XMLBEZ-02-0000-0D00V340F
    CREELED
    LED 照明 Easywhite®, Xlamp® XM-L2 白色,天然 4000K 4 阶麦克亚当椭圆 12V 350mA 115° 2020(5050 公制)
XMLBEZ-02-0000-0D00V340F 数据手册
Cree® XLamp® XM-L2 EasyWhite® LEDs CLD-DS93 Rev 0 Product family data sheet Product Description FEATURES Table of Contents The XLamp XM-L2 EasyWhite LED • Available in 4-step and 2-step Characteristics................................ 2 eliminates chromaticity binning EasyWhite bins at 2700 K, Flux Characteristics, Standard Order and enables luminaire and bulb 3000 K, 3500 K, 4000 K, 5000 K Codes and Bins, 6-V XM‑L2 EZW........ 3 manufacturers CCT, ANSI white bins at 5700 K, Flux Characteristics, Standard Order 6500 K Codes and Bins, 12-V XM‑L2 EZW...... 5 to deliver the consistent color and high efficacy light output of a multi‑die LED in • Wide range of operating Relative Spectral Power the compact XM-L footprint. XLamp current – up to 2 A @ 6 V or 1 A Distribution.................................... 8 XM-L2 EasyWhite LEDs can reduce @ 12 V Relative Flux vs. Junction LED-to-LED color variation to within • 85 °C binning and Temperature................................... 8 a 2‑step MacAdam ellipse, 94% characterization Electrical Characteristic.................... 9 smaller than the total area of the corresponding ANSI C78.377 color region. • Available in 6‑V and 12‑V versions • Low thermal resistance: 2.5 °C/W The XLamp LED is lighting the XM-L2 perfect applications EasyWhite choice where for high luminous flux output is required Relative Flux vs. Current................ 10 Relative Chromaticity vs. Current and Temperature........................... 11 Typical Spatial Distribution.............. 12 • Wide viewing angle: 115° Thermal Design............................. 12 • Wide variety of CRI choices: Performance Groups – Brightness.... 13 standard CRI as well as 80- & Performance Groups – Chromaticity. 13 90‑minimum CRI Cree EasyWhite Bins Plotted on the from a single, small point source. • Electrically neutral thermal path 1931 CIE Color Space.................... 14 Example applications include LED • Unlimited floor life at Cree’s Standard Cool White Kits retrofit bulbs, commercial/retail display spotlights, and other indoor general‑illumination applications. ≤ 30 ºC/85% RH • Reflow solderable - JEDEC J‑STD‑020C Plotted on ANSI Standard Chromaticity Regions..................... 15 Cree ANSI White Bins Plotted on the WWW.CREE.COM/XLAMP 1931 CIE Color Space.................... 15 Bin and Order Code Format............. 16 Reflow Soldering Characteristics...... 17 Notes........................................... 18 Mechanical Dimensions.................. 19 Tape and Reel............................... 20 Packaging..................................... 21 ® Copyright Inc. Copyright © © 2014 2010 Cree, Cree, Inc. All All rights rights®reserved. reserved. The The information information in in this this document document isissubject subjectto tochange changewithout withoutnotice. notice.Cree , ® the Cree EasyWhite are registered trademarks Cree, Inc. Cree, thelogo, Cree XLamp logo andand XLamp are registered trademarks of Cree, of Inc. Cree, Inc. Cree,Drive Inc. 4600 Silicon 4600 Silicon Drive Durham, NC 27703 NC 27703 USA Tel:Durham, +1.919.313.5300 USA Tel: +1.919.407.5300 www.cree.com/xlamp xlamp xm-l2 easywhite leds Characteristics Characteristics Unit Thermal resistance, junction to solder point °C/W 2.5 Viewing angle (FWHM) Minimum Typical degrees 115 Temperature coefficient of voltage (6 V) mV/°C -5 Temperature coefficient of voltage (12 V) mV/°C -10 ESD withstand voltage (HBM per Mil-Std-883D) Maximum V 8000 DC forward current (6 V) mA 2000 DC forward current (12 V) mA 1000 Reverse current (6 V, 12 V) mA 0.1 Forward voltage (@ 700 mA, 85 °C, 6 V) V 5.8 6.5 Forward voltage (@ 350 mA, 85 °C, 12 V) V 11.6 13.0 LED junction temperature °C 150 Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered of Cree, Inc. trademarks of Cree, Inc. 2 xlamp xm-l2 easywhite leds Flux Characteristics, Standard Order Codes and Bins, 6-V XM‑L2 EZW (700 mA, Tj = 85 °C) The following table provides the order codes for 6-volt XLamp XM-L2 EZW LEDs. Color CCT Range 5000 K 4000 K Standard CRI EasyWhite 3500 K 3000 K 2700 K Base Order Codes Min. Luminous Flux @ 700 mA 2-Step Order Code 4-Step Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* U6 380 443 V2 400 466 V3 420 486 XMLBEZ-00-0000-0B00V350H XMLBEZ-00-0000-0B00V350F U6 380 443 XMLBEZ-00-0000-0B00U640H XMLBEZ-00-0000-0B00U640F V2 400 466 V3 420 486 U6 380 443 V2 400 466 V3 420 486 U6 380 443 V2 400 466 U5 360 420 U6 380 443 V2 400 466 Chromaticity Region Chromaticity Region XMLBEZ-00-0000-0B00U650H 50H 40H XMLBEZ-00-0000-0B00V250H XMLBEZ-00-0000-0B00V240H XMLBEZ-00-0000-0B00U650F 50F 40F XMLBEZ-00-0000-0B00V340H XMLBEZ-00-0000-0B00V235H XMLBEZ-00-0000-0B00U635F 35F XMLBEZ-00-0000-0B00V335H 30H XMLBEZ-00-0000-0B00U630H XMLBEZ-00-0000-0B00V230H XMLBEZ-00-0000-0B00U627H XMLBEZ-00-0000-0B00V227H XMLBEZ-00-0000-0B00V235F XMLBEZ-00-0000-0B00V335F 30F XMLBEZ-00-0000-0B00U527H 27H XMLBEZ-00-0000-0B00V240F XMLBEZ-00-0000-0B00V340F XMLBEZ-00-0000-0B00U635H 35H XMLBEZ-00-0000-0B00V250F XMLBEZ-00-0000-0B00U630F XMLBEZ-00-0000-0B00V230F XMLBEZ-00-0000-0B00U527F 27F XMLBEZ-00-0000-0B00U627F XMLBEZ-00-0000-0B00V227F Notes: • For Standard CRI parts, typical CRI is 75 for 5000-4000­-K CCT parts, 80 for 4000–3500-K CCT parts and 82 for 3000–2700-K CCT parts. • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered of Cree, Inc. trademarks of Cree, Inc. 3 xlamp xm-l2 easywhite leds Flux Characteristics, Standard Order Codes and Bins, 6-V XM‑L2 EZW (700 mA, Tj = 85 °C) - Continued Color CCT Range Base Order Codes Min. Luminous Flux @ 700 mA 4000 K 80-CRI Minimum EasyWhite 3500 K 3000 K 2700 K 3000 K 90-CRI Minimum EasyWhite 2700 K 4-Step Order Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* U6 380 443 V2 400 466 V3 420 486 XMLBEZ-00-0000-0B0HV350H XMLBEZ-00-0000-0B0HV350F U6 380 443 XMLBEZ-00-0000-0B0HU640H XMLBEZ-00-0000-0B0HU640F V2 400 466 V3 420 486 XMLBEZ-00-0000-0B0HV340H XMLBEZ-00-0000-0B0HV340F U6 380 443 XMLBEZ-00-0000-0B0HU635H XMLBEZ-00-0000-0B0HU635F V2 400 466 V3 420 486 XMLBEZ-00-0000-0B0HV335H XMLBEZ-00-0000-0B0HV335F U5 360 420 XMLBEZ-00-0000-0B0HU530H XMLBEZ-00-0000-0B0HU530F U6 380 443 V2 400 466 XMLBEZ-00-0000-0B0HV230H XMLBEZ-00-0000-0B0HV230F U4 340 396 XMLBEZ-00-0000-0B0HU427H XMLBEZ-00-0000-0B0HU427F U5 360 420 U6 380 443 XMLBEZ-00-0000-0B0HU627H XMLBEZ-00-0000-0B0HU627F U2 300 350 XMLBEZ-00-0000-0B0UU230H XMLBEZ-00-0000-0B0UU230F Group 5000 K 2-Step Order Code Chromaticity Region Chromaticity Region XMLBEZ-00-0000-0B0HU650H 50H 40H 35H 30H 27H 30H XMLBEZ-00-0000-0B0HV250H XMLBEZ-00-0000-0B0HV240H XMLBEZ-00-0000-0B0HV235H XMLBEZ-00-0000-0B0HU630H XMLBEZ-00-0000-0B0HU527H 40F 35F 30F 27F XMLBEZ-00-0000-0B0HV240F XMLBEZ-00-0000-0B0HV235F XMLBEZ-00-0000-0B0HU630F XMLBEZ-00-0000-0B0HU527F U3 320 373 340 396 XMLBEZ-00-0000-0B0UU430H XMLBEZ-00-0000-0B0UU430F T6 280 326 XMLBEZ-00-0000-0B0UT627H XMLBEZ-00-0000-0B0UT627F U2 300 350 U3 320 373 XMLBEZ-00-0000-0B0UU227H XMLBEZ-00-0000-0B0UU327H 30F XMLBEZ-00-0000-0B0HV250F U4 27H XMLBEZ-00-0000-0B0UU330H XMLBEZ-00-0000-0B0HU650F 50F 27F XMLBEZ-00-0000-0B0UU330F XMLBEZ-00-0000-0B0UU227F XMLBEZ-00-0000-0B0UU327F Notes: • For Standard CRI parts, typical CRI is 75 for 5000-4000­-K CCT parts, 80 for 4000–3500-K CCT parts and 82 for 3000–2700-K CCT parts. • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered of Cree, Inc. trademarks of Cree, Inc. 4 xlamp xm-l2 easywhite leds Flux Characteristics, Standard Order Codes and Bins, 6-V XM‑L2 EZW (700 mA, Tj = 85 °C) - Continued Color Base Order Codes Min Luminous Flux @ 700 mA CCT Range 6500 K Standard CRI ANSI White 5700 K Chromaticity