3 XPGDWT-H1-0000-00LE3 XPGDWT-H1-0000-00KE3 Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 38). XLamp XP-G3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 5 XLAMP ® XP-G3 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - WHITE (STANDARD) - TJ = 85 °C (CONTINUED) Chromaticity Kit CCT F4 4750 K 4E 4500 K E4 4500 K F5 4200 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @25 °C* 70 CRI Typical 70 CRI Minimum S6 180 196 XPGDWT-01-0000-00NF4 XPGDWT-B1-0000-00NF4 S5 172 187 XPGDWT-01-0000-00MF4 XPGDWT-B1-0000-00MF4 S4 164 179 XPGDWT-01-0000-00LF4 XPGDWT-B1-0000-00LF4 S3 156 170 XPGDWT-H1-0000-00KF4 S2 148 161 XPGDWT-H1-0000-00JF4 R5 139 152 XPGDWT-U1-0000-00HF4 R4 130 142 XPGDWT-U1-0000-00GF4 S6 180 196 XPGDWT-B1-0000-00N4E S5 172 187 XPGDWT-B1-0000-00M4E S4 164 179 XPGDWT-B1-0000-00L4E S3 156 170 XPGDWT-H1-0000-00K4E S2 148 161 XPGDWT-H1-0000-00J4E R5 139 152 XPGDWT-U1-0000-00H4E R4 130 142 XPGDWT-U1-0000-00G4E S6 180 196 XPGDWT-01-0000-00NE4 XPGDWT-B1-0000-00NE4 S5 172 187 XPGDWT-01-0000-00ME4 XPGDWT-B1-0000-00ME4 S4 164 179 XPGDWT-01-0000-00LE4 XPGDWT-B1-0000-00LE4 S3 156 170 XPGDWT-H1-0000-00KE4 S2 148 161 XPGDWT-H1-0000-00JE4 R5 139 152 XPGDWT-U1-0000-00HE4 R4 130 142 XPGDWT-U1-0000-00GE4 S6 180 196 S5 172 187 XPGDWT-01-0000-00MF5 XPGDWT-B1-0000-00MF5 S4 164 179 XPGDWT-01-0000-00LF5 XPGDWT-B1-0000-00LF5 XPGDWT-H1-0000-00LF5 S3 156 170 XPGDWT-B1-0000-00KF5 XPGDWT-H1-0000-00KF5 S2 148 161 R5 139 152 XPGDWT-U1-0000-00HF5 R4 130 142 XPGDWT-U1-0000-00GF5 80 CRI Minimum 90 CRI Minimum XPGDWT-H1-0000-00LF4 XPGDWT-U1-0000-00JF4 XPGDWT-H1-0000-00L4E XPGDWT-U1-0000-00J4E XPGDWT-H1-0000-00LE4 XPGDWT-U1-0000-00JE4 XPGDWT-B1-0000-00NF5 XPGDWT-H1-0000-00JF5 XPGDWT-U1-0000-00JF5 Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 38). XLamp XP-G3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 6 XLAMP ® XP-G3 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - WHITE (STANDARD) - TJ = 85 °C (CONTINUED) Chromaticity Kit CCT 5E 4000 K E5 4000 K F6 3700 K 6E 3500 K 6G 3500 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @25 °C* S6 180 196 XPGDWT-B1-0000-00N5E S5 172 187 XPGDWT-B1-0000-00M5E S4 164 179 XPGDWT-B1-0000-00L5E XPGDWT-H1-0000-00L5E S3 156 170 XPGDWT-B1-0000-00K5E XPGDWT-H1-0000-00K5E S2 148 161 R5 139 152 XPGDWT-U1-0000-00H5E R4 130 142 XPGDWT-U1-0000-00G5E S6 180 196 S5 172 187 XPGDWT-01-0000-00ME5 XPGDWT-B1-0000-00ME5 S4 164 179 XPGDWT-01-0000-00LE5 XPGDWT-B1-0000-00LE5 XPGDWT-H1-0000-00LE5 S3 156 170 XPGDWT-B1-0000-00KE5 XPGDWT-H1-0000-00KE5 70 CRI Typical 70 CRI Minimum 80 CRI Minimum XPGDWT-H1-0000-00J5E 90 CRI Minimum XPGDWT-U1-0000-00J5E XPGDWT-B1-0000-00NE5 S2 148 161 R5 139 152 XPGDWT-H1-0000-00JE5 XPGDWT-U1-0000-00HE5 XPGDWT-U1-0000-00JE5 R4 130 142 XPGDWT-U1-0000-00GE5 S5 172 187 S4 164 179 XPGDWT-01-0000-00LF6 XPGDWT-B1-0000-00LF6 S3 156 170 XPGDWT-01-0000-00KF6 XPGDWT-B1-0000-00KF6 S2 148 161 XPGDWT-H1-0000-00JF6 R5 139 152 XPGDWT-H1-0000-00HF6 R4 130 142 S5 172 187 XPGDWT-B1-0000-00M6E S4 164 179 XPGDWT-B1-0000-00L6E S3 156 170 XPGDWT-B1-0000-00K6E S2 148 161 XPGDWT-H1-0000-00J6E R5 139 152 XPGDWT-H1-0000-00H6E R4 130 142 XPGDWT-U1-0000-00G6E R5 139 152 XPGDWT-U1-0000-00H6G R4 130 142 XPGDWT-U1-0000-00G6G XPGDWT-B1-0000-00MF6 XPGDWT-H1-0000-00KF6 XPGDWT-U1-0000-00HF6 XPGDWT-U1-0000-00GF6 XPGDWT-H1-0000-00K6E XPGDWT-U1-0000-00H6E Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 38). XLamp XP-G3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 7 XLAMP ® XP-G3 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - WHITE (STANDARD) - TJ = 85 °C (CONTINUED) Chromaticity Kit CCT E6 3500 K F7 3200 K 7E 3000 K 7G 3000 K E7 3000 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @25 °C* S5 172 187 S4 164 179 XPGDWT-01-0000-00LE6 XPGDWT-B1-0000-00LE6 S3 156 170 XPGDWT-01-0000-00KE6 XPGDWT-B1-0000-00KE6 S2 148 161 XPGDWT-H1-0000-00JE6 R5 139 152 XPGDWT-H1-0000-00HE6 R4 130 142 S5 172 187 S4 164 179 XPGDWT-01-0000-00LF7 XPGDWT-B1-0000-00LF7 S3 156 170 XPGDWT-01-0000-00KF7 XPGDWT-B1-0000-00KF7 XPGDWT-H1-0000-00KF7 S2 148 161 XPGDWT-01-0000-00JF7 XPGDWT-B1-0000-00JF7 XPGDWT-H1-0000-00JF7 R5 139 152 R4 130 142 XPGDWT-U1-0000-00GF7 R3 122 133 XPGDWT-U1-0000-00FF7 S5 172 187 XPGDWT-B1-0000-00M7E S4 164 179 XPGDWT-B1-0000-00L7E S3 156 170 XPGDWT-B1-0000-00K7E XPGDWT-H1-0000-00K7E S2 148 161 XPGDWT-B1-0000-00J7E XPGDWT-H1-0000-00J7E R5 139 152 R4 130 142 XPGDWT-U1-0000-00G7E R3 122 133 XPGDWT-U1-0000-00F7E R4 130 142 XPGDWT-U1-0000-00G7G R3 122 133 XPGDWT-U1-0000-00F7G S5 172 187 S4 164 179 XPGDWT-01-0000-00LE7 XPGDWT-B1-0000-00LE7 S3 156 170 XPGDWT-01-0000-00KE7 XPGDWT-B1-0000-00KE7 XPGDWT-H1-0000-00KE7 S2 148 161 XPGDWT-01-0000-00JE7 XPGDWT-B1-0000-00JE7 XPGDWT-H1-0000-00JE7 R5 139 152 R4 130 142 XPGDWT-U1-0000-00GE7 R3 122 133 XPGDWT-U1-0000-00FE7 70 CRI Typical 70 CRI Minimum 80 CRI Minimum 90 CRI Minimum XPGDWT-B1-0000-00ME6 XPGDWT-H1-0000-00KE6 XPGDWT-U1-0000-00HE6 XPGDWT-U1-0000-00GE6 XPGDWT-B1-0000-00MF7 XPGDWT-H1-0000-00HF7 XPGDWT-H1-0000-00H7E XPGDWT-B1-0000-00ME7 XPGDWT-H1-0000-00HE7 Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 38). XLamp XP-G3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 8 XLAMP ® XP-G3 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - WHITE (STANDARD) - TJ = 85 °C (CONTINUED) Chromaticity Kit CCT F8 2850 K 8E 2700 K 8G 2700 K E8 2700 K EA 2200 K BE 1800 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @25 °C* S2 148 161 XPGDWT-H1-0000-00JF8 R5 139 152 XPGDWT-H1-0000-00HF8 R4 130 142 XPGDWT-H1-0000-00GF8 R3 122 133 XPGDWT-U1-0000-00FF8 R2 114 124 XPGDWT-U1-0000-00EF8 S4 164 179 XPGDWT-B1-0000-00L8E S3 156 170 XPGDWT-B1-0000-00K8E S2 148 161 XPGDWT-B1-0000-00J8E R5 139 152 XPGDWT-H1-0000-00H8E R4 130 142 XPGDWT-H1-0000-00G8E R3 122 133 R2 114 124 XPGDWT-U1-0000-00E8E R3 122 133 XPGDWT-U1-0000-00F8G R2 114 124 XPGDWT-U1-0000-00E8G S4 164 179 XPGDWT-B1-0000-00LE8 S3 156 170 XPGDWT-B1-0000-00KE8 S2 148 161 XPGDWT-B1-0000-00JE8 R5 139 152 XPGDWT-H1-0000-00HE8 R4 130 142 XPGDWT-H1-0000-00GE8 R3 122 133 R2 114 124 R5 139 152 XPGDWT-B1-0000-00HEA R4 130 142 XPGDWT-B1-0000-00GEA R3 122 133 XPGDWT-01-0000-00FBE R2 114 124 XPGDWT-01-0000-00EBE 70 CRI Typical 70 CRI Minimum 80 CRI Minimum 90 CRI Minimum XPGDWT-H1-0000-00J8E XPGDWT-U1-0000-00F8E XPGDWT-H1-0000-00JE8 XPGDWT-U1-0000-00FE8 XPGDWT-U1-0000-00EE8 Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 38). XLamp XP-G3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 9 XLAMP ® XP-G3 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - WHITE (S LINE) - TJ = 85 °C The following table provides order codes for XLamp XP-G3 White (S Line) LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 36). For definitions of the chromaticity kits, please see the Standard Chromaticity Kits section (page 35). Chromaticity Kit CCT E1 6500 K DV 6000 K 50 6000 K E2 5700 K 2E 5700 K 3E 5000 K E3 5000 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @25 °C* 70 CRI Minimum S6 180 196 XPGDWT-BS-0000-00NE1 S5 172 187 XPGDWT-BS-0000-00ME1 S4 164 179 XPGDWT-BS-0000-00LE1 S6 180 196 XPGDWT-BS-0000-00NDV S5 172 187 XPGDWT-BS-0000-00MDV S4 164 179 XPGDWT-BS-0000-00LDV S6 180 196 XPGDWT-BS-0000-00N50 S5 172 187 XPGDWT-BS-0000-00M50 S4 164 179 XPGDWT-BS-0000-00L50 S7 188 205 XPGDWT-BS-0000-00PE2 S6 180 196 XPGDWT-BS-0000-00NE2 S5 172 187 XPGDWT-BS-0000-00ME2 S4 164 179 XPGDWT-BS-0000-00LE2 S7 188 205 XPGDWT-BS-0000-00P2E S6 180 196 XPGDWT-BS-0000-00N2E S5 172 187 XPGDWT-BS-0000-00M2E S4 164 179 XPGDWT-BS-0000-00L2E S7 188 205 XPGDWT-BS-0000-00P3E S6 180 196 XPGDWT-BS-0000-00N3E S5 172 187 XPGDWT-BS-0000-00M3E S4 164 179 XPGDWT-BS-0000-00L3E S7 188 205 XPGDWT-BS-0000-00PE3 S6 180 196 XPGDWT-BS-0000-00NE3 S5 172 187 XPGDWT-BS-0000-00ME3 S4 164 179 XPGDWT-BS-0000-00LE3 Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 38). XLamp XP-G3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 10 XLAMP ® XP-G3 LED ORDER CODES SUGGESTED FOR NEW DESIGNS - WHITE (S LINE) - TJ = 85 °C (CONTINUED) Chromaticity Kit CCT 4E 4500 K E4 4500 K 5E 4000 K E5 4000 K 6E 3500 K E6 3500 K F7 3200K 7E 3000 K E7 3000 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @25 °C* 70 CRI Minimum S6 180 196 XPGDWT-BS-0000-00N4E S5 172 187 XPGDWT-BS-0000-00M4E S4 164 179 XPGDWT-BS-0000-00L4E S6 180 196 XPGDWT-BS-0000-00NE4 S5 172 187 XPGDWT-BS-0000-00ME4 S4 164 179 XPGDWT-BS-0000-00LE4 S7 188 205 XPGDWT-BS-0000-00P5E S6 180 196 XPGDWT-BS-0000-00N5E S5 172 187 XPGDWT-BS-0000-00M5E S4 164 179 XPGDWT-BS-0000-00L5E S7 188 205 XPGDWT-BS-0000-00PE5 S6 180 196 XPGDWT-BS-0000-00NE5 S5 172 187 XPGDWT-BS-0000-00ME5 S4 164 179 XPGDWT-BS-0000-00LE5 S5 172 187 XPGDWT-BS-0000-00M6E S4 164 179 XPGDWT-BS-0000-00L6E S5 172 187 XPGDWT-BS-0000-00ME6 S4 164 179 XPGDWT-BS-0000-00LE6 S5 172 187 XPGDWT-BS-0000-00MF7 S4 164 179 XPGDWT-BS-0000-00LF7 S5 172 187 XPGDWT-BS-0000-00M7E S4 164 te XPGDWT-BS-0000-00L7E S5 172 187 XPGDWT-BS-0000-00ME7 S4 164 179 XPGDWT-BS-0000-00LE7 Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 38). XLamp XP-G3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 11 XLAMP ® XP-G3 LED FLUX CHARACTERISTICS - COLOR (STANDARD) - TJ = 25 °C The following table provides the order code for XLamp XP-G3 color (Standard) LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 36). Peak Wavelength Range Color Royal Blue PWL Kit Code 01 Minimum Group H26 PWL (nm) 440 Maximum Group H47 PWL (nm) 455 Typical Dominant Wavelength (nm) @ 350 mA, Tj=25 °C Photo Red (Standard) PWL Kit Code 01 Minimum Maximum Group PWL (nm) Group PWL (nm) P2 650 P5 670 Calculated Minimum PPF (µmol/s) @ 350 mA, 25 °C Order Code Code Flux (mW) @25 °C 451 E4 635 2.41 XPGDRY-L1-0000-00401 451 F2 680 2.58 XPGDRY-L1-0000-00501 451 F4 730 2.77 XPGDRY-L1-0000-00601 Calculated Minimum PPF (µmol/s) @ 350 mA, 25 °C Order Code Peak Wavelength Range Color Minimum Radiant Flux (mW) @ 350 mA, Typical Dominant Wavelength (nm) @ 350 mA, Tj=25 °C Minimum Radiant Flux (mW) @ 350 mA, Code Flux (mW) @25 °C 645 31 475 2.58 XPGDPR-L1-0000-00E01 645 32 500 2.72 XPGDPR-L1-0000-00F01 FLUX CHARACTERISTICS - COLOR (S LINE) - TJ = 25 °C The following table provides the order code for XLamp XP-G3 color (S Line) LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 36 Peak Wavelength Range Color Photo Red (S Line) PWL Kit Code 01 Minimum Group P2 PWL (nm) 650 Maximum Group P5 PWL (nm) 670 Typical Dominant Wavelength (nm) @ 350 mA, Tj=25 °C Minimum Radiant Flux (mW) @ 350 mA, Calculated Minimum PPF (µmol/s) @ 350 mA, 25 °C Order Code Code Flux (mW) @25 °C 645 32 500 2.72 XPGDPR-LS-0000-00F01 645 33 525 2.85 XPGDPR-LS-0000-00G01 645 34 550 2.98 XPGDPR-LS-0000-00H01 Notes • • • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 38). XLamp XP-G3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Dominant wavelengths are calculated based on peak wavelength specifications and are for reference only. Calculated Photosynthetic Photon Flux (PPF) values are for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 12 XLAMP ® XP-G3 LED FLUX CHARACTERISTICS - BROADCAST ORDER CODES AND BINS (TJ = 85 °C) The following table provides order codes for XLamp XP-G3 Broadcast LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 36). For definitions of the chromaticity kits, please see the Standard Chromaticity Kits section (page 35). Chromaticity Kit CCT E2 5700 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Flux Bin Flux (lm) @ 85 °C Flux (lm) @ 25 °C* 90 CRI Minimum 90 TLCI Minimum R5 139 152 XPGDWT-U1-B001-A0HE2 R4 130 142 95 CRI Minimum 95 TLCI Minimum XPGDWT-Z1-B001-A0GE2 Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 38). XLamp XP-G3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 13 XLAMP ® XP-G3 LED Relative Spectral Power RELATIVE1800 SPECTRAL POWERXPGD1800K DISTRIBUTION - WHITE (STANDARD) K from: 20220725 spectrum.xlsx 100% Relative Radiant Power 80% 5000 K, 70 CRI 60% 4000 K, 70 CRI 3000 K, 80 CRI 40% 1800 K, 70 CRI 20% 0% 380 430 480 Relative Spectral Power 530 580 630 680 730 780 Wavelength (nm) RELATIVE SPECTRAL POWER DISTRIBUTION - WHITE (S LINE) Relative Radiant Power 100% 80% 60% 5000 K, 70 CRI 4000 K, 70 CRI 40% 20% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 14 XLAMP ® XP-G3 LED Relative Spectral Power royal blue data from: graphics/SA products Vf data sheet update.xlsx S Line Photo Red from: XPGD_Red_G2 Datasheet 201217.xlsx RELATIVE SPECTRAL POWER DISTRIBUTION - COLOR 100% Relative Radiant Power 80% Royal Blue 60% Photo Red (Standard) 40% Photo Red (S Line) 20% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Relative Flux Output vs. Junction Temperature RELATIVE FLUX VS. JUNCTION TEMPERATURE - WHITE (STANDARD) - IF = 350 mA 120% Relative Luminous Flux 100% 80% 60% 40% 20% 0% 25 50 75 100 125 150 Junction Temperature (ºC) © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 15 XLAMP ® XP-G3 LED Relative Flux Output vs. Junction Temperature RELATIVE FLUX VS. JUNCTION TEMPERATURE - WHITE (S LINE) - IF = 350 mA 120% Relative Luminous Flux 100% 80% 60% 40% 20% 0% 25 50 75 100 125 150 Junction Temperature (ºC) Relative Flux Output vs. Junction Temperature RELATIVE FLUX VS. JUNCTION TEMPERATURE - COLOR - IF = 350 mA 100% 90% Relative Radiant Flux 80% 70% Royal Blue 60% 50% Photo Red (Standard) 40% Photo Red (S Line) 30% 20% 10% 0% 25 50 75 100 125 150 Junction Temperature (ºC) S Line Photo Red from: XPGD_Red_G2 Datasheet 201217.xlsx © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 16 XLAMP ® XP-G3 LED Electrical Characteristics 2nd order polynomial trendline data line with No Line selected ELECTRICAL CHARACTERISTICS - WHITE (STANDARD) - TJ = 85 °C 2000 Forward Current (mA) 1750 1500 1250 1000 750 500 250 0 2.60 2.65 2.70 2.75 2.80 2.85 2.90 2.95 3.00 3.05 3.10 3.15 3.20 3.00 3.05 3.10 3.15 3.20 Forward Voltage (V) Electrical Characteristics 2nd order polynomial trendline data line with Nofrom: Line selected data graphics/SA products Vf data sheet update.xlsx ELECTRICAL CHARACTERISTICS - WHITE (S LINE) - TJ = 85 °C 2000 Forward Current (mA) 1750 1500 1250 1000 750 500 250 0 2.60 2.65 2.70 2.75 2.80 2.85 2.90 2.95 Forward Voltage (V) data from: graphics/SA products Vf data sheet update.xlsx © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 17 XLAMP ® XP-G3 LED ELECTRICAL CHARACTERISTICS - COLOR (TJ = 25 °C) Electrical Characteristics 2000 2000 Forward Current (mA) Forward Current (mA) 1750 1750 1500 1500 Royal Blue 1250 1250 1000 1000 Royal Blue 750 750 Photo Red Photo Red (Standard) Photo Red (S Line) 500 500 250 250 0 0 1.7 2.60 1.8 2.65 1.9 2.70 2.0 2.3 2.75 2.1 2.802.2 2.85 2.4 2.90 2.5 2.8 2.95 2.63.002.7 3.05 (V) ForwardForward Voltage Voltage (V) 2.9 3.10 3.0 3.15 3.13.20 3.2 royal blue data from: graphics/SA products Vf data sheet update.xlsx Relative Intensity Current (Tj = 25ºC) S Line Photo Red from: vs. XPGD_Red_G2 Datasheet 201217.xlsx RELATIVE LUMINOUS FLUX VS. CURRENT - WHITE (STANDARD) - TJ = 85 °C 500% 450% Relative Luminous Flux 400% 350% 300% 250% 200% 150% 100% 50% 0% 0 250 500 750 1000 1250 1500 1750 2000 Forward Current (mA) © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 18 XLAMP ® XP-G3 LED Relative Intensity vs. Current (Tj = 25ºC) RELATIVE LUMINOUS FLUX VS. CURRENT - WHITE (S LINE) - TJ = 85 °C 500% Relative Luminous Flux 450% 400% 350% 300% 250% 200% 150% 100% 50% 0% 0 250 500 750 1000 1250 1500 1750 2000 Forward Current (mA) Relative Intensity vs. Current (Tj = 25ºC) S Line Photo Red from:VS. XPGD_Red_G2 RELATIVE RADIANT FLUX CURRENTDatasheet - COLOR201217.xlsx (TJ = 25 °C) 500% 450% Relative Radiant Flux 400% 350% Royal Blue 300% 250% Photo Red (Standard) 200% Photo Red (S Line) 150% 100% 50% 0% 0 250 500 750 1000 1250 1500 1750 2000 Forward Current (mA) © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 19 XLAMP ® XP-G3 LED Delta CCT vs. Current RELATIVE CHROMATICITY VS. CURRENT AND TEMPERATURE Data shown is representative of typical XP-G3 70 CRI performance. 0.020 0.015 0.010 0.005 ΔCCx 0.000 ΔCCy -0.005 -0.010 Delta CCT vs Temp -0.015 -0.020 0 250 500 750 1000 1250 1500 1750 2000 Current (mA) 0.020 0.015 0.010 0.005 ΔCCx 0.000 ΔCCy -0.005 -0.010 -0.015 -0.020 25 50 75 100 125 150 Tsp (°C) © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 20 XLAMP ® XP-G3 LED Typical Spatial Radiation Pattern white DISTRIBUTION - WHITE (STANDARD) TYPICAL SPATIAL 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 0% -10 10 30 50 70 90 30 50 70 90 Angle (º) Typical Spatial Radiation Pattern white DISTRIBUTION - WHITE (S LINE) TYPICAL SPATIAL 100% Relative Luminous Intensity 80% 60% 40% 20% -90 -70 -50 -30 -10 0% 10 Angle (º) © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 21 XLAMP ® XP-G3 LED royal blue data from: graphics/SA products Vf data sheet update.xlsx TYPICAL SPATIAL DISTRIBUTION - COLOR S Line Photo Red from: XPGD_Red_G2 Datasheet 201217.xlsx 100% Relative Luminous Intensity 80% Royal Blue 60% Photo Red (Standard) 40% Photo Red (S Line) 20% -90 -70 -50 -30 -10 0% 10 30 50 70 90 Angle (º) © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 22 XLAMP ® XP-G3 LED THERMAL DESIGN Thermal Design hermal The Design - white maximum forward current is determined by the thermal resistance between the LED junction and ambient. It is crucial for the end product to be designed in a manner that minimizes the thermal resistance from the solder point to ambient in order to optimize lamp life and optical characteristics. White (Standard) 2000 2000 1750 1750 1500 1250 1000 750 Rj-a = 10°C/W 500 Rj-a = 15°C/W 1500 1250 1000 750 Rj-a = 10°C/W 500 Rj-a = 15°C/W Rj-a = 20°C/W 250 Rj-a = 20°C/W 250 Rj-a = 25°C/W Thermal0 Design-royal 0 20 40 blue 60 80 100 120 140 Ambient Temperature (ºC) 0 160 Rj-a = 25°C/W 0 20 40 60 80 100 Thermal Design-photoAmbient red Temperature standard (ºC) Royal Blue 2250 2250 120 140 160 Photo Red (Standard) 1750 2000 2000 Maximum Current (mA) 1500 Maximum Current (mA) Maximum Current (mA) 1750 1750 1500 1500 1250 1250 1000 1000 750 750 500 500 250 250 0 00 White (S Line) 2250 Maximum Current (mA) Maximum Current (mA) 2250 Rj-a = 10°C/W Rj-a = 10°C/W Rj-a = 15°C/W Rj-a = 15°C/W Rj-a = 20°C/W Rj-a = 20°C/W Rj-a = 25°C/W Rj-a = 25°C/W 20 0 40 20 1000 750 Rj-a = 10°C/W 500 Rj-a = 15°C/W Rj-a = 20°C/W 250 60 40 1250 80 60 100 80 100 Ambient Temperature (ºC) Ambient Temperature (ºC) 120 120 140 140 Rj-a = 25°C/W 160 0 160 0 20 40 60 80 100 Thermal Design-S Line photo red Ambient Temperature (ºC) 120 140 160 120 140 160 S Line Photo Red from: XPGD_Red_G2 Datasheet 201217.xlsx Photo Red (S Line) 1750 Maximum Current (mA) 1500 1250 1000 750 Rj-a = 10°C/W 500 Rj-a = 15°C/W Rj-a = 20°C/W 250 Rj-a = 25°C/W 0 0 20 40 60 80 100 Ambient Temperature (ºC) © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 23 XLAMP ® XP-G3 LED PERFORMANCE GROUPS - LUMINOUS FLUX XLamp XP-G3 White LEDs are tested for luminous flux and placed into one of the following luminous‑flux groups. Group Code Minimum Luminous Flux (lm) @ 350 mA Maximum Luminous Flux (lm) @ 350 mA Q4 100 107 Q5 107 114 R2 114 122 R3 122 130 R4 130 139 R5 139 148 S2 148 156 S3 156 164 S4 164 172 S5 172 180 S6 180 188 S7 188 196 S8 196 204 © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 24 XLAMP ® XP-G3 LED PERFORMANCE GROUPS - RADIANT FLUX (TJ = 25 °C) XLamp XP-G3 Royal Blue LEDs are tested for radiant flux and placed into one of the following bins. Group Code Minimum Radiant Flux (mW) Maximum Radiant Flux (mW) E4 635 F2 680 F4 730 Calculated PPF (µmol/s) Minimum Maximum 680 2.41 2.58 730 2.58 2.77 780 2.77 2.96 XLamp XP-G3 Photo Red (Standard) LEDs are tested