Regions Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* U6 380 443 V2 400 466 V3 420 486 XMLBEZ-00-0000-0B00V30E1 U6 380 443 XMLBEZ-00-0000-0B00U60E2 V2 400 466 V3 420 486 XMLBEZ-00-0000-0B00U60E1 0E1 XMLBEZ-00-0000-0B00V20E1 0E2 XMLBEZ-00-0000-0B00V20E2 XMLBEZ-00-0000-0B00V30E2 Flux Characteristics, Standard Order Codes and Bins, 12-V XM‑L2 EZW (350 ma, TJ = 85 °C) The following table provides the order codes for 12-volt XLamp XM-L2 EZW LEDs. Color CCT Range 5000 K 4000 K Standard CRI EasyWhite 3500 K 3000 K 2700 K Base Order Codes Min. Luminous Flux @ 350 mA 2-Step Order Code 4-Step Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* U6 380 443 V2 400 466 V3 420 486 XMLBEZ-00-0000-0D00V350H XMLBEZ-00-0000-0D00V350F U6 380 443 XMLBEZ-00-0000-0D00U640H XMLBEZ-00-0000-0D00U640F V2 400 466 V3 420 486 XMLBEZ-00-0000-0D00V340H XMLBEZ-00-0000-0D00V340F U6 380 443 XMLBEZ-00-0000-0D00U635H XMLBEZ-00-0000-0D00U635F V2 400 466 V3 420 486 U6 380 443 V2 400 466 U5 360 420 U6 380 443 V2 400 466 Chromaticity Region Chromaticity Region XMLBEZ-00-0000-0D00U650H 50H 40H 35H XMLBEZ-00-0000-0D00V250H XMLBEZ-00-0000-0D00V240H XMLBEZ-00-0000-0D00V235H XMLBEZ-00-0000-0D00U650F 50F 40F 35F XMLBEZ-00-0000-0D00V335H 30H XMLBEZ-00-0000-0D00U630H XMLBEZ-00-0000-0D00V230H XMLBEZ-00-0000-0D00U627H XMLBEZ-00-0000-0D00V227H XMLBEZ-00-0000-0D00V240F XMLBEZ-00-0000-0D00V235F XMLBEZ-00-0000-0D00V335F 30F XMLBEZ-00-0000-0D00U527H 27H XMLBEZ-00-0000-0D00V250F XMLBEZ-00-0000-0D00U630F XMLBEZ-00-0000-0D00V230F XMLBEZ-00-0000-0D00U527F 27F XMLBEZ-00-0000-0D00U627F XMLBEZ-00-0000-0D00V227F Notes: • For Standard CRI parts, typical CRI is 75 for 5000-4000­-K CCT parts, 80 for 4000–3500-K CCT parts and 82 for 3000–2700-K CCT parts. • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered of Cree, Inc. trademarks of Cree, Inc. 5 xlamp xm-l2 easywhite leds Flux Characteristics, Standard Order Codes and Bins, 12-V XM‑L2 EZW (350 ma, TJ = 85 °C) - cONTINUED Color CCT Range Base Order Codes Min. Luminous Flux @ 350 mA 4000 K 80-CRI Minimum EasyWhite 3500 K 3000 K 2700 K 3000 K 90-CRI Minimum EasyWhite 2700 K 4-Step Order Code Flux (lm) @ 85 °C Flux (lm) @ 25 °C* U6 380 443 V2 400 466 V3 420 486 XMLBEZ-00-0000-0D0HV350H XMLBEZ-00-0000-0D0HV350F U6 380 443 XMLBEZ-00-0000-0D0HU640H XMLBEZ-00-0000-0D0HU640F V2 400 466 V3 420 486 XMLBEZ-00-0000-0D0HV340H XMLBEZ-00-0000-0D0HV340F U6 380 443 XMLBEZ-00-0000-0D0HU635H XMLBEZ-00-0000-0D0HU635F V2 400 466 V3 420 486 XMLBEZ-00-0000-0D0HV335H XMLBEZ-00-0000-0D0HV335F U5 360 420 XMLBEZ-00-0000-0D0HU530H XMLBEZ-00-0000-0D0HU530F U6 380 443 V2 400 466 XMLBEZ-00-0000-0D0HV230H XMLBEZ-00-0000-0D0HV230F U4 340 396 XMLBEZ-00-0000-0D0HU427H XMLBEZ-00-0000-0D0HU427F U5 360 420 U6 380 443 XMLBEZ-00-0000-0D0HU627H XMLBEZ-00-0000-0D0HU627F U2 300 350 XMLBEZ-00-0000-0D0UU230H XMLBEZ-00-0000-0D0UU230F Group 5000 K 2-Step Order Code Chromaticity Region Chromaticity Region XMLBEZ-00-0000-0D0HU650H 50H 40H 35H 30H 27H 30H XMLBEZ-00-0000-0D0HV250H XMLBEZ-00-0000-0D0HV240H XMLBEZ-00-0000-0D0HV235H XMLBEZ-00-0000-0D0HU630H XMLBEZ-00-0000-0D0HU527H 40F 35F 30F 27F XMLBEZ-00-0000-0D0HV240F XMLBEZ-00-0000-0D0HV235F XMLBEZ-00-0000-0D0HU630F XMLBEZ-00-0000-0D0HU527F U3 320 373 340 396 XMLBEZ-00-0000-0D0UU430H XMLBEZ-00-0000-0D0UU430F T6 280 326 XMLBEZ-00-0000-0D0UT627H XMLBEZ-00-0000-0D0UT627F U2 300 350 U3 320 373 XMLBEZ-00-0000-0D0UU227H XMLBEZ-00-0000-0D0UU327H 30F XMLBEZ-00-0000-0D0HV250F U4 27H XMLBEZ-00-0000-0D0UU330H XMLBEZ-00-0000-0D0HU650F 50F 27F XMLBEZ-00-0000-0D0UU330F XMLBEZ-00-0000-0D0UU227F XMLBEZ-00-0000-0D0UU327F Notes: • For Standard CRI parts, typical CRI is 75 for 5000-4000­-K CCT parts, 80 for 4000–3500-K CCT parts and 82 for 3000–2700-K CCT parts. • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered of Cree, Inc. trademarks of Cree, Inc. 6 xlamp xm-l2 easywhite leds Flux Characteristics, Standard