for radiant flux and placed into one of the following bins. Calculated PPF (µmol/s) Group Code Minimum Radiant Flux (mW) Maximum Radiant Flux (mW) Minimum Maximum 31 475 500 2.58 2.72 32 500 525 2.72 2.85 XLamp XP-G3 Photo Red (S Line) LEDs are tested for radiant flux and placed into one of the following bins. Calculated PPF (µmol/s) Group Code Minimum Radiant Flux (mW) Maximum Radiant Flux (mW) Minimum Maximum 32 500 525 2.72 2.85 33 525 550 2.85 2.98 34 550 575 2.98 3.11 Note • Calculated PPF values are for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 25 XLAMP ® XP-G3 LED PERFORMANCE GROUPS - PEAK WAVELENGTH (TJ = 25 °C) XLamp XP-G3 Royal Blue LEDs are tested for peak wavelength and sorted into one of the PWL bins defined below. Group Code Minimum Peak Wavelength (nm) Maximum Peak Wavelength (nm) Typical Dominant Wavelength (nm) H26 440.0 442.5 446.5 H27 442.5 445.0 449.0 H36 445.0 447.5 451.5 H37 447.5 450.0 454.0 H46 450.0 452.5 456.5 H47 452.5 455.0 459.0 XLamp XP-G3 Photo Red LEDs are tested for peak wavelength and sorted into one of the PWL bins defined below. Group Code Minimum Peak Wavelength (nm) Maximum Peak Wavelength (nm) Typical Dominant Wavelength (nm) P2 650 655 638 P3 655 660 643 P4 660 665 647 P5 665 670 652 Note • Typical dominant wavelength values are calculated and for reference only. PERFORMANCE GROUPS - FORWARD VOLTAGE XLamp XP-G3 Photo Red LEDs are tested for forward voltage and sorted into one of the forward voltage bins defined below. Forward Voltage Group Minimum Forward Voltage (V) @ 350 mA Maximum Forward Voltage (V) @ 350 mA W 1.8 1.9 X 1.9 2.0 Y 2.0 2.1 Z 2.1 2.2 © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 26 XLAMP ® XP-G3 LED PERFORMANCE GROUPS - CHROMATICITY Region 0A 0R 1A 1R 2A 2R 3A 3R 4A x y 0.2950 0.2970 0.2920 0.3060 0.2984 0.3133 0.3009 Region x y 0.2920 0.3060 x y x y 0.2984 0.3133 0.2984 0.3133 0.2895 0.3135 0.2962 0.3220 0.3048 0.3207 0.2962 0.3220 0.3028 0.3304 0.3068 0.3113 0.3042 0.2984 0.3133 0.3048 0.3207 0.3009 0.3042 0.2980 0.2880 0.2895 0.3135 0.2962 0.3220 0.3037 0.2937 0.2950 0.2970 0.2870 0.3210 0.2937 0.3312 0.3009 0.3042 0.3009 0.3042 0.2937 0.3312 0.3005 0.3415 0.3068 0.3113 0.3037 0.2937 0.2962 0.3220 0.3028 0.3304 0.3093 0.2993 0.3048 0.3207 0.3028 0.3304 0.3115 0.3391 0.3130 0.3290 0.3130 0.3290 0.3115 0.3391 0.3205 0.3481 0.3213 0.3373 0.3144 0.3186 0.3130 0.3290 0.3213 0.3373 0.3221 0.3261 0.3068 0.3113 0.3048 0.3207 0.3130 0.3290 0.3144 0.3186 0.3068 0.3113 0.3005 0.3415 0.3099 0.3509 0.3144 0.3186 0.3144 0.3186 0.3099 0.3509 0.3196 0.3602 0.3221 0.3261 0.3161 0.3059 0.3115 0.3391 0.3205 0.3481 0.3231 0.3120 0.3093 0.2993 0.3028 0.3304 0.3115 0.3391 0.3161 0.3059 0.3215 0.3350 0.3207 0.3462 0.3290 0.3538 0.3290 0.3417 0.3290 0.3417 0.3290 0.3538 0.3376 0.3616 0.3371 0.3490 0.3290 0.3300 0.3290 0.3417 0.3371 0.3490 0.3366 0.3369 0.3222 0.3243 0.3215 0.3350 0.3290 0.3417 0.3290 0.3300 0.3222 0.3243 0.3196 0.3602 0.3290 0.3690 0.3290 0.3300 0.3290 0.3300 0.3290 0.3690 0.3381 0.3762 0.3366 0.3369 0.3290 0.3180 0.3290 0.3538 0.3376 0.3616 0.3361 0.3245 0.3231 0.3120 0.3207 0.3462 0.3290 0.3538 0.3290 0.3180 0.3371 0.3490 0.3376 0.3616 0.3463 0.3687 0.3451 0.3554 0.3451 0.3554 0.3463 0.3687 0.3551 0.3760 0.3533 0.3620 0.3440 0.3427 0.3451 0.3554 0.3533 0.3620 0.3515 0.3487 0.3366 0.3369 0.3371 0.3490 0.3451 0.3554 0.3440 0.3427 0.3366 0.3369 0.3381 0.3762 0.3440 0.3428 0.3480 0.3840 0.3429 0.3307 0.3463 0.3687 0.3361 0.3245 0.3376 0.3616 0.3530 0.3597 0.3548 0.3736 0.3641 0.3804 0.3615 0.3659 0.3615 0.3659 0.3641 0.3804 0.3736 0.3874 0.3702 0.3722 0.3590 0.3521 0.3615 0.3659 0.3702 0.3722 0.3670 0.3578 0.3512 0.3465 0.3530 0.3597 0.3615 0.3659 0.3590 0.3521 0B 0S 1B 1S 2B 2S 3B 3S 4B Region 0C 0T 1C 1T 2C 2T 3C 4C © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. Region 0D 0U 1D 1U 2D 2U 3D 4D CLD-DS139 REV 14 27 XLAMP ® XP-G3 LED PERFORMANCE GROUPS - CHROMATICITY (CONTINUED) Region 5A1 5B1 5C1 5D1 6A1 6B1 6C1 6D1 7A1 x y 0.3670 0.3578 0.3686 0.3649 0.3744 0.3685 0.3726 0.3612 0.3702 0.3722 0.3719 0.3797 0.3782 0.3837 0.3763 Region x y 0.3686 0.3649 x y x y 0.3744 0.3685 0.3726 0.3612 0.3702 0.3722 0.3763 0.3760 0.3744 0.3685 0.3763 0.3760 0.3744 0.3685 0.3825 0.3798 0.3804 0.3721 0.3804 0.3721 0.3783 0.3646 0.3719 0.3797 0.3782 0.3837 0.3763 0.3760 0.3736 0.3874 0.3802 0.3916 0.3782 0.3837 0.3802 0.3916 0.3869 0.3958 0.3847 0.3877 0.3760 0.3782 0.3837 0.3847 0.3877 0.3825 0.3798 0.3825 0.3798 0.3847 0.3877 0.3912 0.3917 0.3887 0.3836 0.3847 0.3877 0.3869 0.3958 0.3937 0.4001 0.3912 0.3917 0.3912 0.3917 0.3937 0.4001 0.4006 0.4044 0.3978 0.3958 0.3887 0.3836 0.3912 0.3917 0.3978 0.3958 0.3950 0.3875 0.3783 0.3646 0.3804 0.3721 0.3863 0.3758 0.3840 0.3681 0.3804 0.3721 0.3825 0.3798 0.3887 0.3836 0.3863 0.3758 0.3863 0.3758 0.3887 0.3836 0.3950 0.3875 0.3924 0.3794 0.3840 0.3681 0.3863 0.3758 0.3924 0.3794 0.3898 0.3716 0.3889 0.3690 0.3915 0.3768 0.3981 0.3800 0.3953 0.3720 0.3915 0.3768 0.3941 0.3848 0.4010 0.3882 0.3981 0.3800 0.3981 0.3800 0.4010 0.3882 0.4080 0.3916 0.4048 0.3832 0.3953 0.3720 0.3981 0.3800 0.4048 0.3832 0.4017 0.3751 0.3941 0.3848 0.3968 0.3930 0.4040 0.3966 0.4010 0.3882 0.3968 0.3930 0.3996 0.4015 0.4071 0.4052 0.4040 0.3966 0.4040 0.3966 0.4071 0.4052 0.4146 0.4089 0.4113 0.4001 0.4010 0.3882 0.4040 0.3966 0.4113 0.4001 0.4080 0.3916 0.4080 0.3916 0.4113 0.4001 0.4186 0.4037 0.4150 0.3950 0.4113 0.4001 0.4146 0.4089 0.4222 0.4127 0.4186 0.4037 0.4186 0.4037 0.4222 0.4127 0.4299 0.4165 0.4259 0.4073 0.4150 0.3950 0.4186 0.4037 0.4259 0.4073 0.4221 0.3984 0.4017 0.3751 0.4048 0.3832 0.4116 0.3865 0.4082 0.3782 0.4048 0.3832 0.4080 0.3916 0.4150 0.3950 0.4116 0.3865 0.4116 0.3865 0.4150 0.3950 0.4221 0.3984 0.4183 0.3898 0.4082 0.3782 0.4116 0.3865 0.4183 0.3898 0.4147 0.3814 0.4147 0.3814 0.4183 0.3898 0.4242 0.3919 0.4203 0.3833 0.4183 0.3898 0.4221 0.3984 0.4281 0.4006 0.4242 0.3919 0.4242 0.3919 0.4281 0.4006 0.4342 0.4028 0.4300 0.3939 0.4203 0.3833 0.4242 0.3919 0.4300 0.3939 0.4259 0.3853 5A2 5B2 5C2 5D2 6A2 6B2 6C2 6D2 7A2 Region 5A3 5B3 5C3 5D3 6A3 6B3 6C3 6D3 7A3 © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. Region 5A4 5B4 5C4 5D4 6A4 6B4 6C4 6D4 7A4 CLD-DS139 REV 14 28 XLAMP ® XP-G3 LED PERFORMANCE GROUPS - CHROMATICITY (CONTINUED) Region 7B1 7C1 7D1 8A1 8B1 8C1 8D1 AA1 AB1 x y 0.4221 0.3984 0.4259 0.4073 0.4322 0.4096 0.4281 0.4006 0.4342 0.4028 0.4385 0.4119 0.4449 0.4141 0.4403 Region x y 0.4259 0.4073 x y x y 0.4322 0.4096 0.4281 0.4006 0.4299 0.4165 0.4364 0.4188 0.4322 0.4096 0.4364 0.4188 0.4322 0.4096 0.4430 0.4212 0.4385 0.4119 0.4385 0.4119 0.4342 0.4028 0.4385 0.4119 0.4449 0.4141 0.4403 0.4049 0.4430 0.4212 0.4496 0.4236 0.4449 0.4141 0.4496 0.4236 0.4562 0.4260 0.4513 0.4164 0.4049 0.4449 0.4141 0.4513 0.4164 0.4465 0.4071 0.4259 0.3853 0.4300 0.3939 0.4359 0.3960 0.4316 0.3873 0.4300 0.3939 0.4342 0.4028 0.4403 0.4049 0.4359 0.3960 0.4359 0.3960 0.4403 0.4049 0.4465 0.4071 0.4418 0.3981 0.4316 0.3873 0.4359 0.3960 0.4418 0.3981 0.4373 0.3893 0.4373 0.3893 0.4418 0.3981 0.4475 0.3994 0.4428 0.3906 0.4418 0.3981 0.4465 0.4071 0.4523 0.4085 0.4475 0.3994 0.4475 0.3994 0.4523 0.4085 0.4582 0.4099 0.4532 0.4008 0.4428 0.3906 0.4475 0.3994 0.4532 0.4008 0.4483 0.3919 0.4465 0.4071 0.4513 0.4164 0.4573 0.4178 0.4523 0.4085 0.4513 0.4164 0.4562 0.4260 0.4624 0.4274 0.4573 0.4178 0.4573 0.4178 0.4624 0.4274 0.4687 0.4289 0.4634 0.4193 0.4523 0.4085 0.4573 0.4178 0.4634 0.4193 0.4582 0.4099 0.4582 0.4099 0.4634 0.4193 0.4695 0.4207 0.4641 0.4112 0.4634 0.4193 0.4687 0.4289 0.4750 0.4304 0.4695 0.4207 0.4695 0.4207 0.4750 0.4304 0.4813 0.4319 0.4756 0.4221 0.4641 0.4112 0.4695 0.4207 0.4756 0.4221 0.4700 0.4126 0.4483 0.3919 0.4532 0.4008 0.4589 0.4021 0.4538 0.3931 0.4532 0.4008 0.4582 0.4099 0.4641 0.4112 0.4589 0.4021 0.4589 0.4021 0.4641 0.4112 0.4700 0.4126 0.4646 0.4034 0.4538 0.3931 0.4589 0.4021 0.4646 0.4034 0.4593 0.3944 0.4822 0.3973 0.4884 0.4067 0.4942 0.4066 0.4879 0.3972 0.4884 0.4067 0.4946 0.4162 0.5006 0.4160 0.4942 0.4066 0.4942 0.4066 0.5006 0.4160 0.5066 0.4158 0.5001 0.4064 0.4879 0.3972 0.4942 0.4066 0.5001 0.4064 0.4936 0.3970 0.4946 0.4162 0.5008 0.4256 0.5069 0.4254 0.5006 0.4160 0.5008 0.4256 0.5070 0.4350 0.5133 0.4348 0.5069 0.4254 0.5069 0.4254 0.5133 0.4348 0.5196 0.4346 0.5131 0.4252 0.5006 0.4160 0.5069 0.4254 0.5131 0.4252 0.5066 0.4158 7B2 7C2 7D2 8A2 8B2 8C2 8D2 AA2 AB2 Region 7B3 7C3 7D3 8A3 8B3 8C3 8D3 AA3 AB3 © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. Region 7B4 7C4 7D4 8A4 8B4 8C4 8D4 AA4 AB4 CLD-DS139 REV 14 29 XLAMP ® XP-G3 LED PERFORMANCE GROUPS - CHROMATICITY (CONTINUED) Region AC1 AD1 x y 0.5066 0.4158 0.5131 0.4252 0.5192 0.4250 0.5126 0.4156 0.4936 0.3970 0.5001 0.4064 0.5059 0.4062 0.4993 0.3969 Region AC2 AD2 x y Region 0.5131 0.4252 0.5196 0.4346 0.5258 0.4343 0.5192 0.4250 0.5001 0.4064 0.5066 0.4158 0.5126 0.4156 0.5059 0.4062 AC3 AD3 x y 0.5192 0.4250 0.5258 0.4343 0.5321 0.4341 0.5253 0.4248 0.5059 0.4062 0.5126 0.4156 0.5186 0.4154 0.5118 0.4061 Region AC4 AD4 x y 0.5126 0.4156 0.5192 0.4250 0.5253 0.4248 0.5186 0.4154 0.4993 0.3969 0.5059 0.4062 0.5118 0.4061 0.5050 0.3967 XLamp XP-G3 White LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 3-Step Ellipse Bin Code CCT 6G Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 3500 K 0.4073 0.3917 0.00927 0.00414 53.2 7G 3000 K 0.4338 0.4030 0.00834 0.00408 53.2 8G 2700 K 0.4577 0.4099 0.00834 0.00420 48.5 EasyWhite Color Temperatures – 5-Step Ellipse Bin Code CCT 2E Center Point Major Axis Minor Axis Rotation Angle (°) x y a b 5700 K 0.3287 0.3417 0.01230 0.00600 72.0 3E 5000 K 0.3447 0.3553 0.01400 0.00520 65.0 4E 4500 K 0.3611 0.3658 0.01420 0.00550 61.5 5E 4000 K 0.3818 0.3797 0.01565 0.00670 53.7 6E 3500 K 0.4073 0.3917 0.01545 0.00690 54.0 7E 3000 K 0.4338 0.4030 0.01390 0.00680 53.2 8E 2700 K 0.4577 0.4099 0.01350 0.00700 48.5 BE 1800 K 0.5492 0.4082 0.00683 0.01546 -40.0 © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 30 XLAMP ® XP-G3 LED STANDARD COOL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.40 0.40 5000 K 0.39 0.38 0.38 5700 K 5700 K 0.37 0.37 6500 K 6500 K 2T 0.36 0.36 2S DT 0.34 0T 0C 1D 2U 0A ANSI C78.377A 1U 0D 0C 0B 0.31 1R 0A ANSI C78.377A 2R 1U 1R 0U 0.36 0.35 0.30 0.29 0.28 0.36 0.35 0.34 0.33 0.32 0.31 0.28 0.30 0.28 0.34 0R 0.29 CCx CCx 0.40 0.40 5000 K 0.39 0.38 0.38 DV 6500 K 0.36 6500 K 0.36 2C 1T 8000 K 2B 1S 0T 0.33 0S 0.32 0B 0.31 2A 1B 0C 1D 2U 1U E0 0S 0C 0.31 2D 3R 2A 1D 2U ANSI C78.377A 2R 1U 1R 0U 0.30 0.29 3A 2B 1A 0D 0A 0R 2C 1C 1B 0B 3B 2S 1T 1S 0T 0.32 1R 0U 0.30 8000 K 0.34 0.33 ANSI C78.377A 2R 1A 0D 0A 2D 1C 3S 2T E1 0.35 CCy 0.34 5700 K E2 0.37 2T 2S 0.35 5000 K 0.39 5700 K 0.37 0R 0.29 0.36 0.35 0.34 0.33 0.32 0.30 CCx 0.29 0.28 0.28 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.28 0.31 CCy 2U 1D 0D 0R 0.29 2A 1A 0.30 0.29 0.28 2D 1C 1B 0S 0.32 0U 0.30 0T 0.33 2R 1A 0.34 2B 1S 0.33 0B 0.31 2A 2C 1T 8000 K 0.32 0S 0.32 2D 1C 1B CB 0.35 2B 1S 0.33 2C 1T 2T 2S 0.31 8000 K CCy 0.35 CCy 5000 K 0.39 CCx 0.40 5000 K 0.39 0.38 5700 K 6500 K 0.36 2T 3B 2S 0.35 2C 1T 8000 K 0.34 CCy 3S 50 0.37 0T 0.33 0S 0.32 0C 0.31 3R 2A 1D 2U ANSI C78.377A 2R 1A 1U 0D 0A 2D 1C 1B 0B 3A 2B 1S 1R 0U 0.30 0R 0.29 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.28 CCx © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 31 XLAMP ® XP-G3 LED STANDARD WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.46 0.45 2700 K 3000 K 0.44 0.43 0.42 4000 K 0.41 E6 4500 K E5 0.40 CCy E7 3500 K 5000 K 0.39 0.38 E3 0.37 0.36 5B4 4C 4B 3C 4D 3B 6B2 5C3 5C2 5B1 5D2 5A3 5D4 6A1 5A2 5D1 5A4 5A1 6D2 6A3 5D3 6A2 6A4 6D1 7A4 7A1 6D4 7D1 8B2 8B3 8C1 8B4 8C2 8C3 8C4 8D3 8D2 8D4 8A4 8D1 8A1 7D4 8A3 8A2 7D3 7D2 7A3 7A2 6D3 8B1 7C4 7C1 7B4 7B1 6C4 6C1 6B4 5C4 6B1 5C1 5B2 6C2 6B3 5B3 E4 6C3 7C2 7B3 7B2 7C3 E8 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx 0.46 0.45 2700 K 3000 K 0.44 0.43 3500 K 0.42 4000 K 0.41 4500 K CCy 0.40 F5 5000 K 0.39 F4 0.38 0.37 4B 4D 3B 5C4 5C1 5B4 3C 0.36 5B3 5B1 5D2 5A3 5D4 6A1 5A2 5D1 5A4 5A1 6C2 6B3 6B4 6B1 5D3 6A2 6A3 6A4 7B2 6C3 6B2 5C3 5C2 5B2 4C F6 F7 6C1 6D2 6D1 7B1 6C4 6D3 6D4 7A2 7A1 7A4 F8 7A3 7D1 7C2 7B3 7B4 7C1 7D4 8B1 7C4 7D3 7D2 7C3 8A1 8A2 8A3 8B2 8B3 8B4 8D2 8C1 8C2 8C3 8C4 8D3 8D4 8A4 8D1 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 32 XLAMP ® XP-G3 LED STANDARD WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS CONTINUED 0.45 0.44 3000 K 0.43 0.42 CCy 8B1 7C4 0.41 0.40 7C3 7C2 7D3 8A1 8A3 8A2 8A4 8D1 8B3 8B2 8B4 8D2 8C1 8C2 EA 2450 K 2700 K 2200 K AB2 AB3 AC2 AB4 AC1 AC4 8C3 AB1 AC3 8C4 AA2 AA3 AD2 AD3 8D3 AA1 AA4 AD1 8D4 AD4 0.39 0.38 0.37 0.55 0.54 0.53 0.52 0.51 0.50 0.49 0.48 0.47 0.46 0.45 0.44 0.36 CCx © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 33 XLAMP ® XP-G3 LED EASYWHITE® WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.44 0.44 3000 K 3000 K 0.43 0.43 0.42 0.42 2200 K 2200 K 1800 K 1800 K 3500 K 3500 K 0.41 0.41 0.40 0.40 4500 K 4500 K 0.39 0.39 CCy CCy 2700 K 2700 K 4000 K 4000 K 5000 