Order Codes and Bins, 12-V XM‑L2 EZW (350 ma, TJ = 85 °C) - cONTINUED Color Base Order Codes Min Luminous Flux @ 700 mA CCT Range 6500 K Standard CRI ANSI White 5700 K Chromaticity Regions Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* U6 380 443 V2 400 466 V3 420 486 XMLBEZ-00-0000-0D00V30E1 U6 380 443 XMLBEZ-00-0000-0D00U60E2 V2 400 466 V3 420 486 XMLBEZ-00-0000-0D00U60E1 0E1 0E2 XMLBEZ-00-0000-0D00V20E1 XMLBEZ-00-0000-0D00V20E2 XMLBEZ-00-0000-0D00V30E2 Notes: • For Standard CRI parts, typical CRI is 75 for 5000-4000­-K CCT parts, 80 for 4000–3500-K CCT parts and 82 for 3000–2700-K CCT parts. • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered of Cree, Inc. trademarks of Cree, Inc. 7 xlamp xm-l2 easywhite leds Relative Spectral Power Relative Spectral Power Distribution Relative Radiant Power 100% 80% 60% Cool White Warm White 40% 20% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Relative Flux Output vs. Junction Temperature Relative Flux vs. Junction Temperature (6-V - IF = 700 mA; 12-V - IF = 350 mA) Relative Luminous Flux 120% 100% 80% 60% 40% 20% 0% 25 50 75 100 125 150 Junction Temperature (ºC) Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered of Cree, Inc. trademarks of Cree, Inc. 8 xlamp xm-l2 easywhite leds Electrical Characteristics Electrical Characteristics (TJ = 85 °C) 2000 Forward Current (mA) 1750 1500 1250 XM-L2 EZW, 6V 1000 750 500 250 0 5.4 5.5 5.6 5.7 Electrical Characteristics 5.8 5.9 6.0 6.1 6.2 6.3 Forward Voltage (V) Forward Current (mA) 1000 750 XM-L2 EZW, 12V 500 250 0 10.8 11.0 11.2 11.4 11.6 11.8 12.0 12.2 12.4 12.6 Forward Voltage (V) Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered of Cree, Inc. trademarks of Cree, Inc. 9 xlamp xm-l2 easywhite leds Flux vs. Current Relative Flux vs. Current (TJ = 85°C) 225% Relative Luminous Flux 200% 175% 150% 125% XM-L2 EZW, 6V 100% 75% 50% 25% 0% 0 250 500 750 1000 1250 1500 1750 2000 Forward Current (mA) Flux vs. Current 225% Relative Luminous Flux 200% 175% 150% 125% XM-L2 EZW, 12V 100% 75% 50% 25% 0% 0 200 400 600 800 1000 Forward Current (mA) Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered of Cree, Inc. trademarks of Cree, Inc. 10 xlamp xm-l2 easywhite leds XM-L2 EZW 6V Relative Chromaticity vs. Current and Temperature XM-L2 EZW, 6 V 0.005 0.004 0.003 0.002 0.001 0.000 -0.001 -0.002 -0.003 -0.004 -0.005 -0.006 -0.007 ΔCCx ΔCCy 0 500 1000 1500 2000 Current (mA) XM-L2 EZW 12V XM-L2 EZW, 12 V 0.005 0.004 0.003 0.002 0.001 0.000 -0.001 ΔCCx -0.002 ΔCCy -0.003 -0.004 -0.005 -0.006 -0.007 0 200 400 600 800 1000 Current (mA) XM-L2 EZW, 6V, 12V XM-L2 EZW, 6 V & 12 V 0.005 0.004 0.003 0.002 0.001 0.000 -0.001 -0.002 -0.003 -0.004 -0.005 -0.006 -0.007 ΔCCx ΔCCy 25 50 75 100 125 150 Tsp (°C) Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered of Cree, Inc. trademarks of Cree, Inc. 11 xlamp xm-l2 easywhite leds Typical Spatial Radiation Pattern Typical Spatial Distribution Relative Luminous Intensity 100% 80% 60% 40% 20% -100 -80 -60 -40 -20 0% 0 20 40 60 80 100 Angle (º) Thermal Design The maximum forward current is determined by the thermal resistance between the LED junction and ambient. It is crucial for the end product to be designed in a manner that minimizes the thermal resistance from the solder point to Thermal Design (12V) from XML DS Thermal Design (6V) from XML DSand optical characteristics. ambient in order to optimize lamp life XM-L2 EZW, 6-V 1200 1000 2000 Maximum Current (mA) Maximum Current (mA) 2500 1500 1000 Rj-a = 4°C/W Rj-a = 7°C/W 500 Rj-a = 10°C/W 0 XM-L2 EZW, 12-V Rj-a = 15°C/W 0 20 40 800 600 400 0 60 80 100 Ambient Temperature (ºC) 120 140 Rj-a = 4°C/W Rj-a = 7°C/W 200 Rj-a = 10°C/W Rj-a = 15°C/W 0 20 40 60 80 100 120 140 Ambient Temperature (ºC) Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered of Cree, Inc. trademarks of Cree, Inc. 12 xlamp xm-l2 easywhite leds Performance Groups – Brightness (TJ = 85 °C) XLamp XM-L2 EasyWhite LEDs are tested for luminous flux and placed into one of the following bins. Group Code Min. Luminous Flux @ 700 mA, 6 V, @ 350 mA , 12 V Max. Luminous Flux @ 700 mA, 6 V, @ 350 mA, 12 V T5 260 280 T6 280 300 U2 300 320 U3 320 340 U4 340 360 U5 360 380 U6 380 400 V2 400 420 V3 420 440 V4 440 460 Performance Groups – Chromaticity (TJ = 85 °C) XLamp XM-L2 EasyWhite LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 4-Step EasyWhite Color Temperatures – 2-Step Code Code 50F 40F 35F 30F 27F CCT 5000 K 4000 K 3500 K 3000 K 2700 K x y CCT x y 0.3407 0.3459 0.3429 0.3507 0.3415 0.3586 0.3434 0.3571 0.3499 0.3654 0.3475 0.3604 0.3484 0.3521 0.3469 0.3539 0.3744 0.3685 0.3784 0.3741 0.3782 0.3837 0.3804 0.3818 0.3912 0.3917 0.3867 0.3857 0.3863 0.3758 0.3844 0.3778 50H 40H 5000 K 4000 K 0.3981 0.3800 0.4030 0.3857 0.4040 0.3966 0.4061 0.3941 0.4186 0.4037 0.4132 0.3976 0.4116 0.3865 0.4099 0.3890 0.4242 0.3919 0.4291 0.3973 0.4322 0.4096 0.4333 0.4062 0.4449 0.4141 0.4395 0.4084 0.4359 0.3960 0.4351 0.3994 35H 30H 3500 K 3000 K 0.4475 0.3994 0.4528 0.4046 0.4573 0.4178 0.4578 0.4138 0.4695 0.4207 0.4638 0.4152 0.4589 0.4021 0.4586 0.4060 27H 2700 K Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered of Cree, Inc. trademarks of Cree, Inc. 13 xlamp xm-l2 easywhite leds Performance Groups - Chromaticity (Tj = 85 °C) - Continued ANSI White Bins Code CCT Bin Code 1A0 1B0 0E1 6500 K 1C0 1D0 ANSI White Bins x y 0.3048 0.3207 0.3130 0.3290 0.3144 0.3186 Code Bin Code CCT 2A0 x y 0.3215 0.3350 0.3290 0.3417 0.3290 0.3300 0.3068 0.3113 0.3222 0.3243 0.3028 0.3304 0.3207 0.3462 0.3115 0.3391 0.3290 0.3538 0.3130 0.3290 0.3290 0.3417 0.3048 0.3207 0.3115 0.3391 0.3205 0.3481 0.3213 0.3373 2B0 0E2 5700 K 2C0 0.3215 0.3350 0.3290 0.3538 0.3376 0.3616 0.3371 0.3490 0.3130 0.3290 0.3290 0.3417 0.3130 0.3290 0.3290 0.3417 0.3213 0.3373 0.3371 0.3490 0.3221 0.3261 0.3366 0.3369 0.3144 0.3186 0.3290 0.3300 2D0 Cree EasyWhite Bins Plotted on the 1931 CIE Color Space (TJ = 85 °C) 0.45 ANSI C78.377 Quadrangle EasyWhite 4-step EasyWhite 2-step 0.44 2700K 3000K 0.43 3500K 0.42 4000K 0.41 4500K 0.40 5000K CCy 0.39 5700K 0.38 0.37 0.36 0.35 0.34 0.33 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.32 CCx Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered of Cree, Inc. trademarks of Cree, Inc. 14 xlamp xm-l2 easywhite leds Cree’s Standard Cool White Kits Plotted on ANSI Standard Chromaticity Regions 0.40 5000K 0.39 0.38 5700K E2 0.37 3S 6500K 0.36 2T E1 0.35 2C 1T CCy 8000K 3A 2B 0.34 1S 0T 0.33 0S 0.32 3B 2S 0B 0.31 1D 2U ANSI C78.377A 2R 1A 1U 0D 0A 3R 2A 1B 0C 2D 1C 1R 0U 0.30 0R 0.29 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.28 CCx Cree ANSI White Bins Plotted on the 1931 CIE Color Space (TJ = 85 °C) 0.40 0.39 ANSI C76.377 Quadrangle 0.38 0.37 5700K CCy 0.36 0.35 6500K 2B 0.34 0.33 0.32 2C 1C 1B 1D 2D 2A 1A 0.31 0.30 0.28 0.29 0.30 0.31 0.32 0.33 0.34 0.35 0.36 CCx Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered of Cree, Inc. trademarks of Cree, Inc. 15 xlamp xm-l2 easywhite leds Bin and Order Code Format Bin codes and order codes are configured as follows: Order Code Bin Code SSSCCC-BB-HHHH-NNNNNNNNN Series XML = XM-L Series XML = XM-L Internal code Internal code Internal code Flux bin Kit code Internal code Vf class: B = 6-V class D = 12-V class SSSCCC-B-WWW-FFF-GAAAAAA Vf class: B = 6-V class D = 12-V class Reel size 0 = 1000 (standard) Chromaticity bin Color BEZ = XM-L2 EasyWhite Color BEZ = XM-L2 EasyWhite Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered of Cree, Inc. trademarks of Cree, Inc. 16 xlamp xm-l2 easywhite leds Reflow Soldering Characteristics In testing, Cree has found XLamp XM-L2 LEDs to be compatible with JEDEC J-STD-020C, using the parameters listed below. As a general guideline, Cree recommends that users follow