K 5000 K 0.38 0.38 0.37 5700 K 0.37 5700 K 0.36 0.36 0.35 0.56 0.55 0.56 0.54 0.55 0.53 0.54 0.52 0.53 0.51 0.52 0.47 0.48 0.46 0.47 0.45 0.46 0.44 0.45 0.43 0.44 0.42 0.43 0.41 0.42 0.40 0.41 0.39 0.40 0.38 0.39 0.37 0.38 0.36 0.37 0.35 0.36 0.34 0.35 0.33 0.34 0.32 0.32 0.33 0.32 0.50 0.51 0.33 0.32 0.49 0.50 0.34 0.33 0.48 0.49 ANSI C78.377 Quadrangle ANSI C78.377 Quadrangle EasyWhite 5-Step EasyWhite 5-Step EasyWhite 3-Step EasyWhite 3-Step 0.35 0.34 CCx CCx © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 34 XLAMP ® XP-G3 LED STANDARD CHROMATICITY KITS The following table provides the chromaticity bins associated with chromaticity kits. Color Cool White Neutral White Warm White CCT Kit Chromaticity Bins 7000 K DT 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U 6500 K CB 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U >6500 K E0 0A, 0B, 0C, 0D 6500 K E1 1A, 1B, 1C, 1D 6000 K DV 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U 6200 K 50 1A, 1B, 1C, 1D, 2A, 2B, 2C, 2D 5700 K E2 2A, 2B, 2C, 2D 5700 K 2E 57E 5000 K 3E 50E 5000 K E3 3A, 3B, 3C, 3D 4750 K F4 3C, 3D, 4A, 4B 4500 K 4E 45E 4500 K E4 4A, 4B, 4C, 4D 4250 K F5 4C, 4D, 5A1, 5A2, 5A3, 5A4, 5B1, 5B2, 5B3, 5B4 4000 K 5E 40E 4000 K E5 5A1, 5A2, 5A3, 5A4, 5B1, 5B2, 5B3, 5B4, 5C1, 5C2, 5C3, 5C4, 5D1, 5D2, 5D3, 5D4 3750 K F6 5C1, 5C2, 5C3, 5C4, 5D1, 5D2, 5D3, 5D4, 6A1, 6A2, 6A3, 6A4, 6B1, 6B2, 6B3, 6B4 3500 K 6E 35E, 35G 3500 K 6G 35G 3500 K E6 6A1, 6A2, 6A3, 6A4, 6B1, 6B2, 6B3, 6B4, 6C1, 6C2, 6C3, 6C4, 6D1, 6D2, 6D3, 6D4 3250 K F7 6C1, 6C2, 6C3, 6C4, 6D1, 6D2, 6D3, 6D4, 7A1, 7A2, 7A3, 7A4, 7B1, 7B2, 7B3, 7B4 3000 K 7E 30E, 30G 3000 K 7G 30G 3000 K E7 7A1, 7A2, 7A3, 7A4, 7B1, 7B2, 7B3, 7B4, 7C1, 7C2, 7C3, 7C4, 7D1, 7D2, 7D3, 7D4 2850 K F8 7C1, 7C2, 7C3, 7C4, 7D1, 7D2, 7D3, 7D4, 8A1, 8A2, 8A3, 8A4, 8B1, 8B2, 8B3, 8B4 2700 K 8E 27E, 27G 2700 K 8G 27G 2700 K E8 8A1, 8A2, 8A3, 8A4, 8B1, 8B2, 8B3, 8B4, 8C1, 8C2, 8C3, 8C4, 8D1, 8D2, 8D3, 8D4 2200 K EA AA1, AA2, AA3, AA4, AB1, AB2, AB3, AB4, AC1, AC2, AC3, AC4, AD1, AD2, AD3, AD4 1800 K BE 18E © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 35 XLAMP ® XP-G3 LED BIN AND ORDER CODE FORMATS XP-G3 bin codes and order codes are configured in the following manner: Order Code Bin Code Series XPGD = XP-G3 Series XPGD = XP-G3 CRI specification 0 = No CRI minimum B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum CRI specification 0 = No CRI minimum B = 70 CRI minimum H = 80 CRI minimum U = 90 CRI minimum Minimum luminous or radiant flux group Chromaticity or peak wavelength bin SSSSCC-BD-HHHH-NNFWW Chromaticity or peak wavelength group Luminous or radiant flux group SSSSCC-BD-WWW-FF-G-AA Internal code Internal code Version 1 = Standard S = S Line Version 1 = Standard S = S Line Color WT = White RY = Royal blue PR = Photo red Color WT = White RY = Royal blue PR = Photo red © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 36 XLAMP ® XP-G3 LED REFLOW SOLDERING CHARACTERISTICS In testing, Cree LED has found XLamp XP-G3 LEDs to be compatible with JEDEC J-STD-020C, with the exception of the peak temperature requirements listed in the table below. As a general guideline, Cree LED recommends that users follow the recommended soldering profile provided by the manufacturer of the solder paste used, and therefore it is the lamp or luminaire manufacturer’s responsibility to determine applicable soldering requirements. Note that this general guideline may not apply to all PCB designs and configurations of reflow soldering equipment. tP TP Critical Zone TL to TP Temperature Ramp-up TL tL Tsmax Tsmin Ramp-down ts Preheat 25 t 25˚C to Peak Time Profile Feature Average Ramp-Up Rate (Tsmax to Tp) Lead-Free Solder 1.2 °C/second Preheat: Temperature Min (Tsmin) 120 °C Preheat: Temperature Max (Tsmax) 170 °C Preheat: Time (tsmin to tsmax) 65-150 seconds Time Maintained Above: Temperature (TL) Time Maintained Above: Time (tL) Peak/Classification Temperature (Tp) 217 °C 45-90 seconds 235 - 245 °C Time Within 5 °C of Actual Peak Temperature (tp) 20-40 seconds Ramp-Down Rate 1 - 6 °C/second Time 25 °C to Peak Temperature 4 minutes max. Note: All temperatures refer to topside of the package, measured on the package body surface. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 37 XLAMP ® XP-G3 LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Cree LED did not perform Room Temperature Operating Life (RTOL) testing on the XP-G3 LED. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. Moisture Sensitivity Cree LED recommends keeping XLamp LEDs in the provided, resealable moisture-barrier packaging (MBP) until immediately prior to soldering. Unopened MBPs that contain XLamp LEDs do not need special storage for moisture sensitivity. Once the MBP is opened, XLamp XP-G3 LEDs may be stored as MSL 1 per JEDEC J-STD-033, meaning they have unlimited floor life in conditions of ≤ 30 ºC/85% relative humidity (RH). Regardless of the storage condition, Cree LED recommends sealing any unsoldered LEDs in the original MBP. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree LED representative or from the Product Ecology section of the Cree LED website. REACH Compliance REACH substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree LED representative to insure you get the most up-to-date REACH Declaration. REACH banned substance information (REACH Article 67) is also available upon request. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 38 XLAMP ® XP-G3 LED NOTES - CONTINUED UL® Recognized Component This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 39 XLAMP ® XP-G3 LED MECHANICAL DIMENSIONS (TA = 25 °C) Thermal vias, if present, are 8not shown on these drawings. 7 6 OPTICAL MODEL ORIGIN F 4 5 All measurements are ±.13 mm unless otherwise indicated. SOLDERMASK OPTICAL MAY BE PRESENT MODEL ORIGIN 2.26 CATHODE SIDE 2.30 0.73 ANODE SIDE 3.30 0.50 3.45 ANODE SIDE E R1.53 3.45 TOPView VIEW Top SIDE VIEW Side View 4 5 OPTICAL MODEL ORIGIN SOLDERMASK MAY BE PRESENT 3.30 2.26 3.30 0.50 0.73 ANODE SIDE BOTTOM V 3.30 0.18 D 1 2 3 0.50 0.56 0.50 2.30 0.50 0.50 ANODE SIDE 0.56 0.43 6 1.30 0.58 CATHODE SIDE 0.18 TYP 3.30 0.29 TYP 3.30 3.30 3.45 C R1.53 1.30 B SIDE VIEW 0.50 CENTER PAD IS ELECTRICALLY ISOLATED 0.08 0.58 Bottom View BOTTOM 0.50 VIEW 1.30 0.18 3.30 RECOMMENDED PCB FOOTPRINT 0.56 0.50 0.56 0.08 A 0.43 0.18 RECOMMENDED STENCIL O 7 6 PLACES) 8 YP © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 5 40 PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF CREE LED. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT WRITTEN PERMISSION OF CREE LED IS PROHIBITED. © 2021 CreeLED, Inc. a subsidiary of SMART Global Holdings, Inc. 4 2.26 OPTICAL MODEL ORIGIN F CATHODE SIDE 3.30 2.30 0.73 ANODE SIDE 0.50 0.50 ANODE SIDE CATHODE SIDE 3.45 3.30 XLAMP ® XP-G3 LED E R1.53 MECHANICAL DIMENSIONS (T 3.45A = 25 °C) - CONTINUED TOP VIEW 1.30 0.58 SIDE VIEW CENTER PAD IS ELECTRICALLY ISOLATED BOTTOM VIEW mm unless otherwise indicated. All measurements are ±.13 D 3.30 0.56 0.50 0.50 0.56 0.83 (2 PLACES) 0.08 0.43 0.50 0.18 3.30 0.08 0.18 0.18 TYP 0.29 TYP 3.30 3.30 C B 0.50 1.30 0.50 RECOMMENDED PCB FOOTPRINT Recommended PCB Footprint 0.18 0.50 RECOMMENDED STENCIL OPENING Recommended Stencil Openings* UNLESS OTHERWISE SPECIFIED: Notes: • • * DIMENSIONS ARE IN MILLIMETERS TOLERANCES: • ANGULAR: MACH 0.5° BEND 1° • ONE PLACE DECIMAL 0.5 • TWO PLACE DECIMAL 0.05 • INSIDE BEND RADII EQUAL MATERIAL • MACHINE/CASTING RADII 0.50 • RADII AND DIA: 0.10 A DRAWN NAME DATE TLING 24AUG22 CHECKED Cre 440 DU TITLE: ENG APPR. MFG APPR. XPG3 Cree LED recommends using thermal pad kickouts to maximize component thermal performance. SIZE DWG. NO. Cree LED recommends using white solder mask material to minimize system optical loss. 350001 C SCALE 20:1 WEIGHT: ® This stencil has been tested and optimized for the avoidance of voiding when using ALPHA® LUMET P30 Maxrel solder paste. For other solder 5 4 7 8 6 1 3 2 1 2 pastes, a “window pane” design for the thermal pad stencil may result in a lower voiding percentage. Contact your local Cree LED Field Applications Engineer for consultation regarding your specific application. PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF CREE LED. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT WRITTEN PERMISSION OF CREE LED IS PROHIBITED. © 2021 CreeLED, Inc. a subsidiary of SMART Global Holdings, Inc. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. B UDPATED OPTICAL MODEL ORIGIN A INITIAL DRAWING RELEASED REV DESCRIPTION INTERPRET GEOMETRIC TOLERANCING PER: MATERIAL Q.A. THIRD ANGLE PROJECTION MATERIAL FINISH FINISH APPLICATION CLD-DS139 REV 14 41 XLAMP ® XP-G3 LED TAPE AND REEL All Cree LED carrier tapes conform to EIA-481D, Automated Component Handling Systems Standard. All dimensions in mm. All measurements are ±.15 mm unless otherwise indicated. Po T E Do Bo R P2 W A Anode side F A P1 B D1 "H" Ko B-B SECTION Bo (on a place in the bottom of the corner radii) Ao (on a place in the bottom of the corner radii) R "I" Ao Item Dim. Ao Bo Ko 3.70 3.70 2.40 ITEM Dim. Ao 3.70 DETAIL"H" DETAIL"I" A-A SECTION Bo 3.70 Po 4.00 P1 P2 T 8.00 2.00 0.30 Ko 2.40 Po 4.00 P1 8.00 ITEM F Do D1 W R Dim. 5.50 1.55 1.50 12.00 5deg E 1.75 P2 F Do D1 5.50 1.55 1.50 2.00 T 0.30 E 1.75 W R 12.00 5° NOTICE 1) All Cree LED carrier tapes conform to EIA-481D, Automated Component handling Systems Standard 2) Measurement tolerances unless indicated otherwise: .xx = ±.15 mm © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. 2402-M032 XPGD CLD-DS139 REV 14 42 XLAMP ® XP-G3 LED TAPE AND REEL - CONTINUED Feed Direction END START Trailer Loaded Pockets Leader Min. 160 mm empty pockets sealed with tape 1000 Lamps Min. 400 mm empty pockets with min. 100 mm sealed Feed Direction Cover Tape Pocket Tape 13 mm 7.5” © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 43 XLAMP ® XP-G3 LED PACKAGING © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 44 XLAMP ® XP-G3 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS The following order codes are active and valid order codes, but higher performance options are also available. Please see page 4 page 9 for order codes of XLamp XP-G3 White (Standard) LEDs that could serve as alternatives for the order codes set forth below. Chromaticity Kit CCT DT 7000 K CB 6500 K E0 >6500 K E1 6500 K DV 6000 K 50 6000 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @25 °C* S2 148 161 R5 139 152 XPGDWT-H1-0000-00HDT S2 148 161 XPGDWT-H1-0000-00JCB R5 139 152 XPGDWT-H1-0000-00HCB S3 156 170 XPGDWT-01-0000-00KE0 S2 148 161 XPGDWT-01-0000-00JE0 R5 139 152 S3 156 170 XPGDWT-01-0000-00KE1 S2 148 161 XPGDWT-01-0000-00JE1 R5 139 152 S3 156 170 XPGDWT-01-0000-00KDV S2 148 161 XPGDWT-01-0000-00JDV R5 139 152 R4 130 142 R3 122 133 XPGDWT-U1-0000-00FDV R2 114 124 XPGDWT-U1-0000-00EDV S3 156 170 XPGDWT-01-0000-00K50 S2 148 161 XPGDWT-01-0000-00J50 R5 139 152 R4 130 142 R3 122 133 XPGDWT-U1-0000-00F50 R2 114 124 XPGDWT-U1-0000-00E50 70 CRI Typical 70 CRI Minimum 80 CRI Minimum XPGDWT-B1-0000-00JDT XPGDWT-H1-0000-00JDT XPGDWT-B1-0000-00JE0 90 CRI Minimum XPGDWT-H1-0000-00JE0 XPGDWT-H1-0000-00HE0 XPGDWT-B1-0000-00JE1 XPGDWT-H1-0000-00JE1 XPGDWT-H1-0000-00HE1 XPGDWT-B1-0000-00JDV XPGDWT-H1-0000-00JDV XPGDWT-H1-0000-00HDV XPGDWT-B1-0000-00J50 XPGDWT-H1-0000-00J50 XPGDWT-H1-0000-00H50 Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 38). XLamp XP-G3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 45 XLAMP ® XP-G3 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED Chromaticity Kit CCT E2 5700 K 2E 5700 K 3E 5000 K E3 5000 K F4 4750K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @25 °C* 70 CRI Typical S3 156 170 XPGDWT-01-0000-00KE2 S2 148 161 XPGDWT-01-0000-00JE2 R5 139 152 R4 130 142 R3 122 133 XPGDWT-U1-0000-00FE2 R2 114 124 XPGDWT-U1-0000-00EE2 S2 148 161 R5 139 152 R4 130 142 R3 122 133 XPGDWT-U1-0000-00F2E R2 114 124 XPGDWT-U1-0000-00E2E 70 CRI Minimum 80 CRI Minimum XPGDWT-B1-0000-00JE2 XPGDWT-H1-0000-00JE2 90 CRI Minimum XPGDWT-H1-0000-00HE2 XPGDWT-B1-0000-00J2E XPGDWT-H1-0000-00J2E XPGDWT-H1-0000-00H2E S2 148 161 R5 139 152 XPGDWT-B1-0000-00J3E XPGDWT-H1-0000-00J3E R4 130 142 R3 122 133 XPGDWT-U1-0000-00F3E R2 114 124 XPGDWT-U1-0000-00E3E S3 156 170 XPGDWT-01-0000-00KE3 XPGDWT-B1-0000-00KE3 S2 148 161 XPGDWT-01-0000-00JE3 XPGDWT-B1-0000-00JE3 R5 139 152 R4 130 142 R3 122 133 XPGDWT-U1-0000-00FE3 R2 114 124 XPGDWT-U1-0000-00EE3 S3 156 170 XPGDWT-01-0000-00KF4 XPGDWT-B1-0000-00KF4 S2 148 161 XPGDWT-01-0000-00JF4 XPGDWT-B1-0000-00JF4 R5 139 152 R4 130 142 R3 122 133 XPGDWT-U1-0000-00FF4 R2 114 124 XPGDWT-U1-0000-00EF4 XPGDWT-H1-0000-00H3E XPGDWT-H1-0000-00JE3 XPGDWT-H1-0000-00HE3 XPGDWT-B1-0000-00HF4 XPGDWT-H1-0000-00HF4 XPGDWT-H1-0000-00GF4 Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 38). XLamp XP-G3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 46 XLAMP ® XP-G3 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED Chromaticity Kit CCT 4E 4500 K E4 4500 K F5 4200 K 5E 4000 