the recommended soldering profile provided by the manufacturer of solder paste used. Note that this general guideline may not apply to all PCB designs and configurations of reflow soldering equipment. Profile Feature Lead-Based Solder Lead-Free Solder 3 °C/second max. 3 °C/second max. Preheat: Temperature Min (Tsmin) 100 °C 150 °C Preheat: Temperature Max (Tsmax) 150 °C 200 °C 60-120 seconds 60-180 seconds 183 °C 217 °C 60-150 seconds 60-150 seconds 215 °C 260 °C 10-30 seconds 20-40 seconds 6 °C/second max. 6 °C/second max. 6 minutes max. 8 minutes max. Average Ramp-Up Rate (Tsmax to Tp) Preheat: Time (tsmin to tsmax) Time Maintained Above: Temperature (TL) Time Maintained Above: Time (tL) Peak/Classification Temperature (Tp) Time Within 5 °C of Actual Peak Temperature (tp) Ramp-Down Rate Time 25 °C to Peak Temperature Note: All temperatures refer to the topside of the package, measured on the package body surface. Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered of Cree, Inc. trademarks of Cree, Inc. 17 xlamp xm-l2 easywhite leds Notes Lumen Maintenance Projections Cree now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document at www.cree.com/xlamp_app_notes/LM80_results. Please consult the XLamp Long-Term Lumen Maintenance application note at www.cree.com/xlamp_app_notes/lumen_ maintenance for more details on Cree’s lumen maintenance testing and forecasting. Please read the XLamp Thermal Management application note at www.cree.com/xlamp_app_notes/thermal_management for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. Moisture Sensitivity In testing, Cree has found XLamp XM-L2 LEDs to have unlimited floor life in conditions ≤30 ºC/85% relative humidity (RH). Moisture testing included a 168-hour soak at 85 ºC/85% RH followed by 3 reflow cycles, with visual and electrical inspections at each stage. Cree recommends keeping XLamp LEDs in their sealed moisture-barrier packaging until immediately prior to use. Cree also recommends returning any unused LEDs to the resealable moisture-barrier bag and closing the bag immediately after use. Vision Advisory Claim WARNING. Do not look at exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the Cree LED Eye Safety application note at www.cree.com/xlamp_app_notes/led_eye_safety. Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered of Cree, Inc. trademarks of Cree, Inc. 18 4.8 C xlamp xm-l2 easywhite leds 2.26 Mechanical Dimensions 4.7 3.9 All measurements are ±.13 mm unless otherwise indicated. 6 6 5 B 4 NOTICE CREE CONFIDENTIAL. THIS PLOT AND THE INFORMATION CONTAINED WITHIN ARE THE PROPRIETARY AND 6 CONFIDENTIAL INFORMATION OF CREE, INC. 5 THIS PLOT MAY NOT BE COPIED, REPRODUCED OR DISCLOSED TO ANY NOTICE 4.7 UNAUTHORIZED PERSON WITHOUT THE WRITTEN CONSENT CREE CONFIDENTIAL. THIS PLOT AND THE INFORMATION OF CREE INC. 3 REV 4 3 2 B REV CONTAINED WITHIN ARE THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF CREE, INC. THIS PLOT MAY NOT BE COPIED, REPRODUCED OR DISCLOSED TO ANY UNAUTHORIZED PERSON WITHOUTTHE WRITTEN CONSENT OF CREE INC. Anode D A RECOMMENDED STENCIL PATTERN SHADED AREA IS OPEN 5.00 THIRD ANGLE PROJECTION A NEW RELEASE B ADDED CHIPS AND FLASH DIMENSION C REMOVED TRACES D ADDED SOLDERMASK E ADDED DOME RADIUS 3.8 D E 2.8 FOR SHEET METAL PARTS ONLY .X ± 1.5 .XX ± .75 .XXX ± .25 X° ± .5 ° 3.8 3.02 DATE DRAWN BY D. CRONIN 0.73 DATE -- -- 3 A OUTLINE DRAWING, 5050 XM 4 X 1000 WZ1000 SIZE FINAL PROTECTIVE FINISH -- Fax (919) 313-5558 TITLE MATERIAL -- 0.5 Phone (919) 313-5300 -- APPROVED 0.5 4600 Silicon Drive Durham, N.C 27703 DATE -- 0.5 2.8 0.73 3.02 11/10/10 CHECK SURFACE FINISH: 1.6 5.00 4 UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS AND AFTER FINISH. TOLERANCE UNLESS SPECIFIED: .XX ± .25 .XXX ± .125 X° ± .5 ° ADDED C D 5.00 REVISONS DESCRIPTION SCALE C REV. DRAWING NO. 2610-00012 E SHEET 16.000 2 0.5 OF 1 /1 1 5.00 4.8 C C R2.26 R2.26 Anode Top View 4.8 4.8 0.5 0.5 4.7 3.9 4.7 3.9 3.8 3.8 Bottom View Side View 0.6 0.6 B B 0.5 0.5 0.4 0.4 A RECOMMENDED PCB SOLDER PAD Recommended 4.7 0.4 0.4 2.8 4.7 0.4 4.8 0.4 0.5 2.8 A 0.4 4.8 0.5 0.4 UNLESS OTHERWISE SPECIFIED PCB Solder Pad RECOMMENDED STENCIL PATTERN DIMENSIONS ARE IN MILLIMETERS AND AFTER FINISH. STENCIL PATTERN SHADED AREA ISRECOMMENDED OPEN Recommended Stencil Pattern D. CRONIN 11/10/10 UNLESSDATE OTHERWISE SPECIFIED DIMENSIONS ARE IN --MILLIMETERS--AND AFTER FINISH. TOLERANCE UNLESS SPECIFIED: SHADED AREA IS OPEN .XX ± .25 DATE APPROVED TOLERANCE UNLESSTITLE SPECIFIED: .XXX ± .125 --- ± .XX .25 X° ± .5 ° THIRD ANGLE PROJECTION .XXX ± .125 FOR SHEET METAL PARTS ONLY MATERIAL X° ± .5 ° THIRD PROJECTION .X ANGLE ± 1.5 SIZE FOR SHEET METAL PARTS ONLY -.XX ± .75 .XXX ± .25 FINAL PROTECTIVE FINISH .X ± 1.5 X° ± .5 ° .XX ± .75 ± SCALE .25 16.000 SURFACE FINISH: 1.6 -- .XXX X° ± .5 ° (Shaded Area Is Open) RECOMMENDED PCB SOLDER PAD DATE DRAWN BY CHECK 5 6 4 5 3 4 D. CR OUTLINE D 4X C 6 DRAWN CHECK 2 SURFACE FINISH: 1.6 3 Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered of Cree, Inc. trademarks of Cree, Inc. 19 APPROV MATERIA DRAWING FINAL PRO 6 5 4 3 REVISIONS 4.00[.157] DESCRIPTION REV BY DATE APP'D POCKET SIZE D 2.00[.079] 1 2 NOTICE CREE CONFIDENTIAL. THIS PLOT AND THE INFORMATION CONTAINED WITHIN ARE THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF CREE, INC. THIS PLOT MAY NOT BE COPIED, REPRODUCED OR DISCLOSED TO ANY UNAUTHORIZED PERSON WITHOUT THE WRITTEN CONSENT OF CREE INC. Do1.50 P2 +.10 +.0039 .0591 -.00 -.0000 [ ] 1.75[.069] E1 Po Tape and Reel Ao - 5.40mm [.213"] Bo - 5.40mm [.213"] Ko - 3.35mm [.132"] 3.0° xlamp xm-l2 easywhite leds D 5.40[.213] Bo 6 5 4 All Cree carrier tapes conform to EIA-481D, Automated Component Handling Systems3 Standard. 12.00[.472] 6 5 4 3 5.50[.217]F C NOMINAL OF CREE INC. D D 10.25 [.404] E2 1.50[.059] 4.00[.157] D1 4.00[.157] Po 8.00[.315] P REV 12.30 [.484] MAX W 2.00[.079] 2.00[.079] P2 2 REV B 6 5 C NOTICE TIAL. THIS PLOT AND THE INFORMATION HIN ARE THE PROPRIETARY AND NFORMATION OF CREE, INC. THIS PLOT PIED, REPRODUCED OR DISCLOSED TO ANY PERSON WITHOUTTHE WRITTEN CONSENT A Ao B 3.0° 2 B D C BY DATE DDS 11/8/10 DC 2/26/12 B BS MATERIAL SIZE FINAL PROTECTIVE FINISH Direction 6 6 2402-00011 7.0° 2 4 Leader 400mm (min.) of empty pockets with at least 100mm sealed by tape 5 pockets min.) (40 empty 5 A SHEET 7.0° OF B 1 3 2 1 2400-00009 CREE REFERENCE DRAWING FOR TEK-PAK DRAWING 018275 CREE REFERENCE DRAWING FOR TEK-PAK DRAWING 018275 12 INDEX QTY ITEM COMMENTS 1 1 2400-00009-CORE DRAWN BY C DATE UNLESS OTHERWISE SPECIFIED DATE DRAWN BY 2 SPECIFIED 2 D. CRONIN 2400-00009-REEL 4/23/10 UNLESS ARE OTHERWISE DIMENSIONS IN INCHES D. CRONIN 4/23/10 DATE DIMENSIONS ARE IN INCHESCHECK AND AFTER FINISH. CHECK DATE AND AFTERSPECIFIED: FINISH. TOLERANCE UNLESS TOLERANCE .XX ± UNLESS .01 SPECIFIED: APPROVED DATE TITLE ± .01 .XXX .XX ± .005 APPROVED DATE TITLE X° ±.XXX .5± ° .005 THIRD ANGLE PROJECTION MATERIAL X° PARTS ± .5 ° FOR SHEET METAL ONLY THIRD ANGLE PROJECTION MATERIAL FOR.XSHEET ± METAL .06 PARTS ONLY DRAWING NO. SIZE .XX .X ± ±.03 .06 DRAWING NO. SIZE FINAL PROTECTIVE FINISH ± .03 .XXX .XX ± .010 FINAL PROTECTIVE FINISH X° ±.XXX .5± ° .010 SCALE X° ± .5 ° SURFACE FINISH: 63 SCALE DRAWING SCALE SURFACE FINISH: 63 DRAWING SCALE 4600 Silicon Drive Durham, N.C 27703 4600 Silicon Drive Durham, N.C 27703 Phone (919) 313-5300 Phone (919) 313-5300 Fax (919) 313-5558 Fax (919) 313-5558 XMXM 5050 CARRIER TAPE 5050 CARRIER TAPE D 2402-00011 A 2402-00011 A A 4 3 4 2 3 2 SHEET OF SHEET 1 1OF / 1 1 12.4 +.2 .0 MEASURED AT HUB C 330 +.25 -.75 16.4 +0.2 .0 MEASURED AT HUB THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS AND AFTER FINISH. TOLERANCE UNLESS SPECIFIED: .XX ± .25 .XXX ± .125 X° ± .5 ° FOR SHEET METAL PARTS