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @25 °C* S3 156 170 XPGDWT-B1-0000-00K4E S2 148 161 XPGDWT-B1-0000-00J4E R5 139 152 XPGDWT-H1-0000-00H4E R4 130 142 XPGDWT-H1-0000-00G4E R3 122 133 XPGDWT-U1-0000-00F4E R2 114 124 XPGDWT-U1-0000-00E4E Q5 107 117 XPGDWT-U1-0000-00D4E S3 156 170 XPGDWT-01-0000-00KE4 XPGDWT-B1-0000-00KE4 S2 148 161 XPGDWT-01-0000-00JE4 XPGDWT-B1-0000-00JE4 R5 139 152 R4 130 142 R3 122 133 XPGDWT-U1-0000-00FE4 R2 114 124 XPGDWT-U1-0000-00EE4 Q5 107 117 XPGDWT-U1-0000-00DE4 S3 156 170 XPGDWT-01-0000-00KF5 S2 148 161 XPGDWT-01-0000-00JF5 R5 139 152 R4 130 142 R3 122 133 XPGDWT-U1-0000-00FF5 R2 114 124 XPGDWT-U1-0000-00EF5 Q5 107 117 XPGDWT-U1-0000-00DF5 S2 148 161 R5 139 152 XPGDWT-H1-0000-00H5E R4 130 142 XPGDWT-H1-0000-00G5E R3 122 133 XPGDWT-U1-0000-00F5E R2 114 124 XPGDWT-U1-0000-00E5E Q5 107 117 XPGDWT-U1-0000-00D5E 70 CRI Typical 70 CRI Minimum XPGDWT-B1-0000-00HE4 80 CRI Minimum 90 CRI Minimum XPGDWT-H1-0000-00HE4 XPGDWT-H1-0000-00GE4 XPGDWT-B1-0000-00JF5 XPGDWT-B1-0000-00HF5 XPGDWT-H1-0000-00HF5 XPGDWT-H1-0000-00GF5 XPGDWT-B1-0000-00J5E Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 38). XLamp XP-G3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 47 XLAMP ® XP-G3 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED Chromaticity Kit CCT E5 4000 K F6 3700 K 6E 3500 K 6G 3500 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @25 °C* 70 CRI Typical S3 156 170 XPGDWT-01-0000-00KE5 S2 148 161 XPGDWT-01-0000-00JE5 R5 139 152 R4 130 142 R3 122 133 XPGDWT-U1-0000-00FE5 R2 114 124 XPGDWT-U1-0000-00EE5 Q5 107 117 XPGDWT-U1-0000-00DE5 S2 148 161 XPGDWT-01-0000-00JF6 XPGDWT-B1-0000-00JF6 R5 139 152 XPGDWT-01-0000-00HF6 XPGDWT-B1-0000-00HF6 R4 130 142 R3 122 133 70 CRI Minimum 80 CRI Minimum 90 CRI Minimum XPGDWT-B1-0000-00JE5 XPGDWT-B1-0000-00HE5 XPGDWT-H1-0000-00HE5 XPGDWT-H1-0000-00GE5 XPGDWT-H1-0000-00GF6 R2 114 124 XPGDWT-U1-0000-00EF6 Q5 107 117 XPGDWT-U1-0000-00DF6 Q4 100 109 XPGDWT-U1-0000-00CF6 S2 148 161 XPGDWT-B1-0000-00J6E R5 139 152 XPGDWT-B1-0000-00H6E R4 130 142 R3 122 133 R2 114 124 XPGDWT-U1-0000-00E6E Q5 107 117 XPGDWT-U1-0000-00D6E Q4 100 109 XPGDWT-U1-0000-00C6E R2 114 124 XPGDWT-U1-0000-00E6G Q5 107 117 XPGDWT-U1-0000-00D6G Q4 100 109 XPGDWT-U1-0000-00C6G XPGDWT-H1-0000-00G6E Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 38). XLamp XP-G3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 48 XLAMP ® XP-G3 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED Chromaticity Kit CCT E6 3500 K F7 3200 K 7E 3000 K 7G 3000 K E7 3000 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @25 °C* 70 CRI Typical 70 CRI Minimum S2 148 161 XPGDWT-01-0000-00JE6 XPGDWT-B1-0000-00JE6 R5 139 152 XPGDWT-01-0000-00HE6 XPGDWT-B1-0000-00HE6 R4 130 142 R3 122 133 R2 114 124 XPGDWT-U1-0000-00EE6 Q5 107 117 XPGDWT-U1-0000-00DE6 Q4 100 109 XPGDWT-U1-0000-00CE6 R5 139 152 R4 130 142 R3 122 133 R2 114 124 XPGDWT-U1-0000-00EF7 Q5 107 117 XPGDWT-U1-0000-00DF7 Q4 100 109 XPGDWT-U1-0000-00CF7 R5 139 152 R4 130 142 R3 122 133 R2 114 124 XPGDWT-U1-0000-00E7E Q5 107 117 XPGDWT-U1-0000-00D7E Q4 100 109 XPGDWT-U1-0000-00C7E R2 114 124 XPGDWT-U1-0000-00E7G Q5 107 117 XPGDWT-U1-0000-00D7G Q4 100 109 XPGDWT-U1-0000-00C7G R5 139 152 R4 130 142 R3 122 133 80 CRI Minimum 90 CRI Minimum XPGDWT-H1-0000-00GE6 XPGDWT-01-0000-00HF7 XPGDWT-B1-0000-00HF7 XPGDWT-H1-0000-00GF7 XPGDWT-B1-0000-00H7E XPGDWT-H1-0000-00G7E XPGDWT-01-0000-00HE7 XPGDWT-B1-0000-00HE7 XPGDWT-H1-0000-00GE7 R2 114 124 XPGDWT-U1-0000-00EE7 Q5 107 117 XPGDWT-U1-0000-00DE7 Q4 100 109 XPGDWT-U1-0000-00CE7 Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 38). XLamp XP-G3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 49 XLAMP ® XP-G3 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED Chromaticity Kit CCT F8 2850 K 8E 2700 K 8G 2700 K E8 2700 K EA 2200 K Minimum Luminous Flux (lm) @ 350 mA Order Codes Code Flux (lm) @ 85 °C Flux (lm) @25 °C* R3 122 133 R2 114 124 Q5 107 117 XPGDWT-U1-0000-00DF8 Q4 100 109 XPGDWT-U1-0000-00CF8 R3 122 133 R2 114 124 Q5 107 117 XPGDWT-U1-0000-00D8E Q4 100 109 XPGDWT-U1-0000-00C8E Q5 107 117 XPGDWT-U1-0000-00D8G Q4 100 109 XPGDWT-U1-0000-00C8G R3 122 133 R2 114 124 Q5 107 117 XPGDWT-U1-0000-00DE8 Q4 100 109 XPGDWT-U1-0000-00CE8 R3 122 133 XPGDWT-B1-0000-00FEA R2 114 124 XPGDWT-B1-0000-00EEA 70 CRI Typical 70 CRI Minimum 80 CRI Minimum 90 CRI Minimum XPGDWT-H1-0000-00FF8 XPGDWT-H1-0000-00F8E XPGDWT-H1-0000-00FE8 Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 38). XLamp XP-G3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 50 XLAMP ® XP-G3 LED APPENDIX - ORDER CODES NOT FOR NEW DESIGNS - CONTINUED The following order codes are active and valid order codes, but higher performance options are also available. Please see page 10 page 11 for order codes of XLamp XP-G3 White (S Line) LEDs that could serve as alternatives for the order codes set forth below. Chromaticity Minimum Luminous Flux (lm) @ 350 mA Order Codes Kit CCT Code Flux (lm) @ 85 °C Flux (lm) @25 °C* 70 CRI Minimum E1 6500 K S3 156 170 XPGDWT-BS-0000-00KE1 DV 6000 K S3 156 170 XPGDWT-BS-0000-00KDV 50 6000 K S3 156 170 XPGDWT-BS-0000-00K50 E2 5700 K S3 156 170 XPGDWT-BS-0000-00KE2 2E 5700 K S3 156 170 XPGDWT-BS-0000-00K2E 3E 5000 K S3 156 170 XPGDWT-BS-0000-00K3E E3 5000 K S3 156 170 XPGDWT-BS-0000-00KE3 4E 4500K S3 156 170 XPGDWT-BS-0000-00K4E E4 4500 K S3 156 170 XPGDWT-BS-0000-00KE4 5E 4000 K S3 156 170 XPGDWT-BS-0000-00K5E E5 4000 K S3 156 170 XPGDWT-BS-0000-00KE5 S3 156 170 XPGDWT-BS-0000-00K6E S2 148 161 XPGDWT-BS-0000-00J6E S3 156 170 XPGDWT-BS-0000-00KE6 S2 148 161 XPGDWT-BS-0000-00JE6 S3 156 170 XPGDWT-BS-0000-00KF7 S2 148 161 XPGDWT-BS-0000-00JF7 S3 156 170 XPGDWT-BS-0000-00K7E S2 148 161 XPGDWT-BS-0000-00J7E S3 156 170 XPGDWT-BS-0000-00KE7 S2 148 161 XPGDWT-BS-0000-00JE7 6E 3500 K E6 3500 K F7 3200K 7E 3000 K E7 3000 K Notes • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 38). XLamp XP-G3 LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code. Flux values @ 25 °C are calculated and for reference only. © 2016-2023 Cree LED. The information in this document is subject to change without notice. Cree®, XLamp®, EasyWhite®, the Cree logo, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Other trademarks, product, and company names are the property of their respective owners and do not imply specific product and/or vendor endorsement, sponsorship or association. CLD-DS139 REV 14 51
XPGDWT-H1-0000-00H7E 价格&库存
很抱歉,暂时无法提供与“XPGDWT-H1-0000-00H7E”相匹配的价格&库存,您可以联系我们找货