ONLY .X ± 1.5 .XX ± .75 .XXX ± .25 X° ± .5 ° SURFACE FINISH: 5 4 1.6 3 1.9±.4 DATE DRAWN BY D. CRONIN CHECK 21 ±.4 4600 Silicon Drive Durham, N.C 27703 06/08/10 DATE -- Phone (919) 313-5300 -- Fax (919) 313-5558 A DATE APPROVED -- -- MATERIAL TITLE 13.1 ±.2 -- SIZE FINAL PROTECTIVE FINISH -- SCALE XM LOADING SPEC REV. DRAWING NO. C 2402-00012 SHEET 3.000 2 B OF B 1 /1 1 12.4 +1.0 -.5 MEASURED AT EDGE 60° 60° REVISONS REV A DESCRIPTION BY DATE APP'D Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered of Cree, Inc. UNLESS OTHERWISE SPECIFIED 4600 Silicon Drive D. CRONIN 09/29/09 trademarks of Cree, Inc. DIMENSIONS ARE IN INCHES Durham, N.C 27703 THIRD ANGLE PROJECTION AND AFTER FINISH. TOLERANCE UNLESS SPECIFIED: .XX ± .01 .XXX ± .005 X° ± .5 ° FOR SHEET METAL PARTS ONLY DRAWN BY DATE CHECK DATE -APPROVED -MATERIAL 20 Phone (919) 313-5300 -- Fax (919) 313-5558 DATE -- A REV. B C B 1 /1 3.35 1.75 3.35[.132] 3.35[.132] Ko Ko START Ao REV. DRAWING NO. DRAWING SCALE ANODE SIDE A A SCALE D .36[.014] T .36[.014] T A XM 5050 CARRIER TAPE 5.40[.213] 5.40[.213] Ao Loaded Pockets (1000 Lamps) 1.50[.059] Phone (919) 313-5300 Fax (919) 313-5558 D1 1.50[.059] D1 8.00[.315] DATE 8.00[.315] P TITLE P CATHODE SIDE 4 5 4600 Silicon Drive Durham, N.C 27703 4/23/10 DATE APPROVED FOR SHEET METAL PARTS ONLY .X ± .06 .XX ± .03 .XXX ± .010 X° ± .5 ° 8 6 D. CRONIN CHECK 3 A B C APP'D DATE DRAWN BY UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN INCHES AND AFTER FINISH. TOLERANCE UNLESS SPECIFIED: .XX ± .01 .XXX ± .005 X° ± .5 ° NOTICE CREE CONFIDENTIAL. THIS PLOT AND THE INFORMATION CONTANED WITHIN ARE THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF CREE, INC. THIS PLOT MAY NOT BE COPIED, REPRODUCED OR DISCLOSED TO ANY UNAUTHORIZED PERSON WITHOUT THE WRITTEN CONSENT OF CREE INC. 6 D 5.40[.213] 5.40[.213] Bo Bo 3.0° 1 DESCRIPTION A 4 Trailer 160mm (min) of empty pockets sealed with tape (15 pockets min.) 12.00[.472] 12.00[.472] NOMINAL REVISONS NOMINAL 10.25 12.30 [.484] 12.30 [.484] 10.25 Loaded pocket count was 750 MAX [.404] [.404] W MAX MADE CATHODE AND ANODE NOTE LARGER E2 W E2 REV 63 SURFACE FINISH: User Feed 5 D 5.50[.217]F 5.50[.217]F APP'D DATE APP'D CREE REFERENCE DRAWING FOR TEK-PAK DRAWING 018275 THIRD ANGLE PROJECTION END 3 3.35[.132] Ko 5.40[.213] 6 4 C 1 DATE All dimensions in mm. B 7.0° BY BoBo - - 5.40mm [.213"] 5.40mm [.213"] KoKo - - 3.35mm [.132"] 3.35mm [.132"] 1.75[.069] E1 1.75[.069] E1 .36[.014] T Po BY POCKET SIZE POCKET SIZE AoAo - - 5.40mm [.213"] 5.40mm [.213"] +.10 +.0039 Do1.50 .0591 +.0039 -.00 +.10 .0591 -.0000 [] Do1.50 -.00 -.0000 [ ] P2 1 2 REVISIONS REVISIONS DESCRIPTION DESCRIPTION C NOTICE CREE CONFIDENTIAL. THIS PLOT AND THE INFORMATION NOTICE CONTAINED WITHIN ARE THETHIS PROPRIETARY ANDINFORMATION CREE CONFIDENTIAL. PLOT AND THE CONFIDENTIAL INFORMATION CREE, INC. THIS PLOT CONTAINED WITHIN AREOF THE PROPRIETARY AND MAY NOT BE COPIED, INFORMATION REPRODUCEDOF ORCREE, DISCLOSED TO PLOT ANY CONFIDENTIAL INC. THIS UNAUTHORIZED PERSON WITHOUT THE WRITTEN CONSENT MAY NOT BE COPIED, REPRODUCED OR DISCLOSED TO ANY OF CREE INC. UNAUTHORIZED PERSON WITHOUT THE WRITTEN CONSENT TITLE REEL, 13" X 12MM, 3 PIECE SNAP A REV. A 1 /1 A xlamp xm-l2 easywhite leds Humidity Indicator Card (inside bag) Packaging Dessicant (inside bag) Unpackaged Reel Label with Cree Bin Code, Qty, Reel ID Packaged Reel Label with Cree Bin Code, Qty, Lot # Vacuum-Sealed Moisture Barrier Bag Label with Cree Order Code, Qty, Reel ID, PO # Label with Cree Bin Code, Qty, Reel ID Label with Custo Code, Qty, Reel I Boxed Reel Label with Cree Order Code, Qty, Reel ID, PO # Patent Label Label with Cree Bin Code, Qty, Reel ID Patent Label Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered of Cree, Inc. trademarks of Cree, Inc. 21
XMLBEZ-02-0000-0D00V340F 价格&库存
很抱歉,暂时无法提供与“XMLBEZ-02-0000-0D00V340F”相匹配的价格&库存,您可以联系我们找货
